path: root/sound
2005-05-06[PATCH] fix alsa via82xx resumeJens Axboe
Trying software suspend on my workstation makes it crash on resume. The problem is that via82xx marks the chip_init function as _devinit, but calls it on resume as well. Cc: <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] Add CXT48 to modem black list in ac97Herbert Xu
The following patch works around the misdetection of the CXT48 codec as a modem by the OSS ac97 driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] interwave needs isa pnpAndrew Morton
Fix bug #4509 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] intel8x0: fix for Intel AC'97 audio driverJason Gaston
This patch fixes a typo in the Intel AC'97 audio driver intel8x0.c for Intel ESB2. Signed-off-by: Jason Gaston <Jason.d.gaston@intel.com> Cc: <tiwai@suse.de> Cc: <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] ppc32: More fixlet for pmac soundBenjamin Herrenschmidt
As Al Viro noticed, my previous fix missed one instance of "device" in the driver local debug code. Harmless unless you tweak the #define's in there but still work fixing. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] ppc32: Small build fix for alsa powermacBenjamin Herrenschmidt
My newer iMac mini driver doesn't build with verbose debug enabled. This fixes it, and removes an erroneous error printk (since it's normal on some machine to not find some gpios on the "first try"). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] sound/oss/sonicvibes.c: fix an array overflowAdrian Bunk
This patch fixes an array overflow found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] hda_intel: Intel ESB2 supportJason Gaston
This adds the Intel ESB2 HD Audio DID to the hda_intel.c audio driver. Signed-off-by:  Jason Gaston <Jason.d.gaston@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] pmac: save master volume on sleepColin Leroy
Ben's patch that shutdowns master switch and restores it after resume ("pmac: Improve sleep code of tumbler driver") isn't enough here on an iBook (snapper chip). The master switch is correctly saved and restored, but somehow tumbler_put_master_volume() gets called just after tumbler_set_master_volume() and sets mix->master_vol[*] to 0. So, on resuming, the master switch is reenabled, but the volume is set to 0. Here's a patch that also saves and restores master_vol. Signed-off-by: Colin Leroy <colin@colino.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] ppc32: add sound support for Mac MiniBenjamin Herrenschmidt
This patch applies on top of my previous g5 related sound patches and adds support for the Mac Mini to the PowerMac Alsa driver. However, I haven't found any kind of HW support for volume control on this machine. If it exist, it's well hidden. That means that you probably want to make sure you use software with the ability to do soft volume control, or use Alsa 0.9 pre-release with the softvol plugin. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] ppc64: improve g5 sound headphone muteBenjamin Herrenschmidt
This patch fixes a couple more issues with the management of the GPIOs dealing with headphone and line out mute on the G5. It should fix the remaining problems of people not getting any sound out of the headphone jack. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-26[PATCH] fix SND_POWERMAC dependenciesAl Viro
This beast is pmac-only; moreover, it won't build on other subarchitectures. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[PATCH] msnd_pinnacle GFP fixAl Viro
Dumb typo - __get_free_page() takes gfp mask (in this case - GFP_KERNEL), not the page size... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] let SOUND_AD1889 depend on PCIAdrian Bunk
Compiling SOUND_AD1889 with PCI=n results in the following compile error: sound/built-in.o(.text+0x24f0c): In function `ad1889_remove': : undefined reference to `pci_release_region' This patch adds the missing dependency on PCI. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] opl3sa2: MODULE_PARM_DESCMagnus Damm
opl3sa2: Fix "irq"-parameter name typo for parameter description. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in rest of the treePavel Machek
This fixes u32 vs. pm_message_t confusion in remaining places. Fortunately there's few of them. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix pm_message_t vs. u32 in alsaPavel Machek
I thought I'm done with fixing u32 vs. pm_message_t ... unfortunately that turned out not to be the case as Russel King pointed out. This fixes last few bits in alsa. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] intel8x0: AC'97 audio patch for Intel ESB2Jason Gaston
This patch adds the Intel ESB2 DID's to the intel8x0.c file for AC'97 audio support. Signed-off-by:  Jason Gaston <Jason.d.gaston@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] ppc64: very basic desktop g5 sound supportBenjamin Herrenschmidt
This patch hacks the current PowerMac Alsa driver to add some basic support of analog sound output to some desktop G5s. It has severe limitations though: - Only 44100Khz 16 bits - Only work on G5 models using a TAS3004 analog code, that is early single CPU desktops and all dual CPU desktops at this date, but none of the more recent ones like iMac G5. - It does analog only, no digital/SPDIF support at all, no native AC3 support Better support would require a complete rewrite of the driver (which I am working on, but don't hold your breath), to properly support the diversity of apple sound HW setup, including dual codecs, several i2s busses, all the new codecs used in the new machines, proper clock switching with digital, etc etc etc... This patch applies on top of the other PowerMac sound patches I posted in the past couple of days (new powerbook support and sleep fixes). Note: This is a FAQ entry for PowerMac sound support with TI codecs: They have a feature called "DRC" which is automatically enabled for the internal speaker (at least when auto mute control is enabled) which will cause your sound to fade out to nothing after half a second of playback if you don't set a proper "DRC Range" in the mixer. So if you have a problem like that, check alsamixer and raise your DRC Range to something reasonable. Note2: This patch will also add auto-mute of the speaker when line-out jack is used on some earlier desktop G4s (and on the G5) in addition to the headphone jack. If that behaviour isn't what you want, just disable auto-muting and use the manual mute controls in alsamixer. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] pmac: Improve sleep code of tumbler driverBenjamin Herrenschmidt
This patch improves the behaviour of the "tumbler/snapper" driver used on newer PowerMacs during sleep. It properly set the HW mutes to shut down amplifiers and does an analog shutdown of the codec. That might improve power consumption during sleep on a number of machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] pmac: sound support for latest laptopsBenjamin Herrenschmidt
This patch hacks the current Alsa snd-powermac driver to add support for recent machine models with the tas3004 chip, that is basically new laptop models. The Mac Mini is _NOT_ yet supported by this patch (soon soon ...). The G5s (iMac or Desktop) will need the rewritten sound driver on which I'm working on (I _might_ get a hack for analog only on some G5s on the current driver, but no promise). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
