path: root/tools/perf/arch/x86/util/dwarf-regs.c
2016-05-12perf dwarf: Guard !x86_64 definitions under #ifdef else clauseArnaldo Carvalho de Melo
To fix the build on Fedora Rawhide (gcc 6.0.0 20160311 (Red Hat 6.0.0-0.17): CC /tmp/build/perf/arch/x86/util/dwarf-regs.o arch/x86/util/dwarf-regs.c:66:36: error: 'x86_32_regoffset_table' defined but not used [-Werror=unused-const-variable=] static const struct pt_regs_offset x86_32_regoffset_table[] = { ^~~~~~~~~~~~~~~~~~~~~~ cc1: all warnings being treated as errors Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-fghuksc1u8ln82bof4lwcj0o@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf tools: Introduce regs_query_register_offset() for x86Wang Nan
regs_query_register_offset() is a helper function which converts register name like "%rax" to offset of a register in 'struct pt_regs', which is required by BPF prologue generator. Since the function is identical, try to reuse the code in arch/x86/kernel/ptrace.c. Comment inside dwarf-regs.c list the differences between this implementation and kernel code. get_arch_regstr() switches to regoffset_table and the old string table is dropped. Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kaixu Xia <xiakaixu@huawei.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1441523623-152703-20-git-send-email-wangnan0@huawei.com Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-01perf dwarf: Fix potential array out of bounds accessWang Nan
There is a problem in the dwarf-regs.c files for sh, sparc and x86 where it is possible to make an out-of-bounds array access when searching for register names. This patch fixes it by replacing '<=' to '<', so when register (number == XXX_MAX_REGS), get_arch_regstr() will return NULL. Signed-off-by: Wang Nan <wangnan0@huawei.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David S. Miller <davem@davemloft.net> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@huawei.com Link: http://lkml.kernel.org/r/1441078184-105038-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf tools: Fix build on non-glibc systems due to libio.h absenceCody P Schafer
Including libio.h causes build failures on uClibc systems (which lack libio.h). It appears that libio.h was only included to pull in a definition for NULL, so it has been replaced by stddef.h. On powerpc, libio.h was conditionally included, but could be removed completely as it is unneeded. Also, the included of stdlib.h was changed to stddef.h (as again, only NULL is needed). Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1363300074-26288-1-git-send-email-cody@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-22perf: Move arch specific code into separate arch directoryIan Munsie
The perf userspace tool included some architecture specific code to map registers from the DWARF register number into the names used by the regs and stack access API. This moves the architecture specific code out into a separate arch/x86 directory along with the infrastructure required to use it. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
