path: root/tools/lib
2017-08-06tools lib traceevent: Fix prev/next_prio for deadline tasksDaniel Bristot de Oliveira
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ] Currently, the sched:sched_switch tracepoint reports deadline tasks with priority -1. But when reading the trace via perf script I've got the following output: # ./d & # (d is a deadline task, see [1]) # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295] d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295] The task d reports the wrong priority [4294967295]. This happens because the "int prio" is stored in an unsigned long long val. Although it is set as a %lld, as int is shorter than unsigned long long, trace_seq_printf prints it as a positive number. The fix is just to cast the val as an int, and print it as a %d, as in the sched:sched_switch tracepoint's "format". The output with the fix is: # ./d & # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1] d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120] [1] d.c --- #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #include <linux/types.h> #include <linux/sched.h> struct sched_attr { __u32 size, sched_policy; __u64 sched_flags; __s32 sched_nice; __u32 sched_priority; __u64 sched_runtime, sched_deadline, sched_period; }; int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags) { return syscall(__NR_sched_setattr, pid, attr, flags); } int main(void) { struct sched_attr attr = { .size = sizeof(attr), .sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */ .sched_runtime = 10 * 1000 * 1000, .sched_period = attr.sched_deadline = 30 * 1000 * 1000, }; if (sched_setattr(0, &attr, 0) < 0) { perror("sched_setattr"); return -1; } for(;;); } --- Committer notes: Got the program from the provided URL, http://bristot.me/lkml/d.c, trimmed it and included in the cset log above, so that we have everything needed to test it in one place. Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Daniel Bristot de Oliveira <bristot@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21tools/lib/lockdep: Reduce MAX_LOCK_DEPTH to avoid overflowing lock_chain/: DepthBen Hutchings
commit 98dcea0cfd04e083ac74137ceb9a632604740e2d upstream. liblockdep has been broken since commit 75dd602a5198 ("lockdep: Fix lock_chain::base size"), as that adds a check that MAX_LOCK_DEPTH is within the range of lock_chain::depth and in liblockdep it is much too large. That should have resulted in a compiler error, but didn't because: - the check uses ARRAY_SIZE(), which isn't yet defined in liblockdep so is assumed to be an (undeclared) function - putting a function call inside a BUILD_BUG_ON() expression quietly turns it into some nonsense involving a variable-length array It did produce a compiler warning, but I didn't notice because liblockdep already produces too many warnings if -Wall is enabled (which I'll fix shortly). Even before that commit, which reduced lock_chain::depth from 8 bits to 6, MAX_LOCK_DEPTH was too large. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: a.p.zijlstra@chello.nl Link: http://lkml.kernel.org/r/20170525130005.5947-3-alexander.levin@verizon.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-05tools lib traceevent: Fix kbuffer_read_at_offset()Namhyung Kim
When it's called with an offset less than or equal to the first event, it'll return a garbage value since the data is not initialized. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20161001101700.29146-1-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-03perf tools: Query terminal width and use in perf listAndi Kleen
Automatically adapt the now wider and word wrapped perf list output to wider terminals. This requires querying the terminal before the auto pager takes over, and exporting this information from the pager subsystem. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1473978296-20712-8-git-send-email-sukadev@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-09-08tools lib api fs: Add hugetlbfs filesystem detectorWang Nan
Detect hugetlbfs. hugetlbfs__mountpoint() will be used during recording to help identifying hugetlb mmaps: which should be recognized as anon mapping. Signed-off-by: Wang Nan <wangnan0@huawei.com> Reviewed-by: Nilay Vaish <nilayvaish@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Hou Pengyang <houpengyang@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1473137909-142064-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-08-04Merge tag 'perf-core-for-mingo-20160803' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: New features: - Add --sample-cpu to 'perf record', to explicitely ask for sampling the CPU (Jiri Olsa) Fixes: - Fix processing of multi byte chunks in objdump output, fixing disassemble processing for annotation on at least ARM64 (Jan Stancek) - Use SyS_epoll_wait in a BPF 'perf test' entry instead of sys_epoll_wait, that is not present in the DWARF info in vmlinux files (Arnaldo Carvalho de Melo) - Add -wno-shadow when processing files using perl headers, fixing the build on Fedora Rawhide and Arch Linux (Namhyung Kim) Infrastructure changes: - Annotate prep work to better catch and report errors related to using objdump to disassemble DSOs (Arnaldo Carvalho de Melo) - Add 'alloc', 'scnprintf' and 'and' methods for bitmap processing (Jiri Olsa) - Add nested output resorting callback in hists processing (Jiri Olsa) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-08-02tools lib: Add bitmap_and functionJiri Olsa
Add support to perform logical and on bitmaps. Code taken from kernel's include/linux/bitmap.h. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1470074555-24889-4-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-08-02tools lib: Add bitmap_scnprintf functionJiri Olsa
Add support to print bitmap list. Code mostly taken from kernel's bitmap_list_string. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1470074555-24889-3-git-send-email-jolsa@kernel.org [ s/bitmap_snprintf/bitmap_scnprintf/g as it is a scnprintf wrapper, having the same semantics wrt return value ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-08-02tools lib traceevent: Ignore generated library filesNamhyung Kim
Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20160802050148.3413-1-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-27tools lib api: Add str_error_c to libapiArnaldo Carvalho de Melo
Because it uses that function, which would lead every tool using it to need to link against tools/lib/str_error_r.o. This fixes building tools/vm/, that links with libapi. Reported-by: Arjan van de Ven <arjan@linux.intel.com> Reported-by: Randy Dunlap <rdunlap@infradead.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: b31e3e3316a7 ("tools lib api fs: Use str_error_r()") Link: http://lkml.kernel.org/n/tip-aedt3qzibhnhaov2j4caqi61@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-26tools lib bpf: Use official ELF e_machine valueWang Nan
New LLVM will issue newly assigned EM_BPF machine code. The new code will be propagated to glibc and libelf. This patch introduces the new machine code to libbpf. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1468821668-60088-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-15tools lib fd array: Allow associating a pointer cookie with each entryWang Nan
Add a 'ptr' field to fdarray->priv array. This feature will be used by following commits, which introduce muiltiple 'struct perf_mmap' arrays for different types of mapping. Because of this, during fdarray__filter(), a simple 'idx' is not enough. Add a pointer cookie that allows to directly associate a 'struct perf_mmap' pointer to an fdarray entry. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Nilay Vaish <nilayvaish@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1468485287-33422-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-15tools lib api fs: Use base 0 in filename__read_ullJiri Olsa
By using 0 for base, the strtoull() detects the base automatically (see 'man strtoull'). ATM we have just one user of this function, the cpu__get_max_freq function reading the "cpuinfo_max_freq" sysfs file. It should not get affected by this change. Committer note: This change seems motivated by this discussion: "[PATCH] [RFC V1]s390/perf: fix 'start' address of module's map" http://lkml.kernel.org/r/20160711120155.GA29929@krava I.e. this patches paves the way for filename__read_ull() to be used in a S/390 related fix. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Songshan Gong <gongss@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1468567797-27564-4-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-14tools lib traceevent: Add correct header for ipv6 definitionsArnaldo Carvalho de Melo
We need to include netinet/in.h to get the in6_addr struct definition, needed to build it on the Android NDK: In file included from event-parse.c:36:0: /home/acme/android/android-ndk-r12/platforms/android-24/arch-arm/usr/include/netinet/ip6.h:82:18: error: field 'ip6_src' has incomplete type struct in6_addr ip6_src; /* source address */ And it is the canonical way of getting IPv6 definitions, as described, for instance, in Linux's 'man ipv6' Doing that uncovers another problem: this source file uses PRIu64 but doesn't include it, depending on it being included by chance via the now replaced header (netinet/ip6.h), fix it. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Chris Phlipot <cphlipot0@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-tilr31n3yaba1whsd47qlwa3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-13tools lib bpf: Report error when kernel doesn't support program typeWang Nan
Now libbpf support tracepoint program type. Report meaningful error when kernel version is less than 4.7. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1468406646-21642-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-13tools lib bpf: New API to adjust type of a BPF programWang Nan
Add 4 new APIs to adjust and query the type of a BPF program. Load program according to type set by caller. Default is set to BPF_PROG_TYPE_KPROBE. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1468406646-21642-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools lib traceevent: Add filter on task CPU idSteven Rostedt
Add a 'CPU' special field to allow the filter in trace-cmd report to filter on the task's CPU. By adding a special field 'CPU' (all caps) the user can now filter out tasks based on which CPU they are on. This is useful when filtering out (or in) a bunch of threads. -F 'CPU == 0' Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20160712093306.5b058103@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools lib bpf: Copy bpf.h and bpf_common.h from the kernelArnaldo Carvalho de Melo
To allow the build to complete on older systems, where those files are either not uptodate, lacking some recent additions or not present at all. And check if the copy drifts from the kernel, as in this synthetic test: BUILD: Doing 'make -j4' parallel build Warning: tools/include/linux/bpf.h differs from kernel Warning: tools/include/linux/bpf_common.h differs from kernel Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-5plvi2gq4x469dcyybiu226q@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools lib subcmd: Use str_error_r()Arnaldo Carvalho de Melo
To make it portable to non-glibc systems, that follow the XSI variant instead of the GNU specific one that gets in place when _GNU_SOURCE is defined. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-bozcszy93tpgw9ad6qm3dhpx@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools lib api fs: Use str_error_r()Arnaldo Carvalho de Melo
To make it portable to non-glibc systems, that follow the XSI variant instead of the GNU specific one that gets in place when _GNU_SOURCE is defined. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-mixgnh3iyajuqogn2opsocdy@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools lib traceevent: Use str_error_r()Arnaldo Carvalho de Melo
To make it portable to non-glibc systems, that follow the XSI variant instead of the GNU specific one that gets in place when _GNU_SOURCE is defined. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-c1gn8x978qfop65m510wy43o@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12perf tools: Uninline scnprintf() and vscnprint()Arnaldo Carvalho de Melo
They were in tools/include/linux/kernel.h, requiring that it in turn included stdio.h, which is way too heavy. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-855h8olnkot9v0dajuee1lo3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-12tools: Introduce str_error_r()Arnaldo Carvalho de Melo
The tools so far have been using the strerror_r() GNU variant, that returns a string, be it the buffer passed or something else. But that, besides being tricky in cases where we expect that the function using strerror_r() returns the error formatted in a provided buffer (we have to check if it returned something else and copy that instead), breaks the build on systems not using glibc, like Alpine Linux, where musl libc is used. So, introduce yet another wrapper, str_error_r(), that has the GNU interface, but uses the portable XSI variant of strerror_r(), so that users rest asured that the provided buffer is used and it is what is returned. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-d4t42fnf48ytlk8rjxs822tf@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-04tools lib subcmd: Respect WERROR=0 for buildChris Phlipot
this enables the workaround for compilers that generate warnings when compiling libsubcmd. Signed-off-by: Chris Phlipot <cphlipot0@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1467349955-1135-3-git-send-email-cphlipot0@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-04tools lib api: Respect WERROR=0 for buildChris Phlipot
This enables the workaround for compilers that generate warnings when compiling libapi. Signed-off-by: Chris Phlipot <cphlipot0@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1467349955-1135-2-git-send-email-cphlipot0@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-07-04tools lib bpf: Add license headerWang Nan
Adding a missing license descriptopn header to files in libbpf, make it LGPL-2.1. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Eric Leblond <eleblond@stamus-networks.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1467630162-193121-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-29tools lib bpf: Fix spelling mistake: "missmatch" -> "mismatch"Colin Ian King
Trivial fix to spelling mistake Signed-off-by: Colin King <colin.king@canonical.com> Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: He Kuang <hekuang@huawei.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1467116617-8318-1-git-send-email-colin.king@canonical.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Rename set_private() to set_priv()Arnaldo Carvalho de Melo
For consistency with class__priv() elsewhere, and with the callback typedef for clearing those areas (e.g. bpf_map_clear_priv_t). Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-rnbiyv27ohw8xppsgx0el3xb@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Make bpf_program__get_private() use IS_ERR()Arnaldo Carvalho de Melo
For consistency with bpf_map__priv() and elsewhere. Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-x17nk5mrazkf45z0l0ahlmo8@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Remove _get_ from non-refcount method namesArnaldo Carvalho de Melo
The use of this term is not warranted here, we use it in the kernel sources and in tools/ for refcounting, so, for consistency, rename them. Acked-bu: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-4ya1ot2e2fkrz48ws9ebiofs@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Rename bpf_map__get_fd() to bpf_map__fd()Arnaldo Carvalho de Melo
For consistency, leaving "get" for reference counting. Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-msy8sxfz9th6gl2xjeci2btm@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Use IS_ERR() reporting macros with bpf_map__get_def()Arnaldo Carvalho de Melo
And for consistency, rename it to bpf_map__def(), leaving "get" for reference counting. Also make it return a const pointer, as suggested by Wang. Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-mer00xqkiho0ymg66b5i9luw@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Rename bpf_map__get_name() to bpf_map__name()Arnaldo Carvalho de Melo
For consistency, leaving "get" for reference counting. Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-crnflv84ejyhpba933ec71gs@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-06tools lib bpf: Use IS_ERR() reporting macros with bpf_map__get_private()Arnaldo Carvalho de Melo
To try to, over time, consistently use the IS_ERR() interface instead of using two return values, i.e. the integer return value for an error and the pointer address to return the bpf_map->priv pointer. Also rename it to bpf__priv(), to leave the "get" term for reference counting. Noticed while working on using BPF for collecting non-integer syscall argument payloads (struct sockaddr in calls such as connect(), for instance), where we need to use BPF maps and thus generalise bpf__setup_stdout() to connect bpf_output events with maps in a bpf proggie. Acked-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-saypxyd6ptrct379jqgxx4bl@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-06-03tools lib api: Respect CROSS_COMPILE for the linkerLucas Stach
This fixes cross compilation of libapi. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Cc: Jiri Olsa <jolsa@kernel.org> Cc: kernel@pengutronix.de Cc: patchwork-lst@pengutronix.de Link: http://lkml.kernel.org/r/1458235670-27341-1-git-send-email-l.stach@pengutronix.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-30tools: Pass arg to fdarray__filter's call back functionWang Nan
Before this patch there's no way to pass arguments to fdarray__filter's call back function. This improvement will be used by 'perf record' to support unmapping ring buffer for both main evlist and overwrite evlist. Without this patch there's no way to track overwrite evlist from 'struct fdarray'. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1464183898-174512-10-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-16Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Bigger kernel side changes: - Add backwards writing capability to the perf ring-buffer code, which is preparation for future advanced features like robust 'overwrite support' and snapshot mode. (Wang Nan) - Add pause and resume ioctls for the perf ringbuffer (Wang Nan) - x86 Intel cstate code cleanups and reorgnization (Thomas Gleixner) - x86 Intel uncore and CPU PMU driver updates (Kan Liang, Peter Zijlstra) - x86 AUX (Intel PT) related enhancements and updates (Alexander Shishkin) - x86 MSR PMU driver enhancements and updates (Huang Rui) - ... and lots of other changes spread out over 40+ commits. Biggest tooling side changes: - 'perf trace' features and enhancements. (Arnaldo Carvalho de Melo) - BPF tooling updates (Wang Nan) - 'perf sched' updates (Jiri Olsa) - 'perf probe' updates (Masami Hiramatsu) - ... plus 200+ other enhancements, fixes and cleanups to tools/ The merge commits, the shortlog and the changelogs contain a lot more details" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (249 commits) perf/core: Disable the event on a truncated AUX record perf/x86/intel/pt: Generate PMI in the STOP region as well perf buildid-cache: Use lsdir() for looking up buildid caches perf symbols: Use lsdir() for the search in kcore cache directory perf tools: Use SBUILD_ID_SIZE where applicable perf tools: Fix lsdir to set errno correctly perf trace: Move seccomp args beautifiers to tools/perf/trace/beauty/ perf trace: Move flock op beautifier to tools/perf/trace/beauty/ perf build: Add build-test for debug-frame on arm/arm64 perf build: Add build-test for libunwind cross-platforms support perf script: Fix export of callchains with recursion in db-export perf script: Fix callchain addresses in db-export perf script: Fix symbol insertion behavior in db-export perf symbols: Add dso__insert_symbol function perf scripting python: Use Py_FatalError instead of die() perf tools: Remove xrealloc and ALLOC_GROW perf help: Do not use ALLOC_GROW in add_cmd_list perf pmu: Make pmu_formats_string to check return value of strbuf perf header: Make topology checkers to check return value of strbuf perf tools: Make alias handler to check return value of strbuf ...
2016-05-12tools lib traceevent: Do not reassign parg after collapse_tree()Steven Rostedt
At the end of process_filter(), collapse_tree() was changed to update the parg parameter, but the reassignment after the call wasn't removed. What happens is that the "current_op" gets modified and freed and parg is assigned to the new allocated argument. But after the call to collapse_tree(), parg is assigned again to the just freed "current_op", and this causes the tool to crash. The current_op variable must also be assigned to NULL in case of error, otherwise it will cause it to be free()ed twice. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org # 3.14+ Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()") Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-26tools lib api fs: Add helper to read string from procfs fileArnaldo Carvalho de Melo
To read things like /proc/self/comm. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-ztpkbmseidt0hq2psr46o0h9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-30tools/lib/lockdep: Fix unsupported 'basename -s' in run_tests.shSedat Dilek
Here on Ubuntu/precise I have GNU/coreutils v8.13 installed where 'basename -s' is not supported. The result is that run_tests.sh is not done properly. How to reproduce: $ cd $BUILD_DIR $ LC_ALL=C make -C tools/ liblockdep $ cd tools/lib/lockdep/ $ LC_ALL=C ./run_tests.sh basename: invalid option -- 's' Try `basename --help' for more information. ... timeout: failed to run command `./tests/': Permission denied FAILED! rm: cannot remove `tests/': Is a directory Due to unsupported basename the tests programs are not generated and cannot be removed. Fix this by doing a compatible basename invocation and check for the existence of generated tests programs. For more details see this LKML thread: http://marc.info/?t=145906667300001&r=1&w=2 Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Boqun Feng <boqun.feng@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> (maintainer:LIBLOCKDEP) Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-fsdevel <linux-fsdevel@vger.kernel.org> Link: http://lkml.kernel.org/r/1459326169-7009-1-git-send-email-sedat.dilek@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-24Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This tree contains various perf fixes on the kernel side, plus three hw/event-enablement late additions: - Intel Memory Bandwidth Monitoring events and handling - the AMD Accumulated Power Mechanism reporting facility - more IOMMU events ... and a final round of perf tooling updates/fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) perf llvm: Use strerror_r instead of the thread unsafe strerror one perf llvm: Use realpath to canonicalize paths perf tools: Unexport some methods unused outside strbuf.c perf probe: No need to use formatting strbuf method perf help: Use asprintf instead of adhoc equivalents perf tools: Remove unused perf_pathdup, xstrdup functions perf tools: Do not include stringify.h from the kernel sources tools include: Copy linux/stringify.h from the kernel tools lib traceevent: Remove redundant CPU output perf tools: Remove needless 'extern' from function prototypes perf tools: Simplify die() mechanism perf tools: Remove unused DIE_IF macro perf script: Remove lots of unused arguments perf thread: Rename perf_event__preprocess_sample_addr to thread__resolve perf machine: Rename perf_event__preprocess_sample to machine__resolve perf tools: Add cpumode to struct perf_sample perf tests: Forward the perf_sample in the dwarf unwind test perf tools: Remove misplaced __maybe_unused perf list: Fix documentation of :ppp perf bench numa: Fix assertion for nodes bitfield ...
2016-03-24Merge tag 'perf-core-for-mingo-20160323' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/core improvements and fixes: User visible fixes: - Fix documentation of :ppp modifier in 'perf list' (Andi Kleen) - Fix silly nodes bitfield bits/bytes length assertion in 'perf bench numa' (Jakub Jelen) - Remove redundant CPU output in libtraceevent (Steven Rostedt) - Remove 'core_id' check in topology 'perf test' (Sukadev Bhattiprolu) Infrastructure changes/fixes: - Record text offset in dso to calculate objdump address, to use with modules in addition to vDSO symbol address calculations (Wang Nan) - Move utilities.mak from perf to tools/scripts/ (Arnaldo Carvalho de Melo) - Add cpumode to the perf_sample struct, this way we don't need to pass the union event to the machine and thread resolving routines, shortening function signatures and allowing the future introduction of a way to use tracepoint events instead of the unavailable HW cycles counter on powerpc guests in perf kvm by just hooking on perf_evsel__parse_sample, at the end (Arnaldo Carvalho de Melo) - Remove/unexport die() related infrastructure, that at some point will finally be removed (Arnaldo Carvalho de Melo) - Adopt linux/stringify.h from the kernel sources, not to touch this kernel header from tools/ (Arnaldo Carvalho de Melo) - Stop using strbuf for things we can instead trivially use libc's asprintf() (Arnaldo Carvalho de Melo) - Ditch tools/lib/util/abspath.c, its only exported function was used at just one place and can be replaced by libc's realpath() (Arnaldo Carvalho de Melo) - Use strerror_r() in the llvm infrastructure, tread safe, its what is used elsewhere in tools/perf/ (Arnaldo Carvalho de Melo) Cleanups: - Removed misplaced or needless __maybe_unused/export (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-23tools lib traceevent: Remove redundant CPU outputSteven Rostedt
Commit a6745330789f ("tools lib traceevent: Split pevent_print_event() into specific functionality functions") broke apart the function pevent_print_event() into three functions. The first function prints the comm, pid and CPU, the second prints the timestamp. But that commit added the printing of the CPU in the timestamp function, which now causes pevent_print_event() to duplicate the CPU output. Remove the redundant printing of the record's CPU from the timestamp function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung@kernel.org> Fixes: a6745330789f ("tools lib traceevent: Split pevent_print_event() into specific functionality functions") Link: http://lkml.kernel.org/r/20160323101628.459375d2@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-20Merge branch 'core-objtool-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull 'objtool' stack frame validation from Ingo Molnar: "This tree adds a new kernel build-time object file validation feature (ONFIG_STACK_VALIDATION=y): kernel stack frame correctness validation. It was written by and is maintained by Josh Poimboeuf. The motivation: there's a category of hard to find kernel bugs, most of them in assembly code (but also occasionally in C code), that degrades the quality of kernel stack dumps/backtraces. These bugs are hard to detect at the source code level. Such bugs result in incorrect/incomplete backtraces most of time - but can also in some rare cases result in crashes or other undefined behavior. The build time correctness checking is done via the new 'objtool' user-space utility that was written for this purpose and which is hosted in the kernel repository in tools/objtool/. The tool's (very simple) UI and source code design is shaped after Git and perf and shares quite a bit of infrastructure with tools/perf (which tooling infrastructure sharing effort got merged via perf and is already upstream). Objtool follows the well-known kernel coding style. Objtool does not try to check .c or .S files, it instead analyzes the resulting .o generated machine code from first principles: it decodes the instruction stream and interprets it. (Right now objtool supports the x86-64 architecture.) From tools/objtool/Documentation/stack-validation.txt: "The kernel CONFIG_STACK_VALIDATION option enables a host tool named objtool which runs at compile time. It has a "check" subcommand which analyzes every .o file and ensures the validity of its stack metadata. It enforces a set of rules on asm code and C inline assembly code so that stack traces can be reliable. Currently it only checks frame pointer usage, but there are plans to add CFI validation for C files and CFI generation for asm files. For each function, it recursively follows all possible code paths and validates the correct frame pointer state at each instruction. It also follows code paths involving special sections, like .altinstructions, __jump_table, and __ex_table, which can add alternative execution paths to a given instruction (or set of instructions). Similarly, it knows how to follow switch statements, for which gcc sometimes uses jump tables." When this new kernel option is enabled (it's disabled by default), the tool, if it finds any suspicious assembly code pattern, outputs warnings in compiler warning format: warning: objtool: rtlwifi_rate_mapping()+0x2e7: frame pointer state mismatch warning: objtool: cik_tiling_mode_table_init()+0x6ce: call without frame pointer save/setup warning: objtool:__schedule()+0x3c0: duplicate frame pointer save warning: objtool:__schedule()+0x3fd: sibling call from callable instruction with changed frame pointer ... so that scripts that pick up compiler warnings will notice them. All known warnings triggered by the tool are fixed by the tree, most of the commits in fact prepare the kernel to be warning-free. Most of them are bugfixes or cleanups that stand on their own, but there are also some annotations of 'special' stack frames for justified cases such entries to JIT-ed code (BPF) or really special boot time code. There are two other long-term motivations behind this tool as well: - To improve the quality and reliability of kernel stack frames, so that they can be used for optimized live patching. - To create independent infrastructure to check the correctness of CFI stack frames at build time. CFI debuginfo is notoriously unreliable and we cannot use it in the kernel as-is without extra checking done both on the kernel side and on the build side. The quality of kernel stack frames matters to debuggability as well, so IMO we can merge this without having to consider the live patching or CFI debuginfo angle" * 'core-objtool-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) objtool: Only print one warning per function objtool: Add several performance improvements tools: Copy hashtable.h into tools directory objtool: Fix false positive warnings for functions with multiple switch statements objtool: Rename some variables and functions objtool: Remove superflous INIT_LIST_HEAD objtool: Add helper macros for traversing instructions objtool: Fix false positive warnings related to sibling calls objtool: Compile with debugging symbols objtool: Detect infinite recursion objtool: Prevent infinite recursion in noreturn detection objtool: Detect and warn if libelf is missing and don't break the build tools: Support relative directory path for 'O=' objtool: Support CROSS_COMPILE x86/asm/decoder: Use explicitly signed chars objtool: Enable stack metadata validation on 64-bit x86 objtool: Add CONFIG_STACK_VALIDATION option objtool: Add tool to perform compile-time stack metadata validation x86/kprobes: Mark kretprobe_trampoline() stack frame as non-standard sched: Always inline context_switch() ...
2016-03-18tools: Move utilities.mak from perf to tools/scripts/Arnaldo Carvalho de Melo
As it is used by several other tools, better move it outside tools/perf. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-34s9kue3xq9w5mijdmfrfx8s@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-14Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Main kernel side changes: - Big reorganization of the x86 perf support code. The old code grew organically deep inside arch/x86/kernel/cpu/perf* and its naming became somewhat messy. The new location is under arch/x86/events/, using the following cleaner hierarchy of source code files: perf/x86: Move perf_event.c .................. => x86/events/core.c perf/x86: Move perf_event_amd.c .............. => x86/events/amd/core.c perf/x86: Move perf_event_amd_ibs.c .......... => x86/events/amd/ibs.c perf/x86: Move perf_event_amd_iommu.[ch] ..... => x86/events/amd/iommu.[ch] perf/x86: Move perf_event_amd_uncore.c ....... => x86/events/amd/uncore.c perf/x86: Move perf_event_intel_bts.c ........ => x86/events/intel/bts.c perf/x86: Move perf_event_intel.c ............ => x86/events/intel/core.c perf/x86: Move perf_event_intel_cqm.c ........ => x86/events/intel/cqm.c perf/x86: Move perf_event_intel_cstate.c ..... => x86/events/intel/cstate.c perf/x86: Move perf_event_intel_ds.c ......... => x86/events/intel/ds.c perf/x86: Move perf_event_intel_lbr.c ........ => x86/events/intel/lbr.c perf/x86: Move perf_event_intel_pt.[ch] ...... => x86/events/intel/pt.[ch] perf/x86: Move perf_event_intel_rapl.c ....... => x86/events/intel/rapl.c perf/x86: Move perf_event_intel_uncore.[ch] .. => x86/events/intel/uncore.[ch] perf/x86: Move perf_event_intel_uncore_nhmex.c => x86/events/intel/uncore_nmhex.c perf/x86: Move perf_event_intel_uncore_snb.c => x86/events/intel/uncore_snb.c perf/x86: Move perf_event_intel_uncore_snbep.c => x86/events/intel/uncore_snbep.c perf/x86: Move perf_event_knc.c .............. => x86/events/intel/knc.c perf/x86: Move perf_event_p4.c ............... => x86/events/intel/p4.c perf/x86: Move perf_event_p6.c ............... => x86/events/intel/p6.c perf/x86: Move perf_event_msr.c .............. => x86/events/msr.c (Borislav Petkov) - Update various x86 PMU constraint and hw support details (Stephane Eranian) - Optimize kprobes for BPF execution (Martin KaFai Lau) - Rewrite, refactor and fix the Intel uncore PMU driver code (Thomas Gleixner) - Rewrite, refactor and fix the Intel RAPL PMU code (Thomas Gleixner) - Various fixes and smaller cleanups. There are lots of perf tooling updates as well. A few highlights: perf report/top: - Hierarchy histogram mode for 'perf top' and 'perf report', showing multiple levels, one per --sort entry: (Namhyung Kim) On a mostly idle system: # perf top --hierarchy -s comm,dso Then expand some levels and use 'P' to take a snapshot: # cat perf.hist.0 - 92.32% perf 58.20% perf 22.29% libc-2.22.so 5.97% [kernel] 4.18% libelf-0.165.so 1.69% [unknown] - 4.71% qemu-system-x86 3.10% [kernel] 1.60% qemu-system-x86_64 (deleted) + 2.97% swapper # - Add 'L' hotkey to dynamicly set the percent threshold for histogram entries and callchains, i.e. dynamicly do what the --percent-limit command line option to 'top' and 'report' does. (Namhyung Kim) perf mem: - Allow specifying events via -e in 'perf mem record', also listing what events can be specified via 'perf mem record -e list' (Jiri Olsa) perf record: - Add 'perf record' --all-user/--all-kernel options, so that one can tell that all the events in the command line should be restricted to the user or kernel levels (Jiri Olsa), i.e.: perf record -e cycles:u,instructions:u is equivalent to: perf record --all-user -e cycles,instructions - Make 'perf record' collect CPU cache info in the perf.data file header: $ perf record usleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.017 MB perf.data (7 samples) ] $ perf report --header-only -I | tail -10 | head -8 # CPU cache info: # L1 Data 32K [0-1] # L1 Instruction 32K [0-1] # L1 Data 32K [2-3] # L1 Instruction 32K [2-3] # L2 Unified 256K [0-1] # L2 Unified 256K [2-3] # L3 Unified 4096K [0-3] Will be used in 'perf c2c' and eventually in 'perf diff' to allow, for instance running the same workload in multiple machines and then when using 'diff' show the hardware difference. (Jiri Olsa) - Improved support for Java, using the JVMTI agent library to do jitdumps that then will be inserted in synthesized PERF_RECORD_MMAP2 events via 'perf inject' pointed to synthesized ELF files stored in ~/.debug and keyed with build-ids, to allow symbol resolution and even annotation with source line info, see the changeset comments to see how to use it (Stephane Eranian) perf script/trace: - Decode data_src values (e.g. perf.data files generated by 'perf mem record') in 'perf script': (Jiri Olsa) # perf script perf 693 [1] 4.088652: 1 cpu/mem-loads,ldlat=30/P: ffff88007d0b0f40 68100142 L1 hit|SNP None|TLB L1 or L2 hit|LCK No <SNIP> ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - Improve support to 'data_src', 'weight' and 'addr' fields in 'perf script' (Jiri Olsa) - Handle empty print fmts in 'perf script -s' i.e. when running python or perl scripts (Taeung Song) perf stat: - 'perf stat' now shows shadow metrics (insn per cycle, etc) in interval mode too. E.g: # perf stat -I 1000 -e instructions,cycles sleep 1 # time counts unit events 1.000215928 519,620 instructions # 0.69 insn per cycle 1.000215928 752,003 cycles <SNIP> - Port 'perf kvm stat' to PowerPC (Hemant Kumar) - Implement CSV metrics output in 'perf stat' (Andi Kleen) perf BPF support: - Support converting data from bpf events in 'perf data' (Wang Nan) - Print bpf-output events in 'perf script': (Wang Nan). # perf record -e bpf-output/no-inherit,name=evt/ -e ./test_bpf_output_3.c/map:channel.event=evt/ usleep 1000 # perf script usleep 4882 21384.532523: evt: ffffffff810e97d1 sys_nanosleep ([kernel.kallsyms]) BPF output: 0000: 52 61 69 73 65 20 61 20 Raise a 0008: 42 50 46 20 65 76 65 6e BPF even 0010: 74 21 00 00 t!.. BPF string: "Raise a BPF event!" # - Add API to set values of map entries in a BPF object, be it individual map slots or ranges (Wang Nan) - Introduce support for the 'bpf-output' event (Wang Nan) - Add glue to read perf events in a BPF program (Wang Nan) - Improve support for bpf-output events in 'perf trace' (Wang Nan) ... and tons of other changes as well - see the shortlog and git log for details!" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (342 commits) perf stat: Add --metric-only support for -A perf stat: Implement --metric-only mode perf stat: Document CSV format in manpage perf hists browser: Check sort keys before hot key actions perf hists browser: Allow thread filtering for comm sort key perf tools: Add sort__has_comm variable perf tools: Recalc total periods using top-level entries in hierarchy perf tools: Remove nr_sort_keys field perf hists browser: Cleanup hist_browser__fprintf_hierarchy_entry() perf tools: Remove hist_entry->fmt field perf tools: Fix command line filters in hierarchy mode perf tools: Add more sort entry check functions perf tools: Fix hist_entry__filter() for hierarchy perf jitdump: Build only on supported archs tools lib traceevent: Add '~' operation within arg_num_eval() perf tools: Omit unnecessary cast in perf_pmu__parse_scale perf tools: Pass perf_hpp_list all the way through setup_sort_list perf tools: Fix perf script python database export crash perf jitdump: DWARF is also needed perf bench mem: Prepare the x86-64 build for upstream memcpy_mcsafe() changes ...
2016-03-10tools lib traceevent: Add '~' operation within arg_num_eval()Steven Rostedt
When evaluating values for print flags, if the value included a '~' operator, the parsing would fail. This broke kmalloc's parsing of: __print_flags(REC->gfp_flags, "|", {(unsigned long)((((((( gfp_t)(0x400000u|0x2000000u)) | (( gfp_t)0x40u) | (( gfp_t)0x80u) | (( gfp_t)0x20000u)) | (( gfp_t)0x02u)) | (( gfp_t)0x08u)) | (( gfp_t)0x4000u) | (( gfp_t)0x10000u) | (( gfp_t)0x1000u) | (( gfp_t)0x200u)) & ~(( gfp_t)0x2000000u)) ^ | here Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Tested-by: David Ahern <dsahern@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/20160226181328.22f47129@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-03objtool: Support CROSS_COMPILEJosh Poimboeuf
When building with CONFIG_STACK_VALIDATION on a ppc64le host with an x86 cross-compiler, Stephen Rothwell saw the following objtool build errors: DESCEND objtool CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/builtin-check.o CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/special.o CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/elf.o CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/objtool.o MKDIR /home/sfr/next/x86_64_allmodconfig/tools/objtool/arch/x86/insn/ CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/libstring.o elf.c:22:23: fatal error: sys/types.h: No such file or directory compilation terminated. CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/exec-cmd.o CC /home/sfr/next/x86_64_allmodconfig/tools/objtool/help.o builtin-check.c:28:20: fatal error: string.h: No such file or directory compilation terminated. objtool.c:28:19: fatal error: stdio.h: No such file or directory compilation terminated. It fails to build because it tries to compile objtool with the cross-compiler instead of the host compiler. Ensure that it always uses the host compiler by ignoring CROSS_COMPILE. In order to do that properly, the libsubcmd.a library needs to be built in tools/objtool/ rather than tools/lib/subcmd/. The latter directory contains the cross-compiled version which is needed for perf and possibly other tools. Note that cross-compiling for x86 on a _big_ endian system would result in a bunch of false positive objtool warnings during the kernel build because it isn't endian-aware. But that's generally a rare edge case and there haven't been any reports of anybody needing that. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/55b63eefc347f1bb28573f972d8d1adbf1f1c31d.1456962210.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-03tools lib traceevent: Fix output of %llu for 64 bit values read on 32 bit ↵Steven Rostedt (Red Hat)
machines When a long value is read on 32 bit machines for 64 bit output, the parsing needs to change "%lu" into "%llu", as the value is read natively. Unfortunately, if "%llu" is already there, the code will add another "l" to it and fail to parse it properly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20160209204237.337024613@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-03-03tools lib traceevent: Set int_array fields to NULL if freeing from errorSteven Rostedt (Red Hat)
Had a bug where on error of parsing __print_array() where the fields are freed after they were allocated, but since they were not set to NULL, the freeing of the arg also tried to free the already freed fields causing a double free. Fix process_hex() while at it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20160209204237.188327674@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
