[ Upstream commit b980be189c9badba50634671e2303e92bf28e35a ]
Add to the opcode map the following instructions:
cldemote
tpause
umonitor
umwait
movdiri
movdir64b
enqcmd
enqcmds
encls
enclu
enclv
pconfig
wbnoinvd
For information about the instructions, refer Intel SDM May 2019
(325462-070US) and Intel Architecture Instruction Set Extensions
May 2019 (319433-037).
The instruction decoding can be tested using the perf tools'
"x86 instruction decoder - new instructions" test as folllows:
$ perf test -v "new " 2>&1 | grep -i cldemote
Decoded ok: 0f 1c 00 cldemote (%eax)
Decoded ok: 0f 1c 05 78 56 34 12 cldemote 0x12345678
Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%eax,%ecx,8)
Decoded ok: 0f 1c 00 cldemote (%rax)
Decoded ok: 41 0f 1c 00 cldemote (%r8)
Decoded ok: 0f 1c 04 25 78 56 34 12 cldemote 0x12345678
Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%rax,%rcx,8)
Decoded ok: 41 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%r8,%rcx,8)
$ perf test -v "new " 2>&1 | grep -i tpause
Decoded ok: 66 0f ae f3 tpause %ebx
Decoded ok: 66 41 0f ae f0 tpause %r8d
$ perf test -v "new " 2>&1 | grep -i umonitor
Decoded ok: 67 f3 0f ae f0 umonitor %ax
Decoded ok: f3 0f ae f0 umonitor %eax
Decoded ok: 67 f3 0f ae f0 umonitor %eax
Decoded ok: f3 0f ae f0 umonitor %rax
Decoded ok: 67 f3 41 0f ae f0 umonitor %r8d
$ perf test -v "new " 2>&1 | grep -i umwait
Decoded ok: f2 0f ae f0 umwait %eax
Decoded ok: f2 41 0f ae f0 umwait %r8d
$ perf test -v "new " 2>&1 | grep -i movdiri
Decoded ok: 0f 38 f9 03 movdiri %eax,(%ebx)
Decoded ok: 0f 38 f9 88 78 56 34 12 movdiri %ecx,0x12345678(%eax)
Decoded ok: 48 0f 38 f9 03 movdiri %rax,(%rbx)
Decoded ok: 48 0f 38 f9 88 78 56 34 12 movdiri %rcx,0x12345678(%rax)
$ perf test -v "new " 2>&1 | grep -i movdir64b
Decoded ok: 66 0f 38 f8 18 movdir64b (%eax),%ebx
Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx
Decoded ok: 67 66 0f 38 f8 1c movdir64b (%si),%bx
Decoded ok: 67 66 0f 38 f8 8c 34 12 movdir64b 0x1234(%si),%cx
Decoded ok: 66 0f 38 f8 18 movdir64b (%rax),%rbx
Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%rax),%rcx
Decoded ok: 67 66 0f 38 f8 18 movdir64b (%eax),%ebx
Decoded ok: 67 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx
$ perf test -v "new " 2>&1 | grep -i enqcmd
Decoded ok: f2 0f 38 f8 18 enqcmd (%eax),%ebx
Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx
Decoded ok: 67 f2 0f 38 f8 1c enqcmd (%si),%bx
Decoded ok: 67 f2 0f 38 f8 8c 34 12 enqcmd 0x1234(%si),%cx
Decoded ok: f3 0f 38 f8 18 enqcmds (%eax),%ebx
Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx
Decoded ok: 67 f3 0f 38 f8 1c enqcmds (%si),%bx
Decoded ok: 67 f3 0f 38 f8 8c 34 12 enqcmds 0x1234(%si),%cx
Decoded ok: f2 0f 38 f8 18 enqcmd (%rax),%rbx
Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%rax),%rcx
Decoded ok: 67 f2 0f 38 f8 18 enqcmd (%eax),%ebx
Decoded ok: 67 f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx
Decoded ok: f3 0f 38 f8 18 enqcmds (%rax),%rbx
Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%rax),%rcx
Decoded ok: 67 f3 0f 38 f8 18 enqcmds (%eax),%ebx
Decoded ok: 67 f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx
$ perf test -v "new " 2>&1 | grep -i enqcmds
$ perf test -v "new " 2>&1 | grep -i encls
Decoded ok: 0f 01 cf encls
$ perf test -v "new " 2>&1 | grep -i enclu
Decoded ok: 0f 01 d7 enclu
$ perf test -v "new " 2>&1 | grep -i enclv
Decoded ok: 0f 01 c0 enclv
$ perf test -v "new " 2>&1 | grep -i pconfig
Decoded ok: 0f 01 c5 pconfig
$ perf test -v "new " 2>&1 | grep -i wbnoinvd
Decoded ok: f3 0f 09 wbnoinvd
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: x86@kernel.org
Link: http://lore.kernel.org/lkml/20191115135447.6519-3-adrian.hunter@intel.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 700c1018b86d0d4b3f1f2d459708c0cdf42b521d upstream.
gawk 5.0.1 generates the following regexp warnings:
GEN /home/sasha/torvalds/tools/objtool/arch/x86/lib/inat-tables.c
awk: ../arch/x86/tools/gen-insn-attr-x86.awk:260: warning: regexp escape sequence `\:' is not a known regexp operator
awk: ../arch/x86/tools/gen-insn-attr-x86.awk:350: (FILENAME=../arch/x86/lib/x86-opcode-map.txt FNR=41) warning: regexp escape sequence `\&' is not a known regexp operator
Ealier versions of gawk are not known to generate these warnings. The
gawk manual referenced below does not list characters ':' and '&' as
needing escaping, so 'unescape' them. See
https://www.gnu.org/software/gawk/manual/html_node/Escape-Sequences.html
for more info.
Running diff on the output generated by the script before and after
applying the patch reported no differences.
[ bp: Massage commit message. ]
[ Caught the respective tools header discrepancy. ]
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/20190924044659.3785-1-alexander.kapshuk@gmail.com
commit f73b3cc39c84220e6dccd463b5c8279b03514646 upstream.
If the build user has the CFLAGS variable set in their environment,
objtool blindly appends to it, which can cause unexpected behavior.
Clobber CFLAGS to ensure consistent objtool compilation behavior.
Reported-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/83a276df209962e6058fcb6c615eef9d401c21bc.1567121311.git.jpoimboe@redhat.com
CC: Nathan Chancellor <natechancellor@gmail.com>
commit 056d28d135bca0b1d0908990338e00e9dadaf057 upstream.
If it is not in the default location, compilation fails at several points.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/91a25e992566a7968fedc89ec80e7f4c83ad0548.1553622500.git.jpoimboe@redhat.com
commit 4fa5ecda2bf96be7464eb406df8aba9d89260227 upstream.
This fixes the following warning seen on GCC 7.3:
arch/x86/kernel/dumpstack.o: warning: objtool: oops_end() falls through to next function show_regs()
Link: https://lkml.kernel.org/r/3418ebf5a5a9f6ed7e80954c741c0b904b67b5dc.1554398240.git.jpoimboe@redhat.com
commit 684fb246578b9e81fc7b4ca5c71eae22edb650b2 upstream.
machine_real_restart() is annotated as '__noreturn", so add it to the
objtool noreturn list. This fixes the following warning with clang and
CONFIG_CC_OPTIMIZE_FOR_SIZE=y:
arch/x86/kernel/reboot.o: warning: objtool: native_machine_emergency_restart() falls through to next function machine_power_off()
Reported-by: Matthias Kaehlcke <mka@chromium.org>
Tested-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Link: https://lkml.kernel.org/r/791712792aa4431bdd55bf1beb33a169ddf3b4a2.1529423255.git.jpoimboe@redhat.com
commit bcb6fb5da77c2a228adf07cc9cb1a0c2aa2001c6 upstream.
Starting with GCC 8, a lot of unlikely code was moved out of line to
"cold" subfunctions in .text.unlikely.
For example, the unlikely bits of:
irq_do_set_affinity()
are moved out to the following subfunction:
irq_do_set_affinity.cold.49()
Starting with GCC 9, the numbered suffix has been removed. So in the
above example, the cold subfunction is instead:
irq_do_set_affinity.cold()
Tweak the objtool subfunction detection logic so that it detects both
GCC 8 and GCC 9 naming schemes.
Reported-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/015e9544b1f188d36a7f02fa31e9e95629aa5f50.1541040800.git.jpoimboe@redhat.com
commit 4a60aa05a0634241ce17f957bf9fb5ac1eed6576 upstream.
Add support for processing switch jump tables in objects with multiple
.rodata sections, such as those created by '-ffunction-sections' and
'-fdata-sections'. Currently, objtool always looks in .rodata for jump
table information, which results in many "sibling call from callable
instruction with modified stack frame" warnings with objects compiled
using those flags.
The fix is comprised of three parts:
1. Flagging all .rodata sections when importing ELF information for
easier checking later.
2. Keeping a reference to the section each relocation is from in order
to get the list_head for the other relocations in that section.
3. Finding jump tables by following relocations to .rodata sections,
rather than always referencing a single global .rodata section.
The patch has been tested without data sections enabled and no
differences in the resulting orc unwind information were seen.
Note that as objtool adds terminators to end of each .text section the
unwind information generated between a function+data sections build and
a normal build aren't directly comparable. Manual inspection suggests
that objtool is now generating the correct information, or at least
making more of an effort to do so than it did previously.
Signed-off-by: Allan Xavier <allan.x.xavier@oracle.com>
Link: https://lkml.kernel.org/r/099bdc375195c490dda04db777ee0b95d566ded1.1536325914.git.jpoimboe@redhat.com
[ Upstream commit e6da9567959e164f82bc81967e0d5b10dee870b4 ]
The ignore flag is set on fake jumps in order to keep
add_jump_destinations() from setting their jump_dest, since it already
got set when the fake jump was created.
But using the ignore flag is a bit of a hack. It's normally used to
skip validation of an instruction, which doesn't really make sense for
fake jumps.
Also, after the next patch, using the ignore flag for fake jumps can
trigger a false "why am I validating an ignored function?" warning.
Instead just add an explicit check in add_jump_destinations() to skip
fake jumps.
Link: http://lkml.kernel.org/r/71abc072ff48b2feccc197723a9c52859476c068.1557766718.git.jpoimboe@redhat.com
commit 8ea58f1e8b11cca3087b294779bf5959bf89cc10 upstream.
Currently, this Makefile hardcodes GNU ar, meaning that if it is not
available, there is no way to supply a different one and the build will
fail.
$ make AR=llvm-ar CC=clang LD=ld.lld HOSTAR=llvm-ar HOSTCC=clang \
HOSTLD=ld.lld HOSTLDFLAGS=-fuse-ld=lld defconfig modules_prepare
AR /out/tools/objtool/libsubcmd.a
/bin/sh: 1: ar: not found
Follow the logic of HOST{CC,LD} and allow the user to specify a
different ar tool via HOSTAR (which is used elsewhere in other
tools/ Makefiles).
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/80822a9353926c38fd7a152991c6292491a9d0e8.1558028966.git.jpoimboe@redhat.com
Link: https://github.com/ClangBuiltLinux/linux/issues/481
commit e6f393bc939d566ce3def71232d8013de9aaadde upstream.
When a function falls through to the next function due to a compiler
bug, objtool prints some obscure warnings. For example:
drivers/regulator/core.o: warning: objtool: regulator_count_voltages()+0x95: return with modified stack frame
drivers/regulator/core.o: warning: objtool: regulator_count_voltages()+0x0: stack state mismatch: cfa1=7+32 cfa2=7+8
Instead it should be printing:
drivers/regulator/core.o: warning: objtool: regulator_supply_is_couple() falls through to next function regulator_count_voltages()
This used to work, but was broken by the following commit:
13810435b9a7 ("objtool: Support GCC 8's cold subfunctions")
The padding nops at the end of a function aren't actually part of the
function, as defined by the symbol table. So the 'func' variable in
validate_branch() is getting cleared to NULL when a padding nop is
encountered, breaking the fallthrough detection.
If the current instruction doesn't have a function associated with it,
just consider it to be part of the previously detected function by not
overwriting the previous value of 'func'.
Fixes: 13810435b9a7 ("objtool: Support GCC 8's cold subfunctions")
Link: http://lkml.kernel.org/r/546d143820cd08a46624ae8440d093dd6c902cae.1557766718.git.jpoimboe@redhat.com
commit 0c671812f152b628bd87c0af49da032cc2a2c319 upstream.
Objtool uses over 512k of stack, thanks to the hash table embedded in
the objtool_file struct. This causes an unnecessarily large stack
allocation and breaks users with low stack limits.
Move the struct off the stack.
Fixes: 042ba73fe7eb ("objtool: Add several performance improvements")
Reported-by: Vassili Karpov <moosotc@gmail.com>
Link: https://lkml.kernel.org/r/df92dcbc4b84b02ffa252f46876df125fb56e2d7.1552954176.git.jpoimboe@redhat.com
[ Upstream commit 22566c1603030f0a036ad564634b064ad1a55db2 ]
Because find_symbol_by_name() traverses the same lists as
read_symbols(), changing sym->name in place without copying it affects
the result of find_symbol_by_name(). In the case where a ".cold"
function precedes its parent in sec->symbol_list, it can result in a
function being considered a parent of itself. This leads to function
length being set to 0 and other consequent side-effects including a
segfault in add_switch_table(). The effects of this bug are only
visible when building with -ffunction-sections in KCFLAGS.
Fix by copying the search string instead of modifying it in place.
Signed-off-by: Artem Savkov <asavkov@redhat.com>
Link: http://lkml.kernel.org/r/910abd6b5a4945130fd44f787c24e07b9e07c8da.1542736240.git.jpoimboe@redhat.com
[ Upstream commit 0b9301fb632f7111a3293a30cc5b20f1b82ed08d ]
If read_symbols() fails during second list traversal (the one dealing
with ".cold" subfunctions) it frees the symbol, but never deletes it
from the list/hash_table resulting in symbol being freed again in
elf_close(). Fix it by just returning an error, leaving cleanup to
elf_close().
Link: http://lkml.kernel.org/r/beac5a9b7da9e8be90223459dcbe07766ae437dd.1542736240.git.jpoimboe@redhat.com
[ Upstream commit 08b393d01c88aff27347ed2b1b354eb4db2f1532 ]
Since the following commit:
cd77849a69cf ("objtool: Fix GCC 8 cold subfunction detection for aliased functions")
... if the kernel is built with EXTRA_CFLAGS='-fno-reorder-functions',
objtool can get stuck in an infinite loop.
That flag causes the new GCC 8 cold subfunctions to be placed in .text
instead of .text.unlikely. But it also has an unfortunate quirk: in the
symbol table, the subfunction (e.g., nmi_panic.cold.7) is nested inside
the parent (nmi_panic).
That function overlap confuses objtool, and causes it to get into an
infinite loop in next_insn_same_func(). Here's Allan's description of
the loop:
"Objtool iterates through the instructions in nmi_panic using
next_insn_same_func. Once it reaches the end of nmi_panic at 0x534 it
jumps to 0x528 as that's the start of nmi_panic.cold.7. However, since
the instructions starting at 0x528 are still associated with nmi_panic
objtool will get stuck in a loop, continually jumping back to 0x528
after reaching 0x534."
Fix it by shortening the length of the parent function so that the
functions no longer overlap.
Reported-and-analyzed-by: Allan Xavier <allan.x.xavier@oracle.com>
Cc: Allan Xavier <allan.x.xavier@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/9e704c52bee651129b036be14feda317ae5606ae.1530136978.git.jpoimboe@redhat.com
commit 9564a8cf422d7b58f6e857e3546d346fa970191e upstream.
I tried building using a freshly built Make (4.2.1-69-g8a731d1), but
already the objtool build broke with
orc_dump.c: In function ‘orc_dump’:
orc_dump.c:106:2: error: ‘elf_getshnum’ is deprecated [-Werror=deprecated-declarations]
if (elf_getshdrnum(elf, &nr_sections)) {
Turns out that with that new Make, the backslash was not removed, so cpp
didn't see a #include directive, grep found nothing, and
-DLIBELF_USE_DEPRECATED was wrongly put in CFLAGS.
Now, that new Make behaviour is documented in their NEWS file:
* WARNING: Backward-incompatibility!
Number signs (#) appearing inside a macro reference or function invocation
no longer introduce comments and should not be escaped with backslashes:
thus a call such as:
foo := $(shell echo '#')
is legal. Previously the number sign needed to be escaped, for example:
foo := $(shell echo '\#')
Now this latter will resolve to "\#". If you want to write makefiles
portable to both versions, assign the number sign to a variable:
C := \#
foo := $(shell echo '$C')
This was claimed to be fixed in 3.81, but wasn't, for some reason.
To detect this change search for 'nocomment' in the .FEATURES variable.
This also fixes up the two make-cmd instances to replace # with $(pound)
rather than with \#. There might very well be other places that need
similar fixup in preparation for whatever future Make release contains
the above change, but at least this builds an x86_64 defconfig with the
new make.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=197847
Cc: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
tools/objtool/arch/x86/include/asm/insn.h
[ Upstream commit 4fe875e4bd3cae85ae6f6eaf77f63fabe613b66e ]
The following commit:
ee6a7354a362: kprobes/x86: Prohibit probing on exception masking instructions
Modified <asm/insn.h>, adding the insn_masking_exception() function.
Sync the tooling version of the header to it, to fix this warning:
Warning: synced file at 'tools/objtool/arch/x86/include/asm/insn.h' differs from latest kernel version at 'arch/x86/include/asm/insn.h'
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Cc: Francis Deslauriers <francis.deslauriers@efficios.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Yonghong Song <yhs@fb.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: "David S . Miller" <davem@davemloft.net>
commit 0afd0d9e0e7879d666c1df2fa1bea4d8716909fe upstream.
Objtool has some crude logic for detecting static "noreturn" functions
(aka "dead ends"). This is necessary for being able to correctly follow
GCC code flow when such functions are called.
It's remotely possible for two functions to call each other via sibling
calls. If they don't have RET instructions, objtool's noreturn
detection logic goes into a recursive loop:
drivers/char/ipmi/ipmi_ssif.o: warning: objtool: return_hosed_msg()+0x0: infinite recursion (objtool bug!)
drivers/char/ipmi/ipmi_ssif.o: warning: objtool: deliver_recv_msg()+0x0: infinite recursion (objtool bug!)
Instead of reporting an error in this case, consider the functions to be
non-dead-ends.
Reported-and-tested-by: Randy Dunlap <rdunlap@infradead.org>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: damian <damian.tometzki@icloud.com>
Link: http://lkml.kernel.org/r/7cc156408c5781a1f62085d352ced1fe39fe2f91.1525923412.git.jpoimboe@redhat.com
commit 7dec80ccbe310fb7e225bf21c48c672bb780ce7b upstream.
With the following commit:
fd35c88b7417 ("objtool: Support GCC 8 switch tables")
I added a "can't find switch jump table" warning, to stop covering up
silent failures if add_switch_table() can't find anything.
That warning found yet another bug in the objtool switch table detection
logic. For cases 1 and 2 (as described in the comments of
find_switch_table()), the find_symbol_containing() check doesn't adjust
the offset for RIP-relative switch jumps.
Incidentally, this bug was already fixed for case 3 with:
6f5ec2993b1f ("objtool: Detect RIP-relative switch table references")
However, that commit missed the fix for cases 1 and 2.
The different cases are now starting to look more and more alike. So
fix the bug by consolidating them into a single case, by checking the
original dynamic jump instruction in the case 3 loop.
This also simplifies the code and makes it more robust against future
switch table detection issues -- of which I'm sure there will be many...
Switch table detection has been the most fragile area of objtool, by
far. I long for the day when we'll have a GCC plugin for annotating
switch tables. Linus asked me to delay such a plugin due to the
flakiness of the plugin infrastructure in older versions of GCC, so this
rickety code is what we're stuck with for now. At least the code is now
a little simpler than it was.
Link: http://lkml.kernel.org/r/f400541613d45689086329432f3095119ffbc328.1526674218.git.jpoimboe@redhat.com
commit 6f5ec2993b1f39aed12fa6fd56e8dc2272ee8a33 upstream.
Typically a switch table can be found by detecting a .rodata access
followed an indirect jump:
1969: 4a 8b 0c e5 00 00 00 mov 0x0(,%r12,8),%rcx
1970: 00
196d: R_X86_64_32S .rodata+0x438
1971: e9 00 00 00 00 jmpq 1976 <dispc_runtime_suspend+0xb6a>
1972: R_X86_64_PC32 __x86_indirect_thunk_rcx-0x4
Randy Dunlap reported a case (seen with GCC 4.8) where the .rodata
access uses RIP-relative addressing:
19bd: 48 8b 3d 00 00 00 00 mov 0x0(%rip),%rdi # 19c4 <dispc_runtime_suspend+0xbb8>
19c0: R_X86_64_PC32 .rodata+0x45c
19c4: e9 00 00 00 00 jmpq 19c9 <dispc_runtime_suspend+0xbbd>
19c5: R_X86_64_PC32 __x86_indirect_thunk_rdi-0x4
In this case the relocation addend needs to be adjusted accordingly in
order to find the location of the switch table.
The fix is for case 3 (as described in the comments), but also make the
existing case 1 & 2 checks more precise by only adjusting the addend for
R_X86_64_PC32 relocations.
This fixes the following warnings:
drivers/video/fbdev/omap2/omapfb/dss/dispc.o: warning: objtool: dispc_runtime_suspend()+0xbb8: sibling call from callable instruction with modified stack frame
drivers/video/fbdev/omap2/omapfb/dss/dispc.o: warning: objtool: dispc_runtime_resume()+0xcc5: sibling call from callable instruction with modified stack frame
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Link: http://lkml.kernel.org/r/b6098294fd67afb69af8c47c9883d7a68bf0f8ea.1526305958.git.jpoimboe@redhat.com
commit fd35c88b74170d9335530d9abf271d5d73eb5401 upstream.
With GCC 8, some issues were found with the objtool switch table
detection.
1) In the .rodata section, immediately after the switch table, there can
be another object which contains a pointer to the function which had
the switch statement. In this case objtool wrongly considers the
function pointer to be part of the switch table. Fix it by:
a) making sure there are no pointers to the beginning of the
function; and
b) making sure there are no gaps in the switch table.
Only the former was needed, the latter adds additional protection for
future optimizations.
2) In find_switch_table(), case 1 and case 2 are missing the check to
ensure that the .rodata switch table data is anonymous, i.e. that it
isn't already associated with an ELF symbol. Fix it by adding the
same find_symbol_containing() check which is used for case 3.
This fixes the following warnings with GCC 8:
drivers/block/virtio_blk.o: warning: objtool: virtio_queue_rq()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+72
net/ipv6/icmp.o: warning: objtool: icmpv6_rcv()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+64
drivers/usb/core/quirks.o: warning: objtool: quirks_param_set()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+48
drivers/mtd/nand/raw/nand_hynix.o: warning: objtool: hynix_nand_decode_id()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+24
drivers/mtd/nand/raw/nand_samsung.o: warning: objtool: samsung_nand_decode_id()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+32
drivers/gpu/drm/nouveau/nvkm/subdev/top/gk104.o: warning: objtool: gk104_top_oneinit()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+64
Link: http://lkml.kernel.org/r/20180510224849.xwi34d6tzheb5wgw@treble
commit 13810435b9a7014fb92eb715f77da488f3b65b99 upstream.
GCC 8 moves a lot of unlikely code out of line to "cold" subfunctions in
.text.unlikely. Properly detect the new subfunctions and treat them as
extensions of the original functions.
This fixes a bunch of warnings like:
kernel/cgroup/cgroup.o: warning: objtool: parse_cgroup_root_flags()+0x33: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: cgroup_addrm_files()+0x290: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: cgroup_apply_control_enable()+0x25b: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: rebind_subsystems()+0x325: sibling call from callable instruction with modified stack frame
Reported-and-tested-by: damian <damian.tometzki@icloud.com>
Link: http://lkml.kernel.org/r/0965e7fcfc5f31a276f0c7f298ff770c19b68706.1525923412.git.jpoimboe@redhat.com
commit 3c1f05835cbf9fdfe60b81c718d82ceb94b6c55e upstream.
Since the ORC unwinder was made the default on x86_64, Clang-built
defconfig kernels have triggered some new objtool warnings:
drivers/gpu/drm/i915/i915_gpu_error.o: warning: objtool: i915_error_printf()+0x6c: return with modified stack frame
drivers/gpu/drm/i915/intel_display.o: warning: objtool: pipe_config_err()+0xa6: return with modified stack frame
The problem is that objtool has never seen clang-built binaries before.
Shockingly enough, objtool is apparently able to follow the code flow
mostly fine, except for one instruction sequence. Instead of a LEAVE
instruction, clang restores RSP and RBP the long way:
67c: 48 89 ec mov %rbp,%rsp
67f: 5d pop %rbp
Teach objtool about this new code sequence.
Reported-and-test-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Matthias Kaehlcke <mka@chromium.org>
Link: http://lkml.kernel.org/r/fce88ce81c356eedcae7f00ed349cfaddb3363cc.1521741586.git.jpoimboe@redhat.com
commit 63474dc4ac7ed3848a4786b9592dd061901f606d upstream.
Fix the objtool build when cross-compiling a 64-bit kernel on a 32-bit
host. This also simplifies read_retpoline_hints() a bit and makes its
implementation similar to most of the other annotation reading
functions.
Reported-by: Sven Joachim <svenjoac@gmx.de>
Fixes: b5bc2231b8ad ("objtool: Add retpoline validation")
Link: http://lkml.kernel.org/r/2ca46c636c23aa9c9d57d53c75de4ee3ddf7a7df.1520380691.git.jpoimboe@redhat.com
commit 1402fd8ed7e5bda1b3e7613b70780b0db392d1e6 upstream.
Continue the switch table detection whack-a-mole. Add a check to
distinguish KASAN data reads from switch data reads. The switch jump
tables in .rodata have relocations associated with them.
This fixes the following warning:
crypto/asymmetric_keys/x509_cert_parser.o: warning: objtool: x509_note_pkey_algo()+0xa4: sibling call from callable instruction with modified stack frame
Tested-by: Arnd Bergmann <arnd@arndb.de>
Link: https://lkml.kernel.org/r/d7c8853022ad47d158cb81e953a40469fc08a95e.1519784382.git.jpoimboe@redhat.com
commit ca41b97ed9124fd62323a162de5852f6e28f94b8 upstream.
David allowed retpolines in .init.text, except for modules, which will
trip up objtool retpoline validation, fix that.
Requested-by: David Woodhouse <dwmw2@infradead.org>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
commit b5bc2231b8ad4387c9641f235ca0ad8cd300b6df upstream.
David requested a objtool validation pass for CONFIG_RETPOLINE=y enabled
builds, where it validates no unannotated indirect jumps or calls are
left.
Add an additional .discard.retpoline_safe section to allow annotating
the few indirect sites that are required and safe.
Reviewed-by: David Woodhouse <dwmw@amazon.co.uk>
commit 43a4525f80534530077683f6472d8971646b0ace upstream.
Use the existing global variables instead of passing them around and
creating duplicate global variables.
commit fe24e27128252c230a34a6c628da2bf1676781ea upstream.
Peter Zijlstra's patch for converting WARN() to use UD2 triggered a
bunch of false "unreachable instruction" warnings, which then triggered
a seg fault in ignore_unreachable_insn().
The seg fault happened when it tried to dereference a NULL 'insn->func'
pointer. Thanks to static_cpu_has(), some functions can jump to a
non-function area in the .altinstr_aux section. That breaks
ignore_unreachable_insn()'s assumption that it's always inside the
original function.
Make sure ignore_unreachable_insn() only follows jumps within the
current function.
Reported-by: Borislav Petkov <bp@alien8.de>
Cc: kbuild test robot <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/bace77a60d5af9b45eddb8f8fb9c776c8de657ef.1518130694.git.jpoimboe@redhat.com
commit 99ce7962d52d1948ad6f2785e308d48e76e0a6ef upstream.
Linus reported that GCC-7.3 generated a switch-table construct that
confused objtool. It turns out that, in particular due to KASAN, it is
possible to have unrelated .rodata usage in between the .rodata setup
for the switch-table and the following indirect jump.
The simple linear reverse search from the indirect jump would hit upon
the KASAN .rodata usage first and fail to find a switch_table,
resulting in a spurious 'sibling call with modified stack frame'
warning.
Fix this by creating a 'jump-stack' which we can 'unwind' during
reversal, thereby skipping over much of the in-between code.
This is not fool proof by any means, but is sufficient to make the
known cases work. Future work would be to construct more comprehensive
flow analysis code.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/20180208130232.GF25235@hirez.programming.kicks-ass.net
commit 830c1e3d16b2c1733cd1ec9c8f4d47a398ae31bc
With the following fix:
2a0098d70640 ("objtool: Fix seg fault with gold linker")
... a seg fault was avoided, but the original seg fault condition in
objtool wasn't fixed. Replace the seg fault with an error message.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Cc: Juergen Gross <jgross@suse.com>
Link: http://lkml.kernel.org/r/dc4585a70d6b975c99fc51d1957ccdde7bd52f3a.1517284349.git.jpoimboe@redhat.com
commit 17bc33914bcc98ba3c6b426fd1c49587a25c0597
Now that the previous patch gave objtool the ability to read retpoline
alternatives, it shows a new warning:
arch/x86/entry/entry_64.o: warning: objtool: .entry_trampoline: don't know how to handle alternatives at end of section
This is due to the JMP_NOSPEC in entry_SYSCALL_64_trampoline().
Previously, objtool ignored this situation because it wasn't needed, and
it would have required a bit of extra code. Now that this case exists,
add proper support for it.
Link: http://lkml.kernel.org/r/2a30a3c2158af47d891a76e69bb1ef347e0443fd.1517284349.git.jpoimboe@redhat.com
commit a845c7cf4b4cb5e9e3b2823867892b27646f3a98
Currently objtool requires all retpolines to be:
a) patched in with alternatives; and
b) annotated with ANNOTATE_NOSPEC_ALTERNATIVE.
If you forget to do both of the above, objtool segfaults trying to
dereference a NULL 'insn->call_dest' pointer.
Avoid that situation and print a more helpful error message:
quirks.o: warning: objtool: efi_delete_dummy_variable()+0x99: unsupported intra-function call
quirks.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
Future improvements can be made to make objtool smarter with respect to
retpolines, but this is a good incremental improvement for now.
Reported-and-tested-by: Guenter Roeck <linux@roeck-us.net>
Link: http://lkml.kernel.org/r/819e50b6d9c2e1a22e34c1a636c0b2057cc8c6e5.1517284349.git.jpoimboe@redhat.com
commit 385d11b152c4eb638eeb769edcb3249533bb9a00 upstream.
If a nonexistent file is supplied to objtool, it complains with a
non-helpful error:
open: No such file or directory
Improve it to:
objtool: Can't open 'foo': No such file or directory
Reported-by: Markus <M4rkusXXL@web.de>
Link: http://lkml.kernel.org/r/406a3d00a21225eee2819844048e17f68523ccf6.1516025651.git.jpoimboe@redhat.com
commit d89e426499cf36b96161bd32970d6783f1fbcb0e upstream.
Fix a seg fault when no parameter is provided to 'objtool orc'.
Signed-off-by: Simon Ser <contact@emersion.fr>
Link: http://lkml.kernel.org/r/9172803ec7ebb72535bcd0b7f966ae96d515968e.1514666459.git.jpoimboe@redhat.com
commit e7e83dd3ff1dd2f9e60213f6eedc7e5b08192062 upstream.
Fix the following Clang enum conversion warning:
arch/x86/decode.c:141:20: error: implicit conversion from enumeration
type 'enum op_src_type' to different enumeration
type 'enum op_dest_type' [-Werror,-Wenum-conversion]
op->dest.type = OP_SRC_REG;
It just happened to work before because OP_SRC_REG and OP_DEST_REG have
the same value.
Signed-off-by: Lukas Bulwahn <lukas.bulwahn@gmail.com>
Reviewed-by: Nicholas Mc Guire <der.herr@hofr.at>
Reviewed-by: Nick Desaulniers <nick.desaulniers@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Fixes: baa41469a7b9 ("objtool: Implement stack validation 2.0")
Link: http://lkml.kernel.org/r/b4156c5738bae781c392e7a3691aed4514ebbdf2.1514323568.git.jpoimboe@redhat.com
commit ce90aaf5cde4ce057b297bb6c955caf16ef00ee6 upstream.
Fix a seg fault which happens when an input file provided to 'objtool
orc generate' doesn't have a '.shstrtab' section (for instance, object
files produced by clang don't have this section).
Link: http://lkml.kernel.org/r/c0f2231683e9bed40fac1f13ce2c33b8389854bc.1514666459.git.jpoimboe@redhat.com
commit 0f908ccbeca99ddf0ad60afa710e72aded4a5ea7 upstream.
patch(1) loses the x bit. So if a user follows our patching
instructions in Documentation/admin-guide/README.rst, their kernel will
not compile.
Fixes: 3bd51c5a371de ("objtool: Move kernel headers/code sync check to a script")
Reported-by: Nicolas Bock <nicolasbock@gentoo.org>
Reported-by Joakim Tjernlund <Joakim.Tjernlund@infinera.com>
Cc: Holger Hoffstätte <holger@applied-asynchrony.com>
commit 258c76059cece01bebae098e81bacb1af2edad17 upstream.
Getting objtool to understand retpolines is going to be a bit of a
challenge. For now, take advantage of the fact that retpolines are
patched in with alternatives. Just read the original (sane)
non-alternative instruction, and ignore the patched-in retpoline.
This allows objtool to understand the control flow *around* the
retpoline, even if it can't yet follow what's inside. This means the
ORC unwinder will fail to unwind from inside a retpoline, but will work
fine otherwise.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: gnomes@lxorguk.ukuu.org.uk
Cc: thomas.lendacky@amd.com
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Kees Cook <keescook@google.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org>
Cc: Paul Turner <pjt@google.com>
Link: https://lkml.kernel.org/r/1515707194-20531-3-git-send-email-dwmw@amazon.co.uk
commit 39b735332cb8b33a27c28592d969e4016c86c3ea upstream.
A direct jump to a retpoline thunk is really an indirect jump in
disguise. Change the objtool instruction type accordingly.
Objtool needs to know where indirect branches are so it can detect
switch statement jump tables.
This fixes a bunch of warnings with CONFIG_RETPOLINE like:
arch/x86/events/intel/uncore_nhmex.o: warning: objtool: nhmex_rbox_msr_enable_event()+0x44: sibling call from callable instruction with modified stack frame
kernel/signal.o: warning: objtool: copy_siginfo_to_user()+0x91: sibling call from callable instruction with modified stack frame
Link: https://lkml.kernel.org/r/1515707194-20531-2-git-send-email-dwmw@amazon.co.uk
commit f5b5fab1780c98b74526dbac527574bd02dc16f8 upstream
Update x86-opcode-map.txt based on the October 2017 Intel SDM publication.
Fix INVPID to INVVPID.
Add UD0 and UD1 instruction opcodes.
Also sync the objtool and perf tooling copies of this file.
Cc: Masami Hiramatsu <masami.hiramatsu@gmail.com>
Link: http://lkml.kernel.org/r/aac062d7-c0f6-96e3-5c92-ed299e2bd3da@infradead.org
commit 14c47b54b0d9389e3ca0718e805cdd90c5a4303a upstream.
The new ORC unwinder breaks the build of a 64-bit kernel on a 32-bit
host. Building the kernel on a i386 or x32 host fails with:
orc_dump.c: In function 'orc_dump':
orc_dump.c:105:26: error: passing argument 2 of 'elf_getshdrnum' from incompatible pointer type [-Werror=incompatible-pointer-types]
In file included from /usr/local/include/gelf.h:32:0,
from elf.h:22,
from warn.h:26,
from orc_dump.c:20:
/usr/local/include/libelf.h:304:12: note: expected 'size_t * {aka unsigned int *}' but argument is of type 'long unsigned int *'
extern int elf_getshdrnum (Elf *__elf, size_t *__dst);
orc_dump.c:190:17: error: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'Elf64_Sxword {aka long long int}' [-Werror=format=]
printf("%s+%lx:", name, rela.r_addend);
%llx
Fix the build failure.
Another problem is that if the user specifies HOSTCC or HOSTLD
variables, they are ignored in the objtool makefile. Change the
Makefile to respect these variables.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Sven Joachim <svenjoac@gmx.de>
Fixes: 627fce14809b ("objtool: Add ORC unwind table generation")
Link: http://lkml.kernel.org/r/19f0e64d8e07e30a7b307cd010eb780c404fe08d.1512252895.git.jpoimboe@redhat.com
commit a356d2ae50790f49858ebed35da9e206336fafee upstream.
objtool grew this new warning:
Warning: synced file at 'tools/objtool/arch/x86/include/asm/inat.h' differs from latest kernel version at 'arch/x86/include/asm/inat.h'
which upstream header grew new INAT_SEG_* definitions.
Sync up the tooling version of the header.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 9eb719855f6c9b21eb5889d9ac2ca1c60527ad89 upstream.
Stephen Rothwell reported this cross-compilation build failure:
| In file included from orc_dump.c:19:0:
| orc.h:21:10: fatal error: asm/orc_types.h: No such file or directory
Caused by:
6a77cff819ae ("objtool: Move synced files to their original relative locations")
Use the proper arch header files location, not the host-arch location.
Bisected-by: Stephen Rothwell <sfr@canb.auug.org.au>
Cc: Linux-Next Mailing List <linux-next@vger.kernel.org>
Link: http://lkml.kernel.org/r/20171108030152.bd76eahiwjwjt3kp@treble
commit 3bd51c5a371de917e4e7401c9df006b5998579df upstream.
Replace the nasty diff checks in the objtool Makefile with a clean bash
script, and make the warnings more specific.
Heavily inspired by tools/perf/check-headers.sh.
Link: http://lkml.kernel.org/r/ab015f15ccd8c0c6008493c3c6ee3d495eaf2927.1509974346.git.jpoimboe@redhat.com
commit 6a77cff819ae3e31992bde6432c9b5720748a89b upstream.
This will enable more straightforward comparisons, and it also makes the
files 100% identical.
Link: http://lkml.kernel.org/r/407b2aaa317741f48fcf821592c0e96ab3be1890.1509974346.git.jpoimboe@redhat.com
commit 6a93bb7e4a7d6670677d5b0eb980936eb9cc5d2e upstream.
Print top-level objtool commands, along with the error on incorrect
command line usage. Objtool command line parser exit's with code 129,
for incorrect usage. Convert the cmd_usage() exit code also, to maintain
consistency across objtool.
After the patch:
$ ./objtool -j
Unknown option: -j
usage: objtool COMMAND [ARGS]
Commands:
check Perform stack metadata validation on an object file
orc Generate in-place ORC unwind tables for an object file
$ echo $?
129
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1507992474-16142-1-git-send-email-kamalesh@linux.vnet.ibm.com
commit 00d96180dc38ef872ac471c2d3e14b067cbd895d upstream.
If asm code specifies an UNWIND_HINT_EMPTY hint, don't warn if the
section ends unexpectedly. This can happen with the xen-head.S code
because the hypercall_page is "text" but it's all zeros.
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/ddafe199dd8797e40e3c2777373347eba1d65572.1505764066.git.jpoimboe@redhat.com
kernel's latest version
warning: objtool: x86 instruction decoder differs from kernel
Link: http://lkml.kernel.org/r/013315a808ccf5580abc293808827c8e2b5e1354.1509719152.git.jpoimboe@redhat.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
