path: root/tools/perf/util/event.c
2012-02-29perf tools: Ensure comm string is properly terminatedDavid Ahern
If threads in a multi-threaded process have names shorter than the main thread the comm for the named threads is not properly terminated. E.g., for the process 'namedthreads' where each thread is named noploop%d where %d is the thread number: Before: perf script -f comm,tid,ip,sym,dso noploop:4ads 21616 400a49 noploop (/tmp/namedthreads) The 'ads' in the thread comm bleeds over from the process name. After: perf script -f comm,tid,ip,sym,dso noploop:4 21616 400a49 noploop (/tmp/namedthreads) Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1330111898-68071-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-06perf tools: Fix prefix matching for kernel mapsJiri Olsa
In some perf ancient versions we used '[kernel.kallsyms._text]' as the name for the kernel map. This got changed with commit: perf: 'perf kvm' tool for monitoring guest performance from host commit a1645ce12adb6c9cc9e19d7695466204e3f017fe Author: Zhang, Yanmin <yanmin_zhang@linux.intel.com> and we started to use following name '[kernel.kallsyms]_text'. This name change is important for the report code dealing with ancient perf data. When processing the kernel map event, we need to recognize the old naming (dont match the last ']') and initialize the kernel map correctly. The subsequent call to maps__set_kallsyms_ref_reloc_sym deals with the superfluous ']' to get correct symbol name. Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1328461865-6127-1-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Look up thread names for system wide profilingDavid Ahern
This handles multithreaded processes with named threads when doing system wide profiling: the comm for each thread is looked up allowing them to be different from the thread group leader. v2: - fixed sizeof arg to perf_event__get_comm_tgid Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1324578603-12762-3-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Fix comm for processes with named threadsDavid Ahern
perf does not properly handle monitoring of processes with named threads. For example: $ ps -C myapp -L PID LWP TTY TIME CMD 25118 25118 ? 00:00:00 myapp 25118 25119 ? 00:00:00 myapp:worker perf record -e cs -c 1 -fo /tmp/perf.data -p 25118 -- sleep 10 perf report --stdio -i /tmp/perf.data 100.00% myapp:worker [kernel.kallsyms] [k] perf_event_task_sched_out The process name is set to the name of the last thread it finds for the process. The Problem: perf-top and perf-record both create a thread_map of threads to be monitored. That map is used in perf_event__synthesize_thread_map which loops over the entries in thread_map and calls __event__synthesize_thread to generate COMM and MMAP events. __event__synthesize_thread calls perf_event__synthesize_comm which opens /proc/pid/status, reads the name of the task and its thread group id. That's all fine. The problem is that it then reads /proc/pid/task and generates COMM events for each task it finds - but using the name found in /proc/pid/status where pid is the thread of interest. The end result (looping over thread_map + synthesizing comm events for each thread each time) means the name of the last thread processed sets the name for all threads in the process - which is not good for multithreaded processes with named threads. The Fix: perf_event__synthesize_comm has an input argument (full) that decides whether to process task entries for each pid it is passed. It currently never set to 0 (perf_event__synthesize_comm has a single caller and it always passes the value 1). Let's fix that. Add the full input argument to __event__synthesize_thread which passes it to perf_event__synthesize_comm. For thread/process monitoring set full to 0 which means COMM and MMAP events are only generated for the pid passed to it. For system wide monitoring set full to 1 so that COMM events are generated for all threads in a process. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1324578603-12762-2-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-20perf events: Tidy up perf_event__preprocess_sampleNamhyung Kim
Use local variable 'dso' to reduce typing a bit and rearrange the if condition. Also NULL check of al->map in the condition is not necessary. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1323703017-6060-7-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-02perf event: Introduce perf_event__fprintfArnaldo Carvalho de Melo
So that tools like 'perf test' can print the events when in verbose mode, for instance. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xnovdqfi25nc48gy6604k7yp@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-28perf tools: Rename perf_event_ops to perf_toolArnaldo Carvalho de Melo
To better reflect that it became the base class for all tools, that must be in each tool struct and where common stuff will be put. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qgpc4msetqlwr8y2k7537cxe@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-28perf tools: Resolve machine earlier and pass it to perf_event_opsArnaldo Carvalho de Melo
Reducing the exposure of perf_session further, so that we can use the classes in cases where no perf.data file is created. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-stua66dcscsezzrcdugvbmvd@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-28perf tools: Pass tool context in the the perf_event_ops functionsArnaldo Carvalho de Melo
So that we don't need to have that many globals. Next steps will remove the 'session' pointer, that in most cases is not needed. Then we can rename perf_event_ops to 'perf_tool' that better describes this class hierarchy. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-wp4djox7x6w1i2bab1pt4xxp@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Synthesize anonymous mmap eventsAnton Blanchard
perf_event__synthesize_mmap_events does not create anonymous mmap events even though the kernel does. As a result an already running application with dynamically created code will not get profiled - all samples end up in the unknown bucket. This patch skips any entries with '[' in the name to avoid adding events for special regions (eg the vsyscall page). All other executable mmaps are assumed to be anonymous and an event is synthesized. Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Link: http://lkml.kernel.org/r/20110830091506.60b51fe8@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-06-03perf evlist: Don't die if sample_{id_all|type} is invalidArnaldo Carvalho de Melo
Fixes two more cases where the python binding would not load: . Not finding die(), which it shouldn't anyway, not good to just stop the world because some particular perf.data file is invalid, just propagate the error to the caller. . Not finding perf_sample_size: fix it by moving it from event.c to evsel, where it belongs, as most cases are moving to operate on an evsel object.o One of the fixed problems: [root@emilia ~]# python >>> import perf Traceback (most recent call last): File "<stdin>", line 1, in <module> ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: perf_sample_size >>> [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-1hkj7b2cvgbfnoizsekjb6c9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-05-26perf symbols: Handle /proc/sys/kernel/kptr_restrictArnaldo Carvalho de Melo
Perf uses /proc/modules to figure out where kernel modules are loaded. With the advent of kptr_restrict, non root users get zeroes for all module start addresses. So check if kptr_restrict is non zero and don't generate the syntethic PERF_RECORD_MMAP events for them. Warn the user about it in perf record and in perf report. In perf report the reference relocation symbol being zero means that kptr_restrict was set, thus /proc/kallsyms has only zeroed addresses, so don't use it to fixup symbol addresses when using a valid kallsyms (in the buildid cache) or vmlinux (in the vmlinux path) build-id located automatically or specified by the user. Provide an explanation about it in 'perf report' if kernel samples were taken, checking if a suitable vmlinux or kallsyms was found/specified. Restricted /proc/kallsyms don't go to the buildid cache anymore. Example: [acme@emilia ~]$ perf record -F 100000 sleep 1 WARNING: Kernel address maps (/proc/{kallsyms,modules}) are restricted, check /proc/sys/kernel/kptr_restrict. Samples in kernel functions may not be resolved if a suitable vmlinux file is not found in the buildid cache or in the vmlinux path. Samples in kernel modules won't be resolved at all. If some relocation was applied (e.g. kexec) symbols may be misresolved even with a suitable vmlinux or kallsyms file. [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.005 MB perf.data (~231 samples) ] [acme@emilia ~]$ [acme@emilia ~]$ perf report --stdio Kernel address maps (/proc/{kallsyms,modules}) were restricted, check /proc/sys/kernel/kptr_restrict before running 'perf record'. If some relocation was applied (e.g. kexec) symbols may be misresolved. Samples in kernel modules can't be resolved as well. # Events: 13 cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ..................... # 20.24% sleep [kernel.kallsyms] [k] page_fault 20.04% sleep [kernel.kallsyms] [k] filemap_fault 19.78% sleep [kernel.kallsyms] [k] __lru_cache_add 19.69% sleep ld-2.12.so [.] memcpy 14.71% sleep [kernel.kallsyms] [k] dput 4.70% sleep [kernel.kallsyms] [k] flush_signal_handlers 0.73% sleep [kernel.kallsyms] [k] perf_event_comm 0.11% sleep [kernel.kallsyms] [k] native_write_msr_safe # # (For a higher level overview, try: perf report --sort comm,dso) # [acme@emilia ~]$ This is because it found a suitable vmlinux (build-id checked) in /lib/modules/2.6.39-rc7+/build/vmlinux (use -v in perf report to see the long file name). If we remove that file from the vmlinux path: [root@emilia ~]# mv /lib/modules/2.6.39-rc7+/build/vmlinux \ /lib/modules/2.6.39-rc7+/build/vmlinux.OFF [acme@emilia ~]$ perf report --stdio [kernel.kallsyms] with build id 57298cdbe0131f6871667ec0eaab4804dcf6f562 not found, continuing without symbols Kernel address maps (/proc/{kallsyms,modules}) were restricted, check /proc/sys/kernel/kptr_restrict before running 'perf record'. As no suitable kallsyms nor vmlinux was found, kernel samples can't be resolved. Samples in kernel modules can't be resolved as well. # Events: 13 cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ...... # 80.31% sleep [kernel.kallsyms] [k] 0xffffffff8103425a 19.69% sleep ld-2.12.so [.] memcpy # # (For a higher level overview, try: perf report --sort comm,dso) # [acme@emilia ~]$ Reported-by: Stephane Eranian <eranian@google.com> Suggested-by: David Miller <davem@davemloft.net> Cc: Dave Jones <davej@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/n/tip-mt512joaxxbhhp1odop04yit@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-05-24perf tools: Fix sample type size calculation in 32 bits archsFrederic Weisbecker
The shift used here to count the number of bits set in the mask doesn't work above the low part for archs that are not 64 bits. Fix the constant used for the shift. This fixes a 32-bit perf top failure reported by Eric Dumazet: Can't parse sample, err = -14 Can't parse sample, err = -14 ... Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com Link: http://lkml.kernel.org/r/1306200686-17317-1-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-23perf tools: Fix sample size bit operationsFrederic Weisbecker
What we want is to count the number of bits in the mask, not some other random operation written in the middle of the night. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1306148788-6179-2-git-send-email-fweisbec@gmail.com [ Fixed perf_event__names[] alignment which was nearby and hurting my eyes ... ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-22perf tools: Pre-check sample size before parsingFrederic Weisbecker
Check that the total size of the sample fields having a fixed size do not exceed the one of the whole event. This robustifies the sample parsing. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com>
2011-03-28perf symbols: Fix vsyscall symbol lookupAndrew Lutomirski
Perf can't currently trace into the vsyscall page. It looks like it was meant to work. Tested on 2.6.38 and today's -git. The bug is easy to reproduce. Compile this: int main() { int i; struct timespec t; for(i = 0; i < 10000000; i++) clock_gettime(CLOCK_MONOTONIC, &t); return 0; } and run it through perf record; perf report. The top entry shows "[unknown]" and you can't zoom in. It looks like there are two issues. The first is a that a test for user mode executing in kernel space is backwards. (That's the first hunk below). The second (I think) is that something's wrong with the code that generates lots of little struct dso objects for different sections -- when it runs on vmlinux it results in bogus long_name values which cause objdump to fail. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LPU-Reference: <AANLkTikxSw5+wJZUWNz++nL7mgivCh_Zf=2Kq6=f9Ce_@mail.gmail.com> Signed-off-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-05perf hists: Remove needless global col lenght calcsArnaldo Carvalho de Melo
To support multiple events we need to do these calcs per 'struct hists' instance, and it turns out we already do that at: __hists__add_entry hists__inc_nr_entries hists__calc_col_len for all the unfiltered hist_entry instances we stash in the rb tree, so trow away the dead code. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-11Merge remote branch 'acme/perf/urgent' into perf/coreArnaldo Carvalho de Melo
Fixups due to rename of event_t routines from event__ to perf_event__ done in perf/core. Conflicts: tools/perf/builtin-record.c tools/perf/builtin-top.c tools/perf/util/event.c tools/perf/util/event.h Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-10perf tools: Fix thread_map event synthesizing in top and recordArnaldo Carvalho de Melo
Jeff Moyer reported these messages: Warning: ... trying to fall back to cpu-clock-ticks couldn't open /proc/-1/status couldn't open /proc/-1/maps [ls output] [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.008 MB perf.data (~363 samples) ] That lead me and David Ahern to see that something was fishy on the thread synthesizing routines, at least for the case where the workload is started from 'perf record', as -1 is the default for target_tid in 'perf record --tid' parameter, so somehow we were trying to synthesize the PERF_RECORD_MMAP and PERF_RECORD_COMM events for the thread -1, a bug. So I investigated this and noticed that when we introduced support for recording a process and its threads using --pid some bugs were introduced and that the way to fix it was to instead of passing the target_tid to the event synthesizing routines we should better pass the thread_map that has the list of threads for a --pid or just the single thread for a --tid. Checked in the following ways: On a 8-way machine run cyclictest: [root@emilia ~]# perf record cyclictest -a -t -n -p99 -i100 -d50 policy: fifo: loadavg: 0.00 0.13 0.31 2/139 28798 T: 0 (28791) P:99 I:100 C: 25072 Min: 4 Act: 5 Avg: 6 Max: 122 T: 1 (28792) P:98 I:150 C: 16715 Min: 4 Act: 6 Avg: 5 Max: 27 T: 2 (28793) P:97 I:200 C: 12534 Min: 4 Act: 5 Avg: 4 Max: 8 T: 3 (28794) P:96 I:250 C: 10028 Min: 4 Act: 5 Avg: 5 Max: 96 T: 4 (28795) P:95 I:300 C: 8357 Min: 5 Act: 6 Avg: 5 Max: 12 T: 5 (28796) P:94 I:350 C: 7163 Min: 5 Act: 6 Avg: 5 Max: 12 T: 6 (28797) P:93 I:400 C: 6267 Min: 4 Act: 5 Avg: 5 Max: 9 T: 7 (28798) P:92 I:450 C: 5571 Min: 4 Act: 5 Avg: 5 Max: 9 ^C[ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.108 MB perf.data (~4719 samples) ] [root@emilia ~]# This will create one extra thread per CPU: [root@emilia ~]# tuna -t cyclictest -CP thread ctxt_switches pid SCHED_ rtpri affinity voluntary nonvoluntary cmd 28825 OTHER 0 0xff 2169 671 cyclictest 28832 FIFO 93 6 52338 1 cyclictest 28833 FIFO 92 7 46524 1 cyclictest 28826 FIFO 99 0 209360 1 cyclictest 28827 FIFO 98 1 139577 1 cyclictest 28828 FIFO 97 2 104686 0 cyclictest 28829 FIFO 96 3 83751 1 cyclictest 28830 FIFO 95 4 69794 1 cyclictest 28831 FIFO 94 5 59825 1 cyclictest [root@emilia ~]# So we should expect only samples for the above 9 threads when using the --dump-raw-trace|-D perf report switch to look at the column with the tid: [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 629 28825 110 28826 491 28827 308 28828 198 28829 621 28830 225 28831 203 28832 89 28833 [root@emilia ~]# So for workloads started by 'perf record' seems to work, now for existing workloads, just run cyclictest first, without 'perf record': [root@emilia ~]# tuna -t cyclictest -CP thread ctxt_switches pid SCHED_ rtpri affinity voluntary nonvoluntary cmd 28859 OTHER 0 0xff 594 200 cyclictest 28864 FIFO 95 4 16587 1 cyclictest 28865 FIFO 94 5 14219 1 cyclictest 28866 FIFO 93 6 12443 0 cyclictest 28867 FIFO 92 7 11062 1 cyclictest 28860 FIFO 99 0 49779 1 cyclictest 28861 FIFO 98 1 33190 1 cyclictest 28862 FIFO 97 2 24895 1 cyclictest 28863 FIFO 96 3 19918 1 cyclictest [root@emilia ~]# and then later did: [root@emilia ~]# perf record --pid 28859 sleep 3 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.027 MB perf.data (~1195 samples) ] [root@emilia ~]# To collect 3 seconds worth of samples for pid 28859 and its children: [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 15 28859 33 28860 19 28861 13 28862 13 28863 10 28864 11 28865 9 28866 255 28867 [root@emilia ~]# Works, last thing is to check if looking at just one of those threads also works: [root@emilia ~]# perf record --tid 28866 sleep 3 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.006 MB perf.data (~242 samples) ] [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 3 28866 [root@emilia ~]# Works too. Reported-by: Jeff Moyer <jmoyer@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf tools: Kill event_t typedef, use 'union perf_event' insteadArnaldo Carvalho de Melo
And move the event_t methods to the perf_event__ too. No code changes, just namespace consistency. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf tools: Rename 'struct sample_data' to 'struct perf_sample'Arnaldo Carvalho de Melo
Making the namespace more uniform. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf events: Account PERF_RECORD_LOST events in event__processArnaldo Carvalho de Melo
Right now this function is only used by perf top, that uses PROT_READ only, i.e. overwrite mode, so no PERF_RECORD_LOST events are generated, but don't forget those events. The patch that moved this out of perf top was made so that this routine could be used by 'perf probe' in the uprobes patchset, so perhaps there they need to check for LOST events and warn the user, as will be done in the following patches that will switch 'perf top' to non overwrite mode (mmap with PROT_READ|PROT_WRITE). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-24perf tools: Move event__parse_sample to evsel.cArnaldo Carvalho de Melo
To avoid linking more stuff in the python binding I'm working on, future csets will make the sample type be taken from the evsel itself, but for that we need to first have one file per cpu and per sample_type, not a single perf.data file. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf tools: Fix 64 bit integer format stringsArnaldo Carvalho de Melo
Using %L[uxd] has issues in some architectures, like on ppc64. Fix it by making our 64 bit integers typedefs of stdint.h types and using PRI[ux]64 like, for instance, git does. Reported by Denis Kirjanov that provided a patch for one case, I went and changed all cases. Reported-by: Denis Kirjanov <dkirjanov@kernel.org> Tested-by: Denis Kirjanov <dkirjanov@kernel.org> LKML-Reference: <20110120093246.GA8031@hera.kernel.org> Cc: Denis Kirjanov <dkirjanov@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pingtian Han <phan@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf symbols: Improve kallsyms symbol end addr calculationArnaldo Carvalho de Melo
For kallsyms we don't have the symbol address end, so we do an extra pass and set the symbol end addr as being the start of the next minus one. But this was being done just after we filtered the symbols of a particular type (functions, variables), so the symbol end was sometimes after what it really is. Fixing up symbol end also was falling apart when we have symbol aliases, then the end address of all but the last alias was being set to be before its start. Fix it up by checking for symbol aliases and making the kallsyms__parse routine use the next symbol, whatever its type, as the limit for the previous symbol, passing that end address to the callback. This was detected by the 'perf test' synthetic paranoid regression tests, fix it up so that even that case doesn't mislead us. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-09perf event: Prevent unbound event__name array accessThomas Gleixner
event__name[] is missing an entry for PERF_RECORD_FINISHED_ROUND, but we happily access the array from the dump code. Make event__name[] static and provide an accessor function, fix up all callers and add the missing string. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20101207124550.432593943@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-04perf tools: Ask for ID PERF_SAMPLE_ info on all PERF_RECORD_ eventsArnaldo Carvalho de Melo
So that we can use -T == --timestamp, asking for PERF_SAMPLE_TIME: $ perf record -aT $ perf report -D | grep PERF_RECORD_ <SNIP> 3 5951915425 0x47530 [0x58]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff8138c1a2 period: 215979 cpu:3 3 5952026879 0x47588 [0x90]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff810cb480 period: 215979 cpu:3 3 5952059959 0x47618 [0x38]: PERF_RECORD_FORK(6853:6853):(16811:16811) 3 5952138878 0x47650 [0x78]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff811bac35 period: 431478 cpu:3 3 5952375068 0x476c8 [0x30]: PERF_RECORD_COMM: find:6853 3 5952395923 0x476f8 [0x50]: PERF_RECORD_MMAP 6853/6853: [0x400000(0x25000) @ 0]: /usr/bin/find 3 5952413756 0x47748 [0xa0]: PERF_RECORD_SAMPLE(IP, 1): 6853/6853: 0xffffffff810d080f period: 859332 cpu:3 3 5952419837 0x477e8 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44600000(0x21d000) @ 0]: /lib64/ld-2.5.so 3 5952437929 0x47840 [0x48]: PERF_RECORD_MMAP 6853/6853: [0x7fff7e1c9000(0x1000) @ 0x7fff7e1c9000]: [vdso] 3 5952570127 0x47888 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f46200000(0x218000) @ 0]: /lib64/libselinux.so.1 3 5952623637 0x478e0 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44a00000(0x356000) @ 0]: /lib64/libc-2.5.so 3 5952675720 0x47938 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44e00000(0x204000) @ 0]: /lib64/libdl-2.5.so 3 5952710080 0x47990 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f45a00000(0x246000) @ 0]: /lib64/libsepol.so.1 3 5952847802 0x479e8 [0x58]: PERF_RECORD_SAMPLE(IP, 1): 6853/6853: 0xffffffff813897f0 period: 1142536 cpu:3 <SNIP> First column is the cpu and the second the timestamp. That way we can investigate problems in the event stream. If the new perf binary is run on an older kernel, it will disable this feature automatically. Tested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1291318772-30880-5-git-send-email-acme@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-04perf session: Parse sample earlierArnaldo Carvalho de Melo
At perf_session__process_event, so that we reduce the number of lines in eache tool sample processing routine that now receives a sample_data pointer already parsed. This will also be useful in the next patch, where we'll allow sample the identity fields in MMAP, FORK, EXIT, etc, when it will be possible to see (cpu, timestamp) just after before every event. Also validate callchains in perf_session__process_event, i.e. as early as possible, and keep a counter of the number of events discarded due to invalid callchains, warning the user about it if it happens. There is an assumption that was kept that all events have the same sample_type, that will be dealt with in the future, when this preexisting limitation will be removed. Tested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1291318772-30880-4-git-send-email-acme@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-27perf symbols: Correct final kernel map guessesIan Munsie
If a 32bit userspace perf is running on a 64bit kernel, the end of the final map in the kernel would incorrectly be set to 2^32-1 rather than 2^64-1. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290658375-10342-1-git-send-email-imunsie@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-04perf: expose event__process functionSrikar Dronamraju
The event__process function is useful in processing /proc/<pid>/maps. All of the functions that are called from event__process are defined in util/event.c. Though its defined in builtin-top.c, it could be reused for perf probe for uprobes. Hence moving it to util/event.c and exporting the function. LKML-Reference: <20100802123851.GD22812@linux.vnet.ibm.com> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-04perf events: Fix mmap offset determinationDave Martin
Fix buggy-looking code which unnecessarily adjusts the file offset fields read from /proc/*/maps. This may have gone unnoticed since the offset is usually 0 (and the logic in util/symbol.c may work incorrectly for other offset values). Commiter note: This fixes a bug introduced in 4af8b35, there is no need to shift pgoff twice, the show_map_vma routine in fs/proc/task_mmu.c already converts it from the number of pages to the size in bytes, and that is what appears in /proc/PID/map. Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Will Deacon <Will.Deacon@arm.com> LKML-Reference: <1280836116-6654-2-git-send-email-dave.martin@linaro.org> Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-30perf tools: Release session and symbol resources on exitArnaldo Carvalho de Melo
So that we reduce the noise when looking for leaks using tools such as valgrind. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-29perf symbols: Precisely specify if dso->{long,short}_name should be freedArnaldo Carvalho de Melo
2010-07-27perf report: Don't abbreviate file paths relative to the cwdDave Martin
This avoids around some problems where the full path is executables and DSOs it needed for finding debug symbols on platforms with separated debug symbol files such as Ubuntu. This is simpler than tracking an extra name for each image. The only impact should be that paths in verbose output from the perf tools become absolute, instead of relative to . LKML-Reference: <new-submission> Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-23perf sort: Make column width code per hists instanceArnaldo Carvalho de Melo
They were globals, and since we support multiple hists and sessions at the same time, it doesn't make sense to calculate those values considereing all symbols in all sessions. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-28Merge branch 'linus' into perf/coreThomas Gleixner
Reason: Further changes conflict with upstream fixes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-17perf session: Remove threads from tree on PERF_RECORD_EXITArnaldo Carvalho de Melo
Move them to a session->dead_threads list just like we do with maps that are replaced, because we may have hist_entries pointing to them. This fixes a bug when inserting maps for a new thread that reused the TID, mixing maps for two different threads, causing an endless loop. The code for insering maps should be made more robust but for .35 this is the minimalistic patch. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-05perf report: Implement --sort cpuArun Sharma
In a shared multi-core environment, users want to analyze why their program was slow. In particular, if the code ran slower only on certain CPUs due to interference from other programs or kernel threads, the user should be able to notice that. Sample usage: perf record -f -a -- sleep 3 perf report --sort cpu,comm Workload: program is running on 16 CPUs Experiencing interference from an antagonist only on 4 CPUs. Samples: 106218177676 cycles Overhead CPU Command ........ ... ............... 6.25% 2 program 6.24% 6 program 6.24% 11 program 6.24% 5 program 6.24% 9 program 6.24% 10 program 6.23% 15 program 6.23% 7 program 6.23% 3 program 6.23% 14 program 6.22% 1 program 6.20% 13 program 3.17% 12 program 3.15% 8 program 3.14% 0 program 3.13% 4 program 3.11% 4 antagonist 3.11% 0 antagonist 3.10% 8 antagonist 3.07% 12 antagonist Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100505181612.GA5091@sharma-home.net> Signed-off-by: Arun Sharma <aruns@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-05perf tools: Make event__preprocess_sample parse the sampleArnaldo Carvalho de Melo
Simplifying the tools that were using both in sequence and allowing upcoming simplifications, such as Arun's patch to sort by cpus. Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-05perf report: Make -D print sampled CPUStephane Eranian
It is useful to know on which CPU a sample was captured on. The information is captured with perf record -R but it was not printed out by perf report -D. This patch adds this. When -R is not used, cpu is set to -1to indicate that the CPU is unknown (it is not captured). Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4bff964c.e88cd80a.3106.7d31@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-01perf: Do the comm inheritance per thread in event__process_taskFrederic Weisbecker
event__process_task() doesn't propagate the comm copy on clone, but only on process fork. So we loose all the tid:comm resolution for tasks that aren't a main process thread. Progragate the per thread granularity to event__process_task for pid resolution. This fixes various unresolved pids in perf sched, especially when we trace multithread processes. The problem is quickly reproducible with the messaging benchmark using the multithread mode "-t" : perf sched record perf bench sched messaging -t Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Stephane Eranian <eranian@google.com>
2010-05-31perf: Process comm events by tidFrederic Weisbecker
When we synthetize the existing running tasks though procfs, we walk through every threads of a process, queuing one comm events per tid. But then on report time, event__process_comm() only creates and sets the comm on a per process granularity. This is the right thing for comm events that came from the kernel, as they are only created on exec. Sub-threads then inherit their comm from fork events. But that doesn't work with our synthetized comm events taken from procfs informations as the per thread granularity is done on comm events directly there. Hence we need event__process_comm() to work with the tid rather than the pid. It won't change anything for comm events coming from the kernel but this will fix the synthetized ones. Before: $ ./perf report -D | grep COMM | grep firefox 0x2c7b8 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c7d0 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c7e8 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c800 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c818 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c830 [0x18]: PERF_RECORD_COMM: firefox:5297 After: $ ./perf report -D | grep COMM | grep firefox 0x2c7b8 [0x18]: PERF_RECORD_COMM: firefox:5297 0x2c7d0 [0x18]: PERF_RECORD_COMM: firefox:5299 0x2c7e8 [0x18]: PERF_RECORD_COMM: firefox:5300 0x2c800 [0x18]: PERF_RECORD_COMM: firefox:5308 0x2c818 [0x18]: PERF_RECORD_COMM: firefox:5309 0x2c830 [0x18]: PERF_RECORD_COMM: firefox:5312 This fixes various unresolved pid on perf sched. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Stephane Eranian <eranian@google.com>
2010-05-14perf hist: Clarify events_stats fields usageArnaldo Carvalho de Melo
The events_stats.total field is too generic, rename it to .total_period, and also add a comment explaining that it is the sum of all the .period fields in samples, that is needed because we use auto-freq to avoid sampling artifacts. Ditto for events_stats.lost, that is the sum of all lost_event.lost fields, i.e. the number of events the kernel dropped. Looking at the users, builtin-sched.c can make use of these fields and stop doing it again. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf hist: Make event__totals per histsArnaldo Carvalho de Melo
This is one more thing that started global but are more useful per hist or per session. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf hist: Introduce hists class and move lots of methods to itArnaldo Carvalho de Melo
In cbbc79a we introduced support for multiple events by introducing a new "event_stat_id" struct and then made several perf_session methods receive a point to it instead of a pointer to perf_session, and kept the event_stats and hists rb_tree in perf_session. While working on the new newt based browser, I realised that it would be better to introduce a new class, "hists" (short for "histograms"), renaming the "event_stat_id" struct and the perf_session methods that were really "hists" methods, as they manipulate only struct hists members, not touching anything in the other perf_session members. Other optimizations, such as calculating the maximum lenght of a symbol name present in an hists instance will be possible as we add them, avoiding a re-traversal just for finding that information. The rationale for the name "hists" to replace "event_stat_id" is that we may have multiple sets of hists for the same event_stat id, as, for instance, the 'perf diff' tool has, so event stat id is not what characterizes what this struct and the functions that manipulate it do. Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-09perf session: Embed the host machine data on perf_sessionArnaldo Carvalho de Melo
We have just one host on a given session, and that is the most common setup right now, so embed a ->host_machine struct machine instance directly in the perf_session class, check if we're looking for it before going to the rb_tree. This also fixes a problem found when we try to process old perf.data files where we didn't have MMAP events for the kernel and modules and thus don't create the kernel maps, do it in event__preprocess_sample if it wasn't already. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Zhang, Yanmin <yanmin_zhang@linux.intel.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-09perf symbols: Check if a struct machine instance was foundArnaldo Carvalho de Melo
Which can happen when processing old files that had no fake kernel MMAP, events. That shouldn't result in perf_session__create_kernel_maps not being called, this will be fixed in a followup patch, for now do these checks to avoid segfaulting. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-09perf symbols: Consider unresolved DSOs in the dso__col_widt calculationArnaldo Carvalho de Melo
By using BITS_PER_LONG / 4, that is the number of chars that will be used in such cases as the DSO "name". Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-05perf report: Make dso__calc_col_width agree with hist_entry__dso_snprintfArnaldo Carvalho de Melo
The first was always using the ->long_name, while the later used ->short_name if verbose was not set, resulting in the dso column to be much wider than needed most of the time. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-04perf: Fix performance issue with perf reportAnton Blanchard
On a large machine we spend a lot of time in perf_header__find_attr when running perf report. If we are parsing a file without PERF_SAMPLE_ID then for each sample we call perf_header__find_attr and loop through all counter IDs, never finding a match. As the machine gets larger there are more per cpu counters and we spend an awful lot of time in there. The patch below initialises each sample id to -1ULL and checks for this in perf_header__find_attr. We may need to do something more intelligent eventually (eg a hash lookup from counter id to attr) but this at least fixes the most common usage of perf report. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Acked-by: Eric B Munson <ebmunson@us.ibm.com> LKML-Reference: <20100504111915.GB14636@kryten> Signed-off-by: Anton Blanchard <anton@samba.org> -- Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
