path: root/tools/perf/util/trace-event-parse.c
2009-10-12perf tools: Fix const char type propagationRandy Dunlap
The following perf build warnings/errors in function argument types: builtin-sched.c:1894: warning: passing argument 1 of 'sort_dimension__add' discards qualifiers from pointer target type util/trace-event-parse.c:685: warning: passing argument 2 of 'read_expected' discards qualifiers from pointer target type util/trace-event-parse.c:741: warning: passing argument 4 of 'test_type_token' discards qualifiers from pointer target type util/trace-event-parse.c:706: warning: passing argument 2 of 'read_expected_item' discards qualifiers from pointer target type ... trigger because older GCC is not able to prove that sort_dimension__add() does not change the string. Some goes for test_type_token(). Fix this by improving type consistency. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091005131729.78444bfb.randy.dunlap@oracle.com> [ Also remove ugly type cast now unnecessary. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Update eval_flag() flags array to match interrupt.hTom Zanussi
Add missing BLOCK_IOPOLL_SOFTIRQ entry. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-14perf tools: Implement counter output multiplexingIngo Molnar
Finish the -M/--multiplex option implementation: - separate it out from group_fd - correctly set it via the ioctl and dont mmap counters that are multiplexed - modify the perf record event loop to deal with buffer-less counters. - remove the -g option from perf sched record - account for unordered events in perf sched latency - (add -f to perf sched record to ease measurements) - skip idle threads (pid==0) in latency output The result is better latency output by 'perf sched latency': ----------------------------------------------------------------------------------- Task | Runtime ms | Switches | Average delay ms | Maximum delay ms | ----------------------------------------------------------------------------------- ksoftirqd/8 | 0.071 ms | 2 | avg: 0.458 ms | max: 0.913 ms | at-spi-registry | 0.609 ms | 19 | avg: 0.013 ms | max: 0.023 ms | perf | 3.316 ms | 16 | avg: 0.013 ms | max: 0.054 ms | Xorg | 0.392 ms | 19 | avg: 0.011 ms | max: 0.018 ms | sleep | 0.537 ms | 2 | avg: 0.009 ms | max: 0.009 ms | ----------------------------------------------------------------------------------- TOTAL: | 4.925 ms | 58 | --------------------------------------------- Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf sched: Fix bad event alignmentFrederic Weisbecker
perf sched raises the following error when it meets a sched switch event: perf: builtin-sched.c:286: register_pid: Assertion `!(pid >= 65536)' failed. Abandon Currently in x86-64, the sched switch events have a hole in the middle of the structure: u16 common_type; u8 common_flags; u8 common_preempt_count; u32 common_pid; u32 common_tgid; char prev_comm[16]; u32 prev_pid; u32 prev_prio; <--- there u64 prev_state; char next_comm[16]; u32 next_pid; u32 next_prio; Gcc inserts a 4 bytes hole there for prev_state to be u64 aligned. And the events are exported to userspace with this hole. But in userspace, from perf sched, we fetch it using a structure that has a new field in the beginning: u32 size. This is because our trace is exported with its size as a field. But now that we have this new field, the hole in the middle disappears because it makes prev_state becoming well aligned. And since we are using a pointer to the raw trace using this struct, instead of reading prev_state, we are reading the hole. We could fix it by keeping the size seperate from the struct but actually there a lot of other potential problems: some fields may be saved as long in a 64 bits system and later read as long in a 32 bits system. Also this direct cast doesn't care about the endianness differences between the host traced machine and the machine in which we do the post processing. So instead of using such dangerous direct casts, fetch the values using the trace parsing API that already takes care of all these problems. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf sched: Import schedbench.cIngo Molnar
Import the schedbench.c tool that i wrote some time ago to simulate scheduler behavior but never finished. It's a good basis for perf sched nevertheless. Most of its guts are not hooked up to the perf event loop yet - that will be done in the patches to come. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Print out in nanosecondsIngo Molnar
Print out more accurate timestamps - usecs does not cut it anymore on fast enough boxes ;-) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-02perf tools: Work around strict aliasing related warningsIngo Molnar
Older versions of GCC are rather stupid about strict aliasing: util/trace-event-parse.c: In function 'parse_cmdlines': util/trace-event-parse.c:93: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c: In function 'parse_proc_kallsyms': util/trace-event-parse.c:155: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:157: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:158: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c: In function 'parse_ftrace_printk': util/trace-event-parse.c:294: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:295: warning: dereferencing type-punned pointer will break strict-aliasing rules make: *** [util/trace-event-parse.o] Error 1 Make it clear to GCC that we intend with those pointers, by passing them through via an explicit (void *) cast. We might want to add -fno-strict-aliasing as well, like the kernel itself does. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-31perf tools: Complete support for dynamic stringsFrederic Weisbecker
Complete support for __str_loc type strings of ftrace events which have dynamic offsets values set for each of them inside their sammples. Before: geany-5759 [000] 0.000000: lock_release: name geany-5759 [000] 0.000000: lock_release: name geany-5759 [000] 0.000000: lock_release: name kondemand/0-362 [000] 0.000000: lock_release: name pdflush-421 [000] 0.000000: lock_release: name After: geany-5759 [000] 0.000000: lock_release: &u->lock geany-5759 [000] 0.000000: lock_release: key geany-5759 [000] 0.000000: lock_release: &group->notification_mutex kondemand/0-362 [000] 0.000000: lock_release: &rq->lock pdflush-421 [000] 0.000000: lock_release: &rq->lock Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251693921-6579-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2009-08-28perf tools: Fix missing string field printing in perf traceFrederic Weisbecker
Some string fields are not printed because of a missing printf in the post-processing. Before: perf-10070 [000] 0.000000: sched_switch: task :10070 [120] (R) ==> :5720 [120] geany-5720 [000] 0.000000: sched_switch: task :5720 [120] (S) ==> :10070 [120] perf-10070 [000] 0.000000: sched_switch: task :10070 [120] (R) ==> :5720 [120] geany-5720 [000] 0.000000: sched_switch: task :5720 [120] (S) ==> :10070 [120] <idle>-0 [000] 0.000000: sched_switch: task :0 [140] (R) ==> :361 [115] After: perf-10070 [000] 0.000000: sched_switch: task perf:10070 [120] (R) ==> geany:5720 [120] geany-5720 [000] 0.000000: sched_switch: task geany:5720 [120] (S) ==> perf:10070 [120] perf-10070 [000] 0.000000: sched_switch: task perf:10070 [120] (R) ==> geany:5720 [120] geany-5720 [000] 0.000000: sched_switch: task geany:5720 [120] (S) ==> perf:10070 [120] <idle>-0 [000] 0.000000: sched_switch: task swapper:0 [140] (R) ==> kondemand/1:361 [115] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251427567-10551-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-28perf tools: Only save the event formats we needFrederic Weisbecker
While opening a trace event counter, every events are saved in the trace.info file. But we only want to save the specifications of the events we are using. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251421798-9101-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-18perf tools: Make trace event format parser aware of cast to pointersFrederic Weisbecker
The ftrace event format parser handles the usual casts but not the cast to pointers. Such casts have been introduced recently with the module trace events and raise the following parsing error: Fatal: bad op token ) This is because it considers the "*" character as a binary operator. Make it then aware of casts to pointers. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1250543271-8383-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17perf tools: Add trace event information parserSteven Rostedt
Add util/trace-event-parse.c which provides the handlers to parse the ftrace events info from the stream and handles the ftrace perf samples event printing. This file is a rename of the parse-events.c file from the trace-cmd tools, written by Steven Rostedt and Josh Triplett, originated from the git tree: git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/trace-cmd.git This is a perf tools integration. [ fweisbec@gmail.com: various changes for perf tools integration. ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Clark Williams <williams@redhat.com> Cc: Jon Masters <jonathan@jonmasters.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Anton Blanchard <anton@samba.org> LKML-Reference: <1250518688-7207-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
