commit db79afa1e57925ba96ab18514c0ebe42a28e393e upstream.
A number of radeon cards have a HW limitation causing them to be
unable to generate the full 64-bit of address bits for MSIs. This
breaks MSIs on some platforms such as POWER machines.
We used to have a powerpc specific quirk to address that on a
single card, but this doesn't scale very well, this is better
put under control of the drivers who know precisely what a given
HW revision can do.
We now have a generic quirk in the PCI code. We should set it
appropriately for all radeon's from the audio driver.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 911f632c701d9f15a54076cbaca82e7defb339e0 upstream.
The machine originally use the quirk ALC269_FIXUP_HP_GPIO_MIC1_LED,
but the LED doesn't work at all.
After this change, the machine will change to use
ALC269_FIXUP_HP_MUTE_LED_MIC1 through pin_fixup_tbl[], and the LED
works well.
BugLink: https://bugs.launchpad.net/bugs/1389497
Tested-by: TieFu Chen <tienfu.chen@canonical.com>
Cc: Kailang Yang <kailang@realtek.com>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 413cbf469a19e7662ba5025695bf5a573927105a upstream.
AMD/ATI HDMI controller chip models, we already have a filter to lower
to 32bit DMA, but the rest are supposed to be working with 64bit
although the hardware doesn't really work with 63bit but only with 40
or 48bit DMA. In this patch, we take 40bit DMA for safety for the
AMD/ATI controllers as the graphics drivers does.
commit 6e84a8d7ac3ba246ef44e313e92bc16a1da1b04a upstream.
This patch adds a USB control message delay quirk for a few specific Marantz/Denon
devices. Without the delay the DACs will not work properly and produces the
following type of messages:
Nov 15 10:09:21 orwell kernel: [ 91.342880] usb 3-13: clock source 41 is not valid, cannot use
Nov 15 10:09:21 orwell kernel: [ 91.343775] usb 3-13: clock source 41 is not valid, cannot use
There are likely other Marantz/Denon devices using the same USB module which exhibit the
same problems. But as this cannot be verified I limited the patch to the devices
I could test.
The following two devices are covered by this path:
- Marantz SA-14S1
- Marantz HD-DAC1
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
commit 2cb1e0259f50c7be88eb277c7442fa74a3ce7c57 upstream.
In commit a1253ef6d3fa ("ASoC: cs42l51: split i2c from codec driver"),
the I2C part of the CS42L51 was moved to a separate file, but the
definition of the of_device_id array was left in the driver file
itself, no longer connected to the platform_driver structure using the
.of_match_table pointer.
This commit exports the of_device_id array in cs42l51, and uses it as
.of_match_able in cs42l51-i2c.c. This solution was suggested by Brian
Austin.
Fixes: a1253ef6d3fa ("ASoC: cs42l51: split i2c from codec driver")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Brian Austin <brian.austin@cirrus.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit ac87f22147098da9cf83a0b413ef7dda42277d85 upstream.
The patch corrects the incorrect default register values.
Signed-off-by: Bard Liao <bardliao@realtek.com>
commit ea9d0d771fcd32cd56070819749477d511ec9117 upstream.
DPCM can update the FE/BE connection states totally asynchronously
from the FE's PCM state. Most of FE/BE state changes are protected by
mutex, so that they won't race, but there are still some actions that
are uncovered. For example, suppose to switch a BE while a FE's
stream is running. This would call soc_dpcm_runtime_update(), which
sets FE's runtime_update flag, then sets up and starts BEs, and clears
FE's runtime_update flag again.
When a device emits XRUN during this operation, the PCM core triggers
snd_pcm_stop(XRUN). Since the trigger action is an atomic ops, this
isn't blocked by the mutex, thus it kicks off DPCM's trigger action.
It eventually updates and clears FE's runtime_update flag while
soc_dpcm_runtime_update() is running concurrently, and it results in
confusion.
Usually, for avoiding such a race, we take a lock. There is a PCM
stream lock for that purpose. However, as already mentioned, the
trigger action is atomic, and we can't take the lock for the whole
soc_dpcm_runtime_update() or other operations that include the lengthy
jobs like hw_params or prepare.
This patch provides an alternative solution. This adds a way to defer
the conflicting trigger callback to be executed at the end of FE/BE
state changes. For doing it, two things are introduced:
- Each runtime_update state change of FEs is protected via PCM stream
lock.
- The FE's trigger callback checks the runtime_update flag. If it's
not set, the trigger action is executed there. If set, mark the
pending trigger action and returns immediately.
- At the exit of runtime_update state change, it checks whether the
pending trigger is present. If yes, it executes the trigger action
at this point.
Reported-and-tested-by: Qiao Zhou <zhouqiao@marvell.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
commit 9da7a5a9fdeeb76b2243f6b473363a7e6147ab6f upstream.
We should not free any buffers associated with writing out coefficients
to the DSP until all the async writes have completed. This patch updates
the out of memory path when allocating a new buffer to include a call to
regmap_async_complete.
Reported-by: JS Park <aitdark.park@samsung.com>
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
commit 29f95bd76f6ec1eff88eec6a04191104a11a7f97 upstream.
We can get into an infinite loop if the I2S_CLR register fails to
clear due to a missing break statement, so add that.
Signed-off-by: Jianqun <jay.xu@rock-chips.com>
commit 62e6a3b6f4e1f9b96fa66ab1cdf2ffd8594df9e9 upstream.
This enables the snd_soc_snow module to be auto-loaded.
Signed-off-by: Andreas Färber <afaerber@suse.de>
commit c251ea7bd7a04f1f2575467e0de76e803cf59149 upstream.
On a mx28evk with a sgtl5000 codec we notice a loud 'click' sound to happen
5 seconds after the end of a playback.
The SMALL_POP bit should fix this, but its definition is incorrect:
according to the sgtl5000 manual it is bit 0 of CHIP_REF_CTRL register, not
bit 1.
Fix the definition accordingly and enable the bit as intended per the code
comment.
After applying this change, no loud 'click' sound is heard after playback
commit c1b9b9b1ad2df6144ca3fbe6989f7bd9ea5c5562 upstream.
FSI doesn't support PAUSE.
Remove SNDRV_PCM_INFO_PAUSE flags from snd_pcm_hardware info
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
commit 706c66213e5e623e23f521b1acbd8171af7a3549 upstream.
R-Car sound doesn't support PAUSE.
commit 1a290581ded60e87276741f8ca97b161d2b226fc upstream.
M-audio FastTrack Ultra quirk doesn't release the kzalloc'ed memory.
This patch adds the private_free callback to release it properly.
commit 3542aed7480925eb859f7ce101982209cc19a126 upstream.
Lenovo Ideapad Z560 has a mute LED that is controlled via EAPD pin
0x1b on CX20585 codec. (EAPD bit on corresponds to mute LED on.)
The machine doesn't need other EAPD, so the fixup concentrates on
controlling EAPD 0x1b following the vmaster state (but inversely).
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=665315
Reported-by: Szymon Kowalczyk <fazerxlo@o2.pl>
commit c922c4e87b9b5a3b50d4d17b96f189121430f511 upstream.
Without the fix, the mute led can't work on these three machines.
After apply this fix, these three machines will fall back on the led
control quirk as below, and through testing, the mute led works very
well.
PIN_QUIRK(0x10ec0282, 0x103c, "HP", ALC269_FIXUP_HP_LINE1_MIC1_LED,
ALC282_STANDARD_PINS,
{0x12, 0x90a60140},
commit 0725dda207e95ff25f1aa01432250323e0ec49d6 upstream.
Some USB-audio devices show weird sysfs warnings at disconnecting the
devices, e.g.
usb 1-3: USB disconnect, device number 3
WARNING: CPU: 0 PID: 973 at fs/sysfs/group.c:216 device_del+0x39/0x180()
sysfs group ffffffff8183df40 not found for kobject 'midiC1D0'
Call Trace:
[<ffffffff814a3e38>] ? dump_stack+0x49/0x71
[<ffffffff8103cb72>] ? warn_slowpath_common+0x82/0xb0
[<ffffffff8103cc55>] ? warn_slowpath_fmt+0x45/0x50
[<ffffffff813521e9>] ? device_del+0x39/0x180
[<ffffffff81352339>] ? device_unregister+0x9/0x20
[<ffffffff81352384>] ? device_destroy+0x34/0x40
[<ffffffffa00ba29f>] ? snd_unregister_device+0x7f/0xd0 [snd]
[<ffffffffa025124e>] ? snd_rawmidi_dev_disconnect+0xce/0x100 [snd_rawmidi]
[<ffffffffa00c0192>] ? snd_device_disconnect+0x62/0x90 [snd]
[<ffffffffa00c025c>] ? snd_device_disconnect_all+0x3c/0x60 [snd]
[<ffffffffa00bb574>] ? snd_card_disconnect+0x124/0x1a0 [snd]
[<ffffffffa02e54e8>] ? usb_audio_disconnect+0x88/0x1c0 [snd_usb_audio]
[<ffffffffa015260e>] ? usb_unbind_interface+0x5e/0x1b0 [usbcore]
[<ffffffff813553e9>] ? __device_release_driver+0x79/0xf0
[<ffffffff81355485>] ? device_release_driver+0x25/0x40
[<ffffffff81354e11>] ? bus_remove_device+0xf1/0x130
[<ffffffff813522b9>] ? device_del+0x109/0x180
[<ffffffffa01501d5>] ? usb_disable_device+0x95/0x1f0 [usbcore]
[<ffffffffa014634f>] ? usb_disconnect+0x8f/0x190 [usbcore]
[<ffffffffa0149179>] ? hub_thread+0x539/0x13a0 [usbcore]
[<ffffffff810669f5>] ? sched_clock_local+0x15/0x80
[<ffffffff81066c98>] ? sched_clock_cpu+0xb8/0xd0
[<ffffffff81070730>] ? bit_waitqueue+0xb0/0xb0
[<ffffffffa0148c40>] ? usb_port_resume+0x430/0x430 [usbcore]
[<ffffffff8105973e>] ? kthread+0xce/0xf0
[<ffffffff81059670>] ? kthread_create_on_node+0x1c0/0x1c0
[<ffffffff814a8b7c>] ? ret_from_fork+0x7c/0xb0
---[ end trace 40b1928d1136b91e ]---
This comes from the fact that usb-audio driver may receive the
disconnect callback multiple times, per each usb interface. When a
device has both audio and midi interfaces, it gets called twice, and
currently the driver tries to release resources at the last call.
At this point, the first parent interface has been already deleted,
thus deleting a child of the first parent hits such a warning.
For fixing this problem, we need to call snd_card_disconnect() and
cancel pending operations at the very first disconnect while the
release of the whole objects waits until the last disconnect call.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=80931
Reported-and-tested-by: Tomas Gayoso <tgayoso@gmail.com>
Reported-and-tested-by: Chris J Arges <chris.j.arges@canonical.com>
commit 317168d0c766defd14b3d0e9c2c4a9a258b803ee upstream.
In compat mode, we copy each field of snd_pcm_status struct but don't
touch the reserved fields, and this leaves uninitialized values
there. Meanwhile the native ioctl does zero-clear the whole
structure, so we should follow the same rule in compat mode, too.
Reported-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
commit d1d0b6b668818571122d30d68a0b3f768bd83a52 upstream.
snd_bebob_stream_check_internal_clock() may get an id from
saffirepro_both_clk_src_get (via clk_src->get()) that was uninitialized.
a) make logic in saffirepro_both_clk_src_get explicit
b) test if id used in snd_bebob_stream_check_internal_clock matches array size
[fixed missing signed prefix to *_maps[] by tiwai]
Signed-off-by: Christian Vogel <vogelchr@vogel.cx>
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 3b70bdba2fcb374a2235a56ab73334348d819579 upstream.
CMI8888 shows the stuttering playback when the snooping is disabled
on the audio buffer. Meanwhile, we've got reports that CORB/RIRB
doesn't work in the snooped mode. So, as a compromise, disable the
snoop only for CORB/RIRB and enable the snoop for the stream buffers.
The resultant patch became a bit ugly, unfortunately, but we still can
live with it.
Reported-and-tested-by: Geoffrey McRae <geoff@spacevs.com>
commit 3b283f0893f55cb79e4507e5ec34e49c17d0a787 upstream.
For the input PGA to work correctly the ALC clock needs to be active.
Otherwise volume changes are not applied.
Fixes: dab464b60b2 ("ASoC: Add ADAU1361/ADAU1761 audio CODEC support")
commit 2ccf3bd4f8b120936cdfc796baf40c5d3dfab68d upstream.
Fix driver with correct formats.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
commit 31d9f8faf9a54c851e835af489c82f45105a442f upstream.
Current caching implementation during regcache_sync() call bypasses
all register writes of values that are already known as default
(regmap reg_defaults). Same time in TLV320AIC3x codecs register 5
(AIC3X_PLL_PROGC_REG) write should be immediately followed by register
6 write (AIC3X_PLL_PROGD_REG) even if it was not changed. Otherwise
both registers will not be written.
This brings to issue that appears particulary in case of 44.1kHz
playback with 19.2MHz master clock. In this case AIC3X_PLL_PROGC_REG
is 0x6e while AIC3X_PLL_PROGD_REG is 0x0 (same as register
default). Thus AIC3X_PLL_PROGC_REG also remains not written and we get
wrong playback speed.
In this patch snd_soc_read() is used to get cached pll values and
snd_soc_write() (unlike regcache_sync() this function doesn't bypasses
hardware default values) to write them to registers.
Signed-off-by: Dmitry Lavnikevich <d.lavnikevich@sam-solutions.com>
commit 5e63dfccf34d4dbf21429c4919f33c028ff49991 upstream.
In the SNDRV_PCM_STREAM_CAPTURE branch in soc_pcm_apply_msb(), look at
sig_bits of the capture stream, not the playback one.
Spotted by coverity.
Signed-off-by: Daniel Mack <daniel@zonque.org>
commit e5092c96c9c28f4d12811edcd02ca8eec16e748e upstream.
Coverity spotted the following possible use-after-free condition in
dapm_create_or_share_mixmux_kcontrol():
If kcontrol is NULL, and (wname_in_long_name && kcname_in_long_name)
validates to true, 'name' will be set to an allocated string, and be
freed a few lines later via the 'long_name' alias. 'name', however,
is used by dev_err() in case snd_ctl_add() fails.
Fix this by adding a jump label that frees 'long_name' at the end of
the function.
commit decc27b01d584c985c231e73d3b493de6ec07af8 upstream.
Coverity spotted an use-after-free condition in snd_soc_remove_platform().
Fix this by moving snd_soc_component_cleanup() after the debug print
statement which uses the component's string.
commit fb54a645b2739fb196446ffbbbe3f3589d117b55 upstream.
Without this terminating entry, the pin matching would continue
across random memory until a zero or a non-matching entry was found.
The result being that in some cases, the pin quirk would not be
applied correctly.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit b1974f965a506c131b60cd3e483340884e831920 upstream.
We implemented in a wrong way for mute LED on Lenovo Ideapad; the bit
must be flipped.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16373
Fixes: 3e887f379d8a ('ALSA: hda - Add mute LED support to Lenovo Ideapad')
commit 6acce400d9daf1353fbf497302670c90a3205e1d upstream.
The ELD ALSA control change event is sent by hdmi_present_sense() when
eld_changed is true.
Currently, it is only true when the ELD buffer contents have been
modified. However, the user-visible ELD controls also change to a
zero-length value and back when eld_valid is unset/set, and no event is
currently sent in such cases (such as when unplugging or replugging a
sink).
Fix the code to always set eld_changed if eld_valid value is changed,
and therefore to always send the change event when the user-visible
value changes.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
Cc: David Henningsson <david.henningsson@canonical.com>
commit f0b127fbfdc8756eba7437ab668f3169280bd358 upstream.
Adding support for Steinberg UR22 USB interface via quirks table patch
See Ubuntu bug report:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1317244
Also see threads:
http://linux-audio.4202.n7.nabble.com/Support-for-Steinberg-UR22-Yamaha-USB-chipset-0499-1509-tc82888.html#a82917
http://www.steinberg.net/forums/viewtopic.php?t=62290
Tested by at least 4 people judging by the threads.
Did not test MIDI interface, but audio output and capture both are
functional. Built 3.17 kernel with this driver on Ubuntu 14.04 & tested with mpg123
Patch applied to 3.13 Ubuntu kernel works well enough for daily use.
Signed-off-by: Vlad Catoi <vladcatoi@gmail.com>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit b450b17c156e264bc44a198046d3ebaaef5a041d upstream.
This patch sets the headphones mode to default before suspending
which helps avoid the pop noise on headphones
Signed-off-by: Harsha Priya <harshapriya.n@intel.com>
commit 95926035b187cc9fee6fb61385b7da9c28123f74 upstream.
The emu10k1 voice allocator takes voice_lock spinlock. When there is
no empty stream available, it tries to release a voice used by synth,
and calls get_synth_voice. The callback function,
snd_emu10k1_synth_get_voice(), however, also takes the voice_lock,
thus it deadlocks.
The fix is simply removing the voice_lock holds in
snd_emu10k1_synth_get_voice(), as this is always called in the
spinlock context.
Reported-and-tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
commit 3f4032861cfbff0b9134bf94c5c92e2146d1f068 upstream.
This patch fixes a failure to open PCM device with -ENOSYS in
Terratec Phase 88.
Terratec Phase 88 has two Selector Function Blocks of AVC Audio subunit
to switch source of clock. One is to switch internal/external for the
source and another is to switch word/spdif for the external clock.
The IDs for these Selector Function Blocks are 9 and 8. But in current
implementation they're 0 and 0.
Reported-by: András Murányi <muranyia@gmail.com>
Tested-by: András Murányi <muranyia@gmail.com>
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit a011e213f3700233ed2a676f1ef0a74a052d7162 upstream.
This avoids following kernel crash when try to playback on arm64
[ 107.497203] [<ffffffc00046b310>] snd_pcm_mmap_data_fault+0x90/0xd4
[ 107.503405] [<ffffffc0001541ac>] __do_fault+0xb0/0x498
[ 107.508565] [<ffffffc0001576a0>] handle_mm_fault+0x224/0x7b0
[ 107.514246] [<ffffffc000092640>] do_page_fault+0x11c/0x310
[ 107.519738] [<ffffffc000081100>] do_mem_abort+0x38/0x98
Tested: backported to 3.14 and tried to playback on arm64 machine
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fix SSM2602 device identification
Another fix for v3.17, fixing device identification after the split out
of the I2C and SPI code.
The correct type (SSM2602/SSM2603/SSM2604) is passed down
from the ssm2602_spi_probe()/ssm2602_spi_probe() functions,
so use that instead of hardcoding it to SSM2602 in
ssm2602_probe().
Fixes: c924dc68f737 ("ASoC: ssm2602: Split SPI and I2C code into different modules")
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: stable@vger.kernel.org
ASoC: Fixes for v3.17
A few small driver specific fixes and a couple of error handling fixes
in the core.
'asoc/fix/core', 'asoc/fix/fsl-ssi' and 'asoc/fix/rt286' into asoc-linus
Since we cannot make sure the 'params->num_regs' will always be none
zero here, and then if it equals to zero, the kmemdup() will return
ZERO_SIZE_PTR, which equals to ((void *)16).
So this patch fix this with just doing the zero check before calling
kmemdup().
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
We try to write index registers into cache when we write an index
register, but we change the reg value before updating the cache.
As a result, the cache is never be updated. This patch will fix
this issue.
This patch corrects some incorrect default value in the cache.
Fix double unlock of fe card mutex introduced by patch 8f70e515a8bb
"ASoC: soc-pcm: fix dpcm_path_get error handling"
The first unlock is at line 106, and the unlock is at line 149. we
should remove the first unlock.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
code can raise a panic when the ssi_private->pdev is null
* If codec-handle property is missing from SSI node, we assume
* that the machine driver uses new binding which does not require
* SSI driver to trigger machine driver's probe.
if (!of_get_property(np, "codec-handle", NULL))
goto done;
ssi_private->pdev =
platform_device_register_data(&pdev->dev, name, 0, NULL, 0);
done:
if (ssi_private->dai_fmt)
_fsl_ssi_set_dai_fmt(ssi_private, ssi_private->dai_fmt);
Proposal was to not use ssi_private->pdev->dev here but adding a new parameter
of *dev pointer to this _set_dai_fmt() -- passing pdev->dev in probe() and
cpu_dai->dev in fsl_ssi_set_dai_fmt().
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Reported-by: Jean-Michel Hautbois <jean-michel.hautbois@vodalys.com>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
KoreController and KoreController2 need an EP1_CMD_DIMM_LEDS command to set
their LEDs, not EP1_CMD_WRITE_IO.
Reported-and-tested-by: Brad Wilson <brad.wilson.00@gmail.com>
The calculated frame size was wrong because snd_pcm_format_physical_width()
actually returns the number of bits, not bytes.
Use snd_pcm_format_size() instead, which not only returns bytes, but also
simplifies the calculation.
Fixes: 8bea869c5e56 ("ALSA: PCM midlevel: improve fifo_size handling")
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Cc: <stable@vger.kernel.org>
Lemote A1004 is already added in commit a2dd933d01f (ALSA: hda - Add
fixup name lookup for CX5051 and 5066 codecs), but Lemote A1205 has
missing.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: <stable@vger.kernel.org> # 3.15+
This is mostly driver fixes, the biggest one being the tlv320aic31xx
which is relatively large but simple and device specific. There's a
small fix in the error handling in DPCM too which is relatively minor
error handling fix.
'asoc/fix/rockchip', 'asoc/fix/samsung' and 'asoc/fix/tlv320aic31xx' into asoc-linus
