path: root/tools/vm
2016-07-26tools/vm/page_owner: increase temporary buffer sizeJoonsoo Kim
Page owner will be changed to store more deep stacktrace so current temporary buffer size isn't enough. Increase it. Link: http://lkml.kernel.org/r/1464230275-25791-5-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-23tools/vm/slabinfo: fix an unintentional printfDan Carpenter
The curly braces are missing here so we print stuff unintentionally. Fixes: 9da4714a2d44 ('slub: slabinfo update for cmpxchg handling') Link: http://lkml.kernel.org/r/20160715211243.GE19522@mwanda Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Laura Abbott <labbott@fedoraproject.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-24tools/vm/slabinfo: fix spelling mistake: "Ocurrences" -> "Occurrences"Colin Ian King
trivial fix to spelling mistake Link: http://lkml.kernel.org/r/1466672144-831-1-git-send-email-colin.king@canonical.com Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17tools/vm/page-types.c: avoid memset() in walk_pfn() when count == 1Naoya Horiguchi
I found that page-types is very slow and my testing shows many timeout errors. Here's an example with a simple program allocating 1000 thps. $ time ./page-types -p $(pgrep -f test_alloc) ... real 0m17.201s user 0m16.889s sys 0m0.312s Most of time is spent in memset(). Currently memset() clears over whole buffer for every walk_pfn() call, which is inefficient when walk_pfn() is called from walk_vma(), because in that case walk_pfn() is called for each pfn. So this patch limits the zero initialization only for the first element. $ time ./page-types.patched -p $(pgrep -f test_alloc) ... real 0m0.182s user 0m0.046s sys 0m0.135s Fixes: 954e95584579 ("tools/vm/page-types.c: add memory cgroup dumping and filtering") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Suggested-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17tools/vm/page-types.c: add memory cgroup dumping and filteringKonstantin Khlebnikov
This adds two command line keys: -c|--cgroup path|@inode Walk only pages owned by this memory cgroup -C|--list-cgroup Show memory cgroup inodes [vdavydov@virtuozzo.com: opt_cgroup should be uint64_t. Fix conflicts with "tools/vm/page-types.c: support swap entry"] Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17tools/vm/page-types.c: support swap entryNaoya Horiguchi
/proc/pid/pagemap (pte_to_pagemap_entry() internally) already reports about swap entry, so let's make the in-kernel utility aware of it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: convert SLAB_DEBUG_FREE to SLAB_CONSISTENCY_CHECKSLaura Abbott
SLAB_DEBUG_FREE allows expensive consistency checks at free to be turned on or off. Expand its use to be able to turn off all consistency checks. This gives a nice speed up if you only want features such as poisoning or tracing. Credit to Mathias Krause for the original work which inspired this series Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mathias Krause <minipli@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-20tools/vm/page-types.c: support KPF_IDLENaoya Horiguchi
PageIdle is exported in include/uapi/linux/kernel-page-flags.h, so let's make page-types.c tool handle it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: gnuplot slabifo extended statSergey Senozhatsky
GNUplot `slabinfo -X' stats, collected, for example, using the following command: while [ 1 ]; do slabinfo -X >> stats; sleep 1; done `slabinfo-gnuplot.sh stats' pre-processes collected records and generate graphs (totals, slabs sorted by size, slabs sorted by size). Graphs can be [individually] regenerate with different samples range and graph width-heigh (-r %d,%d and -s %d,%d options). To visually compare N `totals' graphs: slabinfo-gnuplot.sh -t FILE1-totals FILE2-totals ... FILEN-totals Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: cosmetic globals cleanupSergey Senozhatsky
checkpatch.pl complains about globals being explicitly zeroed out: "ERROR: do not initialise globals to 0 or NULL". New globals, introduced in this patch set, have no explicit 0 initialization; clean up the old ones to make it less hairy. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: output sizes in bytesSergey Senozhatsky
Introduce "-B|--Bytes" opt to disable store_size() dynamic size scaling and report size in bytes instead. This `expands' the interface a bit, it's impossible to use printf("%6s") anymore to output sizes. Example: slabinfo -X -N 2 Slabcache Totals ---------------- Slabcaches : 91 Aliases : 119->69 Active: 63 Memory used: 199798784 # Loss : 10689376 MRatio: 5% # Objects : 324301 # PartObj: 18151 ORatio: 5% Per Cache Average Min Max Total ---------------------------------------------------------------------------- #Objects 5147 1 89068 324301 #Slabs 199 1 3886 12537 #PartSlab 12 0 240 778 %PartSlab 32% 0% 100% 6% PartObjs 5 0 4569 18151 % PartObj 26% 0% 100% 5% Memory 3171409 8192 127336448 199798784 Used 3001736 160 121429728 189109408 Loss 169672 0 5906720 10689376 Per Object Average Min Max ----------------------------------------------------------- Memory 585 8 8192 User 583 8 8192 Loss 2 0 64 Slabs sorted by size -------------------- Name Objects Objsize Space Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 69948 1736 127336448 3871/0/15 18 3 0 95 a dentry 89068 288 26058752 3164/0/17 28 1 0 98 a Slabs sorted by loss -------------------- Name Objects Objsize Loss Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 69948 1736 5906720 3871/0/15 18 3 0 95 a inode_cache 11628 864 537472 642/0/4 18 2 0 94 a Besides, store_size() does not use powers of two for G/M/K if (value > 1000000000UL) { divisor = 100000000UL; trailer = 'G'; } else if (value > 1000000UL) { divisor = 100000UL; trailer = 'M'; } else if (value > 1000UL) { divisor = 100; trailer = 'K'; } Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: introduce extended totals modeSergey Senozhatsky
Add "-X|--Xtotals" opt to output extended totals summary, which includes: -- totals summary -- slabs sorted by size -- slabs sorted by loss (waste) Example: ======= slabinfo --X -N 1 Slabcache Totals ---------------- Slabcaches : 91 Aliases : 120->69 Active: 65 Memory used: 568.3M # Loss : 30.4M MRatio: 5% # Objects : 920.1K # PartObj: 161.2K ORatio: 17% Per Cache Average Min Max Total --------------------------------------------------------- #Objects 14.1K 1 227.8K 920.1K #Slabs 533 1 11.7K 34.7K #PartSlab 86 0 4.3K 5.6K %PartSlab 24% 0% 100% 16% PartObjs 17 0 129.3K 161.2K % PartObj 17% 0% 100% 17% Memory 8.7M 8.1K 384.7M 568.3M Used 8.2M 160 366.5M 537.9M Loss 468.8K 0 18.2M 30.4M Per Object Average Min Max --------------------------------------------- Memory 587 8 8.1K User 584 8 8.1K Loss 2 0 64 Slabs sorted by size ---------------------- Name Objects Objsize Space Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 211142 1736 384.7M 11732/40/10 18 3 0 95 a Slabs sorted by loss ---------------------- Name Objects Objsize Loss Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 211142 1736 18.2M 11732/40/10 18 3 0 95 a Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: fix alternate opts namesSergey Senozhatsky
Fix mismatches between usage() output and real opts[] options. Add missing alternative opt names, e.g., '-S' had no '--Size' opts[] entry, etc. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: sort slabs by lossSergey Senozhatsky
Introduce opt "-L|--sort-loss" to sort and output slabs by loss (waste) in slabcache(). Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: limit the number of reported slabsSergey Senozhatsky
Introduce opt "-N|--lines=K" to limit the number of slabs being reported in output_slabs(). Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tools/vm/slabinfo: use getopt no_argument/optional_argumentSergey Senozhatsky
This patchset adds 'extended' slabinfo mode that provides additional information: -- totals summary -- slabs sorted by size -- slabs sorted by loss (waste) The patches also introduces several new slabinfo options to limit the number of slabs reported, sort slabs by loss (waste); and some fixes. Extended output example (slabinfo -X -N 2): Slabcache Totals ---------------- Slabcaches : 91 Aliases : 119->69 Active: 63 Memory used: 199798784 # Loss : 10689376 MRatio: 5% # Objects : 324301 # PartObj: 18151 ORatio: 5% Per Cache Average Min Max Total ---------------------------------------------------------------------------- #Objects 5147 1 89068 324301 #Slabs 199 1 3886 12537 #PartSlab 12 0 240 778 %PartSlab 32% 0% 100% 6% PartObjs 5 0 4569 18151 % PartObj 26% 0% 100% 5% Memory 3171409 8192 127336448 199798784 Used 3001736 160 121429728 189109408 Loss 169672 0 5906720 10689376 Per Object Average Min Max ----------------------------------------------------------- Memory 585 8 8192 User 583 8 8192 Loss 2 0 64 Slabs sorted by size -------------------- Name Objects Objsize Space Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 69948 1736 127336448 3871/0/15 18 3 0 95 a dentry 89068 288 26058752 3164/0/17 28 1 0 98 a Slabs sorted by loss -------------------- Name Objects Objsize Loss Slabs/Part/Cpu O/S O %Fr %Ef Flg ext4_inode_cache 69948 1736 5906720 3871/0/15 18 3 0 95 a inode_cache 11628 864 537472 642/0/4 18 2 0 94 a The last patch in the series addresses Linus' comment from http://marc.info/?l=linux-mm&m=144148518703321&w=2 (well, it's been some time. sorry.) gnuplot script takes the slabinfo records file, where every record is a `slabinfo -X' output. So the basic workflow is, for example, as follows: while [ 1 ]; do slabinfo -X -N 2 >> stats; sleep 1; done ^C slabinfo-gnuplot.sh stats The last command will produce 3 png files (and 3 stats files) -- graph of slabinfo totals -- graph of slabs by size -- graph of slabs by loss It's also possible to select a range of records for plotting (a range of collected slabinfo outputs) via `-r 10,100` (for example); and compare totals from several measurements (to visially compare slabs behaviour (10,50 range)) using pre-parsed totals files: slabinfo-gnuplot.sh -r 10,50 -t stats-totals1 .. stats-totals2 This also, technically, supports ktest. Upload new slabinfo to target, collect the stats and give the resulting stats file to slabinfo-gnuplot This patch (of 8): Use getopt constants in `struct option' ->has_arg instead of numerical representations. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22tools vm: Fix build due to removal of tools/lib/api/fs/debugfs.hArnaldo Carvalho de Melo
There were some changes in how this debugfs mounting helper is implemented/exported and we forgot to check if there were other users besides perf, fix it. Need to do a make -C tools/ everytime we do changes to tools/{lib,include} and other places where we're moving things from tools/perf/ to be used by other tools/ living code. Fixed: $ make -C tools/vm make: Entering directory '/home/git/linux/tools/vm' make -C ../lib/api make[1]: Entering directory '/home/git/linux/tools/lib/api' CC fd/array.o LD fd/libapi-in.o CC fs/fs.o CC fs/tracing_path.o LD fs/libapi-in.o CC cpu.o LD libapi-in.o AR libapi.a make[1]: Leaving directory '/home/git/linux/tools/lib/api' gcc -Wall -Wextra -I../lib/ -o page-types page-types.c ../lib/api/libapi.a make: Leaving directory '/home/git/linux/tools/vm' $ Reported-by: Vinson Lee <vlee@twopensource.com> Tested-by: Vinson Lee <vlee@twopensource.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Raphael Beamonte <raphael.beamonte@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Ahern <dsahern@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Namhyung Kim <namhyung@kernel.org> Fixes: 60a1133a5b39 ("tools lib api fs: Remove debugfs, tracefs and findfs objects") Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-08pagemap: add mmap-exclusive bit for marking pages mapped only hereKonstantin Khlebnikov
This patch sets bit 56 in pagemap if this page is mapped only once. It allows to detect exclusively used pages without exposing PFN: present file exclusive state 0 0 0 non-present 1 1 0 file page mapped somewhere else 1 1 1 file page mapped only here 1 0 0 anon non-CoWed page (shared with parent/child) 1 0 1 anon CoWed page (or never forked) CoWed pages in (MAP_FILE | MAP_PRIVATE) areas are anon in this context. MMap-exclusive bit doesn't reflect potential page-sharing via swapcache: page could be mapped once but has several swap-ptes which point to it. Application could detect that by swap bit in pagemap entry and touch that pte via /proc/pid/mem to get real information. See http://lkml.kernel.org/r/CAEVpBa+_RyACkhODZrRvQLs80iy0sqpdrd0AaP_-tgnX3Y9yNQ@mail.gmail.com Requested by Mark Williamson. [akpm@linux-foundation.org: fix spello] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Mark Williamson <mwilliamson@undo-software.com> Tested-by: Mark Williamson <mwilliamson@undo-software.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08pagemap: switch to the new format and do some cleanupKonstantin Khlebnikov
This patch removes page-shift bits (scheduled to remove since 3.11) and completes migration to the new bit layout. Also it cleans messy macro. Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mark Williamson <mwilliamson@undo-software.com> Tested-by: Mark Williamson <mwilliamson@undo-software.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-14tools/vm: fix page-flags buildAndi Kleen
libabikfs.a doesn't exist anymore, so we now need to link with libapi.a. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm:add KPF_ZERO_PAGE flag for /proc/kpageflagsWang, Yalin
Add KPF_ZERO_PAGE flag for zero_page, so that userspace processes can detect zero_page in /proc/kpageflags, and then do memory analysis more accurately. Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13mm/page_owner: keep track of page ownersJoonsoo Kim
This is the page owner tracking code which is introduced so far ago. It is resident on Andrew's tree, though, nobody tried to upstream so it remain as is. Our company uses this feature actively to debug memory leak or to find a memory hogger so I decide to upstream this feature. This functionality help us to know who allocates the page. When allocating a page, we store some information about allocation in extra memory. Later, if we need to know status of all pages, we can get and analyze it from this stored information. In previous version of this feature, extra memory is statically defined in struct page, but, in this version, extra memory is allocated outside of struct page. It enables us to turn on/off this feature at boottime without considerable memory waste. Although we already have tracepoint for tracing page allocation/free, using it to analyze page owner is rather complex. We need to enlarge the trace buffer for preventing overlapping until userspace program launched. And, launched program continually dump out the trace buffer for later analysis and it would change system behaviour with more possibility rather than just keeping it in memory, so bad for debug. Moreover, we can use page_owner feature further for various purposes. For example, we can use it for fragmentation statistics implemented in this patch. And, I also plan to implement some CMA failure debugging feature using this interface. I'd like to give the credit for all developers contributed this feature, but, it's not easy because I don't know exact history. Sorry about that. Below is people who has "Signed-off-by" in the patches in Andrew's tree. Contributor: Alexander Nyberg <alexn@dsv.su.se> Mel Gorman <mgorman@suse.de> Dave Hansen <dave@linux.vnet.ibm.com> Minchan Kim <minchan@kernel.org> Michal Nazarewicz <mina86@mina86.com> Andrew Morton <akpm@linux-foundation.org> Jungsoo Son <jungsoo.son@lge.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Dave Hansen <dave@sr71.net> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Jungsoo Son <jungsoo.son@lge.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: add vmstat counters and kpageflags bitKonstantin Khlebnikov
Always mark pages with PageBalloon even if balloon compaction is disabled and expose this mark in /proc/kpageflags as KPF_BALLOON. Also this patch adds three counters into /proc/vmstat: "balloon_inflate", "balloon_deflate" and "balloon_migrate". They accumulate balloon activity. Current size of balloon is (balloon_inflate - balloon_deflate) pages. All generic balloon code now gathered under option CONFIG_MEMORY_BALLOON. It should be selected by ballooning driver which wants use this feature. Currently virtio-balloon is the only user. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04tools/vm/page-types.c: catch sigbus if raced with truncateKonstantin Khlebnikov
Recently added page-cache dumping is known to be a little bit racy. But after race with truncate it just dies due to unhandled SIGBUS when it tries to poke pages beyond the new end of file. This patch adds handler for SIGBUS which skips the rest of the file. Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07tools/vm/page-types.c: page-cache sniffing featureKonstantin Khlebnikov
After this patch 'page-types' can walk over a file's mappings and analyze populated page cache pages mostly without disturbing its state. It maps chunk of file, marks VMA as MADV_RANDOM to turn off readahead, pokes VMA via mincore() to determine cached pages, triggers page-fault only for them, and finally gathers information via pagemap/kpageflags. Before unmap it marks VMA as MADV_SEQUENTIAL for ignoring reference bits. usage: page-types -f <path> If <path> is directory it will analyse all files in all subdirectories. Symlinks are not followed as well as mount points. Hardlinks aren't handled, they'll be dumped as many times as they are found. Recursive walk brings all dentries into dcache and populates page cache of block-devices aka 'Buffers'. Probably it's worth to add ioctl for dumping file page cache as array of PFNs as a replacement for this hackish juggling with mmap/madvise/mincore/pagemap. Also recursive walk could be replaced with dumping cached inodes via some ioctl or debugfs interface followed by openning them via open_by_handle_at, this would fix hardlinks handling and unneeded population of dcache and buffers. This interface might be used as data source for constructing readahead plans and for background optimizations of actively used files. collateral changes: + fix 64-bit LFS: define _FILE_OFFSET_BITS instead of _LARGEFILE64_SOURCE + replace lseek + read with single pread + make show_page_range() reusable after flush usage example: ~/src/linux/tools/vm$ sudo ./page-types -L -f page-types foffset offset flags page-types Inode: 2229277 Size: 89065 (22 pages) Modify: Tue Feb 25 12:00:59 2014 (162 seconds ago) Access: Tue Feb 25 12:01:00 2014 (161 seconds ago) 0 3cbf3b __RU_lA____M________________________ 1 38946a __RU_lA____M________________________ 2 1a3cec __RU_lA____M________________________ 3 1a8321 __RU_lA____M________________________ 4 3af7cc __RU_lA____M________________________ 5 1ed532 __RU_lA_____________________________ 6 2e436a __RU_lA_____________________________ 7 29a35e ___U_lA_____________________________ 8 2de86e ___U_lA_____________________________ 9 3bdfb4 ___U_lA_____________________________ 10 3cd8a3 ___U_lA_____________________________ 11 2afa50 ___U_lA_____________________________ 12 2534c2 ___U_lA_____________________________ 13 1b7a40 ___U_lA_____________________________ 14 17b0be ___U_lA_____________________________ 15 392b0c ___U_lA_____________________________ 16 3ba46a __RU_lA_____________________________ 17 397dc8 ___U_lA_____________________________ 18 1f2a36 ___U_lA_____________________________ 19 21fd30 __RU_lA_____________________________ 20 2c35ba __RU_l______________________________ 21 20f181 __RU_l______________________________ flags page-count MB symbolic-flags long-symbolic-flags 0x000000000000002c 2 0 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 11 0 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 4 0 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000086c 5 0 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 22 0 ~/src/linux/tools/vm$ sudo ./page-types -f / flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000028 21761 85 ___U_l______________________________ uptodate,lru 0x000000000000002c 127279 497 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 74160 289 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 84469 329 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000007c 1 0 __RUDlA_____________________________ referenced,uptodate,dirty,lru,active 0x0000000000000228 370 1 ___U_l___I__________________________ uptodate,lru,reclaim 0x0000000000000828 49 0 ___U_l_____M________________________ uptodate,lru,mmap 0x000000000000082c 126 0 __RU_l_____M________________________ referenced,uptodate,lru,mmap 0x0000000000000868 137 0 ___U_lA____M________________________ uptodate,lru,active,mmap 0x000000000000086c 12890 50 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 321242 1254 Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-16tools/: Convert to new topic librariesBorislav Petkov
Move debugfs.* to api/fs/. We have a common tools/lib/api/ place where the Makefile lives and then we place the headers in subdirs. For example, all the fs-related stuff goes to tools/lib/api/fs/ from which we get libapikfs.a (acme got almost the naming he wanted :-)) and we link it into the tools which need it - in this case perf and tools/vm/page-types. acme: "Looking at the implementation, I think some tools can even link directly to the .o files, avoiding the .a file altogether. But that is just an optimization/finer granularity tools/lib/ cherrypicking that toolers can make use of." Fixup documentation cleaning target while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <rric@kernel.org> Cc: Stanislav Fomichev <stfomichev@yandex-team.ru> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386605664-24041-2-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-13tools/vm/page-types.c: support KPF_SOFTDIRTY bitNaoya Horiguchi
Soft dirty bit allows us to track which pages are written since the last clear_ref (by "echo 4 > /proc/pid/clear_refs".) This is useful for userspace applications to know their memory footprints. Note that the kernel exposes this flag via bit[55] of /proc/pid/pagemap, and the semantics is not a default one (scheduled to be the default in the near future.) However, it shifts to the new semantics at the first clear_ref, and the users of soft dirty bit always do it before utilizing the bit, so that's not a big deal. Users must avoid relying on the bit in page-types before the first clear_ref. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-15tools/vm: Switch to liblk libraryBorislav Petkov
page-flags.c had some older version of debugfs_mount copied from perf so convert it to using the version in the tools library. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/1361374353-30385-8-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-02-05tools/vm: add .gitignore to ignore built binariesJoonsoo Kim
There is no .gitignore in tools/vm, so 'git status' always show built binaries. To ignore this, add .gitignore. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25UAPI: fix tools/vm/page-types.cDavid Howells
Fix tools/vm/page-types.c to use the UAPI variant of linux/kernel-page-flags.h lest the following error appear: In file included from page-types.c:38:0: ../../include/linux/kernel-page-flags.h:4:42: fatal error: uapi/linux/kernel-page-flags.h: No such file or directory Reported-by: Daniel Hazelton <dshadowwolf@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Fengguang Wu <fengguang.wu@intel.com> Tested-by: Daniel Hazelton <dshadowwolf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-02mm: Fix signal SIGFPE in slabinfo.c.majianpeng
In function slab_stats(), if total_free is equal zero, it will error. So fix it. Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: majianpeng <majianpeng@gmail.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-05-29tools/vm/page-types.c: cleanupsUlrich Drepper
Compiling page-type.c with a recent compiler produces many warnings, mostly related to signed/unsigned comparisons. This patch cleans up most of them. One remaining warning is about an unused parameter. The <compiler.h> file doesn't define a __unused macro (or the like) yet. This can be addressed later. Signed-off-by: Ulrich Drepper <drepper@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29kbuild: install kernel-page-flags.hUlrich Drepper
Programs using /proc/kpageflags need to know about the various flags. The <linux/kernel-page-flags.h> provides them and the comments in the file indicate that it is supposed to be used by user-level code. But the file is not installed. Install the headers and mark the unstable flags as out-of-bounds. The page-type tool is also adjusted to not duplicate the definitions Signed-off-by: Ulrich Drepper <drepper@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move slabinfo.c to tools/vmDave Young
We have tools/vm/ folder for vm tools, so move slabinfo.c from tools/slub/ to tools/vm/ Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move page-types.c from Documentation to tools/vmDave Young
tools/ is the better place for vm tools which are used by many people. Moving them to tools also make them open to more users instead of hide in Documentation folder. This patch moves page-types.c to tools/vm/page-types.c. Also add a Makefile in tools/vm and fix two coding style problems: a) change const arrary to 'const char * const', b) change a space to tab for indent. Signed-off-by: Dave Young <dyoung@redhat.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
