[ Upstream commit 69f8117f17b332a68cd8f4bf8c2d0d3d5b84efc5 ]
Use TEST_GEN_PROGS and don't redefine all, this makes the out-of-tree
build work. We need to move the extra dependencies below the include
of lib.mk, because it adds the $(OUTPUT) prefix if it's defined.
We can also drop the clean rule, lib.mk does it for us.
[ Upstream commit 266bac361d5677e61a6815bd29abeb3bdced2b07 ]
For the out-of-tree build to work we need to tell switch_endian_test
to look for check-reversed.S in $(OUTPUT).
[ Upstream commit 27825349d7b238533a47e3d98b8bb0efd886b752 ]
We should use TEST_GEN_PROGS, not TEST_PROGS. That tells the selftests
makefile (lib.mk) that those tests are generated (built), and so it
adds the $(OUTPUT) prefix for us, making the out-of-tree build work
correctly.
It also means we don't need our own clean rule, lib.mk does it.
We also have to update the signal_tm rule to use $(OUTPUT).
Signed-off-by: Joel Stanley <joel@jms.id.au>
[ Upstream commit 04d5e4bd37516ad60854eb74592c7dbddd75d277 ]
Printf's say errno but print the string version of error.
Make consistent.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hpe.com>
Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
[ Upstream commit 9a244229a4b850b11952a0df79607c69b18fd8df ]
When /dev/watchdog open fails, watchdog exits with "watchdog not enabled"
message. This is incorrect when open fails due to insufficient privilege.
Fix message to clearly state the reason when open fails with EACCESS when
a non-root user runs it.
[ Upstream commit 2452c96e617a0ff6fb2692e55217a3fa57a7322c ]
Test $comm in kprobe-event argument syntax testcase
only if it is supported on the kernel because
$comm has been introduced 4.8 kernel.
So on older stable kernel, it should be skipped.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
commit 5b216ea1c40cf06eead15054c70e238c9bd4729e upstream.
Newer versions of GCC (>= 9) demand that the size of the string to be
copied must be explicitly smaller than the size of the destination.
Thus, the NULL char has to be taken into account on strncpy.
This will avoid the following compiling error:
tlbie_test.c: In function 'main':
tlbie_test.c:639:4: error: 'strncpy' specified bound 100 equals destination size
strncpy(logdir, optarg, LOGDIR_NAME_SIZE);
cc1: all warnings being treated as errors
Cc: stable@vger.kernel.org # v4.14
Signed-off-by: Desnes A. Nunes do Rosario <desnesn@linux.ibm.com>
Link: https://lore.kernel.org/r/20191003211010.9711-1-desnesn@linux.ibm.com
[sandipan: Backported to v4.14]
Signed-off-by: Sandipan Das <sandipan@linux.ibm.com>
commit 93cad5f789951eaa27c3392b15294b4e51253944 upstream.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
[mpe: Some minor fixes to make it build]
Link: https://lore.kernel.org/r/20190924035254.24612-4-aneesh.kumar@linux.ibm.com
[ Upstream commit d64479a3e3f9924074ca7b50bd72fa5211dca9c1 ]
This test reports EINVAL for getsockopt(SOL_SOCKET, SO_DOMAIN)
occasionally due to the uninitialized length parameter.
Initialize it to fix this, and also use int for "test_family" to comply
with the API standard.
Fixes: d6a61f80b871 ("soreuseport: test mixed v4/v6 sockets")
Reported-by: Maciej Żenczykowski <maze@google.com>
Signed-off-by: Wei Wang <weiwan@google.com>
Cc: Craig Gallek <cgallek@google.com>
[ Upstream commit c096397c78f766db972f923433031f2dec01cae0 ]
selftests kvm test cases need pre-required kernel configs for the test
to get pass.
Signed-off-by: Naresh Kamboju <naresh.kamboju@linaro.org>
[ Upstream commit 82ce6eb1dd13fd12e449b2ee2c2ec051e6f52c43 ]
A test for the basic NAT functionality uses ip command which needs veth
device. There is a condition where the kernel support for veth is not
compiled into the kernel and the test script breaks. This patch contains
code for reasonable error display and correct code exit.
Signed-off-by: Jeffrin Jose T <jeffrin@rajagiritech.edu.in>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit fe48319243a626c860fd666ca032daacc2ba84a5 ]
When running under a pipe, some timer tests would not report output in
real-time because stdout flushes were missing after printf()s that lacked
a newline. This adds them to restore real-time status output that humans
can enjoy.
Signed-off-by: Shuah Khan <skhan@linuxfoundation.org>
[ Upstream commit 30c04d796b693e22405c38e9b78e9a364e4c77e6 ]
The run_netsocktests will be marked as passed regardless the actual test
result from the ./socket:
selftests: net: run_netsocktests
running socket test
[FAIL]
ok 1..6 selftests: net: run_netsocktests [PASS]
This is because the test script itself has been successfully executed.
Fix this by exit 1 when the test failed.
Signed-off-by: Po-Hsu Lin <po-hsu.lin@canonical.com>
[ Upstream commit becf2319f320cae43e20cf179cc51a355a0deb5f ]
When an icmp error such as pkttoobig is received, conntrack checks
if the "inner" header (header of packet that did not fit link mtu)
is matches an existing connection, and, if so, sets that packet as
being related to the conntrack entry it found.
It was recently reported that this "related" setting also works
if the inner header is from another, different connection (i.e.,
artificial/forged icmp error).
Add a test, followup patch will add additional "inner dst matches
outer dst in reverse direction" check before setting related state.
Link: https://www.synacktiv.com/posts/systems/icmp-reachable.html
The changes to fix the CVE 2019-7308 make the bpf verifier stricter
with respect to operations that were allowed earlier in unprivileged
mode. Fixup the test cases so that the error messages now correctly
reflect pointer arithmetic going out of range for tests.
Signed-off-by: Balbir Singh <sblbir@amzn.com>
[ Upstream commit 98bfc3414bda335dbd7fec58bde6266f991801d7 ]
Check basic nat/redirect/masquerade for ipv4 and ipv6.
[ Upstream commit 952b72f89ae23b316da8c1021b18d0c388ad6cc4 ]
In selftests the config fragment for netfilter was added as
NF_TABLES_INET=y and this patch correct it as CONFIG_NF_TABLES_INET=y
[ Upstream commit 1bb54c4071f585ebef56ce8fdfe6026fa2cbcddd ]
Previously, bpf_num_possible_cpus() had a bug when calculating a
number of possible CPUs in the case of sparse CPU allocations, as
it was considering only the first range or element of
/sys/devices/system/cpu/possible.
E.g. in the case of "0,2-3" (CPU 1 is not available), the function
returned 1 instead of 3.
This patch fixes the function by making it parse all CPU ranges and
elements.
Signed-off-by: Martynas Pumputis <m@lambda.lt>
Acked-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 7d4e591bc051d3382c45caaa2530969fb42ed23d ]
posix_timers fails to build due to undefined reference errors:
aarch64-linaro-linux-gcc --sysroot=/build/tmp-rpb-glibc/sysroots/hikey
-O2 -pipe -g -feliminate-unused-debug-types -O3 -Wl,-no-as-needed -Wall
-DKTEST -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lrt -lpthread
posix_timers.c
-o /build/tmp-rpb-glibc/work/hikey-linaro-linux/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers
/tmp/cc1FTZzT.o: In function `check_timer_create':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers.c:157:
undefined reference to `timer_create'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/timers/posix_timers.c:170:
undefined reference to `timer_settime'
collect2: error: ld returned 1 exit status
It's GNU Make and linker specific.
The default Makefile rule looks like:
$(CC) $(CFLAGS) $(LDFLAGS) $@ $^ $(LDLIBS)
When linking is done by gcc itself, no issue, but when it needs to be passed
to proper ld, only LDLIBS follows and then ld cannot know what libs to link
with.
More detail:
https://www.gnu.org/software/make/manual/html_node/Implicit-Variables.html
LDFLAGS
Extra flags to give to compilers when they are supposed to invoke the linker,
‘ld’, such as -L. Libraries (-lfoo) should be added to the LDLIBS variable
instead.
LDLIBS
Library flags or names given to compilers when they are supposed to invoke the
linker, ‘ld’. LOADLIBES is a deprecated (but still supported) alternative to
LDLIBS. Non-library linker flags, such as -L, should go in the LDFLAGS
variable.
https://lkml.org/lkml/2010/2/10/362
tools/perf: libraries must come after objects
Link order matters, use LDLIBS instead of LDFLAGS to properly link against
libpthread.
Signed-off-by: Denys Dmytriyenko <denys@ti.com>
Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org>
Signed-off-by: Shuah Khan <shuah@kernel.org>
[ Upstream commit 2b531b6137834a55857a337ac17510d6436b6fbb ]
The cpu-hotplug test assumes that we can offline the maximum CPU as
described by /sys/devices/system/cpu/offline. However, in the case
where the number of CPUs exceeds like kernel configuration then
the offline count can be greater than the present count and we end
up trying to test the offlining of a CPU that is not available to
offline. Fix this by testing the maximum present CPU instead.
Also, the test currently offlines the CPU and does not online it,
so fix this by onlining the CPU after the test.
Fixes: d89dffa976bc ("fault-injection: add selftests for cpu and memory hotplug")
[ Upstream commit 508cacd7da6659ae7b7bdd0a335f675422277758 ]
With gcc 7.3.0:
gpio-mockup-chardev.c: In function ‘get_debugfs’:
gpio-mockup-chardev.c:62:3: warning: ignoring return value of ‘asprintf’, declared with attribute warn_unused_result [-Wunused-result]
asprintf(path, "%s/gpio", mnt_fs_get_target(fs));
Handle asprintf() failures to fix this.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 5bbc73a841d7f0bbe025a342146dde462a796a5a ]
seccomp_bpf fails to build due to undefined reference errors:
-O2 -pipe -g -feliminate-unused-debug-types -Wl,-no-as-needed -Wall
-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lpthread seccomp_bpf.c -o
/build/tmp-rpb-glibc/work/hikey-linaro-linux/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf
/tmp/ccrlR3MW.o: In function `tsync_sibling':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1920: undefined reference to `sem_post'
/tmp/ccrlR3MW.o: In function `TSYNC_setup':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1863: undefined reference to `sem_init'
/tmp/ccrlR3MW.o: In function `TSYNC_teardown':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1904: undefined reference to `sem_destroy'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1897: undefined reference to `pthread_kill'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1898: undefined reference to `pthread_cancel'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1899: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `tsync_start_sibling':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1941: undefined reference to `pthread_create'
/tmp/ccrlR3MW.o: In function `TSYNC_siblings_fail_prctl':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1978: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1990: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:1992: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_ancestor':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2016: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2032: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2034: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_sibling_want_nnp':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2046: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2058: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2060: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_no_filter':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2073: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2098: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2100: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_with_one_divergence':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2125: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2143: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2145: undefined reference to `pthread_join'
/tmp/ccrlR3MW.o: In function `TSYNC_two_siblings_not_under_filter':
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2169: undefined reference to `sem_wait'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2202: undefined reference to `pthread_join'
/usr/src/debug/kselftests/4.12-r0/linux-4.12-rc7/tools/testing/selftests/seccomp/seccomp_bpf.c:2227: undefined reference to `pthread_join'
with.
More detail:
LDFLAGS
instead.
LDLIBS
variable.
libpthread.
[ Upstream commit a0517a0f7ef23550b4484c37e2b9c2d32abebf64 ]
For some reason, my older GCC (< 4.8) isn't smart enough to optimize the
!__builtin_constant_p() branch in bpf_htons, I see:
error: implicit declaration of function '__builtin_bswap16'
Let's use __bpf_constant_htons as suggested by Daniel Borkmann.
I tried to use simple htons, but it produces the following:
test_progs.c:54:17: error: braced-group within expression allowed only
inside a function
.eth.h_proto = htons(ETH_P_IP),
Signed-off-by: Stanislav Fomichev <sdf@google.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit ed5f13261cb65b02c611ae9971677f33581d4286 upstream.
Passing EPERM during syscall skipping was confusing since the test wasn't
actually exercising the errno evaluation -- it was just passing a literal
"1" (EPERM). Instead, expand the tests to check both direct value returns
(positive, 45000 in this case), and errno values (negative, -ESRCH in this
case) to check both fake success and fake failure during syscall skipping.
Reported-by: Colin Ian King <colin.king@canonical.com>
Fixes: a33b2d0359a0 ("selftests/seccomp: Add tests for basic ptrace actions")
This reverts commit e65cd9a20343ea90f576c24c38ee85ab6e7d5fec.
Tommi T. Rrantala notes:
PTRACE_SECCOMP_GET_METADATA was only added in 4.16
(26500475ac1b499d8636ff281311d633909f5d20)
And it's also breaking seccomp_bpf.c compilation for me:
seccomp_bpf.c: In function ‘get_metadata’:
seccomp_bpf.c:2878:26: error: storage size of ‘md’ isn’t known
struct seccomp_metadata md;
commit e1812933b17be7814f51b6c310c5d1ced7a9a5f5 upstream.
There was a bug where the per-mm pkey state was not being preserved across
fork() in the child. fork() is performed in the pkey selftests, but all of
the pkey activity is performed in the parent. The child does not perform
any actions sensitive to pkey state.
To make the test more sensitive to these kinds of bugs, add a fork() where
the parent exits, and execution continues in the child.
To achieve this let the key exhaustion test not terminate at the first
allocation failure and fork after 2*NR_PKEYS loops and continue in the
child.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: bp@alien8.de
Cc: hpa@zytor.com
Cc: peterz@infradead.org
Cc: mpe@ellerman.id.au
Cc: will.deacon@arm.com
Cc: luto@kernel.org
Cc: jroedel@suse.de
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Joerg Roedel <jroedel@suse.de>
Link: https://lkml.kernel.org/r/20190102215657.585704B7@viggo.jf.intel.com
[ Upstream commit b708a3cc9600390ccaa2b68a88087dd265154b2b ]
I've stumbled over the current macro-expand behaviour of the test
harness:
$ gcc -Wall -xc - <<'__EOF__'
TEST(macro) {
int status = 0;
ASSERT_TRUE(WIFSIGNALED(status));
TEST_HARNESS_MAIN
__EOF__
$ ./a.out
[==========] Running 1 tests from 1 test cases.
[ RUN ] global.macro
<stdin>:4:global.macro:Expected 0 (0) != (((signed char) (((status) & 0x7f) + 1) >> 1) > 0) (0)
global.macro: Test terminated by assertion
[ FAIL ] global.macro
[==========] 0 / 1 tests passed.
[ FAILED ]
With this change the output of the same test looks much more
comprehensible:
<stdin>:4:global.macro:Expected 0 (0) != WIFSIGNALED(status) (0)
[ FAILED ]
The issue is very similar to the bug fixed in glibc assert(3)
three years ago:
https://sourceware.org/bugzilla/show_bug.cgi?id=18604
Cc: Shuah Khan <shuah@kernel.org>
Cc: Will Drewry <wad@chromium.org>
Cc: linux-kselftest@vger.kernel.org
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
[ Upstream commit c01ac66b38660f2b507ccd0b75d28e3002d56fbb ]
The message got changed a lot time ago.
This was responsible for 36 test case failures on sparc64.
Fixes: f1174f77b50c ("bpf/verifier: rework value tracking")
[ Upstream commit 25d8bcedbf4329895dbaf9dd67baa6f18dad918c ]
Start flood ping for each cpu while loading/flushing rulesets to make
sure we do not access already-free'd rules from nf_tables evaluation loop.
Also add this to TARGETS so 'make run_tests' in selftest dir runs it
automatically.
This would have caught the bug fixed in previous change
("netfilter: nf_tables: do not skip inactive chains during generation update")
sooner.
[ Upstream commit 693b31b2fc1636f0aa7af53136d3b49f6ad9ff39 ]
Test tm-tmspr might exit before all threads stop executing, because it just
waits for the very last thread to join before proceeding/exiting.
This patch makes sure that all threads that were created will join before
proceeding/exiting.
This patch also guarantees that the amount of threads being created is equal
to thread_num.
Signed-off-by: Breno Leitao <leitao@debian.org>
commit 48dc0ef19044bfb69193302fbe3a834e3331b7ae upstream.
Test ptrace-tm-spd-gpr fails on current kernel (4.19) due to a segmentation
fault that happens on the child process prior to setting cptr[2] = 1. This
causes the parent process to wait forever at 'while (!pptr[2])' and the test to
be killed by the test harness framework by timeout, thus, failing.
The segmentation fault happens because of a inline assembly being
generated as:
0x10000355c <tm_spd_gpr+492> lfs f0, 0(0)
This is reading memory position 0x0 and causing the segmentation fault.
This code is being generated by ASM_LOAD_FPR_SINGLE_PRECISION(flt_4), where
flt_4 is passed to the inline assembly block as:
[flt_4] "r" (&d)
Since the inline assembly 'r' constraint means any GPR, gpr0 is being
chosen, thus causing this issue when issuing a Load Floating-Point Single
instruction.
This patch simply changes the constraint to 'b', which specify that this
register will be used as base, and r0 is not allowed to be used, avoiding
this issue.
Other than that, removing flt_2 register from the input operands, since it
is not used by the inline assembly code at all.
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
[ Upstream commit ba0e41ca81b935b958006c7120466e2217357827 ]
Add a testcase to check the syntax and field types for
synthetic_events interface.
Link: http://lkml.kernel.org/r/153986838264.18251.16627517536956299922.stgit@devbox
Acked-by: Shuah Khan <shuah@kernel.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 262f9d811c7608f1e74258ceecfe1fa213bdf912 ]
If the current process has unlimited RLIMIT_MEMLOCK,
we should should leave it as is.
Fixes: 941ff6f11c02 ("bpf: fix rlimit in reuseport net selftest")
Signed-off-by: John Sperbeck <jsperbeck@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 3c718e677c2b35b449992adc36ecce883c467e98 ]
the script rtnetlink.sh requires a bash-only features (sleep with sub-second
precision). This may cause random test failure if the default shell is not
bash.
Address the above explicitly requiring bash as the script interpreter.
Fixes: 33b01b7b4f19 ("selftests: add rtnetlink test script")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 9c2ddfe55c42bf4b9bc336a0650ab78f9222a159 ]
This test the ptrace hw breakpoints via PTRACE_SET_DEBUGREG and
PPC_PTRACE_SETHWDEBUG. This test was use to find the bugs fixed by
these recent commits:
4f7c06e26e powerpc/ptrace: Fix setting 512B aligned breakpoints with PTRACE_SET_DEBUGREG
cd6ef7eebf powerpc/ptrace: Fix enforcement of DAWR constraints
Signed-off-by: Michael Neuling <mikey@neuling.org>
[mpe: Add SPDX tag, clang format it]
[ Upstream commit 4d85af102a66ee6aeefa596f273169e77fb2b48e ]
add CONFIG_MEMORY_HOTREMOVE=y in config
without this config, /sys/devices/system/memory/memory*/removable
always return 0, I endup getting an early skip during test
Signed-off-by: Lei Yang <Lei.Yang@windriver.com>
[ Upstream commit 53cf59d6c0ad3edc4f4449098706a8f8986258b6 ]
add config file
commit 02e425668f5c9deb42787d10001a3b605993ad15 upstream.
When I added the missing memory outputs, I failed to update the
index of the first argument (ebx) on 32-bit builds, which broke the
fallbacks. Somehow I must have screwed up my testing or gotten
lucky.
Add another test to cover gettimeofday() as well.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Fixes: 715bd9d12f84 ("x86/vdso: Fix asm constraints on vDSO syscall fallbacks")
Link: http://lkml.kernel.org/r/21bd45ab04b6d838278fa5bebfa9163eceffa13c.1538608971.git.luto@kernel.org
commit 7c03e7035ac1cf2a6165754e4f3a49c2f1977838 upstream.
Now that the vDSO implementation of clock_gettime() is getting
reworked, add a selftest for it. This tests that its output is
consistent with the syscall version.
This is marked for stable to serve as a test for commit
Link: https://lkml.kernel.org/r/082399674de2619b2befd8c0dde49b260605b126.1538422295.git.luto@kernel.org
adjustments are in progress
[ Upstream commit 1416270f4a1ae83ea84156ceba19a66a8f88be1f ]
In the past we've warned when ADJ_OFFSET was in progress, usually
caused by ntpd or some other time adjusting daemon running in non
steady sate, which can cause the skew calculations to be
incorrect.
Thus, this patch checks to see if the clock was being adjusted
when we fail so that we don't cause false negatives.
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Suggested-by: Miroslav Lichvar <mlichvar@redhat.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit 0069fb854364da79fd99236ea620affc8e1152d5 ]
Commit fbeb1603bf4e ("bpf: verifier: MOV64 don't mark dst reg unbounded")
revealed a typo in commit fb30d4b71214 ("bpf: Add tests for map-in-map"):
BPF_MOV64_REG(BPF_REG_0, 0) was used instead of
BPF_MOV64_IMM(BPF_REG_0, 0).
I've noticed the problem by running bpf kselftests.
Fixes: fb30d4b71214 ("bpf: Add tests for map-in-map")
Signed-off-by: Roman Gushchin <guro@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Arthur Fabre <afabre@cloudflare.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexei Starovoitov <ast@kernel.org>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 7c27a26e1ed5a7dd709aa19685d2c98f64e1cf0c ]
There are some powerpc selftests, as tm/tm-unavailable, that run for a long
period (>120 seconds), and if it is interrupted, as pressing CRTL-C
(SIGINT), the foreground process (harness) dies but the child process and
threads continue to execute (with PPID = 1 now) in background.
In this case, you'd think the whole test exited, but there are remaining
threads and processes being executed in background. Sometimes these
zombies processes are doing annoying things, as consuming the whole CPU or
dumping things to STDOUT.
This patch fixes this problem by attaching an empty signal handler to
SIGINT in the harness process. This handler will interrupt (EINTR) the
parent process waitpid() call, letting the code to follow through the
normal flow, which will kill all the processes in the child process group.
This patch also fixes a typo.
Signed-off-by: Gustavo Romero <gromero@linux.vnet.ibm.com>
[ Upstream commit 82f4f3e69c5c29bce940dd87a2c0f16c51d48d17 ]
Add a testcase for checking snapshot and tracing_on
relationship. This ensures that the snapshotting doesn't
affect current tracing on/off settings.
Link: http://lkml.kernel.org/r/153149932412.11274.15289227592627901488.stgit@devbox
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Hiraku Toyooka <hiraku.toyooka@cybertrust.co.jp>
[ Upstream commit e8a445dea219c32727016af14f847d2e8f7ebec8 ]
We have short names for the requested and resulting register values.
Use them instead of spelling out the whole register entry for each
case.
Link: http://lkml.kernel.org/r/bb3bc1f923a2f6fe7912d22a1068fe29d6033d38.1530076529.git.luto@kernel.org
[ Upstream commit ec348020566009d3da9b99f07c05814d13969c78 ]
When I wrote the sigreturn test, I didn't realize that AMD's busted
IRET behavior was different from Intel's busted IRET behavior:
On AMD CPUs, the CPU leaks the high 32 bits of the kernel stack pointer
to certain userspace contexts. Gee, thanks. There's very little
the kernel can do about it. Modify the test so it passes.
Link: http://lkml.kernel.org/r/86e7fd3564497f657de30a36da4505799eebef01.1530076529.git.luto@kernel.org
testing script
[ Upstream commit 81e167c2a216e7b54e6add9d2badcda267fe33b1 ]
The test_kmod.sh script require root privilege for the successful
execution of the test.
This patch is to notify the user about the privilege the script
demands for the successful execution of the test.
Signed-off-by: Jeffrin Jose T (Rajagiri SET) <ahiliation@gmail.com>
[ Upstream commit d6a3e55131fcb1e5ca1753f4b6f297a177b2fc91 ]
Unless the software synchronization objects (CONFIG_SW_SYNC) is enabled,
the sync test will be skipped:
TAP version 13
1..0 # Skipped: Sync framework not supported by kernel
Add a config fragment file to be able to run "make kselftest-merge" to
enable relevant configuration required in order to run the sync test.
Link: https://lkml.org/lkml/2017/5/5/14
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
[ Upstream commit a4d7537789724985cafbc9260a31ca4f2b7cf123 ]
When vm test is skipped because of unmet dependencies and/or unsupported
configuration, it exits with error which is treated as a fail by the
Kselftest framework. This leads to false negative result even when the
test could not be run.
Change it to return kselftest skip code when a test gets skipped to
clearly report that the test could not be run.
Kselftest framework SKIP code is 4 and the framework prints appropriate
messages to indicate that the test is skipped.
Acked-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
[ Upstream commit 685814466bf8398192cf855415a0bb2cefc1930e ]
When zram test is skipped because of unmet dependencies and/or
unsupported configuration, it exits with error which is treated as
a fail by the Kselftest framework. This leads to false negative result
even when the test could not be run.
[ Upstream commit d7d5311d4aa9611fe1a5a851e6f75733237a668a ]
When user test is skipped because of unmet dependencies and/or
clearly report that the test could not be run. Add an explicit check
for module presence and return skip code if module isn't present.
