commit 031f335cda879450095873003abb03ae8ed3b74a upstream.
iMac 14,1 requires the same quirk as iMac 12,2, using GPIO 2 and 3 for
headphone and speaker output amps. Add the codec SSID quirk entry
(106b:0600) accordingly.
BugLink: http://lkml.kernel.org/r/CAEw6Zyteav09VGHRfD5QwsfuWv5a43r0tFBNbfcHXoNrxVz7ew@mail.gmail.com
Reported-by: Freaky <freaky2000@gmail.com>
commit e4c9fd10eb21376f44723c40ad12395089251c28 upstream.
There is another Dell XPS 13 variant (SSID 1028:082a) that requires
the existing fixup for reducing the headphone noise.
This patch adds the quirk entry for that.
BugLink: http://lkml.kernel.org/r/CAHXyb9ZCZJzVisuBARa+UORcjRERV8yokez=DP1_5O5isTz0ZA@mail.gmail.com
Reported-and-tested-by: Francisco G. <frangio.1@gmail.com>
commit 23b19b7b50fe1867da8d431eea9cd3e4b6328c2c upstream.
muldiv32() contains a snd_BUG_ON() (which is morphed as WARN_ON() with
debug option) for checking the case of 0 / 0. This would be helpful
if this happens only as a logical error; however, since the hw refine
is performed with any data set provided by user, the inconsistent
values that can trigger such a condition might be passed easily.
Actually, syzbot caught this by passing some zero'ed old hw_params
ioctl.
So, having snd_BUG_ON() there is simply superfluous and rather
harmful to give unnecessary confusions. Let's get rid of it.
Reported-by: syzbot+7e6ee55011deeebce15d@syzkaller.appspotmail.com
commit 898dfe4687f460ba337a01c11549f87269a13fa2 upstream.
The aloop driver tries to update the hw constraints of the connected
target on the cable of the opened PCM substream. This is done by
adding the extra hw constraints rules referring to the substream
runtime->hw fields, while the other substream may update the runtime
hw of another side on the fly.
This is, however, racy and may result in the inconsistent values when
both PCM streams perform the prepare concurrently. One of the reason
is that it overwrites the other's runtime->hw field; which is not only
racy but also broken when it's called before the open of another side
finishes. And, since the reference to runtime->hw isn't protected,
the concurrent write may give the partial value update and become
inconsistent.
This patch is an attempt to fix and clean up:
- The prepare doesn't change the runtime->hw of other side any longer,
but only update the cable->hw that is referred commonly.
- The extra rules refer to the loopback_pcm object instead of the
runtime->hw. The actual hw is deduced from cable->hw.
- The extra rules take the cable_lock to protect against the race.
Fixes: b1c73fc8e697 ("ALSA: snd-aloop: Fix hw_params restrictions and checking")
commit b088b53e20c7d09b5ab84c5688e609f478e5c417 upstream.
The extra hw constraint rule for the formats the aloop driver
introduced has a slight flaw, where it doesn't return a positive value
when the mask got changed. It came from the fact that it's basically
a copy&paste from snd_hw_constraint_mask64(). The original code is
supposed to be a single-shot and it modifies the mask bits only once
and never after, while what we need for aloop is the dynamic hw rule
that limits the mask bits.
This difference results in the inconsistent state, as the hw_refine
doesn't apply the dependencies fully. The worse and surprisingly
result is that it causes a crash in OSS emulation when multiple
full-duplex reads/writes are performed concurrently (I leave why it
triggers Oops to readers as a homework).
For fixing this, replace a few open-codes with the standard
snd_mask_*() macros.
Reported-by: syzbot+3902b5220e8ca27889ca@syzkaller.appspotmail.com
commit 9685347aa0a5c2869058ca6ab79fd8e93084a67f upstream.
The aloop runtime object and its assignment in the cable are left even
when opening a substream fails. This doesn't mean any memory leak,
but it still keeps the invalid pointer that may be referred by the
another side of the cable spontaneously, which is a potential Oops
cause.
Clean up the cable assignment and the empty cable upon the error path
properly.
Fixes: 597603d615d2 ("ALSA: introduce the snd-aloop module for the PCM loopback")
commit 900498a34a3ac9c611e9b425094c8106bdd7dc1c upstream.
PCM OSS read/write loops keep taking the mutex lock for the whole
read/write, and this might take very long when the exceptionally high
amount of data is given. Also, since it invokes with mutex_lock(),
the concurrent read/write becomes unbreakable.
This patch tries to address these issues by replacing mutex_lock()
with mutex_lock_interruptible(), and also splits / re-takes the lock
at each read/write period chunk, so that it can switch the context
more finely if requested.
commit 29159a4ed7044c52e3e2cf1a9fb55cec4745c60b upstream.
The loops for read and write in PCM OSS emulation have no proper check
of pending signals, and they keep processing even after user tries to
break. This results in a very long delay, often seen as RCU stall
when a huge unprocessed bytes remain queued. The bug could be easily
triggered by syzkaller.
As a simple workaround, this patch adds the proper check of pending
signals and aborts the loop appropriately.
Reported-by: syzbot+993cb4cfcbbff3947c21@syzkaller.appspotmail.com
commit 6708913750344a900f2e73bfe4a4d6dbbce4fe8d upstream.
In the OSS emulation plugin builder where the frame size is parsed in
the plugin chain, some places miss the possible errors returned from
the plugin src_ or dst_frames callback.
This patch papers over such places.
commit fe08f34d066f4404934a509b6806db1a4f700c86 upstream.
syzkaller triggered kernel warnings through PCM OSS emulation at
closing a stream:
WARNING: CPU: 0 PID: 3502 at sound/core/pcm_lib.c:1635
snd_pcm_hw_param_first+0x289/0x690 sound/core/pcm_lib.c:1635
Call Trace:
snd_pcm_hw_param_near.constprop.27+0x78d/0x9a0 sound/core/oss/pcm_oss.c:457
snd_pcm_oss_change_params+0x17d3/0x3720 sound/core/oss/pcm_oss.c:969
snd_pcm_oss_make_ready+0xaa/0x130 sound/core/oss/pcm_oss.c:1128
snd_pcm_oss_sync+0x257/0x830 sound/core/oss/pcm_oss.c:1638
snd_pcm_oss_release+0x20b/0x280 sound/core/oss/pcm_oss.c:2431
__fput+0x327/0x7e0 fs/file_table.c:210
This happens while it tries to open and set up the aloop device
concurrently. The warning above (invoked from snd_BUG_ON() macro) is
to detect the unexpected logical error where snd_pcm_hw_refine() call
shouldn't fail. The theory is true for the case where the hw_params
config rules are static. But for an aloop device, the hw_params rule
condition does vary dynamically depending on the connected target;
when another device is opened and changes the parameters, the device
connected in another side is also affected, and it caused the error
from snd_pcm_hw_refine().
That is, the simplest "solution" for this is to remove the incorrect
assumption of static rules, and treat such an error as a normal error
path. As there are a couple of other places using snd_BUG_ON()
incorrectly, this patch removes these spurious snd_BUG_ON() calls.
Reported-by: syzbot+6f11c7e2a1b91d466432@syzkaller.appspotmail.com
commit 285d5ddcffafa5d5e68c586f4c9eaa8b24a2897d upstream.
It has the codec alc256, and add its pin definition to pin quirk
table to let it apply ALC255_FIXUP_DELL1_MIC_NO_PRESENCE.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit a36c2638380c0a4676647a1f553b70b20d3ebce1 upstream.
Since the commit 97cc2ed27e5a ("ALSA: hda - Fix yet another i915
pointer leftover in error path") cleared hdac_acomp pointer, the
WARN_ON() non-NULL check in snd_hdac_i915_register_notifier() may give
a false-positive warning, as the function gets called no matter
whether the component is registered or not. For fixing it, let's get
rid of the spurious WARN_ON().
Fixes: 97cc2ed27e5a ("ALSA: hda - Fix yet another i915 pointer leftover in error path")
Reported-by: Kouta Okamoto <kouta.okamoto@toshiba.co.jp>
commit 15f8c5f2415bfac73f33a14bcd83422bcbfb5298 upstream.
Fix child-node lookup during probe, which ended up searching the whole
device tree depth-first starting at the parent rather than just matching
on its children.
To make things worse, the parent codec node was also prematurely freed,
while the child node was leaked.
Fixes: 2d6d649a2e0f ("ASoC: twl4030: Support for DT booted kernel")
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 695b78b548d8a26288f041e907ff17758df9e1d5 upstream.
AC'97 ops (register read / write) need SSI regmap and clock, so they have
to be set after them.
We also need to set these ops back to NULL if we fail the probe.
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
commit 5a15f289ee87eaf33f13f08a4909ec99d837ec5f upstream.
The commit 89b89d121ffc ("ALSA: usb-audio: Add check return value for
usb_string()") added the check of the return value from
snd_usb_copy_string_desc(), which is correct per se, but it introduced
a regression. In the original code, either the "Clock Source",
"Playback Source" or "Capture Source" suffix is added after the
terminal string, while the commit changed it to add the suffix only
when get_term_name() is failing. It ended up with an incorrect ctl
name like "PCM" instead of "PCM Capture Source".
Also, even the original code has a similar bug: when the ctl name is
generated from snd_usb_copy_string_desc() for the given iSelector, it
also doesn't put the suffix.
This patch addresses these issues: the suffix is added always when no
static mapping is found. Also the patch tries to put more comments
and cleans up the if/else block for better readability in order to
avoid the same pitfall again.
Fixes: 89b89d121ffc ("ALSA: usb-audio: Add check return value for usb_string()")
Reported-and-tested-by: Mauro Santos <registo.mailling@gmail.com>
commit c1cfd9025cc394fd137a01159d74335c5ac978ce upstream.
The rawmidi also allows to obtaining the information via ioctl of ctl
API. It means that user can issue an ioctl to the rawmidi device even
when it's being removed as long as the control device is present.
Although the code has some protection via the global register_mutex,
its range is limited to the search of the corresponding rawmidi
object, and the mutex is already unlocked at accessing the rawmidi
object. This may lead to a use-after-free.
For avoiding it, this patch widens the application of register_mutex
to the whole snd_rawmidi_info_select() function. We have another
mutex per rawmidi object, but this operation isn't very hot path, so
it shouldn't matter from the performance POV.
commit 97cc2ed27e5a168cf423f67c3bc7c6cc41d12f82 upstream.
The hdac_acomp object in hdac_i915.c is left as assigned even after
binding with i915 actually fails, and this leads to the WARN_ON() at
the next load of the module.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=94736
Cc: Kouta Okamoto <kouta.okamoto@toshiba.co.jp>
commit bed2e98e1f4db8b827df507abc30be7b11b0613d upstream.
Currently HD-audio driver on Intel Skylake or Broxteon gives an error
message when binding with i915 audio component fails. However, this
isn't any serious error on a system without Intel graphics. Indeed
there are such systems, where a third-party codec (e.g. Creative) is
put on the mobo while using other discrete GPU (e.g. Nvidia).
Printing a kernel "error" message is overreaction in such a case.
This patch downgrades the print level for that message. For systems
that mandate the i915 binding (e.g. Haswell or Broadwell HDMI/DP),
another kernel error message is shown in addition to make clear what
went wrong.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111021
commit faafd03d23c913633d2ef7e6ffebdce01b164409 upstream.
The commit [d745f5e7b8b2: ALSA: hda - Add the pin / port mapping on
Intel ILK and VLV] introduced a WARN_ON() to check the pointer for
avoiding the double initializations. But hdac_acomp pointer wasn't
cleared at snd_hdac_i915_exit(), thus after reloading the HD-audio
driver, it may result in the false positive warning. This patch makes
sure to clear the leftover pointer at exit.
Reported-by: Daniela Doras-prodan <daniela.doras-prodan@intel.com>
[ Upstream commit cc3a47a248d7791ef0d2c81a35c46769e55e4c6c ]
This tested patch adds missing initialization for Line-In/Out PINs for
the docking station for HP 840 G3.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
[ Upstream commit 04d5466a976b096364a39a63ac264c1b3a5f8fa1 ]
the docking station for HP 820 G2.
commit 89b89d121ffcf8d9546633b98ded9d18b8f75891 upstream.
snd_usb_copy_string_desc() returns zero if usb_string() fails.
In case of failure, we need to check the snd_usb_copy_string_desc()'s
return value and add an exception case
Signed-off-by: Jaejoong Kim <climbbb.kim@gmail.com>
commit 251552a2b0d454badc8f486e6d79100970c744b0 upstream.
The snd_usb_copy_string_desc() retrieves the usb string corresponding to
the index number through the usb_string(). The problem is that the
usb_string() returns the length of the string (>= 0) when successful, but
it can also return a negative value about the error case or status of
usb_control_msg().
If iClockSource is '0' as shown below, usb_string() will returns -EINVAL.
This will result in '0' being inserted into buf[-22], and the following
KASAN out-of-bound error message will be output.
AudioControl Interface Descriptor:
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 1
bmAttributes 0x07 Internal programmable Clock (synced to SOF)
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
To fix it, check usb_string()'return value and bail out.
BUG: KASAN: stack-out-of-bounds in parse_audio_unit+0x1327/0x1960 [snd_usb_audio]
Write of size 1 at addr ffff88007e66735a by task systemd-udevd/18376
CPU: 0 PID: 18376 Comm: systemd-udevd Not tainted 4.13.0+ #3
Hardware name: LG Electronics 15N540-RFLGL/White Tip Mountain, BIOS 15N5
Call Trace:
dump_stack+0x63/0x8d
print_address_description+0x70/0x290
? parse_audio_unit+0x1327/0x1960 [snd_usb_audio]
kasan_report+0x265/0x350
__asan_store1+0x4a/0x50
? save_stack+0xb5/0xd0
? save_stack_trace+0x1b/0x20
? save_stack+0x46/0xd0
? kasan_kmalloc+0xad/0xe0
? kmem_cache_alloc_trace+0xff/0x230
? snd_usb_create_mixer+0xb0/0x4b0 [snd_usb_audio]
? usb_audio_probe+0x4de/0xf40 [snd_usb_audio]
? usb_probe_interface+0x1f5/0x440
? driver_probe_device+0x3ed/0x660
? build_feature_ctl+0xb10/0xb10 [snd_usb_audio]
? init_object+0x69/0xa0
? snd_usb_find_csint_desc+0xa8/0xf0 [snd_usb_audio]
snd_usb_mixer_controls+0x1dc/0x370 [snd_usb_audio]
? build_audio_procunit+0x890/0x890 [snd_usb_audio]
? usb_ifnum_to_if+0xbd/0xf0
snd_usb_create_mixer+0x25b/0x4b0 [snd_usb_audio]
? snd_usb_create_stream+0x255/0x2c0 [snd_usb_audio]
? snd_usb_autosuspend.part.7+0x30/0x30 [snd_usb_audio]
? __pm_runtime_idle+0x90/0x90
? kernfs_activate+0xa6/0xc0
? usb_match_one_id_intf+0xdc/0x130
? __pm_runtime_set_status+0x2d4/0x450
commit 43a3542870328601be02fcc9d27b09db467336ef upstream.
The use of snd_BUG_ON() in ALSA sequencer timer may lead to a spurious
WARN_ON() when a slave timer is deployed as its backend and a
corresponding master timer stops meanwhile. The symptom was triggered
by syzkaller spontaneously.
Since the NULL timer is valid there, rip off snd_BUG_ON().
Reported-by: syzbot <syzkaller@googlegroups.com>
commit 362bca57f5d78220f8b5907b875961af9436e229 upstream.
When the device descriptor is closed, the `substream->runtime` pointer
is freed. But another thread may be in the ioctl handler, case
SNDRV_CTL_IOCTL_PCM_INFO. This case calls snd_pcm_info_user() which
calls snd_pcm_info() which accesses the now freed `substream->runtime`.
Note: this fixes CVE-2017-0861
Signed-off-by: Robb Glasser <rglasser@google.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit 1cab2a84f470e15ecc8e5143bfe9398c6e888032 ]
Protect against corrupt firmware files by ensuring that the length we
get for the data in a region actually lies within the available firmware
file data buffer.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
[ Upstream commit 0ea617a298dcdc2251b4e10f83ac3f3e627b66e3 ]
On an error, snd_ctl_add already free's kctrl, so calling snd_ctl_free_one
to free it again leads to a double free error. Fix this by removing
the extraneous snd_ctl_free_one call.
Issue found using static analysis with CoverityScan, CID 1372908
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[ Upstream commit 972aa2c708703c21f14eb958b37e82aae2530e44 ]
Setting shutup when the action is HDA_FIXUP_ACT_PRE_PROBE might
not have the desired effect since it could be overridden by
another more generic shutup function. Prevent this by setting
the more specific shutup function on HDA_FIXUP_ACT_PROBE.
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit 2d7fe6185722b0817bb345f62ab06b76a7b26542 upstream.
It maybe the typo for ALC700 support patch.
To fix the bit value on this patch.
Fixes: 6fbae35a3170 ("ALSA: hda/realtek - Add support for new codecs ALC700/ALC701/ALC703")
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 3d4e8303f2c747c8540a0a0126d0151514f6468b upstream.
Some timer compat ioctls have NULL checks of timer instance with
snd_BUG_ON() that bring up WARN_ON() when the debug option is set.
Actually the condition can be met in the normal situation and it's
confusing and bad to spew kernel warnings with stack trace there.
Let's remove snd_BUG_ON() invocation and replace with the simple
checks. Also, correct the error code to EBADFD to follow the native
ioctl error handling.
commit 0a62d6c966956d77397c32836a5bbfe3af786fc1 upstream.
The helper functions to parse and look for the clock source, selector
and multiplier unit may return the descriptor with a too short length
than required, while there is no sanity check in the caller side.
Add some sanity checks in the parsers, at least, to guarantee the
given descriptor size, for avoiding the potential crashes.
Fixes: 79f920fbff56 ("ALSA: usb-audio: parse clock topology of UAC2 devices")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit f658f17b5e0e339935dca23e77e0f3cad591926b upstream.
The usb-audio driver may trigger an out-of-bound access at parsing a
malformed selector unit, as it checks the header length only after
evaluating bNrInPins field, which can be already above the given
length. Fix it by adding the length check beforehand.
Fixes: 99fc86450c43 ("ALSA: usb-mixer: parse descriptors with structs")
commit d937cd6790a2bef2d07b500487646bd794c039bb upstream.
When the usb-audio descriptor contains the malformed feature unit
description with a too short length, the driver may access
out-of-bounds. Add a sanity check of the header size at the beginning
of parse_audio_feature_unit().
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
commit 20e3f985bb875fea4f86b04eba4b6cc29bfd6b71 upstream.
commit 3179f6200188 ("ALSA: core: add .get_time_info") had a side effect
of changing the behaviour of the PCM runtime tstamp. Prior to this
change tstamp was not updated by snd_pcm_update_hw_ptr0() unless the
hw_ptr had moved, after this change tstamp was always updated.
For an application using alsa-lib, doing snd_pcm_readi() followed by
snd_pcm_status() to estimate the age of the read samples by subtracting
status->avail * [sample rate] from status->tstamp this change degraded
the accuracy of the estimate on devices where the pcm hw does not
provide a granular hw_ptr, e.g., devices using
soc-generic-dmaengine-pcm.c and a dma-engine with residue_granularity
DMA_RESIDUE_GRANULARITY_DESCRIPTOR. The accuracy of the estimate
depended on the latency between the PCM hw completing a period and the
driver called snd_pcm_period_elapsed() to notify ALSA core, typically
determined by interrupt handling latency. After the change the accuracy
of the estimate depended on the latency between the PCM hw completing a
period and the application calling snd_pcm_status(), determined by the
scheduling of the application process. The maximum error of the
estimate is one period length in both cases, but the error average and
variance is smaller when it depends on interrupt latency.
Instead of always updating tstamp, update it only if audio_tstamp
changed.
Fixes: 3179f6200188 ("ALSA: core: add .get_time_info")
Suggested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Henrik Eriksson <henrik.eriksson@axis.com>
commit 9ceace3c9c18c67676e75141032a65a8e01f9a7a upstream.
This commit adds PCI ID for Raven platform
Signed-off-by: Vijendar Mukunda <Vijendar.Mukunda@amd.com>
[ Upstream commit 28f1f9b26cee161ddd3985b3eb78e3ffada08dda ]
ALC299 was similar as ALC225.
Add headset support for ALC299.
ALC3271 was for Dell rename.
[ Upstream commit 874e1f6fad9a5184b67f4cee37c1335cd2cc5677 ]
The pseudo DMA transfer codes in VX222 and VX-pocket driver have a
slight bug where they check the buffer boundary wrongly, and may
overflow. Also, the zero sample count might be handled badly for the
playback (although it shouldn't happen in theory). This patch
addresses these issues.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=141541
[ Upstream commit ed3c177d960bb5881b945ca6f784868126bb90db ]
The update of stream costs significantly, and we should avoid it
unless the stream really has started. Check pipe->running flag
instead of pipe->prepared.
commit fc27fe7e8deef2f37cba3f2be2d52b6ca5eb9d57 upstream.
ALSA sequencer core has a mechanism to load the enumerated devices
automatically, and it's performed in an off-load work. This seems
causing some race when a sequencer is removed while the pending
autoload work is running. As syzkaller spotted, it may lead to some
use-after-free:
BUG: KASAN: use-after-free in snd_rawmidi_dev_seq_free+0x69/0x70
sound/core/rawmidi.c:1617
Write of size 8 at addr ffff88006c611d90 by task kworker/2:1/567
CPU: 2 PID: 567 Comm: kworker/2:1 Not tainted 4.13.0+ #29
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events autoload_drivers
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x192/0x22c lib/dump_stack.c:52
print_address_description+0x78/0x280 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x230/0x340 mm/kasan/report.c:409
__asan_report_store8_noabort+0x1c/0x20 mm/kasan/report.c:435
snd_rawmidi_dev_seq_free+0x69/0x70 sound/core/rawmidi.c:1617
snd_seq_dev_release+0x4f/0x70 sound/core/seq_device.c:192
device_release+0x13f/0x210 drivers/base/core.c:814
kobject_cleanup lib/kobject.c:648 [inline]
kobject_release lib/kobject.c:677 [inline]
kref_put include/linux/kref.h:70 [inline]
kobject_put+0x145/0x240 lib/kobject.c:694
put_device+0x25/0x30 drivers/base/core.c:1799
klist_devices_put+0x36/0x40 drivers/base/bus.c:827
klist_next+0x264/0x4a0 lib/klist.c:403
next_device drivers/base/bus.c:270 [inline]
bus_for_each_dev+0x17e/0x210 drivers/base/bus.c:312
autoload_drivers+0x3b/0x50 sound/core/seq_device.c:117
process_one_work+0x9fb/0x1570 kernel/workqueue.c:2097
worker_thread+0x1e4/0x1350 kernel/workqueue.c:2231
kthread+0x324/0x3f0 kernel/kthread.c:231
ret_from_fork+0x25/0x30 arch/x86/entry/entry_64.S:425
The fix is simply to assure canceling the autoload work at removing
the device.
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 132d358b183ac6ad8b3fea32ad5e0663456d18d1 upstream.
The SYSEX event delivery in OSS sequencer emulation assumed that the
event is encoded in the variable-length data with the straight
buffering. This was the normal behavior in the past, but during the
development, the chained buffers were introduced for carrying more
data, while the OSS code was left intact. As a result, when a SYSEX
event with the chained buffer data is passed to OSS sequencer port,
it may end up with the wrong memory access, as if it were having a too
large buffer.
This patch addresses the bug, by applying the buffer data expansion by
the generic snd_seq_dump_var_event() helper function.
Reported-by: Mark Salyzyn <salyzyn@android.com>
commit 1e6f4fc06f6411adf98bbbe7fcd79442cd2b2a75 upstream.
The ADC in the ADAU1361 (and possibly other Analog Devices codecs)
exhibits a cyclic variation in the noise floor (in our test setup between
-87 and -93 dB), a new value being attained within this range whenever a
new capture stream is started. The cycle repeats after about 10 or 11
restarts.
The workaround recommended by the manufacturer is to toggle the ADOSR bit
in the Converter Control 0 register each time a new capture stream is
started.
I have verified that the patch fixes this problem on the ADAU1361, and
according to the manufacturer toggling the bit in question in this manner
will at least have no detrimental effect on other chips served by this
driver.
Signed-off-by: Ricard Wanderlof <ricardw@axis.com>
commit 1f20f9ff57ca23b9f5502fca85ce3977e8496cb1 upstream.
syzkaller reported the lockdep splat due to the possible deadlock of
grp->list_mutex of each sequencer client object. Actually this is
rather a false-positive report due to the missing nested lock
annotations. The sequencer client may deliver the event directly to
another client which takes another own lock.
For addressing this issue, this patch replaces the simple down_read()
with down_read_nested(). As a lock subclass, the already existing
"hop" can be re-used, which indicates the depth of the call.
Reference: http://lkml.kernel.org/r/089e082686ac9b482e055c832617@google.com
Reported-by: syzbot <bot+7feb8de6b4d6bf810cf098bef942cc387e79d0ad@syzkaller.appspotmail.com>
commit 79fb0518fec8c8b4ea7f1729f54f293724b3dbb0 upstream.
The races among ioctl and other operations were protected by the
commit af368027a49a ("ALSA: timer: Fix race among timer ioctls") and
later fixes, but one code path was forgotten in the scenario: the
32bit compat ioctl. As syzkaller recently spotted, a very similar
use-after-free may happen with the combination of compat ioctls.
The fix is simply to apply the same ioctl_lock to the compat_ioctl
callback, too.
Fixes: af368027a49a ("ALSA: timer: Fix race among timer ioctls")
Reported-by: syzbot <bot+e5f3c9783e7048a74233054febbe9f1bdf54b6da@syzkaller.appspotmail.com>
commit f265788c336979090ac80b9ae173aa817c4fe40d upstream.
We have several Dell laptops which use the codec alc236, the headset
mic can't work on these machines. Following the commit 736f20a70, we
add the pin cfg table to make the headset mic work.
commit 736f20a7060857ff569e9e9586ae6c1204a73e07 upstream.
Add support for ALC236/ALC3204.
Add headset mode support for ALC236/ALC3204.
commit 6bf88a343db2b3c160edf9b82a74966b31cc80bd upstream.
While converting the error messages to the standard macros in the
commit 4e76a8833fac ("ALSA: hda - Replace with standard printk"), a
superfluous '-' slipped in the code mistakenly. Its influence is
almost negligible, merely shows a dB value as negative integer instead
of positive integer (or vice versa) in the rare error message.
So let's kill this embarrassing byte to show more correct value.
Fixes: 4e76a8833fac ("ALSA: hda - Replace with standard printk")
commit 8009d506a1dd00cf436b0c4cca0dcec130580a21 upstream.
The 'use' locking macros are no-ops if neither SMP or SND_DEBUG is
enabled. This might once have been OK in non-preemptible
configurations, but even in that case snd_seq_read() may sleep while
relying on a 'use' lock. So always use the proper implementations.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 9bb201a5d5acc733943e8af7151cceab9d976a69 upstream.
Add native DSD support quirk for Pro-Ject Pre Box S2 Digital USB id
2772:0230.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
commit c95072b3d88fac4be295815f2b67df366c0c297f upstream.
While line6_probe() may kick off URB for a control MIDI endpoint, the
function doesn't clean up it properly at its error path. This results
in a leftover URB action that is eventually triggered later and causes
an Oops like:
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 0 Comm: swapper/1 Not tainted
RIP: 0010:usb_fill_bulk_urb ./include/linux/usb.h:1619
RIP: 0010:line6_start_listen+0x3fe/0x9e0 sound/usb/line6/driver.c:76
Call Trace:
<IRQ>
line6_data_received+0x1f7/0x470 sound/usb/line6/driver.c:326
__usb_hcd_giveback_urb+0x2e0/0x650 drivers/usb/core/hcd.c:1779
usb_hcd_giveback_urb+0x337/0x420 drivers/usb/core/hcd.c:1845
dummy_timer+0xba9/0x39f0 drivers/usb/gadget/udc/dummy_hcd.c:1965
call_timer_fn+0x2a2/0x940 kernel/time/timer.c:1281
Since the whole clean-up procedure is done in line6_disconnect()
callback, we can simply call it in the error path instead of
open-coding the whole again. It'll fix such an issue automagically.
The bug was spotted by syzkaller.
Fixes: eedd0e95d355 ("ALSA: line6: Don't forget to call driver's destructor at error path")
commit 99fee508245825765ff60155fed43f970ff83a8f upstream.
caiaq driver doesn't kill the URB properly at its error path during
the probe, which may lead to a use-after-free error later. This patch
addresses it.
Reported-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Johan Hovold <johan@kernel.org>
