commit 575bf1d04e908469d26da424b52fc1b12a1db9d8 upstream.
perl.h from new Perl release doesn't like -Wundef and -Wswitch-default:
/usr/lib/perl5/core_perl/CORE/perl.h:548:5: error: "SILENT_NO_TAINT_SUPPORT" is not defined [-Werror=undef]
#if SILENT_NO_TAINT_SUPPORT && !defined(NO_TAINT_SUPPORT)
/usr/lib/perl5/core_perl/CORE/perl.h:556:5: error: "NO_TAINT_SUPPORT" is not defined [-Werror=undef]
#if NO_TAINT_SUPPORT
In file included from /usr/lib/perl5/core_perl/CORE/perl.h:3471:0,
from util/scripting-engines/trace-event-perl.c:30:
/usr/lib/perl5/core_perl/CORE/sv.h:1455:5: error: "NO_TAINT_SUPPORT" is not defined [-Werror=undef]
In file included from /usr/lib/perl5/core_perl/CORE/perl.h:3472:0,
/usr/lib/perl5/core_perl/CORE/regexp.h:436:5: error: "NO_TAINT_SUPPORT" is not defined [-Werror=undef]
In file included from /usr/lib/perl5/core_perl/CORE/hv.h:592:0,
from /usr/lib/perl5/core_perl/CORE/perl.h:3480,
/usr/lib/perl5/core_perl/CORE/hv_func.h: In function ‘S_perl_hash_siphash_2_4’:
/usr/lib/perl5/core_perl/CORE/hv_func.h:222:3: error: switch missing default case [-Werror=switch-default]
switch( left )
/usr/lib/perl5/core_perl/CORE/hv_func.h: In function ‘S_perl_hash_superfast’:
/usr/lib/perl5/core_perl/CORE/hv_func.h:274:5: error: switch missing default case [-Werror=switch-default]
switch (rem) { \
/usr/lib/perl5/core_perl/CORE/hv_func.h: In function ‘S_perl_hash_murmur3’:
/usr/lib/perl5/core_perl/CORE/hv_func.h:398:5: error: switch missing default case [-Werror=switch-default]
switch(bytes_in_carry) { /* how many bytes in carry */
Let's disable the warnings for code which uses perl.h.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Link: http://lkml.kernel.org/r/1372063394-20126-1-git-send-email-kirill@shutemov.name
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[bwh: Backported to 3.2: adjust context]
Cc: Vinson Lee <vlee@twopensource.com>
commit caa470475d9b59eeff093ae650800d34612c4379 upstream.
The original patch introducing this header wrote the number of CPUs available
and online in one order and then swapped those values when reading, fix it.
Before:
# perf record usleep 1
# perf report --header-only | grep 'nrcpus \(online\|avail\)'
# nrcpus online : 4
# nrcpus avail : 4
# echo 0 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 4
# nrcpus avail : 3
# echo 0 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 2
After the fix, bringing back the CPUs online:
# nrcpus online : 2
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 3
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 4
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)")
Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org
[bwh: Backported to 3.2: print_nrcpus() reads and prints these fields
immediately, so read both of them into an array before printing them in
reverse order.]
commit 7b78f13603c6fcb64e020a0bbe31a651ea2b657b upstream.
On a system running glibc trunk perf doesn't build:
CC builtin-sched.o
builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration]
Fix it by including sys/resource.h.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20120404084527.GA294@x4
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream.
Need to check for /dev/zero.
Most likely more strings are missing too.
Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org
commit d0528b5d71faf612014dd7672e44225c915344b2 upstream.
Judging anonymous memory's vm_area_struct, perf_mmap_event's filename
will be set to "//anon" indicating this vma belongs to anonymous
memory.
Once hugepage is used, vma's vm_file points to hugetlbfs. In this way,
this vma will not be regarded as anonymous memory by is_anon_memory() in
perf user space utility.
Signed-off-by: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Akihiro Nagai <akihiro.nagai.hw@hitachi.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1357363797-3550-1-git-send-email-zhu.wen-jie@hp.com
commit 5a1e99dd2028e00998d42029be86835d8ef4a46e upstream.
The comparison between traced and symbol addresses is backwards: if
the traced address doesn't exactly match a symbol (which we don't
expect it to), we'll show the next symbol and the offset to it,
whereas we should show the previous symbol and the offset from it.
commit 140c3c6a2bcd2c31e2f7f5a8d59689724776c8e5 upstream.
This works much better if we don't treat protocol numbers as addresses.
This reverts commit 923415295307845e614589c1cce62abedd4d1731
'perf: Fix parsing of __print_flags() in TP_printk()'. The same
change was already included in 3.2 as commit
d06c27b22aa66e48e32f03f9387328a9af9b0625 but in 3.2.1 this change
was wrongly applied to similar code in a different function.
Thanks to Jiri for pointing this out in 3.0.y.
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Andrew Vagin <avagin@openvz.org>
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream.
The correct syntax for gcc -x is "gcc -x assembler", not
"gcc -xassembler". Even though the latter happens to work, the former
is what is documented in the manual page and thus what gcc wrappers
such as icecream do expect.
This isn't a cosmetic change. The missing space prevents icecream from
recognizing compilation tasks it can't handle, leading to silent kernel
miscompilations.
Besides me, credits go to Michael Matz and Dirk Mueller for
investigating the miscompilation issue and tracking it down to this
incorrect -x parameter syntax.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Bernhard Walle <bernhard@bwalle.de>
Cc: Michal Marek <mmarek@suse.cz>
[bwh: Backported to 3.2: drop unneeded change to arch/x86/Makefile]
[Patch not needed upstream as this is a backport build bugfix - gregkh
gcc correctly complains:
util/hist.c: In function ‘__hists__add_entry’:
util/hist.c:240:27: error: invalid type argument of ‘->’ (have ‘struct hist_entry’)
util/hist.c:241:23: error: invalid type argument of ‘->’ (have ‘struct hist_entry’)
for this new code:
+ if (he->ms.map != entry->ms.map) {
+ he->ms.map = entry->ms.map;
+ if (he->ms.map)
+ he->ms.map->referenced = true;
because "entry" is a "struct hist_entry", not a pointer to a struct.
In mainline, "entry" is a pointer to struct passed as argument to the function.
So this is broken during backporting. But obviously not compile tested.
Signed-off-by: Zeev Tarantov <zeev.tarantov@gmail.com>
Cc: Signed-off-by: David S. Miller <davem@davemloft.net>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 63fa471dd49e9c9ce029d910d1024330d9b1b145 upstream.
When a process exec()'s, all the maps are retired, but we keep the hist
entries around which hold references to those outdated maps.
If the same library gets mapped in for which we have hist entries, a new
map will be created. But when we take a perf entry hit within that map,
we'll find the existing hist entry with the older map.
This causes symbol translations to be done incorrectly. For example,
the perf entry processing will lookup the correct uptodate map entry and
use that to calculate the symbol and DSO relative address. But later
when we update the histogram we'll translate the address using the
outdated map file instead leading to conditions such as out-of-range
offsets in symbol__inc_addr_samples().
Therefore, update the map of the hist_entry dynamically at lookup/
creation time.
Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net
commit e7f01d1e3d8d501deb8abeaa269d5d48a703b8b0 upstream.
Several places were expecting that the value returned was the number of
characters printed, not what would be printed if there was space.
Fix it by using the scnprintf and vscnprintf variants we inherited from
the kernel sources.
Some corner cases where the number of printed characters were not
accounted were fixed too.
Reported-by: Anton Blanchard <anton@samba.org>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-kwxo2eh29cxmd8ilixi2005x@git.kernel.org
commit b832796caa1fda8516464a003c8c7cc547bc20c2 upstream.
I have a workload where perf top scribbles over the stack and we SEGV.
What makes it interesting is that an snprintf is causing this.
The workload is a c++ gem that has method names over 3000 characters
long, but snprintf is designed to avoid overrunning buffers. So what
went wrong?
The problem is we assume snprintf returns the number of characters
written:
ret += repsep_snprintf(bf + ret, size - ret, "[%c] ", self->level);
ret += repsep_snprintf(bf + ret, size - ret, "%s", self->ms.sym->name);
Unfortunately this is not how snprintf works. snprintf returns the
number of characters that would have been written if there was enough
space. In the above case, if the first snprintf returns a value larger
than size, we pass a negative size into the second snprintf and happily
scribble over the stack. If you have 3000 character c++ methods thats a
lot of stack to trample.
This patch fixes repsep_snprintf by clamping the value at size - 1 which
is the maximum snprintf can write before adding the NULL terminator.
I get the sinking feeling that there are a lot of other uses of snprintf
that have this same bug, we should audit them all.
Link: http://lkml.kernel.org/r/20120307114249.44275ca3@kryten
commit 7a0153ee15575a4d07b5da8c96b79e0b0fd41a12 upstream.
By adding following objects:
bench/mem-memcpy-x86-64-asm.o
the x86_64 perf binary ended up with executable stack.
The reason was that above object are assembler sourced and is missing the
GNU-stack note section. In such case the linker assumes that the final binary
should not be restricted at all and mark the stack as RWX.
Adding section ".note.GNU-stack" definition to mentioned object, with all
flags disabled, thus omiting this object from linker stack flags decision.
Problem introduced in:
$ git describe ea7872b
v2.6.37-rc2-19-gea7872b
Reported-at: https://bugzilla.redhat.com/show_bug.cgi?id=783570
Reported-by: Clark Williams <williams@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1328100848-5630-1-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
[ committer note: Backported fix to perf/urgent (3.3-rc2+) ]
commit a4a03fc7ef89020baca4f19174e6a43767c6d78a upstream.
This patch fixes an issue where perf report shows nan% for certain
perf.data files. The below is from a report for a do_fork probe:
-nan% sshd [kernel.kallsyms] [k] do_fork
-nan% packagekitd [kernel.kallsyms] [k] do_fork
-nan% dbus-daemon [kernel.kallsyms] [k] do_fork
-nan% bash [kernel.kallsyms] [k] do_fork
A git bisect shows commit f3bda2c as the cause. However, looking back
through the git history, I saw commit 640c03c which seems to have
removed the required initialization for perf_sample->period. The problem
only started showing after commit f3bda2c. The below patch re-introduces
the initialization and it fixes the problem for me.
With the below patch, for the same perf.data:
73.08% bash [kernel.kallsyms] [k] do_fork
8.97% 11-dhclient [kernel.kallsyms] [k] do_fork
6.41% sshd [kernel.kallsyms] [k] do_fork
3.85% 20-chrony [kernel.kallsyms] [k] do_fork
2.56% sendmail [kernel.kallsyms] [k] do_fork
This patch applies over current linux-tip commit 9949284.
$ git describe 640c03c
v2.6.37-rc3-83-g640c03c
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120203170113.5190.25558.stgit@localhost6.localdomain6
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 49908a1b25d448d68fd26faca260e1850201575f upstream.
A update is made to the sched:sched_switch event that adds some
logic to the first parameter of the __print_flags() that shows the
state of tasks. This change cause perf to fail parsing the flags.
A simple fix is needed to have the parser be able to process ops
within the argument.
Reported-by: Andrew Vagin <avagin@openvz.org>
perf_evsel.name may be not initialized
Cc: Arun Sharma <asharma@fb.com>
Cc: devel@openvz.org
Link: http://lkml.kernel.org/r/1322471015-107825-2-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Cc: stable@vger.kernel.org
perf stat is failing on PowerPC:
Error: open_counter returned with 95 (Operation not supported). /bin/dmesg may provide additional information.
Fatal: Not all events could be opened.
commit 370faf1dd046 (perf stat: Fail softly on unsupported events)
added a check for failure returning ENOENT, but the POWER backend
returns EOPNOTSUPP. It looks like alpha, blackfin and mips do the
same.
With the patch applied, things work as expected:
Performance counter stats for '/bin/true':
0.362176 task-clock # 0.623 CPUs utilized
0 context-switches # 0.000 M/sec
0 CPU-migrations # 0.000 M/sec
28 page-faults # 0.077 M/sec
1,677,020 cycles # 4.630 GHz
<not supported> stalled-cycles-frontend
<not supported> stalled-cycles-backend
431,220 instructions # 0.26 insns per cycle
101,889 branches # 281.325 M/sec
4,145 branch-misses # 4.07% of all branches
0.000581361 seconds time elapsed
Cc: <stable@kernel.org> # 3.0+
Link: http://lkml.kernel.org/r/20111202093833.5fef7226@kryten
commit 5d67be9 added the option to specify a range of CPUs of interest,
but does not catch an invalid CPU list:
$ perf script -c foo
Segmentation fault (core dumped)
Link: http://lkml.kernel.org/r/1321206327-5881-1-git-send-email-dsahern@gmail.com
Signed-off-by: David Ahern <dsahern@gmail.com>
Recently we made perf_evsel__init call hists__init, which broke the perf
python binding:
[root@emilia linux]# ./tools/perf/python/twatch.py
Traceback (most recent call last):
File "./tools/perf/python/twatch.py", line 16, in <module>
import perf
ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: hists__init
Fix it by moving the hists__init function to its only caller, evsel.c.
This way we avoid dragging in other parts of tools/perf/util/ to the
perf python binding.
Link: http://lkml.kernel.org/n/tip-5nffmdt5mu6ozxgj54oi4qon@git.kernel.org
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf top: Fix live annotation in the --stdio interface
perf top tui: Don't recalc column widths considering just the first page
perf report: Add progress bar when processing time ordered events
perf hists browser: Warn about lost events
perf tools: Fix a typo of command name as trace-cmd
perf hists: Fix recalculation of total_period when sorting entries
perf header: Fix build on old systems
perf ui browser: Handle K_RESIZE in dialog windows
perf ui browser: No need to switch char sets that often
perf hists browser: Use K_TIMER
perf ui: Rename ui__warning_paranoid to ui__error_paranoid
perf ui: Reimplement the popup windows using libslang
perf ui: Reimplement ui__popup_menu using ui__browser
perf ui: Reimplement ui_helpline using libslang
perf ui: Improve handling sigwinch a bit
perf ui progress: Reimplement using slang
perf evlist: Fix grouping of multiple events
In the old --stdio interface the annotation is done just after one
selects a symbol, while in --tui, now the default when the required libs
are installed, we annotate all symbols with samples so that when
annotation is asked we see what happened recently on that symbol.
To achieve that the --stdio variant checks if the hist_entry being
processed is the one selected by the user via the 's' hotkey. What
happens now that we share the hist_entry abstractions with 'perf report'
is that for minimizing locking contention multiple rb_trees are used,
one for collecting the samples and other to browse/show them after
resorting it by number of samples and decay them, which is done
periodically.
So the simple test in record_precise_ip doesn't work as we move
hist_entries between those rb_trees. To fix it just check that the
underlying struct symbol associated with those hist_entries is the same.
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Mike Galbraith <efault@gmx.de>
Link: http://lkml.kernel.org/n/tip-bcfnraqkux88fox9ba9767ds@git.kernel.org
It makes sense for the stdio where we can't navigate to the other pages.
On the TUI it breaks as soon as we navigate to other pages that have,
DSOs with longer names than the ones on the first page.
Link: http://lkml.kernel.org/n/tip-zvqfp18mw229agb43cikgb0k@git.kernel.org
So that for large perf.data files the user can have visual feedback that
activity is being performed.
Link: http://lkml.kernel.org/n/tip-3ysn01mpspfrbsy56gznzqqz@git.kernel.org
Just like the old perf top --tui and the --stdio version.
But because we have the initial menu to choose which event to show in a
session with multiple events we can see how many chunks were lost in
each of the event types, clarifying which events are being affected the
most.
Link: http://lkml.kernel.org/n/tip-47yyqbubmjzch2chezmb21m6@git.kernel.org
Fix a typo which may be introduced when original code has been copied
from trace-cmd.
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20111004104456.14591.37395.stgit@fedora15
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
We were doing parts of it in hists__collapse_resort and parts of it in
hists__output_resort, leading to a bogus total_period.
Fix it by doing just the filtering operation when collapsing because
there we know that the Zoom operations adds filters just what is in
hists->entries, not to the new batch of entries being collapsed.
And move all the nr_entries + total_period recalculation to
hists__output_resort since we will traverse all entries anyway there.
Problem introduced when developing threaded addition of new batches
of hist_entries, i.e. post v3.1.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/n/tip-8xyh165h7hmwy0696hu25en6@git.kernel.org
For instance, on Fedora 8:
CC /home/acme/git/build/perf/util/header.o
cc1: warnings being treated as errors
util/header.c: In function ‘write_cpudesc’:
util/header.c:281: warning: implicit declaration of function ‘getline’
util/header.c:281: warning: nested extern declaration of ‘getline’
make: *** [/home/acme/git/build/perf/util/header.o] Error 1
make: Leaving directory `/home/acme/git/linux/tools/perf'
[acme@localhost linux]$
This happens due to header ordering, in perf util.h sets _GNU_SOURCE, so
it must come first.
Reported-by: Ingo Molnar <mingo@elte.hu>
Link: http://lkml.kernel.org/n/tip-alfra9wao63euguj7gr8jw7e@git.kernel.org
Just provide wrappers for things like ui__warning, ui__dialog_yesno and
if they return K_RESIZE, refresh dimensions, redraw the entries, etc.
Link: http://lkml.kernel.org/n/tip-3ih7hyk9weryxaxb501sfq4u@git.kernel.org
Just before and after the loop.
Link: http://lkml.kernel.org/n/tip-0lh91cedngyg1pqarbky5vn7@git.kernel.org
In the switch case entry for the timer routine.
Link: http://lkml.kernel.org/n/tip-ypw3i9kmxoq28skx7jy914it@git.kernel.org
As it will exit the tool after the user is notified.
Link: http://lkml.kernel.org/n/tip-vy06m8xzlvkhr8tk7nylhbng@git.kernel.org
Just another step in stopping the use of libnewt in perf.
Link: http://lkml.kernel.org/n/tip-vtxnmz1t1807ykprapnk9njl@git.kernel.org
Right now let it work just like the other browsers: in full screen, at
the top left corner. If people complain we can revisit, I found it OK
and the laziest/quickest approach at reusing the ui_browser ;-)
Link: http://lkml.kernel.org/n/tip-4bgeqizcxh04q0sk24cw43gk@git.kernel.org
Link: http://lkml.kernel.org/n/tip-gh7e1v2z7pzqmok02r6zvp17@git.kernel.org
No need to unblock it at each ui__getch() and also allow other users to
check if a resize is needed, or force an refresh of terminal dimensions.
The 'force' one shouldn't be needed, but its in a slow path, so leave it
like that for now, I'll revisit this another day.
Link: http://lkml.kernel.org/n/tip-aujchu6yx3bfy64non1rky0w@git.kernel.org
Link: http://lkml.kernel.org/n/tip-vkb9jh5kkzl5ep3puoatd6an@git.kernel.org
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (121 commits)
perf symbols: Increase symbol KSYM_NAME_LEN size
perf hists browser: Refuse 'a' hotkey on non symbolic views
perf ui browser: Use libslang to read keys
perf tools: Fix tracing info recording
perf hists browser: Elide DSO column when it is set to just one DSO, ditto for threads
perf hists: Don't consider filtered entries when calculating column widths
perf hists: Don't decay total_period for filtered entries
perf hists browser: Honour symbol_conf.show_{nr_samples,total_period}
perf hists browser: Do not exit on tab key with single event
perf annotate browser: Don't change selection line when returning from callq
perf tools: handle endianness of feature bitmap
perf tools: Add prelink suggestion to dso update message
perf script: Fix unknown feature comment
perf hists browser: Apply the dso and thread filters when merging new batches
perf hists: Move the dso and thread filters from hist_browser
perf ui browser: Honour the xterm colors
perf top tui: Give color hints just on the percentage, like on --stdio
perf ui browser: Make the colors configurable and change the defaults
perf tui: Remove unneeded call to newtCls on startup
perf hists: Don't format the percentage on hist_entry__snprintf
Fix up conflicts in arch/x86/kernel/kprobes.c manually.
Ingo's tree did the insane "add volatile to const array", which just
doesn't make sense ("volatile const"?). But we could remove the const
*and* make the array volatile to make doubly sure that gcc doesn't
optimize it away..
Also fix up kernel/trace/ring_buffer.c non-data-conflicts manually: the
reader_lock has been turned into a raw lock by the core locking merge,
and there was a new user of it introduced in this perf core merge. Make
sure that new use also uses the raw accessor functions.
The __perf_evsel__open routing was grouping just the threads for that
specific events per cpu when we want to group all threads in all events
to the first fd opened on that cpu.
So pass the xyarray with the first event, where the other events will be
able to get that first per cpu fd.
At some point top and record will switch to using perf_evlist__open that
takes care of this detail and probably will also handle the fallback
from hw to soft counters, etc.
Reported-by: Deng-Cheng Zhu <dczhu@mips.com>
Tested-by: Deng-Cheng Zhu <dczhu@mips.com>
Link: http://lkml.kernel.org/n/tip-ebm34rh098i9y9v4cytfdp0x@git.kernel.org
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits)
MAINTAINERS: linux-m32r is moderated for non-subscribers
linux@lists.openrisc.net is moderated for non-subscribers
Drop default from "DM365 codec select" choice
parisc: Kconfig: cleanup Kernel page size default
Kconfig: remove redundant CONFIG_ prefix on two symbols
cris: remove arch/cris/arch-v32/lib/nand_init.S
microblaze: add missing CONFIG_ prefixes
h8300: drop puzzling Kconfig dependencies
MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers
tty: drop superfluous dependency in Kconfig
ARM: mxc: fix Kconfig typo 'i.MX51'
Fix file references in Kconfig files
aic7xxx: fix Kconfig references to READMEs
Fix file references in drivers/ide/
thinkpad_acpi: Fix printk typo 'bluestooth'
bcmring: drop commented out line in Kconfig
btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888'
doc: raw1394: Trivial typo fix
CIFS: Don't free volume_info->UNC until we are entirely done with it.
treewide: Correct spelling of successfully in comments
Fglrx propietary driver has symbol names over 128 chars (:S). This
breaks the function kallsyms__parse.
This fix increases the size of KSYM_NAME_LEN, so kallsyms__parse can
work on such kernels.
The only counterparty, is that such function requires 128 more bytes to
work.
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: David Ahern <daahern@cisco.com>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/1319096606-11568-1-git-send-email-ricardo.ribalda@gmail.com
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
We don't allocate the histogram data structures for --sort lists without
"sym", so, just like was done for the menu, don't try to annotate when
'a' is pressed, just warn the user about it.
Reported-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/n/tip-27mjg02s2mbw8lfxqv7jpzec@git.kernel.org
Link: http://lkml.kernel.org/n/tip-uy6s534uqxq8tenh6s3k8ocj@git.kernel.org
Fixing the way the tracing information is stored within record command.
The current implementation is causing issues for pipe output.
Following commands fail currently:
perf script syscall-counts ls
perf record -e syscalls:sys_exit_read ls | ./perf report -i -
The tracing information is part of the perf data file. It contains
several files from within the tracing debugfs and procs directories.
Beside some static header files, for each tracing event the format
file is added. The /proc/kallsyms file is also added.
The tracing data are stored with preceeding size. This is causing some
dificulties for pipe output, since there's no way to tell debugfs/proc
file size before reading it. So, for pipe output, all the debugfs files
were read twice. Once to get the overall size and once to store the
content itself. This can cause problem in case any of these file
changed, within the storage time.
To fix this behaviour and ensure the integrity of the tracing data, we:
- read debugfs/proc file into the temp file
- get temp file size and dump it to the pipe
- dump the temp file contents to the pipe
Cc: Neil Horman <nhorman@tuxdriver.com>
Link: http://lkml.kernel.org/r/20111020135943.GD2092@jolsa.brq.redhat.com
for threads
And also no leed to show the [.] (level: k, . for userspace) when
showing just one DSO.
Link: http://lkml.kernel.org/n/tip-4h3f6ro5o7ebepjbssxf0dd3@git.kernel.org
Link: http://lkml.kernel.org/n/tip-rf01wktu1e3f3az32nry86vu@git.kernel.org
Following the 'perf report' model we don't zap hist_entry instances from
the rb tree, we just keep them with he->filtered set to a mask of the
filters applied to it (thread, parent, DSO so far).
In top we need to decay even filtered entries, but we better not touch
total_period for them...
Now everything seems to work when filters are applied on top as they
worked in 'report', i.e. both dynamic and static hist entry browsing
works with filters.
Link: http://lkml.kernel.org/n/tip-yt4xsbq20u9x9ypuwwyw2kao@git.kernel.org
We lost that when we move it outside hist_entry__snprintf, but better
leave it untangled of 'perf diff' stuff (pair_hist, etc).
Link: http://lkml.kernel.org/n/tip-qlhb6ictf5twykog6x344s0b@git.kernel.org
