path: root/sound
2013-05-07ASoC: max98088: Fix logging of hardware revision.Dylan Reid
commit 98682063549bedd6e2d2b6b7222f150c6fbce68c upstream. The hardware revision of the codec is based at 0x40. Subtract that before convering to ASCII. The same as it is done for 98095. Signed-off-by: Dylan Reid <dgreid@chromium.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ALSA: usb-audio: Fix autopm error during probingTakashi Iwai
commit 60af3d037eb8c670dcce31401501d1271e7c5d95 upstream. We've got strange errors in get_ctl_value() in mixer.c during probing, e.g. on Hercules RMX2 DJ Controller: ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x201, wIndex = 0xa00, type = 4 ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xa00, type = 4 .... It turned out that the culprit is autopm: snd_usb_autoresume() returns -ENODEV when called during card->probing = 1. Since the call itself during card->probing = 1 is valid, let's fix the return value of snd_usb_autoresume() as success. Reported-and-tested-by: Daniel Schürmann <daschuer@mixxx.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ALSA: usb-audio: disable autopm for MIDI devicesClemens Ladisch
commit cbc200bca4b51a8e2406d4b654d978f8503d430b upstream. Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) introduced autopm for all USB audio/MIDI devices. However, many MIDI devices, such as synthesizers, do not merely transmit MIDI messages but use their MIDI inputs to control other functions. With autopm, these devices would get powered down as soon as the last MIDI port device is closed on the host. Even some plain MIDI interfaces could get broken: they automatically send Active Sensing messages while powered up, but as soon as these messages cease, the receiving device would interpret this as an accidental disconnection. Commit f5f165418cab (ALSA: usb-audio: Fix missing autopm for MIDI input) introduced another regression: some devices (e.g. the Roland GAIA SH-01) are self-powered but do a reset whenever the USB interface's power state changes. To work around all this, just disable autopm for all USB MIDI devices. Reported-by: Laurens Holst Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINTDaniel Mack
commit ebfc594c02148b6a85c2f178cf167a44a3c3ce10 upstream. The USB_DT_CS_ENDPOINT class-specific endpoint descriptor is usually stuffed directly after the standard USB endpoint descriptor, and this is where the driver currently expects it to be. There are, however, devices in the wild that have it the other way around in their descriptor sets, so the USB_DT_CS_ENDPOINT comes *before* the standard enpoint. Devices known to implement it that way are "Sennheiser BTD-500" and Plantronics USB headsets. When the driver can't find the USB_DT_CS_ENDPOINT, it won't be able to change sample rates, as the bitmask for the validity of this command is storen in bmAttributes of that descriptor. Fix this by searching the entire interface instead of just the extra bytes of the first endpoint, in case the latter fails. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Torstein Hegge <hegge@resisty.net> Reported-and-tested-by: Yves G <alsa-user@vivigatt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25vm: convert snd_pcm_lib_mmap_iomem() to vm_iomap_memory() helperLinus Torvalds
commit 0fe09a45c4848b5b5607b968d959fdc1821c161d upstream. This is my example conversion of a few existing mmap users. The pcm mmap case is one of the more straightforward ones. Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16ASoC: wm8903: Fix the bypass to HP/LINEOUT when no DAC or ADC is runningAlban Bedel
commit f1ca493b0b5e8f42d3b2dc8877860db2983f47b6 upstream. The Charge Pump needs the DSP clock to work properly, without it the bypass to HP/LINEOUT is not working properly. This requirement is not mentioned in the datasheet but has been confirmed by Mark Brown from Wolfson. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16ALSA: usb-audio: fix endianness bug in snd_nativeinstruments_*Eldad Zack
commit 889d66848b12d891248b03abcb2a42047f8e172a upstream. The usb_control_msg() function expects __u16 types and performs the endianness conversions by itself. However, in three places, a conversion is performed before it is handed over to usb_control_msg(), which leads to a double conversion (= no conversion): * snd_usb_nativeinstruments_boot_quirk() * snd_nativeinstruments_control_get() * snd_nativeinstruments_control_put() Caught by sparse: sound/usb/mixer_quirks.c:512:38: warning: incorrect type in argument 6 (different base types) sound/usb/mixer_quirks.c:512:38: expected unsigned short [unsigned] [usertype] index sound/usb/mixer_quirks.c:512:38: got restricted __le16 [usertype] <noident> sound/usb/mixer_quirks.c:543:35: warning: incorrect type in argument 5 (different base types) sound/usb/mixer_quirks.c:543:35: expected unsigned short [unsigned] [usertype] value sound/usb/mixer_quirks.c:543:35: got restricted __le16 [usertype] <noident> sound/usb/mixer_quirks.c:543:56: warning: incorrect type in argument 6 (different base types) sound/usb/mixer_quirks.c:543:56: expected unsigned short [unsigned] [usertype] index sound/usb/mixer_quirks.c:543:56: got restricted __le16 [usertype] <noident> sound/usb/quirks.c:502:35: warning: incorrect type in argument 5 (different base types) sound/usb/quirks.c:502:35: expected unsigned short [unsigned] [usertype] value sound/usb/quirks.c:502:35: got restricted __le16 [usertype] <noident> Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12ALSA: hda - fix typo in proc outputDavid Henningsson
commit aeb3a97222832e5457c4b72d72235098ce4bfe8d upstream. Rename "Digitial In" to "Digital In". This function is only used for proc output, so should not cause any problems to change. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12ALSA: hda - Enabling Realtek ALC 671 codecRainer Koenig
commit 1d87caa69c04008e09f5ff47b5e6acb6116febc7 upstream. * Added the device ID to the modalias list and assinged ALC662 patches for it * Added 4 port support for the device ID 0671 in alc662_parse_auto_config Signed-off-by: Rainer Koenig <Rainer.Koenig@ts.fujitsu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12ALSA: hda - bug fix on return value when getting HDMI ELD infoMengdong Lin
commit 2ef5692efad330b67a234e2c49edad38538751e7 upstream. In function snd_hdmi_get_eld(), the variable 'ret' should be initialized to 0. Otherwise it will be returned uninitialized as non-zero after ELD info is got successfully. Thus hdmi_present_sense() will always assume ELD info is invalid by mistake, and /proc file system cannot show the proper ELD info. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Acked-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12ASoC: dma-sh7760: Fix compile errorLars-Peter Clausen
commit 417a1178f1bf3cdc606376b3ded3a22489fbb3eb upstream. The dma-sh7760 currently fails with the following compile error: sound/soc/sh/dma-sh7760.c:346:2: error: unknown field 'pcm_ops' specified in initializer sound/soc/sh/dma-sh7760.c:346:2: warning: initialization from incompatible pointer type sound/soc/sh/dma-sh7760.c:347:2: error: unknown field 'pcm_new' specified in initializer sound/soc/sh/dma-sh7760.c:347:2: warning: initialization makes integer from pointer without a cast sound/soc/sh/dma-sh7760.c:348:2: error: unknown field 'pcm_free' specified in initializer sound/soc/sh/dma-sh7760.c:348:2: warning: initialization from incompatible pointer type sound/soc/sh/dma-sh7760.c: In function 'sh7760_soc_platform_probe': sound/soc/sh/dma-sh7760.c:353:2: warning: passing argument 2 of 'snd_soc_register_platform' from incompatible pointer type include/sound/soc.h:368:5: note: expected 'struct snd_soc_platform_driver *' but argument is of type 'struct snd_soc_platform *' This is due the misnaming of the snd_soc_platform_driver type name and 'ops' field. The issue was introduced in commit f0fba2a("ASoC: multi-component - ASoC Multi-Component Support"). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ALSA: snd-usb: mixer: ignore -EINVAL in snd_usb_mixer_controls()Daniel Mack
commit 83ea5d18d74f032a760fecde78c0210f66f7f70c upstream. Creation of individual mixer controls may fail, but that shouldn't cause the entire mixer creation to fail. Even worse, if the mixer creation fails, that will error out the entire device probing. All the functions called by parse_audio_unit() should return -EINVAL if they find descriptors that are unsupported or believed to be malformed, so we can safely handle this error code as a non-fatal condition in snd_usb_mixer_controls(). That fixes a long standing bug which is commonly worked around by adding quirks which make the driver ignore entire interfaces. Some of them might now be unnecessary. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Rodolfo Thomazelli <pe.soberbo@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ALSA: snd-usb: mixer: propagate errors up the call chainDaniel Mack
commit 4d7b86c98e445b075c2c4c3757eb6d3d6efbe72e upstream. In check_input_term() and parse_audio_feature_unit(), propagate the error value that has been returned by a failing function instead of -EINVAL. That helps cleaning up the error pathes in the mixer. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ALSA: hda - Fix typo in checking IEC958 emphasis bitTakashi Iwai
commit a686fd141e20244ad75f80ad54706da07d7bb90a upstream. There is a typo in convert_to_spdif_status() about checking the emphasis IEC958 status bit. It should check the given value instead of the resultant value. Reported-by: Martin Weishart <martin.weishart@telosalliance.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ALSA: hda/cirrus - Fix the digital beep registrationTakashi Iwai
commit a86b1a2cd2f81f74e815e07f756edd7bc5b6f034 upstream. The argument passed to snd_hda_attach_beep_device() is a widget NID while spec->beep_amp holds the composed value for amp controls. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20ALSA: seq: Fix missing error handling in snd_seq_timer_open()Takashi Iwai
commit 66efdc71d95887b652a742a5dae51fa834d71465 upstream. snd_seq_timer_open() didn't catch the whole error path but let through if the timer id is a slave. This may lead to Oops by accessing the uninitialized pointer. BUG: unable to handle kernel NULL pointer dereference at 00000000000002ae IP: [<ffffffff819b3477>] snd_seq_timer_open+0xe7/0x130 PGD 785cd067 PUD 76964067 PMD 0 Oops: 0002 [#4] SMP CPU 0 Pid: 4288, comm: trinity-child7 Tainted: G D W 3.9.0-rc1+ #100 Bochs Bochs RIP: 0010:[<ffffffff819b3477>] [<ffffffff819b3477>] snd_seq_timer_open+0xe7/0x130 RSP: 0018:ffff88006ece7d38 EFLAGS: 00010246 RAX: 0000000000000286 RBX: ffff88007851b400 RCX: 0000000000000000 RDX: 000000000000ffff RSI: ffff88006ece7d58 RDI: ffff88006ece7d38 RBP: ffff88006ece7d98 R08: 000000000000000a R09: 000000000000fffe R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000 R13: ffff8800792c5400 R14: 0000000000e8f000 R15: 0000000000000007 FS: 00007f7aaa650700(0000) GS:ffff88007f800000(0000) GS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000002ae CR3: 000000006efec000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process trinity-child7 (pid: 4288, threadinfo ffff88006ece6000, task ffff880076a8a290) Stack: 0000000000000286 ffffffff828f2be0 ffff88006ece7d58 ffffffff810f354d 65636e6575716573 2065756575712072 ffff8800792c0030 0000000000000000 ffff88006ece7d98 ffff8800792c5400 ffff88007851b400 ffff8800792c5520 Call Trace: [<ffffffff810f354d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff819b17e9>] snd_seq_queue_timer_open+0x29/0x70 [<ffffffff819ae01a>] snd_seq_ioctl_set_queue_timer+0xda/0x120 [<ffffffff819acb9b>] snd_seq_do_ioctl+0x9b/0xd0 [<ffffffff819acbe0>] snd_seq_ioctl+0x10/0x20 [<ffffffff811b9542>] do_vfs_ioctl+0x522/0x570 [<ffffffff8130a4b3>] ? file_has_perm+0x83/0xa0 [<ffffffff810f354d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff811b95ed>] sys_ioctl+0x5d/0xa0 [<ffffffff813663fe>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81faed69>] system_call_fastpath+0x16/0x1b Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14Revert "ALSA: hda - hdmi: Make jacks phantom, if they're not detectable"Greg Kroah-Hartman
This reverts commit 30efd8debd1ef30be342d374f01e993509f5b76b upstream (dd54ec4067a23236736afecbda120030d7ce8fe9 in this tree) as it is not needed for the 3.4-stable tree. Cc: David Henningsson <david.henningsson@canonical.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14ALSA: vmaster: Fix slave change notificationTakashi Iwai
commit 2069d483b39a603a5f3428a19d3b4ac89aa97f48 upstream. When a value of a vmaster slave control is changed, the ctl change notification is sometimes ignored. This happens when the master control overrides, e.g. when the corresponding master control is muted. The reason is that slave_put() returns the value of the actual slave put callback, and it doesn't reflect the virtual slave value change. This patch fixes the function just to return 1 whenever a slave value is changed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14ALSA: ice1712: Initialize card->private_data properlySean Connor
commit 69a4cfdd444d1fe5c24d29b3a063964ac165d2cd upstream. Set card->private_data in snd_ice1712_create for fixing NULL dereference in snd_ice1712_remove(). Signed-off-by: Sean Connor <sconnor004@allyinics.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ALSA: hda - hdmi: Make jacks phantom, if they're not detectableDavid Henningsson
commit 30efd8debd1ef30be342d374f01e993509f5b76b upstream. Just as for analog codecs, a jack that isn't suitable for detection (in this case, NO_PRESENCE was set) should be a phantom Jack instead of a normal one. Thanks to Raymond Yau for spotting. BugLink: https://bugs.launchpad.net/bugs/961286 BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=903869 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ASoC: wm2200: correct IN2L and IN3L digital muteChris Rattray
commit 0d2b6422529a26ac4dee06196524ba9da70cf735 upstream. Signed-off-by: Chris Rattray <crattray@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: hda - hdmi: ELD shouldn't be valid after unplugDavid Henningsson
commit bbfd8a19b6913f50a362457c34d49bfafe5e456e upstream. Currently, eld_valid is never set to false, except at kernel module load time. This patch makes sure that eld is no longer valid when the cable is (hot-)unplugged. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: hda - Workaround for silent output on Sony Vaio VGC-LN51JGB with ALC889Fernando Luis Vazquez Cao
commit 12e31a78c70dc12897fda2489113f445c0e94a18 upstream. Some Vaio all-in-one desktop PCs (for example VGC-LN51JGB) are affected by the same issue that caused Vaio Z laptops to become silent: the speaker pin must be connected to the first DAC even though the codec itself advertises flexible routing through any of the DACs. Use the no-primary-hp fixup for choosing the speaker pin as the primary so that the right DAC is assigned on this device. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: hda - Release assigned pin/cvt at error path of hdmi_pcm_open()Takashi Iwai
commit 2ad779b7329d6894a80df94e693e72eaa0d56790 upstream. If the driver detects and invalid ELD, it gives an open error. But it forgot to release the assigned pin, converter and spdif ctls before returning. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: usb-audio: fix Roland A-PRO supportClemens Ladisch
commit 7da58046482fceb17c4a0d4afefd9507ec56de7f upstream. The quirk for the Roland/Cakewalk A-PRO keyboards accidentally used the wrong interface number, which prevented the driver from attaching to the device. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: rme32.c irq enabling after spin_lock_irqDenis Efremov
commit f49a59c4471d81a233e09dda45187cc44fda009d upstream. According to the other code in this driver and similar code in rme96 it seems, that spin_lock_irq in snd_rme32_capture_close function should be paired with spin_unlock_irq. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Denis Efremov <yefremov.denis@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: ali5451: remove irq enabling in pointer callbackDenis Efremov
commit dacae5a19b4cbe1b5e3a86de23ea74cbe9ec9652 upstream. snd_ali_pointer function is called with local interrupts disabled. However it seems very strange to reenable them in such way. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Denis Efremov <yefremov.denis@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ASoC: wm2200: correct mixer values and textChris Rattray
commit a80cc734282805e15b5e023751a4d02f7ffbcc91 upstream. Signed-off-by: Chris Rattray <crattray@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: hda - Add a fixup for Packard-Bell desktop with ALC880Takashi Iwai
commit 0712eea349d8e2b6d0e44b94a752d999319027fb upstream. A Packard-Bell desktop machine gives no proper pin configuration from BIOS. It's almost equivalent with the 6stack+fp standard config, just take the existing fixup. Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=901846 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devicesClemens Ladisch
commit d56268fb108c7c21e19933588ca4d94652585183 upstream. Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0) forgot to adjust the length check for UAC 2.0 feature unit descriptors. This would make the code abort on encountering a feature unit without per-channel controls, and thus prevented the driver to work with any device having such a unit, such as the RME Babyface or Fireface UCX. Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de> Tested-by: Matthew Robbetts <wingfeathera@gmail.com> Tested-by: Michael Beer <beerml@sigma6audio.de> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ALSA: usb-audio: Fix regression by disconnection-race-fix patchTakashi Iwai
[NOTE: the regression below is found only in 3.2-3.4 stable trees, so there is no upstream commit corresponding to this patch] The recent fix for the race at disconnection of usb-audio devices (upstream commit 978520b7) triggers Oops when a device is unplugged while playing on 3.2 and 3.4 kernels. The culprit is that the shutdown flag check was wrongly added around the urb deactivation code snippet. The urb deactivation code has to be performed even after the device disconnected. Otherwise it remains undead and pokes the wild access in the end. The regression fix is simply reverting the shutdown flag check in that code. Reported-and-tested-by: Chris J Arges <christopherarges@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21ALSA: usb - fix race in creation of M-Audio Fast track pro driverDavid Henningsson
commit b98ae2729dea161edc96c9d177459b6c28bcbba5 upstream. A patch in the 3.2 kernel caused regression with hotplugging the M-Audio Fast track pro, or sound after suspend. I don't have the device so I haven't done a full analysis, but it seems userspace (both udev and pulseaudio) got confused when a card was created, immediately destroyed, and then created again. However, at least one person in the bug report (martin djfun) reports that this patch resolves the issue for him. It also leaves a message in the log: "snd-usb-audio: probe of 1-1.1:1.1 failed with error -5" which is a bit misleading. It is better than non-working audio, but maybe there's a more elegant solution? BugLink: https://bugs.launchpad.net/bugs/1095315 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ALSA: pxa27x: fix ac97 warm resetMike Dunn
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream. This patch fixes some code that implements a work-around to a hardware bug in the ac97 controller on the pxa27x. A bug in the controller's warm reset functionality requires that the mfp used by the controller as the AC97_nRESET line be temporarily reconfigured as a generic output gpio (AF0) and manually held high for the duration of the warm reset cycle. This is what was done in the original code, but it was broken long ago by commit fb1bf8cd ([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset()) which changed the mfp to a GPIO input instead of a high output. The fix requires the ac97 controller to obtain the gpio via gpio_request_one(), with arguments that configure the gpio as an output initially driven high. Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a warm reset on hardware that lacks a pull-up on the line, which appears to be the case for me. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ALSA: pxa27x: fix ac97 cold resetMike Dunn
commit 41b645c8624df6ace020a8863ad1449d69140f7d upstream. Cold reset on the pxa27x currently fails and pxa2xx_ac97_try_cold_reset: cold reset timeout (GSR=0x44) appears in the kernel log. Through trial-and-error (the pxa270 developer's manual is mostly incoherent on the topic of ac97 reset), I got cold reset to complete by setting the WARM_RST bit in the GCR register (and later noticed that pxa3xx does this for cold reset as well). Also, a timeout loop is needed to wait for the reset to complete. Tested on a palm treo 680 machine. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm5100: Remove DSP B and left justified formatsMark Brown
commit 5f960294e2031d12f10c8488c3446fecbf59628d upstream. These are not supported Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2200: Remove DSP B and left justified AIF modesMark Brown
commit 0cc411b934c4317b363d1af993549f391852b980 upstream. These are not supported. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2200: Fix setting dai format in wm2200_set_fmtAxel Lin
commit 2a5f431592343b78896013b055582f94c12a5049 upstream. According to the defines in wm2200.h: /* * R1284 (0x504) - Audio IF 1_5 */ We should not left shift 1 bit for fmt_val when setting dai format. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: wm2000: Fix sense of speech clarity enableMark Brown
commit 267f8fa2e1eef0612b2007e1f1846bcbc35cc1fa upstream. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ASoC: sigmadsp: Fix endianness conversion issueLars-Peter Clausen
commit a3adb1432d7a3ad86bb17a1638e44414537e4118 upstream. The 'addr' field of the sigma_action struct is stored as big endian in the firmware file. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Fix pin configuration of HP Pavilion dv7Takashi Iwai
commit 8ae5865ec77c22462c736846a0679947a6953548 upstream. Fix the quirk entry for HP Pavilion dv7 in order to make the bass speaker working. Reported-and-tested-by: Tomas Pospisek <tpo2@sourcepole.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixupTakashi Iwai
commit b78562b10fa66175e30b76073e32a0ad8d92aa83 upstream. The workaround to force VREF50 for dallas/hp model with ALC861VD was introduced in commit 8fdcb6fe4204bdb4c6991652717ab5063751414e, but it contained wrong pincap override bits. This patch fixes to exclude VREF80 pincap bit correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Fix missing autopm for MIDI inputTakashi Iwai
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream. The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added the support of autopm for USB MIDI output, but it didn't take the MIDI input into account. This patch adds the following for fixing the autopm: - Manage the URB start at the first MIDI input stream open, instead of the time of instance creation - Move autopm code to the common substream_open() - Make snd_usbmidi_input_start/_stop() more robust and add the running state check Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Avoid autopm calls after disconnectionTakashi Iwai
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream. Add a similar protection against the disconnection race and the invalid use of usb instance after disconnection, as well as we've done for the USB audio PCM. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201 Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17ASoC: dmaengine: Correct Makefile when sound is built as modulePeter Ujfalusi
commit 961a7aeafab477f63d9eef26afde9cbb8badcd0f upstream. soc-dmaengine-pcm library need to be part of the snd-soc-core in order to be able to compile ASoC as modules when dmaengine is enabled on the platform. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Add support for Realtek ALC292David Henningsson
commit af02dde8a609d8d071c4b31a82df811a55690a4a upstream. We found a new codec ID 292, and that just a simple quirk would enable sound output/input on this ALC292 chip. BugLink: https://bugs.launchpad.net/bugs/1081466 Tested-by: Acelan Kao <acelan.kao@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Fix missing beep on ASUS X43U notebookDuncan Roe
commit 7110005e8d5c3cd418fc4b64f9f124f004422a9a upstream. Signed-off-by: Duncan Roe <duncan_roe@acslink.net.au> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Add new codec ALC283 ALC290 supportKailang Yang
commit 7ff34ad80b7080fafaac8efa9ef0061708eddd51 upstream. These are compatible with standard ALC269 parser. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: hda - Cirrus: Correctly clear line_out_pins when moving to speakerDavid Henningsson
commit 34c3d1926bdaf45d3a891dd577482abcdd9faa34 upstream. If this array is not cleared, the jack related code later might fail to create "Internal Speaker Phantom Jack" on Dell Inspiron 3420 and Dell Vostro 2420. BugLink: https://bugs.launchpad.net/bugs/1076840 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: ua101, usx2y: fix broken MIDI outputClemens Ladisch
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream. Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added autosuspend code to all files making up the snd-usb-audio driver. However, midi.c is part of snd-usb-lib and is also used by other drivers, not all of which support autosuspend. Thus, calls to usb_autopm_get_interface() could fail, and this unexpected error would result in the MIDI output being completely unusable. Make it work by ignoring the error that is expected with drivers that do not support autosuspend. Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com> Reported-by: Devin Venable <venable.devin@gmail.com> Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk> Reported-by: Jannis Achstetter <jannis_achstetter@web.de> Reported-by: Rui Nuno Capela <rncbc@rncbc.org> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03ALSA: snd-usb-caiaq: initialize card pointerDaniel Mack
commit da185443c12f5ef7416af50293833a5654854186 upstream. Fixes the following warning: CC [M] sound/usb/caiaq/device.o sound/usb/caiaq/device.c: In function ‘snd_probe’: sound/usb/caiaq/device.c:500:16: warning: ‘card’ may be used uninitialized in this function [-Wmaybe-uninitialized] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
