path: root/tools/build
2015-09-17tools build: Add test for presence of __get_cpuid() gcc builtinArnaldo Carvalho de Melo
The auxtrace code needed by Intel PT uses the __get_cpuid() gcc builtin, that is not present in old systems, breaking the build. Add a test to check for that builtin and disable AUXTRACE in those systems. [acme@rhel5 linux]$ make NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: <SNIP> ... lzma: [ on ] ... get_cpuid: [ OFF ] <SNIP> config/Makefile:630: Your gcc lacks the __get_cpuid() builtin, disables support for auxtrace/Intel PT, please install a newer gcc MKDIR /tmp/build/perf/util/ <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-d4puslul0jltoodzpx9r4sje@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17tools build: Add test for presence of numa_num_possible_cpus() in libnumaArnaldo Carvalho de Melo
The existing numa test checks only if numa.h and numa_available() are present, but that can be satisfied with an old libnuma that is not enough for the 'perf bench numa' entry, so add a test to check for that: [acme@rhel5 linux]$ make NO_AUXTRACE=1 NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: ... libelf: [ on ] ... libnuma: [ on ] ... numa_num_possible_cpus: [ OFF ] ... libperl: [ on ] <SNIP> config/Makefile:577: Old numa library found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev >= 2.0.8 INSTALL binaries <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-zqriqkezppi2de2iyjin1tnc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-26tools build: Allow duplicate objects in the object listJiri Olsa
It's sometimes useful to specify the object affiliation to multiple config options like: libperf-$(CONFIG_X86) += tsc.o libperf-$(CONFIG_AUXTRACE) += tsc.o while the object itself is linked only once. Adding the support for this and ignoring duplicate objects in the object list. Suggested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20150826130103.GF22670@krava.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-17perf tools: Add Intel PT instruction decoderAdrian Hunter
Add support for decoding instructions for Intel Processor Trace. The kernel x86 instruction decoder is copied for this. This essentially provides intel_pt_get_insn() which takes a binary buffer, uses the kernel's x86 instruction decoder to get details of the instruction and then categorizes it for consumption by an Intel PT decoder. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1439450095-30122-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-13perf tools: Support static linking with libdwAndi Kleen
The Fedora 22 version of libdw requires a couple of extra libraries to link. With a dynamic link the dependencies are pulled in automatically, but this doesn't work for static linking. Add the needed libraries explicitely to the feature probe and the Makefile. v2: Explicitly check for static linking and only add the dependencies when -static is set. This is to avoid regressions on Arnaldo's system. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1439419717-20601-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-07bpf tools: Introduce 'bpf' library and add bpf feature checkWang Nan
This is the first patch of libbpf. The goal of libbpf is to create a standard way for accessing eBPF object files. This patch creates 'Makefile' and 'Build' for it, allows 'make' to build libbpf.a and libbpf.so, 'make install' to put them into proper directories. Most part of Makefile is borrowed from traceevent. Before building, it checks the existence of libelf in Makefile, and deny to build if not found. Instead of throwing an error if libelf not found, the error raises in a phony target "elfdep". This design is to ensure 'make clean' still workable even if libelf is not found. Because libbpf requires 'kern_version' field set for 'union bpf_attr' (bpfdep" is used for that dependency), Kernel BPF API is also checked by intruducing a new feature check 'bpf' into tools/build/feature, which checks the existence and version of linux/bpf.h. When building libbpf, it searches that file from include/uapi/linux in kernel source tree (controlled by FEATURE_CHECK_CFLAGS-bpf). Since it searches kernel source tree it reside, installing of newest kernel headers is not required, except we are trying to port these files to an old kernel. To avoid checking that file when perf building, the newly introduced 'bpf' feature check doesn't added into FEATURE_TESTS and FEATURE_DISPLAY by default in tools/build/Makefile.feature, but added into libbpf's specific. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kaixu Xia <xiakaixu@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Bcc: pi3orama@163.com Link: http://lkml.kernel.org/r/1435716878-189507-4-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-05perf tools: Fix build errors with mipsel-linux-uclibc compilerPetri Gynther
linux/tools$ make ARCH=mips CROSS_COMPILE=mipsel-linux- perf ... config/Makefile:256: *** No gnu/libc-version.h found, please install glibc-dev[el]. Stop. make[1]: *** [all] Error 2 make: *** [perf] Error 2 ... In file included from builtin-sched.c:13:0: util/cloexec.h:8:12: error: redundant redeclaration of ‘sched_getcpu’ [-Werror=redundant-decls] extern int sched_getcpu(void) __THROW; mipsel-buildroot-linux-uclibc/sysroot/usr/include/bits/sched.h:88:12: note: previous declaration of ‘sched_getcpu’ was here extern int sched_getcpu (void) __THROW; uclibc info: sysroot/usr/include/bits/uClibc_config.h __UCLIBC_MAJOR__ 0 __UCLIBC_MINOR__ 9 __UCLIBC_SUBLEVEL__ 33 sysroot/usr/include/features.h __UCLIBC__ 1 __GLIBC__ 2 __GLIBC_MINOR__ 2 Signed-off-by: Petri Gynther <pgynther@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1438735081-24131-1-git-send-email-pgynther@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-01perf tools: Create config.detected into OUTPUT directoryAaro Koskinen
Create config.detected into OUTPUT directory instead of source directory. This fixes parallel builds that share the same source directory. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1435751683-18500-1-git-send-email-aaro.koskinen@nokia.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-06-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "These are the left over fixes from the v4.1 cycle" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix build breakage if prefix= is specified perf/x86: Honor the architectural performance monitoring version perf/x86/intel: Fix PMI handling for Intel PT perf/x86/intel/bts: Fix DS area sharing with x86_pmu events perf/x86: Add more Broadwell model numbers perf: Fix ring_buffer_attach() RCU sync, again
2015-06-19perf tools: Fix build breakage if prefix= is specifiedLukas Wunner
Invoking Makefile.perf with prefix= breaks the build since Makefile.perf hands that variable down to Makefile.build where it overrides prefix := $(subst ./,,$(OUTPUT)$(dir)/) leading to errors like this: No rule to make target '/usrabspath.o', needed by '/usrlibperf-in.o' Signed-off-by: Lukas Wunner <lukas@wunner.de> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Fixes: c819e2cf2eb6f65d3208d195d7a0edef6108d5 Link: http://lkml.kernel.org/r/5582c48a.84a22b0a.a918.5285SMTPIN_ADDED_MISSING@mx.google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-29perf build: Do not fail on missing Build fileJiri Olsa
Allow nesting into directories without Build file. Currently we force include of the Build file, which fails the build when the Build file is missing. We already support empty *-in.o' objects if there's nothing in the directory to be compiled, so we can just use it for missing Build file cases. Also adding this case under tests. Reported-by: Rabin Vincent <rabin.vincent@axis.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rabin Vincent <rabin.vincent@axis.com> Link: http://lkml.kernel.org/r/1432914178-24086-1-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-18tools build: Change FEATURE_TESTS and FEATURE_DISPLAY to weak bindingWang Nan
Replace strong binding of FEATURE_TESTS and FEATURE_DISPLAY by weak binding. This patch enables other makefiles which include tools/build/Makefile.feature enable only limited feathres to check. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: pi3orama@163.com Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1431860222-61636-5-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-21tools build: Add feature check for lzma libraryJiri Olsa
Will be used to decompress 'xz' objects. The check detects the liblzma.so devel library normally delivered by xz package. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com>
2015-03-21perf build: Move feature checks code under tools/buildJiri Olsa
Moving feature checks code under tools/build directory. Changing also $feature_dir to point to new feature directory location and perf Makefiles to include Makefile.feature from new location. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <david.ahern@oracle.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-3lamtb30dhf4wo99y1n8kxg0@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Display make commands on V=1Jiri Olsa
Get more verbose output wrt displaying executed commands from make. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-68v67h59zoz7ilb1ggcuff3j@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add single target build framework supportJiri Olsa
Add support to build single targets, like: $ make util/map.o # objects $ make util/map.i # preprocessor $ make util/map.s # assembly Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-tt10y0dmweq6rjaod937rpb4@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add libperf objects buildingJiri Olsa
Move the util objects building under build framework. Add the new libperf build object so it's separated from the rest of the perf code and could be librarized. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-574tgt9t23tnxo9td8qjiibc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12tools build: Add subdir supportJiri Olsa
Add support to make directory any time we build objects out of the tree (O=/tmp/krava) and the output directory does not exist. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-h80ukls4o2kpr0e4c4bfln6u@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12tools build: Add detected config supportJiri Olsa
Adding support to include detected configuration makefile into the build process. This will allow the Build objects to be configurable based on the config data, like: perf-$(CONFIG_KRAVA) += krava.o The configuration is stored in '.config-detected' file, which is generated for each compilation. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-bl8qho0ubck7aqrbbfu9inlm@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-11tools build: Add new build supportJiri Olsa
Adding new build framework into 'tools/build' to be used by tools. There's no change for actual building at this point, it comes in the next patches. The idea and more details are explained in the 'tools/build/Documentation/Build.txt' file. I adopted everything from the kernel build system, with some changes to allow for multiple binaries build definitions. While the kernel's build output is single image (forget modules) we need to be able to build several binaries/libraries. The basic idea is that sser provides 'Build' files with objects definitions like: perf-y += a.o perf-y += b.o libperf-y += c.o libperf-y += d.o and the build framework outputs files: perf-in.o # a.o, b.o compiled in libperf-in.o # c.o, d.o compiled in Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-fbj22h4av0otlxupwcmrxgpa@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
