commit 65973dd3fd31151823f4b8c289eebbb3fb7e6bc0 upstream.
i386 glibc is buggy and calls the sigaction syscall incorrectly.
This is asymptomatic for normal programs, but it blows up on
programs that do evil things with segmentation. The ldt_gdt
self-test is an example of such an evil program.
This doesn't appear to be a regression -- I think I just got lucky
with the uninitialized memory that glibc threw at the kernel when I
wrote the test.
This hackish fix manually issues sigaction(2) syscalls to undo the
damage. Without the fix, ldt_gdt_32 segfaults; with the fix, it
passes for me.
See: https://sourceware.org/bugzilla/show_bug.cgi?id=21269
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Thomas Garnier <thgarnie@google.com>
Link: http://lkml.kernel.org/r/aaab0f9f93c9af25396f01232608c163a760a668.1490218061.git.luto@kernel.org
commit 32677207dcc5e594254b7fb4fb2352b1755b1d5b upstream.
The child_exit errno needs to be shifted by 8 bits to compare against the
return values for the bisect variables.
Fixes: c5dacb88f0a64 ("ktest: Allow overriding bisect test results")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit df21d2fa733035e4d414379960f94b2516b41296 upstream.
Test uses PMC2 to count the event. But PMC1 is being initialized.
Patch to fix it.
Fixes: 3752e453f6ba ('selftests/powerpc: Add tests of PMU EBBs')
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
commit a2b1e8a20c992b01eeb76de00d4f534cbe9f3822 upstream.
Nothing in this minimal script seems to require bash. We often run these
tests on embedded devices where the only shell available is the busybox
ash. Use sh instead.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit 3659f98b5375d195f1870c3e508fe51e52206839 upstream.
commit d8d378fa1a0c98ecb50ca52c9bf3bc14e25aa2d2 upstream.
The unit tests crash when hotplug races the previous probe. This race
requires that the loading of the nfit_test module be terminated with
SIGTERM, and the module to be unloaded while the ars scan is still
running.
In contrast to the normal nfit driver, the unit test calls
acpi_nfit_init() twice to simulate hotplug, whereas the nominal case
goes through the acpi_nfit_notify() event handler. The
acpi_nfit_notify() path is careful to flush the previous region
registration before servicing the hotplug event. The unit test was
missing this guarantee.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810cdce7>] pwq_activate_delayed_work+0x47/0x170
Call Trace:
[<ffffffff810ce186>] pwq_dec_nr_in_flight+0x66/0xa0
[<ffffffff810ce490>] process_one_work+0x2d0/0x680
[<ffffffff810ce331>] ? process_one_work+0x171/0x680
[<ffffffff810ce88e>] worker_thread+0x4e/0x480
[<ffffffff810ce840>] ? process_one_work+0x680/0x680
[<ffffffff810d5343>] kthread+0xf3/0x110
[<ffffffff8199846f>] ret_from_fork+0x1f/0x40
[<ffffffff810d5250>] ? kthread_create_on_node+0x230/0x230
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
When support for _FIT was added, the code presumed that the data
returned by the _FIT method is identical to the NFIT table, which
starts with an acpi_table_header. However, the _FIT is defined
to return a data in the format of a series of NFIT type structure
entries and as a method, has an acpi_object header rather tahn
To address the differences, explicitly save the acpi_table_header
from the NFIT, since it is accessible through /sys, and change
the nfit pointer in the acpi_desc structure to point to the
table entries rather than the headers.
Reported-by: Jeff Moyer (jmoyer@redhat.com>
Signed-off-by: Linda Knippers <linda.knippers@hpe.com>
Acked-by: Vishal Verma <vishal.l.verma@intel.com>
[vishal: fix up unit test for new header assumptions]
The commit fd88d16c58c2 ("selftests/seccomp: Be more precise with
syscall arguments.") use PAGE_SIZE directly which lead to build
failure on arm64.
Replace it with generic interface(sysconf(_SC_PAGESIZE)) to fix this
failure.
Build and test successful on x86_64 and arm64.
Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
Correct typo in tools/testing/selftests/futex/README.
Signed-off-by: Wei Jiangang <weijg.fnst@cn.fujitsu.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Commit ca321d1ca672 "ACPICA: Update NFIT table to rename a flags field"
performed a tree-wide s/ACPI_NFIT_MEM_ARMED/ACPI_NFIT_MEM_NOT_ARMED/
operation, but missed the tools/testing/nvdimm/ directory.
Cc: Bob Moore <robert.moore@intel.com>
Cc: Lv Zheng <lv.zheng@intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Merge final patch-bomb from Andrew Morton:
"Various leftovers, mainly Christoph's pci_dma_supported() removals"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
pci: remove pci_dma_supported
usbnet: remove ifdefed out call to dma_supported
kaweth: remove ifdefed out call to dma_supported
sfc: don't call dma_supported
nouveau: don't call pci_dma_supported
netup_unidvb: use pci_set_dma_mask insted of pci_dma_supported
cx23885: use pci_set_dma_mask insted of pci_dma_supported
cx25821: use pci_set_dma_mask insted of pci_dma_supported
cx88: use pci_set_dma_mask insted of pci_dma_supported
saa7134: use pci_set_dma_mask insted of pci_dma_supported
saa7164: use pci_set_dma_mask insted of pci_dma_supported
tw68-core: use pci_set_dma_mask insted of pci_dma_supported
pcnet32: use pci_set_dma_mask insted of pci_dma_supported
lib/string.c: add ULL suffix to the constant definition
hugetlb: trivial comment fix
selftests/mlock2: add ULL suffix to 64-bit constants
selftests/mlock2: add missing #define _GNU_SOURCE
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest updates from Shuah Khan:
"This 12 patch update for 4.4-rc1 consists of a new pstore test and
fixes to existing tests"
* tag 'linux-kselftest-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests: breakpoint: Actually build it
selftests: vm: Try harder to allocate huge pages
selftests: Make scripts executable
selftests: kprobe: Choose an always-defined function to probe
selftests: memfd: Stop unnecessary rebuilds
selftests: Add missing #include directives
selftests/seccomp: Be more precise with syscall arguments.
selftests/seccomp: build and pass on arm64
selftests: memfd_test: Revised STACK_SIZE to make it 16-byte aligned
selftests/pstore: add pstore test scripts going with reboot
selftests/pstore: add pstore test script for pre-reboot
selftests: add .gitignore for efivarfs
On 32-bit (e.g. m68k):
mlock2-tests.c: In function 'lock_check':
mlock2-tests.c:293: warning: integer constant is too large for 'long' type
mlock2-tests.c:294: warning: integer constant is too large for 'long' type
mlock2-tests.c:299: warning: integer constant is too large for 'long' type
Acked-by: Eric B Munson <emunson@akamai.com>
On glibc 2.3.6:
mlock2-tests.c: In function 'seek_to_smaps_entry':
mlock2-tests.c:158: warning: implicit declaration of function 'getline'
According to the manpage of getline(), it needs _GNU_SOURCE before glibc
2.10.
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
"Outside of the new ACPI-NFIT hot-add support this pull request is more
notable for what it does not contain, than what it does. There were a
handful of development topics this cycle, dax get_user_pages, dax
fsync, and raw block dax, that need more more iteration and will wait
for 4.5.
The patches to make devm and the pmem driver NUMA aware have been in
-next for several weeks. The hot-add support has not, but is
contained to the NFIT driver and is passing unit tests. The coredump
support is straightforward and was looked over by Jeff. All of it has
received a 0day build success notification across 107 configs.
Summary:
- Add support for the ACPI 6.0 NFIT hot add mechanism to process
updates of the NFIT at runtime.
- Teach the coredump implementation how to filter out DAX mappings.
- Introduce NUMA hints for allocations made by the pmem driver, and
as a side effect all devm allocations now hint their NUMA node by
default"
* tag 'libnvdimm-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
coredump: add DAX filtering for FDPIC ELF coredumps
coredump: add DAX filtering for ELF coredumps
acpi: nfit: Add support for hot-add
nfit: in acpi_nfit_init, break on a 0-length table
pmem, memremap: convert to numa aware allocations
devm_memremap_pages: use numa_mem_id
devm: make allocations numa aware by default
devm_memremap: convert to return ERR_PTR
devm_memunmap: use devres_release()
pmem: kill memremap_pmem()
x86, mm: quiet arch_add_memory()
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"Core:
- Fix rtctest error path
New drivers:
- Microcrystal RV8803
Subsystem wide cleanups:
- remove misuse of IRQF_NO_SUSPEND flag
Drivers:
- at91rm9200: clear RTC alarm status flag prior to suspending
- davinci: remove incorrect reference to probe function
- ds1307: Fix alarm programming for mcp794xx
- ds1390: trickle charger support, fix ds1390_get_reg
- isl1208: Pass the IRQF_ONESHOT flag
- opal: fix type of token
- pcf2127: fix RTC_READ_VL, remove useless driver version
- pcf85063: return an error when date is invalid
- pcf8563: add CLKOUT to common clock framework
- rx8025: remove unnecessary braces
- s3c: Set year, month, day value for setting alarm
- stmp3xxx: unify register access macros
- License fixes: pcf2127, da9063
- wakeup-source support for isl12057 and opal"
* tag 'rtc-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (23 commits)
rtc: Add a driver for Micro Crystal RV8803
rtc: s3c: Set year, month, day value for setting alarm
rtc: ds1307: Fix alarm programming for mcp794xx
rtc: isl12057: enable support for the standard "wakeup-source" property
rtc: opal: enable support for the stardard "wakeup-source" property
rtc: isl1208: Pass the IRQF_ONESHOT flag
rtc: pcf8563: add CLKOUT to common clock framework
rtc: davinci: remove incorrect reference to probe function
rtc: at91rm9200: clear RTC alarm status flag prior to suspending
rtc: pcf2127: remove useless driver version
rtc: pcf2127: fix reading uninitialized value on RTC_READ_VL ioctl
rtc: stmp3xxx: unify register access macros
rtc: da9063: GPL copyright inconsistency fix
rtc: pcf85063: return an error when date is invalid
rtc: rx8025: remove unnecessary braces
rtc: ds1343: remove misuse of IRQF_NO_SUSPEND flag
rtc: ab8500: remove misuse of IRQF_NO_SUSPEND flag
rtc: pl031: remove misuse of IRQF_NO_SUSPEND flag
rtc: opal: fix type of token
rtc: ds1390: Add trickle charger device tree binding
This runs the lib/test_printf module to make sure printf is operating
sanely.
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
- Kconfig: remove BE-only platforms from LE kernel build from Boqun
Feng
- Refresh ps3_defconfig from Geoff Levand
- Emit GNU & SysV hashes for the vdso from Michael Ellerman
- Define an enum for the bolted SLB indexes from Anshuman Khandual
- Use a local to avoid multiple calls to get_slb_shadow() from Michael
Ellerman
- Add gettimeofday() benchmark from Michael Neuling
- Avoid link stack corruption in __get_datapage() from Michael Neuling
- Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar
K.V
- Add ppc64le_defconfig from Michael Ellerman
- pseries: extract of_helpers module from Andy Shevchenko
- Correct string length in pseries_of_derive_parent() from Nathan
Fontenot
- Free the MSI bitmap if it was slab allocated from Denis Kirjanov
- Shorten irq_chip name for the SIU from Christophe Leroy
- Wait 1s for secondaries to enter OPAL during kexec from Samuel
Mendoza-Jonas
- Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V
- powerpc/pseries/hvcserver: don't memset pi_buff if it is null from
Colin Ian King
- Disable hugepd for 64K page size, from Aneesh Kumar K.V
- Differentiate between hugetlb and THP during page walk from Aneesh
Kumar K.V
- Make PCI non-optional for pseries from Michael Ellerman
- Individual System V IPC system calls from Sam bobroff
- Add selftest of unmuxed IPC calls from Michael Ellerman
- discard .exit.data at runtime from Stephen Rothwell
- Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul
Gortmaker
- Use of_get_next_parent to simplify code from Christophe Jaillet
- Paginate some xmon output from Sam bobroff
- Add some more elements to the xmon PACA dump from Michael Ellerman
- Allow the tm-syscall selftest to build with old headers from Michael
Ellerman
- Run EBB selftests only on POWER8 from Denis Kirjanov
- Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael
Ellerman
- Avoid reference to potentially freed memory in prom.c from Christophe
Jaillet
- Quieten boot wrapper output with run_cmd from Geoff Levand
- EEH fixes and cleanups from Gavin Shan
- Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan
- Use of_get_next_parent() in of_get_ibm_chip_id() from Michael
Ellerman
- Fix section mismatch warning in msi_bitmap_alloc() from Denis
Kirjanov
- Fix ps3-lpm white space from Rudhresh Kumar J
- Fix ps3-vuart null dereference from Colin King
- nvram: Add missing kfree in error path from Christophe Jaillet
- nvram: Fix function name in some errors messages, from Christophe
Jaillet
- drivers/macintosh: adb: fix misleading Kconfig help text from Aaro
Koskinen
- agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov
- cxl: Free virtual PHB when removing from Andrew Donnellan
- scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from
Michael Ellerman
- scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building
with O= from Michael Ellerman
- Freescale updates from Scott: Highlights include 64-bit book3e
kexec/kdump support, a rework of the qoriq clock driver, device tree
changes including qoriq fman nodes, support for a new 85xx board, and
some fixes.
- MPC5xxx updates from Anatolij: Highlights include a driver for
MPC512x LocalPlus Bus FIFO with its device tree binding
documentation, mpc512x device tree updates and some minor fixes.
* tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits)
powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc()
powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id()
powerpc/pseries: Correct string length in pseries_of_derive_parent()
powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry
powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s)
powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan
powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes
powerpc: handle error case in cpm_muram_alloc()
powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake
powerpc/book3e-64: Enable kexec
powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop
powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32
powerpc/book3e-64/kexec: Enable SMP release
powerpc/book3e-64/kexec: create an identity TLB mapping
powerpc/book3e-64: Don't limit paca to 256 MiB
powerpc/book3e/kdump: Enable crash_kexec_wait_realmode
powerpc/book3e: support CONFIG_RELOCATABLE
powerpc/booke64: Fix args to copy_and_flush
powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts
powerpc/e6500: kexec: Handle hardware threads
Test the mmap() flag, and the mlockall() flag. These tests ensure that
pages are not faulted in until they are accessed, that the pages are
unevictable once faulted in, and that VMA splitting and merging works with
the new VM flag. The second test ensures that mlock limits are respected.
Note that the limit test needs to be run a normal user.
Also add tests to use the new mlock2 family of system calls.
[treding@nvidia.com: : Fix mlock2-tests for 32-bit architectures]
[treding@nvidia.com: ensure the mlock2 syscall number can be found]
[treding@nvidia.com: use the right arguments for main()]
Signed-off-by: Eric B Munson <emunson@akamai.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Pull x86 fpu changes from Ingo Molnar:
"There are two main areas of changes:
- Rework of the extended FPU state code to robustify the kernel's
usage of cpuid provided xstate sizes - and related changes (Dave
Hansen)"
- math emulation enhancements: new modern FPU instructions support,
with testcases, plus cleanups (Denys Vlasnko)"
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
x86/fpu: Fixup uninitialized feature_name warning
x86/fpu/math-emu: Add support for FISTTP instructions
x86/fpu/math-emu, selftests: Add test for FISTTP instructions
x86/fpu/math-emu: Add support for FCMOVcc insns
x86/fpu/math-emu: Add support for F[U]COMI[P] insns
x86/fpu/math-emu: Remove define layer for undocumented opcodes
x86/fpu/math-emu, selftests: Add tests for FCMOV and FCOMI insns
x86/fpu/math-emu: Remove !NO_UNDOC_CODE
x86/fpu: Check CPU-provided sizes against struct declarations
x86/fpu: Check to ensure increasing-offset xstate offsets
x86/fpu: Correct and check XSAVE xstate size calculations
x86/fpu: Add C structures for AVX-512 state components
x86/fpu: Rework YMM definition
x86/fpu/mpx: Rework MPX 'xstate' types
x86/fpu: Add xfeature_enabled() helper instead of test_bit()
x86/fpu: Remove 'xfeature_nr'
x86/fpu: Rework XSTATE_* macros to remove magic '2'
x86/fpu: Rename XFEATURES_NR_MAX
x86/fpu: Rename XSAVE macros
x86/fpu: Remove partial LWP support definitions
Pull x86 asm changes from Ingo Molnar:
"The main change in this cycle is another step in the big x86 system
call interface rework by Andy Lutomirski, which moves most of the low
level x86 entry code from assembly to C, for all syscall entries
except native 64-bit system calls:
arch/x86/entry/entry_32.S | 182 ++++------
arch/x86/entry/entry_64_compat.S | 547 ++++++++-----------------------
194 insertions(+), 535 deletions(-)
... our hope is that the final remaining step (converting native
64-bit system calls) will be less painful as all the previous steps,
given that most of the legacies and quirks are concentrated around
native 32-bit and compat environments"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (47 commits)
x86/entry/32: Fix FS and GS restore in opportunistic SYSEXIT
x86/entry/32: Fix entry_INT80_32() to expect interrupts to be on
um/x86: Fix build after x86 syscall changes
x86/asm: Remove the xyz_cfi macros from dwarf2.h
selftests/x86: Style fixes for the 'unwind_vdso' test
x86/entry/64/compat: Document sysenter_fix_flags's reason for existence
x86/entry: Split and inline syscall_return_slowpath()
x86/entry: Split and inline prepare_exit_to_usermode()
x86/entry: Use pt_regs_to_thread_info() in syscall entry tracing
x86/entry: Hide two syscall entry assertions behind CONFIG_DEBUG_ENTRY
x86/entry: Micro-optimize compat fast syscall arg fetch
x86/entry: Force inlining of 32-bit syscall code
x86/entry: Make irqs_disabled checks in exit code depend on lockdep
x86/entry: Remove unnecessary IRQ twiddling in fast 32-bit syscalls
x86/asm: Remove thread_info.sysenter_return
x86/entry/32: Re-implement SYSENTER using the new C path
x86/entry/32: Switch INT80 to the new C syscall path
x86/entry/32: Open-code return tracking from fork and kthreads
x86/entry/compat: Implement opportunistic SYSRETL for compat syscalls
x86/vdso/compat: Wire up SYSENTER and SYSCSALL for compat userspace
Fixes: 9fae100cbd10 ("selftests: breakpoints: fix installing error on ...")
If we need to increase the number of huge pages, drop caches first
to reduce fragmentation and then check that we actually allocated
as many as we wanted. Retry once if that doesn't work.
Fixes: 87b2d44026e0 ("selftests: add memfd/sealing page-pinning tests")
Fixes: 2bf9e0ab08c6 ("locking/static_keys: Provide a selftest")
do_fork() is no longer defined on x86, so probe _do_fork() instead.
Fixes: 3033f14ab78c ("clone: support passing tls argument via C ...")
Instead of explicitly running the compiler, add dependencies and take
advantage of implicit rules to build only as necessary.
Several C programs fail to include the headers declaring all the
functions they call, resulting in warnings or errors.
After this, memfd_test.c is still missing some function declarations
but can't easily get them because of a conflict between
<linux/fcntl.h> and <sys/fcntl.h>.
Pull RCU changes from Ingo Molnar:
"The main changes in this cycle were:
- Improvements to expedited grace periods (Paul E McKenney)
- Performance improvements to and locktorture tests for percpu-rwsem
(Oleg Nesterov, Paul E McKenney)
- Torture-test changes (Paul E McKenney, Davidlohr Bueso)
- Documentation updates (Paul E McKenney)
- Miscellaneous fixes (Paul E McKenney, Boqun Feng, Oleg Nesterov,
Patrick Marlier)"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits)
fs/writeback, rcu: Don't use list_entry_rcu() for pointer offsetting in bdi_split_work_to_wbs()
rcu: Better hotplug handling for synchronize_sched_expedited()
rcu: Enable stall warnings for synchronize_rcu_expedited()
rcu: Add tasks to expedited stall-warning messages
rcu: Add online/offline info to expedited stall warning message
rcu: Consolidate expedited CPU selection
rcu: Prepare for consolidating expedited CPU selection
cpu: Remove try_get_online_cpus()
rcu: Stop excluding CPU hotplug in synchronize_sched_expedited()
rcu: Stop silencing lockdep false positive for expedited grace periods
rcu: Switch synchronize_sched_expedited() to IPI
locktorture: Fix module unwind when bad torture_type specified
torture: Forgive non-plural arguments
rcutorture: Fix unused-function warning for torturing_tasks()
rcutorture: Fix module unwind when bad torture_type specified
rcu_sync: Cleanup the CONFIG_PROVE_RCU checks
locking/percpu-rwsem: Clean up the lockdep annotations in percpu_down_read()
locking/percpu-rwsem: Fix the comments outdated by rcu_sync
locking/percpu-rwsem: Make use of the rcu_sync infrastructure
locking/percpu-rwsem: Make percpu_free_rwsem() after kzalloc() safe
Pull timer updates from Thomas Gleixner:
"The timer departement provides:
- More y2038 work in the area of ntp and pps.
- Optimization of posix cpu timers
- New time related selftests
- Some new clocksource drivers
- The usual pile of fixes, cleanups and improvements"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
timeconst: Update path in comment
timers/x86/hpet: Type adjustments
clocksource/drivers/armada-370-xp: Implement ARM delay timer
clocksource/drivers/tango_xtal: Add new timer for Tango SoCs
clocksource/drivers/imx: Allow timer irq affinity change
clocksource/drivers/exynos_mct: Use container_of() instead of this_cpu_ptr()
clocksource/drivers/h8300_*: Remove unneeded memset()s
clocksource/drivers/sh_cmt: Remove unneeded memset() in sh_cmt_setup()
clocksource/drivers/em_sti: Remove unneeded memset()s
clocksource/drivers/mediatek: Use GPT as sched clock source
clockevents/drivers/mtk: Fix spurious interrupt leading to crash
posix_cpu_timer: Reduce unnecessary sighand lock contention
posix_cpu_timer: Convert cputimer->running to bool
posix_cpu_timer: Check thread timers only when there are active thread timers
posix_cpu_timer: Optimize fastpath_timer_check()
timers, kselftest: Add 'adjtick' test to validate adjtimex() tick adjustments
timers: Use __fls in apply_slack()
clocksource: Remove return statement from void functions
net: sfc: avoid using timespec
ntp/pps: use y2038 safe types in pps_event_time
Calling ioctl(..., RTC_UIE_ON, ...) without CONFIG_RTC_INTF_DEV_UIE_EMUL
either ends in rtc_update_irq_enable if rtc->uie_unsupported is true
or in __rtc_set_alarm in the if (!rtc->ops->set_alarm) branch. In both
cases the return value is -EINVAL. So check for that one instead of
ENOTTY.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Certain syscall emulation layers strictly check that the number of
arguments match what the syscall handler expects. The KILL_one_arg_one and
KILL_one_arg_six tests passed more parameters than expected to various
syscalls, causing failures in this emulation mode. Instead, test using
syscalls that take the appropriate number of arguments.
Signed-off-by: Robert Sesek <rsesek@google.com>
Add a .notify callback to the acpi_nfit_driver that gets called on a
hotplug event. From this, evaluate the _FIT ACPI method which returns
the updated NFIT with handles for the hot-plugged NVDIMM.
Iterate over the new NFIT, and add any new tables found, and
register/enable the corresponding regions.
In the nfit test framework, after normal initialization, update the NFIT
with a new hot-plugged NVDIMM, and directly call into the driver to
update its view of the available regions.
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Elliott, Robert <elliott@hpe.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: <linux-acpi@vger.kernel.org>
Cc: <linux-nvdimm@lists.01.org>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
Mere possession of vm86 state is strange. Make sure that nothing
gets corrupted if we fork after calling vm86().
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/08f83295460a80e41dc5e3e81ec40d6844d316f5.1446270067.git.luto@kernel.org
EBB (Event Based Branches) are currently only available on POWER8, so we
should skip them on other CPUs.
I've found that at least one test loops forever on 970MP (cycles_with_freeze_test).
Signed-off-by: Denis Kirjanov <kda@linux-powerpc.org>
[mpe: Minor change log editing, add skip to cpu_event_vs_ebb_test]
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Miscellaneous fixes. (Paul E. McKenney, Boqun Feng, Oleg Nesterov, Patrick Marlier)
- Improvements to expedited grace periods. (Paul E. McKenney)
- Performance improvements to and locktorture tests for percpu-rwsem.
(Oleg Nesterov, Paul E. McKenney)
- Torture-test changes. (Paul E. McKenney, Davidlohr Bueso)
- Documentation updates. (Paul E. McKenney)
Changing arm64 syscalls is done via a specific register set, more like s390
than like arm (specific ptrace call) and x86 (part of general registers).
Since (restarting) poll doesn't exist on arm64, switch to using nanosleep
for testing restart_syscall. And since it looks like the syscall ABI is
inconsistent on arm-compat, so we must work around it (and document it) in
the test.
There is a mandate of 16-byte aligned stack on AArch64 [1], so the
STACK_SIZE here should also be 16-byte aligned, otherwise we would
get an error when calling clone().
[1] http://lxr.free-electrons.com/source/arch/arm64/kernel/process.c#L265
Signed-off-by: Chunyan Zhang <zhang.chunyan@linaro.org>
To test pstore in earnest, we have to cause kernel crash and check
pstore filesystem after reboot.
We add two scripts:
- pstore_crash_test
This script causes kernel crash and reboot. It is executed by
'make run_pstore_crash' in selftests. It can also be used with kdump.
- pstore_post_reboot_tests
This script includes test cases which check pstore's behavior after
crash and reboot. It is executed together with pstore_tests by
'make run_tests [-C pstore]' in selftests.
The test cases in pstore_post_reboot_tests are currently following.
- Check pstore backend is registered
- Mount pstore filesystem
- Check dmesg/console/pmsg files exist in pstore filesystem
- Check dmesg/console files contain oops end marker
- Check pmsg file properly keeps the content written before crash
- Remove all files in pstore filesystem
Example usage is following.
(before reboot)
# cd /path/to/selftests
# make run_tests -C pstore
=== Pstore unit tests (pstore_tests) ===
UUID=b49b02cf-b0c2-4309-be43-b08c3971e37f
selftests: pstore_tests [PASS]
=== Pstore unit tests (pstore_post_reboot_tests) ===
UUID=953eb1bc-8e03-48d7-b27a-6552b24c5b7e
Checking pstore backend is registered ... ok
backend=ramoops
cmdline=console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait mem=768M ramoops.mem_address=0x30000000 ramoops.mem_size=0x10000
pstore_crash_test has not been executed yet. we skip further tests.
selftests: pstore_post_reboot_tests [PASS]
# make run_pstore_crash
=== Pstore unit tests (pstore_crash_test) ===
UUID=93c8972d-1466-430b-8c4a-28d8681e74c6
backend=ramoops
Causing kernel crash ...
(kernel crash and reboot)
(after reboot)
UUID=8e511e77-2285-499f-8bc0-900d9af1fbcc
UUID=2dcc2132-4f3c-45aa-a38f-3b54bff8cef1
backend=ramoops
Mounting pstore filesystem ... ok
Checking dmesg files exist in pstore filesystem ... ok
dmesg-ramoops-0
dmesg-ramoops-1
Checking console files exist in pstore filesystem ... ok
console-ramoops-0
Checking pmsg files exist in pstore filesystem ... ok
pmsg-ramoops-0
Checking dmesg files contain oops end marker
dmesg-ramoops-0 ... ok
dmesg-ramoops-1 ... ok
Checking console file contains oops end marker ... ok
Checking pmsg file properly keeps the content written before crash ... ok
Removing all files in pstore filesystem
console-ramoops-0 ... ok
pmsg-ramoops-0 ... ok
Signed-off-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Mark Salyzyn <salyzyn@android.com>
Cc: Seiji Aguchi <seiji.aguchi.tr@hitachi.com>
Cc: linux-api@vger.kernel.org
The pstore_tests script includes test cases which check pstore's
behavior before crash (and reboot).
The test cases are currently following.
- Check pstore console is registered
- Check /dev/pmsg0 exists
- Write unique string to /dev/pmsg0
The unique string written to /dev/pmsg includes UUID. The UUID is also
left in 'uuid' file in order to enable us to check if the pmsg keeps the
string correctly after reboot.
# make run_tests -C pstore (or just .pstore/pstore_tests)
make: Entering directory '/path/to/selftests/pstore'
backend=ramoops
Checking pstore console is registered ... ok
Checking /dev/pmsg0 exists ... ok
Writing unique string to /dev/pmsg0 ... ok
make: Leaving directory '/path/to/selftests/pstore'
We can also see test logs later.
# cat pstore/logs/20151001-072718_b49b02cf-b0c2-4309-be43-b08c3971e37f/pstore_tests.log
Thu Oct 1 07:27:18 UTC 2015
backend=ramoops
Signed-off-by: Yuan Sun <sunyuan3@huawei.com>
When building against older kernel headers, currently the tm-syscall
test fails to build because PPC_FEATURE2_HTM_NOSC is not defined.
Tweak the test so that if PPC_FEATURE2_HTM_NOSC is not defined it still
builds, but prints a warning at run time and marks the test as skipped.
This list has gotten too long. Split it into individual lines and sort
them, so in future we can add new entries more cleanly.
This is just a simple test which confirms that the individual IPC
syscalls are all available.
Checkpatch is really quite bad for user code like this, but it
caught two legit style issues.
Reported-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/3335040bdd40d2bca4b1a28a3f8b165361c801b7.1444696194.git.luto@kernel.org
Commit 7a5692e6e533 ("arch/powerpc: provide zero_bytemask() for
big-endian") added a call to __fls() in our word-at-a-time.h. That was
fine for the kernel build but missed the fact that we also use
word-at-a-time.h in a userspace test.
Pulling in the kernel version of __fls() gets messy, so just define our
own, it's unlikely to change often.
Fixes: 7a5692e6e533 ("arch/powerpc: provide zero_bytemask() for big-endian")
Recently a kernel side NTP bug was fixed via the following commit:
2619d7e9c92d ("time: Fix timekeeping_freqadjust()'s incorrect use of abs() instead of abs64()")
When the bug was reported it was difficult to detect, except by
tweaking the adjtimex tick value, and noticing how quickly the
adjustment took:
https://lkml.org/lkml/2015/9/1/488
Thus this patch introduces a new test which manipulates the
adjtimex tick value and validates that the results are what we
expect.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Nuno Gonçalves <nunojpg@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1444094217-20258-1-git-send-email-john.stultz@linaro.org
[ Tidied up the code and the changelog a bit. ]
'torture.2015.10.06a' into HEAD
doc.2015.10.06a: Documentation updates.
percpu-rwsem.2015.10.06a: Optimization of per-CPU reader-writer semaphores.
torture.2015.10.06a: Torture-test updates.
This tests assumptions about how fast syscall works wrt pt_regs
and, in particular, what happens if IP is decremented by 2
during a syscall.
Link: http://lkml.kernel.org/r/1c44dbfe59000ba135bbf35ccc5d2433a0b31618.1444091584.git.luto@kernel.org
While the kernel itself doesn't use DWARF unwinding, user code
expects to be able to unwind the vDSO. The vsyscall
(AT_SYSINFO) entry is manually CFI-annotated, and this tests
that it unwinds correctly.
I tested the test by incorrectly annotating __kernel_vsyscall,
and the test indeed fails if I do that.
Link: http://lkml.kernel.org/r/8bf736d1925cdd165c0f980156a4248e55af47a1.1444091584.git.luto@kernel.org
