path: root/tools/perf/builtin-report.c
2013-04-01perf tools: Remove dependency on libnewtArnaldo Carvalho de Melo
Now that the map browser shares the input routine with the hists browser, there is no need for using any libnewt routine, so remove all traces except for honouring NO_NEWT=1 on the makefile command line as an indication that TUI support is not needed, in fact it just sets NO_SLANG=1. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-wae5o7xca9m52bj1re28jc5j@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf report: Add support for mem access profilingStephane Eranian
This patch adds the --mem-mode option to perf report. This mode requires a perf.data file created with memory access samples. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1359040242-8269-13-git-send-email-eranian@google.com [ Removed duplicates in the --sort help, man page needs updating, Fixed minor conflict with 328ccda "perf report: Add --no-demangle option" ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf tools: Add support for weight v7 (modified)Andi Kleen
perf record has a new option -W that enables weightened sampling. Add sorting support in top/report for the average weight per sample and the total weight sum. This allows to both compare relative cost per event and the total cost over the measurement period. Add the necessary glue to perf report, record and the library. v2: Merge with new hist refactoring. v3: Fix manpage. Remove value check. Rename global_weight to weight and weight to local_weight. v4: Readd sort keys to manpage v5: Move weight to end v6: Move weight to template v7: Rename weight key. Original patch from Andi modified by Stephane Eranian <eranian@google.com> to include ONLY the weight supporting code and apply to pristine 3.8.0-rc4. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1359040242-8269-6-git-send-email-eranian@google.com [ committer note: changed to cope with fc5871ed and the hists_link perf test entry ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-26perf report: Add --no-demangle optionNamhyung Kim
It's sometimes useful to see undemangled raw symbol name for example other tools using the perf output to do manipulation of binaries. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Suggested-by: William Cohen <wcohen@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: William Cohen <wcohen@redhat.com> BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=55571 Link: http://lkml.kernel.org/r/1364203098-17741-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf report: Remove duplicated includeWei Yongjun
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/CAPgLHd9=EXaH1hv4jeVvTa4tZFsjnx+8+g3zqmmUKqQ5qRqTEA@mail.gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15perf evsel: Introduce perf_evsel__is_group_event() helperNamhyung Kim
The perf_evsel__is_group_event function is for checking whether given evsel needs event group view support or not. Please note that it's different to the existing perf_evsel__is_group_leader() which checks only the given evsel is a leader or a standalone (i.e. non-group) event regardless of event group feature. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1362462812-30885-7-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-02-06perf sort: Make setup_sorting returns an error codeNamhyung Kim
Currently the setup_sorting() is called for parsing sort keys and exits if it failed to add the sort key. As it's included in libperf it'd be better returning an error code rather than exiting application inside of the library. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Suggested-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1360130237-9963-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-02-06perf report: Enable the runtime switching of perf data fileFeng Tang
This is for tui browser only. This patch will check the returned key of tui hists browser, if it's K_SWITH_INPUT_DATA, then recreate a session for the new selected data file. V2: Move the setup_brower() before the "repeat" jump point. Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1359873501-24541-2-git-send-email-feng.tang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-31perf report: Add report.group config optionNamhyung Kim
Add report.group config option for setting default value of event group view. It affects the report output only if perf.data contains event group info. A user can write .perfconfig file like below to enable group view by default: $ cat ~/.perfconfig [report] group = true And it can be disabled through command line: $ perf report --no-group Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1358845787-1350-19-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-31perf report: Add --group optionNamhyung Kim
Add --group option to enable event grouping. When enabled, all the group members information will be shown together with the leader. $ perf report --group ... # group: {ref-cycles,cycles} # ======== # # Samples: 7K of event 'anon group { ref-cycles, cycles }' # Event count (approx.): 6876107743 # # Overhead Command Shared Object Symbol # ................ ....... ................. .......................... # 99.84% 99.76% noploop noploop [.] main 0.07% 0.00% noploop ld-2.15.so [.] strcmp 0.03% 0.00% noploop [kernel.kallsyms] [k] timerqueue_del 0.03% 0.03% noploop [kernel.kallsyms] [k] sched_clock_cpu 0.02% 0.00% noploop [kernel.kallsyms] [k] account_user_time 0.01% 0.00% noploop [kernel.kallsyms] [k] __alloc_pages_nodemask 0.00% 0.00% noploop [kernel.kallsyms] [k] native_write_msr_safe 0.00% 0.11% noploop [kernel.kallsyms] [k] _raw_spin_lock 0.00% 0.06% noploop [kernel.kallsyms] [k] find_get_page 0.00% 0.02% noploop [kernel.kallsyms] [k] rcu_check_callbacks 0.00% 0.02% noploop [kernel.kallsyms] [k] __current_kernel_time Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1358845787-1350-18-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-31perf report: Show group description when event group is enabledNamhyung Kim
When using event group viewer, it's better to show the group description rather than the leader information alone. If a leader did not contain any member, it's a non-group event. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1358845787-1350-17-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-31perf report: Bypass non-leader events when event group is enabledNamhyung Kim
Since we have all necessary information in the leader events and other members don't, bypass members. Member events will be shown along with the leaders if event group is enabled. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1358845787-1350-16-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-31perf report: Make another loop for linking group histsNamhyung Kim
Now the event grouping viewing requires linking all member hists in a group to the leader's. Thus hists__output_resort should be called after linking all events in evlist. Introduce symbol_conf.event_group flag to determine whether the feature is enabled or not. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1358845787-1350-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-24perf report: Update documentation for sort keysNamhyung Kim
Add description of sort keys to the perf-report document and also add missing cpu and srcline keys to the command line help string. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1356599507-14226-11-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-24perf machine: Introduce struct machinesArnaldo Carvalho de Melo
That consolidates the grouping of host + guests, isolating a bit more of functionality now centered on 'perf_session' that can be used independently in tools that don't need a 'perf_session' instance, but needs to have all the thread/map/symbol machinery. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-c700rsiphpmzv8klogojpfut@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-12-09perf hists: Introduce perf_hpp__list for period related columnsJiri Olsa
Adding perf_hpp__list list to register and contain all period related columns the command is interested in. This way we get rid of static array holding all possible columns and enable commands to register their own columns. It'll be handy for diff command in future to process and display data for multiple files. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/n/tip-kiykge4igrcl7etmpmveto1h@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-05perf report: Postpone objdump check until annotation requestedNamhyung Kim
David reported that current perf report refused to run on a data file captured from a different machine because of objdump. Since the objdump tools won't be used unless annotation was requested, checking its presence at init time doesn't make sense. Reported-by: David Ahern <dsahern@gmail.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: David Ahern <dsahern@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Irina Tirdea <irina.tirdea@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1351835406-15208-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-05perf tools: Introduce struct hist_browser_timerNamhyung Kim
Currently various hist browser functions receive 3 arguments for refreshing histogram but only used from a few places. Also it's only for perf top command so that it can be NULL for other (and probably most) cases. Pack them into a struct in order to reduce number of those unused arguments. This is a mechanical change and does not intend a functional change. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Irina Tirdea <irina.tirdea@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1351835406-15208-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-29perf tools: Add a global variable "const char *input_name"Feng Tang
Currently many perf commands annotate/evlist/report/script/lock etc all support "-i" option to chose a specific perf data, and all of them create a local "input_name" to save the file name for that perf data. Since most of these commands need it, we can add a global variable for it, also it can some other benefits: 1. When calling script browser inside hists/annotation browser, it needs to know the perf data file name to run that script. 2. For further feature like runtime switching to another perf data file, this variable can also help. Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1351569369-26732-2-git-send-email-feng.tang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-24perf tools: Try to find cross-built objdump pathIrina Tirdea
As we have architecture information of saved perf.data file, we can try to find cross-built objdump path. The triplets include support for Android (arm, x86 and mips architectures). Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Originally-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1350344020-8071-5-git-send-email-irina.tirdea@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-06perf event: No need to create a thread when handling PERF_RECORD_EXITArnaldo Carvalho de Melo
When we were processing a PERF_RECORD_EXIT event we first used machine__findnew_thread for both the thread exiting and for its parent, only to use just the thread struct associated with the one exiting, and to just delete it. If it existed, i.e. not created at this very moment in machine__findnew_thread, it will be moved to the machine->dead_threads linked list, because we may have hist_entries pointing to it, but if it was created just do be deleted, it will just sit there with no references at all. Use the new machine__find_thread() method so that if it is not there, we don't create it. As a bonus the parent thread will also not be created at this point. Create process_fork() and process_exit() helpers to use this and make the builtins use it instead of the generic process_task(), ditched by this patch. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-z7n2y98ebjyrvmytaope4vdl@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-04perf tool: Add hpp interface to enable/disable hpp columnJiri Olsa
Adding perf_hpp__column_enable function to enable/disable hists column and removing diff command specific stuff 'need_pair and show_displacement' from hpp code. The diff command now enables/disables columns separately according to the user arguments. This will be helpful in future patches where more columns are added into diff output. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1349354994-17853-6-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-04perf tools: Removing hists pair argument from output pathJiri Olsa
The hists pointer is now part of the 'struct hist_entry'. And since the overhead and baseline columns are split now, there's no reason to pass it through the output path. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1349354994-17853-5-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-10-04perf diff: Refactor diff displacement possition infoJiri Olsa
Moving the position calculation into the diff command, so the position as prepared inside struct hist_entry data and there's no need to compute in the output display path. Removing 'displacement' from struct perf_hpp as it is no longer needed. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1349354994-17853-3-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-17perf report: Add missing perf_hpp__init for pipe-modeNamhyung Kim
The perf_hpp__init() function was only called from setup_browser() so that the pipe-mode missed the initialization thus didn't respond to related options. Fix it. Reported-by: Robert Richter <robert.richter@amd.com> Tested-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-tip-commits@vger.kernel.org Link: http://lkml.kernel.org/r/87txv28spl.fsf_-_@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-17perf report: Enable integrated annotation only if possibleNamhyung Kim
The integrated annotation feature is supported only in TUI mode. Also it should be enabled with 'symbol' sort key otherwise resulting hist entry doesn't need to have same symbol as of a sample so that it can fail on hist_entry__inc_addr_samples with -ERANGE. You can easily see it when start perf report TUI without symbol* sort key. This patch fixes the problem. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1347611729-16994-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-05perf tools: Allow user to indicate path to objdump in command lineMaciek Borzecki
When analyzing perf data from hosts of other architecture than one of the local host it's useful to call objdump that is part of a toolchain for that architecture. Instead of calling regular objdump, call one that user specified in command line. Signed-off-by: Maciek Borzecki <maciek.borzecki@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1346754750.16299.3.camel@localhost.localdomain Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-11perf tools: Support for DWARF CFI unwinding on post processingJiri Olsa
This brings the support for DWARF cfi unwinding on perf post processing. Call frame informations are retrieved and then passed to libunwind that requests memory and register content from the applications. Adding unwind object to handle the user stack backtrace based on the user register values and user stack dump. The unwind object access the libunwind via remote interface and provides to it all the necessary data to unwind the stack. The unwind interface provides following function: unwind__get_entries And callback (specified in above function) to retrieve the backtrace entries: typedef int (*unwind_entry_cb_t)(struct unwind_entry *entry, void *arg); Signed-off-by: Jiri Olsa <jolsa@redhat.com> Original-patch-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-12-git-send-email-jolsa@redhat.com [ Replaced use of perf_session by usage of perf_evsel ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-01perf session: Use perf_evlist__sample_type more extensivelyArnaldo Carvalho de Melo
Removing perf_session->sample_type, as it can be obtained from the evsel/evlist. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-mnt1zwlik7sp7z6ljc9kyefg@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-27perf report: Delay sample_type checks in pipe modeDavid Ahern
The pipeline: perf record -a -g -o - sleep 5 |perf inject -v -b | perf report -g -i - generates the warning: Selected -g but no callchain data. Did you call 'perf record' without -g? The problem is that the header data is not written to the pipe, so the sample_type has not been available when perf_report__setup_sample_type is called. For pipe mode, record dumps the sample type as part of the synthesized events stream -- perf_event__synthesize_attrs(). Handle this be detecting pipe mode and not doing early sanity checks on sample_type. Signed-off-by: David Ahern <dsahern@gmail.com> Tested-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tim Chen <tim.c.chen@linux.intel.com> Link: http://lkml.kernel.org/r/1339444121-26236-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-19perf tools: Remove unused evsel parameter from machine__resolve_callchainJiri Olsa
Removing unused evsel parameter from machine__resolve_callchain function. Plus related header file and callers changes. The evsel parameter is unused since following commit: perf callchain: Make callchain cursors TLS commit 472606458f3e1ced5fe3cc5f04e90a6b5a4732cf Author: Namhyung Kim <namhyung.kim@lge.com> Date: Thu May 31 14:43:26 2012 +0900 Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1339420814-7379-9-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-19perf tools: Move all users of event_name to perf_evsel__nameArnaldo Carvalho de Melo
So that we don't use global variables that could make us misreport event names when having a multi window top, for instance. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-mccancovi1u0wdkg8ncth509@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-31perf callchain: Make callchain cursors TLSNamhyung Kim
perf top -G has a race on callchain cursor between main thread and display thread. Since the callchain cursors are used locally make them thread-local data would solve the problem. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Reported-by: Sunjin Yang <fan4326@gmail.com> Suggested-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sunjin Yang <fan4326@gmail.com> Link: http://lkml.kernel.org/r/1338443007-24857-1-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-30perf report: Use the right symbol for annotationArnaldo Carvalho de Melo
In non symbolic views, i.e. --sort without "symbol", as in: perf report --sort comm We're segfaulting in the --tui because we're testing the symbol resolved and then trying to use the symbol on the histogram entry where we're coalescing all hits for a COMM, and the first hist_entry for a comm may have a NULL symbol, i.e. the RIP didn't resolve to any symbol. In this case we're segfaulting, fix it by testing against the symbol in the histogram entry. Reported-by: William Cohen <wcohen@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-8ylwubbcmu27ucc9ffrku3yv@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-29perf tools: Convert critical messages to ui__error()Namhyung Kim
There were places where use ui__warning (or even fprintf) to show critical messages. This patch converts them to ui__error so that the front-end code can implement appropriate behavior. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1338265382-6872-3-git-send-email-namhyung@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-18Merge remote-tracking branch 'tip/perf/urgent' into perf/coreArnaldo Carvalho de Melo
Merge reason: We are going to queue up a dependent patch: "perf tools: Move parse event automated tests to separated object" That depends on: commit e7c72d8 perf tools: Add 'G' and 'H' modifiers to event parsing Conflicts: tools/perf/builtin-stat.c Conflicted with the recent 'perf_target' patches when checking the result of perf_evsel open routines to see if a retry is needed to cope with older kernels where the exclude guest/host perf_event_attr bits were not used. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-09perf report: Fix format string for x86-32 compilationJiri Olsa
Using PRIu64 for printing out u64 nr_events to fix compilation for x86 32 bits. Cc: Arun Sharma <asharma@fb.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank C. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1335958638-5160-7-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-02perf ui: Add gtk2 support into setup_browser()Namhyung Kim
Now setup_browser can handle gtk2 front-end so split the TUI code to ui/tui/setup.c in order to remove dependency. To this end, make ui__init/exit global symbols and take an argument. Also split gtk code to ui/gtk/setup.c. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1335761711-31403-5-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-02perf ui gtk: Rename functions for consistencyNamhyung Kim
We use double underscore characters to distinguish its subsystem and actual function name. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1335761711-31403-4-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-02perf ui gtk: Drop arg[cv] arguments from perf_gtk_setup_browser()Namhyung Kim
As perf doesn't allow to specify gtk command-line option, drop the arguments and pass NULL to gtk_init(). This makes the function easier to be called from setup_browser(). Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1335761711-31403-3-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-16perf report: Fix crash showing warning related to kernel mapsDavid Ahern
While testing https://lkml.org/lkml/2012/4/10/123 I hit this crash: (gdb) bt 0 0x000000000042000f in __cmd_report (rep=0x7fff80cec580) at builtin-report.c:380 1 cmd_report (argc=0, argv=<optimized out>, prefix=<optimized out>) at builtin-report.c:759 2 0x0000000000414513 in run_builtin (p=0x7724a8, argc=3, argv=0x7fff80ceca70) at perf.c:273 3 0x0000000000413d41 in handle_internal_command (argv=0x7fff80ceca70, argc=3) at perf.c:345 4 run_argv (argv=0x7fff80cec880, argcp=0x7fff80cec88c) at perf.c:389 5 main (argc=3, argv=0x7fff80ceca70) at perf.c:487 kernel_map can be NULL, so need to handle it while dumping a warning to user. v2: - fixed RB_EMPTY_ROOT check -- desc takes the altnerative output when RB_EMPTY_ROOT is false. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Link: http://lkml.kernel.org/r/1334544855-55021-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-07perf report: Correct display of samples and events in headerAshay Rane
This patch prints the number of samples and the count of performance events separately. This allows comparing performance of different applications with each other. Previously, the sample count was displayed against an 'Events:' heading. With this patch, the header now reads (for example): Samples: 5K of event 'instructions' Event count (approx.): 2993026545 The patch covers both the stdio and the browser interface. Signed-off-by: Ashay Rane <ashay.rane@tacc.utexas.edu> [ committer note: Fixed wrt e7f01d1 ] Link: http://lkml.kernel.org/n/tip-h4nfjm8msedlk8gxkzivfh5y@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-19perf report: Add a simple GTK2-based 'perf report' browserPekka Enberg
This patch adds a simple GTK2-based browser to 'perf report' that's based on the TTY-based browser in builtin-report.c. To launch "perf report" using the new GTK interface just type: $ perf report --gtk The interface is somewhat limited in features at the moment: - No callgraph support - No KVM guest profiling support - No color coding for percentages - No sorting from the UI - ..and many, many more! That said, I think this patch a reasonable start to build future features on. Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: Colin Walters <walters@verbum.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1202231952410.6689@tux.localdomain [ committer note: Added #pragma to make gtk no strict prototype problem go away as suggested by Colin Walters modulo avoiding push/pop ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-16perf report: Treat an argument as a symbol filterNamhyung Kim
As Ingo requested, it'd be better off treating first (and the only) argument as a symbol filter, so that user doesn't need to input the symbol on the dialog window on TUI. Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1331887855-874-5-git-send-email-namhyung.kim@lge.com Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-16perf report: Add --symbol-filter optionNamhyung Kim
Add new --symbol-filter command line option to set appropriate filter string. Its short version is missing as I couldn't find an ideal one and --filter option of perf record also has no short version. Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1331887855-874-4-git-send-email-namhyung.kim@lge.com Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-09perf report: Enable TUI in branch view modeStephane Eranian
This patch updates perf report to support TUI mode when the perf.data file contains samples with branch stacks. For each row in the report, it is possible to annotate either the source or target of each branch. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: peterz@infradead.org Cc: acme@redhat.com Cc: asharma@fb.com Cc: ravitillo@lbl.gov Cc: vweaver1@eecs.utk.edu Cc: khandual@linux.vnet.ibm.com Cc: dsahern@gmail.com Link: http://lkml.kernel.org/r/1331246868-19905-5-git-send-email-eranian@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-09perf report: Auto-detect branch stack sampling modeStephane Eranian
This patch enhances perf report to auto-detect when the perf.data file contains samples with branch stacks. That way it is not necessary to use the -b option. To force branch view mode to off, simply use --no-branch-stack. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: peterz@infradead.org Cc: acme@redhat.com Cc: asharma@fb.com Cc: ravitillo@lbl.gov Cc: vweaver1@eecs.utk.edu Cc: khandual@linux.vnet.ibm.com Cc: dsahern@gmail.com Link: http://lkml.kernel.org/r/1331246868-19905-4-git-send-email-eranian@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-09perf report: Add support for taken branch samplingRoberto Agostino Vitillo
This patch adds support for taken branch sampling, i.e, the PERF_SAMPLE_BRANCH_STACK feature to perf report. In other words, to display histograms based on taken branches rather than executed instructions addresses. The new option is called -b and it takes no argument. To generate meaningful output, the perf.data must have been obtained using perf record -b xxx ... where xxx is a branch filter option. The output shows symbols, modules, sorted by 'who branches where' the most often. The percentages reported in the first column refer to the total number of branches captured and not the usual number of samples. Here is a quick example. Here branchy is simple test program which looks as follows: void f2(void) {} void f3(void) {} void f1(unsigned long n) { if (n & 1UL) f2(); else f3(); } int main(void) { unsigned long i; for (i=0; i < N; i++) f1(i); return 0; } Here is the output captured on Nehalem, if we are only interested in user level function calls. $ perf record -b any_call,u -e cycles:u branchy $ perf report -b --sort=symbol 52.34% [.] main [.] f1 24.04% [.] f1 [.] f3 23.60% [.] f1 [.] f2 0.01% [k] _IO_new_file_xsputn [k] _IO_file_overflow 0.01% [k] _IO_vfprintf_internal [k] _IO_new_file_xsputn 0.01% [k] _IO_vfprintf_internal [k] strchrnul 0.01% [k] __printf [k] _IO_vfprintf_internal 0.01% [k] main [k] __printf About half (52%) of the call branches captured are from main() -> f1(). The second half (24%+23%) is split in two equal shares between f1() -> f2(), f1() ->f3(). The output is as expected given the code. It should be noted, that using -b in perf record does not eliminate information in the perf.data file. Consequently, a typical profile can also be obtained by perf report by simply not using its -b option. It is possible to sort on branch related columns: - dso_from, symbol_from - dso_to, symbol_to - mispredict Signed-off-by: Roberto Agostino Vitillo <ravitillo@lbl.gov> Signed-off-by: Stephane Eranian <eranian@google.com> Cc: peterz@infradead.org Cc: acme@redhat.com Cc: robert.richter@amd.com Cc: ming.m.lin@intel.com Cc: andi@firstfloor.org Cc: asharma@fb.com Cc: vweaver1@eecs.utk.edu Cc: khandual@linux.vnet.ibm.com Cc: dsahern@gmail.com Link: http://lkml.kernel.org/r/1328826068-11713-14-git-send-email-eranian@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-23perf report: Accept fifos as input fileRobert Richter
The default input file for perf report is not handled the same way as perf record does it for its output file. This leads to unexpected behavior of perf report, etc. E.g.: # perf record -a -e cpu-cycles sleep 2 | perf report | cat failed to open perf.data: No such file or directory (try 'perf record' first) While perf record writes to a fifo, perf report expects perf.data to be read. This patch changes this to accept fifos as input file. Applies to the following commands: perf annotate perf buildid-list perf evlist perf kmem perf lock perf report perf sched perf script perf timechart Also fixes char const* -> const char* type declaration for filename strings. v2: * Prevent potential null pointer access to input_name in builtin-report.c. Needed due to removal of patch "perf report: Setup browser if stdout is a pipe" Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-5-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
