path: root/sound
2006-04-07[PATCH] Add default entry for CTL Travel Master U553WTakashi Iwai
Added the default entry of ALC880 configuration table for CTL Travel Master U553W. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-07[PATCH] opti9x - Fix compile without CONFIG_PNPTakashi Iwai
Modules: Opti9xx drivers Fix compile errors without CONFIG_PNP. This patch was already included in Linus' tree. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-06[PATCH] alsa: fix error paths in snd_ctl_elem_add()Takashi Iwai
Fix bugs in error paths of snd_ctl_elem_add() - NULL reference - double free (already freed in snd_ctl_add()) Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] alsa: fix bogus snd_device_free() in opl3-oss.cTakashi Iwai
Remove snd_device_free() for an opl3-oss instance which should have been released. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] snd-cs4236 typo fixRene Herman
I noticed on 2.6.16-rc4 that my MPU-401 wasn't functional, due to a simple copy & paste error in sound/isa/cs423x/cs4236.c. Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] Fix snd-usb-audio in 32-bit compat environmentJuergen Kreileder
I'm getting oopses with snd-usb-audio in 32-bit compat environments: control_compat.c:get_ctl_type() doesn't initialize 'info', so 'itemlist[uinfo->value.enumerated.item]' in usbmixer.c:mixer_ctl_selector_info() might access random memory (The 'if ((int)uinfo->value.enumerated.item >= cval->max)' doesn't fix all problems because of the unsigned -> signed conversion.) Signed-off-by: Juergen Kreileder <jk@blackdown.de> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Greg KH <greg@kroah.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] powerpc: Fix sound driver use of i2cBenjamin Herrenschmidt
The PowerMac sound drivers used to rely on a "bug" of the i2c-keywest driver that implemented I2C_SMBUS_BLOCK_DATA incorrectly, that is it did what I2C_SMBUS_I2C_BLOCK_DATA should have done. The new i2c-powermac driver that replaces keywest has this bug fixed, thus the sound drivers must be fixed too. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] bogus asm/delay.h includesAl Viro
asm/delay.h is non-portable; linux/delay.h should be used in generic code. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-03Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2006-02-01[ARM] 3290/1: Fix the FIFO size detectionCatalin Marinas
Patch from Catalin Marinas AACI reports TX FIFO full after the first write to it if the AC97 is not enabled. This patch enables the AC97 probing before the check for the TX FIFO size. The patch also adds a warning if the TX FIFO size is not multiple of 16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-01[ALSA] hda-codec - Fix typos in alc882 model tableTakashi Iwai
Modules: HDA Codec driver Fixed typos in alc882 model table. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] patch_realtek.c: Add new modelArnaud Patard
Modules: HDA Codec driver This little patch add the model for the motherboard K8N51 from Gigabyte to the known models of ALC boards. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda: sigmatel fixesMatt Porter
Modules: HDA Codec driver * Fix init sequence so manually retaskable jacks don't get added to the line_out list. * Update intel mobo config defaults to specify surround outputs as line outs rather than speakers. Signed-off-by: Matt Porter <mporter@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] Fix adding second dma channelAlexey Dobriyan
Modules: OPL3SA2 driver,GUS Classic driver dma2 is a global array. sprintf below suggests there was a typo. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] intel8x0 - Add MCP51 PCI IDTakashi Iwai
Modules: Documentation,Intel8x0 driver Added MCP51 PCI ID to intel8x0 driver. Also, updated the supported chips in documentation. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda-codec - Fix init verb of ALC260Jonathan Woithe
Modules: HDA Codec driver Fixed the wrong widget id for line-2 selector in the init verb of ALC260. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda-codec - Fix max_channels computation for STAC92xx codecsTakashi Iwai
Modules: HDA Codec driver Fix max_channels computation for STAC92xx codecs in the case only HP pin without line-out pins is detected in the default pin config. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] via82xx - Add dxs entry for P4M800/VIA8237RTakashi Iwai
Modules: VIA82xx driver Added the dxs entry for P4M800/VIA8237R, reported by OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda-codec - add sigmatel 927x codec supportMatt Porter
Modules: HDA Codec driver Adds support for the SigmaTel STAC927x HDA codec family. Signed-off-by: Matt Porter <mporter@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda-codec - add D975XBK support to sigmatel patchMatt Porter
Modules: HDA Codec driver Add SigmaTel HDA support for the Intel D975XBK motherboard. Signed-off-by: Matt Porter <mporter@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] hda-codec - support for Agere's HDA soft modemSasha Khapyorsky
Modules: HDA Codec driver This adds support for Agere's variant of Si3054/5 based HDA modem. Signed-off-by: Sasha Khapyorsky <sashak@alsa-project.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] cs4236 - Add PnP ids for Netfinity 3000Lukasz Stemach
Modules: CS4236+ driver PnP ids for Netfinity 3000 builtin soundcard. This one works for me. This patch was submitted through kernel Bugzilla #4214. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] serial-uart16550 - Fix a compile warningTakashi Iwai
Modules: Generic drivers Fix a gcc-4.1 compile warning regarding uninitialized variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] opti93x - Fix a compile warningTakashi Iwai
Modules: Opti9xx drivers Fix a gcc-4.1 compile warning regarding uninitialized variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] wavefront - Fix a compile warningTakashi Iwai
Modules: Wavefront drivers Fix a gcc-4.1 compile warning regarding uninitialized variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] via82xx - Add dxs entry for a FSC boardTakashi Iwai
Modules: VIA82xx driver Add dxs entry for a FSC board. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01Merge with ↵Jaroslav Kysela
rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
2006-01-31[PATCH] USB: Au1xx0: replace casual readl() with au_readl() in the driversSergei Shtylylov
au_readl() does needed byteswapping, etc. Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-22[ALSA] cs4232/cs4236 - moved CS423X_DRIVER define outside CONFIG_PNPJaroslav Kysela
Modules: CS4236+ driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-22[ALSA] sound/ppc/pmac.c typoStelian Pop
Modules: PPC PMAC driver In 2.6.16-rc1 there is a small typo introduced by the 'Remove device_node addrs/n_addr' changes which prevents my Powerbook G4 sound from working: Advanced Linux Sound Architecture Driver Version 1.0.11rc2 (Wed Jan 04 08:57:20 2006 UTC). snd: can't request rsrc 0 (Sound Control: 0x80000000:80004fff) ALSA device list: No soundcards found. The patch below fixes it. Of course, the patch fixing the i2c issues ('i2c_smbus_write_i2c_block_data' patch) needs to be applied to in order for the sound to completly work. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] pcxhr - Fix printk warningAndrew Morton
Modules: Digigram PCXHR driver sound/pci/pcxhr/pcxhr.c: In function 'pcxhr_update_r_buffer': sound/pci/pcxhr/pcxhr.c:460: warning: unsigned int format, different type arg (arg 7) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] hdsp - Fix printk warningsAndrew Morton
Modules: RME9652 driver sound/pci/rme9652/hdspm.c: In function 'snd_hdspm_preallocate_memory': sound/pci/rme9652/hdspm.c:3327: warning: int format, different type arg (arg 4) sound/pci/rme9652/hdspm.c:3331: warning: int format, different type arg (arg 4) sound/pci/rme9652/hdspm.c: In function 'snd_hdspm_create': sound/pci/rme9652/hdspm.c:3513: warning: int format, different type arg (arg 4) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] sb16 - Fix duplicated PnP entryTakashi Iwai
Modules: SB16/AWE driver Fix the duplicated PnP entry between sb16 and sbawe drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] opl3sa2 - Fix conflict of driver name on sysfsTakashi Iwai
Modules: OPL3SA2 driver Fix the conflict of driver name 'opl3sa2' on sysfs with OSS driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] Fix a typo in snd_assert()Andrew Morton
Modules: CS46xx driver Reported by <dcb314@hotmail.com> in http://bugzilla.kernel.org/show_bug.cgi?id=5903 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] au88x0 - Fix a compile warningTakashi Iwai
Modules: au88x0 driver Fixed an uninitialized variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] via82xx - Add dxs_support entry for EpoX 9HEAITakashi Iwai
Modules: VIA82xx driver Added the dxs_support entry for EpoX 9HEAI. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] hda-codec - Fix capture on Sigmatel STAC92xx codecsTakashi Iwai
Modules: HDA Codec driver Added the missing 'Capture Switch' control for Sigmatel STAC92xx codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] intel8x0: Add quirk for Optiplex GX270Chris Ball
Modules: Intel8x0 driver This patch adds a quirk entry for the Dell Optiplex GX270, on which the volume is set by the headphone control, not the master control. Signed-off-by: Chris Ball <cjb@mrao.cam.ac.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] ali5451: Add PCI_DEVICE and #defines in snd_ali_idsJon Mason
Modules: ALI5451 driver This patch uses #defines for the Vendor ID and Device ID and uses the new PCI_DEVICE macro. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] Prevent ALSA trident driver from grabbing pcnet32 hardwareJon Mason
Modules: Trident driver Some pcnet32 hardware erroneously has the Vendor ID for Trident. The pcnet32 driver looks for the PCI ethernet class before grabbing the hardware, but the current trident driver does not check against the PCI audio class. This allows the trident driver to claim the pcnet32 hardware. This patch prevents that. Per Jiri Slaby's request, I changed the trident driver to use PCI_DEVICE macro and PCI ID #defines. This patch is untested on Trident 4DWAVE_DX hardware, but has been tested on pcnet32 hardware. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] usb-audio: fix non-48k sample rates with SB Audigy 2 ZSClemens Ladisch
Modules: USB generic driver On the Audigy 2 ZS, disable all sample rate that are not a multiple of 48 kHz because the others work only with the digital output which is not yet supported. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-22[ALSA] ymfpci: fix SPDIF sample rate informationClemens Ladisch
Modules: YMFPCI driver Set the (read only) sample rate field in the IEC958 mixer controls to 48 kHz (instead of 44.1 kHz) because that is the rate actually supported by the hardware. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-22[ALSA] ac97 - Fix CLFE channel setting of ALC850Takashi Iwai
Modules: AC97 Codec Fix CLFE channel setting of ALC850 (ALSA bug#1731). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] AMD cs5536 ID for cs5535audioRene Rebe
Modules: CS5535 driver Added AMD CS5536 to the cs5535audio driver. Signed-off-by: Rene Rebe <rene@exactcode.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] usb-audio: don't use empty packets at start of playbackClemens Ladisch
Modules: USB generic driver Some widespread USB interface chips with adaptive iso endpoints hang after receiving a series of empty packets when they expect data (ALSA bug#1585). To avoid this, we have to send packets containing silence (zero samples) instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-22[ALSA] bt87x - fix detection of unknown cardJaroslav Kysela
Modules: BT87x driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-22[ALSA] ac97 - Suppress jack sense controls for ThinkpadsTakashi Iwai
Modules: AC97 Codec Added a blacklist to suppress to create jack sense controls. These controls must be always off on some devices (e.g. Thinkpad). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] hda-codec - Add model entry for Sony VAIOTakashi Iwai
Modules: HDA Codec driver Added an ALC260 model entry (basic) for Sony VAIO. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] pcxhr - Fix the sample rate changesTakashi Iwai
Modules: Digigram PCXHR driver Fix the hardware set up when the sample rate is changed multiple times. Signed-off-by: Takashi Iwai <tiwai@suse.de>
