commit 119e7a22bb70d84849384e5113792cd45afa4f85 upstream.
This improves patch fa6963b24 so that perf.data stuff that has
been dumped as root can be read (annotate/report) by a user
without the use of the --force.
Rationale is that root has plenty of ways to screw us (usually)
that do not require twisted schemes involving specially
crafting a perf.data.
Signed-off-by: Pierre Habouzit <pierre.habouzit@intersec.com>
LKML-Reference: <20090827075902.GF19653@laphroaig.corp>
Add an owner check to opening perf.data files and a switch to
silence it.
Because perf-report/perf-annotate are binary parsers reading
another users' perf.data file could be a security risk if the
file were explicitly engineered to trigger bugs in the parser
(we hope of course there are non such bugs, but you never
know).
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20090819092023.896648538@chello.nl>
Linus reported this perf annotate segfault:
[torvalds@nehalem git]$ perf annotate unmap_vmas
Segmentation fault
#0 map__clone (self=<value optimized out>) at builtin-annotate.c:236
#1 thread__fork (self=<value optimized out>) at builtin-annotate.c:372
The bug here was that builtin-annotate.c was a copy of
builtin-report.c and a threading related fix to builtin-report.c
didnt get propagated to builtin-annotate.c ...
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: <new-submission>
Anton noted that for inherited counters the counter-id as provided by
PERF_SAMPLE_ID isn't mappable to the id found through PERF_RECORD_ID
because each inherited counter gets its own id.
His suggestion was to always return the parent counter id, since that
is the primary counter id as exposed. However, these inherited
counters have a unique identifier so that events like
PERF_EVENT_PERIOD and PERF_EVENT_THROTTLE can be specific about which
counter gets modified, which is important when trying to normalize the
sample streams.
This patch removes PERF_EVENT_PERIOD in favour of PERF_SAMPLE_PERIOD,
which is more useful anyway, since changing periods became a lot more
common than initially thought -- rendering PERF_EVENT_PERIOD the less
useful solution (also, PERF_SAMPLE_PERIOD reports the more accurate
value, since it reports the value used to trigger the overflow,
whereas PERF_EVENT_PERIOD simply reports the requested period changed,
which might only take effect on the next cycle).
This still leaves us PERF_EVENT_THROTTLE to consider, but since that
_should_ be a rare occurrence, and linking it to a primary id is the
most useful bit to diagnose the problem, we introduce a
PERF_SAMPLE_STREAM_ID, for those few cases where the full
reconstruction is important.
[Does change the ABI a little, but I see no other way out]
Suggested-by: Anton Blanchard <anton@samba.org>
LKML-Reference: <1248095846.15751.8781.camel@twins>
Among perf annotate, perf report and perf top, we can find the
common colored printing of percents according to the following
rules:
High overhead = > 5%, colored in red
Mid overhead = > 0.5%, colored in green
Low overhead = < 0.5%, default color
Factorize these multiple checks in a single function named
percent_color_fprintf() and also provide a get_percent_color()
for sites which print percentages and other things at the same
time.
LKML-Reference: <1246558475-10624-2-git-send-email-fweisbec@gmail.com>
Add the -m/--modules option to perf report and perf annotate,
which enables live module symbol/image loading. To be used
with -k/--vmlinux.
(Also give perf annotate a -P/--full-paths option.)
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1246514986.13293.48.camel@marge.simson.net>
infrastructure
LKML-Reference: <1246514916.13293.46.camel@marge.simson.net>
symbols
perf_counter tools: Make symbol loading consistently return number of loaded symbols.
LKML-Reference: <1246514758.13293.42.camel@marge.simson.net>
The copy we were using came from another copy I did for the dwarves
(pahole) package, that came from the kernel years ago.
The only function that is used by the perf tools and that isn't in the
kernel is list_del_range, that I'm leaving in the perf tools only for
now.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20090701174608.GA5823@ghostprotocols.net>
The tools/perf/util/rbtree.c copy already drifted by three
csets:
4b324126e0c6c3a5080ca3ec0981e8766ed6f1ee
4c60117811171d867d4f27f17ea07d7419d45dae
16c047add3ceaf0ab882e3e094d1ec904d02312d
So remove the copy and use the lib/rbtree.c directly, sharing
the source code while still generating a separate object file,
since tools/perf uses a far more agressive -O6 switch.
LKML-Reference: <20090701152837.GG15682@ghostprotocols.net>
Enable -Wextra. This found a few real bugs plus a number
of signed/unsigned type mismatches/uncleanlinesses. It
also required a few annotations
All things considered it was still worth it so lets try with
this enabled for now.
The PERF_EVENT_READ implementation made me realize we don't
actually need the sample_type int the output sample, since
we already have that in the perf_counter_attr information.
Therefore, remove the PERF_EVENT_MISC_OVERFLOW bit and the
event->type overloading, and imply put counter overflow
samples in a PERF_EVENT_SAMPLE type.
This also fixes the issue that event->type was only 32-bit
and sample_type had 64 usable bits.
On 64-bit powerpc, __u64 is defined to be unsigned long rather than
unsigned long long. This causes compiler warnings every time we
print a __u64 value with %Lx.
Rather than changing __u64, we define our own u64 to be unsigned long
long on all architectures, and similarly s64 as signed long long.
For consistency we also define u32, s32, u16, s16, u8 and s8. These
definitions are put in a new header, types.h, because these definitions
are needed in util/string.h and util/symbol.h.
The main change here is the mechanical change of __[us]{64,32,16,8}
to remove the "__". The other changes are:
* Create types.h
* Include types.h in perf.h, util/string.h and util/symbol.h
* Add types.h to the LIB_H definition in Makefile
* Added (u64) casts in process_overflow_event() and print_sym_table()
to kill two remaining warnings.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: benh@kernel.crashing.org
LKML-Reference: <19003.33494.495844.956580@cargo.ozlabs.ibm.com>
- fix addr2line on userspace binary: don't only check kernel image.
- fix string allocation size for path: missing ending null char room
- fix overflow in symbol extra info
Reported-by: Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1244907563-7820-1-git-send-email-fweisbec@gmail.com>
It's can be very annoying to scroll down perf annotated output
until we find relevant overhead.
Using the -l option, you can now have a small summary sorted per
overhead in the beginning of the output.
Example:
./perf annotate -l -k ../../vmlinux -s __lock_acquire
Sorted summary for file ../../vmlinux
12.04 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1653
4.61 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1740
3.77 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1775
3.56 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1653
2.93 /home/fweisbec/linux/linux-2.6-tip/arch/x86/include/asm/irqflags.h:15
2.83 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2545
2.30 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2594
2.20 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2388
2.20 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:730
2.09 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:730
2.09 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:138
1.88 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2548
1.47 /home/fweisbec/linux/linux-2.6-tip/arch/x86/include/asm/irqflags.h:15
1.36 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2594
1.36 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:730
1.26 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1654
1.26 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1653
1.15 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:2592
1.15 /home/fweisbec/linux/linux-2.6-tip/kernel/lockdep.c:1740
Only overhead over 0.5% are summarized.
LKML-Reference: <1244844682-12928-2-git-send-email-fweisbec@gmail.com>
When we have a colored line in perf annotate, ie a middle/high
overhead one, it's sometimes useful to get the matching line
and filename from the source file, especially this path prepares
to another subsequent one which will print a sorted summary of
midle/high overhead lines in the beginning of the output.
Filename:Lines have the same color than the concerned ip lines.
It can be slow because it relies on addr2line. We could also
use objdump with -l but that implies we would have to bufferize
objdump output and parse it to filter the relevant lines since
we want to print a sorted summary in the beginning.
LKML-Reference: <1244844682-12928-1-git-send-email-fweisbec@gmail.com>
A build error slipped in:
builtin-report.c: In function ‘hist_entry__fprintf’:
builtin-report.c:711: error: format ‘%12d’ expects type ‘int’, but argument 3 has type ‘uint64_t’
Because we got a bit sloppy with those types. uint64_t really sucks,
because there's no printf format for it. So standardize on __u64
instead - for all types that go to or come from the ABI (which is __u64),
or for values that need to be large enough even on 32-bit.
The rule is:
- high overhead: red
- mid overhead: green
- low overhead: normal (white/black)
Arjan noticed this bug in the perf annotate help output:
-s, --symbol <file> symbol to annotate
that should be <symbol> instead.
Reported-by: Arjan van de Ven <arjan@linux.intel.com>
Right now kernel debug info does not get resolved by default, because
we dont know where to look for the vmlinux.
The -k option can be used for that - but if no option is given, pick
up vmlinux files in the current directory - in case a kernel hacker
runs profiling from the source directory that the kernel was built in.
The real solution would be to embedd the location (and perhaps the
date/timestamp) of the vmlinux file in /proc/kallsyms, so that
tools can pick it up automatically.
Several people have suggested that 'perf' has become a full-fledged
tool that should be moved out of Documentation/. Move it to the
(new) tools/ directory.
