path: root/sound
2007-10-07Convert snd-page-alloc proc file to use seq_file (CVE-2007-4571)Takashi Iwai
Commit ccec6e2c4a74adf76ed4e2478091a311b1806212 in mainline. Use seq_file for the proc file read/write of snd-page-alloc module. This automatically fixes bugs in the old proc code. Adrian Bunk: Backported to 2.6.16. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-07snd_mem_proc_read(): convert to list_for_each_entry*Adrian Bunk
Stolen from a patch by Johannes Berg <johannes@sipsolutions.net>. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-06sound/core/pcm_lib.c: don't export static functionsAdrian Bunk
Static functions mustn't be exported. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-03-28[ALSA] ca0106 - Add missing sysfs device assignmentTakashi Iwai
Added the missing device assignment before creating sysfs tree. This caused the insufficient device permissions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] cs4281 - Fix the check of right channelTakashi Iwai
Fix the check of right channel in mixer volume put callback. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] Dereference after free in snd_hwdep_release()Florin Malita
snd_card_file_remove() may free hw->card so we can't dereference hw->card->module after that. Coverity ID 1420. Signed-off-by: Florin Malita <fmalita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] cmipci - Fix a typo in 'PC Speaker Playback Switch' controlTakashi Iwai
Fixed a typo in 'PC Speaker Playback Switch' control name. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] fix NULL pointer dereference in sound/synth/emux/soundfont.cEric Sesterhenn
this is about coverity id #100. It seems the if statement is negated, since the else branch calls remove_info() with sflist->currsf as a parameter where it gets dereferenced. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] Fix invalid assignment of PCI revisionTakashi Iwai
Fix the type of PCI revision to char from int and avoid invalid assignment with pointer cast. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] hda-intel - Don't try to probe invalid codecsTakashi Iwai
Fix the max number of codecs detected by HD-intel (and compatible) controllers. ATI controllers may have up to 4 codecs while ICH up to 3. Now max codecs is defined according to the driver type, either 3 or 4. Currently 4 is set only to ATI chips. Other might need the same change, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[ALSA] hda-codec - Don't return error at initialization of modem codecTakashi Iwai
Some modem codec seem to fail in the initialization, and this stopped loading of the whole module although the audio is OK. Since it's usually a non-fatal issue, the driver tries to proceed to initialize now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28usb-audio: work around wrong frequency in CM6501 descriptorsClemens Ladisch
The C-Media CM6501 chip's descriptors say that altsetting 5 supports 48 kHz, but it actually plays at 96 kHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28sound/pci/au88x0/au88x0.c: ioremap balanced with iounmapAmol Lad
Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-14[ALSA] echo3g_dsp.c shouldn't include #include <linux/irq.h>Adrian Bunk
Despite being under linux/, linux/irq.h shouldn't be #include'd by arch independent code. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: snd_rtctimer: handle RTC interrupts with a taskletClemens Ladisch
The calls to rtc_control() from inside the interrupt handler can deadlock the RTC code, so move our interrupt handling code to a tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-By: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: emu10k1: Fix outl() in snd_emu10k1_resume_regs()Arnaud Patard
The emu10k1 driver saves the A_IOCFG and HCFG register on suspend and restores it on resumes. Unfortunately, this doesn't work as the arguments to outl() are reversed. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09ALSA: Fix initiailization of user-space controlsTakashi Iwai
Fix an assertion when accessing a user-defined control due to lack of initialization (appears only when CONFIG_SND_DEBUg is enabled). ALSA sound/core/control.c:660: BUG? (info->access == 0) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09[SOUND] Sparc CS4231: Use 64 for period_bytes_minDavid S. Miller
This matches what the ISA cs4231 driver uses. Tested by Georg Chini. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09[SOUND] Sparc CS4231: Fix IRQ return value and initialization.Georg Chini
SBUS: Change IRQ-handler return value from 0 to IRQ_HANDLED and fix some initialisation problems. Change period_bytes_min from 4096 to 256 to allow driver to work with low latency (VOIP) applications. Hope this does not break EBUS. Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] fix usbmixer double kfreeDave Jones
snd_ctl_add() kfree's the kcontrol already if we fail there, so this driver is currently doing a double kfree. Coverity bug #959 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] sound/isa/sb/sb_mixer.c double kfreeDave Jones
snd_ctl_add() already does the free on error. Coverity bug #957 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] Fix use after free in opl3_seq and opl3_ossDave Jones
Don't read from free'd memory. Also make use of the return value, and don't register the device if something went wrong creating the port. Coverity #954, #955 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] ad1848 double freeDave Jones
snd_ctl_add() already kfree's on error. Coverity #956 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] sound/pci/rme9652/hdspm.c: fix off-by-one errorsAdrian Bunk
This patch fixes off-by-one errors found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] fix some memory leaksAdrian Bunk
This patch fixes two memory leaks spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-15[ALSA] sound/core/: fix 3 off-by-one errorsAdrian Bunk
This patch fixes three off-by-one errors found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-29proper flags type of spin_lock_irqsave()Alexey Dobriyan
Convert various spin_lock_irqsave() callers to correctly use `unsigned long' Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[ALSA] echoaudio - Remove kfree_nocheck()Takashi Iwai
Remove obsoleted kfree_nochec() (for debug). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[ALSA] echoaudio - Fix MakefileTakashi Iwai
Fix missing makefile entries for echoaudio drivers Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[ALSA] Fix a typo in echoaudio/midi.cTakashi Iwai
Fixed a typo in echoaudio/midi.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[ALSA] Add echoaudio sound driversGiuliano Pochini pochini@shiny.it
Add echoaudio sound drivers (darla20, darla24, echo3g, gina20, gina24, indigo, indigodj, indigoio, layla20, lala24, mia, mona) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-24update the OBSOLETE_OSS_DRIVER help textAdrian Bunk
2006-09-05ALSA: RME HDSP - fixed proc interface (missing {})Remy Bruno
Signed-off-by: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: hda-intel - Fix race in removeTakashi Iwai
Call iounmap after free_irq to avoid invalid accesses in the shared irq. The patch is taken from https://bugzilla.novell.com/show_bug.cgi?id=167869 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: Fix workaround for AD1988A rev2 codecTakashi Iwai
Fix the workaround for AD1988A rev2 codec not to apply to AD1988B codec chips. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: Fix model for HP dc7600Takashi Iwai
Changed the assigned model for HP dc7600 with ALC260 codec to match better with the actual I/O assignment. Patch taken from ALSA bug#2157. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: Fix missing array terminators in AD1988 codec supportTakashi Iwai
Fixed the missing array terminators in AD1988 codec support code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: Fix a deadlock in snd-rtctimerTakashi Iwai
Fix an occasional deadlock occuring with snd-rtctimer driver, added irqsave to the lock in tasklet (ALSA bug#952). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-05ALSA: au88x0 - Fix 64bit address of MPU401 MMIO portTakashi Iwai
Fix 64bit address of MPU401 MMIO port on au88x0 chip. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-09SOUND_SSCAPE shouldn't depend on OBSOLETE_OSS_DRIVERAdrian Bunk
Due to a regression in the correcponding ALSA driver (ALSA #2234), the OSS driver should stay until it's fixed. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-03fix the SND_FM801_TEA575X dependenciesAdrian Bunk
CONFIG_SND_FM801=y, CONFIG_SND_FM801_TEA575X=m resulted in the following compile error: <-- snip --> ... LD vmlinux sound/built-in.o: In function 'snd_fm801_free': fm801.c:(.text+0x3c15b): undefined reference to 'snd_tea575x_exit' sound/built-in.o: In function 'snd_card_fm801_probe': fm801.c:(.text+0x3cfde): undefined reference to 'snd_tea575x_init' make: *** [vmlinux] Error 1 <-- snip --> This patch fixes kernel Bugzilla #6458. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-24[PATCH] PPC: fix oops in alsa powermac driverGuido Guenther
this fixes an oops in 2.6.16.X when loading the snd_powermac module. The name of the requested module changed during the 2.6.16 development cycle from i2c-keylargo to i2c-powermac: Signed-off-by: Guido Guenther <agx@sigxcpu.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] Add default entry for CTL Travel Master U553WTakashi Iwai
Added the default entry of ALC880 configuration table for CTL Travel Master U553W. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] opti9x - Fix compile without CONFIG_PNPTakashi Iwai
Modules: Opti9xx drivers Fix compile errors without CONFIG_PNP. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-06[PATCH] alsa: fix error paths in snd_ctl_elem_add()Takashi Iwai
Fix bugs in error paths of snd_ctl_elem_add() - NULL reference - double free (already freed in snd_ctl_add()) Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] alsa: fix bogus snd_device_free() in opl3-oss.cTakashi Iwai
Remove snd_device_free() for an opl3-oss instance which should have been released. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] snd-cs4236 typo fixRene Herman
I noticed on 2.6.16-rc4 that my MPU-401 wasn't functional, due to a simple copy & paste error in sound/isa/cs423x/cs4236.c. Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] Fix snd-usb-audio in 32-bit compat environmentJuergen Kreileder
I'm getting oopses with snd-usb-audio in 32-bit compat environments: control_compat.c:get_ctl_type() doesn't initialize 'info', so 'itemlist[uinfo->value.enumerated.item]' in usbmixer.c:mixer_ctl_selector_info() might access random memory (The 'if ((int)uinfo->value.enumerated.item >= cval->max)' doesn't fix all problems because of the unsigned -> signed conversion.) Signed-off-by: Juergen Kreileder <jk@blackdown.de> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Greg KH <greg@kroah.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] powerpc: Fix sound driver use of i2cBenjamin Herrenschmidt
The PowerMac sound drivers used to rely on a "bug" of the i2c-keywest driver that implemented I2C_SMBUS_BLOCK_DATA incorrectly, that is it did what I2C_SMBUS_I2C_BLOCK_DATA should have done. The new i2c-powermac driver that replaces keywest has this bug fixed, thus the sound drivers must be fixed too. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] bogus asm/delay.h includesAl Viro
asm/delay.h is non-portable; linux/delay.h should be used in generic code. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
