path: root/tools/build/Makefile.include
2017-02-17perf build: Add special fixdep cleaning ruleJiri Olsa
Ingo reported following build failure: On Sat, Feb 11, 2017 at 12:12:34PM +0100, Ingo Molnar wrote: > > So I had this oldish 32-bit 15.10 Ubuntu installation around (fully updated), and > trying to build perf gave me: > > deimos:~/tip/tools/perf> make > BUILD: Doing 'make -j4' parallel build > make[3]: *** No rule to make target '/usr/include/x86_64-linux-gnu/sys/types.h', needed by 'fixdep.o'. Stop. > Makefile:42: recipe for target 'fixdep-in.o' failed > make[2]: *** [fixdep-in.o] Error 2 > /home/mingo/tip/tools/build/Makefile.include:4: recipe for target 'fixdep' failed > make[1]: *** [fixdep] Error 2 > Makefile:68: recipe for target 'all' failed > make: *** [all] Error 2 > > Now this got a bit better after I did a 'make mrproper' in the kernel tree: > > deimos:~/tip/tools/perf> make > BUILD: Doing 'make -j4' parallel build > HOSTCC fixdep.o > /home/mingo/tip/tools/build/fixdep: 1: /home/mingo/tip/tools/build/fixdep: Syntax error: "(" unexpected > /home/mingo/tip/tools/build/Makefile.build:101: recipe for target 'fixdep.o' failed > make[3]: *** [fixdep.o] Error 2 > Makefile:42: recipe for target 'fixdep-in.o' failed > make[2]: *** [fixdep-in.o] Error 2 > /home/mingo/tip/tools/build/Makefile.include:4: recipe for target 'fixdep' failed > make[1]: *** [fixdep] Error 2 > Makefile:68: recipe for target 'all' failed > make: *** [all] Error 2 > > After some digging it turns out that my 'fixdep' binary was 64-bit: > > deimos:~/tip/tools/perf> file /home/mingo/tip/tools/build/fixdep > /home/mingo/tip/tools/build/fixdep: ELF 64-bit LSB executable, x86-64, version 1 > (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux > 2.6.32, BuildID[sha1]=d527f736b57b5ba47210fbcb562a3b52867d21c1, not stripped > > But it did not get cleaned out by 'make clean'. > > Only after I did a 'make clean' in tools/ itself, did it get built properly. It shows we don't clean up properly the fixdep objects, so adding special rule for that. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Reported-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1487340058-10496-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03tools build: Make fixdep a hostprogJiri Olsa
It is used in the build process, so stop suppressing its build in tools cross builds. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160927141846.GA6589@krava [ Use HOSTCC on the $(OUTPUT)fixdep target, it was using the x-compiler to link fixdep-in.o, that was correctly built with HOSTCC and thus failing ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-26tools build: Use fixdep with OUTPUT path prefixJiri Olsa
Adding OUTPUT path prefix for fixdep target so we use it properly in out of tree builds. If the fixdep already existed in the tree, the out of tree build would see it already exist and did not build the out of tree version, as reported by Arnaldo: [acme@zoo linux]$ make O=/tmp/build/perf -C tools/perf make: Entering directory '/home/git/linux/tools/perf' BUILD: Doing 'make -j4' parallel build make[2]: Nothing to be done for 'fixdep'. make: Leaving directory '/home/git/linux/tools/perf' Reported-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20151126185055.GC19410@krava.brq.redhat.com [ Fixed conflict with 5725dd8fa888 ("tools build: Clean CFLAGS and LDFLAGS for fixdep") ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-25tools build: Clean CFLAGS and LDFLAGS for fixdepWang Nan
Sometimes passing variables to tools/build is dangerous. For example, on my platform there is a gcc problem (gcc 4.8.1): It passes the stackprotector-all feature check: $ gcc -fstack-protector-all -c ./test.c $ echo $? 0 But requires LDFLAGS support if separate compiling and linking: $ gcc -fstack-protector-all -c ./test.c $ gcc ./test.o ./test.o: In function `main': test.c:(.text+0xb): undefined reference to `__stack_chk_guard' test.c:(.text+0x21): undefined reference to `__stack_chk_guard' collect2: error: ld returned 1 exit status $ gcc -fstack-protector-all ./test.o $ echo $? 0 $ gcc ./test.o -lssp $ echo $? 0 $ In this environment building perf throws an error: $ make BUILD: Doing 'make -j24' parallel build config/Makefile:344: No libunwind found. Please install libunwind-dev[el] >= 1.1 and/or set LIBUNWIND_DIR config/Makefile:403: No libaudit.h found, disables 'trace' tool, please install audit-libs-devel or libaudit-dev config/Makefile:418: slang not found, disables TUI support. Please install slang-devel or libslang-dev config/Makefile:432: GTK2 not found, disables GTK2 support. Please install gtk2-devel or libgtk2.0-dev config/Makefile:564: No bfd.h/libbfd found, please install binutils-dev[el]/zlib-static/libiberty-dev to gain symbol demangling config/Makefile:606: No numa.h found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev CC fixdep.o LD fixdep-in.o LINK fixdep fixdep-in.o: In function `parse_dep_file': /kernel/tools/build/fixdep.c:47: undefined reference to `__stack_chk_guard' /kernel/tools/build/fixdep.c:117: undefined reference to `__stack_chk_guard' fixdep-in.o: In function `main': /kernel-hydrogen/tools/build/fixdep.c:156: undefined reference to `__stack_chk_guard' /kernel/tools/build/fixdep.c:168: undefined reference to `__stack_chk_guard' collect2: error: ld returned 1 exit status make[2]: *** [fixdep] Error 1 make[1]: *** [fixdep] Error 2 make: *** [all] Error 2 This is because the CFLAGS used in building perf pollutes the CFLAGS used for fixdep, passing -fstack-protector-all to buiold fixdep which is obviously not required. Since fixdep is a small host side tool, we should keep its CFLAGS/LDFLAGS simple and clean. This patch clears the CFLAGS and LDFLAGS passed when building fixdep, so such gcc problem won't block the perf build process. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1448372181-151723-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-13tools build: Fix cross compile buildJiri Olsa
He Kuang the new fixdep tool breaks cross compiling. The reason is it wouldn't get compiled under host arch, but under cross arch and failed to run. We need to add support for host side tools build, meanwhile disabling fixdep usage for cross arch builds. Reported-by: He Kuang <hekuang@huawei.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20151013124358.GB9467@krava.brq.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Build fixdep helper from perf and basic libsJiri Olsa
Adding the fixdep target into the Makefile.include to ease up building of fixdep helper, that needs to be built before we dive in to the build itself. The user can invoke the fixdep target to build the helper. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-8-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-28tools build: Add Makefile.includeJiri Olsa
To ease up build framework code setup for users. More shared code will be added in the following patches. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1443004442-32660-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
