commit d06c27b22aa66e48e32f03f9387328a9af9b0625 upstream.
A update is made to the sched:sched_switch event that adds some
logic to the first parameter of the __print_flags() that shows the
state of tasks. This change cause perf to fail parsing the flags.
A simple fix is needed to have the parser be able to process ops
within the argument.
Reported-by: Andrew Vagin <avagin@openvz.org>
commit 44a56040a0037a845d5fa218dffde464579f0cab upstream.
Fix perf probe to show correct error string when it
fails to delete an event. The write(2) returns -1
if failed, and errno stores real error number.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20111004104504.14591.41266.stgit@fedora15
Wrong pointer is being passed for raw data sanity checking, when parsing
sample event.
This ends up with invalid event and perf record being stuck in
__perf_session__process_events function during processing build IDs
(process_buildids function).
Following command hangs up in my setup:
./perf record -e raw_syscalls:sys_enter ls
The fix is to use proper pointer to the raw data instead of the 'u'
union.
Reviewed-by: David Ahern <dsahern@gmail.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Link: http://lkml.kernel.org/r/1317308709-9474-2-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Problem introduced in 936be50, that missed one perf_event__parse_sample
user, the python binding.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-ja4phms9618ggi657plyuch2@git.kernel.org
GCC often introduces new warnings with lots of false positives -
breaking -Werror builds. WERROR=0 allows one to build perf without much
fuss - while still encouraging people to send patches to avoid the fuss
of having to type WERROR=0.
Bisecting back to commits that produce a (mostly harmless) warning on
some compilers is more difficult. With WERROR=0 one could bisect without
worrying about harmless warnings.
Link: http://lkml.kernel.org/r/eac06c7cc4920e5d4830417d466161fb26c7359c.1315514559.git.dvhart@linux.intel.com
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
The 'perf top' tool came from the kernel where we had each DSO (vmlinux,
modules) loaded just once at a time.
But userspace may have DSOs loaded in multiple addresses (shared
libraries), requiring that we use the just resolved map instead of the
first one found.
Link: http://lkml.kernel.org/n/tip-ag53wz0yllpgers0n2w7hchp@git.kernel.org
Buildid can vary in size. According to the man page of ld, buildid can
be 160 bits (sha1) or 128 bits (md5, uuid). Perf assumes buildid size of
20 bytes (160 bits) regardless. When dealing with md5 buildids, it would
thus read more than needed and that would cause mismatches and samples
without symbols.
This patch fixes this by taking into account the actual buildid size as
encoded int he section header. The leftover bytes are also cleared.
This second version fixes a minor issue with the memset() base position.
Cc: Robert Richter <robert.richter@amd.com>
Cc: Stephane Eranian <eranian@gmail.com>
Link: http://lkml.kernel.org/r/4cc1af3c.8ee7d80a.5a28.ffff868e@mx.google.com
Signed-off-by: Stephane Eranian <eranian@google.com>
Currently, analyzing PPC data files on x86 the cpu field is always 0 and
the tid and pid are backwards. For example, analyzing a PPC file on PPC
the pid/tid fields show:
rsyslogd 1210/1212
and analyzing the same PPC file using an x86 perf binary shows:
rsyslogd 1212/1210
The problem is that the swap_op method for samples is
perf_event__all64_swap which assumes all elements in the sample_data
struct are u64s. cpu, tid and pid are u32s and need to be handled
individually. Given that the swap is done before the sample is parsed,
the simplest solution is to undo the 64-bit swap of those elements when
the sample is parsed and do the proper swap.
The RAW data field is generic and perf cannot have programmatic knowledge
of how to treat that data. Instead a warning is given to the user.
Thanks to Anton Blanchard for providing a data file for a mult-CPU
PPC system so I could verify the fix for the CPU fields.
v3 -> v4:
- fixed use of WARN_ONCE
v2 -> v3:
- used WARN_ONCE for message regarding raw data
- removed struct wrapper around union
- fixed whitespace issues
v1 -> v2:
- added a union for undoing the byte-swap on u64 and redoing swap on
u32's to address compiler errors (see git commit 65014ab3)
Link: http://lkml.kernel.org/r/1315321946-16993-1-git-send-email-dsahern@gmail.com
Signed-off-by: David Ahern <dsahern@gmail.com>
I took a profile that suggested 60% of total CPU time was in the
hypervisor:
60.20% [H] 0x33d43c
4.43% [k] ._spin_lock_irqsave
1.07% [k] ._spin_lock
Using perf stat to get the user/kernel/hypervisor breakdown contradicted
this.
The problem is we merge all unresolved samples into the one unknown
bucket. If add a comparison by sample type to sort__sym_cmp we get the
real picture:
57.11% [.] 0x80fbf63c
0.65% [H] 0x33d43c
So it was almost all userspace, not hypervisor as the initial profile
suggested.
I found another issue while adding this. Symbol sorting sometimes shows
multiple entries for the unknown bucket:
16.65% [.] 0x6cd3a8
7.25% [.] 0x422460
5.37% [.] yylex
4.79% [.] malloc
4.78% [.] _int_malloc
4.03% [.] _int_free
3.95% [.] hash_source_code_string
2.82% [.] 0x532908
2.64% [.] 0x36b538
0.94% [H] 0x8000000000e132a4
0.82% [H] 0x800000000000e8b0
This happens because we aren't consistent with our sorting. On
one hand we check to see if both symbols match and for two unresolved
samples sym is NULL so we match:
if (left->ms.sym == right->ms.sym)
return 0;
On the other hand we use sample IP for unresolved samples when
comparing against a symbol:
ip_l = left->ms.sym ? left->ms.sym->start : left->ip;
ip_r = right->ms.sym ? right->ms.sym->start : right->ip;
This means unresolved samples end up spread across the rbtree and we
can't merge them all.
If we use cmp_null all unresolved samples will end up in the one bucket
and the output makes more sense:
39.12% [.] 0x36b538
5.37% [.] yylex
4.79% [.] malloc
4.03% [.] _int_free
2.26% [H] 0x800000000000e8b0
Acked-by: Eric B Munson <emunson@mgebm.net>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Ian Munsie <imunsie@au1.ibm.com>
Link: http://lkml.kernel.org/r/20110831115145.4f598ab2@kryten
perf_event__synthesize_mmap_events does not create anonymous mmap events
even though the kernel does. As a result an already running application
with dynamically created code will not get profiled - all samples end up
in the unknown bucket.
This patch skips any entries with '[' in the name to avoid adding events
for special regions (eg the vsyscall page). All other executable mmaps
are assumed to be anonymous and an event is synthesized.
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Link: http://lkml.kernel.org/r/20110830091506.60b51fe8@kryten
perf-record currently creates events enabled. When doing a system wide
collection (-a arg) this causes data collection for perf's
initialization activities -- eg., perf_event__synthesize_threads().
For some events (e.g., context switch S/W event or tracepoints like
syscalls) perf's initialization causes a lot of events to be captured
frequently generating "Check IO/CPU overload!" warnings on larger
systems (e.g., 2 socket, quad core, hyperthreading).
perf's initialization phase can be skipped by creating events
disabled and then enabling them once the initialization is done.
Link: http://lkml.kernel.org/r/1314289075-14706-1-git-send-email-dsahern@gmail.com
Try and pick the best symbol based on a few heuristics:
- Prefer a non weak symbol over a weak one
- Prefer a global symbol over a non global one
- Prefer a symbol with less underscores (idea taken from kallsyms.c)
- If all else fails, choose the symbol with the longest name
Link: http://lkml.kernel.org/r/20110824065243.161953371@samba.org
kallsyms__parse capitalises the symbol type, so every symbol is marked
global. Remove this and fix symbol_type__is_a to handle both local and
global symbols.
Link: http://lkml.kernel.org/r/20110824065243.077125989@samba.org
kallsyms__parse assumes that /proc/kallsyms is sorted and sets the end
of the previous symbol to the start of the current one.
Unfortunately module symbols are not sorted, eg:
ffffffffa0081f30 t e1000_clean_rx_irq [e1000e]
ffffffffa00817a0 t e1000_alloc_rx_buffers [e1000e]
Some symbols end up with a negative length and others have a length
larger than they should. This results in confusing perf output.
We already have a function to fixup the end of zero length symbols so
use that instead.
Link: http://lkml.kernel.org/r/20110824065242.969681349@samba.org
64bit PowerPC debuginfo files have an empty function descriptor section.
I hit a SEGV when perf tried to use this section for symbol resolution.
To fix this we need to check the section is valid and we can do this by
checking for type SHT_PROGBITS.
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/20110824065242.895239970@samba.org
Fix to call convert_variable() if previous call does not fail.
To call convert_variable, it ensures "ret" is 0. However, since
"ret" has the return value of synthesize_perf_probe_arg() which
always returns positive value if it succeeded, perf probe doesn't
call convert_variable(). This will cause a SEGV when we add an
event with arguments.
This has to be fixed as it ensures "ret" is greater than 0
(or not negative).
This regression has been introduced by my previous patch, f182e3e1.
Cc: Pekka Enberg <penberg@kernel.org>
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20110820053922.3286.65805.stgit@fedora15
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: pm: avoid writing the auxillary control register for ARMv7
ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness
ARM: pm: arm920/926: fix number of registers saved
ARM: pm: CPU specific code should not overwrite r1 (v:p offset)
ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU
ARM: 7065/1: kexec: ensure new kernel is entered in ARM state
ARM: 7003/1: vexpress: Add clock definition for the SP805.
ARM: 7051/1: cpuimx* boards: fix mach-types errors
ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER
ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled
ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation.
ARM: 6967/1: ep93xx: ts72xx: fix board model detection
ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards
ARM: cache: detect VIPT aliasing I-cache on ARMv6
ARM: twd: register clockevents device before enabling PPI
ARM: realview: ensure visibility of writes during reset
ARM: perf: make name of arm_pmu_type consistent
ARM: perf: fix prototype of release_pmu
ARM: fix perf build with uclibc toolchains
Group event scheduling command line option is missing in perf
record/stat.
Add it to perf record/stat, which is same as in perf top.
Reported-by: Andi Kleen <andi@firstfloor.org>
Link: http://lkml.kernel.org/r/1313577727.2754.5.camel@hp6530s
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Upstream glibc commit 295e904 added a definition for __attribute_const__
to cdefs.h. This causes the following error when building perf:
util/include/linux/compiler.h:8:0: error: "__attribute_const__"
redefined [-Werror] /usr/include/sys/cdefs.h:226:0: note: this is the
location of the previous definition
Wrap __attribute_const__ in #ifndef as we do for __always_inline.
Link: http://lkml.kernel.org/r/20110818113720.GL2227@zod.bos.redhat.com
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
There was a problem with the parse_events() code not printing the
correct event name when an event was unknown and starting with an 'r'.
The source of the problem was the way raw notation was parsed.
Without the patch:
$ perf stat -e retired_foo
invalid event modifier: 'tired_foo'
With the patch:
invalid or unsupported event: 'retired_foo'
This also covers the case where the name of the event was not printed at
all when perf was linked with libpfm4.
Link: http://lkml.kernel.org/r/20110723021043.GA20178@quad
When no event is given to perf record, perf top, a default event is
initialized (cycles). However, perf_evlist__add_default() was not
setting the symbolic name for the event. Perf top worked simply because
it was reconstructing the name from the event code. But it should not
have to do this. This patch initializes the evsel->name field properly.
This second version improves the code flow on the non error path.
Link: http://lkml.kernel.org/r/20110607161936.GA8163@quad
[committer note: Use perf_evsel__delete() instead of plain free()]
This patch fixes an issue with the exit value of perf list:
$ perf list; echo $?
129
perf list returns an error exit code even though there is no error.
There was a stray exit(129) in print_events(). This patch removes this
exit().
0
$ perf list hw sw
cpu-cycles OR cycles [Hardware event]
stalled-cycles-frontend OR idle-cycles-frontend [Hardware event]
stalled-cycles-backend OR idle-cycles-backend [Hardware event]
instructions [Hardware event]
cache-references [Hardware event]
cache-misses [Hardware event]
branch-instructions OR branches [Hardware event]
branch-misses [Hardware event]
bus-cycles [Hardware event]
cpu-clock [Software event]
task-clock [Software event]
page-faults OR faults [Software event]
minor-faults [Software event]
major-faults [Software event]
context-switches OR cs [Software event]
cpu-migrations OR migrations [Software event]
alignment-faults [Software event]
emulation-faults [Software event]
$ echo $?
0
Link: http://lkml.kernel.org/r/20110523123917.GA31060@quad
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
libio.h is not provided by uClibc, in order to be able to test the
definition of __UCLIBC__ we need to include stdlib.h, which also
includes stddef.h, providing the definition of 'NULL'.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
With gcc4.6, some instances of concrete inlined function looks redundant
and broken, because it appears inside of a concrete instance and its
call_file and call_line are same as the original abstruct's decl_file
and decl_line respectively.
e.g.
[ d1aa] subprogram
external (flag) Yes
name (strp) "add_timer"
decl_file (data1) 2 ;here is original
decl_line (data2) 847 ;line and file
prototyped (flag) Yes
inline (data1) inlined (1)
sibling (ref4) [ d1c6]
[ 11d84] subprogram
abstract_origin (ref4) [ d1aa] ; concrete instance
low_pc (addr) .text+0x000000000000246f <add_timer>
high_pc (addr) .text+0x000000000000248b <mod_timer_pending>
frame_base (block1) [ 0] call_frame_cfa
sibling (ref4) [ 11dd9]
[ 11d9f] formal_parameter
abstract_origin (ref4) [ d1b9]
location (data4) location list [ 701b]
[ 11da8] inlined_subroutine
abstract_origin (ref4) [ d1aa] ; redundant instance
low_pc (addr) .text+0x000000000000247e <add_timer+0xf>
high_pc (addr) .text+0x0000000000002480 <add_timer+0x11>
call_file (data1) 2 ; call line and file
call_line (data2) 847 ; are same as above
Those redundant instances leads unwilling results;
e.g. find probe points inside of functions even if we specify
a function entry as below;
$ perf probe -V add_timer
Available variables at add_timer
@<add_timer+0>
struct timer_list* timer
@<add_timer+15>
(No matched variables)
So, this filters out those redundant instances based on call-site and
decl-site information.
Link: http://lkml.kernel.org/r/20110811110317.19900.59525.stgit@fedora15
gcc 4.6 generates a concrete out-of-line instance when there is a
function which is implicitly inlined somewhere but also has its own
instance. The concrete out-of-line instance means that it has an
abstract origin of the function which is referred by not only
inlined-subroutines but also a concrete subprogram.
Since current dwarf_func_inline_instances() can find only instances of
inlined-subroutines, this introduces new die_walk_instances() to find
both of subprogram and inlined-subroutines.
e.g. without this,
Available variables at sched_group_rt_period
@<cpu_rt_period_read_uint+9>
struct task_group* tg
perf probe failed to find actual subprogram instance of
sched_group_rt_period().
With this,
@<sched_group_rt_period+0>
Now it found the sched_group_rt_period() itself.
Link: http://lkml.kernel.org/r/20110811110311.19900.63997.stgit@fedora15
Fix variable searching logic to search one in inner than local scope or
global(CU) scope. In the other words, skip searching in intermediate
scopes.
e.g., in the following code,
int var1;
void inline infunc(int i)
i++; <--- [A]
void func(void)
int var1, var2;
infunc(var2);
At [A], "var1" should point the global variable "var1", however, if user
mis-typed as "var2", variable search should be failed. However, current
logic searches variable infunc() scope, global scope, and then func()
scope. Thus, it can find "var2" variable in func() scope. This may not
be what user expects.
So, it would better not search outer scopes except outermost (compile
unit) scope which contains only global variables, when it failed to find
given variable in local scope.
E.g.
Without this:
$ perf probe -V pre_schedule --externs > without.vars
With this:
$ perf probe -V pre_schedule --externs > with.vars
Check the diff:
$ diff without.vars with.vars
88d87
< int cpu
133d131
< long unsigned int* switch_count
These vars are actually in the scope of schedule(), the caller of
pre_schedule().
Link: http://lkml.kernel.org/r/20110811110305.19900.94374.stgit@fedora15
Fix perf probe to search local variables in appropriate local inlined
function scope. For example, pre_schedule() has only 2 local variables,
as below;
$ perf probe -L pre_schedule
<pre_schedule@/home/mhiramat/ksrc/linux-2.6/kernel/sched.c:0>
0 static inline void pre_schedule(struct rq *rq, struct task_struct *prev)
2 if (prev->sched_class->pre_schedule)
3 prev->sched_class->pre_schedule(rq, prev);
However, current perf probe shows 4 local variables on pre_schedule(),
because it searches variables in the caller(schedule()) scope.
Available variables at pre_schedule
@<schedule+445>
int cpu
struct rq* rq
struct task_struct* prev
This patch fixes this issue by searching variables in the local scope of
the instance of inlined function. Here is the result.
@<schedule+445>
struct rq* rq
Link: http://lkml.kernel.org/r/20110811110259.19900.85664.stgit@fedora15
Check multiple --lines option and print warning informing that only the
first specified --line option is valid.
Changes from the 1st post:
- Accept only the first option instead of the last.
- Fix warning message according to David's comment.
- Mark as a bugfix.
Link: http://lkml.kernel.org/r/20110811110253.19900.96192.stgit@fedora15
Fix line-range collector to walk all instances of inlined function,
because some execution paths can be optimized out depending on the
function argument of instances.
E.g.)
inline_func (arg) {
if (arg)
do_something;
else
do_another;
func_A() {
inline_func(1)
func_B() {
inline_func(0)
In this case, func_A may have only do_something code and func_B may have
only do_another.
Cc: Masami Hiramatsu <masami.hiramatsu@gmail.com>
Link: http://lkml.kernel.org/r/20110811110247.19900.93702.stgit@fedora15
Signed-off-by: Masami Hiramatsu <masami.hiramatsu@gmail.com>
Fix perf probe to walk through the lines of all nested inlined function
call sites and declared lines when a whole CU is passed to the line
walker.
The die_walk_lines() can have two different type of DIEs, subprogram (or
inlined-subroutine) DIE and CU DIE.
If a caller passes a subprogram DIE, this means that the walker walk on
lines of given subprogram. In this case, it just needs to search on
direct children of DIE tree for finding call-site information of inlined
function which directly called from given subprogram.
On the other hand, if a caller passes a CU DIE to the walker, this means
that the walker have to walk on all lines in the source files included
in given CU DIE. In this case, it has to search whole DIE trees of all
subprograms to find the call-site information of all nested inlined
functions.
Without this patch:
$ perf probe --line kernel/cpu.c:151-157
</home/mhiramat/ksrc/linux-2.6/kernel/cpu.c:151>
static int cpu_notify(unsigned long val, void *v)
154 return __cpu_notify(val, v, -1, NULL);
With this:
152 static int cpu_notify(unsigned long val, void *v)
As you can see, --line option with source line range shows the declared
lines as probe-able.
Link: http://lkml.kernel.org/r/20110811110241.19900.34994.stgit@fedora15
Fix line walker to check whether a given DIE is CU or not.
Actually this function accepts CU, subprogram and inlined_subroutine
DIEs.
Without this fix, perf probe always fails to analyze lines on inlined
functions;
Debuginfo analysis failed. (-2)
Error: Failed to show lines. (-2)
This fixes that bug, as below.
/* rq->lock is NOT held, but preemption is disabled */
Changes from v1:
- Update against current tip tree.(Fix dwarf-aux.c)
Link: http://lkml.kernel.org/r/20110811110235.19900.20614.stgit@fedora15
Fix a memory leak for scopes array when it finds a variable in the
global scope.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/20110811110229.19900.63019.stgit@fedora15
A file in /tmp/ might be a symlink, so lstat() should be used instead of
stat().
Link: http://lkml.kernel.org/r/20110811205537.GA22864@albatros
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
If we bring the recorded perf data together with kernel binary from another
machine using:
on server A:
perf archive
on server B:
tar xjvf perf.data.tar.bz2 -C ~/.debug
the build_id kernel dso is not properly recognized during the "perf report"
command on server B.
The reason is, that build_id dsos are added during the session initialization,
while the kernel maps are created during the sample event processing.
The machine__create_kernel_maps functions ends up creating new dso object for
kernel, but it does not check if we already have one added by build_id
processing.
Also the build_id reading ABI quirk added in commit:
- commit b25114817a73bbd2b84ce9dba02ee1ef8989a947
perf build-id: Add quirk to deal with perf.data file format breakage
populates the "struct build_id_event::pid" with 0, which
is later interpreted as DEFAULT_GUEST_KERNEL_ID.
This is not always correct, so it's better to guess the pid
value based on the "struct build_id_event::header::misc" value.
- Tested with data generated on x86 kernel version v2.6.34
and reported back on x86_64 current kernel.
- Not tested for guest kernel case.
Note the problem stays for PERF_RECORD_MMAP events recorded by perf that
does not use proper pid (HOST_KERNEL_ID/DEFAULT_GUEST_KERNEL_ID). They are
misinterpreted within the current perf code. Probably there's not much we
can do about that.
Cc: Avi Kivity <avi@redhat.com>
Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Link: http://lkml.kernel.org/r/20110601194346.GB1934@jolsa.brq.redhat.com
It will be immediately replaced in perf_top_browser__run.
Link: http://lkml.kernel.org/n/tip-q7e2jzb44elqpkvdllk94x0i@git.kernel.org
The external symbol files are generated by JIT compilers, for example, but we
need to make sure they're ours before injecting them to 'perf report'.
Requested-by: Ingo Molnar <mingo@elte.hu>
Link: http://lkml.kernel.org/r/1312919658-17158-1-git-send-email-penberg@kernel.org
Signed-off-by: Pekka Enberg <penberg@kernel.org>
The 'perf sched' command usage still showing 'trace' command instead of
the 'script' command.
Link: http://lkml.kernel.org/r/20110809124651.GD2056@jolsa.brq.redhat.com
The session object is released prematurely when processing events for
latency command. The session's thread objects are used within the
output_lat_thread function.
Runnning following commands:
# perf sched record
# perf sched latency
the latter displays incorrect data and might cause access violation.
Link: http://lkml.kernel.org/r/1312837414-3819-1-git-send-email-jolsa@redhat.com
Just like we do already for perf.data files.
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Christian Ohm <chr.ohm@gmx.net>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Link: http://lkml.kernel.org/n/tip-qgokmxsmvppwpc5404qhyk7e@git.kernel.org
Adding install-python_ext target to install python extension related
files. Installation directory is governed by python distutils package
and follows the DESTDIR variable settings.
Also moving python extension build output into '$(O)python_ext_build'
directory and making it configurable via PYTHON_EXTBUILD variable.
Keeping the '$(O)python/perf.so' file, so it could be used for testing
as of until now.
Link: http://lkml.kernel.org/r/20110722113307.GA1931@jolsa.brq.redhat.com
In addition to /etc/perfconfig and $HOME/.perfconfig, perf looks for
configuration in the file ./config, imitating git which looks at
$GIT_DIR/config. If ./config is not a perf configuration file, it
fails, or worse, treats it as a configuration file and changes behavior
in some unexpected way.
"config" is not an unusual name for a file to be lying around and perf
does not have a private directory dedicated for its own use, so let's
just stop looking for configuration in the cwd. Callers needing
context-sensitive configuration can use the PERF_CONFIG environment
variable.
Requested-by: Christian Ohm <chr.ohm@gmx.net>
Cc: 632923@bugs.debian.org
Link: http://lkml.kernel.org/r/20110805165838.GA7237@elie.gateway.2wire.net
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Use LIB_OBJS and BUILTIN_OBJS for .o files.
LIB_FILE is already prefixed with OUTPUT.
Link: http://lkml.kernel.org/r/20110807083932.9C0E514C03B@msa103.auone-net.jp
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Looks to me like the :r modifier is not supported anymore, so remove it
from the list of events. Without this fix 'perf lock record' doesn't
work.
Cc: Zhu Yanhai <gaoyang.zyh@taobao.com>
Link: http://lkml.kernel.org/r/1312035232-9534-1-git-send-email-gaoyang.zyh@taobao.com
Signed-off-by: Zhu Yanhai <gaoyang.zyh@taobao.com>
perf will coredump if the user doesn't give the "-m" option in probe
command, this patch fixes it.
[root@localhost perf]# ./perf probe --add='PROBE'
Segmentation fault (core dumped)
Link: http://lkml.kernel.org/r/1311602888-2389-1-git-send-email-bookjovi@gmail.com
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
So that we get a proper warning in the TUI in cases like:
$ perf report --stdio -g fractal,0.5,caller --sort pid
Selected -g but no callchain data. Did you call 'perf record' without -g?
The --stdio case is ok because it uses fprintf, ui__warning is needed to
figure out if --stdio or --tui is being used.
Cc: Arun Sharma <asharma@fb.com>
Cc: Sam Liao <phyomh@gmail.com>
Link: http://lkml.kernel.org/n/tip-ag9fz2wd17mbbfjsbznq1wms@git.kernel.org
