path: root/sound
2014-08-15Merge tag 'sound-fix-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here is the additional fix patches that have been queued up since the previous pull request. A few HD-audio fixes, a USB-audio quirk addition, and a couple of trivial cleanup for the legacy OSS codes" * tag 'sound-fix-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Set TLV_DB_SCALE_MUTE bit for cx5051 vmaster ALSA: hda/ca0132 - Don't try loading firmware at resume when already failed ALSA: hda - Fix pop noises on reboot for Dell XPS 13 9333 ALSA: hda - Set internal mic as default input source on Dell XPS 13 9333 ALSA: usb-audio: fix BOSS ME-25 MIDI regression ALSA: hda - Fix parsing of CMI8888 codec ALSA: hda - Fix probing and stuttering on CMI8888 HD-audio controller ALSA: hda/realtek - Fixed ALC286/ALC288 recording delay for Headset Mic sound: oss: Remove typedefs wanc_info and wavnc_port_info sound: oss: uart401: Remove typedef uart401_devc
2014-08-14Merge tag 'pci-v3.17-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull DEFINE_PCI_DEVICE_TABLE removal from Bjorn Helgaas: "Part two of the PCI changes for v3.17: - Remove DEFINE_PCI_DEVICE_TABLE macro use (Benoit Taine) It's a mechanical change that removes uses of the DEFINE_PCI_DEVICE_TABLE macro. I waited until later in the merge window to reduce conflicts, but it's possible you'll still see a few" * tag 'pci-v3.17-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Remove DEFINE_PCI_DEVICE_TABLE macro use
2014-08-14Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree updates from Grant Likely: "The branch contains the following device tree changes the v3.17 merge window: Group changes to the device tree. In preparation for adding device tree overlay support, OF_DYNAMIC is reworked so that a set of device tree changes can be prepared and applied to the tree all at once. OF_RECONFIG notifiers see the most significant change here so that users always get a consistent view of the tree. Notifiers generation is moved from before a change to after it, and notifiers for a group of changes are emitted after the entire block of changes have been applied Automatic console selection from DT. Console drivers can now use of_console_check() to see if the device node is specified as a console device. If so then it gets added as a preferred console. UART devices get this support automatically when uart_add_one_port() is called. DT unit tests no longer depend on pre-loaded data in the device tree. Data is loaded dynamically at the start of unit tests, and then unloaded again when the tests have completed. Also contains a few bugfixes for reserved regions and early memory setup" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: (21 commits) of: Fixing OF Selftest build error drivers: of: add automated assignment of reserved regions to client devices of: Use proper types for checking memory overflow of: typo fix in __of_prop_dup() Adding selftest testdata dynamically into live tree of: Add todo tasklist for Devicetree of: Transactional DT support. of: Reorder device tree changes and notifiers of: Move dynamic node fixups out of powerpc and into common code of: Make sure attached nodes don't carry along extra children of: Make devicetree sysfs update functions consistent. of: Create unlocked versions of node and property add/remove functions OF: Utility helper functions for dynamic nodes of: Move CONFIG_OF_DYNAMIC code into a separate file of: rename of_aliases_mutex to just of_mutex of/platform: Fix of_platform_device_destroy iteration of devices of: Migrate of_find_node_by_name() users to for_each_node_by_name() tty: Update hypervisor tty drivers to use core stdout parsing code. arm/versatile: Add the uart as the stdout device. of: Enable console on serial ports specified by /chosen/stdout-path ...
2014-08-14ALSA: hda - Set TLV_DB_SCALE_MUTE bit for cx5051 vmasterTakashi Iwai
Conexnat HD-audio driver has a workaround for cx5051 (aka CX20561) chip to add fake mute controls to each amp (commit 3868137e). This implies the minimum-as-mute TLV bit in TLV for each corresponding control. Meanwhile we build the virtual master from these, but the TLV bit is missing, even though the slaves have it. This patch simply adds the missing TLV_DB_SCALE_MUTE bit for vmaster, as already done in patch_sigmatel.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-08-11Merge branch 'devicetree/next-console' into devicetree/nextGrant Likely
2014-08-10ALSA: hda/ca0132 - Don't try loading firmware at resume when already failedTakashi Iwai
CA0132 driver tries to reload the firmware at resume. Usually this works since the firmware loader core caches the firmware contents by itself. However, if the driver failed to load the firmwares (e.g. missing files), reloading the firmware at resume goes through the actual file loading code path, and triggers a kernel WARNING like: WARNING: CPU: 10 PID:11371 at drivers/base/firmware_class.c:1105 _request_firmware+0x9ab/0x9d0() For avoiding this situation, this patch makes CA0132 skipping the f/w loading at resume when it failed at probe time. Reported-and-tested-by: Janek Kozicki <cosurgi@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: hda - Fix pop noises on reboot for Dell XPS 13 9333Gabriele Mazzotta
If nid 0x15 (Headphone Playback Switch) is in D3 and headphones are plugged in when the laptop reboots, a pop noise is generated. Prevent this by keeping nid 0x15 in D0 when headphones are plugged in. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=76611 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: hda - Set internal mic as default input source on Dell XPS 13 9333Gabriele Mazzotta
If the laptop is powered on with a jack plugged in, independently on what is plugged, the jack is treated as a microphone jack. Initialize the capture source so that by default jacks are treated as headphones jacks. This will also prevent pop noises on boot in case headphones are plugged in since setting/unsetting mic-in as input source causes a pop noise. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=76611 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: usb-audio: fix BOSS ME-25 MIDI regressionClemens Ladisch
The BOSS ME-25 turns out not to have any useful descriptors in its MIDI interface, so its needs a quirk entry after all. Reported-and-tested-by: Kees van Veen <kees.vanveen@gmail.com> Fixes: 8e5ced83dd1c ("ALSA: usb-audio: remove superfluous Roland quirks") Cc: <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-07Merge tag 'mfd-for-linus-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD update from Lee Jones: "Changes to existing drivers: - checkpatch fixes throughout the subsystem - use Regmap to handle IRQs in max77686, extcon-max77693 and mc13xxx-core - use DMA in rtsx_pcr - restrict building on unsupported architectures on timberdale, cs5535 - SPI hardening in cros_ec_spi - more robust error handing in asic3, cros_ec, ab8500-debugfs, max77686 and pcf50633-core - reorder PM runtime and regulator handing during shutdown in arizona - enable wakeup in cros_ec_spi - unused variable/code clean-up in pm8921-core, cros_ec, htc-i2cpld, tps65912-spi, wm5110-tables and ab8500-debugfs - add regulator handing into suspend() in sec-core - remove pointless wrapper functions in extcon-max77693 and i2c-cros-ec-tunnel - use cross-architecture friendly data sizes in stmpe-i2c, arizona, max77686 and tps65910 - devicetree documentation updates throughout - provide power management support in max77686 - few OF clean-ups in max77686 - use manged resources in tps6105x New drivers/supported devices: - add support for s2mpu02 to sec-core - add support for Allwinner A32 to sun6i-prcm - add support for Maxim 77802 in max77686 - add support for DA9063 AD in da9063 - new driver for Intel PMICs (generic) and specifically Crystal Cove (Re-)moved drivers == - move out keyboard functionality cros_ec ==> input/keyboard/cros_ec_keyb" * tag 'mfd-for-linus-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (101 commits) MAINTAINERS: Update MFD repo location mfd: omap-usb-host: Fix improper mask use. mfd: arizona: Only free the CTRLIF_ERR IRQ if we requested it mfd: arizona: Add missing handling for ISRC3 under/overclocked mfd: wm5110: Add new interrupt register definitions mfd: arizona: Rename thermal shutdown interrupt mfd: wm5110: Add in the output done interrupts mfd: wm5110: Remove non-existant interrupts mfd: tps65912-spi: Remove unused variable mfd: htc-i2cpld: Remove unused code mfd: da9063: Add support for AD silicon variant mfd: arizona: Map MICVDD from extcon device to the Arizona core mfd: arizona: Add MICVDD to mapped regulators for wm8997 mfd: max77686: Ensure device type IDs are architecture agnostic mfd: max77686: Add Maxim 77802 PMIC support mfd: tps6105x: Use managed resources when allocating memory mfd: wm8997-tables: Suppress 'line over 80 chars' warnings mfd: kempld-core: Correct a variety of checkpatch warnings mfd: ipaq-micro: Fix coding style errors/warnings reported by checkpatch mfd: si476x-cmd: Remedy checkpatch style complains ...
2014-08-07Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for 3.17. It contains: - misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates - MIPS ptrace updates and cleanups - various fixes that will also go to -stable - a number of cleanups and small non-critical fixes. - NUMA support for the Loongson 3. - more support for MSA - support for MAAR - various FP enhancements and fixes" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) MIPS: jz4740: remove unnecessary null test before debugfs_remove MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive MIPS: ZBOOT: implement stack protector in compressed boot phase MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT MIPS: Bonito64: remove a duplicate define MIPS: Malta: initialise MAARs MIPS: Initialise MAARs MIPS: detect presence of MAARs MIPS: define MAAR register accessors & bits MIPS: mark MSA experimental MIPS: Don't build MSA support unless it can be used MIPS: consistently clear MSA flags when starting & copying threads MIPS: 16 byte align MSA vector context MIPS: disable preemption whilst initialising MSA MIPS: ensure MSA gets disabled during boot MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains MIPS: fix MSA context for tasks which don't use FP first MIPS: init upper 64b of vector registers when MSA is first used MIPS: save/disable MSA in lose_fpu MIPS: preserve scalar FP CSR when switching vector context ...
2014-08-07ALSA: hda - Fix parsing of CMI8888 codecTakashi Iwai
CMI8888 codec chip has a boost amp (only) on the headphone pin, and this confuses the generic parser, which tends to pick up the most outside amp. This results in the wrong volume setup, as the driver complains like: hda_codec: Mismatching dB step for vmaster slave (-100!=1000) For avoiding this problem, rule out the amp on NID 0x10 and create "Headphone Amp" volume control manually instead. Note that this patch still doesn't fix all problems yet. The sound output from the line out seems still too low. It will be fixed in another patch (hopefully). Reported-and-tested-by: Vincent Lejeune <vljn@ovi.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-07ALSA: hda - Fix probing and stuttering on CMI8888 HD-audio controllerTakashi Iwai
ASUS Phoebus with CMI8888 HD-audio chip (PCI id 13f6:5011) doesn't work with HD-audio driver as is because of some weird nature. For making DMA properly working, we need to disable MSI. The position report buffer doesn't work, thus we need to force reading LPIB instead. And yet, the codec CORB/RIRB communication gives errors unless we disable the snooping (caching). In this patch, all these workarounds are added as a quirk for the device. The HD-audio *codec* chip needs yet another workaround, but it'll be provided in the succeeding patch. Reported-and-tested-by: Vincent Lejeune <vljn@ovi.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-07ALSA: hda/realtek - Fixed ALC286/ALC288 recording delay for Headset MicKailang Yang
It will be recording voice delay for resume back recording for Headset Mic. This alc286 will quickly open Headset Mic, to prevent avoid recording files are missing. The issue was fixed. This is follow ALC286 programing guide. [fix build error, add static and renamed the function by tiwai] Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-06sound: oss: Remove typedefs wanc_info and wavnc_port_infoHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedefs for wanc_info and wavnc_port_info. A simplified version of the Coccinelle semantic patch that finds the case is: @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-06sound: oss: uart401: Remove typedef uart401_devcHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedef for uart401_devc. The following Coccinelle semantic patch detects the case. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05ALSA: usb-audio: Whitespace cleanups for sound/usb/midi.*Adam Goode
Signed-off-by: Adam Goode <agoode@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05ALSA: usb-audio: Respond to suspend and resume callbacks for MIDI inputAdam Goode
sound/usb/card.c registers USB suspend and resume but did not previously kill the input URBs. This means that USB MIDI devices left open across suspend/resume had non-functional input (output still usually worked, but it looks like that is another issue). Before this change, we would get ESHUTDOWN for each of the input URBs at suspend time, killing input. Signed-off-by: Adam Goode <agoode@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05sound/oss/pss: Remove typedefs pss_mixerdata and pss_confdataHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedefs for pss_mixerdata and pss_confdata. The following Coccinelle semantic patch is used to make the change. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05sound/oss/opl3: Remove typedef opl_devinfoHimangi Saraogi
This typedef is unnecessary and should just be removed as they are never used. The following Coccinelle semantic patch detects the case. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05ALSA: fireworks: fix specifiers in format strings for propper outputTakashi Sakamoto
Use %d for loop counter and %X for device capabilities. This is a supplemental patch for Hans Wennborg's patch. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-04Merge tag 'asoc-v3.17' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v3.17 This has been a pretty exciting release in terms of the framework, we've finally got support for multiple CODECs attached to a single DAI link which has been something there's been interest in as long as I've been working on ASoC. A big thanks to Benoit and Misael for their work on this. Otherwise it's been a fairly standard release for development, including more componentisation work from Lars-Peter and a good selection of both CODEC and CPU drivers. - Support for multiple CODECs attached to a single DAI, enabling systems with for example multiple DAC/speaker drivers on a single link, contributed by Benoit Cousson based on work from Misael Lopez Cruz. - Support for byte controls larger than 256 bytes based on the use of TLVs contributed by Omair Mohammed Abdullah. - More componentisation work from Lars-Peter Clausen. - The remainder of the conversions of CODEC drivers to params_width() - Drivers for Cirrus Logic CS4265, Freescale i.MX ASRC blocks, Realtek RT286 and RT5670, Rockchip RK3xxx I2S controllers and Texas Instruments TAS2552. - Lots of updates and fixes, especially to the DaVinci, Intel, Freescale, Realtek, and rcar drivers.
2014-08-04Merge remote-tracking branch 'asoc/topic/wm8985' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branches 'asoc/topic/tlv320aic3x', 'asoc/topic/width', ↵Mark Brown
'asoc/topic/wm0010', 'asoc/topic/wm8904' and 'asoc/topic/wm8962' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/tlv', 'asoc/topic/tlv320aic23', ↵Mark Brown
'asoc/topic/tlv320aic31xx' and 'asoc/topic/tlv320aic32x4' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/sigmadsp', 'asoc/topic/sirf', ↵Mark Brown
'asoc/topic/spdif', 'asoc/topic/tas2552' and 'asoc/topic/tas5086' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/rt5670', 'asoc/topic/rt5677', ↵Mark Brown
'asoc/topic/s6000', 'asoc/topic/samsung' and 'asoc/topic/sh-fsi' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/rl6231', 'asoc/topic/rockchip', ↵Mark Brown
'asoc/topic/rt286', 'asoc/topic/rt5640' and 'asoc/topic/rt5645' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/omap', 'asoc/topic/oom' and ↵Mark Brown
'asoc/topic/pxa' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/intel', 'asoc/topic/kirkwood', ↵Mark Brown
'asoc/topic/max98090' and 'asoc/topic/mc13783' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/fsl', 'asoc/topic/fsl-asrc', ↵Mark Brown
'asoc/topic/fsl-spdif' and 'asoc/topic/imx-audmux' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/cs4265', 'asoc/topic/cs42l56', ↵Mark Brown
'asoc/topic/cs42xx8', 'asoc/topic/cx20442' and 'asoc/topic/davinci' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/atmel', 'asoc/topic/cirrus' and ↵Mark Brown
'asoc/topic/cleanup' into asoc-next
2014-08-04Merge remote-tracking branches 'asoc/topic/adau1977', 'asoc/topic/ak4642', ↵Mark Brown
'asoc/topic/ak5386' and 'asoc/topic/arizona' into asoc-next
2014-08-04Merge remote-tracking branch 'asoc/topic/rcar' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branch 'asoc/topic/pcm1792' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branch 'asoc/topic/core' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branch 'asoc/topic/component' into asoc-nextMark Brown
2014-08-04Merge remote-tracking branch 'asoc/fix/tlv320aic31xx' into asoc-linusMark Brown
2014-08-04Merge remote-tracking branch 'asoc/fix/fsl-sai' into asoc-linusMark Brown
2014-08-04Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2014-08-04Merge tag 'asoc-v3.16-rc5' into asoc-linusMark Brown
ASoC: Fixes for v3.16 A bigger batch of changes than I would like as I didn't send any for a few weeks without noticing how many had built up. They are almost all driver specific though, larger changes are: - Fixes to the newly added Baytrail/MAX98090 which look like some QA was missed on the microphone detection. - Deletion of some erroniously listed audio formats for Haswell. - Fix debugfs creation in the core so that we don't try to generate multiple directories with the same name, relatively large textually but simple to inspect by eye and test. - A couple of bugfixes for the rcar driver one of which which involves a bit of code motion to move initailisation of some hardware out of common paths into device specific ones. - Ensure both channels are powered up for mono outputs on Arizona devices, involving some simple data tables listing the outputs and a loop over them. - A couple of fixes to save and restore information on suspended and idle Samsung I2S controllers. # gpg: Signature made Tue 22 Jul 2014 00:52:53 BST using RSA key ID 7EA229BD # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2014-08-04Merge tag 'asoc-v3.16-rc1' into asoc-linusMark Brown
ASoC: Fixes for v3.16 Quite a few build coverage fixes in here among the usual small driver fixes includling the sigmadsp change from Lars - moving the driver to separate modules per bus (which is basically just code motion) avoids issues with some combinations of buses being enabled. # gpg: Signature made Thu 19 Jun 2014 11:57:31 BST using RSA key ID 7EA229BD # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2014-08-04ASoC: imx-audmux: Use uintptr_t for port numbersMark Brown
Since we pass the port number through file private data for debugfs we cast it to and from a pointer so use uintptr_t in order to ensure that the types are compatible, avoiding warnings on 64 bit platforms where pointers are 64 bit and unsigned integers 32 bit. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-04ASoC: davinci: Enable menuconfig entry for McASPPeter Ujfalusi
In order to be able to use simple-card with McASP on TI SoC based boards we need to be able to select the McASP via menuconfig. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-04ASoC: fsl_asrc: Don't access members of config before checking itNicolin Chen
sound/soc/fsl/fsl_asrc.c:250 fsl_asrc_config_pair() warn: variable dereferenced before check 'config' (see line 243) git remote add next git://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git git remote update next git checkout 3117bb3109dc223e186302f5dc8ce9ed04adca90 vim +/config +250 sound/soc/fsl/fsl_asrc.c 237 */ 238 static int fsl_asrc_config_pair(struct fsl_asrc_pair *pair) 239 { 240 struct asrc_config *config = pair->config; 241 struct fsl_asrc *asrc_priv = pair->asrc_priv; 242 enum asrc_pair_index index = pair->index; @243 u32 inrate = config->input_sample_rate, indiv; 244 u32 outrate = config->output_sample_rate, outdiv; 245 bool ideal = config->inclk == INCLK_NONE; 246 u32 clk_index[2], div[2]; 247 int in, out, channels; 248 struct clk *clk; 249 @250 if (!config) { 251 pair_err("invalid pair config\n"); 252 return -EINVAL; 253 } Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-04ASoC: fsl_sarc_dma: Check pair before using itNicolin Chen
The patch 3117bb3109dc: "ASoC: fsl_asrc: Add ASRC ASoC CPU DAI and platform drivers" from Jul 29, 2014, leads to the following Smatch complaint: sound/soc/fsl/fsl_asrc_dma.c:304 fsl_asrc_dma_shutdown() warn: variable dereferenced before check 'pair' (see line 302) sound/soc/fsl/fsl_asrc_dma.c 301 struct fsl_asrc_pair *pair = runtime->private_data; 302 struct fsl_asrc *asrc_priv = pair->asrc_priv; ^^^^^^^^^^^^^^^ Dereference. 303 304 if (pair && asrc_priv->pair[pair->index] == pair) ^^^^ Check. 305 asrc_priv->pair[pair->index] = NULL; 306 So we just let the driver check pair before using it. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
