[ Upstream commit 1cab2a84f470e15ecc8e5143bfe9398c6e888032 ]
Protect against corrupt firmware files by ensuring that the length we
get for the data in a region actually lies within the available firmware
file data buffer.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 0ea617a298dcdc2251b4e10f83ac3f3e627b66e3 ]
On an error, snd_ctl_add already free's kctrl, so calling snd_ctl_free_one
to free it again leads to a double free error. Fix this by removing
the extraneous snd_ctl_free_one call.
Issue found using static analysis with CoverityScan, CID 1372908
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[ Upstream commit 972aa2c708703c21f14eb958b37e82aae2530e44 ]
Setting shutup when the action is HDA_FIXUP_ACT_PRE_PROBE might
not have the desired effect since it could be overridden by
another more generic shutup function. Prevent this by setting
the more specific shutup function on HDA_FIXUP_ACT_PROBE.
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit 2d7fe6185722b0817bb345f62ab06b76a7b26542 upstream.
It maybe the typo for ALC700 support patch.
To fix the bit value on this patch.
Fixes: 6fbae35a3170 ("ALSA: hda/realtek - Add support for new codecs ALC700/ALC701/ALC703")
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit c2432466f583cb719b35a41e757da587d9ab1d00 upstream.
We got a regression report about the HD-audio HDMI chmap, where some
surround channels are reported as UNKNOWN. The git bisection pointed
the culprit at the commit 9b3dc8aa3fb1 ("ALSA: hda - Register chmap
obj as priv data instead of codec"). The story behind scene is like
this:
- While moving the code out of the legacy HDA to the HDA common place,
the patch modifies the code to obtain the chmap array indirectly in
a byte array, and it expands it to kctl value array.
- At the latter operation, the size of the array is wrongly passed by
sizeof() to the pointer.
- It can be 4 on 32bit arch, thus too short for 6+ channels.
(And that's the reason why it didn't hit other persons; it's 8 on
64bit arch, thus it's usually enough.)
The code was further changed meanwhile, but the problem persisted.
Let's fix it by correctly evaluating the array size.
Fixes: 9b3dc8aa3fb1 ("ALSA: hda - Register chmap obj as priv data instead of codec")
Reported-by: VDR User <user.vdr@gmail.com>
commit 3d4e8303f2c747c8540a0a0126d0151514f6468b upstream.
Some timer compat ioctls have NULL checks of timer instance with
snd_BUG_ON() that bring up WARN_ON() when the debug option is set.
Actually the condition can be met in the normal situation and it's
confusing and bad to spew kernel warnings with stack trace there.
Let's remove snd_BUG_ON() invocation and replace with the simple
checks. Also, correct the error code to EBADFD to follow the native
ioctl error handling.
Reported-by: syzbot <syzkaller@googlegroups.com>
commit 0a62d6c966956d77397c32836a5bbfe3af786fc1 upstream.
The helper functions to parse and look for the clock source, selector
and multiplier unit may return the descriptor with a too short length
than required, while there is no sanity check in the caller side.
Add some sanity checks in the parsers, at least, to guarantee the
given descriptor size, for avoiding the potential crashes.
Fixes: 79f920fbff56 ("ALSA: usb-audio: parse clock topology of UAC2 devices")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit f658f17b5e0e339935dca23e77e0f3cad591926b upstream.
The usb-audio driver may trigger an out-of-bound access at parsing a
malformed selector unit, as it checks the header length only after
evaluating bNrInPins field, which can be already above the given
length. Fix it by adding the length check beforehand.
Fixes: 99fc86450c43 ("ALSA: usb-mixer: parse descriptors with structs")
commit d937cd6790a2bef2d07b500487646bd794c039bb upstream.
When the usb-audio descriptor contains the malformed feature unit
description with a too short length, the driver may access
out-of-bounds. Add a sanity check of the header size at the beginning
of parse_audio_feature_unit().
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
commit 20e3f985bb875fea4f86b04eba4b6cc29bfd6b71 upstream.
commit 3179f6200188 ("ALSA: core: add .get_time_info") had a side effect
of changing the behaviour of the PCM runtime tstamp. Prior to this
change tstamp was not updated by snd_pcm_update_hw_ptr0() unless the
hw_ptr had moved, after this change tstamp was always updated.
For an application using alsa-lib, doing snd_pcm_readi() followed by
snd_pcm_status() to estimate the age of the read samples by subtracting
status->avail * [sample rate] from status->tstamp this change degraded
the accuracy of the estimate on devices where the pcm hw does not
provide a granular hw_ptr, e.g., devices using
soc-generic-dmaengine-pcm.c and a dma-engine with residue_granularity
DMA_RESIDUE_GRANULARITY_DESCRIPTOR. The accuracy of the estimate
depended on the latency between the PCM hw completing a period and the
driver called snd_pcm_period_elapsed() to notify ALSA core, typically
determined by interrupt handling latency. After the change the accuracy
of the estimate depended on the latency between the PCM hw completing a
period and the application calling snd_pcm_status(), determined by the
scheduling of the application process. The maximum error of the
estimate is one period length in both cases, but the error average and
variance is smaller when it depends on interrupt latency.
Instead of always updating tstamp, update it only if audio_tstamp
changed.
Fixes: 3179f6200188 ("ALSA: core: add .get_time_info")
Suggested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Signed-off-by: Henrik Eriksson <henrik.eriksson@axis.com>
commit 9ceace3c9c18c67676e75141032a65a8e01f9a7a upstream.
This commit adds PCI ID for Raven platform
Signed-off-by: Vijendar Mukunda <Vijendar.Mukunda@amd.com>
[ Upstream commit 28f1f9b26cee161ddd3985b3eb78e3ffada08dda ]
ALC299 was similar as ALC225.
Add headset support for ALC299.
ALC3271 was for Dell rename.
[ Upstream commit 874e1f6fad9a5184b67f4cee37c1335cd2cc5677 ]
The pseudo DMA transfer codes in VX222 and VX-pocket driver have a
slight bug where they check the buffer boundary wrongly, and may
overflow. Also, the zero sample count might be handled badly for the
playback (although it shouldn't happen in theory). This patch
addresses these issues.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=141541
[ Upstream commit ed3c177d960bb5881b945ca6f784868126bb90db ]
The update of stream costs significantly, and we should avoid it
unless the stream really has started. Check pipe->running flag
instead of pipe->prepared.
commit fc27fe7e8deef2f37cba3f2be2d52b6ca5eb9d57 upstream.
ALSA sequencer core has a mechanism to load the enumerated devices
automatically, and it's performed in an off-load work. This seems
causing some race when a sequencer is removed while the pending
autoload work is running. As syzkaller spotted, it may lead to some
use-after-free:
BUG: KASAN: use-after-free in snd_rawmidi_dev_seq_free+0x69/0x70
sound/core/rawmidi.c:1617
Write of size 8 at addr ffff88006c611d90 by task kworker/2:1/567
CPU: 2 PID: 567 Comm: kworker/2:1 Not tainted 4.13.0+ #29
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events autoload_drivers
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x192/0x22c lib/dump_stack.c:52
print_address_description+0x78/0x280 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x230/0x340 mm/kasan/report.c:409
__asan_report_store8_noabort+0x1c/0x20 mm/kasan/report.c:435
snd_rawmidi_dev_seq_free+0x69/0x70 sound/core/rawmidi.c:1617
snd_seq_dev_release+0x4f/0x70 sound/core/seq_device.c:192
device_release+0x13f/0x210 drivers/base/core.c:814
kobject_cleanup lib/kobject.c:648 [inline]
kobject_release lib/kobject.c:677 [inline]
kref_put include/linux/kref.h:70 [inline]
kobject_put+0x145/0x240 lib/kobject.c:694
put_device+0x25/0x30 drivers/base/core.c:1799
klist_devices_put+0x36/0x40 drivers/base/bus.c:827
klist_next+0x264/0x4a0 lib/klist.c:403
next_device drivers/base/bus.c:270 [inline]
bus_for_each_dev+0x17e/0x210 drivers/base/bus.c:312
autoload_drivers+0x3b/0x50 sound/core/seq_device.c:117
process_one_work+0x9fb/0x1570 kernel/workqueue.c:2097
worker_thread+0x1e4/0x1350 kernel/workqueue.c:2231
kthread+0x324/0x3f0 kernel/kthread.c:231
ret_from_fork+0x25/0x30 arch/x86/entry/entry_64.S:425
The fix is simply to assure canceling the autoload work at removing
the device.
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 96e53c41e1f81c9e9d1ce38d3f28b95668b71dcf upstream.
The dapm components are now handled by the ALSA SoC SPDIF DIT driver
so can be removed.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 132d358b183ac6ad8b3fea32ad5e0663456d18d1 upstream.
The SYSEX event delivery in OSS sequencer emulation assumed that the
event is encoded in the variable-length data with the straight
buffering. This was the normal behavior in the past, but during the
development, the chained buffers were introduced for carrying more
data, while the OSS code was left intact. As a result, when a SYSEX
event with the chained buffer data is passed to OSS sequencer port,
it may end up with the wrong memory access, as if it were having a too
large buffer.
This patch addresses the bug, by applying the buffer data expansion by
the generic snd_seq_dump_var_event() helper function.
Reported-by: Mark Salyzyn <salyzyn@android.com>
[ Upstream commit 3639ac1cd5177685a5c8abb7230096b680e1d497 ]
This patch corrects an omission in bytcr_rt5640 and bytcr_rt5651.
All existing machine drivers shall not use .pm_ops to avoid a double
suspend, as initially implemented by 3f2dcbeaeb2b
("ASoC: Intel: Remove soc pm handling to allow platform driver handle it").
Reported-by: Shrirang Bagul <shrirang.bagul@canonical.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
commit 1e6f4fc06f6411adf98bbbe7fcd79442cd2b2a75 upstream.
The ADC in the ADAU1361 (and possibly other Analog Devices codecs)
exhibits a cyclic variation in the noise floor (in our test setup between
-87 and -93 dB), a new value being attained within this range whenever a
new capture stream is started. The cycle repeats after about 10 or 11
restarts.
The workaround recommended by the manufacturer is to toggle the ADOSR bit
in the Converter Control 0 register each time a new capture stream is
started.
I have verified that the patch fixes this problem on the ADAU1361, and
according to the manufacturer toggling the bit in question in this manner
will at least have no detrimental effect on other chips served by this
driver.
Signed-off-by: Ricard Wanderlof <ricardw@axis.com>
commit 1f20f9ff57ca23b9f5502fca85ce3977e8496cb1 upstream.
syzkaller reported the lockdep splat due to the possible deadlock of
grp->list_mutex of each sequencer client object. Actually this is
rather a false-positive report due to the missing nested lock
annotations. The sequencer client may deliver the event directly to
another client which takes another own lock.
For addressing this issue, this patch replaces the simple down_read()
with down_read_nested(). As a lock subclass, the already existing
"hop" can be re-used, which indicates the depth of the call.
Reference: http://lkml.kernel.org/r/089e082686ac9b482e055c832617@google.com
Reported-by: syzbot <bot+7feb8de6b4d6bf810cf098bef942cc387e79d0ad@syzkaller.appspotmail.com>
commit 79fb0518fec8c8b4ea7f1729f54f293724b3dbb0 upstream.
The races among ioctl and other operations were protected by the
commit af368027a49a ("ALSA: timer: Fix race among timer ioctls") and
later fixes, but one code path was forgotten in the scenario: the
32bit compat ioctl. As syzkaller recently spotted, a very similar
use-after-free may happen with the combination of compat ioctls.
The fix is simply to apply the same ioctl_lock to the compat_ioctl
callback, too.
Fixes: af368027a49a ("ALSA: timer: Fix race among timer ioctls")
Reported-by: syzbot <bot+e5f3c9783e7048a74233054febbe9f1bdf54b6da@syzkaller.appspotmail.com>
commit f265788c336979090ac80b9ae173aa817c4fe40d upstream.
We have several Dell laptops which use the codec alc236, the headset
mic can't work on these machines. Following the commit 736f20a70, we
add the pin cfg table to make the headset mic work.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 736f20a7060857ff569e9e9586ae6c1204a73e07 upstream.
Add support for ALC236/ALC3204.
Add headset mode support for ALC236/ALC3204.
commit 098a0a62c1554f5a3813ef1b8539563214ada8f6 upstream.
The loop in snd_hdac_bus_parse_capabilities() may go to nirvana when
it hits an invalid register value read:
BUG: unable to handle kernel paging request at ffffad5dc41f3fff
IP: pci_azx_readl+0x5/0x10 [snd_hda_intel]
Call Trace:
snd_hdac_bus_parse_capabilities+0x3c/0x1f0 [snd_hda_core]
azx_probe_continue+0x7d5/0x940 [snd_hda_intel]
This happened on a new Intel machine, and we need to check the value
and abort the loop accordingly.
[Note: the fixes tag below indicates only the commit where this patch
can be applied; the original problem was introduced even before that
commit]
Fixes: 6720b38420a0 ("ALSA: hda - move bus_parse_capabilities to core")
Acked-by: Vinod Koul <vinod.koul@intel.com>
commit 6bf88a343db2b3c160edf9b82a74966b31cc80bd upstream.
While converting the error messages to the standard macros in the
commit 4e76a8833fac ("ALSA: hda - Replace with standard printk"), a
superfluous '-' slipped in the code mistakenly. Its influence is
almost negligible, merely shows a dB value as negative integer instead
of positive integer (or vice versa) in the rare error message.
So let's kill this embarrassing byte to show more correct value.
Fixes: 4e76a8833fac ("ALSA: hda - Replace with standard printk")
commit 8009d506a1dd00cf436b0c4cca0dcec130580a21 upstream.
The 'use' locking macros are no-ops if neither SMP or SND_DEBUG is
enabled. This might once have been OK in non-preemptible
configurations, but even in that case snd_seq_read() may sleep while
relying on a 'use' lock. So always use the proper implementations.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 9bb201a5d5acc733943e8af7151cceab9d976a69 upstream.
Add native DSD support quirk for Pro-Ject Pre Box S2 Digital USB id
2772:0230.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
[ Upstream commit 72cedf599fcebfd6cd2550274d7855838068d28c ]
We should not select drivers that depend on I2C when that is disabled,
as it results in a build error:
warning: (SND_SOC_MT2701_CS42448) selects SND_SOC_CS42XX8_I2C which has unmet direct dependencies (SOUND && !M68K && !UML && SND && SND_SOC && I2C)
sound/soc/codecs/cs42xx8-i2c.c:60:1: warning: data definition has no type or storage class
module_i2c_driver(cs42xx8_i2c_driver);
sound/soc/codecs/cs42xx8-i2c.c:60:1: error: type defaults to 'int' in declaration of 'module_i2c_driver' [-Werror=implicit-int]
Fixes: 1f458d53f76c ("ASoC: mediatek: Add mt2701-cs42448 driver and config option.")
[ Upstream commit 126cfa2f5e15ae2ca7f70be71b07e6cd8d2b44d1 ]
Geminilake HDMI codec 0x280d is similar to previous platforms, so add it with
similar ops as previous.
Signed-off-by: Senthilnathan Veppur <senthilnathanx.veppur@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit c95072b3d88fac4be295815f2b67df366c0c297f upstream.
While line6_probe() may kick off URB for a control MIDI endpoint, the
function doesn't clean up it properly at its error path. This results
in a leftover URB action that is eventually triggered later and causes
an Oops like:
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 0 Comm: swapper/1 Not tainted
RIP: 0010:usb_fill_bulk_urb ./include/linux/usb.h:1619
RIP: 0010:line6_start_listen+0x3fe/0x9e0 sound/usb/line6/driver.c:76
Call Trace:
<IRQ>
line6_data_received+0x1f7/0x470 sound/usb/line6/driver.c:326
__usb_hcd_giveback_urb+0x2e0/0x650 drivers/usb/core/hcd.c:1779
usb_hcd_giveback_urb+0x337/0x420 drivers/usb/core/hcd.c:1845
dummy_timer+0xba9/0x39f0 drivers/usb/gadget/udc/dummy_hcd.c:1965
call_timer_fn+0x2a2/0x940 kernel/time/timer.c:1281
Since the whole clean-up procedure is done in line6_disconnect()
callback, we can simply call it in the error path instead of
open-coding the whole again. It'll fix such an issue automagically.
The bug was spotted by syzkaller.
Fixes: eedd0e95d355 ("ALSA: line6: Don't forget to call driver's destructor at error path")
commit cb02ffc76a53b5ea751b79b8d4f4d180e5868475 upstream.
The error path in podhd_init() tries to clear the pending timer, while
the timer object is initialized at the end of init sequence, thus it
may hit the uninitialized object, as spotted by syzkaller:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 1 PID: 1845 Comm: kworker/1:2 Not tainted
4.14.0-rc2-42613-g1488251d1a98 #238
Workqueue: usb_hub_wq hub_event
Call Trace:
dump_stack+0x292/0x395 lib/dump_stack.c:52
register_lock_class+0x6c4/0x1a00 kernel/locking/lockdep.c:769
__lock_acquire+0x27e/0x4550 kernel/locking/lockdep.c:3385
lock_acquire+0x259/0x620 kernel/locking/lockdep.c:4002
del_timer_sync+0x12c/0x280 kernel/time/timer.c:1237
podhd_disconnect+0x8c/0x160 sound/usb/line6/podhd.c:299
line6_probe+0x844/0x1310 sound/usb/line6/driver.c:783
podhd_probe+0x64/0x70 sound/usb/line6/podhd.c:474
For addressing it, assure the initializations of timer and work by
moving them to the beginning of podhd_init().
Fixes: 790869dacc3d ("ALSA: line6: Add support for POD X3")
commit 99fee508245825765ff60155fed43f970ff83a8f upstream.
caiaq driver doesn't kill the URB properly at its error path during
the probe, which may lead to a use-after-free error later. This patch
addresses it.
Reported-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Johan Hovold <johan@kernel.org>
commit 5803b023881857db32ffefa0d269c90280a67ee0 upstream.
The event handler in the virmidi sequencer code takes a read-lock for
the linked list traverse, while it's calling snd_seq_dump_var_event()
in the loop. The latter function may expand the user-space data
depending on the event type. It eventually invokes copy_from_user(),
which might be a potential dead-lock.
The sequencer core guarantees that the user-space data is passed only
with atomic=0 argument, but snd_virmidi_dev_receive_event() ignores it
and always takes read-lock(). For avoiding the problem above, this
patch introduces rwsem for non-atomic case, while keeping rwlock for
atomic case.
Also while we're at it: the superfluous irq flags is dropped in
snd_virmidi_input_open().
Reported-by: Jia-Ju Bai <baijiaju1990@163.com>
commit 71105998845fb012937332fe2e806d443c09e026 upstream.
There is a potential race window opened at creating and deleting a
port via ioctl, as spotted by fuzzing. snd_seq_create_port() creates
a port object and returns its pointer, but it doesn't take the
refcount, thus it can be deleted immediately by another thread.
Meanwhile, snd_seq_ioctl_create_port() still calls the function
snd_seq_system_client_ev_port_start() with the created port object
that is being deleted, and this triggers use-after-free like:
BUG: KASAN: use-after-free in snd_seq_ioctl_create_port+0x504/0x630 [snd_seq] at addr ffff8801f2241cb1
BUG kmalloc-512 (Tainted: G B ): kasan: bad access detected
INFO: Allocated in snd_seq_create_port+0x94/0x9b0 [snd_seq] age=1 cpu=3 pid=4511
___slab_alloc+0x425/0x460
__slab_alloc+0x20/0x40
kmem_cache_alloc_trace+0x150/0x190
snd_seq_ioctl_create_port+0xd1/0x630 [snd_seq]
snd_seq_do_ioctl+0x11c/0x190 [snd_seq]
snd_seq_ioctl+0x40/0x80 [snd_seq]
do_vfs_ioctl+0x54b/0xda0
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x16/0x75
INFO: Freed in port_delete+0x136/0x1a0 [snd_seq] age=1 cpu=2 pid=4717
__slab_free+0x204/0x310
kfree+0x15f/0x180
snd_seq_delete_port+0x235/0x350 [snd_seq]
snd_seq_ioctl_delete_port+0xc8/0x180 [snd_seq]
SyS_ioctl+0x79/0x90
Call Trace:
[<ffffffff81b03781>] dump_stack+0x63/0x82
[<ffffffff81531b3b>] print_trailer+0xfb/0x160
[<ffffffff81536db4>] object_err+0x34/0x40
[<ffffffff815392d3>] kasan_report.part.2+0x223/0x520
[<ffffffffa07aadf4>] ? snd_seq_ioctl_create_port+0x504/0x630 [snd_seq]
[<ffffffff815395fe>] __asan_report_load1_noabort+0x2e/0x30
[<ffffffffa07aadf4>] snd_seq_ioctl_create_port+0x504/0x630 [snd_seq]
[<ffffffffa07aa8f0>] ? snd_seq_ioctl_delete_port+0x180/0x180 [snd_seq]
[<ffffffff8136be50>] ? taskstats_exit+0xbc0/0xbc0
[<ffffffffa07abc5c>] snd_seq_do_ioctl+0x11c/0x190 [snd_seq]
[<ffffffffa07abd10>] snd_seq_ioctl+0x40/0x80 [snd_seq]
[<ffffffff8136d433>] ? acct_account_cputime+0x63/0x80
[<ffffffff815b515b>] do_vfs_ioctl+0x54b/0xda0
We may fix this in a few different ways, and in this patch, it's fixed
simply by taking the refcount properly at snd_seq_create_port() and
letting the caller unref the object after use. Also, there is another
potential use-after-free by sprintf() call in snd_seq_create_port(),
and this is moved inside the lock.
This fix covers CVE-2017-15265.
Reported-and-tested-by: Michael23 Yu <ycqzsy@gmail.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 124751d5e63c823092060074bd0abaae61aaa9c4 upstream.
USB-audio driver may leave a stray URB for the mixer interrupt when it
exits by some error during probe. This leads to a use-after-free
error as spotted by syzkaller like:
BUG: KASAN: use-after-free in snd_usb_mixer_interrupt+0x604/0x6f0
Call Trace:
<IRQ>
kasan_report+0x23d/0x350 mm/kasan/report.c:409
__asan_report_load8_noabort+0x19/0x20 mm/kasan/report.c:430
snd_usb_mixer_interrupt+0x604/0x6f0 sound/usb/mixer.c:2490
Allocated by task 1484:
save_stack_trace+0x1b/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
kmem_cache_alloc_trace+0x11e/0x2d0 mm/slub.c:2772
kmalloc ./include/linux/slab.h:493
kzalloc ./include/linux/slab.h:666
snd_usb_create_mixer+0x145/0x1010 sound/usb/mixer.c:2540
create_standard_mixer_quirk+0x58/0x80 sound/usb/quirks.c:516
snd_usb_create_quirk+0x92/0x100 sound/usb/quirks.c:560
create_composite_quirk+0x1c4/0x3e0 sound/usb/quirks.c:59
usb_audio_probe+0x1040/0x2c10 sound/usb/card.c:618
Freed by task 1484:
kasan_slab_free+0x72/0xc0 mm/kasan/kasan.c:524
slab_free_hook mm/slub.c:1390
slab_free_freelist_hook mm/slub.c:1412
slab_free mm/slub.c:2988
kfree+0xf6/0x2f0 mm/slub.c:3919
snd_usb_mixer_free+0x11a/0x160 sound/usb/mixer.c:2244
snd_usb_mixer_dev_free+0x36/0x50 sound/usb/mixer.c:2250
__snd_device_free+0x1ff/0x380 sound/core/device.c:91
snd_device_free_all+0x8f/0xe0 sound/core/device.c:244
snd_card_do_free sound/core/init.c:461
release_card_device+0x47/0x170 sound/core/init.c:181
Actually such a URB is killed properly at disconnection when the
device gets probed successfully, and what we need is to apply it for
the error-path, too.
In this patch, we apply snd_usb_mixer_disconnect() at releasing.
Also introduce a new flag, disconnected, to struct usb_mixer_interface
for not performing the disconnection procedure twice.
commit 7682e399485fe19622b6fd82510b1f4551e48a25 upstream.
The usx2y driver allocates the stream read/write buffers in continuous
pages depending on the stream setup, and this may spew the kernel
warning messages with a stack trace like:
WARNING: CPU: 1 PID: 1846 at mm/page_alloc.c:3883
__alloc_pages_slowpath+0x1ef2/0x2d70
Modules linked in:
CPU: 1 PID: 1846 Comm: kworker/1:2 Not tainted
It may confuse user as if it were any serious error, although this is
no fatal error and the driver handles the error case gracefully.
Since the driver has already some sanity check of the given size (128
and 256 pages), it can't pass any crazy value. So it's merely page
fragmentation.
This patch adds __GFP_NOWARN to each caller for suppressing such
kernel warnings. The original issue was spotted by syzkaller.
members and total number of members"
commit 51db452df07bb4c5754b73789253ba21681d9dc2 upstream.
This reverts commit 275353bb684e to fix a regression which can abort
'alsactl' program in alsa-utils due to assertion in alsa-lib.
alsactl: control.c:2513: snd_ctl_elem_value_get_integer: Assertion `idx < sizeof(obj->value.integer.value) / sizeof(obj->value.integer.value[0])' failed.
alsactl: control.c:2976: snd_ctl_elem_value_get_integer: Assertion `idx < ARRAY_SIZE(obj->value.integer.value)' failed.
This commit is a band-aid. In a point of usage of ALSA control interface,
the drivers still bring an issue that they prevent userspace applications
to have a consistent way to parse each levels of the dimension information
via ALSA control interface.
Let me investigate this issue. Current implementation of the drivers
have three control element sets with dimension information:
* 'Monitor Mixer Volume' (type: integer)
* 'VMixer Volume' (type: integer)
* 'VU-meters' (type: boolean)
Although the number of elements named as 'Monitor Mixer Volume' differs
depending on drivers in this group, it can be calculated by macros
defined by each driver (= (BX_NUM - BX_ANALOG_IN) * BX_ANALOG_IN). Each
of the elements has one member for value and has dimension information
with 2 levels (= BX_ANALOG_IN * (BX_NUM - BX_ANALOG_IN)). For these
elements, userspace applications are expected to handle the dimension
information so that all of the elements construct a matrix where the
number of rows and columns are represented by the dimension information.
The same way is applied to elements named as 'VMixer Volume'. The number
of these elements can also be calculated by macros defined by each
drivers (= PX_ANALOG_IN * BX_ANALOG_IN). Each of the element has one
member for value and has dimension information with 2 levels
(= BX_ANALOG_IN * PX_ANALOG_IN). All of the elements construct a matrix
with the dimension information.
An element named as 'VU-meters' gets a different way in a point of
dimension information. The element includes 96 members for value. The
element has dimension information with 3 levels (= 3 or 2 * 16 * 2). For
this element, userspace applications are expected to handle the dimension
information so that all of the members for value construct a matrix
where the number of rows and columns are represented by the dimension
information. This is different from the way for the former.
As a summary, the drivers were not designed to produce a consistent way to
parse the dimension information. This makes it hard for general userspace
applications such as amixer to parse the information by a consistent way,
and actually no userspace applications except for 'echomixer' utilize the
dimension information. Additionally, no drivers excluding this group use
the information.
The reverted commit was written based on the latter way. A commit
860c1994a70a ('ALSA: control: add dimension validator for userspace
elements') is written based on the latter way, too. The patch should be
reconsider too in the same time to re-define a consistent way to parse the
Reported-by: Mark Hills <mark@xwax.org>
Reported-by: S. Christian Collins <s.chriscollins@gmail.com>
Fixes: 275353bb684e ('ALSA: echoaudio: purge contradictions between dimension matrix members and total number of members')
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit a931b9ce93841a5b66b709ba5a244276e345e63b upstream.
Commit 04c5d5a430fc ("ALSA: compress: Embed struct device") removed
the statement that used 'str' but didn't remove the variable itself.
So remove it.
[Adding stable to Cc since pr_debug() may refer to the uninitialized
buffer -- tiwai]
Fixes: 04c5d5a430fc ("ALSA: compress: Embed struct device")
Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com>
commit bfc81a8bc18e3c4ba0cbaa7666ff76be2f998991 upstream.
When a USB-audio device receives a maliciously adjusted or corrupted
buffer descriptor, the USB-audio driver may access an out-of-bounce
value at its parser. This was detected by syzkaller, something like:
BUG: KASAN: slab-out-of-bounds in usb_audio_probe+0x27b2/0x2ab0
Read of size 1 at addr ffff88006b83a9e8 by task kworker/0:1/24
CPU: 0 PID: 24 Comm: kworker/0:1 Not tainted 4.14.0-rc1-42251-gebb2c2437d80 #224
Call Trace:
kasan_report+0x22f/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x19/0x20 mm/kasan/report.c:427
snd_usb_create_streams sound/usb/card.c:248
usb_audio_probe+0x27b2/0x2ab0 sound/usb/card.c:605
usb_probe_interface+0x35d/0x8e0 drivers/usb/core/driver.c:361
really_probe drivers/base/dd.c:413
driver_probe_device+0x610/0xa00 drivers/base/dd.c:557
__device_attach_driver+0x230/0x290 drivers/base/dd.c:653
bus_for_each_drv+0x161/0x210 drivers/base/bus.c:463
__device_attach+0x26e/0x3d0 drivers/base/dd.c:710
device_initial_probe+0x1f/0x30 drivers/base/dd.c:757
bus_probe_device+0x1eb/0x290 drivers/base/bus.c:523
device_add+0xd0b/0x1660 drivers/base/core.c:1835
usb_set_configuration+0x104e/0x1870 drivers/usb/core/message.c:1932
generic_probe+0x73/0xe0 drivers/usb/core/generic.c:174
usb_probe_device+0xaf/0xe0 drivers/usb/core/driver.c:266
usb_new_device+0x7b8/0x1020 drivers/usb/core/hub.c:2457
hub_port_connect drivers/usb/core/hub.c:4903
hub_port_connect_change drivers/usb/core/hub.c:5009
port_event drivers/usb/core/hub.c:5115
hub_event+0x194d/0x3740 drivers/usb/core/hub.c:5195
process_one_work+0xc7f/0x1db0 kernel/workqueue.c:2119
worker_thread+0x221/0x1850 kernel/workqueue.c:2253
kthread+0x3a1/0x470 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:431
This patch adds the checks of out-of-bounce accesses at appropriate
places and bails out when it goes out of the given buffer.
commit 13f99ebdd602ebdafb909e15ec6ffb1e34690167 upstream.
The latest gcc-7.0.1 snapshot points out that we if nr_ch is zero, we never
initialize some variables:
sound/pci/au88x0/au88x0_core.c: In function 'vortex_adb_allocroute':
sound/pci/au88x0/au88x0_core.c:2304:68: error: 'mix[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
sound/pci/au88x0/au88x0_core.c:2305:58: error: 'src[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
I assume this can never happen in practice, but adding a check here doesn't
hurt either and avoids the warning. The code has been unchanged since
the start of git history.
commit 4281fcc02ed9f902dfa52d3635ac7f04b1a7341f upstream.
Drop the const qualifier as it is being added by SOC_ENUM_DOUBLE_DECL()
already which is called by SOC_ENUM_SINGLE_DECL() here.
Fixes: commit 2b26dd4c1fc5 ("ASoC: rt5660: add rt5660 codec driver")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
commit eae39b5f4269260d5d8b35133ba0f4c5e2895b71 upstream.
already which is called by SOC_ENUM_SINGLE_DECL() as well as the
double const by calls to SOC_VALUE_ENUM_SINGLE_DECL() via
SOC_VALUE_ENUM_DOUBLE_DECL).
Fixes: commit d3cb2de2479b ("ASoC: rt5659: add rt5659 codec driver")
commit 03ba791df98d15d07ea74075122af71e35c7611c upstream.
gcc-7 warns that there is a duplicate 'const' specifier in some
variables that are declared using the SOC_ENUM_SINGLE_DECL macro:
sound/soc/codecs/rt5514.c:398:14: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
static const SOC_ENUM_SINGLE_DECL(
sound/soc/codecs/rt5514.c:405:14: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier]
This removes one to fix the warning.
Fixes: 4a6180ea7399 ("ASoC: rt5514: add rt5514 codec driver")
[ Upstream commit 67430a39ca7a6af28aade5acb92d43ee257c1014 ]
Volatile controls should only be accessed when the firmware is active,
currently however writes to these controls will succeed, but the data
will be lost, if the firmware is powered down. Update this behaviour such
that an error is returned the same as it is for reads.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
[ Upstream commit 639467c8f26d834c934215e8b59129ce442475fe ]
commit 66feeec9322132689d42723df2537d60f96f8e44
"RFC: ASoC: dapm: handle probe deferrals"
forgot a to update some two sites where the call
was used. The static codechecks quickly found them.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 66feeec93221 ("RFC: ASoC: dapm: handle probe deferrals")
[ Upstream commit 37e1df8c95e2c8a57c77eafc097648f6e40a60ff ]
This starts to handle probe deferrals on regulators and clocks
on the ASoC DAPM.
I came to this patch after audio stopped working on Ux500 ages
ago and I finally looked into it to see what is wrong. I had
messages like this in the console since a while back:
ab8500-codec.0: ASoC: Failed to request audioclk: -517
ab8500-codec.0: ASoC: Failed to create DAPM control audioclk
ab8500-codec.0: Failed to create new controls -12
snd-soc-mop500.0: ASoC: failed to instantiate card -12
snd-soc-mop500.0: Error: snd_soc_register_card failed (-12)!
snd-soc-mop500: probe of snd-soc-mop500.0 failed with error -12
Apparently because the widget table for the codec looks like
this (sound/soc/codecs/ab8500-codec.c):
static const struct snd_soc_dapm_widget ab8500_dapm_widgets[] = {
/* Clocks */
SND_SOC_DAPM_CLOCK_SUPPLY("audioclk"),
/* Regulators */
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AUD", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AMIC1", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-AMIC2", 0, 0),
SND_SOC_DAPM_REGULATOR_SUPPLY("V-DMIC", 0, 0),
So when we call snd_soc_register_codec() and any of these widgets
get a deferred probe we do not get an -EPROBE_DEFER (-517) back as
we should and instead we just fail. Apparently the code assumes
that clocks and regulators must be available at this point and
not defer.
After this patch it rather looks like this:
ab8500-codec.0: Failed to create new controls -517
snd-soc-mop500.0: ASoC: failed to instantiate card -517
snd-soc-mop500.0: Error: snd_soc_register_card failed (-517)!
abx500-clk.0: registered clocks for ab850x
snd-soc-mop500.0: ab8500-codec-dai.0 <-> ux500-msp-i2s.1 mapping ok
snd-soc-mop500.0: ab8500-codec-dai.1 <-> ux500-msp-i2s.3 mapping ok
I'm pretty happy about the patch as it it, but I'm a bit
uncertain on how to proceed: there are a lot of users of the
external functions snd_soc_dapm_new_control() (111 sites)
and that will now return an occassional error pointer, which
is not handled in the calling sites.
I want an indication from the maintainers whether I should just
go in and augment all these call sites, or if deferred probe
is frowned upon when it leads to this much overhead.
commit 20e2b791796bd68816fa115f12be5320de2b8021 upstream.
The ISA msnd drivers have loops fetching the ring-buffer head, tail
and size values inside the loops. Such codes are inefficient and
fragile.
This patch optimizes it, and also adds the sanity check to avoid the
endless loops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196131
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196133
Signed-off-by: grygorii tertychnyi <gtertych@cisco.com>
data of iso-resource
commit 0c264af7be2013266c5b4c644f3f366399ee490a upstream.
When calling 'iso_resource_free()' for uninitialized data, this function
causes NULL pointer dereference due to its 'unit' member. This occurs when
unplugging audio and music units on IEEE 1394 bus at failure of card
registration.
This commit fixes the bug. The bug exists since kernel v4.5.
Fixes: 324540c4e05c ('ALSA: fireface: postpone sound card registration') at v4.12
Fixes: 8865a31e0fd8 ('ALSA: firewire-motu: postpone sound card registration') at v4.12
Fixes: b610386c8afb ('ALSA: firewire-tascam: deleyed registration of sound card') at v4.7
Fixes: 86c8dd7f4da3 ('ALSA: firewire-digi00x: delayed registration of sound card') at v4.7
Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card') at v4.7
Fixes: 7d3c1d5901aa ('ALSA: fireworks: delayed registration of sound card') at v4.7
Fixes: 04a2c73c97eb ('ALSA: bebob: delayed registration of sound card') at v4.7
Fixes: b59fb1900b4f ('ALSA: dice: postpone card registration') at v4.5
commit bbba6f9d3da357bbabc6fda81e99ff5584500e76 upstream.
Lenovo G50-70 (17aa:3978) with Conexant codec chip requires the
similar workaround for the inverted stereo dmic like other Lenovo
models.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1020657
commit 88c54cdf61f508ebcf8da2d819f5dfc03e954d1d upstream.
When user tries to replace the user-defined control TLV, the kernel
checks the change of its content via memcmp(). The problem is that
the kernel passes the return value from memcmp() as is. memcmp()
gives a non-zero negative value depending on the comparison result,
and this shall be recognized as an error code.
The patch covers that corner-case, return 1 properly for the changed
TLV.
Fixes: 8aa9b586e420 ("[ALSA] Control API - more robust TLV implementation")
