commit 6c4798d3f08b81c2c52936b10e0fa872590c96ae upstream.
Disable a couple of compilation warnings (which are treated as errors)
on strlcpy() definition and declaration, allowing users to compile perf
and kernel (objtool) when:
1. glibc have strlcpy() (such as in ALT Linux since 2004) objtool and
perf build fails with this (in gcc):
In file included from exec-cmd.c:3:
tools/include/linux/string.h:20:15: error: redundant redeclaration of ‘strlcpy’ [-Werror=redundant-decls]
20 | extern size_t strlcpy(char *dest, const char *src, size_t size);
2. clang ignores `-Wredundant-decls', but produces another warning when
building perf:
CC util/string.o
../lib/string.c:99:8: error: attribute declaration must precede definition [-Werror,-Wignored-attributes]
size_t __weak strlcpy(char *dest, const char *src, size_t size)
../../tools/include/linux/compiler.h:66:34: note: expanded from macro '__weak'
# define __weak __attribute__((weak))
/usr/include/bits/string_fortified.h:151:8: note: previous definition is here
__NTH (strlcpy (char *__restrict __dest, const char *__restrict __src,
Committer notes:
The
#pragma GCC diagnostic
directive was introduced in gcc 4.6, so check for that as well.
Fixes: ce99091 ("perf tools: Move strlcpy() from perf to tools/lib/string.c")
Fixes: 0215d59 ("tools lib: Reinstate strlcpy() header guard with __UCLIBC__")
Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=118481
Signed-off-by: Vitaly Chikunov <vt@altlinux.org>
Reviewed-by: Dmitry Levin <ldv@altlinux.org>
Cc: Dmitry Levin <ldv@altlinux.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: kbuild test robot <lkp@intel.com>
Cc: stable@vger.kernel.org
Cc: Vineet Gupta <vineet.gupta1@synopsys.com>
Link: http://lore.kernel.org/lkml/20191224172029.19690-1-vt@altlinux.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit ba4aa02b417f08a0bee5e7b8ed70cac788a7c854 upstream.
So that we reduce the difference of tools/include/linux/bitops.h to the
original kernel file, include/linux/bitops.h, trying to remove the need
to define BITS_PER_LONG, to avoid clashes with asm/bitsperlong.h.
And the things removed from tools/include/linux/bitops.h are really in
linux/bits.h, so that we can have a copy and then
tools/perf/check_headers.sh will tell us when new stuff gets added to
linux/bits.h so that we can check if it is useful and if any adjustment
needs to be done to the tools/{include,arch}/ copies.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: https://lkml.kernel.org/n/tip-y1sqyydvfzo0bjjoj4zsl562@git.kernel.org
perf wants matching .h files otherwise it complains during the build
process. As these files have been modified over the past few 4.14.y
releases, they are out of sync, so fix that problem by properly copying
the respective versions to the tools/ mirror copies.
commit f335195adf043168ee69d78ea72ac3e30f0c57ce upstream.
Commit 4675ff05de2d ("kmemcheck: rip it out") has removed the code but
for some reason SPDX header stayed in place. This looks like a rebase
mistake in the mmotm tree or the merge mistake. Let's drop those
leftovers as well.
Signed-off-by: Michal Hocko <mhocko@suse.com>
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream.
Fix up makefiles, remove references, and git rm kmemcheck.
Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Tim Hansen <devtimhansen@gmail.com>
[ Upstream commit 6ae8eefc6c8fe050f057781b70a83262eb0a61ee ]
LIST_POISON[12] are used to initialize list_head and hlist_node
pointers, and do void pointer arithmetic, which C++ doesn't like, so, to
avoid drifting from the kernel by introducing some HLIST_POISON to do
away with void pointer math, just make those poisoned pointers be NULL
when building it with a C++ compiler.
Noticed with:
$ make LLVM_CONFIG=/usr/bin/llvm-config-3.9 LIBCLANGLLVM=1
CXX util/c++/clang.o
CXX util/c++/clang-test.o
In file included from /home/lizj/linux/tools/include/linux/list.h:5:0,
from /home/lizj/linux/tools/perf/util/namespaces.h:13,
from /home/lizj/linux/tools/perf/util/util.h:15,
from /home/lizj/linux/tools/perf/util/util-cxx.h:20,
from util/c++/clang-c.h:5,
from util/c++/clang-test.cpp:2:
/home/lizj/linux/tools/include/linux/list.h: In function ‘void list_del(list_head*)’:
/home/lizj/linux/tools/include/linux/poison.h:14:31: error: pointer of type ‘void *’ used in arithmetic [-Werror=pointer-arith]
# define POISON_POINTER_DELTA 0
/home/lizj/linux/tools/include/linux/poison.h:22:41: note: in expansion of macro ‘POISON_POINTER_DELTA’
#define LIST_POISON1 ((void *) 0x100 + POISON_POINTER_DELTA)
/home/lizj/linux/tools/include/linux/list.h:107:16: note: in expansion of macro ‘LIST_POISON1’
entry->next = LIST_POISON1;
In file included from /home/lizj/linux/tools/perf/util/namespaces.h:13:0,
/home/lizj/linux/tools/include/linux/list.h:107:14: error: invalid conversion from ‘void*’ to ‘list_head*’ [-fpermissive]
Reported-by: Li Zhijian <lizhijian@cn.fujitsu.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Philip Li <philip.li@intel.com>
Link: http://lkml.kernel.org/n/tip-m5ei2o0mjshucbr28baf5lqz@git.kernel.org
Last minute upstream update to one of the UAPI headers - sync it with tooling,
to address this warning:
Warning: Kernel ABI header at 'tools/include/uapi/drm/i915_drm.h' differs from latest version at 'include/uapi/drm/i915_drm.h'
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
After the SPDX license tags were added a number of tooling headers got out of
sync with their kernel variants, generating lots of build warnings.
Sync them:
- tools/arch/x86/include/asm/disabled-features.h,
tools/arch/x86/include/asm/required-features.h,
tools/include/linux/hash.h:
Remove the SPDX tag where the kernel version does not have it.
- tools/include/asm-generic/bitops/__fls.h,
tools/include/asm-generic/bitops/arch_hweight.h,
tools/include/asm-generic/bitops/const_hweight.h,
tools/include/asm-generic/bitops/fls.h,
tools/include/asm-generic/bitops/fls64.h,
tools/include/uapi/asm-generic/ioctls.h,
tools/include/uapi/asm-generic/mman-common.h,
tools/include/uapi/sound/asound.h,
tools/include/uapi/linux/kvm.h,
tools/include/uapi/linux/perf_event.h,
tools/include/uapi/linux/sched.h,
tools/include/uapi/linux/vhost.h,
tools/include/uapi/sound/asound.h:
Add the SPDX tag of the respective kernel header.
- tools/include/uapi/linux/bpf_common.h,
tools/include/uapi/linux/fcntl.h,
tools/include/uapi/linux/hw_breakpoint.h,
tools/include/uapi/linux/mman.h,
tools/include/uapi/linux/stat.h,
Change the tag to the kernel header version:
-/* SPDX-License-Identifier: GPL-2.0 */
+/* SPDX-License-Identifier: GPL-2.0 WITH Linux-syscall-note */
Also sync other header details:
- include/uapi/sound/asound.h:
Fix pointless end of line whitespace noise the header grew in this cycle.
- tools/arch/x86/lib/memcpy_64.S:
Sync the code and add tools/include/asm/export.h with dummy wrappers
to support building the kernel side code in a tooling header environment.
- tools/include/uapi/asm-generic/mman.h,
tools/include/uapi/linux/bpf.h:
Sync other details that don't impact tooling's use of the ABIs.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
Now that SK_REDIRECT is no longer a valid return code. Remove it
from the UAPI completely. Then do a namespace remapping internal
to sockmap so SK_REDIRECT is no longer externally visible.
Patchs primary change is to do a namechange from SK_REDIRECT to
__SK_REDIRECT
Reported-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
Recent additions to support multiple programs in cgroups impose
a strict requirement, "all yes is yes, any no is no". To enforce
this the infrastructure requires the 'no' return code, SK_DROP in
this case, to be 0.
To apply these rules to SK_SKB program types the sk_actions return
codes need to be adjusted.
This fix adds SK_PASS and makes 'SK_DROP = 0'. Finally, remove
SK_ABORTED to remove any chance that the API may allow aborted
program flows to be passed up the stack. This would be incorrect
behavior and allow programs to break existing policies.
Acked-by: Alexei Starovoitov <ast@kernel.org>
Pull networking fixes from David Miller:
"A little more than usual this time around. Been travelling, so that is
part of it.
Anyways, here are the highlights:
1) Deal with memcontrol races wrt. listener dismantle, from Eric
Dumazet.
2) Handle page allocation failures properly in nfp driver, from Jaku
Kicinski.
3) Fix memory leaks in macsec, from Sabrina Dubroca.
4) Fix crashes in pppol2tp_session_ioctl(), from Guillaume Nault.
5) Several fixes in bnxt_en driver, including preventing potential
NVRAM parameter corruption from Michael Chan.
6) Fix for KRACK attacks in wireless, from Johannes Berg.
7) rtnetlink event generation fixes from Xin Long.
8) Deadlock in mlxsw driver, from Ido Schimmel.
9) Disallow arithmetic operations on context pointers in bpf, from
Jakub Kicinski.
10) Missing sock_owned_by_user() check in sctp_icmp_redirect(), from
Xin Long.
11) Only TCP is supported for sockmap, make that explicit with a
check, from John Fastabend.
12) Fix IP options state races in DCCP and TCP, from Eric Dumazet.
13) Fix panic in packet_getsockopt(), also from Eric Dumazet.
14) Add missing locked in hv_sock layer, from Dexuan Cui.
15) Various aquantia bug fixes, including several statistics handling
cures. From Igor Russkikh et al.
16) Fix arithmetic overflow in devmap code, from John Fastabend.
17) Fix busted socket memory accounting when we get a fault in the tcp
zero copy paths. From Willem de Bruijn.
18) Don't leave opt->tot_len uninitialized in ipv6, from Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits)
stmmac: Don't access tx_q->dirty_tx before netif_tx_lock
ipv6: flowlabel: do not leave opt->tot_len with garbage
of_mdio: Fix broken PHY IRQ in case of probe deferral
textsearch: fix typos in library helpers
rxrpc: Don't release call mutex on error pointer
net: stmmac: Prevent infinite loop in get_rx_timestamp_status()
net: stmmac: Fix stmmac_get_rx_hwtstamp()
net: stmmac: Add missing call to dev_kfree_skb()
mlxsw: spectrum_router: Configure TIGCR on init
mlxsw: reg: Add Tunneling IPinIP General Configuration Register
net: ethtool: remove error check for legacy setting transceiver type
soreuseport: fix initialization race
net: bridge: fix returning of vlan range op errors
sock: correct sk_wmem_queued accounting on efault in tcp zerocopy
bpf: add test cases to bpf selftests to cover all access tests
bpf: fix pattern matches for direct packet access
bpf: fix off by one for range markings with L{T, E} patterns
bpf: devmap fix arithmetic overflow in bitmap_size calculation
net: aquantia: Bad udp rate on default interrupt coalescing
net: aquantia: Enable coalescing management via ethtool interface
SK_SKB BPF programs are run from the socket/tcp context but early in
the stack before much of the TCP metadata is needed in tcp_skb_cb. So
we can use some unused fields to place BPF metadata needed for SK_SKB
programs when implementing the redirect function.
This allows us to drop the preempt disable logic. It does however
require an API change so sk_redirect_map() has been updated to
additionally provide ctx_ptr to skb. Note, we do however continue to
disable/enable preemption around actual BPF program running to account
for map updates.
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Silences the checker:
Warning: Kernel ABI header at 'tools/include/uapi/linux/bpf.h' differs from latest version at 'include/uapi/linux/bpf.h'
The 90caccdd8cc0 ("bpf: fix bpf_tail_call() x64 JIT") cset only updated
a comment in uapi/bpf.h.
Cc: Alexei Starovoitov <ast@fb.com>
Link: http://lkml.kernel.org/n/tip-rwx2cqbf0x1lwa1krsr6e6hd@git.kernel.org
Time for a sync with ABI/uapi headers with the upcoming v4.14 kernel.
None of the ABI changes require any source code level changes to our
existing in-kernel tooling code:
- tools/arch/s390/include/uapi/asm/kvm.h:
New KVM_S390_VM_TOD_EXT ABI, not used by in-kernel tooling.
- tools/arch/x86/include/asm/cpufeatures.h:
tools/arch/x86/include/asm/disabled-features.h:
New PCID, SME and VGIF x86 CPU feature bits defined.
- tools/include/asm-generic/hugetlb_encode.h:
tools/include/uapi/asm-generic/mman-common.h:
tools/include/uapi/linux/mman.h:
Two new madvise() flags, plus a hugetlb system call mmap flags
restructuring/extension changes.
- tools/include/uapi/drm/drm.h:
tools/include/uapi/drm/i915_drm.h:
New drm_syncobj_create flags definitions, new drm_syncobj_wait
and drm_syncobj_array ABIs. DRM_I915_PERF_* calls and a new
I915_PARAM_HAS_EXEC_FENCE_ARRAY ABI for the Intel driver.
- tools/include/uapi/linux/bpf.h:
New bpf_sock fields (::mark and ::priority), new XDP_REDIRECT
action, new kvm_ppc_smmu_info fields (::data_keys, instr_keys)
Cc: Milian Wolff <milian.wolff@kdab.com>
Cc: Taeung Song <treeze.taeung@gmail.com>
Cc: Yao Jin <yao.jin@linux.intel.com>
Link: http://lkml.kernel.org/r/20170913073823.lxmi4c7ejqlfabjx@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
- Fix TUI progress bar when delta from new total from that of the
previous update is greater than the progress "step" (screen width
progress bar block)) (Jiri Olsa)
- Make tools/lib/api make DEBUG=1 build use -D_FORTIFY_SOURCE=2 not
to cripple debuginfo, just like tools/perf/ does (Jiri Olsa)
- Avoid leaking the 'perf.data' file to workloads started from the
'perf record' command line by using the O_CLOEXEC open flag (Jiri Olsa)
- Fix building when libunwind's 'unwind.h' file is present in the
include path, clashing with tools/perf/util/unwind.h (Milian Wolff)
- Check per .perfconfig section entry flag, not just per section (Taeung Song)
- Support running perf binaries with a dash in their name, needed to
run perf as an AppImage (Milian Wolff)
- Wait for the right child by using waitpid() when running workloads
from 'perf stat', also to fix using perf as an AppImage (Milian Wolff)
Pull perf tooling updates from Ingo Molnar:
"Perf tooling updates and fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf annotate browser: Help for cycling thru hottest instructions with TAB/shift+TAB
perf stat: Only auto-merge events that are PMU aliases
perf test: Add test case for PERF_SAMPLE_PHYS_ADDR
perf script: Support physical address
perf mem: Support physical address
perf sort: Add sort option for physical address
perf tools: Support new sample type for physical address
perf vendor events powerpc: Remove duplicate events
perf intel-pt: Fix syntax in documentation of config option
perf test powerpc: Fix 'Object code reading' test
perf trace: Support syscall name globbing
perf syscalltbl: Support glob matching on syscall names
perf report: Calculate the average cycles of iterations
When cross building to android r15c (and older versions) on Fedora 26
we notice these:
/opt/android-ndk-r15c/platforms/android-24/arch-arm/usr/include/sys/cdefs.h:332:0: note: this is the location of the previous definition
For __aligned, __packed and __noreturn, so guard those with ifdefs to
avoid drowning useful warnings in these.
Link: http://lkml.kernel.org/n/tip-d7w3fa9c22dtmrwbedos6ie1@git.kernel.org
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big char/misc driver update for 4.14-rc1.
Lots of different stuff in here, it's been an active development cycle
for some reason. Highlights are:
- updated binder driver, this brings binder up to date with what
shipped in the Android O release, plus some more changes that
happened since then that are in the Android development trees.
- coresight updates and fixes
- mux driver file renames to be a bit "nicer"
- intel_th driver updates
- normal set of hyper-v updates and changes
- small fpga subsystem and driver updates
- lots of const code changes all over the driver trees
- extcon driver updates
- fmc driver subsystem upadates
- w1 subsystem minor reworks and new features and drivers added
- spmi driver updates
Plus a smattering of other minor driver updates and fixes.
All of these have been in linux-next with no reported issues for a
while"
* tag 'char-misc-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (244 commits)
ANDROID: binder: don't queue async transactions to thread.
ANDROID: binder: don't enqueue death notifications to thread todo.
ANDROID: binder: Don't BUG_ON(!spin_is_locked()).
ANDROID: binder: Add BINDER_GET_NODE_DEBUG_INFO ioctl
ANDROID: binder: push new transactions to waiting threads.
ANDROID: binder: remove proc waitqueue
android: binder: Add page usage in binder stats
android: binder: fixup crash introduced by moving buffer hdr
drivers: w1: add hwmon temp support for w1_therm
drivers: w1: refactor w1_slave_show to make the temp reading functionality separate
drivers: w1: add hwmon support structures
eeprom: idt_89hpesx: Support both ACPI and OF probing
mcb: Fix an error handling path in 'chameleon_parse_cells()'
MCB: add support for SC31 to mcb-lpc
mux: make device_type const
char: virtio: constify attribute_group structures.
Documentation/ABI: document the nvmem sysfs files
lkdtm: fix spelling mistake: "incremeted" -> "incremented"
perf: cs-etm: Fix ETMv4 CONFIGR entry in perf.data file
nvmem: include linux/err.h from header
Support new sample type PERF_SAMPLE_PHYS_ADDR for physical address.
Add new option --phys-data to record sample physical address.
Signed-off-by: Kan Liang <kan.liang@intel.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Stephane Eranian <eranian@google.com>
Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1504026672-7304-2-git-send-email-kan.liang@intel.com
[ Added missing printing in evsel.c patch sent by Jiri Olsa ]
In the initial sockmap API we provided strparser and verdict programs
using a single attach command by extending the attach API with a the
attach_bpf_fd2 field.
However, if we add other programs in the future we will be adding a
field for every new possible type, attach_bpf_fd(3,4,..). This
seems a bit clumsy for an API. So lets push the programs using two
new type fields.
BPF_SK_SKB_STREAM_PARSER
BPF_SK_SKB_STREAM_VERDICT
This has the advantage of having a readable name and can easily be
extended in the future.
Updates to samples and sockmap included here also generalize tests
slightly to support upcoming patch for multiple map support.
Fixes: 174a79ff9515 ("bpf: sockmap with sk redirect support")
Suggested-by: Alexei Starovoitov <ast@kernel.org>
The value passed into the perf.data file for the CONFIGR register in ETMv4
was incorrectly being set to the command line options/ETMv3 value.
Adds bit definitions and function to remap this value to the correct ETMv4
CONFIGR bit values for all selected options.
Signed-off-by: Mike Leach <mike.leach@linaro.org>
Return stack is a programmable option on some ETM and PTM hardware.
Adds the option flags to enable this from the perf event command line.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Add decoding for the new "lvlx" and "snoopx" meminfo fields added
earlier to the kernel so that "perf mem report" and other tools can
print it properly.
v2: Merge with persistent memory patch.
Switch to new bit encoding for each combination.
v3: Switch to generic lvlnum field.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20170816222156.19953-4-andi@firstfloor.org
This patch makes the needed changes to allow each process of
the INNER_LRU_HASH_PREALLOC test to provide its numa node id
when creating the lru map.
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Alexei Starovoitov <ast@fb.com>
This program binds a program to a cgroup and then matches hard
coded IP addresses and adds these to a sockmap.
This will receive messages from the backend and send them to
the client.
client:X <---> frontend:10000 client:X <---> backend:10001
To keep things simple this is only designed for 1:1 connections
using hard coded values. A more complete example would allow many
backends and clients.
To run,
# sockmap <cgroup2_dir>
Currently, eBPF only understands BPF_JGT (>), BPF_JGE (>=),
BPF_JSGT (s>), BPF_JSGE (s>=) instructions, this means that
particularly *JLT/*JLE counterparts involving immediates need
to be rewritten from e.g. X < [IMM] by swapping arguments into
[IMM] > X, meaning the immediate first is required to be loaded
into a register Y := [IMM], such that then we can compare with
Y > X. Note that the destination operand is always required to
be a register.
This has the downside of having unnecessarily increased register
pressure, meaning complex program would need to spill other
registers temporarily to stack in order to obtain an unused
register for the [IMM]. Loading to registers will thus also
affect state pruning since we need to account for that register
use and potentially those registers that had to be spilled/filled
again. As a consequence slightly more stack space might have
been used due to spilling, and BPF programs are a bit longer
due to extra code involving the register load and potentially
required spill/fills.
Thus, add BPF_JLT (<), BPF_JLE (<=), BPF_JSLT (s<), BPF_JSLE (s<=)
counterparts to the eBPF instruction set. Modifying LLVM to
remove the NegateCC() workaround in a PoC patch at [1] and
allowing it to also emit the new instructions resulted in
cilium's BPF programs that are injected into the fast-path to
have a reduced program length in the range of 2-3% (e.g.
accumulated main and tail call sections from one of the object
file reduced from 4864 to 4729 insns), reduced complexity in
the range of 10-30% (e.g. accumulated sections reduced in one
of the cases from 116432 to 88428 insns), and reduced stack
usage in the range of 1-5% (e.g. accumulated sections from one
of the object files reduced from 824 to 784b).
The modification for LLVM will be incorporated in a backwards
compatible way. Plan is for LLVM to have i) a target specific
option to offer a possibility to explicitly enable the extension
by the user (as we have with -m target specific extensions today
for various CPU insns), and ii) have the kernel checked for
presence of the extensions and enable them transparently when
the user is selecting more aggressive options such as -march=native
in a bpf target context. (Other frontends generating BPF byte
code, e.g. ply can probe the kernel directly for its code
generation.)
[1] https://github.com/borkmann/llvm/tree/bpf-insns
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Add test for xdp_redirect by creating two namespaces with two
veth peers, then forward packets in-between.
Signed-off-by: William Tu <u9012063@gmail.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: John Fastabend <john.fastabend@gmail.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
We will use it to generate tables for beautifying ioctl's 'cmd' arg.
Cc: Jason Wang <jasowang@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Link: http://lkml.kernel.org/n/tip-nxwpq34hu6te1m2ra5m7o8n9@git.kernel.org
Link: http://lkml.kernel.org/n/tip-wit4wwmrh9d37dtgtk0glbbj@git.kernel.org
Link: http://lkml.kernel.org/n/tip-bqoq114h917u6ggazn8m1w0t@git.kernel.org
In 04df41e343db ("bpf: update tools/include/uapi/linux/bpf.h") the files
added in 40304b2a1567 ("bpf: BPF support for sock_ops") were added to
tools/include, but not in a verbatim way, missing the comments, which
ends up triggering this warning when build tools/perf/:
make: Entering directory '/home/acme/git/linux/tools/perf'
BUILD: Doing 'make -j4' parallel build
Make sure the the lines are equal, to fix the simple header copy
drift detector in tools/perf/.
Cc: Lawrence Brakmo <brakmo@fb.com>
Fixes: 04df41e343db ("bpf: update tools/include/uapi/linux/bpf.h")
Link: http://lkml.kernel.org/n/tip-z9qyyqht9qq3yyxu76sfy0dh@git.kernel.org
So that we can build on older systems where otherwise we would end up
with:
CC /tmp/build/perf/trace/beauty/ioctl.o
trace/beauty/ioctl.c: In function 'ioctl__scnprintf_tty_cmd':
trace/beauty/ioctl.c:25:17: error: 'TIOCGEXCL' undeclared (first use in this function)
trace/beauty/ioctl.c:25:17: note: each undeclared identifier is reported only once for each function it appears in
trace/beauty/ioctl.c:25:2: error: array index in initializer not of integer type
trace/beauty/ioctl.c:25:2: error: (near initialization for 'ioctl_tty_cmd')
This way we can build a tool on an older system and it will still be
capable of processing perf.data files generated on newer systems.
Link: http://lkml.kernel.org/n/tip-8qvkv6txwuzua6d0yvt65wl3@git.kernel.org
In 2be7e212d541 ("bpf: add bpf_skb_adjust_room helper") BPF_ADJ_ROOM_NET was
added to include/uapi/linux/bpf.h but BPF_ADJ_ROOM_NET_OPS was added to
tools/include/uapi/linux/bpf.h, making these files differ, fix it by using the
same name in both, BPF_ADJ_ROOM_NET, the one in the kernel headers copy.
Fixes: 2be7e212d541 ("bpf: add bpf_skb_adjust_room helper")
Link: http://lkml.kernel.org/n/tip-2bmwovi9lymplyz6wsszppyf@git.kernel.org
refresh the tree
Apparently through one of my revisions of the initial patches
series I lost the devmap test. We can add more testing later but
for now lets fix the simple one we have.
Fixes: 546ac1ffb70d "bpf: add devmap, a map for storing net device references"
Reported-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Replacing prefixcmp(), same purpose, inverted result, so standardize on
the kernel variant, to reduce silly differences among tools/ and the
kernel sources, making it easier for people to work in both codebases.
And then doing:
if (strstarts(option, "no-"))
Looks clearer than doing:
if (!prefixcmp(option, "no-"))
To figure out if option starts witn "no-".
Link: http://lkml.kernel.org/n/tip-kaei42gi7lpa8subwtv7eug8@git.kernel.org
So that we make sure we have recent enough defines for things
such as 'perf trace' system call argument beautifiers.
For instance, the 'clone' syscall argument 'flag' needs to use
CLONE_NEWCGROUP, and that is not available in RHEL7.
Link: http://lkml.kernel.org/n/tip-81sln0ng4a2lcxrth14vcov4@git.kernel.org
It is often useful to know the branch types while analyzing branch data.
For example, a call is very different from a conditional branch.
Currently we have to look it up in binary while the binary may later not
be available and even the binary is available but user has to take some
time. It is very useful for user to check it directly in perf report.
Perf already has support for disassembling the branch instruction to get
the x86 branch type.
To keep consistent on kernel and userspace and make the classification
more common, the patch adds the common branch type classification
in perf_event.h.
The patch only defines a minimum but most common set of branch types.
PERF_BR_UNKNOWN : unknown
PERF_BR_COND :conditional
PERF_BR_UNCOND : unconditional
PERF_BR_IND : indirect
PERF_BR_CALL : function call
PERF_BR_IND_CALL : indirect function call
PERF_BR_RET : function return
PERF_BR_SYSCALL : syscall
PERF_BR_SYSRET : syscall return
PERF_BR_COND_CALL : conditional function call
PERF_BR_COND_RET : conditional function return
The patch also adds a new field type (4 bits) in perf_branch_entry
to record the branch type.
Since the disassembling of branch instruction needs some overhead,
a new PERF_SAMPLE_BRANCH_TYPE_SAVE is introduced to indicate if it
needs to disassemble the branch instruction and record the branch
type.
Change log:
v10: Not changed.
v9: Not changed.
v8: Change PERF_BR_NONE to PERF_BR_UNKNOWN.
No other change.
v7: Just keep the most common branch types.
Others are removed.
v6: Not changed.
v5: Not changed. The v5 patch series just change the userspace.
v4: Comparing to previous version, the major changes are:
1. Remove the PERF_BR_JCC_FWD/PERF_BR_JCC_BWD, they will be
computed later in userspace.
2. Remove the "cross" field in perf_branch_entry. The cross page
computing will be done later in userspace.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1500379995-6449-2-git-send-email-yao.jin@linux.intel.com
We'll need defines for beautifying fcntl arguments that are not
available in older distros, these:
trace/beauty/fcntl.c: In function 'syscall_arg__scnprintf_fcntl_arg':
trace/beauty/fcntl.c:93: error: 'F_OFD_SETLK' undeclared (first use in this function)
trace/beauty/fcntl.c:93: error: (Each undeclared identifier is reported only once
trace/beauty/fcntl.c:93: error: for each function it appears in.)
trace/beauty/fcntl.c:93: error: 'F_OFD_SETLKW' undeclared (first use in this function)
trace/beauty/fcntl.c:93: error: 'F_OFD_GETLK' undeclared (first use in this function)
trace/beauty/fcntl.c:94: error: 'F_GETOWN_EX' undeclared (first use in this function)
trace/beauty/fcntl.c:94: error: 'F_SETOWN_EX' undeclared (first use in this function)
Link: http://lkml.kernel.org/n/tip-gvlw67a47e9z65jdunj4je5s@git.kernel.org
To get the changes in the commit c75b1d9421f8 ("fs: add fcntl()
interface for setting/getting write life time hints").
Silencing this perf build warning:
Warning: include/uapi/linux/fcntl.h differs from kernel
We already beautify the fcntl cmd argument, so an upcoming cset will
update the 'cmd' strarray to cover these new commands.
The hints are in the 3rd arg, a pointer, so not yet supported in 'perf
trace', for that we need to copy it somehow, probably using eBPF, a new
attempt at doing that is planned.
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Link: http://lkml.kernel.org/n/tip-al471wzs3x48alql0tm3mnfa@git.kernel.org
"Reasonably busy this cycle, but perhaps not as busy as in the 4.12
merge window:
1) Several optimizations for UDP processing under high load from
Paolo Abeni.
2) Support pacing internally in TCP when using the sch_fq packet
scheduler for this is not practical. From Eric Dumazet.
3) Support mutliple filter chains per qdisc, from Jiri Pirko.
4) Move to 1ms TCP timestamp clock, from Eric Dumazet.
5) Add batch dequeueing to vhost_net, from Jason Wang.
6) Flesh out more completely SCTP checksum offload support, from
Davide Caratti.
7) More plumbing of extended netlink ACKs, from David Ahern, Pablo
Neira Ayuso, and Matthias Schiffer.
8) Add devlink support to nfp driver, from Simon Horman.
9) Add RTM_F_FIB_MATCH flag to RTM_GETROUTE queries, from Roopa
Prabhu.
10) Add stack depth tracking to BPF verifier and use this information
in the various eBPF JITs. From Alexei Starovoitov.
11) Support XDP on qed device VFs, from Yuval Mintz.
12) Introduce BPF PROG ID for better introspection of installed BPF
programs. From Martin KaFai Lau.
13) Add bpf_set_hash helper for TC bpf programs, from Daniel Borkmann.
14) For loads, allow narrower accesses in bpf verifier checking, from
Yonghong Song.
15) Support MIPS in the BPF selftests and samples infrastructure, the
MIPS eBPF JIT will be merged in via the MIPS GIT tree. From David
Daney.
16) Support kernel based TLS, from Dave Watson and others.
17) Remove completely DST garbage collection, from Wei Wang.
18) Allow installing TCP MD5 rules using prefixes, from Ivan
Delalande.
19) Add XDP support to Intel i40e driver, from Björn Töpel
20) Add support for TC flower offload in nfp driver, from Simon
Horman, Pieter Jansen van Vuuren, Benjamin LaHaise, Jakub
Kicinski, and Bert van Leeuwen.
21) IPSEC offloading support in mlx5, from Ilan Tayari.
22) Add HW PTP support to macb driver, from Rafal Ozieblo.
23) Networking refcount_t conversions, From Elena Reshetova.
24) Add sock_ops support to BPF, from Lawrence Brako. This is useful
for tuning the TCP sockopt settings of a group of applications,
currently via CGROUPs"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1899 commits)
net: phy: dp83867: add workaround for incorrect RX_CTRL pin strap
dt-bindings: phy: dp83867: provide a workaround for incorrect RX_CTRL pin strap
cxgb4: Support for get_ts_info ethtool method
cxgb4: Add PTP Hardware Clock (PHC) support
cxgb4: time stamping interface for PTP
nfp: default to chained metadata prepend format
nfp: remove legacy MAC address lookup
nfp: improve order of interfaces in breakout mode
net: macb: remove extraneous return when MACB_EXT_DESC is defined
bpf: add missing break in for the TCP_BPF_SNDCWND_CLAMP case
bpf: fix return in load_bpf_file
mpls: fix rtm policy in mpls_getroute
net, ax25: convert ax25_cb.refcount from atomic_t to refcount_t
net, ax25: convert ax25_route.refcount from atomic_t to refcount_t
net, ax25: convert ax25_uid_assoc.refcount from atomic_t to refcount_t
net, sctp: convert sctp_ep_common.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_transport.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_chunk.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_datamsg.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_auth_bytes.refcnt from atomic_t to refcount_t
Pull perf updates from Ingo Molnar:
"Most of the changes are for tooling, the main changes in this cycle were:
- Improve Intel-PT hardware tracing support, both on the kernel and
on the tooling side: PTWRITE instruction support, power events for
C-state tracing, etc. (Adrian Hunter)
- Add support to measure SMI cost to the x86 architecture, with
tooling support in 'perf stat' (Kan Liang)
- Support function filtering in 'perf ftrace', plus related
improvements (Namhyung Kim)
- Allow adding and removing fields to the default 'perf script'
columns, using + or - as field prefixes to do so (Andi Kleen)
- Allow resolving the DSO name with 'perf script -F brstack{sym,off},dso'
(Mark Santaniello)
- Add perf tooling unwind support for PowerPC (Paolo Bonzini)
- ... and various other improvements as well"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (84 commits)
perf auxtrace: Add CPU filter support
perf intel-pt: Do not use TSC packets for calculating CPU cycles to TSC
perf intel-pt: Update documentation to include new ptwrite and power events
perf intel-pt: Add example script for power events and PTWRITE
perf intel-pt: Synthesize new power and "ptwrite" events
perf intel-pt: Move code in intel_pt_synth_events() to simplify attr setting
perf intel-pt: Factor out intel_pt_set_event_name()
perf intel-pt: Tidy messages into called function intel_pt_synth_event()
perf intel-pt: Tidy Intel PT evsel lookup into separate function
perf intel-pt: Join needlessly wrapped lines
perf intel-pt: Remove unused instructions_sample_period
perf intel-pt: Factor out common code synthesizing event samples
perf script: Add synthesized Intel PT power and ptwrite events
perf/x86/intel: Constify the 'lbr_desc[]' array and make a function static
perf script: Add 'synth' field for synthesized event payloads
perf auxtrace: Add itrace option to output power events
perf auxtrace: Add itrace option to output ptwrite events
tools include: Add byte-swapping macros to kernel.h
perf script: Add 'synth' event type for synthesized events
x86/insn: perf tools: Add new ptwrite instruction
This work adds a helper that can be used to adjust net room of an
skb. The helper is generic and can be further extended in future.
Main use case is for having a programmatic way to add/remove room to
v4/v6 header options along with cls_bpf on egress and ingress hook
of the data path. It reuses most of the infrastructure that we added
for the bpf_skb_change_type() helper which can be used in nat64
translations. Similarly, the helper only takes care of adjusting the
room so that related data is populated and csum adapted out of the
BPF program using it.
Update tools/include/uapi/linux/bpf.h to include changes related to new
bpf sock_ops program type.
Signed-off-by: Lawrence Brakmo <brakmo@fb.com>
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1495786658-18063-23-git-send-email-adrian.hunter@intel.com
To have a more compact way to ask the compiler to use a specific
alignment, making tools/ look more like kernel source code.
Link: http://lkml.kernel.org/n/tip-8jiem6ubg9rlpbs7c2p900no@git.kernel.org
