path: root/sound
2009-01-06Check fops_get() return valueLaurent Pinchart
Several subsystem open handlers dereference the fops_get() return value without checking it for nullness. This opens a race condition between the open handler and module unloading. A module can be marked as being unloaded (MODULE_STATE_GOING) before its exit function is called and gets the chance to unregister the driver. During that window open handlers can still be called, and fops_get() will fail in try_module_get() and return a NULL pointer. This change checks the fops_get() return value and returns -ENODEV if NULL. Reported-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-01-05Merge branch 'topic/asoc' into for-linusTakashi Iwai
2009-01-05Merge branch 'fixes' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into topic/asoc
2009-01-05ALSA: ice1724 - Fix a typo in IEC958 PCM nameAlan Horstmann
Fix trivial name string typo as reported in bug 2552. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-05ASoC: fix davinci-sffsdr bugletDavid Brownell
Minor bugfix: now that DaVinci kernels can support multiple boards, board-specific ASoC components need to verify they're running on the right board before initializing. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-05Merge branch 'topic/usbaudio' into for-linusTakashi Iwai
2009-01-05Merge branch 'topic/hda' into for-linusTakashi Iwai
2009-01-04ALSA: sound/usb: Use negated usb_endpoint_xfer_control, etcJulia Lawall
This patch extends 42a6e66f1e40a930d093c33ba0bb9d8d8e4555ed by using usb_endpoint_xfer_control, usb_endpoint_xfer_isoc, usb_endpoint_xfer_bulk, and usb_endpoint_xfer_int in the negated case as well. This patch also rewrites some calls to usb_endpoint_dir_in as negated calls to !usb_endpoint_dir_out, and vice versa, to better correspond to the intent of the original code. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_CONTROL\|0\)) + !usb_endpoint_xfer_control(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_ISOC\|1\)) + !usb_endpoint_xfer_isoc(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_BULK\|2\)) + !usb_endpoint_xfer_bulk(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_INT\|3\)) + !usb_endpoint_xfer_int(epd) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-03ALSA: hda - cxt5051 report jack stateUlrich Dangel
Signed-off-by: Ulrich Dangel <uli@spamt.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-03ALSA: hda - add basic jack reporting functions to patch_conexant.cUlrich Dangel
Added functions to report jack sense. As CXT5051_PORTB_EVENT has the same value as CONEXANT_MIC_EVENT two input devices for the microphone will be created if using CXT5051. Signed-off-by: Ulrich Dangel <uli@spamt.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02ALSA: Use usb_set/get_intfdataJulia Lawall
Use the USB functions usb_get_intfdata and usb_set_intfdata instead of dev_get_drvdata and dev_set_drvdata, respectively. The semantic patch that makes this change for the usb_get_intfdata case is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @header@ @@ #include <linux/usb.h> @same depends on header@ position p; @@ usb_get_intfdata@p(...) { ... } @depends on header@ position _p!=same.p; identifier _f; struct usb_interface*intf; @@ _f@_p(...) { <+... - dev_get_drvdata(&intf->dev) + usb_get_intfdata(intf) ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-01ASoC: Clean up kerneldoc warningsMark Brown
Almost all parameters that have been misnamed in the comments. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-01ASoC: Fix pxa2xx-pcm checks for invalid DMA channelsStephen Ware
Set the invalid dma channel to -1 (and check properly for it) in pxa2xx_pcm_hw_free(). Was assuming 0 is an invalid channel number but 0 is a valid pxa dma channel num. Signed-off-by: stephen <stephen.ware@eqware.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-01LSA: hda - Add HP Acacia detectionChris Bagwell
Add automatic mapping of HP Acacia motherboards to 3stack-hp. Allows for greater then 2 channel audio by enabling Channel Mode option in mixer. Motherboard specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321559&lc=en&dlc=en&cc=us&product=3829353&os=2093&lang=en# Signed-off-by: Chris Bagwell <chris at cnpbagwell dot com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-01ALSA: hda - fix name for ALC1200Wu Fengguang
Move the more specific preset for ALC1200 above the general one for ALC888, so that it will have the chance to get matched and selected. Reported-by: Thomas Schneider <nailstudio@gmx.net> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-01ALSA: sound/usb: use USB API functions rather than constantsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) @inc@ @@ #include <linux/usb.h> @depends on !inc && (r1||r5)@ @@ + #include <linux/usb.h> #include <linux/usb/...> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-31ASoC: TWL4030: DAPM based capture implementationPeter Ujfalusi
This patch adds DAPM implementaion for the capture path on twlx030. TWL has two physical ADC and two digital microphone (stereo) connections. The CPU interface has four microphone channels. For simplicity the microphone channel paths are named as: TX1 (Left/Right) - when using i2s mode, only the TX1 data is valid TX2 (Left/Right) Input routing (simplified version): There is two levels of mux settings for TWL in input path: Analog input mux: ADCL <- {Off, Main mic, Headset mic, AUXL, Carkit mic} ADCR <- {Off, Sub mic, AUXR} Analog/Digital mux: TX1 Analog mode: TX1L <- ADCL TX1R <- ADCR TX1 Digital mode: TX1L <- Digimic0 (Left) TX1R <- Digimic0 (Right) TX2 Analog mode: TX2L <- ADCL TX2R <- ADCR TX2 Digital mode: TX2L <- Digimic1 (Left) TX2R <- Digimic1 (Right) The patch provides the following user controls for the capture path: Mux settings: "TX1 Capture Route": {Analog, Digimic0} "TX2 Capture Route": {Analog, Digimic1} "Analog Left Capture Route": {Off, Main Mic, Headset Mic, AUXL, Carkit Mic} "Analog Right Capture Route": {Off, Sub Mic, AUXR} Volume/Gain controls: "TX1 Digital Capture Volume": Stereo gain control for TX1 path "TX2 Digital Capture Volume": Stereo gain control for TX2 path "Analog Capture Volume": Stereo gain control for the analog path only Important things for the board files: Microphone bias: "Mic Bias 1": Bias for Main mic or for digimic0 (analog or digital path) "Mic Bias 2": Bias for Sub mic or for digimic1 (analog or digital path) "Headset Mic Bias": Bias for Headset mic When the routing configured correctly only the needed components will be powered/enabled. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-31ASoC: TWL4030: Make the enum filter generic for twl4030Peter Ujfalusi
Modify the enum filter to more generic that it will filter out the enums with text "Invalid". The enum filter also required for the capture path. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (583 commits) V4L/DVB (10130): use USB API functions rather than constants V4L/DVB (10129): dvb: remove deprecated use of RW_LOCK_UNLOCKED in frontends V4L/DVB (10128): modify V4L documentation to be a valid XHTML V4L/DVB (10127): stv06xx: Avoid having y unitialized V4L/DVB (10125): em28xx: Don't do AC97 vendor detection for i2s audio devices V4L/DVB (10124): em28xx: expand output formats available V4L/DVB (10123): em28xx: fix reversed definitions of I2S audio modes V4L/DVB (10122): em28xx: don't load em28xx-alsa for em2870 based devices V4L/DVB (10121): em28xx: remove worthless Pinnacle PCTV HD Mini 80e device profile V4L/DVB (10120): em28xx: remove redundant Pinnacle Dazzle DVC 100 profile V4L/DVB (10119): em28xx: fix corrupted XCLK value V4L/DVB (10118): zoran: fix warning for a variable not used V4L/DVB (10116): af9013: Fix gcc false warnings V4L/DVB (10111a): usbvideo.h: remove an useless blank line V4L/DVB (10111): quickcam_messenger.c: fix a warning V4L/DVB (10110): v4l2-ioctl: Fix warnings when using .unlocked_ioctl = __video_ioctl2 V4L/DVB (10109): anysee: Fix usage of an unitialized function V4L/DVB (10104): uvcvideo: Add support for video output devices V4L/DVB (10102): uvcvideo: Ignore interrupt endpoint for built-in iSight webcams. V4L/DVB (10101): uvcvideo: Fix bulk URB processing when the header is erroneous ...
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimers: fix warning in kernel/hrtimer.c x86: make sure we really have an hpet mapping before using it x86: enable HPET on Fujitsu u9200 linux/timex.h: cleanup for userspace posix-timers: simplify de_thread()->exit_itimers() path posix-timers: check ->it_signal instead of ->it_pid to validate the timer posix-timers: use "struct pid*" instead of "struct task_struct*" nohz: suppress needless timer reprogramming clocksource, acpi_pm.c: put acpi_pm_read_slow() under CONFIG_PCI nohz: no softirq pending warnings for offline cpus hrtimer: removing all ur callback modes, fix hrtimer: removing all ur callback modes, fix hotplug hrtimer: removing all ur callback modes x86: correct link to HPET timer specification rtc-cmos: export second NVRAM bank Fixed up conflicts in sound/drivers/pcsp/pcsp.c and sound/core/hrtimer.c manually.
2008-12-29V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI cardIgor M. Liplianin
The card based on stv0299 or stv0288 demodulators. Signed-off-by: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-25Merge branches 'timers/clocksource', 'timers/hpet', 'timers/hrtimers', ↵Ingo Molnar
'timers/nohz', 'timers/ntp', 'timers/posixtimers' and 'timers/rtc' into timers/core
2008-12-25Merge branch 'topic/udev-id-rename' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/sound-core-fix' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/snd-hrtimer' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/pcxhr-update' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/oxygen' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/jack-mechanical' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/hda' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/cs5535audio' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/convert-tasklet' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/ca0106' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/audigy-capture-boost' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/asoc' into to-pushTakashi Iwai
2008-12-25Merge branch 'topic/aoa' into to-pushTakashi Iwai
2008-12-24Merge branch 'fix/hda' into topic/hdaTakashi Iwai
2008-12-24ALSA: hda - Add missing terminators in patch_sigmatel.cHerton Ronaldo Krzesinski
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-22ALSA: ASoC: fix a typo in omp-pcm.cRoel Kluin
Fix a typo (& and &&) Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-22ASoC: Fix DSP formats in SSM2602 audio codecJarkko Nikula
Thanks to Troy Kisky <troy.kisky@boundarydevices.com> for noticing. - DSP_A format has 1-bit data delay which corresponds to SSM6202 submode 2 - DSP_B has 0-bit data delay which corresponds to submode 1 - Currently driver sets them opposite so swap the submode setting Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Cc: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-22ASoC: Fix incorrect DSP format in OMAP McBSP DAI and affected driversJarkko Nikula
- OMAP McBSP DAI driver claims to support DSP_A format which has 1-bit data delay but configures link for 0-bit data delay which is in fact DSP_B - Fix this by changing format from DSP_A to DSP_B - Fix also TLV320AIC23 codec and OSK5912 machine drivers since the same error is populated also there Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: Arun KS <arunks@mistralsolutions.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-20ALSA: hda: fix incorrect mixer index values for 92hd83xxMatthew Ranostay
Fixed incorrect mixer index values for 92hd83xx codec's audio input mixer. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-20ALSA: hda: dinput_mux checkMatthew Ranostay
Add check to determine if dinput_mux is set by any of patch_stac*() functions, otherwise a invalid pointer my be referenced causing gibberish to mixer values. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-20Merge branch 'topic/ca0106-spdif-stream' into topic/ca0106Takashi Iwai
2008-12-20Merge branch 'topic/ca0106-resume' into topic/ca0106Takashi Iwai
2008-12-20Merge branch 'topic/ca0106-capture-no-44khz' into topic/ca0106Takashi Iwai
