path: root/sound
2012-07-16ASoC: tlv320aic3x: Fix codec pll configure bugHebbar, Gururaja
commit c9fe573a6584034670c1a55ee8162d623519cbbf upstream. In sound/soc/codecs/tlv320aic3x.c data = snd_soc_read(codec, AIC3X_PLL_PROGA_REG); snd_soc_write(codec, AIC3X_PLL_PROGA_REG, data | (pll_p << PLLP_SHIFT)); In the above code, pll-p value is OR'ed with previous value without clearing it. Bug is not seen if pll-p value doesn't change across Sampling frequency. However on some platforms (like AM335x EVM-SK), pll-p may have different values across different sampling frequencies. In such case, above code configures the pll with a wrong value. Because of this bug, when a audio stream is played with pll value different from previous stream, audio is heard as differently(like its stretched). Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ASoC: wm2200: Add missing BCLK rateMark Brown
commit b0dfa4541e48ac4cc5f017285432c89923ad0f58 upstream. Without this very high BCLKs will be configured incorrectly. Reported-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ALSA: hda - Fix power-map regression for HP dv6 & coTakashi Iwai
commit 6e1c39c6b00d9141a82c231ba7c5e5b1716974b2 upstream. The recent fix for power-map controls (commit b0791dda813) caused regressions on some other HP laptops. They have fixed pins but these pins are exposed as jack-detectable. Thus the driver tries to control the power-map dynamically per jack detection where it never gets on. This patch corrects the condition check for fixed pins so that the power-map is set always for these pins. NOTE: this is no simple backport from 3.5 kernel. Since 3.5 kernel had significant code change in the relevant part, I fixed this differently. BugLink: http://bugs.launchpad.net/bugs/1013183 Reported-by: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ALSA: hda - Fix memory leaks at module unloadTakashi Iwai
commit 59cad16bc6deb85bd2a464da92bbaae289f0286f upstream. Some caches aren't released properly at module unloading time. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ALSA: hda - Add Realtek ALC280 codec supportDavid Henningsson
commit befae82e2906cb7155020876a531b0b8c6c8d8c8 upstream. This chip looks very similar to ALC269 and ALC27* variants. The bug reporter has verified that sound was working after this patch had been applied. BugLink: https://bugs.launchpad.net/bugs/1017017 Tested-by: Richard Crossley <richardcrossley@o2.co.uk> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-22ASoC: wm8904: Fix GPIO and MICBIAS initialisation for regmap conversionMark Brown
commit 433897f7408b556f7dfbb98c94deea02e634d2a7 upstream. We no longer have a flat ASoC cache so can't peer directly into the array any more but should instead use the register I/O functions to update the cache. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17ALSA: HDA: Pin fixup for Zotac Z68 motherboardDavid Henningsson
commit edfe3bfc1b779ddda9bcff523eb022dda37b93c8 upstream. Pin 0x1b was connected to the front panel connector, which according to the HDA standard should contain a mic and a headphone. In this case, the headphone was listed as "line out" by BIOS. BugLink: https://bugs.launchpad.net/bugs/993162 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17ASoC: wm8994: Apply volume updates with clocks enabledMark Brown
commit bfd37bb5f681961e255fd2f346c20fdae2ef3f27 upstream. Volume updates may not be acted upon if there is no clock applied when the volume update is written. Ensure this doesn't happen by writing out registers with volume updates after we enable each of the clocks. There are more registers updated than before as previously we were relying on wm_hubs to set those for controls it manages. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17ASoC: wm8994: Ensure all AIFnCLK events are run from the _late variantsMark Brown
commit c8fdc1b56611faa7b38eab6b99da5e20113661ff upstream. Ensure that all the actions get taken at appropriate times by calling the _PRE and _POST events for the aifNclk_ev functions explicitly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ALSA: usb-audio: fix rate_list memory leakClemens Ladisch
commit 5cd5d7c44990658df6ab49f6253c39617c53b03d upstream. The array of sample rates is reallocated every time when opening the PCM device, but was freed only once when unplugging the device. Reported-by: "Alexander E. Patrakov" <patrakov@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-16Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A few last-minute regression fixes for 3.4 final kernel. All trivial, and Cc'ed to stable kernel." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: wm8994: Fix AIF2ADC power down ALSA: hda/idt - Fix power-map for speaker-pins with some HP laptops ASoC: cs42l73: Sync digital mixer kcontrols to allow for 0dB
2012-05-15Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Last minute fixes Some last minute fixes for ASoC. Small, focused changes to specific drivers.
2012-05-15ASoC: wm8994: Fix AIF2ADC power downMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-05-15ALSA: hda/idt - Fix power-map for speaker-pins with some HP laptopsTakashi Iwai
BIOS on some HP laptops don't set the speaker-pins as fixed but expose as jacks, and this confuses the driver as if these pins are jack-detectable. As a result, the machine doesn't get sounds from speakers because the driver prepares the power-map update via jack unsol events which never come up in reality. The bug was introduced in some time in 3.2 for enabling the power-mapping feature. This patch fixes the problem by replacing the check of the persistent power-map bits with a proper is_jack_detectable() call. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43240 Cc: <stable@vger.kernel.org> [v3.2+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-11ASoC: cs42l73: Sync digital mixer kcontrols to allow for 0dBBrian Austin
Some of the Digital mixer kcontrol max values were off by 1 not allowing a max of 0dB. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-05-10Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Slightly more than expected as rc7, but all are reasonablly small fixes. A few additions of HD-audio fixup entries, a couple of other regression fixes including a revert, and a few other trivial oneliners." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: sh: fix migor.c compilation ALSA: HDA: Lessen CPU usage when waiting for chip to respond Revert "ALSA: hda - Set codec to D3 forcibly even if not used" ALSA: hda/realtek - Call alc_auto_parse_customize_define() always after fixup ALSA: hdsp - Provide ioctl_compat ALSA: hda/realtek - Add missing CD-input pin for MSI-7350 mobo ALSA: hda/realtek - Add a fixup for Acer Aspire 5739G ALSA: echoaudio: Remove incorrect part of assertion
2012-05-09Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Build fix for SH in 3.4 An API update which wasn't sufficiently thorough in updating the tree...
2012-05-09ASoC: sh: fix migor.c compilationGuennadi Liakhovetski
Fix a recent compilation breakage, caused by a change in SH clock API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-09ALSA: HDA: Lessen CPU usage when waiting for chip to respondDavid Henningsson
When an IRQ for some reason gets lost, we wait up to a second using udelay, which is CPU intensive. This patch improves the situation by waiting about 30 ms in the CPU intensive mode, then stepping down to using msleep(2) instead. In essence, we trade some granularity in exchange for less CPU consumption when the waiting time is a bit longer. As a result, PulseAudio should no longer be killed by the kernel for taking up to much RT-prio CPU time. At least not for *this* reason. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Tested-by: Arun Raghavan <arun.raghavan@collabora.co.uk> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-08Revert "ALSA: hda - Set codec to D3 forcibly even if not used"Takashi Iwai
This reverts commit 785f857d1cb0856b612b46a0545b74aa2596e44a. The commit causes a problem with the wrong D3 state after suspend because the call of hda_set_power_state() involves with the power-up sequence, which changes the power_count, and this confuses the resume sequence that checks the power_count as well. Originally, this go-to-D3 sequence should be a simple task without the power-up sequence. But, it'd need some proper sanity checks in the case of power-saved state, so it's not too easy to write now in the 3.4-rc cycle. In short, the safest option now is to revert this affecting commit. Of course, we need to clean up and robustify the power-saving code better for 3.5 kernel. Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-08ALSA: hda/realtek - Call alc_auto_parse_customize_define() always after fixupTakashi Iwai
The call for alc_auto_parse_customize_define() must be done after the fixup pre-probe initialization. Otherwise SKU_IGNORE fixup won't work properly (e.g. HP RP5800 with ALC662 codec). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-08ALSA: hdsp - Provide ioctl_compatAndre Schramm
snd_hdsp uses its own ioctls to acquire config- and status information. Expose the corresponding ioctl handler via ioctl_compat, so that 32bit applications can use it on 64bit kernels. Signed-off-by: Andre Schramm <andre.schramm@iosono-sound.com> Reviewed-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-07ALSA: hda/realtek - Add missing CD-input pin for MSI-7350 moboTakashi Iwai
Reported-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Cc: <stable@kernel.org> [v3.3+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-07ALSA: hda/realtek - Add a fixup for Acer Aspire 5739GTakashi Iwai
Acer Aspire 5739G requires the same fix-up for 4930G to support the surround / bass speakers. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43180 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-06ALSA: echoaudio: Remove incorrect part of assertionMark Hills
This assertion seems to imply that chip->dsp_code_to_load is a pointer. It's actually an integer handle on the actual firmware, and 0 has no special meaning. The assertion prevents initialisation of a Darla20 card, but would also affect other models. It seems it was introduced in commit dd7b254d. ALSA sound/pci/echoaudio/echoaudio.c:2061 Echoaudio driver starting... ALSA sound/pci/echoaudio/echoaudio.c:1969 chip=ebe4e000 ALSA sound/pci/echoaudio/echoaudio.c:2007 pci=ed568000 irq=19 subdev=0010 Init hardware... ALSA sound/pci/echoaudio/darla20_dsp.c:36 init_hw() - Darla20 ------------[ cut here ]------------ WARNING: at sound/pci/echoaudio/echoaudio_dsp.c:478 init_hw+0x1d1/0x86c [snd_darla20]() Hardware name: Dell DM051 BUG? (!chip->dsp_code_to_load || !chip->comm_page) Signed-off-by: Mark Hills <mark@pogo.org.uk> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-05Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound sound fixes from Takashi Iwai: "As good as nothing exciting here; just a few trivial fixes for various ASoC stuff." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: omap-pcm: Free dma buffers in case of error. ASoC: s3c2412-i2s: Fix dai registration ASoC: wm8350: Don't use locally allocated codec struct ASoC: tlv312aic23: unbreak resume ASoC: bf5xx-ssm2602: Set DAI format ASoC: core: check of_property_count_strings failure ASoC: dt: sgtl5000.txt: Add description for 'reg' field ASoC: wm_hubs: Make sure we don't disable differential line outputs
2012-05-05Merge branch 'fix/asoc' into for-linusTakashi Iwai
2012-05-05Merge branch 'for-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc into fix/asoc
2012-05-05Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for 3.4 Nothing terribly exciting here, a bunch of small and simple fixes scattered around the place.
2012-05-04ASoC: omap-pcm: Free dma buffers in case of error.Oleg Matcovschi
Signed-off-by: Oleg Matcovschi <oleg.matcovschi@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2012-04-30ASoC: s3c2412-i2s: Fix dai registrationHeiko Stübner
As s3c2412-i2s is using the s3c_i2sv2 it should call the more specialised s3c_i2sv2_register_dai instead of simply calling snd_soc_register_dai. Without this call the snd_soc_dai_ops structure isn't initialised correctly. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-30ASoC: wm8350: Don't use locally allocated codec structMark Brown
The core allocates the live copies, we shouldn't try to duplicate it and were buggy trying to do so as we were using uninitialised data for the control data. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-30ASoC: tlv312aic23: unbreak resumeEric Bénard
* commit f9dfbf9 "ASoC: tlv320aic23: convert to soc-cache" leads to a bug preventing resumeof the codec as regmap expects a 9 bits data register but 0xFFFF is passed in tlv320aic23_set_bias_level and this values gets cached preventing any write to the TLV320AIC23_PWR register as the final value produced by regmap is (register << 9) | value * this patch solves the problem by only working on the 9 bits the register contains. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-04-26Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A workaround for an ASUS laptop and a few ASoC changes; most of the commits are tagged for stable, too." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: wm8994: Improve sequencing of AIF channel enables ALSA: HDA: Add external mic quirk for Asus Zenbook UX31E ASoC: fsi: update for dmaengine prep_slave_sg fallout. ASoC: core: Fix card RTD count for deferred probe. ASoC: cs42l73: don't use negative array index ASoC: dapm: Ensure power gets managed for line widgets
2012-04-25ASoC: bf5xx-ssm2602: Set DAI formatLars-Peter Clausen
Commit 980b0bc69 ("ASoC: blackfin: Use dai_fmt") converted the blackfin ASoC machine drivers to use the dai_links dai_fmt field to setup their DAI format. For the bf5xx-ssm2602 the commit removed the manual call to snd_soc_dai_set_fmt, but missed to set the dai_links dai_fmt field. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-24ASoC: core: check of_property_count_strings failureRichard Zhao
Signed-off-by: Richard Zhao <richard.zhao@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-04-23ASoC: wm_hubs: Make sure we don't disable differential line outputsMark Brown
While we need to clean up unused single ended line outputs we don't want to do this if the outputs are in differential mode. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-23Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: updates for 3.4 Slightly larger than normal - the DAPM fix is a "this should always have worked" type of thing which is very clear and should have no impact on systems that don't need it. The WM8994 fix is driver specific but pretty important for that driver.
2012-04-23ASoC: wm8994: Improve sequencing of AIF channel enablesMark Brown
This ensures a clean startup of the channels, without this change some use cases could result in issues in a small proportion of cases. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-04-21Merge tag 'mfd-for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD fixes from Samuel Ortiz: "We have 3 build fixes, a OMAP USB host PHY reset fix and the twl6040 conversion to an i2c driver. The latter may not sound like a fix but the twl6040 MFD driver won't probe without it, triggering an OMAP4 audio regression." * tag 'mfd-for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: Fix modular builds of rc5t583 regulator support mfd: Fix asic3_gpio_to_irq ARM: OMAP3: USB: Fix the EHCI ULPI PHY reset issue mfd: Convert twl6040 to i2c driver, and separate it from twl core mfd : Fix dbx500 compilation error
2012-04-20Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Fixes for a few regressions of HD-audio, originated partly from 3.4 and partly 3.3. The fixes for ThinkPad docking-station are for 3.3 kernels, thus they are based on 3.3 then merged back to 3.4, so that they can be merged to stable tree cleanly. The non-trivial merge conflicts are because of this action. In addition, a couple of trivial fixes for documentation and a long- standing issue in the listing of built-in sound driver at boot time." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/conexant - Set up the missing docking-station pins ALSA: hda/conexant - Don't set HP pin-control bit unconditionally ALSA: workaround: change the timing of alsa_sound_last_init() ALSA: hda/sigmatel - Fix inverted mute LED ALSA: hda/realtek - Fix regression on Quanta/Gericom KN1 ALSA: fix core/vmaster.c kernel-doc warning
2012-04-20ALSA: HDA: Add external mic quirk for Asus Zenbook UX31EDavid Henningsson
According to the reporter, external mic starts to work if the laptop-dmic model is used. According to BIOS pin config, all pins are consistent with the alc269vb_laptop_dmic fixup, except for the external mic, which is not present. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/950490 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-19Merge branch 'fix/cxt-stable' into fix/hdaTakashi Iwai
Merge fixes for Thinkpad docking-station regressions for 3.3 kernels back to 3.4. These were committed in that branch to make the stable merging easier. Conflicts: sound/pci/hda/patch_conexant.c
2012-04-19ALSA: hda/conexant - Set up the missing docking-station pinsTakashi Iwai
ThinkPad 410,420,510,520 and X201 with cx50585 & co chips have the docking-station ports, but BIOS doesn't initialize for these pins. Thus, like the former X200, we need to set up the pins manually in the driver. The odd part is that the same PCI SSID is used for X200 and T400, thus we need to prepare individual fixup tables for cx5051 and others. Bugzilla entries: https://bugzilla.redhat.com/show_bug.cgi?id=808559 https://bugzilla.redhat.com/show_bug.cgi?id=806217 https://bugzilla.redhat.com/show_bug.cgi?id=810697 Reported-by: Josh Boyer <jwboyer@redhat.com> Reported-by: Jens Taprogge <jens.taprogge@taprogge.org> Tested-by: Jens Taprogge <jens.taprogge@taprogge.org> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-19ALSA: hda/conexant - Don't set HP pin-control bit unconditionallyTakashi Iwai
Some output pins on Conexant chips have no HP control bit, but the auto-parser initializes these pins unconditionally with PIN_HP. Check the pin-capability and avoid the HP bit if not supported. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-19ALSA: workaround: change the timing of alsa_sound_last_init()Kuninori Morimoto
Current alsa_sound_last_init() was called as __initcall(). So, on current ALSA, only devices that had been properly registered at this point were shown. So, it will show "No soundcards found" if driver requests probe deferment. it's often misleading. This patch delays the timing of alsa_sound_last_init() as workaround. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Reviwed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-19ALSA: hda/sigmatel - Fix inverted mute LEDTakashi Iwai
While refactoring the mute-LED handling for HP laptops, I messed up the polarity check in a wrong way. The red (or the mute-LED if any) should appear in the muted state, corresponding to GPIO on. Reported-by: Mikko Vinni <mmvinni@yahoo.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-19ALSA: hda/realtek - Fix regression on Quanta/Gericom KN1Takashi Iwai
Through the transition to the auto-parser, the support for Quanta/Gericom KN1 got broken. There are two problems behind it: - This machine doesn't like the default COEF setup for ALC260 we take now as default - BIOS doesn't set the pins correctly at all; especially the machine uses only the pin 0x0f for both headphone and speaker This patch adds the fixup as a workaround for these issues. Reported-and-tested-by: Uros Vampl <mobile.leecher@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-18ASoC: fsi: update for dmaengine prep_slave_sg fallout.Paul Mundt
Leading up to the ->device_prep_slave_sg change in 185ecb5f4fd43911c35956d4cc7d94a1da30417f 'dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic' a generic wrapper was added in place to guard against the API change, though the fsi driver wasn't updated in the process (presumably its dmaengine support hadn't been merged yet at the time). This trivially switches over to the new wrapper and gets it building again. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-18ALSA: fix core/vmaster.c kernel-doc warningRandy Dunlap
Fix kernel-doc warning in sound/core/vmaster.c: Warning(sound/core/vmaster.c:429): No description found for parameter 'private_data' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
