path: root/sound
2009-12-10vfs: Implement proper O_SYNC semanticsChristoph Hellwig
While Linux provided an O_SYNC flag basically since day 1, it took until Linux 2.4.0-test12pre2 to actually get it implemented for filesystems, since that day we had generic_osync_around with only minor changes and the great "For now, when the user asks for O_SYNC, we'll actually give O_DSYNC" comment. This patch intends to actually give us real O_SYNC semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC patches which are required before this patch it's actually surprisingly simple, we just need to figure out when to set the datasync flag to vfs_fsync_range and when not. This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's numerical value to keep binary compatibility, and adds a new real O_SYNC flag. To guarantee backwards compatiblity it is defined as expanding to both the O_DSYNC and the new additional binary flag (__O_SYNC) to make sure we are backwards-compatible when compiled against the new headers. This also means that all places that don't care about the differences can just check O_DSYNC and get the right behaviour for O_SYNC, too - only places that actuall care need to check __O_SYNC in addition. Drivers and network filesystems have been updated in a fail safe way to always do the full sync magic if O_DSYNC is set. The few places setting O_SYNC for lower layers are kept that way for now to stay failsafe. We enforce that O_DSYNC is set when __O_SYNC is set early in the open path to make sure we always get these sane options. Note that parisc really screwed up their headers as they already define a O_DSYNC that has always been a no-op. We try to repair it by using it for the new O_DSYNC and redefinining O_SYNC to send both the traditional O_SYNC numerical value _and_ the O_DSYNC one. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: ice1724 - aureon - modify WM8770 Master & DAC volume ALSA: hda/realtek: quirk for D945GCLF2 mainboard ALSA: hda - Terradici HDA controllers does not support 64-bit mode ALSA: document: Add direct git link to grub hda-analyzer ALSA: radio/sound/miro: fix build, cleanup depends/selects ALSA: hda - Generalize EAPD inversion check in patch_analog.c ASoC: Wrong variable returned on error ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKII ALSA: hda - Exclude unusable ADCs for ALC88x ALSA: hda - Add missing Line-Out and PCM switches as slave ALSA: hda - iMac 9,1 sound patch. ALSA: opti93x: set MC indirect registers base from PnP data
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09Merge branch 'topic/asoc' into for-linusTakashi Iwai
2009-12-09Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-09ALSA: ice1724 - aureon - modify WM8770 Master & DAC volumeJaroslav Kysela
The volume levels in original implementation are incorrect and does not match the dB scale. The real range is linear (in the sense of the dB scale) from 0dB to -100dB. Remove logaritmic table and make all volumes from range 0dB..100dB. The tests are in RedHat's bugzilla #540817. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09ALSA: hda/realtek: quirk for D945GCLF2 mainboardDavid Santinoli
Quirk for the ALC662 found on the Intel D945GCLF2 (and possibly other) mainboards. Signed-off-by: David Santinoli <david@santinoli.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09ALSA: hda - Terradici HDA controllers does not support 64-bit modeJaroslav Kysela
Confirmed from vendor and tests in RedHat bugzilla #536782 . Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: hda - Generalize EAPD inversion check in patch_analog.cTakashi Iwai
Add a flag to spec field so that the EAPD inversion can be checked outside the relevant control callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (149 commits) arm: omap: Add omap3_defconfig AM35xx: Defconfig for AM3517 EVM board AM35xx: Add support for AM3517 EVM board omap: 3630sdp: defconfig creation omap: 3630sdp: introduce 3630 sdp board support omap3: Add defconfig for IGEP v2 board omap3: Add minimal IGEP v2 support omap3: Add CompuLab CM-T35 defconfig omap3: Add CompuLab CM-T35 board support omap3: rx51: Add wl1251 wlan driver support omap3: rx51: Add SDRAM init omap1: Add default kernel configuration for Herald omap1: Add board support and LCD for HTC Herald omap: zoom2: update defconfig for LL_DEBUG_NONE omap: zoom3: defconfig creation omap3: zoom: Introduce zoom3 board support omap3: zoom: Drop i2c-1 speed to 2400 omap3: zoom: rename zoom2 name to generic zoom omap3: zoom: split board file for software reuse omap3evm: MIgrate to smsc911x ethernet driver ... Fix trivial conflict (two unrelated config options added next to each other) in arch/arm/mach-omap2/Makefile
2009-12-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (294 commits) S3C64XX: Staticise platform data for PCM devices ASoC: Rename controls with a / in wm_hubs snd-fm801: autodetect SF64-PCR (tuner-only) card ALSA: tea575x-tuner: fix mute ASoC: au1x: dbdma2: plug memleak in pcm device creation error path ASoC: au1x: dbdma2: fix oops on soc device removal. ALSA: hda - Fix memory leaks in the previous patch ALSA: hda - Add ALC661/259, ALC892/888VD support ALSA: opti9xx: remove snd_opti9xx fields ALSA: aaci - Clean up duplicate code ALSA: usb - Fix mixer map for Hercules Gamesurround Muse Pocket LT ALSA: hda - Add position_fix quirk for HP dv3 ALSA: hda - Add a pin-fix for FSC Amilo Pi1505 ALSA: hda - Fix Cxt5047 test mode ASoC: pxa/raumfeld: adopt new snd_soc_dai_set_pll() API ASoC: sh: fsi: Add runtime PM support sh: ms7724se: Add runtime PM support for FSI ALSA: hda - Add a position_fix quirk for MSI Wind U115 ALSA: opti-miro: add PnP detection ALSA: opti-miro: separate comon probing code ...
2009-12-08ASoC: Wrong variable returned on errorRoel Kluin
The wrong variable was returned in the case of an error Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-08ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKIITobias Hansen
I added the product IDs of the new revisions of the devices, so owners can test whether this suffices to make them work. Patched against ALSA snapshot 20091207. Signed-off-by: Tobias Hansen <Tobias.Hansen at physik.uni-hamburg.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: hda - Exclude unusable ADCs for ALC88xTakashi Iwai
On Realtek codecs, a digital mic pin is connected often only to a single ADC. But the parser tries to set up all ADCs no matter whether the digital mic is available, and results in non-selectable input source. This patch adds a check of input-source availability of each ADC, and excludes ones that don't support all input sources. Reference: Novell bnc#561235 http://bugzilla.novell.com/show_bug.cgi?id=561235 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: hda - Add missing Line-Out and PCM switches as slaveTakashi Iwai
Realtek codecs may have "PCM" and "Line-Out" playback switches, and they can be slaves for vmaster. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: hda - iMac 9,1 sound patch.Justin P. Mattock
This is an updated patch for the Apple iMac 9,1 model to add sound. Original patch posted here: http://article.gmane.org/gmane.linux.alsa.devel/61361/match= I have been using this patch for a while now and have to say it works vary well, except for a few minor things: With the iMac 24-inch 3.06GHz Intel Core 2 Duo everything seems to be working as it should, although I have not looked into the microphone (never really use one, nor have any apps to test, my guess is it doesn't work, or I never figured out how to get it to work). With the iMac 24-inch 2.66GHz Intel Core 2 Duo everything is the same as with the above machine except I'm hearing a light scratchy/distortion noise come out of the speakers when using headphones(above machine does not do this). Other than that the sound level is great(especially with good Dj headphones). Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Tested-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: opti93x: set MC indirect registers base from PnP dataKrzysztof Helt
The PnP data on the OPTI931 and OPTI933 contains io port range for the MC indirect registers. Use the PnP range instead of hardwired value 0xE0E. Also, request region of MC indirect registers so it is marked as used to other drivers (this was missing previously). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
2009-12-04Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-12-04Merge branch 'topic/asoc' into for-linusTakashi Iwai
2009-12-04Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-12-04Merge branch 'topic/core-change' into for-linusTakashi Iwai
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04tree-wide: fix typos "couter" -> "counter"Uwe Kleine-König
This patch was generated by git grep -E -i -l 'couter' | xargs -r perl -p -i -e 's/couter/counter/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04ASoC: Rename controls with a / in wm_hubsJoonyoung Shim
This renames from a character / to : of controls. A / occurs below error messages. ASoC: Failed to create IN2RP/VXRP debugfs file ASoC: Failed to create IN2LP/VXRN debugfs file Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-03snd-fm801: autodetect SF64-PCR (tuner-only) cardOndrej Zary
When primary AC97 is not found, don't fail with tons of AC97 errors. Assume that the card is SF64-PCR (tuner-only). This makes the SF64-PCR radio card work "out of the box". Also fixes a bug that can cause an oops here:         if (tea575x_tuner > 0 && (tea575x_tuner & 0x000f) < 4) { when tea575x_tuner == 16, it passes this check and causes problems a couple lines below:         chip->tea.ops = &snd_fm801_tea_ops[(tea575x_tuner & 0x000f) - 1]; Tested with SF64-PCR, but I don't have any of those sound or sound+radio cards to test if I didn't break anything. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-03ALSA: tea575x-tuner: fix muteOndrej Zary
Fix mute state reporting in tea575x-tuner. This fixes mute function in kradio on SF64-PCR radio card. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-03ASoC: au1x: dbdma2: plug memleak in pcm device creation error pathManuel Lauss
free the allocated pcm platform device in the error path. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-03ASoC: au1x: dbdma2: fix oops on soc device removal.Manuel Lauss
platform_device_unregister() frees resources for us, no need to do it explicitly. Fixes an oops when machine code removes the soc-audio device. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-03ALSA: hda - Fix memory leaks in the previous patchTakashi Iwai
The previous hack for replacing the codec name give memory leaks at error paths. This patch fixes them. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-03ALSA: hda - Add ALC661/259, ALC892/888VD supportKailang Yang
Fixed List: 1. Add alc_read_coef_idx function 2. Add ALC661 ALC259 3. Add ALC892 ALC888VD Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-02ALSA: opti9xx: remove snd_opti9xx fieldsKrzysztof Helt
Remove snd_opti9xx fields which are indirect arguments to the snd_opti9xx_configure(). Pass these values as function arguments. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01ALSA: aaci - Clean up duplicate codeTakashi Iwai
Now snd_ac97_pcm_open() is called with the exactly same arguments for both playback and capture directions. Remove the unneeded check. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01ALSA: usb - Fix mixer map for Hercules Gamesurround Muse Pocket LTAlexey Fisher
Muse Pocket use brocken mixer names, so alsamixer and PA can't use it correctly This patch add quirk to overwirte default mixers. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01Merge branch 'topic/pcm-dma-fix' into topic/core-changeTakashi Iwai
2009-12-01Merge branch 'topic/beep-rename' into topic/core-changeTakashi Iwai
2009-12-01Merge branch 'topic/ice1724-quartet' into topic/hdaTakashi Iwai
2009-12-01Merge branch 'topic/oxygen' into topic/hdaTakashi Iwai
2009-12-01ALSA: hda - Add position_fix quirk for HP dv3Takashi Iwai
HP dv3 requires position_fix=1. Reference: Novell bnc#555935 https://bugzilla.novell.com/show_bug.cgi?id=555935 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01ALSA: hda - Add a pin-fix for FSC Amilo Pi1505Takashi Iwai
FSC Amilo Pi 1505 has a buggy BIOS and doesn't set up the HP and speaker pins properly. Add the pinfix entry for that. Reference: Novell bnc#557403 https://bugzilla.novell.com/show_bug.cgi?id=557403 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-11-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: AACI: fix recording bug ALSA: AACI: fix AC97 multiple-open bug ASoC: AIC23: Fixing infinite loop in resume path ASoC: Fix suspend with active audio streams
2009-11-30ALSA: hda - Fix Cxt5047 test modeTakashi Iwai
The NID 0x1a of Conexant 5047 chip is a mic boost volume only with the output amp unlike 5045 chip. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: AACI: fix recording bugRussell King
pcm->r[1].slots is the double rate slot information, not the capture information. For capture, 'pcm' will already be the capture ac97 pcm structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: AACI: fix AC97 multiple-open bugRussell King
2009-11-30Merge branch 'fix/asoc' into fix/miscTakashi Iwai
2009-11-30ASoC: pxa/raumfeld: adopt new snd_soc_dai_set_pll() APIDaniel Mack
ALSA's for-2.6.33 branch has a new source argument to snd_soc_dai_set_pll(). Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-30ASoC: sh: fsi: Add runtime PM supportKuninori Morimoto
This patch add support runtime PM. Driver callbacks for Runtime PM are empty because the device registers are always re-initialized after pm_runtime_get_sync(). The Runtime PM functions replaces the clock framework module stop bit handling in this driver. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-30ALSA: hda - Add a position_fix quirk for MSI Wind U115Takashi Iwai
MSI Wind U115 seems to require position_fix=1 explicitly. Otherwise it screws up PulseAudio. Signed-off-by: Takashi Iwai <tiwai@suse.de>
