path: root/sound
2018-10-04ALSA: hda/realtek - Cannot adjust speaker's volume on Dell XPS 27 7760Kai-Heng Feng
The issue is the same as commit dd9aa335c880 ("ALSA: hda/realtek - Can't adjust speaker's volume on a Dell AIO"), the output requires to connect to a node with Amp-out capability. Applying the same fixup ALC298_FIXUP_SPK_VOLUME can fix the issue. BugLink: https://bugs.launchpad.net/bugs/1775068 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-20ALSA: hda: Fix the audio-component completion timeoutTakashi Iwai
The timeout of audio component binding was incorrectly specified in msec, not in jiffies, which results in way too shorter timeout than expected. Along with fixing it, add the information print about the binding failure to show the unexpected situation more clearly. Fixes: a57942bfdd61 ("ALSA: hda: Make audio component support more generic") Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-17Merge tag 'asoc-v4.19-rc4' of ↵Takashi Iwai
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v4.19 This is the usual set of small fixes scatterd around various drivers, plus one fix for DAPM and a UAPI build fix. There's not a huge amount that stands out here relative to anything else.
2018-09-17ALSA: fireworks: fix memory leak of response buffer at error pathTakashi Sakamoto
After allocating memory object for response buffer, ALSA fireworks driver has leak of the memory object at error path. This commit releases the object at the error path. Fixes: 7d3c1d5901aa('ALSA: fireworks: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-17ALSA: oxfw: fix memory leak of discovered stream formats at error pathTakashi Sakamoto
After finishing discover of stream formats, ALSA OXFW driver has memory leak of allocated memory object at error path. This commit releases the memory object at the error path. Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-17ALSA: oxfw: fix memory leak for model-dependent data at error pathTakashi Sakamoto
After allocating model-dependent data, ALSA OXFW driver has memory leak of the data at error path. This commit releases the data at the error path. Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-17ALSA: bebob: fix memory leak for M-Audio FW1814 and ProjectMix I/O at error pathTakashi Sakamoto
After allocating model-dependent data for M-Audio FW1814 and ProjectMix I/O, ALSA bebob driver has memory leak at error path. This commit releases the allocated data at the error path. Fixes: 04a2c73c97eb('ALSA: bebob: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-13ALSA: hda - Enable runtime PM only for discrete GPUTakashi Iwai
The recent change of vga_switcheroo allowed the runtime PM for HD-audio on AMD GPUs, but this also resulted in a regression. When the HD-audio controller driver gets runtime-suspended, HD-audio link is turned off, and the hotplug notification is ignored. This leads to the inconsistent audio state (the connection isn't notified and ELD is ignored). The best fix would be to implement the proper ELD notification via the audio component, but it's still not ready. As a quick workaround, this patch adds the check of runtime_idle and allows the runtime suspend only when the vga_switcheroo is bound with discrete GPU. That is, a system with a single GPU and APU would be again without runtime PM to keep the HD-audio link for the hotplug notification and ELD read out. Also, the codec->auto_runtime_pm flag is set only for the discrete GPU at the time GPU gets bound via vga_switcheroo (i.e. only dGPU is forcibly runtime-PM enabled), so that APU can still get the ELD notification. For identifying which GPU is bound, a new vga_switcheroo client callback, gpu_bound, is implemented. The vga_switcheroo simply calls this when GPU is bound, and tells whether it's dGPU or APU. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200945 Fixes: 07f4f97d7b4b ("vga_switcheroo: Use device link for HDA controller") Reported-by: Jian-Hong Pan <jian-hong@endlessm.com> Tested-by: Jian-Hong Pan <jian-hong@endlessm.com> Acked-by: Lukas Wunner <lukas@wunner.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-13ALSA: oxfw: fix memory leak of private dataTakashi Sakamoto
Although private data of sound card instance is usually allocated in the tail of the instance, drivers in ALSA firewire stack allocate the private data before allocating the instance. In this case, the private data should be released explicitly at .private_free callback of the instance. This commit fixes memory leak following to the above design. Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-13ALSA: firewire-tascam: fix memory leak of private dataTakashi Sakamoto
Although private data of sound card instance is usually allocated in the tail of the instance, drivers in ALSA firewire stack allocate the private data before allocating the instance. In this case, the private data should be released explicitly at .private_free callback of the instance. This commit fixes memory leak following to the above design. Fixes: b610386c8afb ('ALSA: firewire-tascam: deleyed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-13ALSA: firewire-digi00x: fix memory leak of private dataTakashi Sakamoto
Although private data of sound card instance is usually allocated in the tail of the instance, drivers in ALSA firewire stack allocate the private data before allocating the instance. In this case, the private data should be released explicitly at .private_free callback of the instance. This commit fixes memory leak following to the above design. Fixes: 86c8dd7f4da3 ('ALSA: firewire-digi00x: delayed registration of sound card') Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-12sound: don't call skl_init_chip() to reset intel skl socYu Zhao
Internally, skl_init_chip() calls snd_hdac_bus_init_chip() which 1) sets bus->chip_init to prevent multiple entrances before device is stopped; 2) enables interrupt. We shouldn't use it for the purpose of resetting device only because 1) when we really want to initialize device, we won't be able to do so; 2) we are ready to handle interrupt yet, and kernel crashes when interrupt comes in. Rename azx_reset() to snd_hdac_bus_reset_link(), and use it to reset device properly. Fixes: 60767abcea3d ("ASoC: Intel: Skylake: Reset the controller in probe") Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-12sound: enable interrupt after dma buffer initializationYu Zhao
In snd_hdac_bus_init_chip(), we enable interrupt before snd_hdac_bus_init_cmd_io() initializing dma buffers. If irq has been acquired and irq handler uses the dma buffer, kernel may crash when interrupt comes in. Fix the problem by postponing enabling irq after dma buffer initialization. And warn once on null dma buffer pointer during the initialization. Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-12Revert "ASoC: Intel: Skylake: Acquire irq after RIRB allocation"Yu Zhao
This reverts commit 12eeeb4f4733bbc4481d01df35933fc15beb8b19. The patch doesn't fix accessing memory with null pointer in skl_interrupt(). There are two problems: 1) skl_init_chip() is called twice, before and after dma buffer is allocate. The first call sets bus->chip_init which prevents the second from initializing bus->corb.buf and rirb.buf from bus->rb.area. 2) snd_hdac_bus_init_chip() enables interrupt before snd_hdac_bus_init_cmd_io() initializing dma buffers. There is a small window which skl_interrupt() can be called if irq has been acquired. If so, it crashes when using null dma buffer pointers. Will fix the problems in the following patches. Also attaching the crash for future reference. [ 16.949148] general protection fault: 0000 [#1] PREEMPT SMP KASAN PTI <snipped> [ 16.950903] Call Trace: [ 16.950906] <IRQ> [ 16.950918] skl_interrupt+0x19e/0x2d6 [snd_soc_skl] [ 16.950926] ? dma_supported+0xb5/0xb5 [snd_soc_skl] [ 16.950933] __handle_irq_event_percpu+0x27a/0x6c8 [ 16.950937] ? __irq_wake_thread+0x1d1/0x1d1 [ 16.950942] ? __do_softirq+0x57a/0x69e [ 16.950944] handle_irq_event_percpu+0x95/0x1ba [ 16.950948] ? _raw_spin_unlock+0x65/0xdc [ 16.950951] ? __handle_irq_event_percpu+0x6c8/0x6c8 [ 16.950953] ? _raw_spin_unlock+0x65/0xdc [ 16.950957] ? time_cpufreq_notifier+0x483/0x483 [ 16.950959] handle_irq_event+0x89/0x123 [ 16.950962] handle_fasteoi_irq+0x16f/0x425 [ 16.950965] handle_irq+0x1fe/0x28e [ 16.950969] do_IRQ+0x6e/0x12e [ 16.950972] common_interrupt+0x7a/0x7a [ 16.950974] </IRQ> <snipped> [ 16.951031] RIP: snd_hdac_bus_update_rirb+0x19b/0x4cf [snd_hda_core] RSP: ffff88015c807c08 [ 16.951036] ---[ end trace 58bf9ece1775bc92 ]--- Fixes: 2eeeb4f4733b ("ASoC: Intel: Skylake: Acquire irq after RIRB allocation") Signed-off-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-10ALSA: emu10k1: fix possible info leak to userspace on SNDRV_EMU10K1_IOCTL_INFOWilly Tarreau
snd_emu10k1_fx8010_ioctl(SNDRV_EMU10K1_IOCTL_INFO) allocates memory using kmalloc() and partially fills it by calling snd_emu10k1_fx8010_info() before returning the resulting structure to userspace, leaving uninitialized holes. Let's just use kzalloc() here. BugLink: http://blog.infosectcbr.com.au/2018/09/linux-kernel-infoleaks.html Signed-off-by: Willy Tarreau <w@1wt.eu> Cc: Jann Horn <jannh@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-10ASoC: cs4265: fix MMTLR Data switch controlSébastien Szymanski
The MMTLR bit is in the CS4265_SPDIF_CTL2 register at address 0x12 bit 0 and not at address 0x0 bit 1. Fix this. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2018-09-10ASoC: AMD: Ensure reset bit is cleared before configuringAkshu Agrawal
HW register descriptions says: "DMA Channel Reset...Software must confirm that this bit is cleared before reprogramming any of the channel configuration registers." There could be cases where dma stop errored out leaving dma channel in reset state. We need to ensure that before the start of another dma, channel is out of the reset state. Signed-off-by: Akshu Agrawal <akshu.agrawal@amd.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-10ALSA: fireface: fix memory leak in ff400_switch_fetching_mode()Takashi Sakamoto
An allocated memory forgets to be released. Fixes: 76fdb3a9e13 ('ALSA: fireface: add support for Fireface 400') Cc: <stable@vger.kernel.org> # 4.12+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-10ALSA: bebob: use address returned by kmalloc() instead of kernel stack for ↵Takashi Sakamoto
streaming DMA mapping When executing 'fw_run_transaction()' with 'TCODE_WRITE_BLOCK_REQUEST', an address of 'payload' argument is used for streaming DMA mapping by 'firewire_ohci' module if 'size' argument is larger than 8 byte. Although in this case the address should not be on kernel stack, current implementation of ALSA bebob driver uses data in kernel stack for a cue to boot M-Audio devices. This often brings unexpected result, especially for a case of CONFIG_VMAP_STACK=y. This commit fixes the bug. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=201021 Reference: https://forum.manjaro.org/t/firewire-m-audio-410-driver-wont-load-firmware/51165 Fixes: a2b2a7798fb6('ALSA: bebob: Send a cue to load firmware for M-Audio Firewire series') Cc: <stable@vger.kernel.org> # v3.16+ Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-06ASoC: rsnd: don't fallback to PIO mode when -EPROBE_DEFERKuninori Morimoto
Current rsnd driver will fallback to PIO mode if it can't get DMA handler. But, DMA might return -EPROBE_DEFER when probe timing. This driver always fallback to PIO mode especially from commit ac6bbf0cdf4206c ("iommu: Remove IOMMU_OF_DECLARE") because of this reason. The DMA driver will be probed later, but sound driver might be probed as PIO mode in such case. This patch fixup this issue. Then, -EPROBE_DEFER is not error. Thus, let's don't indicate error message in such case. And it needs to call rsnd_adg_remove() individually if probe failed, because it registers clk which should be unregister. Maybe PIO fallback feature itself is not needed, but let's keep it so far. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-06ASoC: rsnd: adg: care clock-frequency sizeKuninori Morimoto
ADG has buffer over flow bug if DT has more than 3 clock-frequency. This patch fixup this issue, and uses first 2 values. clock-frequency = <x y>; /* this is OK */ clock-frequency = <x y z>; /* this is NG */ Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-09-03ALSA: hda: Fix several mismatch for register mask and valueKeyon Jie
E.g. for snd_hdac_ext_link_clear_stream_id(), we should set (1 << stream) as mask, and 0 as value, here correct it and several similar mismatches. And, here also remove unreadable register_mask usage for those mask value updating. Signed-off-by: Keyon Jie <yang.jie@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-03ASoC: rsnd: fixup not to call clk_get/set under non-atomicJiada Wang
Clocking operations clk_get/set_rate, are non-atomic, they shouldn't be called in soc_pcm_trigger() which is atomic. Following issue was found due to execution of clk_get_rate() causes sleep in soc_pcm_trigger(), which shouldn't be blocked. We can reproduce this issue by following > enable CONFIG_DEBUG_ATOMIC_SLEEP=y > compile, and boot > mount -t debugfs none /sys/kernel/debug > while true; do cat /sys/kernel/debug/clk/clk_summary > /dev/null; done & > while true; do aplay xxx; done This patch adds support to .prepare callback, and moves non-atomic clocking operations to it. As .prepare is non-atomic, it is always called before trigger_start/trigger_stop. BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620 in_atomic(): 1, irqs_disabled(): 128, pid: 2242, name: aplay INFO: lockdep is turned off. irq event stamp: 5964 hardirqs last enabled at (5963): [<ffff200008e59e40>] mutex_lock_nested+0x6e8/0x6f0 hardirqs last disabled at (5964): [<ffff200008e623f0>] _raw_spin_lock_irqsave+0x24/0x68 softirqs last enabled at (5502): [<ffff200008081838>] __do_softirq+0x560/0x10c0 softirqs last disabled at (5495): [<ffff2000080c2e78>] irq_exit+0x160/0x25c Preemption disabled at:[ 62.904063] [<ffff200008be4d48>] snd_pcm_stream_lock+0xb4/0xc0 CPU: 2 PID: 2242 Comm: aplay Tainted: G B C 4.9.54+ #186 Hardware name: Renesas Salvator-X board based on r8a7795 (DT) Call trace: [<ffff20000808fe48>] dump_backtrace+0x0/0x37c [<ffff2000080901d8>] show_stack+0x14/0x1c [<ffff2000086f4458>] dump_stack+0xfc/0x154 [<ffff2000081134a0>] ___might_sleep+0x57c/0x58c [<ffff2000081136b8>] __might_sleep+0x208/0x21c [<ffff200008e5980c>] mutex_lock_nested+0xb4/0x6f0 [<ffff2000087cac74>] clk_prepare_lock+0xb0/0x184 [<ffff2000087cb094>] clk_core_get_rate+0x14/0x54 [<ffff2000087cb0f4>] clk_get_rate+0x20/0x34 [<ffff20000113aa00>] rsnd_adg_ssi_clk_try_start+0x158/0x4f8 [snd_soc_rcar] [<ffff20000113da00>] rsnd_ssi_init+0x668/0x7a0 [snd_soc_rcar] [<ffff200001133ff4>] rsnd_soc_dai_trigger+0x4bc/0xcf8 [snd_soc_rcar] [<ffff200008c1af24>] soc_pcm_trigger+0x2a4/0x2d4 Fixes: e7d850dd10f4 ("ASoC: rsnd: use mod base common method on SSI-parent") Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Signed-off-by: Timo Wischer <twischer@de.adit-jv.com> [Kuninori: tidyup for upstream] Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2018-09-03ALSA: rawmidi: Initialize allocated buffersTakashi Iwai
syzbot reported the uninitialized value exposure in certain situations using virmidi loop. It's likely a very small race at writing and reading, and the influence is almost negligible. But it's safer to paper over this just by replacing the existing kvmalloc() with kvzalloc(). Reported-by: syzbot+194dffdb8b22fc5d207a@syzkaller.appspotmail.com Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-09-03ASoC: q6routing: initialize data correctlySrinivas Kandagatla
Some of the router data fields are left as default zeros which are valid dai ids, so initialize these to invalid value of -1. Without intializing these correctly get_session_from_id() can return incorrect session resulting in not closing the opened copp and messing up with the copp ref count. Fixes: e3a33673e845 ("ASoC: qdsp6: q6routing: Add q6routing driver") Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-31ASoC: tas6424: Save last fault register even when clearAndrew F. Davis
When there is no fault bit set in a fault register we skip the fault reporting section for that register. This also skips over saving that registers value. We save the value so we will not double report an error, but if an error clears then returns we will also not report it as we did not save the all cleared register value. Fix this by saving the fault register value in the all clear path. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2018-08-30ALSA: hda - Fix cancel_work_sync() stall from jackpoll workTakashi Iwai
On AMD/ATI controllers, the HD-audio controller driver allows a bus reset upon the error recovery, and its procedure includes the cancellation of pending jack polling work as found in snd_hda_bus_codec_reset(). This works usually fine, but it becomes a problem when the reset happens from the jack poll work itself; then calling cancel_work_sync() from the work being processed tries to wait the finish endlessly. As a workaround, this patch adds the check of current_work() and applies the cancel_work_sync() only when it's not from the jackpoll_work. This doesn't fix the root cause of the reported error below, but at least, it eases the unexpected stall of the whole system. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200937 Cc: <stable@vger.kernel.org> Cc: Lukas Wunner <lukas@wunner.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-28ASoC: sigmadsp: safeload should not have lower byte limitDanny Smith
Fixed range in safeload conditional to allow safeload to up to 20 bytes, without a lower limit. Signed-off-by: Danny Smith <dannys@axis.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-28ASoC: wm8804: Add ACPI supportPierre-Louis Bossart
HID made of either Wolfson/CirrusLogic PCI ID + 8804 identifier. This helps enumerate the HifiBerry Digi+ HAT boards on the Up2 platform. The scripts at https://github.com/thesofproject/acpi-scripts can be used to add the ACPI initrd overlays. Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-28ASoC: rt5682: Change DAC/ADC volume scaleShuming Fan
The step of DAC/ADC volume scale changes from 0.375dB to 0.75dB Signed-off-by: Shuming Fan <shumingf@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2018-08-28ASoC: max98373: Added 10ms sleep after amp software resetRyan Lee
Signed-off-by: Ryan Lee <ryans.lee@maximintegrated.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-23Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge yet more updates from Andrew Morton: - the rest of MM - various misc fixes and tweaks * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits) mm: Change return type int to vm_fault_t for fault handlers lib/fonts: convert comments to utf-8 s390: ebcdic: convert comments to UTF-8 treewide: convert ISO_8859-1 text comments to utf-8 drivers/gpu/drm/gma500/: change return type to vm_fault_t docs/core-api: mm-api: add section about GFP flags docs/mm: make GFP flags descriptions usable as kernel-doc docs/core-api: split memory management API to a separate file docs/core-api: move *{str,mem}dup* to "String Manipulation" docs/core-api: kill trailing whitespace in kernel-api.rst mm/util: add kernel-doc for kvfree mm/util: make strndup_user description a kernel-doc comment fs/proc/vmcore.c: hide vmcoredd_mmap_dumps() for nommu builds treewide: correct "differenciate" and "instanciate" typos fs/afs: use new return type vm_fault_t drivers/hwtracing/intel_th/msu.c: change return type to vm_fault_t mm: soft-offline: close the race against page allocation mm: fix race on soft-offlining free huge pages namei: allow restricted O_CREAT of FIFOs and regular files hfs: prevent crash on exit from failed search ...
2018-08-23treewide: correct "differenciate" and "instanciate" typosFinn Thain
Also add these typos to spelling.txt so checkpatch.pl will look for them. Link: http://lkml.kernel.org/r/88af06b9de34d870cb0afc46cfd24e0458be2575.1529471371.git.fthain@telegraphics.com.au Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-23Merge tag 'sound-fix-4.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "No surprises here: a regression fix for virmidi code refactoring, three fixes for the new AC97 bus compat and runtime PM, and a usual HD-audio quirk" * tag 'sound-fix-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix HP Headset Mic can't record ALSA: ac97: fix unbalanced pm_runtime_enable ALSA: ac97: fix check of pm_runtime_get_sync failure ALSA: ac97: fix device initialization in the compat layer ALSA: seq: virmidi: Fix discarding the unsubscribed output
2018-08-21ALSA: hda/realtek - Fix HP Headset Mic can't recordKailang Yang
This patch will fix HP workstation Headset Mic not recording. Signed-off-by: Kailang Yang <kailang@realtek.com> Tested-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-19ALSA: ac97: fix unbalanced pm_runtime_enableLihua Yao
Runtime PM is enabled at ac97_bus_probe() and should be disabled at ac97_bus_remove(). Fixes: 74426fbff66e ("ALSA: ac97: add an ac97 bus") Signed-off-by: Lihua Yao <ylhuajnu@163.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-19ALSA: ac97: fix check of pm_runtime_get_sync failureLihua Yao
pm_runtime_get_sync returns negative on failure. Fixes: 74426fbff66e ("ALSA: ac97: add an ac97 bus") Signed-off-by: Lihua Yao <ylhuajnu@163.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-19ALSA: ac97: fix device initialization in the compat layerLihua Yao
ac97->dev is an object of 'struct device' type. It should be initialized via device_initialize() or device_register(). Fixes: 74426fbff66e ("ALSA: ac97: add an ac97 bus") Signed-off-by: Lihua Yao <ylhuajnu@163.com> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-18Merge tag 'dmaengine-4.19-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull DMAengine updates from Vinod Koul: "This round brings couple of framework changes, a new driver and usual driver updates: - new managed helper for dmaengine framework registration - split dmaengine pause capability to pause and resume and allow drivers to report that individually - update dma_request_chan_by_mask() to handle deferred probing - move imx-sdma to use virt-dma - new driver for Actions Semi Owl family S900 controller - minor updates to intel, renesas, mv_xor, pl330 etc" * tag 'dmaengine-4.19-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: Add Actions Semi Owl family S900 DMA driver dt-bindings: dmaengine: Add binding for Actions Semi Owl SoCs dmaengine: sh: rcar-dmac: Should not stop the DMAC by rcar_dmac_sync_tcr() dmaengine: mic_x100_dma: use the new helper to simplify the code dmaengine: add a new helper dmaenginem_async_device_register dmaengine: imx-sdma: add memcpy interface dmaengine: imx-sdma: add SDMA_BD_MAX_CNT to replace '0xffff' dmaengine: dma_request_chan_by_mask() to handle deferred probing dmaengine: pl330: fix irq race with terminate_all dmaengine: Revert "dmaengine: mv_xor_v2: enable COMPILE_TEST" dmaengine: mv_xor_v2: use {lower,upper}_32_bits to configure HW descriptor address dmaengine: mv_xor_v2: enable COMPILE_TEST dmaengine: mv_xor_v2: move unmap to before callback dmaengine: mv_xor_v2: convert callback to helper function dmaengine: mv_xor_v2: kill the tasklets upon exit dmaengine: mv_xor_v2: explicitly freeup irq dmaengine: sh: rcar-dmac: Add dma_pause operation dmaengine: sh: rcar-dmac: add a new function to clear CHCR.DE with barrier dmaengine: idma64: Support dmaengine_terminate_sync() dmaengine: hsu: Support dmaengine_terminate_sync() ...
2018-08-17Merge tag 'powerpc-4.19-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Notable changes: - A fix for a bug in our page table fragment allocator, where a page table page could be freed and reallocated for something else while still in use, leading to memory corruption etc. The fix reuses pt_mm in struct page (x86 only) for a powerpc only refcount. - Fixes to our pkey support. Several are user-visible changes, but bring us in to line with x86 behaviour and/or fix outright bugs. Thanks to Florian Weimer for reporting many of these. - A series to improve the hvc driver & related OPAL console code, which have been seen to cause hardlockups at times. The hvc driver changes in particular have been in linux-next for ~month. - Increase our MAX_PHYSMEM_BITS to 128TB when SPARSEMEM_VMEMMAP=y. - Remove Power8 DD1 and Power9 DD1 support, neither chip should be in use anywhere other than as a paper weight. - An optimised memcmp implementation using Power7-or-later VMX instructions - Support for barrier_nospec on some NXP CPUs. - Support for flushing the count cache on context switch on some IBM CPUs (controlled by firmware), as a Spectre v2 mitigation. - A series to enhance the information we print on unhandled signals to bring it into line with other arches, including showing the offending VMA and dumping the instructions around the fault. Thanks to: Aaro Koskinen, Akshay Adiga, Alastair D'Silva, Alexey Kardashevskiy, Alexey Spirkov, Alistair Popple, Andrew Donnellan, Aneesh Kumar K.V, Anju T Sudhakar, Arnd Bergmann, Bartosz Golaszewski, Benjamin Herrenschmidt, Bharat Bhushan, Bjoern Noetel, Boqun Feng, Breno Leitao, Bryant G. Ly, Camelia Groza, Christophe Leroy, Christoph Hellwig, Cyril Bur, Dan Carpenter, Daniel Klamt, Darren Stevens, Dave Young, David Gibson, Diana Craciun, Finn Thain, Florian Weimer, Frederic Barrat, Gautham R. Shenoy, Geert Uytterhoeven, Geoff Levand, Guenter Roeck, Gustavo Romero, Haren Myneni, Hari Bathini, Joel Stanley, Jonathan Neuschäfer, Kees Cook, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring, Mathieu Malaterre, Mauro S. M. Rodrigues, Michael Hanselmann, Michael Neuling, Michael Schmitz, Mukesh Ojha, Murilo Opsfelder Araujo, Nicholas Piggin, Parth Y Shah, Paul Mackerras, Paul Menzel, Ram Pai, Randy Dunlap, Rashmica Gupta, Reza Arbab, Rodrigo R. Galvao, Russell Currey, Sam Bobroff, Scott Wood, Shilpasri G Bhat, Simon Guo, Souptick Joarder, Stan Johnson, Thiago Jung Bauermann, Tyrel Datwyler, Vaibhav Jain, Vasant Hegde, Venkat Rao, zhong jiang" * tag 'powerpc-4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (234 commits) powerpc/mm/book3s/radix: Add mapping statistics powerpc/uaccess: Enable get_user(u64, *p) on 32-bit powerpc/mm/hash: Remove unnecessary do { } while(0) loop powerpc/64s: move machine check SLB flushing to mm/slb.c powerpc/powernv/idle: Fix build error powerpc/mm/tlbflush: update the mmu_gather page size while iterating address range powerpc/mm: remove warning about ‘type’ being set powerpc/32: Include setup.h header file to fix warnings powerpc: Move `path` variable inside DEBUG_PROM powerpc/powermac: Make some functions static powerpc/powermac: Remove variable x that's never read cxl: remove a dead branch powerpc/powermac: Add missing include of header pmac.h powerpc/kexec: Use common error handling code in setup_new_fdt() powerpc/xmon: Add address lookup for percpu symbols powerpc/mm: remove huge_pte_offset_and_shift() prototype powerpc/lib: Use patch_site to patch copy_32 functions once cache is enabled powerpc/pseries: Fix endianness while restoring of r3 in MCE handler. powerpc/fadump: merge adjacent memory ranges to reduce PT_LOAD segements powerpc/fadump: handle crash memory ranges array index overflow ...
2018-08-16ASoC: rt5514: Fix the issue of the delay volume applied againOder Chiou
After our evaluation, we need to modify the default values to make sure the volume applied immediately. Signed-off-by: Oder Chiou <oder_chiou@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-16ASoC: max98373: Added speaker FS gain cotnrol register to volatile.Ryan Lee
2018-08-15ALSA: update dell-wmi mic-mute registration to new world orderLinus Torvalds
Commit c647f806b8c2 ("ALSA: hda - Allow multiple ADCs for mic mute LED controls") changed the return value of the snd_hda_gen_add_micmute_led() without actually updating the callers. Admittedly, almost no callers actually cared about the return value. But one call site very much did: the Dell wmi code. It would see the registration return zero, which _used_ to mean "failed" but now means "success", and clear the dell_micmute_led_set_func pointer. End result: the successful registration would end up calling the Dell code that thought it had all failed, and call through a NULL pointer. To make matters worse, it ends up being a tail-call, and with the retpoline sequence you don't even see the caller (dell_micmute_update()) in the stack trace, so the error ended up way less obvious than it should have been. Fixes: c647f806b8c2 "ALSA: hda - Allow multiple ADCs for mic mute LED controls" Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-15ASoC: dapm: Fix NULL pointer deference on CODEC to CODEC DAIsCharles Keepax
Commit a655de808cbde ("ASoC: core: Allow topology to override machine driver FE DAI link config.") caused soc_dai_hw_params to be come dependent on the substream private_data being set with a pointer to the snd_soc_pcm_runtime. Currently, CODEC to CODEC links don't set this, which causes a NULL pointer dereference: [<4069de54>] (soc_dai_hw_params) from [<40694b68>] (snd_soc_dai_link_event+0x1a0/0x380) Since the ASoC core in general assumes that the substream private_data will be set to a pointer to the snd_soc_pcm_runtime, update the CODEC to CODEC links to respect this. Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-14ALSA: seq: virmidi: Fix discarding the unsubscribed outputTakashi Iwai
The recent change to move the virmidi output processing to a work slightly modified the code to discard the unsubscribed outputs so that it works without a temporary buffer. However, this is actually buggy, and may spew a kernel warning due to the unexpected call of snd_rawmidi_transmit_ack(), as triggered by syzbot. This patch takes back to the original code in that part, use a temporary buffer and simply repeat snd_rawmidi_transmit(), in order to address the regression. Fixes: f7debfe54090 ("ALSA: seq: virmidi: Offload the output event processing") Reported-by: syzbot+ec5f605c91812d200367@syzkaller.appspotmail.com Signed-off-by: Takashi Iwai <tiwai@suse.de>
2018-08-14ASoC: Intel: Skylake: Acquire irq after RIRB allocationYong Zhi
Cold reboot stress test found that the hda irq could access rirb ring buffer before its memory gets allocated which resulting in null pointer dereference inside snd_hdac_bus_update_rirb(). Fix it by moving the skl_acquire_irq after ring buffer allocation. While here, also change err return from -EBUSY to actual error code. Signed-off-by: Yong Zhi <yong.zhi@intel.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-14ASoC: wm9712: fix replace codec to componentMarcel Ziswiler
Since commit 143b44845d87 ("ASoC: wm9712: replace codec to component") "wm9712-codec" got renamed to "wm9712-component", however, this change never got propagated down to the actual board/platform drivers. E.g. on Colibri T20 this lead to the following spew upon boot with sound/touch being broken: [ 2.214121] tegra-snd-wm9712 sound: ASoC: CODEC DAI wm9712-hifi not registered [ 2.222137] tegra-snd-wm9712 sound: snd_soc_register_card failed (-517) ... [ 2.344384] tegra-snd-wm9712 sound: ASoC: CODEC DAI wm9712-hifi not registered [ 2.351885] tegra-snd-wm9712 sound: snd_soc_register_card failed (-517) ... [ 2.668339] tegra-snd-wm9712 sound: ASoC: CODEC DAI wm9712-hifi not registered [ 2.675811] tegra-snd-wm9712 sound: snd_soc_register_card failed (-517) ... [ 3.208408] tegra-snd-wm9712 sound: ASoC: CODEC DAI wm9712-hifi not registered [ 3.216312] tegra-snd-wm9712 sound: snd_soc_register_card failed (-517) ... [ 3.235397] tegra-snd-wm9712 sound: ASoC: CODEC DAI wm9712-hifi not registered [ 3.248938] tegra-snd-wm9712 sound: snd_soc_register_card failed (-517) ... [ 14.970443] ALSA device list: [ 14.996628] No soundcards found. This commit finally fixes this again. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2018-08-14ASoC: Intel: bytcr_rt5640: Add quirks for 2 more devicesHans de Goede
Add quirks to select the right input-map, jack-detect pin, etc. for: Linx Linx7 tablet Onda V975w tablet Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-13Merge tag 'asoc-v4.19' of ↵Takashi Iwai
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v4.19 A fairly big update, including quite a bit of core activity this time around (which is good to see) along with a fairly large set of new drivers. - A new snd_pcm_stop_xrun() helper which is now used in several drivers. - Support for providing name prefixes to generic component nodes. - Quite a few fixes for DPCM as it gains a bit wider use and more robust testing. - Generalization of the DIO2125 support to a simple amplifier driver. - Accessory detection support for the audio graph card. - DT support for PXA AC'97 devices. - Quirks for a number of new x86 systems. - Support for AM Logic Meson, Everest ES7154, Intel systems with RT5682, Qualcomm QDSP6 and WCD9335, Realtek RT5682 and TI TAS5707.
2018-08-12Merge branch 'for-next' into for-linusTakashi Iwai
Preparation for 4.19 merge material. Signed-off-by: Takashi Iwai <tiwai@suse.de>
