path: root/sound
2014-12-20Merge tag 'pm-config-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull CONFIG_PM_RUNTIME elimination from Rafael Wysocki: "This removes the last few uses of CONFIG_PM_RUNTIME introduced recently and makes that config option finally go away. CONFIG_PM will be available directly from the menu now and also it will be selected automatically if CONFIG_SUSPEND or CONFIG_HIBERNATION is set" * tag 'pm-config-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM: Eliminate CONFIG_PM_RUNTIME tty: 8250_omap: Replace CONFIG_PM_RUNTIME with CONFIG_PM sound: sst-haswell-pcm: Replace CONFIG_PM_RUNTIME with CONFIG_PM spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM
2014-12-19Merge tag 'sound-fix-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here are a few fixes that have landed after the previous pull request. All are driver specific fixes including: - error/int value fixes in OXFW, - Intel Skylake HD-audio HDMI codec support, - Additional HD-audio Realtek codecs and AD1986A codec fixes/quirks, - a few more DSD support and a quirk for Arcam rPAC in usb-audio, - a typo fix for Scarlett 6i6, - fixes for new ASIHPI firmware, - ASoC Exynos7 cleanups, - Intel ACPI support, and - a fix for PCM512 register cache sync" * tag 'sound-fix-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (24 commits) ALSA: usb-audio: extend KEF X300A FU 10 tweak to Arcam rPAC ALSA: hda/realtek - New codec support for ALC298 ALSA: asihpi: update to HPI version 4.14 ALSA: asihpi: increase tuner pad cache size ALSA: asihpi: relax firmware version check ALSA: usb-audio: Fix Scarlett 6i6 initialization typo ALSA: hda - Add quirk for Packard Bell EasyNote MX65 ALSA: usb-audio: add native DSD support for Matrix Audio DACs ALSA: hda/realtek - New codec support for ALC256 ALSA: hda/realtek - Add new Dell desktop for ALC3234 headset mode ASoC: Intel: fix possible acpi enumeration panic ALSA: hda/hdmi - apply Haswell fix-ups to Skylake display codec ASoC: Intel: fix return value check in sst_acpi_probe() ALSA: hda - Make add_stereo_mix_input flag tristate ALSA: hda - Create capture source ctls when stereo mix input is added ALSA: hda - Fix typos in snd_hda_get_int_hint() kerneldoc comments ALSA: hda - add codec ID for Skylake display audio codec ALSA: oxfw: some signedness bugs ALSA: oxfw: fix detect_loud_models() return value ASoC: rt5677: add REGMAP_I2C and REGMAP_IRQ dependency ...
2014-12-19sound: sst-haswell-pcm: Replace CONFIG_PM_RUNTIME with CONFIG_PMRafael J. Wysocki
The sst-haswell-pcm driver is a new user of CONFIG_PM_RUNTIME. However, after commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM in sound/soc/intel/sst-haswell-pcm.c. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Mark Brown <broonie@kernel.org>
2014-12-18Merge tag 'pm+acpi-3.19-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are regression fixes (leds-gpio, ACPI backlight driver, operating performance points library, ACPI device enumeration messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device PM), some cleanups in the operating performance points (OPP) framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of minor intel_pstate driver changes, a new MAINTAINERS entry for it and an ACPI fan driver change needed for better support of thermal management in user space. Specifics: - Fix a regression in leds-gpio introduced by a recent commit that inadvertently changed the name of one of the properties used by the driver (Fabio Estevam). - Fix a regression in the ACPI backlight driver introduced by a recent fix that missed one special case that had to be taken into account (Aaron Lu). - Drop the level of some new kernel messages from the ACPI core introduced by a recent commit to KERN_DEBUG which they should have used from the start and drop some other unuseful KERN_ERR messages printed by ACPI (Rafael J Wysocki). - Revert an incorrect commit modifying the cpupower tool (Prarit Bhargava). - Fix two regressions introduced by recent commits in the OPP library and clean up some existing minor issues in that code (Viresh Kumar). - Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the tree (or drop it where that can be done) in order to make it possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf Hansson, Ludovic Desroches). There will be one more "CONFIG_PM_RUNTIME removal" batch after this one, because some new uses of it have been introduced during the current merge window, but that should be sufficient to finally get rid of it. - Make the ACPI EC driver more robust against race conditions related to GPE handler installation failures (Lv Zheng). - Prevent the ACPI device PM core code from attempting to disable GPEs that it has not enabled which confuses ACPICA and makes it report errors unnecessarily (Rafael J Wysocki). - Add a "force" command line switch to the intel_pstate driver to make it possible to override the blacklisting of some systems in that driver if needed (Ethan Zhao). - Improve intel_pstate code documentation and add a MAINTAINERS entry for it (Kristen Carlson Accardi). - Make the ACPI fan driver create cooling device interfaces witn names that reflect the IDs of the ACPI device objects they are associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B"). That's necessary for user space thermal management tools to be able to connect the fans with the parts of the system they are supposed to be cooling properly. From Srinivas Pandruvada" * tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits) MAINTAINERS: add entry for intel_pstate ACPI / video: update the skip case for acpi_video_device_in_dod() power / PM: Eliminate CONFIG_PM_RUNTIME NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / EC: Fix unexpected ec_remove_handlers() invocations Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()" tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c PM: Remove the SET_PM_RUNTIME_PM_OPS() macro mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro PM / Kconfig: Replace PM_RUNTIME with PM in dependencies ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / PM: Do not disable wakeup GPEs that have not been enabled ACPI / utils: Drop error messages from acpi_evaluate_reference() ...
2014-12-18ALSA: usb-audio: extend KEF X300A FU 10 tweak to Arcam rPACJiri Jaburek
The Arcam rPAC seems to have the same problem - whenever anything (alsamixer, udevd, 3.9+ kernel from 60af3d037eb8c, ..) attempts to access mixer / control interface of the card, the firmware "locks up" the entire device, resulting in SNDRV_PCM_IOCTL_HW_PARAMS failed (-5): Input/output error from alsa-lib. Other operating systems can somehow read the mixer (there seems to be playback volume/mute), but any manipulation is ignored by the device (which has hardware volume controls). Cc: <stable@vger.kernel.org> Signed-off-by: Jiri Jaburek <jjaburek@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-18ALSA: hda/realtek - New codec support for ALC298Kailang Yang
Add new support for ALC298 codec. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-18ALSA: asihpi: update to HPI version 4.14Eliot Blennerhassett
This corresponds with updated asihpi firmware in alsa-firmware repo Signed-off-by: Eliot Blennerhassett <eliot@blennerhassett.gen.nz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-18ALSA: asihpi: increase tuner pad cache sizeEliot Blennerhassett
Increase size allocated for PAD (programme associated data) control. This is used by newer tuner products. Signed-off-by: Eliot Blennerhassett <eliot@blennerhassett.gen.nz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-18ALSA: asihpi: relax firmware version checkEliot Blennerhassett
Some products firmware is no longer being updated e.g. dsp5000, dsp8700 but it should continue to work with updated HPI versions. Avoid regression by allowing this firmware to be loaded as long as major version is the same. Warn about mismatching versions, as matching versions are preferred. Signed-off-by: Eliot Blennerhassett <eliot@blennerhassett.gen.nz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-18ALSA: usb-audio: Fix Scarlett 6i6 initialization typoChris J Arges
The num_controls field was incorrectly set to 0 causing 6i6 to not be initialized. Set this to 9. Reported-and-tested-by: Mark Roberts <sunifiram@gmail.com> Signed-off-by: Chris J Arges <chris.j.arges@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-17ALSA: hda - Add quirk for Packard Bell EasyNote MX65Takashi Iwai
Packard Bell EasyNote MX65 with AD1986A codec needs a few fixups, namely, the pin config overrides to set only the known I/O pins and the EAPD has to be turned on. In addition, add stereo mix input forcibly for avoiding the weird KDE behavior by this update. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88251 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-17ALSA: usb-audio: add native DSD support for Matrix Audio DACsJurgen Kramer
This patch adds native DSD support for two XMOS based DACs from Matrix Audio: - X-Sabre - Mini-i Pro Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-17ALSA: hda/realtek - New codec support for ALC256Kailang Yang
Add new support for ALC256 codec. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-17ALSA: hda/realtek - Add new Dell desktop for ALC3234 headset modeKailang Yang
New Dell desktop needs to support headset mode for ALC3234. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-16Merge tag 'asoc-v3.19-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Merge window fixes for v3.19 A smattering of driver specific fixes here, some more cleanup of the Exynos7 and Intel ACPI support plus a fix for register cache sync on the pcm512x driver which has been lurking for a while.
2014-12-16Merge remote-tracking branches 'asoc/fix/atmel', 'asoc/fix/intel', ↵Mark Brown
'asoc/fix/rt5645', 'asoc/fix/rt5677' and 'asoc/fix/samsung' into asoc-linus
2014-12-16ASoC: Intel: fix possible acpi enumeration panicKevin Strasser
A crash can occur on some platforms where adsp is enumerated but codec is not matched. Define codec_id as a pointer intead of an array so that it gets initialized to NULL for the terminating element of sst_acpi_bytcr[] and sst_acpi_chv[]. Signed-off-by: Kevin Strasser <kevin.strasser@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-16ALSA: hda/hdmi - apply Haswell fix-ups to Skylake display codecLibin Yang
Skylake and Haswell have the same behavior on display audio. So this patch applys Haswell fix-ups to Skylake. Signed-off-by: Libin Yang <libin.yang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-15ASoC: Intel: fix return value check in sst_acpi_probe()Wei Yongjun
In case of error, the function platform_device_register_data() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-15ALSA: hda - Make add_stereo_mix_input flag tristateTakashi Iwai
... for distinguishing whether it's explicitly enabled via a user hint or enabled by a driver as a fallback. Now the former case corresponds to HDA_HINT_STEREO_MIX_ENABLE while the latter to HDA_HINT_STEREO_MIX_AUTO. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-15ALSA: hda - Create capture source ctls when stereo mix input is addedTakashi Iwai
When the stereo mix input is explicitly enabled via a user hint, the driver should create always a capture source enum ctl and disable the auto-mic switch. Otherwise the behavior gets confused. For doing it, this patch just sets spec->suppress_auto_mic flag appropriately. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-15ALSA: hda - Fix typos in snd_hda_get_int_hint() kerneldoc commentsTakashi Iwai
2014-12-15ALSA: hda - add codec ID for Skylake display audio codecLibin Yang
This patch adds codec ID (0x80862809) and module alias for Skylake display codec. Signed-off-by: Libin Yang <libin.yang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-15ALSA: oxfw: some signedness bugsDan Carpenter
This code tends to use unsigned variables by default and it causes signedness bugs when we use negative variables for error handling. The "i" and "j" variables are used to iterated over small positive values and so they should be type "int". The "len" variable doesn't *need* to be signed but it should be signed to make the code easier to read and audit. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-14ALSA: oxfw: fix detect_loud_models() return valueDan Carpenter
This code causes a static checker warning: sound/firewire/oxfw/oxfw.c:46 detect_loud_models() warn: signedness bug returning '(-2)' The detect_loud_models() function should return false on falure, so that we don't try to set up the loud code for hardware that doesn't support it. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-13sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PMRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under sound/. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Nicolin Chen <nicoleotsuka@gmail.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Acked-by: Mark Brown <broonie@kernel.org>
2014-12-12ASoC: rt5677: add REGMAP_I2C and REGMAP_IRQ dependencyBen Zhang
The codec driver uses regmap to do i2c read/write. The codec driver started to use REGMAP_IRQ since: 5e3363ad1b7b2e1f197a3f56b01e21cb155ad454 ASoC: rt5677: add GPIO IRQ support Signed-off-by: Ben Zhang <benzh@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-11Merge tag 'sound-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This became a fairly large pull request. In addition to the usual driver updates / fixes, there have been a high amount of cleanups in ASoC area, as well as control API helpers and kernel documentations fixes touching through the whole tree. In the driver side, the biggest changes are the support for new Intel SoC found on new x86 machines, and the updates of FireWire dice and oxfw drivers. Some remarkable items are below: ALSA core: - PCM mmap code cleanup, removal of arch-dependent codes - PCM xrun injection support - PCM hwptr tracepoint support - Refactoring of snd_pcm_action(), simplification of PCM locking - Robustified sequecner auto-load functionality - New control API helpers and lots of cleanups along with them - Lots of kerneldoc fixes and cleanups USB-audio: - The mixer resume code was largely rewritten, and the devices with quirks are resumed properly. - New hardware support: Focusrite Scarlett, Digidesign Mbox1, Denon/Marantz DACs, Zoom R16/24 FireWire: - DICE driver updates with better duplex and sync support, including MIDI support - New OXFW driver for Oxford Semiconductor FW970/971 chipset, including the previous LaCie Speakers device. Fullduplex and MIDI support included as well as DICE driver. HD-audio: - Refactoring the driver-caps quirk handling in snd-hda-intel - More consistent control names representing the topology better - Fixups: HP mute LED with ALC268 codec, Ideapad S210 built-in mic fix, ASUS Z99He laptop EAPD ASoC: - Conversion of AC'97 drivers to use regmap, bringing us closer to the removal of the ASoC level I/O code - Clean up a lot of old drivers that were open coding things that have subsequently been implemented in the core - Some DAPM performance improvements - Removal of the now seldom used CODEC mutex - Lots of updates for the newer Intel SoC support, including support for the DSP and some Cherrytrail and Braswell machine drivers - Support for Samsung boards using rt5631 as the CODEC - Removal of the obsolete AFEB9260 machine driver - Driver support for the TI TS3A227E headset driver used in some Chrombeooks Others: - ASIHPI driver update and cleanups - Lots of dev_*() printk conversions - Lots of trivial cleanups for the codes spotted by Coccinelle" * tag 'sound-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (594 commits) ALSA: pcxhr: NULL dereference on probe failure ALSA: lola: NULL dereference on probe failure ALSA: hda - Add "eapd" model string for AD1986A codec ALSA: hda - Add EAPD fixup for ASUS Z99He laptop ALSA: oxfw: Add hwdep interface ALSA: oxfw: Add support for capture/playback MIDI messages ALSA: oxfw: add support for capturing PCM samples ALSA: oxfw: Add support AMDTP in-stream ALSA: oxfw: Add support for Behringer/Mackie devices ALSA: oxfw: Change the way to start stream ALSA: oxfw: Add proc interface for debugging purpose ALSA: oxfw: Change the way to make PCM rules/constraints ALSA: oxfw: Add support for AV/C stream format command to get/set supported stream formation ALSA: oxfw: Change the way to name card ALSA: dice: Add support for MIDI capture/playback ALSA: dice: Add support for capturing PCM samples ALSA: dice: Support for non SYT-Match sampling clock source mode ALSA: dice: Add support for duplex streams with synchronization ALSA: dice: Change the way to start stream ALSA: jack: Add dummy snd_jack_set_key() definition ...
2014-12-11Merge tag 'fbdev-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - support for mx6sl and mx6sx - OMAP HDMI audio rewrite to make it finally work - OMAP video PLL work to prepare for new DRA7xx SoCs - simplefb DT related improvements * tag 'fbdev-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (81 commits) video: uvesafb: Deletion of an unnecessary check before the function call "platform_device_put" video: fbdev-VIA: Deletion of an unnecessary check before the function call "framebuffer_release" video: fbdev-MMP: Deletion of an unnecessary check before the function call "mmp_unregister_path" video: mx3fb: Deletion of an unnecessary check before the function call "backlight_device_unregister" video: fbdev-OMAP2: Deletion of unnecessary checks before the function call "i2c_put_adapter" video: fbdev-SIS: Deletion of unnecessary checks before the function call "pci_dev_put" video: smscufx: Deletion of unnecessary checks before the function call "vfree" video: udlfb: Deletion of unnecessary checks before the function call "vfree" video: uvesafb: Deletion of an unnecessary check before the function call "uvesafb_free" video: fbdev-LCDC: Deletion of an unnecessary check before the function call "vfree" video: fbdev: arkfb: suppress build warning video: fbdev: s3fb: suppress build warning video: fbdev: vt8623fb: suppress build warning OMAPDSS: hdmi5: Fix bit field for IEC958_AES2_CON_SOURCE OMAPDSS: hdmi: Remove __exit qualifier from hdmi_uninit_output() OMAPDSS: hdmi5: Change hdmi_wp idlemode to to no_idle for audio playback OMAPDSS: Remove all references to obsolete HDMI audio callbacks ASoC: omap: Remove obsolete HDMI audio code and Kconfig options OMAPDSS: hdmi5: Register ASoC platform device for omap hdmi audio OMAPDSS: hdmi5: Remove callbacks for the old ASoC DAI driver ...
2014-12-11Merge tag 'media/v3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Two new dvb frontend drivers: mn88472 and mn88473 - A new driver for some PCIe DVBSky cards - A new remote controller driver: meson-ir - One LIRC staging driver got rewritten and promoted to mainstream: igorplugusb - A new tuner driver (m88rs6000t) - The old omap2 media driver got removed from staging. This driver uses an old DMA API and it is likely broken on recent kernels. Nobody cared enough to fix it - Media bus format moved to a separate header, as DRM will also use the definitions there - mem2mem_testdev were renamed to vim2m, in order to use the same naming convention taken by the other virtual test driver (vivid) - Added a new driver for coda SoC (coda-jpeg) - The cx88 driver got converted to use videobuf2 core - Make DMABUF export buffer to work with DMA Scatter/Gather and Vmalloc cores - Lots of other fixes, improvements and cleanups on the drivers. * tag 'media/v3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (384 commits) [media] mn88473: One function call less in mn88473_init() after error [media] mn88473: Remove uneeded check before release_firmware() [media] lirc_zilog: Deletion of unnecessary checks before vfree() [media] MAINTAINERS: Add myself as img-ir maintainer [media] img-ir: Don't set driver's module owner [media] img-ir: Depend on METAG or MIPS or COMPILE_TEST [media] img-ir/hw: Drop [un]register_decoder declarations [media] img-ir/hw: Fix potential deadlock stopping timer [media] img-ir/hw: Always read data to clear buffer [media] redrat3: ensure dma is setup properly [media] ddbridge: remove unneeded check before dvb_unregister_device() [media] si2157: One function call less in si2157_init() after error [media] tuners: remove uneeded checks before release_firmware() [media] arm: omap2: rx51-peripherals: fix build warning [media] stv090x: add an extra protetion against buffer overflow [media] stv090x: Remove an unreachable code [media] stv090x: Some whitespace cleanups [media] em28xx: checkpatch cleanup: whitespaces/new lines cleanups [media] si2168: add support for firmware files in new format [media] si2168: debug printout for firmware version ...
2014-12-10ALSA: pcxhr: NULL dereference on probe failureDan Carpenter
"card" is NULL if snd_card_new() fails. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: lola: NULL dereference on probe failureDan Carpenter
2014-12-10ALSA: hda - Add "eapd" model string for AD1986A codecTakashi Iwai
Also update the documentation to the latest state. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: hda - Add EAPD fixup for ASUS Z99He laptopTakashi Iwai
The same fixup to enable EAPD is needed for ASUS Z99He with AD1986A codec like another ASUS machine. Reported-and-tested-by: Dmitry V. Zimin <pfzim@mail.ru> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add hwdep interfaceTakashi Sakamoto
This interface is designed for mixer/control application. By using this interface, an application can get information about firewire node, can lock/unlock kernel streaming and can get notification at starting/stopping kernel streaming. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add support for capture/playback MIDI messagesTakashi Sakamoto
This commit adds MIDI functionality with an assumption of 'if the device has MIDI comformant data channels in its stream formation, the device has one MIDI port'. When no streams have already started, MIDI functionality starts stream with current sampling rate. When MIDI functionality has already starts some streams and PCM functionality is going to start streams at different sampling rate, this driver stops streams once and changes sampling rate, then restarts streams for both PCM/MIDI substreams. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: add support for capturing PCM samplesTakashi Sakamoto
In previous commit, a support for transmitted packets is added. This commit add a support for capturing PCM samples. When any streams are already started, this driver should not change sampling rate of the device, thus this commit also adds a restriction of sampling rate in this situation. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add support AMDTP in-streamTakashi Sakamoto
Previous commit adds support for some devices which can capture PCM samples. These devices transmit AMDTP stream in non-blocking mode. This commit adds functionality to handle AMDTP incoming stream. OXFW seems to have two quirks: - Transmits packets with non-zero dbc in its beginning - Transmits packets with wrong values in syt field For the first quirk, this commit adds CIP_SKIP_INIT_DBC_CHECK flag for incoming stream to skip first check of dbc. For the second quirk, this commit doesn't add duplex stream which Fireworks/BeBoB drivers use. So OXFW driver generates syt value for outgoing stream. Here are examples of a sequence of packets transmitted by Behringer F-Control Audio 202. There are differences between sequences of syt value when OXFW driver transfers outgoing stream or not. When driver gives no outgoing stream: Index Payload CIP_Header_0 CIP_Header_1 38 14 00020092 900103D1 39 12 00020098 900102FF 40 12 0002009D 9001027F 41 14 000200A2 90010396 42 14 000200A8 900102E8 43 12 000200AE 90010219 44 14 000200B3 90010331 45 12 000200B9 9001025F 46 14 000200BE 90010376 47 12 000200C4 900102A1 00 12 000200C9 9001023E 01 14 000200CE 90010358 02 12 000200D4 90010289 03 16 000200D9 900103A3 04 12 000200E0 900102DD 05 14 000200E5 900103F1 06 12 000200EB 90010335 07 12 000200F0 90010263 08 14 000200F5 9001037C 09 12 000200FB 900102AE When driver gives outgoing stream: Index Payload CIP_Header_0 CIP_Header_1 38 12 000200BD 900104A8 39 14 000200C2 900104A8 40 12 000200C8 900104AC 41 14 000200CD 900104A9 42 12 000200D3 900104B1 43 14 000200D8 900104A8 44 12 000200DE 900104AA 45 14 000200E3 900104A9 46 14 000200E9 900104AE 47 12 000200EF 900104A8 00 14 000200F4 900104AD 01 12 000200FA 900104A7 02 14 000200FF 900104A9 03 12 00020005 900104A9 04 14 0002000A 900104B1 05 12 00020010 900104AA 06 14 00020015 900104AD 07 12 0002001B 900104A7 08 14 00020020 900104AC 09 12 00020026 900104A7 Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add support for Behringer/Mackie devicesTakashi Sakamoto
Some devices produced by Behringer/Mackie are based on OXFW970/971. This commit adds support for them. Additionally, this commit changes the way to name card with some information in config rom. Ids of some Mackie(Loud) models are not identified, therefore this commit applies name detection for these models. The devices support capture/playback of PCM-samples and some of them supports capture/playback of MIDI messages. These functionalities are implemented by followed commits. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Change the way to start streamTakashi Sakamoto
In past commit, this driver can keep stream formations for each sampling rate. So its stream functionality can decide stream formations with given some parameters. This commit moves related codes from PCM functionality to stream functionality. Furthermore, to set stream format correctly, this commit uses AV/C Stream Format Information command instead of AV/C Input/Output Plug Signal Format command. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add proc interface for debugging purposeTakashi Sakamoto
This commit adds proc interface to get information about stream formation. This commit also adds snd_oxfw_stream_get_current_formation() to get current stream formation. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Change the way to make PCM rules/constraintsTakashi Sakamoto
In previous commit, this driver can get to know stream formations at each supported sampling rates. This commit uses it to make PCM rules/constraints and obsoletes hard-coded rules/constraints. For this purpose, this commit adds 'struct snd_oxfw_stream_formation' and snd_oxfw_stream_parse_format() to parse data channel formation of data block. According to datasheet of OXFW970/971, they support 32.0kHz to 196.0kHz. As long as developers investigate, some devices are confirmed to have several formats for the same sampling rate. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Add support for AV/C stream format command to get/set supported ↵Takashi Sakamoto
stream formation OXFW970/971 may supports AV/C Stream Format Information Specification 1.1 Working Draft (Apr 2005, 1394TA). By using this command, drivers can get to know stream formations which device supports. This commit adds 'EXTENDED STREAM FORMAT INFORMATION' command. This command has two subfunctions, 'SINGLE' and 'LIST'. Drivers can use 'SINGLE' subfunction to know/set current formation of AMDTP stream, Drivers can use 'LIST' subfunction to know an available formation of AMDTP stream in a certain sampling rate. But some devices don't implement the 'LIST' subfunction. So this commit uses an assumption that 'if they don't implement it, they don't change stream formation depending on current each sampling rate'. With this assumption, this driver generates formations for such devices by: 1.getting current formation by SINGLE subfunction 2.getting supported sampling rates 3.applying current formation for all of supported sampling rates Followed commit implements a parser of this format information. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: oxfw: Change the way to name cardTakashi Sakamoto
This is a preparation for more models. In following commit, members of 'struct snd_card' related to name becomes to consists of vendor and model strings in device's config-rom. Current supported devices also has strings in their config rom, but the strings are too long to name sound card, thus this driver still keep hard-coded vendor and model names for them. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for MIDI capture/playbackTakashi Sakamoto
This commit adds a support for MIDI capture/playback When MIDI substrams already start streaming and PCM substreams are going to join at different sampling rate, streams are stopped once. Then sampling rate is changed and streams are restarted. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for capturing PCM samplesTakashi Sakamoto
This commit adds a support for capturing PCM samples. When opposite PCM substream is already running, available sampling rate is limited at current one. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Support for non SYT-Match sampling clock source modeTakashi Sakamoto
This commit allows this driver to handle devices with non SYT-Match sampling clock source. When sampling clock source is SYT-Match mode, devices handle 'presentation timestamp' in received packets and generates sampling clock according to the information. In this case, driver is synchronization master and must transfer correct value in SYT field of each packets in outgoing stream, then the outgoing stream is a master stream. On the other hand, non SYT-Match mode, devices do this. So drivers must pick up the value in SYT field of incoming packets and use the value for outgoing stream. Currently firewire-lib module achieve this work. Furthermore, without SYT-Match and internal clock source, the sampling rate should be fixed for the other devices connected to the handled device. This commit add a restriction of sampling rate at this situation. With these implementations, this driver has no need to set clock source. This commit remove set function. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for duplex streams with synchronizationTakashi Sakamoto
This commit adds support for AMDTP in-stream. As a result, Dice driver supports full duplex streams with synchronization. AMDTP can transfer timestamps in its packets. By handling the timestamp, devices can synchronize to the other devices or drivers on the same bus. When Dice chipset is 'enabled', it starts streams with correct settings. This 'enable' register is global, thus, when a stream is started to run, an opposite stream can't start unless turning off 'enable'. Therefore a pair of streams must be running. This causes a loss of CPU usage when single stream is needed for neither playbacking or capturing. This commit assumes that playback-only models also have a functionality to transmit stream for delivering timestamps. Currently, sampling clock source is restricted to SYT-Match mode. This is improved in followed commit. I note that at SYT-Match mode, Dice can select from 4 streams for synchronization but this driver uses the 1st stream only for simplicity. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Change the way to start streamTakashi Sakamoto
Streaming functionality can start streams when rate is given but currently some codes are in PCM functionality. This commit changes the way to start stream and add some arrangement to make it easy to understand the way. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
