path: root/tools/perf/Build
2017-07-18perf trace: Only build tools/perf/trace/beauty/ when building 'perf trace'Arnaldo Carvalho de Melo
As it calls functions in builtin-trace.c. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-bt3lhw1rvy3jzbsp2fvvegb0@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-03-31perf trace: Beautify statx syscall 'flag' and 'mask' argumentsArnaldo Carvalho de Melo
To test it, build samples/statx/test_statx, which I did as: $ make headers_install $ cc -I ~/git/linux/usr/include samples/statx/test-statx.c -o /tmp/statx And then use perf trace on it: # perf trace -e statx /tmp/statx /etc/passwd statx(/etc/passwd) = 0 results=7ff Size: 3496 Blocks: 8 IO Block: 4096 regular file Device: fd:00 Inode: 280156 Links: 1 Access: (0644/-rw-r--r--) Uid: 0 Gid: 0 Access: 2017-03-29 16:01:01.650073438-0300 Modify: 2017-03-10 16:25:14.156479354-0300 Change: 2017-03-10 16:25:14.171479328-0300 0.000 ( 0.007 ms): statx/30648 statx(dfd: CWD, filename: 0x7ef503f4, flags: SYMLINK_NOFOLLOW, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7fff7ef4eb10) = 0 # Using the test-stat.c options to change the mask: # perf trace -e statx /tmp/statx -O /etc/passwd > /dev/null 0.000 ( 0.008 ms): statx/30745 statx(dfd: CWD, filename: 0x3a0753f4, flags: SYMLINK_NOFOLLOW, mask: BTIME, buffer: 0x7ffd3a0735c0) = 0 # # perf trace -e statx /tmp/statx -A /etc/passwd > /dev/null 0.000 ( 0.010 ms): statx/30757 statx(dfd: CWD, filename: 0xa94e63f4, flags: SYMLINK_NOFOLLOW|NO_AUTOMOUNT, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7ffea94e49d0) = 0 # # trace --no-inherit -e statx /tmp/statx -F /etc/passwd > /dev/null 0.000 ( 0.011 ms): statx(dfd: CWD, filename: 0x3b02d3f3, flags: SYMLINK_NOFOLLOW|STATX_FORCE_SYNC, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7ffd3b02c850) = 0 # # trace --no-inherit -e statx /tmp/statx -F -L /etc/passwd > /dev/null 0.000 ( 0.008 ms): statx(dfd: CWD, filename: 0x15cff3f3, flags: STATX_FORCE_SYNC, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7fff15cfdda0) = 0 # # trace --no-inherit -e statx /tmp/statx -D -O /etc/passwd > /dev/null 0.000 ( 0.009 ms): statx(dfd: CWD, filename: 0xfa37f3f3, flags: SYMLINK_NOFOLLOW|STATX_DONT_SYNC, mask: BTIME, buffer: 0x7ffffa37da20) = 0 # Adding a probe to get the filename collected as well: # perf probe 'vfs_getname=getname_flags:72 pathname=result->name:string' Added new event: probe:vfs_getname (on getname_flags:72 with pathname=result->name:string) You can now use it in all perf tools, such as: perf record -e probe:vfs_getname -aR sleep 1 # trace --no-inherit -e statx /tmp/statx -D -O /etc/passwd > /dev/null 0.169 ( 0.007 ms): statx(dfd: CWD, filename: /etc/passwd, flags: SYMLINK_NOFOLLOW|STATX_DONT_SYNC, mask: BTIME, buffer: 0x7ffda9bf50f0) = 0 # Same technique could be used to collect and beautify the result put in the 'buffer' argument. Finally do a system wide 'perf trace' session looking for any use of statx, then run the test proggie with various flags: # trace -e statx 16612.967 ( 0.028 ms): statx/4562 statx(dfd: CWD, filename: /tmp/statx, flags: SYMLINK_NOFOLLOW, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7ffef195d660) = 0 33064.447 ( 0.011 ms): statx/4569 statx(dfd: CWD, filename: /tmp/statx, flags: SYMLINK_NOFOLLOW|STATX_FORCE_SYNC, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7ffc5484c790) = 0 36050.891 ( 0.023 ms): statx/4576 statx(dfd: CWD, filename: /tmp/statx, flags: SYMLINK_NOFOLLOW, mask: BTIME, buffer: 0x7ffeb18b66e0) = 0 38039.889 ( 0.023 ms): statx/4584 statx(dfd: CWD, filename: /tmp/statx, flags: SYMLINK_NOFOLLOW, mask: TYPE|MODE|NLINK|UID|GID|ATIME|MTIME|CTIME|INO|SIZE|BLOCKS|BTIME, buffer: 0x7fff1db0ea90) = 0 ^C# This one also starts moving the beautifiers from files directly included in builtin-trace.c to separate objects + a beauty.h header with prototypes, so that we can add test cases in tools/perf/tests/ to fire syscalls with various arguments and then get them intercepted as syscalls:sys_enter_foo or raw_syscalls:sys_enter + sys_exit to then format and check that the formatted output is the one we expect. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: David Ahern <dsahern@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-xvzw8eynffvez5czyzidhrno@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-01-26perf ftrace: Introduce new 'ftrace' toolNamhyung Kim
The 'perf ftrace' command is a simple wrapper of kernel's ftrace functionality. It only supports single thread tracing currently and just reads trace_pipe in text and then write it to stdout. Committer notes: Testing it: # perf ftrace -f function_graph usleep 123456 <SNIP> 2) | SyS_nanosleep() { 2) | _copy_from_user() { <SNIP> 2) 0.900 us | } 2) 1.354 us | } 2) | hrtimer_nanosleep() { 2) 0.062 us | __hrtimer_init(); 2) | do_nanosleep() { 2) | hrtimer_start_range_ns() { <SNIP> 2) 5.025 us | } 2) | schedule() { 2) 0.125 us | rcu_note_context_switch(); 2) 0.057 us | _raw_spin_lock(); 2) | deactivate_task() { 2) 0.369 us | update_rq_clock.part.77(); 2) | dequeue_task_fair() { <SNIP> 2) + 22.453 us | } 2) + 23.736 us | } 2) | pick_next_task_fair() { <SNIP> 2) + 47.167 us | } 2) | pick_next_task_idle() { <SNIP> 2) 4.462 us | } ------------------------------------------ 2) usleep-20387 => <idle>-0 ------------------------------------------ 2) 0.806 us | switch_mm_irqs_off(); ------------------------------------------ 2) <idle>-0 => usleep-20387 ------------------------------------------ 2) 0.151 us | finish_task_switch(); 2) @ 123597.2 us | } 2) 0.037 us | _cond_resched(); 2) | hrtimer_try_to_cancel() { 2) 0.064 us | hrtimer_active(); 2) 0.353 us | } 2) @ 123605.3 us | } 2) @ 123606.2 us | } 2) @ 123608.3 us | } /* SyS_nanosleep */ 2) | __do_page_fault() { <SNIP> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Tested-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeremy Eder <jeder@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com>, Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-r1hgmsj4dxny8arn3o9mw512@git.kernel.org [ Various foward port fixes, add man page ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-01-17perf tools: Move two variables usied in libperf from perf.cSoramichi AKIYAMA
The use_browser and perf_version_string variables are both declared in perf.c but they are also referenced by other functions of libperf.a. Therefore a user linking an own main() with libperf.a must declare those two variables in their files even if the files never use the browser or the version information. This patch fixes this issue by moving use_browser and perf_version_string out of perf.c to some other files. Signed-off-by: Soramichi Akiyama <akiyama@m.soramichi.jp> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20170117002237.c1aec0ce3b4d675dca018deb@m.soramichi.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-01-11perf kallsyms: Introduce tool to look for extended symbol information on the ↵Arnaldo Carvalho de Melo
running kernel Its similar to doing grep on a /proc/kallsyms, but it also shows extra information like the path to the kernel module and the unrelocated addresses in it, to help in diagnosing problems. It is also helps demonstrate the use of the symbols routines so that tool writers can use them more effectively. Using it: $ perf kallsyms e1000_xmit_frame netif_rx usb_stor_set_xfer_buf e1000_xmit_frame: [e1000e] /lib/modules/4.9.0+/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko 0xffffffffc046fc10-0xffffffffc0470bb0 (0x19c80-0x1ac20) netif_rx: [kernel] [kernel.kallsyms] 0xffffffff916f03a0-0xffffffff916f0410 (0xffffffff916f03a0-0xffffffff916f0410) usb_stor_set_xfer_buf: [usb_storage] /lib/modules/4.9.0+/kernel/drivers/usb/storage/usb-storage.ko 0xffffffffc057aea0-0xffffffffc057af19 (0xf10-0xf89) $ Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-79bk9pakujn4l4vq0f90klv3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-10-19perf c2c: Add c2c commandJiri Olsa
Adding c2c command base wirings. Its implementation is going to be added gradually in following patches. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Joe Mario <jmario@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1474558645-19956-11-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-12perf tools: Set and pass DOCDIR to builtin-report.cNamhyung Kim
It'll be used to locate perf document directory to find tips.txt in case it's not installed on the system. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1452334589-8782-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-08perf report: Show random usage tip on the help lineNamhyung Kim
Currently perf report only shows a help message "For a higher level overview, try: perf report --sort comm,dso" unconditionally (even if the sort keys were used). Add more help tips and show randomly. Load tips from ${prefix}/share/doc/perf-tip/tips.txt file. $ perf report | tail 0.10% swapper [kernel.vmlinux] [k] irq_exit 0.09% swapper [kernel.vmlinux] [k] flush_smp_call_function_queue 0.08% swapper [kernel.vmlinux] [k] native_write_msr_safe 0.03% swapper [kernel.vmlinux] [k] group_sched_in 0.01% perf [kernel.vmlinux] [k] native_write_msr_safe # # (Tip: Search options using a keyword: perf report -h <keyword>) # Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1452166913-27046-1-git-send-email-namhyung@kernel.org [ Renamed it to perf_tip() and the parameter dirname to dirpath to fix the build on older distros ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-16perf tools: Provide subcmd configuration at runtimeJosh Poimboeuf
Create init functions for exec_cmd.c and pager.c. This allows their configuration to be specified at runtime so they can be split out into a separate library which can be used by other programs. Their configuration is stored in a shared subcmd_config struct. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/21f5f6b38da72c985a8dcfa185700d03e7eecd1d.1450193761.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-09perf tools: Move cmd_version() to builtin-version.cJosh Poimboeuf
Move cmd_version() to its own file so that help.c can be moved to a library. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/e908b1b68f20ab6d8d33941d5571c23110622e60.1449548395.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-23perf tools: Add 'perf config' commandTaeung Song
The perf configuration file contains many variables to change various aspects of each of its tools, including output, disk usage, etc. But looking at the state of configuration is difficult and there's no documentation about config variables except for the variables in perfconfig.example exist. So this patch adds a 'perf-config' command with a '--list' option. perf config [options] display current perf config variables. # perf config -l | --list Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1447768424-17327-1-git-send-email-treeze.taeung@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-20perf trace: Support 'strace' syscall event groupsArnaldo Carvalho de Melo
I.e.: $ cat ~/share/perf-core/strace/groups/file access chmod creat execve faccessat getcwd lstat mkdir open openat quotactl readlink rename rmdir stat statfs symlink unlink $ Then, on a quiet desktop, try running this and then moving your mouse to see the deluge of mouse related activity: # perf probe 'vfs_getname=getname_flags:72 pathname=filename:string' Added new event: probe:vfs_getname (on getname_flags:72 with pathname=filename:string) You can now use it in all perf tools, such as: perf record -e probe:vfs_getname -aR sleep 1 # # trace --ev probe:vfs_getname --filter-pids 2232 -e file 0.042 (0.042 ms): mousetweaks/2235 open(filename: 0x14e3910, mode: 438 ) ... 0.042 ( ): probe:vfs_getname:(ffffffff812230bc) pathname="/home/acme/.icons/Adwaita/cursors/xterm") 0.100 (0.100 ms): mousetweaks/2235 ... [continued]: open()) = -1 ENOENT No such file or directory 0.142 (0.018 ms): mousetweaks/2235 open(filename: 0x14c3c10, mode: 438 ) ... 0.142 ( ): probe:vfs_getname:(ffffffff812230bc) pathname="/home/acme/.icons/Adwaita/index.theme") 0.192 (0.069 ms): mousetweaks/2235 ... [continued]: open()) = -1 ENOENT No such file or directory 0.230 (0.017 ms): mousetweaks/2235 open(filename: 0x14c3c10, mode: 438 ) ... 0.230 ( ): probe:vfs_getname:(ffffffff812230bc) pathname="/usr/share/icons/Adwaita/cursors/xterm") 0.253 (0.041 ms): mousetweaks/2235 ... [continued]: open()) = 14 0.459 (0.008 ms): mousetweaks/2235 open(filename: 0x14e3910, mode: 438 ) ... 0.459 ( ): probe:vfs_getname:(ffffffff812230bc) pathname="/home/acme/.icons/Adwaita/cursors/left_side") 0.468 (0.017 ms): mousetweaks/2235 ... [continued]: open()) = -1 ENOENT No such file or directory Need to combine that raw_syscalls:sys_enter(open) + probe:vfs_getname + raw_syscalls:sys_exit(open) sequence... Now, if you're bored, please write some more syscall groups, like the ones in 'strace' and send it our way :-) Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Milian Wolff <mail@milianw.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-a42xklu59lcbxp7bbnic74a8@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-25perf tools: Add new 'perf data' commandJiri Olsa
Adding new 'perf data' command to provide operations over data files. The 'perf data convert' sub command is coming in following patch, but there's possibility for other useful commands like 'perf data ls' (to display perf data file in directory in ls style). Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeremie Galarneau <jgalar@efficios.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1424470628-5969-3-git-send-email-jolsa@kernel.org Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add perf.o object buildingJiri Olsa
Move the perf object building under build framework to be included in the perf build object. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-wiiciip2w6ajvj03huqz50xw@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add scripts objects buildingJiri Olsa
Move the scripts objects building under build framework to be included in the libperf build object. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ry8pd41ahwpq9h46i8te33c7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add gtk objects buildingJiri Olsa
Move the gtk objects building under build framework. Add new gtk build object so it's separated from the rest of the code and could be librarized. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-cd27z7vww85nxdq37rkjkkbm@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add ui objects buildingJiri Olsa
Move the ui objects building under build framework to be included in the libperf build object. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-re5vuat8uu396n7hyor9b5ve@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add probe objects buildingJiri Olsa
Move the probe objects building under build framework to be included in the libperf build object. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-p39iitiu2ltgmtbn48bsh7nz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add libperf objects buildingJiri Olsa
Move the util objects building under build framework. Add the new libperf build object so it's separated from the rest of the perf code and could be librarized. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-574tgt9t23tnxo9td8qjiibc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add builtin objects buildingJiri Olsa
Move the rest of builtin objects (bench and test are already in) building under build framework. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-mrh2d4kfyi4g1el4kmdcghl8@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add tests objects buildingJiri Olsa
Move test objects building under build framework. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-azbkwd1fl32t997a4shz4lgp@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-12perf build: Add bench objects buildingJiri Olsa
Move bench objects building under build framework and enable perf-in.o rule. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Alexis Berlemont <alexis.berlemont@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-b0gxubmn3qjabaq0lune53y3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
