path: root/tools/perf/builtin-stat.c
2010-06-05perf tools: Add the ability to specify list of cpus to monitorStephane Eranian
This patch adds a -C option to stat, record, top to designate a list of CPUs to monitor. CPUs can be specified as a comma-separated list or ranges, no space allowed. Examples: $ perf record -a -C0-1,4-7 sleep 1 $ perf top -C0-4 $ perf stat -a -C1,2,3,4 sleep 1 With perf record in per-thread mode with inherit mode on, samples are collected only when the thread runs on the designated CPUs. The -C option does not turn on system-wide mode automatically. Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4bff9496.d345d80a.41fe.7b00@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-18perf stat: add perf stat -B to pretty print large numbersStephane Eranian
It is hard to read very large numbers so provide an option to perf stat to separate thousands using a separator. The patch leverages the locale support of stdio. You need to set your LC_NUMERIC appropriately, for instance LC_NUMERIC=en_US.UTF8. You need to pass -B to activate this feature. This way existing scripts parsing the output do not need to be changed. Here is an example. $ perf stat noploop 2 noploop for 2 seconds Performance counter stats for 'noploop 2': 1998.347031 task-clock-msecs # 0.998 CPUs 61 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 118 page-faults # 0.000 M/sec 4,138,410,900 cycles # 2070.917 M/sec (scaled from 70.01%) 2,062,650,268 instructions # 0.498 IPC (scaled from 70.01%) 2,057,653,466 branches # 1029.678 M/sec (scaled from 70.01%) 40,267 branch-misses # 0.002 % (scaled from 30.04%) 2,055,961,348 cache-references # 1028.831 M/sec (scaled from 30.03%) 53,725 cache-misses # 0.027 M/sec (scaled from 30.02%) 2.001393933 seconds time elapsed $ perf stat -B noploop 2 noploop for 2 seconds Performance counter stats for 'noploop 2': 1998.297883 task-clock-msecs # 0.998 CPUs 59 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 119 page-faults # 0.000 M/sec 4,131,380,160 cycles # 2067.450 M/sec (scaled from 70.01%) 2,059,096,507 instructions # 0.498 IPC (scaled from 70.01%) 2,054,681,303 branches # 1028.216 M/sec (scaled from 70.01%) 25,650 branch-misses # 0.001 % (scaled from 30.05%) 2,056,283,014 cache-references # 1029.017 M/sec (scaled from 30.03%) 47,097 cache-misses # 0.024 M/sec (scaled from 30.02%) 2.001391016 seconds time elapsed Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4bf28fe8.914ed80a.01ca.fffff5f5@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf tools: change event inheritance logic in stat and recordStephane Eranian
By default, event inheritance across fork and pthread_create was on but the -i option of stat and record, which enabled inheritance, led to believe it was off by default. This patch fixes this logic by inverting the meaning of the -i option. By default inheritance is on whether you attach to a process (-p), a thread (-t) or start a process. If you pass -i, then you turn off inheritance. Turning off inheritance if you don't need it, helps limit perf resource usage as well. The patch also fixes perf stat -t xxxx and perf record -t xxxx which did not start the counters. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4bea9d2f.d60ce30a.0b5b.08e1@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-14perf: Fix endianness argument compatibility with OPT_BOOLEAN() and introduce ↵Ian Munsie
OPT_INCR() Parsing an option from the command line with OPT_BOOLEAN on a bool data type would not work on a big-endian machine due to the manner in which the boolean was being cast into an int and incremented. For example, running 'perf probe --list' on a PowerPC machine would fail to properly set the list_events bool and would therefore print out the usage information and terminate. This patch makes OPT_BOOLEAN work as expected with a bool datatype. For cases where the original OPT_BOOLEAN was intentionally being used to increment an int each time it was passed in on the command line, this patch introduces OPT_INCR with the old behaviour of OPT_BOOLEAN (the verbose variable is currently the only such example of this). I have reviewed every use of OPT_BOOLEAN to verify that a true C99 bool was passed. Where integers were used, I verified that they were only being used for boolean logic and changed them to bools to ensure that they would not be mistakenly used as ints. The major exception was the verbose variable which now uses OPT_INCR instead of OPT_BOOLEAN. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <stable@kernel.org> # NOTE: wont apply to .3[34].x cleanly, please backport Cc: Git development list <git@vger.kernel.org> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Valdis.Kletnieks@vt.edu Cc: WANG Cong <amwang@redhat.com> Cc: Thiago Farina <tfransosi@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mike Galbraith <efault@gmx.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: John Kacur <jkacur@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-22perf stat: Better report failure to collect system wide statsArnaldo Carvalho de Melo
Before: [acme@doppio linux-2.6-tip]$ perf stat -a sleep 1s Performance counter stats for 'sleep 1s': <not counted> task-clock-msecs <not counted> context-switches <not counted> CPU-migrations <not counted> page-faults <not counted> cycles <not counted> instructions <not counted> branches <not counted> branch-misses <not counted> cache-references <not counted> cache-misses 1.016998463 seconds time elapsed [acme@doppio linux-2.6-tip]$ Now: [acme@doppio linux-2.6-tip]$ perf stat -a sleep 1s No permission to collect system-wide stats. Consider tweaking /proc/sys/kernel/perf_event_paranoid. [acme@doppio linux-2.6-tip]$ Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1269274229-20442-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-18perf events: Change perf parameter --pid to process-wide collection instead ↵Zhang, Yanmin
of thread-wide Parameter --pid (or -p) of perf currently means a thread-wide collection. For exmaple, if a process whose id is 8888 has 10 threads, 'perf top -p 8888' just collects the main thread statistics. That's misleading. Users are used to attach a whole process when debugging a process by gdb. To follow normal usage style, the patch change --pid to process-wide collection and add --tid (-t) to mean a thread-wide collection. Usage example is: # perf top -p 8888 # perf record -p 8888 -f sleep 10 # perf stat -p 8888 -f sleep 10 Above commands collect the statistics of all threads of process 8888. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sheng Yang <sheng@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Jes Sorensen <Jes.Sorensen@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: zhiteng.huang@intel.com Cc: Zachary Amsden <zamsden@redhat.com> LKML-Reference: <1268922965-14774-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-18perf stat: Enable counters when collecting process-wide or system-wide dataZhang, Yanmin
Command 'perf stat' doesn't enable counters when collecting an existing (by -p) process or system-wide statistics. Fix the issue. Change the condition of fork/exec subcommand. If there is a subcommand parameter, perf always forks/execs it. The usage example is: # perf stat -a sleep 10 So this command could collect statistics for 10 seconds precisely. User still could stop it by CTRL+C. Without the new capability, user could only use CTRL+C to stop it without precise time clock. Another issue is 'perf stat -a' consumes 100% time of a full single logical cpu. It has a bad impact on running workload. Fix it by adding a sleep(1) in the while(!done) loop in function run_perf_stat. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sheng Yang <sheng@linux.intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Jes Sorensen <Jes.Sorensen@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Zachary Amsden <zamsden@redhat.com> Cc: <zhiteng.huang@intel.com> LKML-Reference: <1268922965-14774-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11perf tools: Fix sparse CPU numbering related bugsPaul Mackerras
At present, the perf subcommands that do system-wide monitoring (perf stat, perf record and perf top) don't work properly unless the online cpus are numbered 0, 1, ..., N-1. These tools ask for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN) and then try to create events for cpus 0, 1, ..., N-1. This creates problems for systems where the online cpus are numbered sparsely. For example, a POWER6 system in single-threaded mode (i.e. only running 1 hardware thread per core) will have only even-numbered cpus online. This fixes the problem by reading the /sys/devices/system/cpu/online file to find out which cpus are online. The code that does that is in tools/perf/util/cpumap.[ch], and consists of a read_cpu_map() function that sets up a cpumap[] array and returns the number of online cpus. If /sys/devices/system/cpu/online can't be read or can't be parsed successfully, it falls back to using sysconf to ask how many cpus are online and sets up an identity map in cpumap[]. The perf record, perf stat and perf top code then calls read_cpu_map() in the system-wide monitoring case (instead of sysconf) and uses cpumap[] to get the cpu numbers to pass to perf_event_open. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13perf tools: Fix --pid option for statLiming Wang
current pid option doesn't work for perf stat. Change it to what perf record --pid acts as. Signed-off-by: Liming Wang <liming.wang@windriver.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1262246750-2191-1-git-send-email-liming.wang@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-15perf stat: Do not print ratio when task-clock event is not countedLucas De Marchi
The ratio between the number of events and the time elapsed makes sense only if task-clock event is counted. Otherwise it will be simply a (confusing) # 0.000 M/sec This patch outputs the ratio only if task-clock event is counted. Some test examples of before and after: Before: [lucas@skywalker linux.trees.git]$ sudo perf stat -e branch-misses -a -- sleep 1 Performance counter stats for 'sleep 1': 1367818 branch-misses # 0.000 M/sec 1.001494325 seconds time elapsed After (without task-clock): [lucas@skywalker perf]$ sudo ./perf stat -e branch-misses -a -- sleep 1 Performance counter stats for 'sleep 1': 1135044 branch-misses 1.001370775 seconds time elapsed After (with task-clock): [lucas@skywalker perf]$ sudo ./perf stat -e branch-misses -e task-clock -a -- sleep 1 Performance counter stats for 'sleep 1': 1070111 branch-misses # 0.534 M/sec 2002.730893 task-clock-msecs # 1.999 CPUs 1.001640292 seconds time elapsed Signed-off-by: Lucas De Marchi <lucas.de.marchi@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091115140507.GB21561@skywalker.lan> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-19perf stat: Count branches firstIngo Molnar
Count branches first, cache-misses second. The reason is that on x86 branches are not counted by all counters on all CPUs. Before: Performance counter stats for 'ls': 0.756653 task-clock-msecs # 0.802 CPUs 0 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 250 page-faults # 0.330 M/sec 2375725 cycles # 3139.781 M/sec 1628129 instructions # 0.685 IPC 19643 cache-references # 25.960 M/sec 4608 cache-misses # 6.090 M/sec 342532 branches # 452.694 M/sec <not counted> branch-misses 0.000943356 seconds time elapsed After: Performance counter stats for 'ls': 1.056734 task-clock-msecs # 0.859 CPUs 0 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 259 page-faults # 0.245 M/sec 3345932 cycles # 3166.295 M/sec 3074090 instructions # 0.919 IPC 616928 branches # 583.806 M/sec 39279 branch-misses # 6.367 % 21312 cache-references # 20.168 M/sec 3661 cache-misses # 3.464 M/sec 0.001230551 seconds time elapsed (also prettify the printout of branch misses, in case it's getting scaled.) Cc: Tim Blechmann <tim@klingt.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4ADC3975.8050109@klingt.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> --- tools/perf/builtin-stat.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-) diff --git a/tools/perf/builtin-stat.c b/tools/perf/builtin-stat.c index c373683..95a55ea 100644 --- a/tools/perf/builtin-stat.c +++ b/tools/perf/builtin-stat.c @@ -59,6 +59,8 @@ static struct perf_event_attr default_attrs[] = { { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_INSTRUCTIONS }, { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_REFERENCES}, { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_MISSES }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_INSTRUCTIONS}, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_MISSES }, }; --- tools/perf/builtin-stat.c | 20 ++++++++++---------- 1 files changed, 10 insertions(+), 10 deletions(-) diff --git a/tools/perf/builtin-stat.c b/tools/perf/builtin-stat.c index 95a55ea..90e0a26 100644 --- a/tools/perf/builtin-stat.c +++ b/tools/perf/builtin-stat.c @@ -50,17 +50,17 @@ static struct perf_event_attr default_attrs[] = { - { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_TASK_CLOCK }, - { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_CONTEXT_SWITCHES}, - { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_CPU_MIGRATIONS }, - { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_PAGE_FAULTS }, - - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CPU_CYCLES }, - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_INSTRUCTIONS }, - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_REFERENCES}, - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_MISSES }, - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_INSTRUCTIONS}, - { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_MISSES }, + { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_TASK_CLOCK }, + { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_CONTEXT_SWITCHES }, + { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_CPU_MIGRATIONS }, + { .type = PERF_TYPE_SOFTWARE, .config = PERF_COUNT_SW_PAGE_FAULTS }, + + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CPU_CYCLES }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_INSTRUCTIONS }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_REFERENCES }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_MISSES }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_INSTRUCTIONS }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_MISSES }, };
2009-10-19perf stat: Re-align the default_attrs[] arrayIngo Molnar
Clean up the array definition to be vertically aligned. No functional effects. Cc: Tim Blechmann <tim@klingt.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4ADC3975.8050109@klingt.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> --- tools/perf/builtin-stat.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-) diff --git a/tools/perf/builtin-stat.c b/tools/perf/builtin-stat.c index c373683..95a55ea 100644 --- a/tools/perf/builtin-stat.c +++ b/tools/perf/builtin-stat.c @@ -59,6 +59,8 @@ static struct perf_event_attr default_attrs[] = { { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_INSTRUCTIONS }, { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_REFERENCES}, { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_CACHE_MISSES }, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_INSTRUCTIONS}, + { .type = PERF_TYPE_HARDWARE, .config = PERF_COUNT_HW_BRANCH_MISSES }, };
2009-10-19perf stat: Add branch performance events to default outputTim Blechmann
Adds performance event information about branches and branch misses to the default output of perf stat. Signed-off-by: Tim Blechmann <tim@klingt.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4ADC3975.8050109@klingt.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-19perf stat: Add branch performance metricAnton Blanchard
When we count both branches and branch-misses it is useful to print out the percentage of branch-misses: # perf stat -e branches -e branch-misses /bin/true Performance counter stats for '/bin/true': 401684 branches # 0.000 M/sec 23301 branch-misses # 5.801 % Signed-off-by: Anton Blanchard <anton@samba.org> Cc: paulus@samba.org Cc: a.p.zijlstra@chello.nl LKML-Reference: <20091018112923.GQ4808@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-04perf: Propagate term signal to childChris Wilson
If we launch the child on behalf of the user, ensure that it dies along with ourselves when we are interrupted. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Chris Wilson <chris@chris-wilson.co.uk> LKML-Reference: <1254616502-4728-1-git-send-email-chris@chris-wilson.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22perf stat: Fix zero total printoutsIngo Molnar
Before: 0 sched:sched_switch # nan M/sec After: 0 sched:sched_switch # 0.000 M/sec Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04perf stat: Clean up statistics calculations a bit morePeter Zijlstra
Remove some, now useless, global storage. Don't calculate the stddev when not needed. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04perf stat: More advanced variance computationPeter Zijlstra
Use the more advanced single pass variance algorithm outlined on the wikipedia page. This is numerically more stable for larger sample sets. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04perf stat: Use stddev_mean in stead of stddevPeter Zijlstra
When we're computing the mean by sampling the distribution, then the std dev of the mean is related to the std dev of the sample set by: stddev_mean = std_dev / sqrt(N) Which is exactly what we want. This results in the error on the mean decreasing with increasing number of samples. Also fix the scaled == -1, aka not counted case. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04perf stat: Remove the limit on repeatPeter Zijlstra
Since we don't need all the individual samples to calculate the error remove both the limit and the storage overhead associated with that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04perf stat: Change noise calculation to use stddevPeter Zijlstra
The current noise computation does: \Sum abs(n_i - avg(n)) * N^-1.5 Which is (afaik) not a regular noise function, and needs the complete sample set available to post-process. Change this to use a regular stddev computation which can be done by keeping a two sums: stddev = sqrt( 1/N (\Sum n_i^2) - avg(n)^2 ) For which we only need to keep \Sum n_i and \Sum n_i^2. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16perf tools: Librarize trace_event() helperFrederic Weisbecker
Librarize trace_event() helper so that perf trace can use it too. Also clean up the debug.h includes a bit. It's not good to have it included in perf.h because it doesn't make it flexible against other headers it may need (headers that can also depend on perf.h and then create a recursive header dependency). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1250453149-664-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-12perf tools: Factorize high level dso helpersFrederic Weisbecker
Factorize multiple definitions of high level dso helpers into the symbol source file. The side effect is a general export of the verbose and eprintf debugging helpers into a new file dedicated to debugging purposes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Brice Goglin <Brice.Goglin@inria.fr>
2009-08-09perf stat: Fix tool option consistency: rename -S/--scale to -c/--scaleBrice Goglin
We want to use a coherent flag for -S/--stat across all tools, so free up -S in perf stat. Signed-off-by: Brice Goglin <Brice.Goglin@inria.fr> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-22perf_counter: Improve perf stat and perf record option parsingAnton Blanchard
perf stat and perf record currently look for all options on the command line. This can lead to some confusion: # perf stat ls -l Error: unknown switch `l' While we can work around this by adding '--' before the command, the git option parsing code can stop at the first non option: # perf stat ls -l Performance counter stats for 'ls -l': .... Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090722130412.GD9029@kryten>
2009-07-01perf stat: Handle pipe read failures in perf statFrederic Weisbecker
Building builtin-stat.c reports the following errors: cc1: warnings being treated as errors builtin-stat.c: In function ‘run_perf_stat’: builtin-stat.c:242: erreur: ignoring return value of ‘read’, declared with attribute warn_unused_result builtin-stat.c:255: erreur: ignoring return value of ‘read’, declared with attribute warn_unused_result make: *** [builtin-stat.o] Erreur 1 This patch handles the possible pipe read failures. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1246474930-6088-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-01perf stat: Define MATCH_EVENT for easy attr checkingJaswinder Singh Rajput
MATCH_EVENT is useful: 1. for multiple attrs checking 2. avoid repetition of PERF_TYPE_ and PERF_COUNT_ and save space 3. avoids line breakage Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1246440909.3403.5.camel@hpdv5.satnam> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-01perf_counter tools: Add more warnings and fix/annotate themIngo Molnar
Enable -Wextra. This found a few real bugs plus a number of signed/unsigned type mismatches/uncleanlinesses. It also required a few annotations All things considered it was still worth it so lets try with this enabled for now. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-30perf_counter: Provide a way to enable counters on execPaul Mackerras
This provides a way to mark a counter to be enabled on the next exec. This is useful for measuring the total activity of a program without including overhead from the process that launches it. This also changes the perf stat command to use this new facility. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <19017.43927.838745.689203@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-29perf_counter tools: Reduce perf stat measurement overhead/skewPaul Mackerras
Vince Weaver reported a 'perf stat' measurement overhead in the count of retired instructions, which can amount to a +6000 instructions inflated count in the reported count. At present, perf stat creates its counters on the perf process. Thus the counters count the fork and various other activity in both the parent and child, such as the resolver overhead for resolving PLT entries for any libc functions that haven't been called before, such as execvp. This reduces the overhead by creating the counters on the child process after the fork, using a couple of pipes to synchronize so that the child process waits until the parent has created the counters before doing the exec. To eliminate the PLT resolution overhead on calling execvp, this does a dummy execvp first which will always fail. With this, the overhead of executing a program goes down from over 4800 instructions to about 90 instructions on powerpc (32-bit). This was measured with a statically-linked program written in assembler which only does the 3 instructions needed to call _exit(0). Before: $ perf stat -e 0:1:u ./three Performance counter stats for './three': 4858 instructions 0.001274523 seconds time elapsed After: $ perf stat -e 0:1:u ./three Performance counter stats for './three': 92 instructions 0.000468153 seconds time elapsed Reported-by: Vince Weaver <vince@deater.net> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <19016.41425.814043.870352@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-29perf stat: Use percentages for scaling outputIngo Molnar
Peter expressed a strong preference for percentage based display of scaled values - so revert to that from the recently introduced multiplication-factor unit. Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-28perf stat: Micro-optimize the code: memcpy is only required if no event is ↵Jaswinder Singh Rajput
selected and !null_run Set attrs and nr_counters if no event is selected and !null_run. Setting of attrs should depend on number of counters, so we need to memcpy only for sizeof(default_attrs) Also set nr_counters as ARRAY_SIZE(default_attrs) in place of hardcoded value. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1246126749.32198.16.camel@hpdv5.satnam> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-27perf stat: Improve outputJaswinder Singh Rajput
Increase size for event name to handle bigger names like 'L1-d$-prefetch-misses' Changed scaled counters from percentage to a multiplicative factor because the latter is more expressive. Also aligned the scaling factor, otherwise sometimes it looks like: 384 iTLB-load-misses (4.74x scaled) 452029 branch-loads (8.00x scaled) 5892 branch-load-misses (20.39x scaled) 972315 iTLB-loads (3.24x scaled) Before: 150708 L1-d$-stores (scaled from 23.57%) 428804 L1-d$-prefetches (scaled from 23.47%) 314446 L1-d$-prefetch-misses (scaled from 23.42%) 252626137 L1-i$-loads (scaled from 23.24%) 5297550 dTLB-load-misses (scaled from 23.96%) 106992392 branch-loads (scaled from 23.67%) 5239561 branch-load-misses (scaled from 23.43%) After: 1731713 L1-d$-loads ( 14.25x scaled) 44241 L1-d$-prefetches ( 3.88x scaled) 21076 L1-d$-prefetch-misses ( 3.40x scaled) 5789421 L1-i$-loads ( 3.78x scaled) 29645 dTLB-load-misses ( 2.95x scaled) 461474 branch-loads ( 6.52x scaled) 7493 branch-load-misses ( 26.57x scaled) Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1246051927.2988.10.camel@hpdv5.satnam> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-27perf stat: Fix multi-run statsIngo Molnar
In multi-run (-r/--repeat) printouts, print out the noise of the wall-clock average as well. Also, fix a bug in printing out scaled counters: if it was not scaled then we should not update the average with -1. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-27perf stat: Add -n/--null option to run without countersIngo Molnar
Allow a no-counters run. This can be useful to measure just elapsed wall-clock time - or to assess the raw overhead of perf stat itself, without running any counters. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-24perf stat: Remove dead codeJaswinder Singh Rajput
Remove dead code and do some code alignment. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1245847774.2681.2.camel@ht.satnam> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-23perf stat: Fix verbose for perf statJaswinder Singh Rajput
Error message should use stderr for verbose (-v), otherwise message will be lost for: $ ./perf stat -v <cmd> > /dev/null For example on AMD bus-cycles event is not available so now it looks like: $ ./perf stat -v -e bus-cycles ls > /dev/null Error: counter 0, sys_perf_counter_open() syscall returned with -1 (Invalid argument) Performance counter stats for 'ls': <not counted> bus-cycles 0.006765877 seconds time elapsed. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1245757369.3776.1.camel@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-19perf_counter tools: Define and use our own u64, s64 etc. definitionsPaul Mackerras
On 64-bit powerpc, __u64 is defined to be unsigned long rather than unsigned long long. This causes compiler warnings every time we print a __u64 value with %Lx. Rather than changing __u64, we define our own u64 to be unsigned long long on all architectures, and similarly s64 as signed long long. For consistency we also define u32, s32, u16, s16, u8 and s8. These definitions are put in a new header, types.h, because these definitions are needed in util/string.h and util/symbol.h. The main change here is the mechanical change of __[us]{64,32,16,8} to remove the "__". The other changes are: * Create types.h * Include types.h in perf.h, util/string.h and util/symbol.h * Add types.h to the LIB_H definition in Makefile * Added (u64) casts in process_overflow_event() and print_sym_table() to kill two remaining warnings. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: benh@kernel.crashing.org LKML-Reference: <19003.33494.495844.956580@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-13perf stat: Enable raw data to be printedIngo Molnar
If -vv (very verbose) is specified, print out raw data in the following format: $ perf stat -vv -r 3 ./loop_1b_instructions [ perf stat: executing run #1 ... ] [ perf stat: executing run #2 ... ] [ perf stat: executing run #3 ... ] debug: runtime[0]: 235871872 debug: walltime[0]: 236646752 debug: runtime_cycles[0]: 755150182 debug: counter/0[0]: 235871872 debug: counter/1[0]: 235871872 debug: counter/2[0]: 235871872 debug: scaled[0]: 0 debug: counter/0[1]: 2 debug: counter/1[1]: 235870662 debug: counter/2[1]: 235870662 debug: scaled[1]: 0 debug: counter/0[2]: 1 debug: counter/1[2]: 235870437 debug: counter/2[2]: 235870437 debug: scaled[2]: 0 debug: counter/0[3]: 140 debug: counter/1[3]: 235870298 debug: counter/2[3]: 235870298 debug: scaled[3]: 0 debug: counter/0[4]: 755150182 debug: counter/1[4]: 235870145 debug: counter/2[4]: 235870145 debug: scaled[4]: 0 debug: counter/0[5]: 1001411258 debug: counter/1[5]: 235868838 debug: counter/2[5]: 235868838 debug: scaled[5]: 0 debug: counter/0[6]: 27897 debug: counter/1[6]: 235868560 debug: counter/2[6]: 235868560 debug: scaled[6]: 0 debug: counter/0[7]: 2910 debug: counter/1[7]: 235868151 debug: counter/2[7]: 235868151 debug: scaled[7]: 0 debug: runtime[0]: 235980257 debug: walltime[0]: 236770942 debug: runtime_cycles[0]: 755114546 debug: counter/0[0]: 235980257 debug: counter/1[0]: 235980257 debug: counter/2[0]: 235980257 debug: scaled[0]: 0 debug: counter/0[1]: 3 debug: counter/1[1]: 235980049 debug: counter/2[1]: 235980049 debug: scaled[1]: 0 debug: counter/0[2]: 1 debug: counter/1[2]: 235979907 debug: counter/2[2]: 235979907 debug: scaled[2]: 0 debug: counter/0[3]: 135 debug: counter/1[3]: 235979780 debug: counter/2[3]: 235979780 debug: scaled[3]: 0 debug: counter/0[4]: 755114546 debug: counter/1[4]: 235979652 debug: counter/2[4]: 235979652 debug: scaled[4]: 0 debug: counter/0[5]: 1001439771 debug: counter/1[5]: 235979304 debug: counter/2[5]: 235979304 debug: scaled[5]: 0 debug: counter/0[6]: 23723 debug: counter/1[6]: 235979050 debug: counter/2[6]: 235979050 debug: scaled[6]: 0 debug: counter/0[7]: 2213 debug: counter/1[7]: 235978820 debug: counter/2[7]: 235978820 debug: scaled[7]: 0 debug: runtime[0]: 235888002 debug: walltime[0]: 236700533 debug: runtime_cycles[0]: 754881504 debug: counter/0[0]: 235888002 debug: counter/1[0]: 235888002 debug: counter/2[0]: 235888002 debug: scaled[0]: 0 debug: counter/0[1]: 2 debug: counter/1[1]: 235887793 debug: counter/2[1]: 235887793 debug: scaled[1]: 0 debug: counter/0[2]: 1 debug: counter/1[2]: 235887645 debug: counter/2[2]: 235887645 debug: scaled[2]: 0 debug: counter/0[3]: 135 debug: counter/1[3]: 235887499 debug: counter/2[3]: 235887499 debug: scaled[3]: 0 debug: counter/0[4]: 754881504 debug: counter/1[4]: 235887368 debug: counter/2[4]: 235887368 debug: scaled[4]: 0 debug: counter/0[5]: 1001401731 debug: counter/1[5]: 235887024 debug: counter/2[5]: 235887024 debug: scaled[5]: 0 debug: counter/0[6]: 24212 debug: counter/1[6]: 235886786 debug: counter/2[6]: 235886786 debug: scaled[6]: 0 debug: counter/0[7]: 1824 debug: counter/1[7]: 235886560 debug: counter/2[7]: 235886560 debug: scaled[7]: 0 Performance counter stats for '/home/mingo/loop_1b_instructions' (3 runs): 235.913377 task-clock-msecs # 0.997 CPUs ( +- 0.011% ) 2 context-switches # 0.000 M/sec ( +- 0.000% ) 1 CPU-migrations # 0.000 M/sec ( +- 0.000% ) 136 page-faults # 0.001 M/sec ( +- 0.730% ) 755048744 cycles # 3200.534 M/sec ( +- 0.009% ) 1001417586 instructions # 1.326 IPC ( +- 0.001% ) 25277 cache-references # 0.107 M/sec ( +- 3.988% ) 2315 cache-misses # 0.010 M/sec ( +- 9.845% ) 0.236706075 seconds time elapsed. This allows the summary stats to be validated. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-13perf stat: Add feature to run and measure a command multiple timesIngo Molnar
Add the --repeat <n> feature to perf stat, which repeats a given command up to a 100 times, collects the stats and calculates an average and a stddev. For example, the following oneliner 'perf stat' command runs hackbench 5 times and prints a tabulated result of all metrics, with averages and noise levels (in percentage) printed: aldebaran:~/linux/linux/tools/perf> ./perf stat --repeat 5 ~/hackbench 10 Time: 0.117 Time: 0.108 Time: 0.089 Time: 0.088 Time: 0.100 Performance counter stats for '/home/mingo/hackbench 10' (5 runs): 1243.989586 task-clock-msecs # 10.460 CPUs ( +- 4.720% ) 47706 context-switches # 0.038 M/sec ( +- 19.706% ) 387 CPU-migrations # 0.000 M/sec ( +- 3.608% ) 17793 page-faults # 0.014 M/sec ( +- 0.354% ) 3770941606 cycles # 3031.329 M/sec ( +- 4.621% ) 1566372416 instructions # 0.415 IPC ( +- 2.703% ) 16783421 cache-references # 13.492 M/sec ( +- 5.202% ) 7128590 cache-misses # 5.730 M/sec ( +- 7.420% ) 0.118924455 seconds time elapsed. The goal of this feature is to allow the reliance on these accurate statistics and to know how many times a command has to be repeated for the noise to go down to an acceptable level. (The -v option can be used to see a line printed out as each run progresses.) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-13perf stat: Reorganize outputIngo Molnar
- use IPC for the instruction normalization output - CPUs for the CPU utilization factor value. - print out time elapsed like the other rows - tidy up the task-clocks/cpu-clocks printout Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter: Standardize event namesPeter Zijlstra
Pure renames only, to PERF_COUNT_HW_* and PERF_COUNT_SW_*. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-10perf_counter tools: Propagate signals properlyPeter Zijlstra
Currently report and stat catch SIGINT (and others) without altering their exit state. This means that things like: while :; do perf stat ./foo ; done Loops become hard-to-interrupt, because bash never sees perf terminate due to interruption. Fix this. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-07perf stat: Print out instructins/cycle metricIngo Molnar
Before: 7549326754 cycles # 3201.811 M/sec 10007594937 instructions # 4244.408 M/sec After: 7542051194 cycles # 3201.996 M/sec 10007743852 instructions # 4248.811 M/sec # 1.327 per cycle Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-07perf stat: Continue even on counter creation errorIngo Molnar
Before: $ perf stat ~/hackbench 5 error: syscall returned with -1 (No such device) After: $ perf stat ~/hackbench 5 Time: 1.640 Performance counter stats for '/home/mingo/hackbench 5': 6524.570382 task-clock-ticks # 3.838 CPU utilization factor 35704 context-switches # 0.005 M/sec 191 CPU-migrations # 0.000 M/sec 8958 page-faults # 0.001 M/sec <not counted> cycles <not counted> instructions <not counted> cache-references <not counted> cache-misses Wall-clock time elapsed: 1699.999995 msecs Also add -v (--verbose) option to allow the printing of failed counter opens. Plus dont print 'inf' if wall-time is zero (due to jiffies granularity), instead skip the printing of the CPU utilization factor. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
