Fix a bug to support %return probe syntax again. Previous commit 4235b04 has a
bug which disables the %return syntax on perf probe.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20100827113852.22882.87447.stgit@ltc236.sdl.hitachi.co.jp>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Add a perf script which shows packets processing and processed
time. It helps us to investigate networking or network devices.
If you want to use it, install perf and record perf.data like
following.
If you set script, perf gathers records until it ends.
If not, you must Ctrl-C to stop recording.
And if you want a report from record,
If you use some options, you can limit the output.
Option is below.
tx: show only tx packets processing
rx: show only rx packets processing
dev=: show processing on this device
debug: work with debug mode. It shows buffer status.
For example, if you want to show received packets processing
associated with eth4,
106133.171439sec cpu=0
irq_entry(+0.000msec irq=24:eth4)
softirq_entry(+0.006msec)
|---netif_receive_skb(+0.010msec skb=f2d15900 len=100)
| skb_copy_datagram_iovec(+0.039msec 10291::10291)
napi_poll_exit(+0.022msec eth4)
This perf script helps us to analyze the processing time of a
transmit/receive sequence.
Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Kaneshige Kenji <kaneshige.kenji@jp.fujitsu.com>
Cc: Izumo Taku <izumi.taku@jp.fujitsu.com>
Cc: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Scott Mcmillan <scott.a.mcmillan@intel.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <4C72439D.3040001@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
tools/perf/util/callchain.h
Merge reason:
Fix a non-trivial conflict with latest fixes
Each histogram entry has a callchain root that stores the
callchain samples. However we forgot to initialize the
tracking of children hits of these roots, which then got
random values on their creation.
The root children hits is multiplied by the minimum percentage
of hits provided by the user, and the result becomes the minimum
hits expected from children branches. If the random value due
to the uninitialization is big enough, then this minimum number
of hits can be huge and eventually filter every children branches.
The end result was invisible callchains. All we need to
fix this is to initialize the children hits of the root.
Reported-by: Christoph Hellwig <hch@infradead.org>
Cc: 2.6.32.x-2.6.35.y <stable@kernel.org>
External shared libraries should never be appended to the LDFLAGS as this
messes the linking order. As EXTLIBS collects those libraries, it seems that
perl and python libraries should also be appended to EXTLIBS.
Also fix the broken linking order.
This is a refresh of a patch by Ozan Çağlayan and improved by both Tom Zanussi
and Kirill A. Shutemov.
Cc: Ozan Çağlayan <ozan@pardus.org.tr>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <1282627430.28324.8.camel@tropicana>
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Given a dso, list the symbols in ascending name order. Needed for
listing available symbols from perf probe.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com>
Cc: Mark Wielaard <mjw@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Naren A Devaiah <naren.devaiah@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
LKML-Reference: <20100825134329.5447.92261.sendpatchset@localhost6.localdomain6>
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
When looking at a callchains enabled perf data file one can find it
tiresome to start with all callchains collapsed and then to have to go
one by one expanding them.
So associate 'E' with "Expand all callchains" and 'C' with "Collapse all
callchains".
This way now one can have the top level view and then switch to/from
having all callchains expanded.
More work is needed to allow expanding just from one branch down to its
leaves.
Cc: Stephane Eranian <eranian@google.com>
LKML-Reference: <new-submission>
Not everytime we show the callchains, removing duplicated initialization
of this field.
Its way too stupid to use rb_first() for just caching if there are
children, use the cheaper RB_EMPTY_ROOT() instead.
It wasn't setting the ms.has_children for the hist_entry itself, just
for the callchain
Merge reason: pick up perf fixes
If we sort the histograms by comm, which is the default,
we need to merge some of them, typically different thread
histograms of a same process, or just same comm. But during
this merge, we forgot to merge callchains.
So imagine we have three threads (tids: 1000, 1001, 1002) that
belong to comm "foo".
tid 1000 got 100 events
tid 1001 got 10 events
tid 1002 got 3 events
Once we merge these histograms to get a per comm result, we'll
finally get:
"foo" got 113 events
The problem is if we merge 1000 and 1001 histograms into 1002, then
the end merge result, wrt callchains, will be only callchains that
belong to 1002.
This is because we haven't handled callchains in the merge. Only those
from one of the threads inside a common comm survive.
It means during this merge, we can lose a lot of callchains.
Fix this by implementing callchains merge and apply it on histograms
that collapse.
Do that to start a consistant callchain API namespace.
In order to implement callchains collapsing, we need to keep
track of the maximum depth in a histogram tree of callchains.
This way we'll avoid allocating an arbitrary temporary buffer
size on callchain merge time.
Some Linux distributions like ALT Linux provides patched glibc with
contains strlcpy(). It's confilcts with strlcpy() from perf.
Let's add check for strlcpy().
LKML-Reference: <1282351101-8879-1-git-send-email-kirill@shutemov.name>
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Relying just on ~/.perfconfig or rebuilding the tool disabling support
for the TUI is too cumbersome, so allow specifying which UI to use and
make the command line switch override whatever is in ~/.perfconfig.
Suggested-by: Christoph Hellwig <hch@infradead.org>
This makes the usual idiom for specifying a series of key codes to exit
ui_browser__run() for specialized processing (search, annotate, etc) or
plain exiting the browser more compact.
It also abstracts away some more libnewt operations. At some point we'll
also replace NEWT_KEY_foo with something that can be mapped to NEWT or,
say, gtk.
Make all browsers return the exit key uniformly and remove the
newtExitStruct parameter, removing one more newt specific thing from the
ui API.
Browsers don't have to deal with absolute coordinates, just using (row,
column) and leaving the rest to ui_browser is better and removes one
more UI backend detail from the browsers.
Also shorten the percent_color setting idiom, removing some more direct
libslang calls.
Parts of the build process were generating files outside the specified
O= directory, causing the build to fail on systems where the sources are
in a read only file system.
Fix it by using $(OUTPUT) on these locations.
Also check that $(OUTPUT) actually exists, just like the top level
kernel Makefile does. Otherwise the failure message emitted is
completely misleading.
LKML-Reference: <20100817140841.0859362C03A@msa106.auone-net.jp>
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
POSIX sh does not specify the brace expansion, so fix it by replacing the
global $(shell ...) lines quite at the top creating the output directories with
real rules.
Cc: Kusanagi Kouichi <slash@ac.auone-net.jp>
LKML-Reference: <1282046280.5822.4.camel@thorin>
Signed-off-by: Bernd Petrovitsch <bernd@sysprog.at>
As part of ongoing effort to reduce the coupling with libnewt, browsers
are being changed to return the exit key.
The annotate browser is not returning it as expected by builtin-annotate
when annotating multiple symbols (when 'perf annotate' is called without
specifying a symbol name).
Fix it by returning the exit key and also adding the RIGHT key as a exit
key so that going to the next symbol in the TUI can work again.
This commit:
de5d9bf: Move list types from <linux/list.h> to <linux/types.h>.
Moved the list head data types out of list.h, breaking the build.
Add them to the perf types.h as well.
Merge reason: Fix upstream breakage introduced by:
To match what is shown when '?' or 'H' is pressed, i.e. the keybind help
window.
So that the common tasks of providing a helpline at __run entry and
destroying the window and releasing resourses at exit can be abstracted
away, reducing a bit more the coupling with libnewt.
The annotate TUI now starts centered on the line with most samples, i.e.
the hottest line in the annotated function. Pressing TAB will center on
the second hottest function and so on. Shift+TAB goes in the other
direction.
This way one can more easily sift thru the function hotspots.
Not just on the annotate one.
Right now it will just sort and position at the hottest line, i.e.
the one where more samples were taken.
It will be at the center of the screen and later TAB/shift-TAB will
cycle thru the hottest lines.
ARM ELF files use symbols with special names $a, $t, $d to identify regions of
ARM code, Thumb code and data within code sections. This can cause confusing
output from the perf tools, especially for partially stripped binaries, or
binaries containing user-added zero-sized symbols (which may occur in
hand-written assembler which hasn't been fully annotated with .size
directives).
This patch filters out these symbols at load time.
LKML-Reference: <1281352878-8735-2-git-send-email-dave.martin@linaro.org>
Signed-off-by: Dave Martin <dave.martin@linaro.org>
As new TUI features get added the newt.c file is growing a lot and its
name is growing misleading as an effort is being made to reduce the
So that building other browser based on structures linked via a linked
list can be as easy as it is already for the ones linked via an rb_tree.
Fix several memory leaks of pkgs and tevs in add_perf_probe_events().
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <4C577ADC.1000309@hitachi.com>
Copy type field if it is for raw parameters.
Without this fix, perf probe drops the type if user passes it
for raw parameters (e.g. %ax:u32 will be converted to %ax).
LKML-Reference: <4C577AD8.50808@hitachi.com>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
When cmd_record exits the whole perf binary will exit right after,
so no need to traverse lots of complex data structures freeing them.
Sticked a comment for leak detectives and for a experiment with obstacks
to be performed so that we can speed up freeing that memory.
Cc: Nick Piggin <npiggin@suse.de>
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
LKML-Reference: <Pine.LNX.4.64.1008052227330.31692@ask.diku.dk>
Removed duplicated #includes util/trace-event.h and
util/exec_cmd.h.
Grouped and sorted all the #includes.
LKML-Reference: <1281016299-23958-14-git-send-email-andrea.gelmini@gelma.net>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1281016299-23958-15-git-send-email-andrea.gelmini@gelma.net>
Only in verbose mode so as not to bloat struct symbol too much.
The key used is '/', just like in vi, less, etc.
More work is needed to allocate space on the symbol in a more clear way.
This experiment shows how to do it for the hist_browser, in the main
window.
By using BITS_PER_LONG/4 as the width specifier.
Otherwise entries will get chopped up on the window.
