path: root/tools/objtool/warn.h
2017-06-30objtool: Implement stack validation 2.0Josh Poimboeuf
This is a major rewrite of objtool. Instead of only tracking frame pointer changes, it now tracks all stack-related operations, including all register saves/restores. In addition to making stack validation more robust, this also paves the way for undwarf generation. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/678bd94c0566c6129bcc376cddb259c4c5633004.1498659915.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-29objtool: Add tool to perform compile-time stack metadata validationJosh Poimboeuf
This adds a host tool named objtool which has a "check" subcommand which analyzes .o files to ensure the validity of stack metadata. It enforces a set of rules on asm code and C inline assembly code so that stack traces can be reliable. For each function, it recursively follows all possible code paths and validates the correct frame pointer state at each instruction. It also follows code paths involving kernel special sections, like .altinstructions, __jump_table, and __ex_table, which can add alternative execution paths to a given instruction (or set of instructions). Similarly, it knows how to follow switch statements, for which gcc sometimes uses jump tables. Here are some of the benefits of validating stack metadata: a) More reliable stack traces for frame pointer enabled kernels Frame pointers are used for debugging purposes. They allow runtime code and debug tools to be able to walk the stack to determine the chain of function call sites that led to the currently executing code. For some architectures, frame pointers are enabled by CONFIG_FRAME_POINTER. For some other architectures they may be required by the ABI (sometimes referred to as "backchain pointers"). For C code, gcc automatically generates instructions for setting up frame pointers when the -fno-omit-frame-pointer option is used. But for asm code, the frame setup instructions have to be written by hand, which most people don't do. So the end result is that CONFIG_FRAME_POINTER is honored for C code but not for most asm code. For stack traces based on frame pointers to be reliable, all functions which call other functions must first create a stack frame and update the frame pointer. If a first function doesn't properly create a stack frame before calling a second function, the *caller* of the first function will be skipped on the stack trace. For example, consider the following example backtrace with frame pointers enabled: [<ffffffff81812584>] dump_stack+0x4b/0x63 [<ffffffff812d6dc2>] cmdline_proc_show+0x12/0x30 [<ffffffff8127f568>] seq_read+0x108/0x3e0 [<ffffffff812cce62>] proc_reg_read+0x42/0x70 [<ffffffff81256197>] __vfs_read+0x37/0x100 [<ffffffff81256b16>] vfs_read+0x86/0x130 [<ffffffff81257898>] SyS_read+0x58/0xd0 [<ffffffff8181c1f2>] entry_SYSCALL_64_fastpath+0x12/0x76 It correctly shows that the caller of cmdline_proc_show() is seq_read(). If we remove the frame pointer logic from cmdline_proc_show() by replacing the frame pointer related instructions with nops, here's what it looks like instead: [<ffffffff81812584>] dump_stack+0x4b/0x63 [<ffffffff812d6dc2>] cmdline_proc_show+0x12/0x30 [<ffffffff812cce62>] proc_reg_read+0x42/0x70 [<ffffffff81256197>] __vfs_read+0x37/0x100 [<ffffffff81256b16>] vfs_read+0x86/0x130 [<ffffffff81257898>] SyS_read+0x58/0xd0 [<ffffffff8181c1f2>] entry_SYSCALL_64_fastpath+0x12/0x76 Notice that cmdline_proc_show()'s caller, seq_read(), has been skipped. Instead the stack trace seems to show that cmdline_proc_show() was called by proc_reg_read(). The benefit of "objtool check" here is that because it ensures that *all* functions honor CONFIG_FRAME_POINTER, no functions will ever[*] be skipped on a stack trace. [*] unless an interrupt or exception has occurred at the very beginning of a function before the stack frame has been created, or at the very end of the function after the stack frame has been destroyed. This is an inherent limitation of frame pointers. b) 100% reliable stack traces for DWARF enabled kernels This is not yet implemented. For more details about what is planned, see tools/objtool/Documentation/stack-validation.txt. c) Higher live patching compatibility rate This is not yet implemented. For more details about what is planned, see tools/objtool/Documentation/stack-validation.txt. To achieve the validation, "objtool check" enforces the following rules: 1. Each callable function must be annotated as such with the ELF function type. In asm code, this is typically done using the ENTRY/ENDPROC macros. If objtool finds a return instruction outside of a function, it flags an error since that usually indicates callable code which should be annotated accordingly. This rule is needed so that objtool can properly identify each callable function in order to analyze its stack metadata. 2. Conversely, each section of code which is *not* callable should *not* be annotated as an ELF function. The ENDPROC macro shouldn't be used in this case. This rule is needed so that objtool can ignore non-callable code. Such code doesn't have to follow any of the other rules. 3. Each callable function which calls another function must have the correct frame pointer logic, if required by CONFIG_FRAME_POINTER or the architecture's back chain rules. This can by done in asm code with the FRAME_BEGIN/FRAME_END macros. This rule ensures that frame pointer based stack traces will work as designed. If function A doesn't create a stack frame before calling function B, the _caller_ of function A will be skipped on the stack trace. 4. Dynamic jumps and jumps to undefined symbols are only allowed if: a) the jump is part of a switch statement; or b) the jump matches sibling call semantics and the frame pointer has the same value it had on function entry. This rule is needed so that objtool can reliably analyze all of a function's code paths. If a function jumps to code in another file, and it's not a sibling call, objtool has no way to follow the jump because it only analyzes a single file at a time. 5. A callable function may not execute kernel entry/exit instructions. The only code which needs such instructions is kernel entry code, which shouldn't be be in callable functions anyway. This rule is just a sanity check to ensure that callable functions return normally. It currently only supports x86_64. I tried to make the code generic so that support for other architectures can hopefully be plugged in relatively easily. On my Lenovo laptop with a i7-4810MQ 4-core/8-thread CPU, building the kernel with objtool checking every .o file adds about three seconds of total build time. It hasn't been optimized for performance yet, so there are probably some opportunities for better build performance. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at> Cc: Borislav Petkov <bp@alien8.de> Cc: Chris J Arges <chris.j.arges@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/f3efb173de43bd067b060de73f856567c0fa1174.1456719558.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
