The default EAPD control uses verb command to control EAPD. Some codec
does not have verb command for EAPD. It needs to control by hidden
register.
This update will avoid wrong behavior for some codec. This patch will
fix double setup for EAPD. It just needs to turn on by one site for
verb command or hidden register controlled.
Detailed changes:
- alc889_coef_init() is replaced with alc_update_coef_idx() with a
correct COEF value.
- for ALC262, ALC887 and ALC900, the EAPD setup via the hidden
register is removed because this rather conflicts with the EAPD verb
setup.
- For ALC888-VC, also the hidden register access is removed in
alc888_coef_init().
- Remove the dead #if 0 code for ALC267/ALC268.
Signed-off-by: Kailang Yang <kailang@realtek.com>
Cc: <stable@vger.kernel.org>
These three HP machines all have the same pin config, so we can
change it to a pin quirk.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
These HP machines needs GPIO 4 low to enable the headphone amplifier.
In addition, we still need to control LEDs via vref and GPIO.
Cc: stable@vger.kernel.org
BugLink: https://bugs.launchpad.net/bugs/1387128
Tested-by: TienFu Chen <tienfu.chen@canonical.com>
Adding ultra doch support for Lenovo Thinkpad X240 (17aa:2214).
[Actually replaced the entry with ALC292_FIXUP_TPT440_DOCK -- tiwai]
Signed-off-by: Lukas Bossard <mr.bobukas@gmail.com>
Commit 14621c7e5e72 ("ASoC: Consolidate CPU and CODEC DAI lookup")
consolidated the lookup of CPU DAIs and CODEC DAIs into a single function.
When matching a component by name for CODEC DAIs the code previous to the
patch compared the name in the DAI link table with component->name. For CPU
DAIs the code compared to dev_name(component->dev). The newly introduced
function ended up using the later as well.
For most components dev_name(component->dev) and component->name are the
same. The main notable exception are I2C devices where the driver name and
the device name are concatenated to form the component name. By using
dev_name(component->dev) instead of component->name the patch broke the
matching of I2C CODECs by name.
This patch restores the original behavior by using component->name instead
of dev_name(component->dev). This will be safe even for CPU DAIs since for
CPU DAIs both are the same.
Fixes: 14621c7e5e72 ("ASoC: Consolidate CPU and CODEC DAI lookup")
Reported-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
CMI8888 shows the stuttering playback when the snooping is disabled
on the audio buffer. Meanwhile, we've got reports that CORB/RIRB
doesn't work in the snooped mode. So, as a compromise, disable the
snoop only for CORB/RIRB and enable the snoop for the stream buffers.
The resultant patch became a bit ugly, unfortunately, but we still can
live with it.
Reported-and-tested-by: Geoffrey McRae <geoff@spacevs.com>
Cc: <stable@vger.kernel.org> # 3.17+
R-Car sound doesn't support PAUSE.
Remove SNDRV_PCM_INFO_PAUSE flags from snd_pcm_hardware info
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
FSI doesn't support PAUSE.
amixer query fails due to it is not readable reigster
Signed-off-by: Fang, Yang A <yang.a.fang@intel.com>
Acked-by: Bard Liao <bardliao@realtek.com>
We can get into an infinite loop if the I2S_CLR register fails to
clear due to a missing break statement, so add that.
Signed-off-by: Jianqun <jay.xu@rock-chips.com>
In compat mode, we copy each field of snd_pcm_status struct but don't
touch the reserved fields, and this leaves uninitialized values
there. Meanwhile the native ioctl does zero-clear the whole
structure, so we should follow the same rule in compat mode, too.
Reported-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
The convention for i2c_device_id name does not need to have company prefix.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Kernel dump (WARN_ON) ocurred during system boot-up inside regmap_write():
WARNING: CPU: 0 PID: 47 at kernel/locking/lockdep.c:2744 lockdep_trace_alloc+0xe8/0x108()
DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags))
Modules linked in:
CPU: 0 PID: 47 Comm: kworker/u2:2 Not tainted 3.18.0-rc1-10245-gb75d289-dirty #56
Workqueue: deferwq deferred_probe_work_func
Backtrace:
[<80012294>] (dump_backtrace) from [<80012578>] (show_stack+0x18/0x1c)
r6:8097c73c r5:8097c73c r4:00000000 r3:be33ba80
[<80012560>] (show_stack) from [<806aac48>] (dump_stack+0x8c/0xa4)
[<806aabbc>] (dump_stack) from [<8002a694>] (warn_slowpath_common+0x70/0x94)
r6:80062838 r5:00000009 r4:bd827b30 r3:be33ba80
[<8002a624>] (warn_slowpath_common) from [<8002a6f0>] (warn_slowpath_fmt+0x38/0x40)
r8:00000004 r7:00000001 r6:000080d0 r5:60000193 r4:bd826010
[<8002a6bc>] (warn_slowpath_fmt) from [<80062838>] (lockdep_trace_alloc+0xe8/0x108)
r3:80831590 r2:8082e160
[<80062750>] (lockdep_trace_alloc) from [<800ea5dc>] (kmem_cache_alloc+0x28/0x134)
r5:000080d0 r4:be001f00
[<800ea5b4>] (kmem_cache_alloc) from [<8038d72c>] (regcache_rbtree_write+0x15c/0x648)
r10:00000000 r9:0000001c r8:00000004 r7:00000001 r6:00000000 r5:bd819a00
r4:00000000 r3:811aea88
[<8038d5d0>] (regcache_rbtree_write) from [<8038c4d8>] (regcache_write+0x5c/0x64)
r10:be3f9f88 r9:00000000 r8:00000004 r7:00000001 r6:00000000 r5:00000001
r4:bd819a00
[<8038c47c>] (regcache_write) from [<8038b0dc>] (_regmap_raw_write+0x134/0x5f4)
r6:be3f9f84 r5:00000001 r4:bd819a00 r3:00000001
[<8038afa8>] (_regmap_raw_write) from [<8038b610>] (_regmap_bus_raw_write+0x74/0x94)
r10:00000000 r9:00000001 r8:be3fb080 r7:bd819a00 r6:00000001 r5:00000000
r4:bd819a00
[<8038b59c>] (_regmap_bus_raw_write) from [<8038a8b4>] (_regmap_write+0x60/0x9c)
r6:00000001 r5:00000000 r4:bd819a00 r3:8038b59c
[<8038a854>] (_regmap_write) from [<8038ba24>] (regmap_write+0x48/0x68)
r7:bd81ad80 r6:00000001 r5:00000000 r4:bd819a00
[<8038b9dc>] (regmap_write) from [<80528f30>] (fsl_asrc_dai_probe+0x34/0x104)
r6:bd888628 r5:be3fb080 r4:be3b4410 r3:be3b442c
------------[ dump end ]------------
2741 /*
2742 * Oi! Can't be having __GFP_FS allocations with IRQs disabled.
2743 */
2744 if (DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags)))
2745 return;
By looking at 2744 line, we can get that it's because regcache_rbtree_write()
would call kmalloc() with GFP flag if it couldn't find an existing block to
insert nodes while this kmalloc() call is inside a spin_lock_irq_save pair,
i.e. IRQs disabled.
Even though this may be a bug that should be fixed, I still try to send this
patch as a quick fix (work around) since it does no harm to assign default
values of every registers when using regcache.
Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com>
snd_bebob_stream_check_internal_clock() may get an id from
saffirepro_both_clk_src_get (via clk_src->get()) that was uninitialized.
a) make logic in saffirepro_both_clk_src_get explicit
b) test if id used in snd_bebob_stream_check_internal_clock matches array size
[fixed missing signed prefix to *_maps[] by tiwai]
Signed-off-by: Christian Vogel <vogelchr@vogel.cx>
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v3.18
A few small driver fixes for v3.18 plus the removal of the s6000 support
since the relevant chip is no longer supported in mainline.
'asoc/fix/intel', 'asoc/fix/s6000' and 'asoc/fix/sgtl5000' into asoc-linus
It is lite version of AIO machine(0x0626).
The audio layout of this machine was similar with SSID 0x0626.
The audio was same as commit ad8ff99e6beb8708b0bdefd9d5658324e90200f0.
Precedence of & and >> is not the same and is not left to right.
shift has higher precedence and should be done after the mask.
Add parentheses around the mask.
Rack FW
Terratec PHASE 88 rack fw has two registers for source of clock, one is
for internal/external, and another is for wordclock/spdif for external.
When clock source is internal, information in another register has no meaning.
Thus it must be ignored, but current implementation decodes it. This causes
over-indexing reference to labels.
Reported-by: András Murányi <muranyia@gmail.com>
Tested-by: András Murányi <muranyia@gmail.com>
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here are a chunk of small fixes since rc1: two PCM core fixes, one is
a long-standing annoyance about lockdep and another is an ARM64 mmap
fix.
The rest are a HD-audio HDMI hotplug notification fix, a fix for
missing NULL termination in Realtek codec quirks and a few new
device/codec-specific quirks as usual"
* tag 'sound-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Add missing terminating entry to SND_HDA_PIN_QUIRK macro
ALSA: pcm: Fix false lockdep warnings
ALSA: hda - Fix inverted LED gpio setup for Lenovo Ideapad
ALSA: hda - hdmi: Fix missing ELD change event on plug/unplug
ALSA: usb-audio: Add support for Steinberg UR22 USB interface
ALSA: ALC283 codec - Avoid pop noise on headphones during suspend/resume
ALSA: pcm: use the same dma mmap codepath both for arm and arm64
Update two records for ALC283 for restore default value.
[The update doesn't seem to have high impact on the existing machines,
but it fixes possible issues, especially expected in BIOS changes on
new machines, according to Realtek -- tiwai]
Update default value for ALC282 for COEF.
Without this terminating entry, the pin matching would continue
across random memory until a zero or a non-matching entry was found.
The result being that in some cases, the pin quirk would not be
applied correctly.
Use strncpy() instead of strcpy(). That's not a security issue, as the
source buffer is taken from DT nodes, but we should still enforce bound
checks. Spotted by Coverity.
Signed-off-by: Daniel Mack <daniel@zonque.org>
For the input PGA to work correctly the ALC clock needs to be active.
Otherwise volume changes are not applied.
Fixes: dab464b60b2 ("ASoC: Add ADAU1361/ADAU1761 audio CODEC support")
As PCM core handles the multiple linked streams in parallel, lockdep
gets confused (partly because of weak annotations) and spews the
false-positive warnings. This hasn't been a problem for long time but
the latest PCM lock path update seems to have woken up a sleeping
dog.
Here is an attempt to paper over this issue: pass the lock subclass
just calculated from the depth in snd_pcm_action_group(). Also, a
(possibly) wrong lock subclass set in snd_pcm_action_lock_mutex() is
dropped, too.
Reported-and-tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
The s6000 Xtensa support is removed from the kernel. There are no
other chips known to use this I2S controller.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
We implemented in a wrong way for mute LED on Lenovo Ideapad; the bit
must be flipped.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16373
Fixes: 3e887f379d8a ('ALSA: hda - Add mute LED support to Lenovo Ideapad')
Cc: <stable@vger.kernel.org> # 3.15+
The ELD ALSA control change event is sent by hdmi_present_sense() when
eld_changed is true.
Currently, it is only true when the ELD buffer contents have been
modified. However, the user-visible ELD controls also change to a
zero-length value and back when eld_valid is unset/set, and no event is
currently sent in such cases (such as when unplugging or replugging a
sink).
Fix the code to always set eld_changed if eld_valid value is changed,
and therefore to always send the change event when the user-visible
value changes.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
Cc: David Henningsson <david.henningsson@canonical.com>
Cc: <stable@vger.kernel.org> # 3.9+
Adding support for Steinberg UR22 USB interface via quirks table patch
See Ubuntu bug report:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1317244
Also see threads:
http://linux-audio.4202.n7.nabble.com/Support-for-Steinberg-UR22-Yamaha-USB-chipset-0499-1509-tc82888.html#a82917
http://www.steinberg.net/forums/viewtopic.php?t=62290
Tested by at least 4 people judging by the threads.
Did not test MIDI interface, but audio output and capture both are
functional. Built 3.17 kernel with this driver on Ubuntu 14.04 & tested with mpg123
Patch applied to 3.13 Ubuntu kernel works well enough for daily use.
Signed-off-by: Vlad Catoi <vladcatoi@gmail.com>
This patch sets the headphones mode to default before suspending
which helps avoid the pop noise on headphones
Signed-off-by: Harsha Priya <harshapriya.n@intel.com>
"Here are a collection of small fixes after 3.18 merge.
The urgent one is the fix for kernel panics with linked PCM substream
triggered by the recent nonatomic PCM ops support. Other two fixes
(emu10k1 and bebob) are stable fixes, and one easy PCI ID addition for
a new Intel HD-audio controller"
* tag 'sound-fix-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda_intel: Add Device IDs for Intel Sunrise Point PCH
ALSA: emu10k1: Fix deadlock in synth voice lookup
ALSA: pcm: Fix referred substream in snd_pcm_action_group() unlock loop
ALSA: bebob: Fix failure to detect source of clock for Terratec Phase 88
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
This avoids following kernel crash when try to playback on arm64
[ 107.497203] [<ffffffc00046b310>] snd_pcm_mmap_data_fault+0x90/0xd4
[ 107.503405] [<ffffffc0001541ac>] __do_fault+0xb0/0x498
[ 107.508565] [<ffffffc0001576a0>] handle_mm_fault+0x224/0x7b0
[ 107.514246] [<ffffffc000092640>] do_page_fault+0x11c/0x310
[ 107.519738] [<ffffffc000081100>] do_mem_abort+0x38/0x98
Tested: backported to 3.14 and tried to playback on arm64 machine
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Fix driver with correct formats.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
The introduced include/linux/dma/dw.h is going to contain the private
extensions and structures which are shared for dw_dmac users in the kernel.
Meanwhile include/linux/platform_data/dma-dw.h keeps only platform related data
types and definitions.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This patch adds the HD Audio Device IDs for the Intel Sunrise Point PCH.
[the item position rearranged by tiwai]
Signed-off-by: James Ralston <james.d.ralston@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030
- Export symbols for use in modules in max14577
- Plenty of static code analysis/Coccinelle fixes throughout the SS
- Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808
- Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona
- Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr
- IRQ fixups in arizona, stmpe, max14577
- Regulator related changes in axp20x
- Pass DMA coherency information from parent => child in MFD core
- Rename DT document files for consistency
- Add ACPI support to the MFD core
- Add Andreas Werner to MAINTAINERS for MEN F21BMC
New drivers/supported devices:
- New driver for MEN 14F021P00 Board Management Controller
- New driver for Ricoh RN5T618 PMIC
- New driver for Rockchip RK808
- New driver for HiSilicon Hi6421 PMIC
- New driver for Qualcomm SPMI PMICs
- Add support for Intel Braswell in lpc_ich
- Add support for Intel 9 Series PCH in lpc_ich
- Add support for Intel Quark ILB in lpc_sch"
[ Delayed to after the poweer/reset pull due to Kconfig problems with
recursive Kconfig select/depends-on chains. - Linus ]
* tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits)
mfd: cros_ec: wait for completion of commands that return IN_PROGRESS
i2c: i2c-cros-ec-tunnel: Set retries to 3
mfd: cros_ec: move locking into cros_ec_cmd_xfer
mfd: cros_ec: stop calling ->cmd_xfer() directly
mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC
MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC
mfd: arizona: Correct mask to allow setting micbias external cap
mfd: Add ACPI support
Revert "mfd: wm5102: Manually apply register patch"
mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS
mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention
mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention
mfd: Inherit coherent_dma_mask from parent device
mfd: Document DT bindings for Qualcomm SPMI PMICs
mfd: Add support for Qualcomm SPMI PMICs
mfd: dt-bindings: pm8xxx: Add new compatible string
mfd: axp209x: Drop the parent supplies field
mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off
mfd: dt-bindings: twl4030-power: Use the standard property to mark power control
mfd: syscon: Add Atmel GPBR DT bindings documention
The emu10k1 voice allocator takes voice_lock spinlock. When there is
no empty stream available, it tries to release a voice used by synth,
and calls get_synth_voice. The callback function,
snd_emu10k1_synth_get_voice(), however, also takes the voice_lock,
thus it deadlocks.
The fix is simply removing the voice_lock holds in
snd_emu10k1_synth_get_voice(), as this is always called in the
spinlock context.
In the unlock loop of snd_pcm_action_group(), the object "s" is used
as the check of nonatomic PCM, but it should be rather "s1", which is
the iterator of the loop. This supposedly causes a kernel panic when
the substreams in operatino are linked.
Fixes: 257f8cce5d40 ('ALSA: pcm: Allow nonatomic trigger operations')
Pull sound updates from Takashi Iwai:
"This time it's a relatively calm update batch, but the amount isn't
too small in the end. Here we go over some highlights:
ALSA core:
- One major change is the support of nonatomic PCM operations. This
allows the trigger and other callbacks to call schedule(), which
would be useful for mailbox type communications. Already some
drivers (Digigram ones) have been converted to use together with
threaded irqs as an example.
- Improvement / fixes of DSD PCM format support
HD-audio:
- Large volume of rewrites are found in Realtek codec driver for
converting Dell and HP quirks to generic forms.
- Inverted dmic code cleanup from David.
- Realtek COEF access has been optimized.
- Now HD-audio jack infrastructure allows multiple callbacks, which
fixes / simplifies the jack-dependent power controls on STAC/IDT
and VIA codecs.
- Many additional device-specific fixups as usual
- A few deadcode cleanups, CA0132 code cleanup, etc.
ASoC:
- More componentization work from Lars-Peter, this time mainly
cleaning up the suspend and bias level transition callbacks.
- Real system support for the Intel drivers and a bunch of fixes and
enhancements for the associated CODEC drivers, this is going to
need a lot quirks over time due to the lack of any firmware
description of the boards.
- Jack detect support for simple card from Dylan Reid.
- A bunch of small fixes and enhancements for the Freescale drivers.
- New drivers for Analog Devices SSM4567, Cirrus Logic CS35L32,
Everest Semiconductor ES8328 and Freescale cards using the ASRC in
newer i.MX processors.
- A few simple-card fixes, mostly cleanups but also a fix for
interaction between GPIO 0 and simple-card.
Misc:
- Virtuoso / Oxygen updates by Clemens
- USB-audio: Yamaha MOTIF XF MIDI port name fixes
- Conversion of kernel messages to standard dev_*() in ctxfi driver"
* tag 'sound-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (251 commits)
ASoC: mc13783: Ensure we only try to dereference valid of_nodes
ASoC: rockchip-i2s: fix infinite loop in rockchip_snd_txctrl
ALSA: hda - Add dock port support to Thinkpad L440 (71aa:501e)
ALSA: Allow pass NULL dev for snd_pci_quirk_lookup()
ASoC: imx-es8328: Fix of_node_put() call with uninitialized object
ASoC: soc-pcm: fix sig_bits determination in soc_pcm_apply_msb()
ASoC: simple-card: Initialize headphone and mic GPIO numbers
ASoC: imx-es8328: Fix missing return code in imx_es8328_probe()
ALSA: hda - Add dock support for Thinkpad T440 (17aa:2212)
ALSA: usb: caiaq: check for cdev->n_streams > 1
ASoC: 88pm860x-codec: Fix possibly missing string termination
ASoC: core: fix use after free in snd_soc_remove_platform()
ASoC: soc-dapm: fix use after free
ALSA: hda - Make the inv dmic handling for Realtek use generic parser
ALSA: hda - Add Inverted Internal mic for Samsung Ativ book 9 (NP900X3G)
ALSA: hda - Add inverted internal mic for Asus Aspire 4830T
ASoC: Intel: byt-rt5640: fix coccinelle warnings
ASoC: fsl_esai doc: Add "fsl,vf610-esai" as compatible string
ASoC: da732x: Remove unnecessary KERN_ERR in pr_err()
ASoC: simple-card: Fix detect gpio documentation.
This patch fixes a failure to open PCM device with -ENOSYS in
Terratec Phase 88.
Terratec Phase 88 has two Selector Function Blocks of AVC Audio subunit
to switch source of clock. One is to switch internal/external for the
source and another is to switch word/spdif for the external clock.
The IDs for these Selector Function Blocks are 9 and 8. But in current
implementation they're 0 and 0.
Cc: <stable@vger.kernel.org> # v3.16+
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
A few small fixes, mostly small although a few really nasty ones like
the interaction between GPIO 0 and simple-card.
'asoc/fix/imx', 'asoc/fix/mc13783', 'asoc/fix/rockchip' and 'asoc/fix/simple' into asoc-linus
Reported-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 3.18-rc1. Also in here is the PHY
tree, as it seems to fit well with the USB tree for various reasons...
Anyway, lots of little changes in here, all over the place, full
details in the changelog
All have been in the linux-next tree for a while with no issues"
* tag 'usb-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (244 commits)
USB: host: st: fix typo 'CONFIG_USB_EHCI_HCD_ST'
uas: Reduce number of function arguments for uas_alloc_foo functions
xhci: Allow xHCI drivers to be built as separate modules
xhci: Export symbols used by host-controller drivers
xhci: Check for XHCI_COMP_MODE_QUIRK when disabling D3cold
xhci: Introduce xhci_init_driver()
usb: hcd: add generic PHY support
usb: rename phy to usb_phy in HCD
usb: gadget: uvc: fix up uvcg_v4l2_get_unmapped_area typo
USB: host: st: fix ehci/ohci driver selection
usb: host: ehci-exynos: Remove unnecessary usb-phy support
usb: core: return -ENOTSUPP for all targeted hosts
USB: Remove .owner field for driver
usb: core: log higher level message on malformed LANGID descriptor
usb: Add LED triggers for USB activity
usb: Rename usb-common.c
usb: gadget: Refactor request completion
usb: gadget: Introduce usb_gadget_giveback_request()
usb: dwc2/gadget: move phy bus legth initialization
phy: remove .owner field for drivers using module_platform_driver
