path: root/tools/power
2016-11-16tools/power/acpi: Remove direct kernel source include referenceLv Zheng
Avoid breaking cross-compiled ACPI tools builds by rearranging the handling of kernel header files. This patch also contains OUTPUT/srctree cleanups in order to make above fix working for various build environments. Fixes: e323c02dee59 (ACPICA: MSVC9: Fix <sys/stat.h> inclusion order issue) Reported-and-tested-by: Yisheng Xie <xieyisheng1@huawei.com> Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> [ rjw: Changelog ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-11-01cpupower: Correct return type of cpu_power_is_cpu_online() in cpufreq-setLaura Abbott
When converting to a shared library in ac5a181d065d ("cpupower: Add cpuidle parts into library"), cpu_freq_cpu_exists() was converted to cpupower_is_cpu_online(). cpu_req_cpu_exists() returned 0 on success and -ENOSYS on failure whereas cpupower_is_cpu_online returns 1 on success. Check for the correct return value in cpufreq-set. Link: https://bugzilla.redhat.com/show_bug.cgi?id=1374212 Fixes: ac5a181d065d (cpupower: Add cpuidle parts into library) Reported-by: Julian Seward <jseward@acm.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Acked-by: Thomas Renninger <trenn@suse.com> Cc: 4.7+ <stable@vger.kernel.org> # 4.7+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-09-10ACPICA: Cleanup for all string-to-integer conversionsBob Moore
ACPICA commit e2e72a351201fd58e4694418859ae2c247dafca0 Consolidate multiple versions of strtoul64 to one common version. limit possible bases to either 10 or 16. Handles both implicit and explicit conversions. Added a 2-character ascii-to-hex function for GPEs and buffers. Adds a new file, utstrtoul64.c Link: https://github.com/acpica/acpica/commit/e2e72a35 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: Clib: Eliminate acpi_os_XXXFile()/acpi_log_error and link clibrary ↵Lv Zheng
fxxx()/errno/perror() instead ACPICA commit 189429fb7d06cdb89043ae32d615faf553467f1d This patch follows new ACPICA design, eliminates old portable OSLs, and implements fopen/fread/fwrite/fclose/fseek/ftell for GNU EFI environment. This patch also eliminates acpi_log_error(), convering them into fprintf(stderr)/perror(). Lv Zheng. Link: https://github.com/acpica/acpica/commit/189429fb Link: https://bugs.acpica.org/show_bug.cgi?id=1302 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: Clib: Add -nostdinc support for EFI layerLv Zheng
ACPICA commit d261d40ea168f8e4c4e3986de720b8651c4aba1c This patch adds sprintf()/snprintf()/vsnprintf()/printf()/vfprintf() support for OSPMs that have ACPI_USE_SYSTEM_CLIBRARY defined but do not have ACPI_USE_STANDARD_HEADERS defined. -iwithprefix include is required to include <stdarg.h> which contains compiler specific implementation of vargs when -nostdinc is specified. -fno-builtin is required for GCC to avoid optimization performed printf(). This optimization cannot be automatically disabled by specifying -nostdlib. Please refer to the first link below for the details. However, the build option changes do not affect Linux kernel builds and are not included. Lv Zheng. Link: http://www.ciselant.de/projects/gcc_printf/gcc_printf.html Link: https://github.com/acpica/acpica/commit/d261d40e Link: https://bugs.acpica.org/show_bug.cgi?id=1302 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: MSVC9: Fix <sys/stat.h> inclusion order issueLv Zheng
ACPICA commit 9bb265c2afb9910e46f820d6759648580edabd09 When /Za is specified, headers of some Windows SDKs contain bugs breaking VC builds, and MSVC9's default SDK is one of such header-buggy library. In order to solve this issue, many VC developers stop using /Za. However we've been asked to have this fixed without removing /Za. In MSVC9 default SDK, this issue can be fixed by restricting <sys/stat.h> to be the last standard file included by every source file in the projects. This patch thus moves <sys/stat.h> inclusion to "acapps.h", so that this issue can be fixed by ensuring that "acapps.h" is always the last standard file included by all of the ACPICA source files. This is in fact also a useful cleanup because applications can only include one header (e.x., acpidump.h) instead of including acapps.h separately. Lv Zheng. Except some harmless header inclusion re-ordering, Linux kernel is not affected by this change. Link: https://github.com/acpica/acpica/commit/9bb265c2 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: Clib/EFI: Fix wrong order of standard integer types/IO handlesLv Zheng
ACPICA commit 7f9b359b7c78c69b07f62eb2d58f710c351fd75d EFI header should use standard C library stuffs (integer types and IO handles) rather than implementing such standard stuffs. This patch fixes this issue by: 1. Implementing standard integer types for ACPI_USE_STANDARD_HADERS=n; 2. Defining EFI types using standard integer types and standard IO handles; 3. Tuning header inclusion order and environment definition order; 4. Removing wrong standard header inclusion from ACPICA core files; 5. Moving several application headers from acpidump.h to acenv.h. This patch corrects some of them. Lv Zheng. Except some harmless header inclusion re-ordering, Linux kernel is not affected by this change. Link: https://github.com/acpica/acpica/commit/7f9b359b Link: https://bugs.acpica.org/show_bug.cgi?id=1300 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: Clib: Fix build issues when ACPI_USE_STANDARD_HEADERS is not defined ↵Lv Zheng
by converting size_t to acpi_size ACPICA commit 7cf411136c69ef0b8f184b96599eb45c15b89226 When standard size_t is not defined due to ACPI_USE_STANDARD_HEADERS=n, we shouldn't use size_t, but should use acpi_size instead. This fixes such build issue. Lv Zheng. Link: https://github.com/acpica/acpica/commit/7cf41113 Link: https://bugs.acpica.org/show_bug.cgi?id=1296 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: acpidump: Fix a duplicate variable definitionLv Zheng
ACPICA commit 080f99d5b29313380accd00d2b9768e809eb417b acpi_gbl_integer_byte_width has already been instantiated by ACPI_GLOBAL() in acglobal.h. Lv Zheng. Link: https://github.com/acpica/acpica/commit/080f99d5 Link: https://bugs.acpica.org/show_bug.cgi?id=1301 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: OSL: Add correct acpi_gbl_debug_timeout export to allow acpiexec to linkLv Zheng
ACPICA commit 408198c8c9786f9f104ee925020c3ab1701906e4 The acpi_gbl_debug_timeout which is used by acpiexec -et option now is only implemented in oswinxf.c and used for WIN32 builds. This makes it very difficult to remember that we need to add this variable to other os specific layer files in order for linking. This patch makes it a global option dependent on ACPI_APPLICATION so that it can always be linked by the applications. Lv Zheng. Link: https://github.com/acpica/acpica/commit/408198c8 Link: https://bugs.acpica.org/show_bug.cgi?id=1295 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-08-13ACPICA: iASL/Disassembler: Add a check for missing filenameBob Moore
ACPICA commit fc0f12b1eff6253f83e599a7ee1765fcc8e42dcc Add check for required filename for the -d and -da options. ACPICA BZ 1285. Link: https://github.com/acpica/acpica/commit/fc0f12b1 Link: https://bugs.acpica.org/show_bug.cgi?id=1285 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-07-26Merge tag 'acpi-4.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI updates from Rafael Wysocki: "The new feaures here are the support for ACPI overlays (allowing ACPI tables to be loaded at any time from EFI variables or via configfs) and the LPI (Low-Power Idle) support. Also notable is the ACPI-based NUMA support for ARM64. Apart from that we have two new drivers, for the DPTF (Dynamic Power and Thermal Framework) power participant device and for the Intel Broxton WhiskeyCove PMIC, some more PMIC-related changes, support for the Boot Error Record Table (BERT) in APEI and support for platform-initiated graceful shutdown. Plus two new pieces of documentation and usual assorted fixes and cleanups in quite a few places. Specifics: - Support for ACPI SSDT overlays allowing Secondary System Description Tables (SSDTs) to be loaded at any time from EFI variables or via configfs (Octavian Purdila, Mika Westerberg). - Support for the ACPI LPI (Low-Power Idle) feature introduced in ACPI 6.0 and allowing processor idle states to be represented in ACPI tables in a hierarchical way (with the help of Processor Container objects) and support for ACPI idle states management on ARM64, based on LPI (Sudeep Holla). - General improvements of ACPI support for NUMA and ARM64 support for ACPI-based NUMA (Hanjun Guo, David Daney, Robert Richter). - General improvements of the ACPI table upgrade mechanism and ARM64 support for that feature (Aleksey Makarov, Jon Masters). - Support for the Boot Error Record Table (BERT) in APEI and improvements of kernel messages printed by the error injection code (Huang Ying, Borislav Petkov). - New driver for the Intel Broxton WhiskeyCove PMIC operation region and support for the REGS operation region on Broxton, PMIC code cleanups (Bin Gao, Felipe Balbi, Paul Gortmaker). - New driver for the power participant device which is part of the Dynamic Power and Thermal Framework (DPTF) and DPTF-related code reorganization (Srinivas Pandruvada). - Support for the platform-initiated graceful shutdown feature introduced in ACPI 6.1 (Prashanth Prakash). - ACPI button driver update related to lid input events generated automatically on initialization and system resume that have been problematic for some time (Lv Zheng). - ACPI EC driver cleanups (Lv Zheng). - Documentation of the ACPICA release automation process and the in-kernel ACPI AML debugger (Lv Zheng). - New blacklist entry and two fixes for the ACPI backlight driver (Alex Hung, Arvind Yadav, Ralf Gerbig). - Cleanups of the ACPI pci_slot driver (Joe Perches, Paul Gortmaker). - ACPI CPPC code changes to make it more robust against possible defects in ACPI tables and new symbol definitions for PCC (Hoan Tran). - System reboot code modification to execute the ACPI _PTS (Prepare To Sleep) method in addition to _TTS (Ocean He). - ACPICA-related change to carry out lock ordering checks in ACPICA if ACPICA debug is enabled in the kernel (Lv Zheng). - Assorted minor fixes and cleanups (Andy Shevchenko, Baoquan He, Bhaktipriya Shridhar, Paul Gortmaker, Rafael Wysocki)" * tag 'acpi-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (71 commits) ACPI: enable ACPI_PROCESSOR_IDLE on ARM64 arm64: add support for ACPI Low Power Idle(LPI) drivers: firmware: psci: initialise idle states using ACPI LPI cpuidle: introduce CPU_PM_CPU_IDLE_ENTER macro for ARM{32, 64} arm64: cpuidle: drop __init section marker to arm_cpuidle_init ACPI / processor_idle: Add support for Low Power Idle(LPI) states ACPI / processor_idle: introduce ACPI_PROCESSOR_CSTATE ACPI / DPTF: move int340x_thermal.c to the DPTF folder ACPI / DPTF: Add DPTF power participant driver ACPI / lpat: make it explicitly non-modular ACPI / dock: make dock explicitly non-modular ACPI / PCI: make pci_slot explicitly non-modular ACPI / PMIC: remove modular references from non-modular code ACPICA: Linux: Enable ACPI_MUTEX_DEBUG for Linux kernel ACPI: Rename configfs.c to acpi_configfs.c to prevent link error ACPI / debugger: Add AML debugger documentation ACPI: Add documentation describing ACPICA release automation ACPI: add support for loading SSDTs via configfs ACPI: add support for configfs efi / ACPI: load SSTDs from EFI variables ...
2016-07-07tools/power turbostat: Replace MSR_NHM_TURBO_RATIO_LIMITSrinivas Pandruvada
Replace MSR_NHM_TURBO_RATIO_LIMIT with MSR_TURBO_RATIO_LIMIT. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-06-28tools/turbostat: allow user to alter DESTDIR and PREFIXAndy Shevchenko
When run make -C tools DESTDIR=/my/nice/dir turbostat_install get a message install: cannot create regular file '/usr/bin/turbostat': Permission denied Allow user to alter DESTDIR and PREFIX variables. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-06-23tools/acpi: use CROSS_COMPILE to define prefixAndy Shevchenko
CROSS_COMPILE can be considered as standard definition for toolchain prefix when cross-compiling. Use it here. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-16Merge tag 'acpi-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI updates from Rafael Wysocki: "The new features here are ACPI 6.1 support (and some previously missing bits of ACPI 6.0 support) in ACPICA and two new drivers, a driver for the ACPI Generic Event Device (GED) feature introduced by ACPI 6.1 and the INT3406 thermal driver for display thermal management. Also the value returned by the _HRV (hardware revision) ACPI object will be exported to user space via sysfs now. In addition to that, ACPI on ARM64 will not depend on EXPERT any more. The rest is mostly fixes and cleanups and some code reorganization. Specifics: - In-kernel ACPICA code update to the upstream release 20160422 adding support for ACPI 6.1 along with some previously missing bits of ACPI 6.0 support, making a fair amount of fixes and cleanups and reducing divergences between the upstream ACPICA and the in-kernel code (Bob Moore, Lv Zheng, Al Stone, Aleksey Makarov, Will Miles) - ACPI Generic Event Device (GED) support and a fix for it (Sinan Kaya, Paul Gortmaker) - INT3406 thermal driver for display thermal management and ACPI backlight support code reorganization related to it (Aaron Lu, Arnd Bergmann) - Support for exporting the value returned by the _HRV (hardware revision) ACPI object via sysfs (Betty Dall) - Removal of the EXPERT dependency for ACPI on ARM64 (Mark Brown) - Rework of the handling of ACPI _OSI mechanism allowing the _OSI("Darwin") support to be overridden from the kernel command line among other things (Lv Zheng, Chen Yu) - Rework of the ACPI tables override mechanism to prepare it for the introduction of overlays support going forward (Lv Zheng, Rafael Wysocki) - Fixes related to the ECDT support and module-level execution of AML (Lv Zheng) - ACPI PCI interrupts management update to make it work better on ARM64 mostly (Sinan Kaya) - ACPI SRAT handling update to make the code process all entires in the table order regardless of the entry type (Lukasz Anaczkowski) - EFI power off support for full-hardware ACPI platforms that don't support ACPI S5 (Chen Yu) - Fixes and cleanups related to the ACPI core's sysfs interface (Dan Carpenter, Betty Dall) - acpi_dev_present() API rework to reduce possible confusion related to it (Lukas Wunner) - Removal of CLK_IS_ROOT from two ACPI drivers (Stephen Boyd)" * tag 'acpi-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (82 commits) ACPI / video: mark acpi_video_get_levels() inline Thermal / ACPI / video: add INT3406 thermal driver ACPI / GED: make evged.c explicitly non-modular ACPI / tables: Fix DSDT override mechanism ACPI / sysfs: fix error code in get_status() ACPICA: Update version to 20160422 ACPICA: Move all ASCII utilities to a common file ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support for acpi_hw_write() ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support in acpi_hw_read() ACPICA: Executer: Introduce a set of macros to handle bit width mask generation ACPICA: Hardware: Add optimized access bit width support ACPICA: Utilities: Add ACPI_IS_ALIGNED() macro ACPICA: Renamed some #defined flag constants for clarity ACPICA: ACPI 6.0, tools/iasl: Add support for new resource descriptors ACPICA: ACPI 6.0: Update _BIX support for new package element ACPICA: ACPI 6.1: Support for new PCCT subtable ACPICA: Refactor evaluate_object to reduce nesting ACPICA: Divergence: remove unwanted spaces for typedef ACPI,PCI,IRQ: remove SCI penalize function ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init() ..
2016-05-16Merge branches 'acpi-pci', 'acpi-misc' and 'acpi-tools'Rafael J. Wysocki
* acpi-pci: ACPI,PCI,IRQ: remove SCI penalize function ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init() ACPI,PCI,IRQ: reduce static IRQ array size to 16 ACPI,PCI,IRQ: reduce resource requirements * acpi-misc: ACPI / sysfs: fix error code in get_status() ACPI / device_sysfs: Clean up checkpatch errors ACPI / device_sysfs: Change _SUN and _STA show functions error return to EIO ACPI / device_sysfs: Add sysfs support for _HRV hardware revision arm64: defconfig: Enable ACPI ACPI / ARM64: Remove EXPERT dependency for ACPI on ARM64 ACPI / ARM64: Don't enable ACPI by default on ARM64 acer-wmi: Use acpi_dev_found() eeepc-wmi: Use acpi_dev_found() ACPI / utils: Rename acpi_dev_present() * acpi-tools: tools/power/acpi: close file only if it is open
2016-05-06Merge back new ACPICA material for v4.7.Rafael J. Wysocki
2016-05-05ACPICA: Move all ASCII utilities to a common fileBob Moore
ACPICA commit ba60e4500053010bf775d58f6f61febbdb94d817 New file is utascii.c Link: https://github.com/acpica/acpica/commit/ba60e450 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-05ACPICA: Divergence: remove unwanted spaces for typedefLv Zheng
ACPICA commit b2294cae776f5a66a7697414b21949d307e6856f This patch removes unwanted spaces for typedef. This solution doesn't cover function types. Note that the linuxize result of this commit is very giant and should have many conflicts against the current Linux upstream. Thus it is required to modify the linuxize result of this commit and the commits around it manually in order to have them merged to the Linux upstream. Since this is very costy, we should do this only once, and if we can't ensure to do this only once, we need to revert the Linux code to the wrong indentation result before merging the linuxize result of this commit. Lv Zheng. Link: https://github.com/acpica/acpica/commit/b2294cae Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-05cpupower: fix potential memory leakArjun Sreedharan
Signed-off-by: Thomas Renninger <trenn@suse.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-28cpupower: Add cpuidle parts into libraryThomas Renninger
This more or less is a renaming and moving of functions and should not introduce any functional change. cpupower was built from cpufrequtils (which had a C library providing easy access to cpu frequency platform info). In the meantime it got enhanced by quite some neat cpuidle userspace tools. Now the cpu idle functions have been separated and added to the cpupower.so library. So beside an already existing public header file: cpufreq.h cpupower now also exports these cpu idle functions in: cpuidle.h Here again pasted for better review of the interfaces: ====================================== int cpuidle_is_state_disabled(unsigned int cpu, unsigned int idlestate); int cpuidle_state_disable(unsigned int cpu, unsigned int idlestate, unsigned int disable); unsigned long cpuidle_state_latency(unsigned int cpu, unsigned int idlestate); unsigned long cpuidle_state_usage(unsigned int cpu, unsigned int idlestate); unsigned long long cpuidle_state_time(unsigned int cpu, unsigned int idlestate); char *cpuidle_state_name(unsigned int cpu, unsigned int idlestate); char *cpuidle_state_desc(unsigned int cpu, unsigned int idlestate); unsigned int cpuidle_state_count(unsigned int cpu); char *cpuidle_get_governor(void); char *cpuidle_get_driver(void); ====================================== Signed-off-by: Thomas Renninger <trenn@suse.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-28cpupowerutils: bench: trivial fix of spelling mistake on "average"Colin Ian King
fix spelling mistake, avarage -> average Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Thomas Renninger <trenn@suse.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-28Fix cpupower manpages "NAME" sectionMattia Dongili
The token before "-" should be the program name, no spaces allowed. See man(7) and lexgrog(1). Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Thomas Renninger <trenn@suse.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-28cpupower: bench: parse.c: fix several resource leaksColin Ian King
The error handling in prepare_output has several issues with resource leaks. Ensure that filename is free'd and the directory stream DIR is closed before returning. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Thomas Renninger <trenn@suse.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-28Honour user's LDFLAGSMattia Dongili
2016-04-09tools/power/acpi: close file only if it is openLv Zheng
The logic on the test for a valid fd to close is incorrect. This was just a mistake and was pointed out by Colin Ian King. Link: https://patchwork.kernel.org/patch/8620201/ Original-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-08Merge branches 'pm-core', 'powercap' and 'pm-tools'Rafael J. Wysocki
* pm-core: PM / wakeirq: fix wakeirq setting after wakup re-configuration from sysfs PM / runtime: Document steps for device removal * powercap: powercap: intel_rapl: Add missing Haswell model * pm-tools: tools/power turbostat: work around RC6 counter wrap tools/power turbostat: initial KBL support tools/power turbostat: initial SKX support tools/power turbostat: decode BXT TSC frequency via CPUID tools/power turbostat: initial BXT support tools/power turbostat: print IRTL MSRs tools/power turbostat: SGX state should print only if --debug
2016-04-07tools/power turbostat: work around RC6 counter wrapLen Brown
Sometimes the rc6 sysfs counter spontaneously resets, causing turbostat prints a very large number as it tries to calcuate % = 100 * (old - new) / interval When we see (old > new), print ***.**% instead of a bogus huge number. Note that this detection is not fool-proof, as the counter could reset several times and still result in new > old. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: initial KBL supportLen Brown
KBL is similar to SKL Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: initial SKX supportLen Brown
SKX has a lot in common with HSX Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: decode BXT TSC frequency via CPUIDLen Brown
Hard-code BXT ART to 19200MHz, so turbostat --debug can fully enumerate TSC: CPUID(0x15): eax_crystal: 3 ebx_tsc: 186 ecx_crystal_hz: 0 TSC: 1190 MHz (19200000 Hz * 186 / 3 / 1000000) Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: initial BXT supportLen Brown
Broxton has a lot in common with SKL Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: print IRTL MSRsLen Brown
Some processors use the Interrupt Response Time Limit (IRTL) MSR value to describe the maximum IRQ response time latency for deep package C-states. (Though others have the register, but do not use it) Lets print it out to give insight into the cases where it is used. IRTL begain in SNB, with PC3/PC6/PC7, and HSW added PC8/PC9/PC10. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-07tools/power turbostat: SGX state should print only if --debugLen Brown
The CPUID.SGX bit was printed, even if --debug was used Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-05ACPICA: Utilities: Update for strtoul64 mergerBob Moore
ACPICA commit 795e136d2ac77c1c8b091fba019b5fe36a44a323 Fixes a problem with the merger of the two internal versions of this function. Make the maximum integer width (32-bit or 64-bit) a parameter to the function so that it no longer exclusively uses the integer width specified in the DSDT/SSDT. ACPICA BZ 1260 Link: https://github.com/acpica/acpica/commit/795e136d Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-05ACPICA: Add support for QNX 6.6 platformWill Miles
ACPICA commit 37a1dec2391272251e59948c16c60713183ae78f Link: https://github.com/acpica/acpica/commit/37a1dec2 Signed-off-by: Will Miles <wmiles@sgl.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-03-16Merge tag 'pm+acpi-4.6-rc1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "This time the majority of changes go into cpufreq and they are significant. First off, the way CPU frequency updates are triggered is different now. Instead of having to set up and manage a deferrable timer for each CPU in the system to evaluate and possibly change its frequency periodically, cpufreq governors set up callbacks to be invoked by the scheduler on a regular basis (basically on utilization updates). The "old" governors, "ondemand" and "conservative", still do all of their work in process context (although that is triggered by the scheduler now), but intel_pstate does it all in the callback invoked by the scheduler with no need for any additional asynchronous processing. Of course, this eliminates the overhead related to the management of all those timers, but also it allows the cpufreq governor code to be simplified quite a bit. On top of that, the common code and data structures used by the "ondemand" and "conservative" governors are cleaned up and made more straightforward and some long-standing and quite annoying problems are addressed. In particular, the handling of governor sysfs attributes is modified and the related locking becomes more fine grained which allows some concurrency problems to be avoided (particularly deadlocks with the core cpufreq code). In principle, the new mechanism for triggering frequency updates allows utilization information to be passed from the scheduler to cpufreq. Although the current code doesn't make use of it, in the works is a new cpufreq governor that will make decisions based on the scheduler's utilization data. That should allow the scheduler and cpufreq to work more closely together in the long run. In addition to the core and governor changes, cpufreq drivers are updated too. Fixes and optimizations go into intel_pstate, the cpufreq-dt driver is updated on top of some modification in the Operating Performance Points (OPP) framework and there are fixes and other updates in the powernv cpufreq driver. Apart from the cpufreq updates there is some new ACPICA material, including a fix for a problem introduced by previous ACPICA updates, and some less significant changes in the ACPI code, like CPPC code optimizations, ACPI processor driver cleanups and support for loading ACPI tables from initrd. Also updated are the generic power domains framework, the Intel RAPL power capping driver and the turbostat utility and we have a bunch of traditional assorted fixes and cleanups. Specifics: - Redesign of cpufreq governors and the intel_pstate driver to make them use callbacks invoked by the scheduler to trigger CPU frequency evaluation instead of using per-CPU deferrable timers for that purpose (Rafael Wysocki). - Reorganization and cleanup of cpufreq governor code to make it more straightforward and fix some concurrency problems in it (Rafael Wysocki, Viresh Kumar). - Cleanup and improvements of locking in the cpufreq core (Viresh Kumar). - Assorted cleanups in the cpufreq core (Rafael Wysocki, Viresh Kumar, Eric Biggers). - intel_pstate driver updates including fixes, optimizations and a modification to make it enable enable hardware-coordinated P-state selection (HWP) by default if supported by the processor (Philippe Longepe, Srinivas Pandruvada, Rafael Wysocki, Viresh Kumar, Felipe Franciosi). - Operating Performance Points (OPP) framework updates to improve its handling of voltage regulators and device clocks and updates of the cpufreq-dt driver on top of that (Viresh Kumar, Jon Hunter). - Updates of the powernv cpufreq driver to fix initialization and cleanup problems in it and correct its worker thread handling with respect to CPU offline, new powernv_throttle tracepoint (Shilpasri Bhat). - ACPI cpufreq driver optimization and cleanup (Rafael Wysocki). - ACPICA updates including one fix for a regression introduced by previos changes in the ACPICA code (Bob Moore, Lv Zheng, David Box, Colin Ian King). - Support for installing ACPI tables from initrd (Lv Zheng). - Optimizations of the ACPI CPPC code (Prashanth Prakash, Ashwin Chaugule). - Support for _HID(ACPI0010) devices (ACPI processor containers) and ACPI processor driver cleanups (Sudeep Holla). - Support for ACPI-based enumeration of the AMBA bus (Graeme Gregory, Aleksey Makarov). - Modification of the ACPI PCI IRQ management code to make it treat 255 in the Interrupt Line register as "not connected" on x86 (as per the specification) and avoid attempts to use that value as a valid interrupt vector (Chen Fan). - ACPI APEI fixes related to resource leaks (Josh Hunt). - Removal of modularity from a few ACPI drivers (BGRT, GHES, intel_pmic_crc) that cannot be built as modules in practice (Paul Gortmaker). - PNP framework update to make it treat ACPI_RESOURCE_TYPE_SERIAL_BUS as a valid resource type (Harb Abdulhamid). - New device ID (future AMD I2C controller) in the ACPI driver for AMD SoCs (APD) and in the designware I2C driver (Xiangliang Yu). - Assorted ACPI cleanups (Colin Ian King, Kaiyen Chang, Oleg Drokin). - cpuidle menu governor optimization to avoid a square root computation in it (Rasmus Villemoes). - Fix for potential use-after-free in the generic device properties framework (Heikki Krogerus). - Updates of the generic power domains (genpd) framework including support for multiple power states of a domain, fixes and debugfs output improvements (Axel Haslam, Jon Hunter, Laurent Pinchart, Geert Uytterhoeven). - Intel RAPL power capping driver updates to reduce IPI overhead in it (Jacob Pan). - System suspend/hibernation code cleanups (Eric Biggers, Saurabh Sengar). - Year 2038 fix for the process freezer (Abhilash Jindal). - turbostat utility updates including new features (decoding of more registers and CPUID fields, sub-second intervals support, GFX MHz and RC6 printout, --out command line option), fixes (syscall jitter detection and workaround, reductioin of the number of syscalls made, fixes related to Xeon x200 processors, compiler warning fixes) and cleanups (Len Brown, Hubert Chrzaniuk, Chen Yu)" * tag 'pm+acpi-4.6-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (182 commits) tools/power turbostat: bugfix: TDP MSRs print bits fixing tools/power turbostat: correct output for MSR_NHM_SNB_PKG_CST_CFG_CTL dump tools/power turbostat: call __cpuid() instead of __get_cpuid() tools/power turbostat: indicate SMX and SGX support tools/power turbostat: detect and work around syscall jitter tools/power turbostat: show GFX%rc6 tools/power turbostat: show GFXMHz tools/power turbostat: show IRQs per CPU tools/power turbostat: make fewer systems calls tools/power turbostat: fix compiler warnings tools/power turbostat: add --out option for saving output in a file tools/power turbostat: re-name "%Busy" field to "Busy%" tools/power turbostat: Intel Xeon x200: fix turbo-ratio decoding tools/power turbostat: Intel Xeon x200: fix erroneous bclk value tools/power turbostat: allow sub-sec intervals ACPI / APEI: ERST: Fixed leaked resources in erst_init ACPI / APEI: Fix leaked resources intel_pstate: Do not skip samples partially intel_pstate: Remove freq calculation from intel_pstate_calc_busy() intel_pstate: Move intel_pstate_calc_busy() into get_target_pstate_use_performance() ...
2016-03-14Merge branch 'turbostat' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-tools Pull turbostat updates for 4.6 from Len Brown. * 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: bugfix: TDP MSRs print bits fixing tools/power turbostat: correct output for MSR_NHM_SNB_PKG_CST_CFG_CTL dump tools/power turbostat: call __cpuid() instead of __get_cpuid() tools/power turbostat: indicate SMX and SGX support tools/power turbostat: detect and work around syscall jitter tools/power turbostat: show GFX%rc6 tools/power turbostat: show GFXMHz tools/power turbostat: show IRQs per CPU tools/power turbostat: make fewer systems calls tools/power turbostat: fix compiler warnings tools/power turbostat: add --out option for saving output in a file tools/power turbostat: re-name "%Busy" field to "Busy%" tools/power turbostat: Intel Xeon x200: fix turbo-ratio decoding tools/power turbostat: Intel Xeon x200: fix erroneous bclk value tools/power turbostat: allow sub-sec intervals tools/power turbostat: Decode MSR_MISC_PWR_MGMT tools/power turbostat: decode HWP registers x86 msr-index: Simplify syntax for HWP fields tools/power turbostat: CPUID(0x16) leaf shows base, max, and bus frequency tools/power turbostat: decode more CPUID fields
2016-03-13tools/power turbostat: bugfix: TDP MSRs print bits fixingChen Yu
MSR_CONFIG_TDP_NOMINAL: should print all 8 bits of base_ratio (bit 0:7) 0xFF MSR_CONFIG_TDP_LEVEL_1: should print all 15 bits of PKG_MIN_PWR_LVL1 (bit 48:62) 0x7FFF should print all 15 bits of PKG_MAX_PWR_LVL1 (bit 32:46) 0x7FFF should print all 8 bits of LVL1_RATIO (bit 16:23) 0xFF should print all 15 bits of PKG_TDP_LVL1 (bit 0:14) 0x7FFF And the same modification to MSR_CONFIG_TDP_LEVEL_2. MSR_TURBO_ACTIVATION_RATIO: should print all 8 bits of MAX_NON_TURBO_RATIO (bit 0:7) 0xFF Signed-off-by: Chen Yu <yu.c.chen@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: correct output for MSR_NHM_SNB_PKG_CST_CFG_CTL dumpLen Brown
MSR_NHM_SNB_PKG_CST_CFG_CTL: 0x1e008008 (...pkg-cstate-limit=0: unlimited) should print as MSR_NHM_SNB_PKG_CST_CFG_CTL: 0x1e008008 (...pkg-cstate-limit=8: unlimited) Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: call __cpuid() instead of __get_cpuid()Len Brown
turbostat already checks whether calling each cpuid leavf is legal, and it doesn't look at the function return value, so call the simpler gcc intrinsic __cpuid() instead of __get_cpuid(). syntax only, no functional change Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: indicate SMX and SGX supportLen Brown
SGX presence is related to a SKL power workaround, so lets show when that is enabled. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: detect and work around syscall jitterLen Brown
The accuracy of Bzy_Mhz and Busy% depend on reading the TSC, APERF, and MPERF close together in time. When there is a very short measurement interval, or a large system is profoundly idle, the changes in APERF and MPERF may be very small. They can be small enough that an expensive interrupt between reading APERF and MPERF can cause the APERF/MPERF ratio to become inaccurate, resulting in invalid calculation and display of Bzy_MHz. A dummy APERF read of APERF makes this problem much more rare. Apparently this 1st systemn call after exiting a long stretch of idle is when we typically see expensive timer interrupts that cause large jitter. For the cases that dummy APERF read fails to prevent, we compare the latency of the APERF and MPERF reads. If they differ by more than 2x, we re-issue them. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: show GFX%rc6Len Brown
The column "GFX%c6" show the percentage of time the GPU is in the "render C6" state, rc6. Deep package C-states on several systems depend on the GPU being in RC6. This information comes from the counter /sys/class/drm/card0/power/rc6_residency_ms, as read before and after the measurement interval. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: show GFXMHzLen Brown
Under the column "GFXMHz", show a snapshot of this attribute: /sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz This is an instantaneous snapshot of what sysfs presents at the end of the measurement interval. turbostat does not average or otherwise perform any math on this value. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: show IRQs per CPULen Brown
The new IRQ column shows how many interrupts have occurred on each CPU during the measurement inteval. This information comes from the difference between /proc/interrupts shapshots made before and after the measurement interval. The first row, the system summary, shows the sum of the IRQS for all CPUs during that interval. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: make fewer systems callsLen Brown
skip the open(2)/close(2) on each msr read by keeping the /dev/cpu/*/msr files open. The remaining read(2) is generally far fewer cycles than the removed open(2) system call. Signed-off-by: Len Brown <len.brown@intel.com>
2016-03-13tools/power turbostat: fix compiler warningsLen Brown
2016-03-13tools/power turbostat: add --out option for saving output in a fileLen Brown
By default... Turbostat --debug gconfiguration info goes to stderr. In FORK mode, turbostat statistics go to stderr. In PERIODIC mode, turbostat statistics go to stdout. These defaults do not change, but an option "--out file" will send all output above only to the specified file. Signed-off-by: Len Brown <len.brown@intel.com>
