path: root/sound
2012-07-14Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Containing the regression fixes for USB-audio due to the transition to the new streaming logic, mostly found on Logitech webcams." * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: move calls to usb_set_interface ALSA: usb-audio: Fix the first PCM interface assignment
2012-07-13ALSA: snd-usb: move calls to usb_set_interfaceDaniel Mack
The rework of the snd-usb endpoint logic moved the calls to snd_usb_set_interface() into the snd_usb_endpoint implemenation. This changed the order in which these calls are issued to the device, and thereby caused regressions for some webcams. Fix this by moving the calls back to pcm.c for now to make it work again and use snd_usb_endpoint_activate() to really tear down all remaining URBs in the flight, consequently fixing another regression caused by USB packets on the wire after altsetting 0 has been selected. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Philipp Dreimann <philipp@dreimann.net> Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-06ALSA: usb-audio: Fix the first PCM interface assignmentTakashi Iwai
In the new PCM streaming logic, the interface number is assigned to usb stream instance (subs->interface) after the format and rate setups are succeeded, but some codes are still passing subs->interface as the reference to helper functions. This leads to initializing with an invalid iface number (-1). This patch replaces the wrong references with the ones from the target fmt correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-03Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just a few driver-specific fixes for ASoC and HD-audio." * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix no sound from ALC662 after Windows reboot ASoC: tlv320aic3x: Fix codec pll configure bug ASoC: wm2200: Add missing BCLK rate
2012-06-29ALSA: hda - Fix no sound from ALC662 after Windows rebootKailang Yang
Windows use hidden register to control EAPD. Linux use verb to control EAPD. If windows reboot to Linux, it must change the EAPD control to verb control. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-29ASoC: tlv320aic3x: Fix codec pll configure bugHebbar, Gururaja
In sound/soc/codecs/tlv320aic3x.c data = snd_soc_read(codec, AIC3X_PLL_PROGA_REG); snd_soc_write(codec, AIC3X_PLL_PROGA_REG, data | (pll_p << PLLP_SHIFT)); In the above code, pll-p value is OR'ed with previous value without clearing it. Bug is not seen if pll-p value doesn't change across Sampling frequency. However on some platforms (like AM335x EVM-SK), pll-p may have different values across different sampling frequencies. In such case, above code configures the pll with a wrong value. Because of this bug, when a audio stream is played with pll value different from previous stream, audio is heard as differently(like its stretched). Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-06-29ASoC: wm2200: Add missing BCLK rateMark Brown
Without this very high BCLKs will be configured incorrectly. Reported-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-06-27Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here you find quite a few changes for HD-audio and a copule of quirk additions for USB-audio. All reasonably small and/or trivial." * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix power-map regression for HP dv6 & co ALSA: hda - Initialize caches at codec reconfiguration ALSA: hda - Fix memory leaks at module unload ALSA: hda - Fix memory leaks in Realtek & Conexant codec parsers ALSA: hda - Add Realtek ALC280 codec support ALSA: hda - Remove obsoleted CONFIG_SND_HDA_ENABLE_REALTEK_QUIRKS ASoC: wm8994: remove duplicate code ALSA: usb-audio: add BOSS GT-100 support ALSA: HDA: Add inverted internal mic quirk for Lenovo S205 ALSA: hda - Fix ALC272X codec detection ALSA: snd_usb_audio: ignore ctrl errors on QuickCam Pro for Notebooks ALSA: snd_usb_audio: ignore ctrl errors on QuickCam E3500
2012-06-26ALSA: hda - Fix power-map regression for HP dv6 & coTakashi Iwai
The recent fix for power-map controls (commit b0791dda813) caused regressions on some other HP laptops. They have fixed pins but these pins are exposed as jack-detectable. Thus the driver tries to control the power-map dynamically per jack detection where it never gets on. This patch adds the check of connection and it assumes the no jack detection is available for fixed pins no matter what pin capability says. BugLink: http://bugs.launchpad.net/bugs/1013183 Reported-by: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-26ALSA: hda - Initialize caches at codec reconfigurationTakashi Iwai
Better to clean up the caches for avoiding inconsistent codec state after the reconfiguration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-26ALSA: hda - Fix memory leaks at module unloadTakashi Iwai
Some caches aren't released properly at module unloading time. Cc: <stable@vger.kernel.org> [v3.4+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-26ALSA: hda - Fix memory leaks in Realtek & Conexant codec parsersTakashi Iwai
When moved to the helper code, forgot to release the verb arrays. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-25Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab. Trivial conflict due to new USB HID ID's being added next to each other (Baanto vs Axentia). * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (44 commits) [media] smia: Fix compile failures [media] Fix VIDIOC_DQEVENT docbook entry [media] s5p-fimc: Fix control creation function [media] s5p-mfc: Fix checkpatch error in s5p_mfc_shm.h file [media] s5p-mfc: Fix setting controls [media] v4l/s5p-mfc: added image size align in VIDIOC_TRY_FMT [media] v4l/s5p-mfc: corrected encoder v4l control definitions [media] v4l: mem2mem_testdev: Fix race conditions in driver [media] s5p-mfc: Bug fix of timestamp/timecode copy mechanism [media] cxd2820r: Fix an incorrect modulation type bitmask [media] em28xx: Show a warning if the board does not support remote controls [media] em28xx: Add remote control support for Terratec's Cinergy HTC Stick HD [media] USB: Staging: media: lirc: initialize spinlocks before usage [media] Revert "[media] media: mx2_camera: Fix mbus format handling" [media] bw-qcam: driver and pixfmt documentation fixes [media] cx88: fix firmware load on big-endian systems [media] cx18: support big-endian systems [media] ivtv: fix support for big-endian systems [media] tuner-core: return the frequency range of the correct tuner [media] v4l2-dev.c: fix g_parm regression in determine_valid_ioctls() ...
2012-06-25ALSA: hda - Add Realtek ALC280 codec supportDavid Henningsson
This chip looks very similar to ALC269 and ALC27* variants. The bug reporter has verified that sound was working after this patch had been applied. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1017017 Tested-by: Richard Crossley <richardcrossley@o2.co.uk> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-25ALSA: hda - Remove obsoleted CONFIG_SND_HDA_ENABLE_REALTEK_QUIRKSTakashi Iwai
I simply forgot to remove this entry although all Realtek quirks have been dropped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-25ASoC: wm8994: remove duplicate codeJaroslav Kysela
It seems that the code duplication was added at a merge operation. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-25ALSA: usb-audio: add BOSS GT-100 supportClemens Ladisch
Reported-by: John McFarland <mcfarljm@gmail.com> Tested-by: John McFarland <mcfarljm@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-21ALSA: HDA: Add inverted internal mic quirk for Lenovo S205David Henningsson
The Lenovo Ideapad S205 has an internal mic where the right channel is phase inverted. BugLink: https://bugs.launchpad.net/bugs/884652 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-21ALSA: hda - Fix ALC272X codec detectionTakashi Iwai
The codec ALC272X is a special codec for some Dell machines, and its detection got broken in the recent kernel because SSID check (required by ALC272X check) was moved to the later point. Now we need to move this codec check to the right place, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-20ALSA: snd_usb_audio: ignore ctrl errors on QuickCam Pro for NotebooksOleksij Rempel
This webcam works mostly ok, exept with skype. Skype sends lots of ctrl messages to dynamically ajust record level. If for some reasons it pokes some error every thing goes broken: - first pulseaudio blocks sound for all apps - then video is reseted - then skype freez dmesg has lots of messages like: cannot set freq 16000 to ep 0x86" Setting ignore_ctl_error=1 fixes this problem. Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-20ALSA: snd_usb_audio: ignore ctrl errors on QuickCam E3500Oleksij Rempel
if this cam is pluged in, pulse audio can't initiate capture device. dmesg has lots of messages like: "cannot set freq 16000 to ep 0x86" Setting ignore_ctl_error=1 fixes this problem. Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: 6fire: use NULL instead of 0 for pointer assignmentDaniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: hda - Handle open while transitioning to D3.Dylan Reid
This addresses an issue encountered when a pcm is opened while transitioning to low power state (codec->power_on == 1 && codec->power_transition == -1). Add snd_pcm_power_up_d3wait to hda_codec. This function is used to power up from azx_open as opposed to snd_hda_power_up used from codec_exec_verb. When powering up from azx_open, wait for pending power downs to complete, avoiding the power up continuing in parallel with the power down on the work queue. The specific issue seen was with the CS4210 codec, it powers off the ADC and DAC nid in its suspend handler. If it is re-opened before the ~100ms power down process completes, the ADC and DAC nid are initialized while powered down and audio is lost until another suspend/resume cycle. Signed-off-by: Dylan Reid <dgreid@chromium.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: snd-usb: make snd_usb_substream_capture_trigger staticDaniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: snd-usb: fix sync pipe checkDaniel Mack
Fix a bogus sanity check for sync pipe in pcm.c. This flaw was introduced during the streaming logic refactorization. While at it, improve the error messages that are generated in such cases. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: <ben@b1c1l1.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18Merge tag 'asoc-3.5' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for 3.5 All driver specific and fairly small. The pxa-ssp changes are larger than I'd like but they're build failures and are pretty clear to inspection.
2012-06-13ALSA: hda - Don't forget to call init verbs added by fixup listTakashi Iwai
During the split to the auto-parser helper functions, the actual call of init verbs was lost. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43366 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-12ALSA: HDA: Pin fixup for Zotac Z68 motherboardDavid Henningsson
Pin 0x1b was connected to the front panel connector, which according to the HDA standard should contain a mic and a headphone. In this case, the headphone was listed as "line out" by BIOS. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/993162 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-12ALSA: compress_core: cleanup pointers on stopVinod Koul
as the start can be called after stop again, we need to reset state Signed-off-by: Namarta Kohli <namartax.kohli@intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-12ALSA: compress_core: don't wake up on pauseVinod Koul
during pause the core should maintain the status-quo on the device and pointers and not wake up. If app needs it should call DROP explcitly. Signed-off-by: Namarta Kohli <namartax.kohli@intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-12ASoC: tegra+wm8903: turn of mic detect when card is removedStephen Warren
If mic detect is left enabled and the WM8903 detects a status change, the WM8903 driver will make a callback against the free()d jack, which will cause a crash. This problem can be triggered by fully initializing an audio card, then removing and re-inserting the machine driver module. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-11[media] snd_tea575x: set_freq: update cached freq to the actual achieved ↵Hans de Goede
frequency Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] snd_tea575x: Make the module using snd_tea575x the fops ownerHans de Goede
Before this patch the owner field of the /dev/radio# device fops was set to the snd-tea575x-tuner module itself. Meaning that the module which was using it could be rmmod-ed while the device is open, and then BAD things happen. I know, as I found out the hard way :) Note that there is no need to also somehow increase the refcount of the snd-tea575x-tuner module itself, since any drivers using it will have symbolic references to it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] snd_tea575x: Report correct frequency range for EU/US versus JA modelsHans de Goede
My EU/US 5757 cannot tune below approx 86 Mhz, that is below that it does not even generate the standard not tuned to anything radio noise anymore, so clearly the 5757 cannot tune to the Japanese frequencies. This patch assumes that likewise the 5759 cannot tune to the EU/US frequencies. Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11ALSA: hda - Fix detection of Creative SoundCore3D controllersTakashi Iwai
The PCI ID entries of Creative SoundCore3D HD-audio controllers should be before the wildcard for vendor = Creative. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-11ASoC: wm8996: Mark the CODEC as cache only when powering off on bootMark Brown
Otherwise we might try to write to a powered off device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-11ASoC: wm8996: Move reset before the initial regulator disableMark Brown
If we don't have control over the LDO but do have control over the other regulators then we may end up trying to write to a powered off device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-11ASoC: wm8996: Remove spurious regulator_bulk_free()Mark Brown
We're using demv_regulator_bulk_get() so don't need to manually free and this is in the CODEC driver not the I2C driver anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-11ASoC: wm8904: Fix cache only managementMark Brown
We should be using the regmap API consistently for all the cache only configuration and we should be going cache only before we power down the supplies. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-11ASoC: wm8904: Fix GPIO and MICBIAS initialisation for regmap conversionMark Brown
We no longer have a flat ASoC cache so can't peer directly into the array any more but should instead use the register I/O functions to update the cache. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org (v3.4)
2012-06-11ASoC: fix pxa-ssp compiling issue under mach-mmpQiao Zhou
pxa-ssp.c uses API like cpu_is_pxa3xx(), cpu_is_pxa2xx(), which is defined under arch-pxa architecture, and drivers under mach-mmp can't find it. so just use ssp->type to replace that API. Signed-off-by: Qiao Zhou <zhouqiao@marvell.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-08ALSA: hda - HDMI Audio init all connectors when VGA-switcheroo is offSteven Newbury
When VGA_SWITCHEROO support is enabled hda_intel initialises the HDMI audio device on the current VGA device. When it's not enabled it only initialises the HDMI device on the default VGA adaptor, this means secondary cards get no audio support which is very unhelpful for multi-seat! With this patch, when SUPPORT_VGA_SWITCHEROO is disabled hda_intel initialises all HDMI audio devices, not just the default VGA. [minor optimizations by tiwai] Signed-off-by: Steven Newbury <steve@snewbury.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-08ALSA: hda - Fix uninitialized HDMI controllers with VGA-switcherooTakashi Iwai
When VGA-switcheroo is built in but unused on systems with multiple graphics cards, the initializations of non-default graphics cards are skipped and never enabled (because the switcheroo is activated only when the controller supports). The current behavior is for avoiding the system lockup by accessing the disabled GPU, but due to the recent change in VGA-switcheroo, it determines the state simply by checking with the default VGA device. This is the culprit. Now with the new vga_switcheroo_get_client_state(), we can know the initial state of the bound GPU, thus can determine the initial audio client state more correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-08ALSA: usb-audio: Fix substream assignmentsTakashi Iwai
In 3.5 kernel, the endpoint is assigned dynamically for the substreams, but the PCM assignment still checks the presence of the endpoint pointer. This ended up in duplicated PCM substream creations at probing time, resulting in kernel warnings like: WARNING: at fs/proc/generic.c:586 proc_register+0x169/0x1a6() Pid: 1152, comm: modprobe Not tainted 3.5.0-rc1-00110-g71fae7e #2 Call Trace: [<ffffffff8102a400>] warn_slowpath_common+0x83/0x9c [<ffffffff8102a4bc>] warn_slowpath_fmt+0x46/0x48 [<ffffffff813829ad>] ? add_preempt_count+0x39/0x3b [<ffffffff811292f0>] proc_register+0x169/0x1a6 [<ffffffff8112962e>] create_proc_entry+0x74/0x8c [<ffffffffa018eb63>] snd_info_register+0x3e/0xc3 [snd] [<ffffffffa01fde2e>] snd_pcm_new_stream+0xb1/0x404 [snd_pcm] [<ffffffffa024861f>] snd_usb_add_audio_stream+0xd2/0x230 [snd_usb_audio] [<ffffffffa0241d33>] ? snd_usb_parse_audio_format+0x252/0x34f [snd_usb_audio] [<ffffffff810d6b17>] ? kmem_cache_alloc_trace+0xab/0xbb [<ffffffffa0248c29>] snd_usb_parse_audio_interface+0x4ac/0x567 [snd_usb_audio] [<ffffffffa023f0ff>] snd_usb_create_stream+0xe9/0x125 [snd_usb_audio] [<ffffffffa023f9b1>] usb_audio_probe+0x62a/0x72c [snd_usb_audio] ..... This patch fixes the regression by checking the fixed endpoint number for each substream instead of the endpoint pointer. Reported-and-tested-by: Jamie Heilman <jamie@audible.transient.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-08ASoC: tegra: add MODULE_DEVICE_TABLE to tegra30_ahubStephen Warren
This allows the module to automatically load when instantiated from device tree. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-08ASoC: wm2000: Always use a 4s timeout for the firmwareMark Brown
Rather than having varying timeouts depending on the transition always use a 4s timeout. This provides better diagnostics for clocking errors and ensures compatibility with current calibration firmwares. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-08ASoC: dapm: Fix input list to use source widgetsLiam Girdwood
We should only add source widgets to the input list. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-08ASoC: dpcm: Fix dpcm_get_be() to check that DAI is BELiam Girdwood
Make sure that the dpcm_get_be() only returns BE DAI links. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-05ASoC: wm8994: Apply volume updates with clocks enabledMark Brown
Volume updates may not be acted upon if there is no clock applied when the volume update is written. Ensure this doesn't happen by writing out registers with volume updates after we enable each of the clocks. There are more registers updated than before as previously we were relying on wm_hubs to set those for controls it manages. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-06-05ASoC: wm8994: Ensure all AIFnCLK events are run from the _late variantsMark Brown
Ensure that all the actions get taken at appropriate times by calling the _PRE and _POST events for the aifNclk_ev functions explicitly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
