path: root/tools/perf/builtin-help.c
2015-10-19perf help: Change 'usage' to 'Usage' for consistencyYunlong Song
Capitalize 'usage' to make it consistent with all the other 'Usage' in the codes, e.g., usage_builtin. Signed-off-by: Yunlong Song <yunlong.song@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Sriram Raghunathan <sriram.r@nokia.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1444894792-2338-3-git-send-email-yunlong.song@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-19perf tools: Add the bash completion for listing subsubcommands of perf helpYunlong Song
The bash completion does not support listing subsubcommands for 'perf help <TAB>', so fix it. Example: Before this patch: $ perf help <TAB> $ As shown above, the subsubcommands of perf help does not come out. After this patch: $ perf help <TAB> annotate buildid-cache data evlist inject kvm lock probe report script test top bench buildid-list diff help kmem list mem record sched stat timechart trace As shown above, the subsubcommands of perf help can come out now. Signed-off-by: Yunlong Song <yunlong.song@huawei.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1426685758-25488-9-git-send-email-yunlong.song@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-08-15perf help: Use strerror_r instead of strerrorMasami Hiramatsu
Use strerror_r instead of strerror in error messages for thread-safety. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Naohiro Aota <naota@elisp.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20140814022253.3545.82136.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-17perf tools: Move pr_* debug macros into debug objectJiri Olsa
Moving pr_* debug macros to have it with in same object as debug variables, becase we will change them to use verbose variable in next patch. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1405374411-29012-3-git-send-email-jolsa@kernel.org [ Add missing debug.h include in python scripting glue and in the libdw unwind lib ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-22perf help: Fix --help for builtinsNamhyung Kim
It seems that commit cc5848213329 ("perf help: Remove use of die and handle errors") caused the problem - it changed the initial value of 'help_format' from HELP_FORMAT_MAN to HELP_FORMAT_NONE. This broke the --help option for all builtins, that would produce no output, while 'man perf-top' would work it MANPATH is properly setup. Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: David Ahern <dsahern@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/87r4orj7zc.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-02perf help: Don't use globals where not needed toArnaldo Carvalho de Melo
Some variables were global but used in just one function, so move it to where it belongs. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-plurd9htha6ea2mo9e9sd1p5@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-05perf help: Remove use of die and handle errorsDavid Ahern
Allows perf to clean up properly on exit. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1346005487-62961-6-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check all the remaining OPT_ variantsArnaldo Carvalho de Melo
OPT_SET_INT was renamed to OPT_SET_UINT since the only use in these tools is to set something that has an enum type, that is builtin compatible with unsigned int. Several string constifications were done to make OPT_STRING require a const char * type. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-14perf: Fix endianness argument compatibility with OPT_BOOLEAN() and introduce ↵Ian Munsie
OPT_INCR() Parsing an option from the command line with OPT_BOOLEAN on a bool data type would not work on a big-endian machine due to the manner in which the boolean was being cast into an int and incremented. For example, running 'perf probe --list' on a PowerPC machine would fail to properly set the list_events bool and would therefore print out the usage information and terminate. This patch makes OPT_BOOLEAN work as expected with a bool datatype. For cases where the original OPT_BOOLEAN was intentionally being used to increment an int each time it was passed in on the command line, this patch introduces OPT_INCR with the old behaviour of OPT_BOOLEAN (the verbose variable is currently the only such example of this). I have reviewed every use of OPT_BOOLEAN to verify that a true C99 bool was passed. Where integers were used, I verified that they were only being used for boolean logic and changed them to bools to ensure that they would not be mistakenly used as ints. The major exception was the verbose variable which now uses OPT_INCR instead of OPT_BOOLEAN. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <stable@kernel.org> # NOTE: wont apply to .3[34].x cleanly, please backport Cc: Git development list <git@vger.kernel.org> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Valdis.Kletnieks@vt.edu Cc: WANG Cong <amwang@redhat.com> Cc: Thiago Farina <tfransosi@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mike Galbraith <efault@gmx.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: John Kacur <jkacur@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13perf: Make cmd_to_page() function more compactWenji Huang
Remove branch for is_perf_command. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Cc: fweisbec@gmail.com Cc: jkacur@redhat.com Cc: acme@redhat.com LKML-Reference: <1263373298-13282-1-git-send-email-wenji.huang@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf: Use format string of printf to align stringsAmerigo Wang
Instead of filling whitespaces to do alignment, use printf's format string. This simplifies the code a bit. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091214082700.4224.57640.sendpatchset@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-24perf tools: Introduce zalloc() for the common calloc(1, N) caseArnaldo Carvalho de Melo
This way we type less characters and it looks more like the kzalloc kernel counterpart. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1259071517-3242-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-03perf: Clean up trivial style issues in builtin-help.cThiago Farina
Pointed out by checkpatch. Signed-off-by: Thiago Farina <tfransosi@gmail.com> Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <1257254925-5423-1-git-send-email-tfransosi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16perf: Enable more compiler warningsIngo Molnar
Related to a shadowed variable bug fix Valdis Kletnieks noticed that perf does not get built with -Wshadow, which could have helped us avoid the bug. So enable -Wshadow and also enable the following warnings on perf builds, in addition to the already enabled -Wall -Wextra -std=gnu99 warnings: -Wcast-align -Wformat=2 -Wshadow -Winit-self -Wpacked -Wredundant-decls -Wstack-protector -Wstrict-aliasing=3 -Wswitch-default -Wswitch-enum -Wno-system-headers -Wundef -Wvolatile-register-var -Wwrite-strings -Wbad-function-cast -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wold-style-definition -Wstrict-prototypes -Wdeclaration-after-statement And change/fix the perf code to build cleanly under GCC 4.3.2. The list of warnings enablement is rather arbitrary: it's based on my (quick) reading of the GCC manpages and trying them on perf. I categorized the warnings based on individually enabling them and looking whether they trigger something in the perf build. If i liked those warnings (i.e. if they trigger for something that arguably could be improved) i enabled the warning. If the warnings seemed to come from language laywers spamming the build with tons of nuisance warnings i generally kept them off. Most of the sign conversion related warnings were in this category. (A second patch enabling some of the sign warnings might be welcome - sign bugs can be nasty.) I also kept warnings that seem to make sense from their manpage description and which produced no actual warnings on our code base. These warnings might still be turned off if they end up being a nuisance. I also left out a few warnings that are not supported in older compilers. [ Note that these changes might break the build on older compilers i did not test, or on non-x86 architectures that produce different warnings, so more testing would be welcome. ] Reported-by: Valdis.Kletnieks@vt.edu Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-01perf_counter tools: Add more warnings and fix/annotate themIngo Molnar
Enable -Wextra. This found a few real bugs plus a number of signed/unsigned type mismatches/uncleanlinesses. It also required a few annotations All things considered it was still worth it so lets try with this enabled for now. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
