path: root/sound
2014-03-19ALSA: compress: Pass through return value of open ops callbackCharles Keepax
The snd_compr_open function would always return 0 even if the compressed ops open function failed, obviously this is incorrect. Looks like this was introduced by a small typo in: commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 ALSA: Add a reference counter to card instance This patch returns the value from the compressed op as it should. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-18ALSA: oxygen: Xonar DG(X): fix Stereo Upmixing regressionClemens Ladisch
The code introduced in commit 1f91ecc14dee ("ALSA: oxygen: modify adjust_dg_dac_routing function") accidentally disregarded the old value of the playback routing register, so it broke the "Stereo Upmixing" mixer control. The unmuted parts of the channel routing are the same for all settings of the output destination, so it suffices to revert that part of the patch. Fixes: 1f91ecc14dee ('ALSA: oxygen: modify adjust_dg_dac_routing function') Tested-by: Roman Volkov <v1ron@mail.ru> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-11Merge tag 'asoc-v3.14-rc6' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.14 A few things here: - Avoid memory leaks in error cases with DPCM, this code has never been that well tested in mainline due to the lack of mainline drivers but we now have one queued for the merge window! - Fix the N810 audio driver to load when booted with DT since the platform was converted to DT during the merge window. - Fixes for initialisation of some MFD drivers that are probably unused in mainline
2014-03-10Merge remote-tracking branches 'asoc/fix/88pm860', 'asoc/fix/omap' and ↵Mark Brown
'asoc/fix/si476x' into asoc-linus
2014-03-10Merge remote-tracking branch 'asoc/fix/pcm' into asoc-linusMark Brown
2014-03-10ASoC: 88pm860: Fix IO setupLars-Peter Clausen
The 88pm860 is a MFD device and the CODEC driver is using the regmap struct of the parent device, hence automatic IO setup will not work and we need to manually call snd_soc_codec_set_cache_io(). The issue was introduced in commit f9ded3b2e7 ("ASoC: 88pm860x: Use regmap for I/O"). Fixes: f9ded3b2e7 ("ASoC: 88pm860x: Use regmap for I/O"). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-03-10ASoC: si476x: Fix IO setupLars-Peter Clausen
The si476x is a MFD device and the CODEC driver is using the regmap struct of the parent device, hence automatic IO setup will not work and we need to manually call snd_soc_codec_set_cache_io(). The issue was introduced commit d6173df35f ("ASoC: si476x: Remove custom register I/O implementation") Fixes: d6173df35f ("ASoC: si476x: Remove custom register I/O implementation") Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-03-07ALSA: hda - Fix loud click noise with IdeaPad 410YTakashi Iwai
Lenovo IdeaPad 410Y with ALC282 codec makes loud click noises at boot and shutdown. Also, it wrongly misdetects the acpi_thinkpad hook. This patch adds a device-specific fixup for disabling the shutup callback that is the cause of the click noise and also avoiding the thinpad_helper calls. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=71511 Reported-and-tested-by: Guilherme Amadio <guilherme.amadio@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-05ALSA: usb-audio: Add quirk for Logitech Webcam C500Takashi Iwai
Logitech C500 (046d:0807) needs the same workaround like other Logitech Webcams. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-05ALSA: hda - Use analog beep for Thinkpads with AD1984 codecsTakashi Iwai
For making the driver behavior compatible with the earlier kernels, use the analog beep in the loopback path instead of the digital beep. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-05ALSA: hda - Add missing loopback merge path for AD1884/1984 codecsTakashi Iwai
The mixer widget (NID 0x20) of AD1884 and AD1984 codecs isn't connected directly to the actual I/O paths but only via another mixer widget (NID 0x21). We need a similar fix as we did for AD1882. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-05ASoC: pcm: free path list before exiting from error conditionsPatrick Lai
dpcm_path_get() allocates dynamic memory to hold path list. Corresponding dpcm_path_put() must be called to free the memory. dpcm_path_put() is not called under several error conditions. This leads to memory leak. Signed-off-by: Patrick Lai <plai@codeaurora.org> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-03-04ALSA: hda - add automute fix for another dell AIO modelHui Wang
When plugging a headphone or headset, lots of noise is heard from internal speaker, after changing the automute via amp instead of pinctl, the noise disappears. BugLink: https://bugs.launchpad.net/bugs/1268468 Cc: David Henningsson <david.henningsson@canonical.com> Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-04ASoC: n810: fix init with DT bootAaro Koskinen
Since 3.14-rc1 only DT boot has been supported on N810, so this file fails to init. Make a minimal fix to retain functionality. This file should be properly converted to DT in longer term. There seems to be still other unresolved issues with N810 audio support, but this patch is needed at minimum as otherwise the machine driver probing would completely fail. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-03ALSA: hda - Added inverted digital-mic handling for Acer TravelMate 8371Marius Knaust
Signed-off-by: Marius Knaust <marius.knaust@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-27Merge tag 'asoc-v3.14-rc4-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v3.14 A few more driver specific bug fixes, all driver specific things that only affect users of those devices.
2014-02-27Merge remote-tracking branch 'asoc/fix/wm8958' into asoc-linusMark Brown
2014-02-27Merge remote-tracking branches 'asoc/fix/da732x' and 'asoc/fix/sta32x' into ↵Mark Brown
asoc-linus
2014-02-27ASoC: sta32x: Fix wrong enum for limiter2 release rateTakashi Iwai
There is a typo in the Limiter2 Release Rate control, a wrong enum for Limiter1 is assigned. It must point to Limiter2. Spotted by a compile warning: In file included from sound/soc/codecs/sta32x.c:34:0: sound/soc/codecs/sta32x.c:223:29: warning: ‘sta32x_limiter2_release_rate_enum’ defined but not used [-Wunused-variable] static SOC_ENUM_SINGLE_DECL(sta32x_limiter2_release_rate_enum, ^ include/sound/soc.h:275:18: note: in definition of macro ‘SOC_ENUM_DOUBLE_DECL’ struct soc_enum name = SOC_ENUM_DOUBLE(xreg, xshift_l, xshift_r, \ ^ sound/soc/codecs/sta32x.c:223:8: note: in expansion of macro ‘SOC_ENUM_SINGLE_DECL’ static SOC_ENUM_SINGLE_DECL(sta32x_limiter2_release_rate_enum, ^ Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: <stable@vger.kernel.org>
2014-02-27Merge tag 'asoc-v3.14-rc4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.14 A somewhat large set of fixes here due to the identification of some systematic problems with hard to use APIs in the subsystem. Takashi did a lot of work to address the enumeration API which uncovered a number of off by one bugs caused by confusing APIs while Charles addressed issues in the locking around DAPM.
2014-02-26ASoC: da732x: Mark DC offset control registers volatileMark Brown
The driver reads from the DC offset control registers during callibration but since the registers are marked as volatile and there is a register cache the values will not be read from the hardware after the first reading rendering the callibration ineffective. It appears that the driver was originally written for the ASoC level register I/O code but converted to regmap prior to merge and this issue was missed during the conversion as the framework level volatile register functionality was not being used. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Cc: stable@vger.kernel.org
2014-02-26ALSA: hda/realtek - Add more entry for enable HP mute ledKailang Yang
I lost this SSID. Add it into the fixup table. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-25ALSA: hda - Add a fixup for HP Folio 13 mute LEDTakashi Iwai
HP Folio 13 may have a broken BIOS that doesn't set up the mute LED GPIO properly, and the driver guesses it wrongly, too. Add a new fixup entry for setting the GPIO pin statically for this laptop. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=70991 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-25ASoC: wm8958-dsp: Fix firmware block loadingLars-Peter Clausen
The codec->control_data contains a pointer to the device's regmap struct. But wm8994_bulk_write() expects a pointer to the parent wm8998 device. The issue was introduced in commit d9a7666f ("ASoC: Remove ASoC-specific WM8994 I/O code"). Fixes: d9a7666f ("ASoC: Remove ASoC-specific WM8994 I/O code") Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-23Merge remote-tracking branches 'asoc/fix/sta32x', 'asoc/fix/wm8400', ↵Mark Brown
'asoc/fix/wm8770', 'asoc/fix/wm8900' and 'asoc/fix/wm8994' into asoc-linus
2014-02-23Merge remote-tracking branches 'asoc/fix/ad1980' and 'asoc/fix/isabelle' ↵Mark Brown
into asoc-linus
2014-02-23Merge remote-tracking branch 'asoc/fix/dapm' into asoc-linusMark Brown
2014-02-23ASoC: sta32x: Fix cache syncLars-Peter Clausen
codec->control_data contains a pointer to the regmap struct of the device, not to the device private data. Use snd_soc_codec_get_drvdata() instead. The issue was introduced in commit 29fdf4fbbe ("ASoC: sta32x: Convert to regmap"). Fixes: 29fdf4fbbe (ASoC: sta32x: Convert to regmap) Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-21ALSA: hda/realtek - Add more entry for enable HP mute ledKailang Yang
More HP machine need mute led support. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-20ASoC: dapm: Add locking to snd_soc_dapm_xxxx_pin functionsCharles Keepax
The snd_soc_dapm_xxxx_pin all require the dapm_mutex to be held when they are called as they edit the dirty list, however very few of the callers do so. This patch adds unlocked versions of all the functions replacing the existing implementations with one that holds the lock internally. We also fix up the places where the lock was actually held on the caller side. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-20ALSA: hda - Enable front audio jacks on one HP desktop modelHui Wang
The front headphone and mic jackes on a HP desktop model (Vendor Id: 0x111d76c7 Subsystem Id: 0x103c2b17) can not work, the codec on this machine has 8 physical ports, 6 of them are routed to rear jackes and all of them work very well, while the remaining 2 ports are routed to front headphone and mic jackes, but the corresponding pin complex node are not defined correctly. After apply this fix, the front audio jackes can work very well. [trivial fix of enum definition by tiwai] BugLink: https://bugs.launchpad.net/bugs/1282369 Cc: David Henningsson <david.henningsson@canonical.com> Tested-by: Gerald Yang <gerald.yang@canonical.com> Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-20Merge tag 'asoc-v3.14-rc3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.14 A few fixes, all driver speccific ones. The DaVinci ones aren't as clear as they should be from the subject lines on the commits but they fix issues which will prevent correct operation in some use cases and only affect that particular driver so are reasonably safe.
2014-02-20ASoC: wm8400: Fix the wrong number of enum itemsTakashi Iwai
wm8400 codec driver has a few places wrongly defining the number of enum items. Use SOC_ENUM_SINGLE_DECL() macro and they are automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-20ASoC: isabelle: Fix the wrong number of items in enum ctlsTakashi Iwai
isabelle codec driver has a few places wrongly defining the number of enum items. Use SOC_ENUM_SINGLE_DECL() macro and they are automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-20ASoC: ad1980: Fix wrong number of items for capture sourceTakashi Iwai
The number of capture sources is 8, not 7. Use SOC_ENUM_DOUBLE_DECL() macro and it's automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-20ASoC: wm8994: Fix the wrong number of enum itemsTakashi Iwai
wm8994 codec driver has a few places wrongly defining the number of enum items. Use SOC_ENUM_SINGLE_DECL() macro and they are automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-20ASoC: wm8900: Fix the wrong number of enum itemsTakashi Iwai
wm8900 codec driver has a few places wrongly defining the number of enum items. Use SOC_ENUM_SINGLE_DECL() macro and they are automatically fixed. Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-20ASoC: wm8770: Fix wrong number of enum itemsTakashi Iwai
wm8770 codec driver defines ain_enum with a wrong number of items. Use SOC_ENUM_DOUBLE_DECL() macro and it's automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-20ASoC: sta32x: Fix array access overflowTakashi Iwai
Preset EQ enum of sta32x codec driver declares too many number of items and it may lead to the access over the actual array size. Use SOC_ENUM_SINGLE_DECL() helper and it's automatically fixed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-19ALSA: hda/ca0132 - Fix recording from mode id 0x8Hsin-Yu Chao
Incorrect ADC is picked in ca0132_capture_pcm_prepare(), where it assumes multiple streams while there is one stream per ADC. Note that ca0132_capture_pcm_cleanup() already does the right thing. The Chromebook Pixel has a microphone under the keyboard that is attached to node id 0x8. Before this fix, recording would always go to the main internal mic (node id 0x7). Signed-off-by: Hsin-Yu Chao <hychao@chromium.org> Reviewed-by: Dylan Reid <dgreid@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-19ALSA: hda/ca0132 - setup/cleanup streamsHsin-Yu Chao
When a HDMI stream is opened with the same stream tag as a following opened stream to ca0132, audio will be heard from two ports simultaneously. Fix this issue by change to use snd_hda_codec_setup_stream and snd_hda_codec_cleanup_stream instead, so that an inactive stream can be marked as 'dirty' when found with a conflict stream tag, and then get purified. Signed-off-by: Hsin-Yu Chao <hychao@chromium.org> Reviewed-by: Chih-Chung Chang <chihchung@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-19ASoC: dapm: Correct regulator bypass error messagesCharles Keepax
The error messages for bypassing/unbypassing a regulator appear to be swapped round, this patch corrects these. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-19Merge remote-tracking branch 'asoc/fix/wm8993' into asoc-linusMark Brown
2014-02-19Merge remote-tracking branches 'asoc/fix/blackfin', 'asoc/fix/da9055', ↵Mark Brown
'asoc/fix/davinci', 'asoc/fix/fsl', 'asoc/fix/fsl-esai', 'asoc/fix/max98090', 'asoc/fix/rt5640', 'asoc/fix/samsung' and 'asoc/fix/txx9aclc-ac97' into asoc-linus
2014-02-18ALSA: hda - add headset mic detect quirks for two Dell laptopsHui Wang
When we plug a 3-ring headset on the Dell machines (Vendor ID: 0x10ec0255, Subsystem ID: 0x10280657; Vendor ID: 0x10ec0255, Subsystem ID: 0x1028065f), the headset mic can't be detected, after apply this patch, the headset mic can work well. BugLink: https://bugs.launchpad.net/bugs/1260303 Cc: David Henningsson <david.henningsson@canonical.com> Tested-by: Cyrus Lien <cyrus.lien@canonical.com> Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-17ALSA: usb-audio: work around KEF X300A firmware bugClemens Ladisch
When the driver tries to access Function Unit 10, the KEF X300A speakers' firmware apparently locks up, making even PCM streaming impossible. Work around this by ignoring this FU. Cc: <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-16ASoC: max98090: make REVISION_ID readableStephen Warren
The REVISION_ID register is not currently marked readable. snd_soc_read() refuses to read the register, and hence probe() fails. Fixes: d4807ad2c4c0 ("regmap: Check readable regs in _regmap_read") [exposed the bug, by checking for readability] Fixes: 685e42154dcf ("ASoC: Replace max98090 Device Driver") [left out this register from the readable list] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-16ASoC: txx9aclc_ac97: Fix kernel crash on probeAlexander Shiyan
This patch fixes a crash caused by commit 3bed3344c826 (ASoC: txx9aclc_ac97: Convert to devm_ioremap_resource()). This is an attempt to assign "drvdata->base" while memory for "drvdata" is not already allocated. Fixes: 3bed3344c826 (ASoC: txx9aclc_ac97: Convert to devm_ioremap_resource()) Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-12ASoC: max98090: sync regcache on entering STANDBYDylan Reid
Sync regcache when entering STANDBY from OFF. ON isn't entered with OFF as the current state, so the registers were not being re-synced after suspend/resume. The 98088 and 98095 already call regcache_sync from STANDBY. Signed-off-by: Dylan Reid <dgreid@chromium.org> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-02-12ALSA: Revert "ALSA: hda/realtek - Avoid invalid COEFs for ALC271X"Martin Kepplinger
This reverts commit d3c56568f43807135f2c2a09582a69f809f0d8b7. The reverted commit breaks audio through headphone line out on the Acer TravelMate B113 (Type1Sku0) Notebook, my main work machine. I don't know much about it but this fixes my problem. Bisected and tested. Fixes: d3c56568f438 ('ALSA: hda/realtek - Avoid invalid COEFs for ALC271X') Cc: <stable@vger.kernel.org> Tested-by: Martin Kepplinger <martink@posteo.de> Signed-off-by: Martin Kepplinger <martink@posteo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
