[ Upstream commit a2b22dddc7bb6110ac3b5ed1a60aa9279836fadb ]
The tools/usb/ffs-test.c file defines cpu_to_le16/32 by using the C
library htole16/32 function calls. However, cpu_to_le16/32 are used when
initializing structures, i.e in a context where a function call is not
allowed.
It works fine on little endian systems because htole16/32 are defined by
the C library as no-ops. But on big-endian systems, they are actually
doing something, which might involve calling a function, causing build
failures, such as:
ffs-test.c:48:25: error: initializer element is not constant
#define cpu_to_le32(x) htole32(x)
ffs-test.c:128:12: note: in expansion of macro ‘cpu_to_le32’
.magic = cpu_to_le32(FUNCTIONFS_DESCRIPTORS_MAGIC_V2),
To solve this, we code cpu_to_le16/32 in a way that allows them to be
used when initializing structures. This fix was imported from
meta-openembedded/android-tools/fix-big-endian-build.patch written by
Thomas Petazzoni <thomas.petazzoni@free-electrons.com>.
CC: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit d179f99a651685b19333360e6558110da2fe9bd7 ]
detach_port() fails to call usbip_vhci_driver_close() from its error
path after usbip_vhci_detach_device() returns failure, leaking memory
allocated in usbip_vhci_driver_open() and holding udev_context and udev
references. Fix it to call usbip_vhci_driver_close().
Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
[ Upstream commit 77be4c878c72e411ad22af96b6f81dd45c26450a ]
Indeed musl doesn't define old SIGCLD signal name but only new one SIGCHLD.
SIGCHLD is the new POSIX name for that signal so it doesn't change
anything on other libcs.
This fixes this kind of build error:
usbipd.c: In function ‘set_signal’:
usbipd.c:459:12: error: 'SIGCLD' undeclared (first use in this function)
sigaction(SIGCLD, &act, NULL);
usbipd.c:459:12: note: each undeclared identifier is reported only once
for each function it appears in
Makefile:407: recipe for target 'usbipd.o' failed
make[3]: *** [usbipd.o] Error 1
Signed-off-by: Julien BOIBESSOT <julien.boibessot@armadeus.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
commit ef824501f50846589f02173d73ce3fe6021a9d2a upstream.
usbip host lists devices attached to vhci_hcd on the same server
when user does attach over localhost or specifies the server as the
remote.
usbip attach -r localhost -b busid
or
usbip attach -r servername (or server IP)
Fix it to check and not list devices that are attached to vhci_hcd.
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit ef54cf0c600fb8f5737fb001a9e357edda1a1de8 upstream.
usbip host binds to devices attached to vhci_hcd on the same server
remote.
or
Unbind followed by bind works, however device is left in a bad state with
accesses via the attached busid result in errors and system hangs during
shutdown.
Fix it to check and bail out if the device is already attached to vhci_hcd.
commit e5dfa3f902b9a642ae8c6997d57d7c41e384a90b upstream.
The usbip userspace tools call sprintf()/snprintf() and don't check for
the return value which can lead the paths to overflow, truncating the
final file in the path.
More urgently, GCC 7 now warns that these aren't checked with
-Wformat-overflow, and with -Werror enabled in configure.ac, that makes
these tools unbuildable.
This patch fixes these problems by replacing sprintf() with snprintf() in
one place and adding checks for the return value of snprintf().
Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Jonathan Dieter <jdieter@lesbg.com>
commit cfd6ed4537a9e938fa76facecd4b9cd65b6d1563 upstream.
GCC 7 now warns when switch statements fall through implicitly, and with
-Werror enabled in configure.ac, that makes these tools unbuildable.
We fix this by notifying the compiler that this particular case statement
is meant to fall through.
commit 2f2d0088eb93db5c649d2a5e34a3800a8a935fc5 upstream.
When a client has a USB device attached over IP, the vhci_hcd driver is
locally leaking a socket pointer address via the
/sys/devices/platform/vhci_hcd/status file (world-readable) and in debug
output when "usbip --debug port" is run.
Fix it to not leak. The socket pointer address is not used at the moment
and it was made visible as a convenient way to find IP address from socket
pointer address by looking up /proc/net/{tcp,tcp6}.
As this opens a security hole, the fix replaces socket pointer address with
sockfd.
Reported-by: Secunia Research <vuln@secunia.com>
commit 544c4605acc5ae4afe7dd5914147947db182f2fb upstream.
usbip bind writes commands followed by random string when writing to
match_busid attribute in sysfs, caused by using full variable size
instead of string length.
Signed-off-by: Juan Zea <juan.zea@qindel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v4.4 merge window
This pull request is large with a total of 136 non-merge
commits. Because of its size, we will only describe the big things in
broad terms.
Many will be happy to know that dwc3 is now almost twice as fast after
some profiling and speed improvements. Also in dwc3, John Youn from
Synopsys added support for their new DWC USB3.1 IP Core and the HAPS
platform which can be used to validate it.
A series of patches from Robert Baldyga cleaned up uses of
ep->driver_data as a flag for "claimed endpoint" in favor of the new
ep->claimed flag.
Sudip Mukherjee fixed a ton of really old problems on the amd5536udc
driver. That should make a few people happy.
Heikki Krogerus worked on converting dwc3 to the unified device property
interface.
Together with these, there's a ton of non-critical fixes, typos and
stuff like that.
Signed-off-by: Felipe Balbi <balbi@ti.com>
For ctrl out test, it needs length > vary, so in order to run it with
default parameters, we do this change.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
The 'length' is the transfer length, not the packet size, so
change the help text.
Instead of calling strlen on every iteration of the for loop, just call it
once and cache the result in a temporary local variable which will be used
in the for loop instead.
Signed-off-by: Eric Curtin <ericcurtin17@gmail.com>
This makes examples more platform independent and more compatible with
USB standard, as endpoint addresses in given interface may differ
between hardware platforms or even between configurations in single
USB device.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
It's needed, to have more than 64 bytes of maxpacketsize.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big set of USB and PHY patches for 3.19-rc1.
The normal churn in the USB gadget area is in here, as well as xhci
and other individual USB driver updates. The PHY tree is also in
here, as there were dependancies on the USB tree.
All of these have been in linux-next"
* tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits)
arm: omap3: twl: remove usb phy init data
usbip: fix error handling in stub_probe()
usb: gadget: udc: missing curly braces
USB: mos7720: delete some unneeded code
wusb: replace memset by memzero_explicit
usbip: remove unneeded structure
usb: xhci: fix comment for PORT_DEV_REMOVE
xhci: don't use the same variable for stopped and halted rings current TD
xhci: clear extra bits from slot context when setting max exit latency
xhci: cleanup finish_td function
USB: adutux: NULL dereferences on disconnect
usb: chipidea: fix platform_no_drv_owner.cocci warnings
usb: chipidea: Fixed a few typos in comments
Documentation: bindings: add doc for the USB2 ChipIdea USB driver
usb: chipidea: add a usb2 driver for ci13xxx
usb: chipidea: fix phy handling
usb: chipidea: remove duplicate dev_set_drvdata for host_start
usb: chipidea: parameter 'mode' isn't needed for hw_device_reset
usb: chipidea: add controller reset API
usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER
Delete a local structure that is only used to be initialized by memset.
A semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
identifier x,i;
... when any
-struct i x;
<+... when != x
- memset(&x,...);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Valentina Manea <valentina.manea.m@gmail.com>
This patch fix spelling typo in printk and Kconfig within
various part of kernel sources.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
There's no such thing as "list_struct".
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Linux 3.17-rc5
Documentation/devicetree/bindings/usb/mxs-phy.txt
drivers/usb/phy/phy-mxs-usb.c
Merge Linux 3.17-rc4 here so we have all the latest
fixes on next too. This also cleans up a few conflicts
when applying patches.
drivers/usb/gadget/Makefile
drivers/usb/gadget/function/Makefile
drivers/usb/gadget/legacy/Makefile
drivers/usb/phy/phy-samsung-usb.h
Fixes: 588b48caf65c ("usbip: move usbip userspace code out of staging")
which introduced build failure by not changing uapi/usbip.h include path
according to new location.
Signed-off-by: Piotr Król <piotr.krol@3mdeb.com>
If ffs-test is used with a kernel prior to 3.14, which do not
support the new descriptors format, it will fail when trying to
write the descriptors. Add a function that converts the new
descriptors to the legacy ones and use it to retry writing the
descriptors using the legacy format.
Also add “-l” flag to ffs-test which will cause the tool to
never try the new format and instead immediatelly try the
legacy one. This should be useful to test whether parsing
of the old format still works on given 3.14+ kernel.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Since commit [ac8dde11: “Add flags to descriptors block”] functionfs
supports a new, more powerful and extensible, descriptor format.
Since ffs-test is probably the first thing users of the functionfs
interface see when they start writing functionfs user space daemons,
convert it to use the new format thus promoting it.
At this point, USB/IP userspace code is fully functional
and can be moved out of staging.
Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com>
Felipe writes:
usb: patches for v3.17 merge window
Surprisingly enough, while a big set of patches, the majority is
composed of cleanups (using devm_*, fixing sparse errors, moving
code around, adding const, etc).
The highlights are addition of new support for PLX USB338x devices,
and support for USB 2.0-only configurations of the DWC3 IP core.
Signed-of-by: Felipe Balbi <balbi@ti.com>
It appears that no one ever run ffs-test on a big-endian machine,
since it used cpu-endianess for fs_count and hs_count fields which
should be in little-endian format. Fix by wrapping the numbers in
cpu_to_le32.
Cc: stable@vger.kernel.org
Add missing information about license. Some people will probably want to
reuse this code in their projects released under variety of licenses. For this
reason this example is under Public Domain license to avoid GPL limitations.
supports a new descriptor format, so we update example application
to make it using recomended version of descriptors.
We wrap numeric values of fs_count and hs_count fields in htole32,
because they should be in little-endian format.
error"
This reverts commit f2af74123f8c5a735248547f4286a3adc28633c1.
There is a better fix for this build error coming in a following
patch.
Commit [ac8dde11: “usb: gadget: f_fs: Add flags to descriptors block”]
which introduced a new descriptor format for FunctionFS removed the
usb_functionfs_descs_head structure, which is still used by ffs-test.
tool.
Convert ffs-test by converting it to use the new header format. For
testing kernels prior to 3.14 (when the new format was introduced) and
parsing of the legacy headers in the new kernels, provide a compilation
flag to make the tool use the old format.
Finally, include information as to when the legacy FunctionFS headers
format has been deprecated (which is also when the new one has been
introduced).
Reported-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
This patch adds two example applications showing usage of Asynchronous I/O API
of FunctionFS. First one (aio_simple) is simple example of bidirectional data
transfer. Second one (aio_multibuff) shows multi-buffer data transfer, which
may to be used in high performance applications.
Both examples contains userspace applications for device and for host.
It needs libaio library on the device, and libusb library on host.
Reproduce:
ray@hr-bak:~/usb$ make -C tools/usb/
make: Entering directory `/home/ray/usb/tools/usb'
gcc -Wall -Wextra -g -lpthread -I../include -o testusb testusb.c
/tmp/cc0EMxfy.o: In function `main':
/home/ray/usb/tools/usb/testusb.c:508: undefined reference to `pthread_create'
/home/ray/usb/tools/usb/testusb.c:531: undefined reference to `pthread_join'
collect2: error: ld returned 1 exit status
make: *** [testusb] Error 1
make: Leaving directory `/home/ray/usb/tools/usb'
Comments:
In the latest version (4.7.3) of gcc compiler, it requres that
libraries must follow the object or source files like below:
"gcc hello.c -lpthread" instead of "gcc -lpthread hello.c"
And it isn't encountered at gcc version 4.7.2.
So this patch fix to move the pthread option after testusb.c.
Signed-off-by: Huang Rui <ray.huang@amd.com>
Fixes this build failure:
gcc -Wall -Wextra -g -lpthread -I../include -o ffs-test ffs-test.c
In file included from ffs-test.c:41:0:
../../include/linux/usb/functionfs.h:4:39: fatal error:
uapi/linux/usb/functionfs.h: No such file or directory
compilation terminated.
make: *** [ffs-test] Error 1
Signed-off-by: Maxin B. John <maxin.john@enea.com>
Cc: stable <stable@vger.kernel.org> # 3.7+
Commit 8a424bf40d772fedacc91862ecc86f10541fabb3 (tools/usb: remove last USBFS
user) removed 'usbfs' files from the source but retained mentions of 'usbfs'
all over the place, most importantly in the misleading error messages printed
in case USB device files are not there. Remove all the mentions of 'usbfs'
for good now!
Signed-off-by: Sergei Shtylyov <sshtylyov@dev.rtsoft.ru>
Basically remove unneeded code. Since that 'continue' is at the end
of the for() there's no need for it.
Acked-by: Felipe Balbi <balbi@ti.com>
In commit fb28d58b ("USB: remove CONFIG_USB_DEVICEFS") USBFS got
removed. Since it is gone we can stop using it in testusb and try udev
nodes right away.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The testusb.c tool has support for looping forever implemented, which
may be useful for stress test, yet it is not exposed to the user, so
even though the code is there, it cannot be used. This commit adds
"l" to the set of options handled by the application which enables
the feature.
Also, I collate help information for each command line option to make
it easier to use for novice.
Signed-off-by: Du Changbin <changbinx.du@intel.com>
As real device-nodes managed by udev whose nodes lived in /dev/bus/usb
are mostly used today, let testusb tool use that directory as one default
path make tool be more convenient to use.
The out functions should only handle actual available data instead of the complete buffer.
Otherwise for example the ep0_consume function will report ghost events since it tries to decode
the complete buffer - which may contain partly invalid data.
Signed-off-by: Matthias Fend <matthias.fend@wolfvision.net>
Pull x86/build changes from Ingo Molnar.
* 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, build: Fix portability issues when cross-building
x86, tools: Remove unneeded header files from tools/build.c
USB: ffs-test: Don't duplicate {get,put}_unaligned*() functions
x86, efi: Fix endian issues and unaligned accesses
x86, boot: Restrict CFLAGS for hostprogs
x86, mkpiggy: Don't open code put_unaligned_le32()
x86, relocs: Don't open code put_unaligned_le32()
tools/include: Add byteshift headers for endian access
Use the header file in tools/include instead of duplicating the endian
functions.
Cc: Davidlohr Bueso <dave@gnu.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1330436245-24875-7-git-send-email-matt@console-pimps.org
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
The m.nazarewicz@samsung.com email address is no longer valid,
so this commit replaces it with mina86@mina86.com which is
employer-agnostic and thus should be valid for foreseeable
feature.
When compiling this program the functionfs.h header cannot be found, producing:
ffs-test.c:40: fatal error: linux/usb/functionfs.h: No such file or directory
This patch also fixes the following warning:
ffs-test.c:453: warning: format ‘%4d’ expects type ‘int’, but argument 3 has type ‘size_t’
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Build USB tools easier.
Enhance the test script to call the new tests added to usbtest
in order to detect host controllers that don't accept byte
aligned DMA.
The unaligned tests are called after their aligned
equivalents but for fewer iterations (since alignment
failure is generally immediate).
Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com>
This patch just adds the script available at
http://www.linux-usb.org/usbtest/test.sh as is.
The FunctionFS gadget may provide the source/sink interface
not as the first interface (with id == 0) but some different
interface hence a code to find the interface number is
required.
(Note that you will still configure the gadget to report
idProduct == 0xa4a4 (an "echo 0xa4a4
>/sys/module/g_ffs/parameters/usb_product" should suffice) or
configure host to handle 0x0525:0xa4ac devices using the
usbtest driver.)
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
The testusb program just issues ioctls to perform the tests
implemented by the kernel driver. It can generate a variety
of transfer patterns; you should make sure to test both regular
streaming and mixes of transfer sizes (including short transfers).
For more information on how this can be used and on USB testing
refer to <URL:http://www.linux-usb.org/usbtest/>.
