path: root/tools/testing/selftests/x86/trivial_32bit_program.c
2015-05-12selftests, x86: Rework x86 target architecture detectionAndy Lutomirski
We currently fail to build on a non-multilib x86_64 target. We print a helpful error, but it's nicer to allow the build to succeed. Fix it and improve cross-compilation support by detecting architecture support directly and building only the relevant tests. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-04-08x86, selftests: Add sigreturn selftestAndy Lutomirski
This is my sigreturn test, added mostly unchanged from its old home. It exercises the sigreturn(2) syscall, specifically focusing on its interactions with various IRET corner cases. It tests for correct behavior in several areas that were historically dangerously buggy. For example, it exercises espfix on kernels of both bitnesses under various conditions, and it contains testcases for several now-fixed bugs in IRET error handling. If you run it on older kernels without the fixes, your system will crash. It probably won't eat your data in the process. There is no released kernel on which the sigreturn_64 test will pass, but it passes on tip:x86/asm. I plan to switch to lib.mk for Linux 4.2. I'm not using the ksft_ helpers at all yet. I can do that later. Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuah.kh@samsung.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/89d10b76b92c7202d8123654dc8d36701c017b3d.1428386971.git.luto@kernel.org [ Fixed empty format string GCC build warning in trivial_32bit_program.c ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
