path: root/tools
2014-02-13turbostat: Use GCC's CPUID functions to support PICJosh Triplett
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream. turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems that have certain security features enabled by default that make -fPIC the default, this causes a build error: turbostat.c: In function ‘check_cpuid’: turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’ asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx"); ^ GCC provides a header cpuid.h, containing a __get_cpuid function that works with both PIC and non-PIC. (On PIC, it saves and restores ebx around the cpuid instruction.) Use that instead. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13turbostat: Don't put unprocessed uapi headers in the include pathJosh Triplett
commit b731f3119de57144e16c19fd593b8daeb637843e upstream. turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so that it can include <asm/msr.h> from it. It isn't in general safe to include even uapi headers directly from the kernel tree without processing them through scripts/headers_install.sh, but asm/msr.h happens to work. However, that include path can break with some versions of system headers, by overriding some system headers with the unprocessed versions directly from the kernel source. For instance: In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0, from /build/x86-generic/usr/include/signal.h:339, from /build/x86-generic/usr/include/sys/wait.h:31, from turbostat.c:27: ../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory This occurs because the system bits/sigcontext.h on that build system includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source includes <linux/compiler.h>, which scripts/headers_install.sh would have filtered out. Since turbostat really only wants a single header, just include that one header rather than putting an entire directory of kernel headers on the include path. In the process, switch from msr.h to msr-index.h, since turbostat just wants the MSR numbers. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06perf kvm: Fix kvm report without guestmount.Dongsheng Yang
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream. Currently, if we use perf kvm --guestkallsyms --guestmodules report, we can not get the perf information from perf data file. All sample are shown as unknown. Reproducing steps: # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ] # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep % 100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330 This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation). In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine which has the same pid, if no machine found, deliver it to *default* guest. But if we use perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built and added. Then the default guest which with pid == 0 will never get a symbol. And because the new machine initialized here has no kernel map created, the symbol delivered to it will be marked as "unknown". This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way. Verification steps: # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ] # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep % 22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70 19.99% :6471 [guest.kernel.kallsyms] [g] d_free 18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments 16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task 12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to 7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick 1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write 0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17cpupower: Fix segfault due to incorrect getopt_long arugmentsJosh Boyer
If a user calls 'cpupower set --perf-bias 15', the process will end with a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi call. This is because the getopt_long structure currently has all of the options as having an optional_argument when they really have a required argument. We change the structure to use required_argument to match the short options and it resolves the issue. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Thomas Renninger <trenn@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-08Merge tag 'usb-3.13-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a bunch of USB fixes for 3.13-rc3. Nothing major, but we seem to have an argument about a XHCI fix, so I'm not including a revert that Sarah requested, because that breaks a USB network driver, and I can't revert the USB network driver fix without reintroducing other bugs that it fixed. So as it is, everything should now be working. Worse case, I can revert the XHCI fix before 3.13-final is out, but it seems to work well here with my testing, so all should be good. Other than that, some driver updates based on reports" * tag 'usb-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (40 commits) usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED usb: ohci-pxa27x: include linux/dma-mapping.h USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem usb: tools: fix a regression issue that gcc can't link to pthread USB: switch maintainership of chipidea to Peter USB: pl2303: fixed handling of CS5 setting USB: ftdi_sio: fixed handling of unsupported CSIZE setting USB: mos7840: correct handling of CS5 setting USB: spcp8x5: correct handling of CS5 setting usb: wusbcore: fix deadlock in wusbhc_gtk_rekey usb: wusbcore: do device lookup while holding the hc mutex usb: wusbcore: send keepalives to unauthenticated devices USB: option: support new huawei devices USB: serial: option: blacklist interface 1 for Huawei E173s-6 usb: xhci: Link TRB must not occur within a USB payload burst usb: gadget: f_mass_storage: call try_to_freeze only when its safe usb: gadget: tcm_usb_gadget: mark bot_cleanup_old_alt static usb: gadget: ffs: fix sparse warning usb: gadget: zero: module parameters can be static usb: gadget: storage: fix sparse warning ...
2013-12-04usb: tools: fix a regression issue that gcc can't link to pthreadHuang Rui
Reproduce: ray@hr-bak:~/usb$ make -C tools/usb/ make: Entering directory `/home/ray/usb/tools/usb' gcc -Wall -Wextra -g -lpthread -I../include -o testusb testusb.c /tmp/cc0EMxfy.o: In function `main': /home/ray/usb/tools/usb/testusb.c:508: undefined reference to `pthread_create' /home/ray/usb/tools/usb/testusb.c:531: undefined reference to `pthread_join' collect2: error: ld returned 1 exit status make: *** [testusb] Error 1 make: Leaving directory `/home/ray/usb/tools/usb' Comments: In the latest version (4.7.3) of gcc compiler, it requres that libraries must follow the object or source files like below: "gcc hello.c -lpthread" instead of "gcc -lpthread hello.c" And it isn't encountered at gcc version 4.7.2. So this patch fix to move the pthread option after testusb.c. Signed-off-by: Huang Rui <ray.huang@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-02Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc kernel and tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tools lib traceevent: Fix conversion of pointer to integer of different size perf/trace: Properly use u64 to hold event_id perf: Remove fragile swevent hlist optimization ftrace, perf: Avoid infinite event generation loop tools lib traceevent: Fix use of multiple options in processing field perf header: Fix possible memory leaks in process_group_desc() perf header: Fix bogus group name perf tools: Tag thread comm as overriden
2013-11-25tools: cpupower: fix wrong err msg not supported vs not availableThomas Renninger
idlestates in sysfs are counted from 0. This fixes a wrong error message. Current behavior on a machine with 4 sleep states is: cpupower idle-set -e 4 Idlestate 4 enabled on CPU 0 -----Wrong--------------------- cpupower idle-set -e 5 Idlestate enabling not supported by kernel -----Must and now will be ----- cpupower idle-set -e 5 Idlestate 6 not available on CPU 0 ------------------------------- cpupower idle-set -e 6 Idlestate 6 not available on CPU 0 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-25tools: cpupower: Add cpupower-idle-set(1) manpageThomas Renninger
The cpupower idle-set subcommand was introduce recently. This patch provides the missing manpage. If cpupower is properly installed it will show up automatically (similar to git), when invoking: cpupower help idle-set or cpupower idle-set --help Some parts have been taken over and adjusted from git commit 62d6ae880e3e76098 documentation submitted by Carsten Emde. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-20Merge tag 'pm+acpi-2-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: - ACPI-based device hotplug fixes for issues introduced recently and a fix for an older error code path bug in the ACPI PCI host bridge driver - Fix for recently broken OMAP cpufreq build from Viresh Kumar - Fix for a recent hibernation regression related to s2disk - Fix for a locking-related regression in the ACPI EC driver from Puneet Kumar - System suspend error code path fix related to runtime PM and runtime PM documentation update from Ulf Hansson - cpufreq's conservative governor fix from Xiaoguang Chen - New processor IDs for intel_idle and turbostat and removal of an obsolete Kconfig option from Len Brown - New device IDs for the ACPI LPSS (Low-Power Subsystem) driver and ACPI-based PCI hotplug (ACPIPHP) cleanup from Mika Westerberg - Removal of several ACPI video DMI blacklist entries that are not necessary any more from Aaron Lu - Rework of the ACPI companion representation in struct device and code cleanup related to that change from Rafael J Wysocki, Lan Tianyu and Jarkko Nikula - Fixes for assigning names to ACPI-enumerated I2C and SPI devices from Jarkko Nikula * tag 'pm+acpi-2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (24 commits) PCI / hotplug / ACPI: Drop unused acpiphp_debug declaration ACPI / scan: Set flags.match_driver in acpi_bus_scan_fixed() ACPI / PCI root: Clear driver_data before failing enumeration ACPI / hotplug: Fix PCI host bridge hot removal ACPI / hotplug: Fix acpi_bus_get_device() return value check cpufreq: governor: Remove fossil comment in the cpufreq_governor_dbs() ACPI / video: clean up DMI table for initial black screen problem ACPI / EC: Ensure lock is acquired before accessing ec struct members PM / Hibernate: Do not crash kernel in free_basic_memory_bitmaps() ACPI / AC: Remove struct acpi_device pointer from struct acpi_ac spi: Use stable dev_name for ACPI enumerated SPI slaves i2c: Use stable dev_name for ACPI enumerated I2C slaves ACPI: Provide acpi_dev_name accessor for struct acpi_device device name ACPI / bind: Use (put|get)_device() on ACPI device objects too ACPI: Eliminate the DEVICE_ACPI_HANDLE() macro ACPI / driver core: Store an ACPI device pointer in struct acpi_dev_node cpufreq: OMAP: Fix compilation error 'r & ret undeclared' PM / Runtime: Fix error path for prepare PM / Runtime: Update documentation around probe|remove|suspend cpufreq: conservative: set requested_freq to policy max when it is over policy max ...
2013-11-19tools lib traceevent: Fix conversion of pointer to integer of different sizeArnaldo Carvalho de Melo
gcc complaint on 32-bit system: /home/acme/git/linux/tools/lib/traceevent/event-parse.c: In function ‘eval_num_arg’: /home/acme/git/linux/tools/lib/traceevent/event-parse.c:3468:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] This is because the eval_num_arg returns everything as an 'unsigned long long', so it converts a void pointer to a wider integer, fix it by converting the void pointer to an integer of the same size, 'unsigned long', before casting it to 'unsigned long long'. Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-yllx4aqcg06v5n4vjpwiiuld@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-19tools lib traceevent: Fix use of multiple options in processing fieldSteven Rostedt
Jiri Olsa reported that the scsi_dispatch_cmd_done event failed to parse with: Error: expected type 5 but read 4 Error: expected type 5 but read 4 The problem is with this part of the print_fmt: __print_symbolic(((REC->result) >> 24) & 0xff, ... The __print_symbolic() helper function's first parameter is the field to use to determine what symbol to print based on the value of the result. The parser can handle one operation, but it can not handle multiple operations ('>>' and '&'). Add code to process all operations for the field argument for __print_symbolic() as well as __print_flags(). Reported-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131118142314.27ca334b@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-19perf header: Fix possible memory leaks in process_group_desc()Namhyung Kim
After processing all group descriptors or encountering an error, it frees all descriptors. However, current logic can leak memory since it might not traverse all descriptors. Note that the 'i' can have different value than nr_groups when an error occurred and it's safe to call free(desc[i].name) for every desc since we already make it NULL when it's reused for group names. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1384741244-7271-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-19perf header: Fix bogus group nameNamhyung Kim
When processing event group descriptor in perf file header, we reuse an allocated group name but forgot to prevent it from freeing. Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1384741244-7271-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-19perf tools: Tag thread comm as overridenFrederic Weisbecker
The problem is that when a thread overrides its default ":%pid" comm, we forget to tag the thread comm as overriden. Hence, this overriden comm is not inherited on future forks. Fix it. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131116010207.GA18855@localhost.localdomain Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-19Merge branch 'pm-tools'Rafael J. Wysocki
* pm-tools: tools / power turbostat: Support Silvermont
2013-11-16Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Tooling changes only: it includes the ARM tooling fixlets, various other fixes, smaller updates, minor cleanups" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf record: Add an option to force per-cpu mmaps perf probe: Add '--demangle'/'--no-demangle' perf ui browser: Fix segfault caused by off by one handling END key perf symbols: Limit max callchain using max_stack on DWARF unwinding too perf evsel: Introduce perf_evsel__prev() method perf tools: Use perf_evlist__{first,last}, perf_evsel__next perf tools: Synthesize anon MMAP records again perf top: Add missing newline if the 'uid' is invalid perf tools: Remove trivial extra semincolon perf trace: Tweak summary output tools/perf/build: Fix feature-libunwind-debug-frame handling tools/perf/build: Fix timerfd feature check
2013-11-15Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Nothing really exciting: some groundwork for changing virtio endian, and some robustness fixes for broken virtio devices, plus minor tweaks" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio_scsi: verify if queue is broken after virtqueue_get_buf() x86, asmlinkage, lguest: Pass in globals into assembler statement virtio: mmio: fix signature checking for BE guests virtio_ring: adapt to notify() returning bool virtio_net: verify if queue is broken after virtqueue_get_buf() virtio_console: verify if queue is broken after virtqueue_get_buf() virtio_blk: verify if queue is broken after virtqueue_get_buf() virtio_ring: add new function virtqueue_is_broken() virtio_test: verify if virtqueue_kick() succeeded virtio_net: verify if virtqueue_kick() succeeded virtio_ring: let virtqueue_{kick()/notify()} return a bool virtio_ring: change host notification API virtio_config: remove virtio_config_val virtio: use size-based config accessors. virtio_config: introduce size-based accessors. virtio_ring: plug kmemleak false positive. virtio: pm: use CONFIG_PM_SLEEP instead of CONFIG_PM
2013-11-14perf record: Add an option to force per-cpu mmapsAdrian Hunter
By default, when tasks are specified (i.e. -p, -t or -u options) per-thread mmaps are created. Add an option to override that and force per-cpu mmaps. Further comments by peterz: So this option allows -t/-p/-u to create one buffer per cpu and attach all the various thread/process/user tasks' their counters to that one buffer? As opposed to the current state where each such counter would have its own buffer. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1383313899-15987-7-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf probe: Add '--demangle'/'--no-demangle'Azat Khuzhin
You can't pass demangled name into "perf probe", because of special chars: ./perf probe -f -x /tmp/a.out 'foo(int)' Semantic error :There is non-digit char in line number. And you can't even pass without demangling (because it search symbol in DSO with demangle=true): ./perf probe -f -x /tmp/a.out _Z3fooi no symbols found in /tmp/a.out, maybe install a debug package? However: nm /tmp/a.out | grep foo 000000000040056d T _Z3fooi After this patch, using the next command: ./perf probe -f --no-demangle -x /tmp/a.out _Z3fooi probe will be successfully added. Signed-off-by: Azat Khuzhin <a3at.mail@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1382947464-31266-1-git-send-email-a3at.mail@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf ui browser: Fix segfault caused by off by one handling END keyArnaldo Carvalho de Melo
$ perf record ls $ perf report Press 'down enter end' Result: Program received signal SIGSEGV, Segmentation fault. The UI browser, used on a argv array would access past the end of the array on SEEK_END because it wasn't using 'nr_entries - 1', fix it. Reported-by: v.karpov@samsung.com Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=59291 Link: http://lkml.kernel.org/n/tip-3g83ipasqi219ktv764xzzjs@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf symbols: Limit max callchain using max_stack on DWARF unwinding tooArnaldo Carvalho de Melo
It was affecting only frame-pointer (fp) based callchain processing. Usage example: perf top --call-graph dwarf,1024 --max-stack 2 Works for any tool that does callchain resolving and provides a --max-stack option. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/n/tip-eu45v8s3tq9ruay8tpfyon79@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf evsel: Introduce perf_evsel__prev() methodArnaldo Carvalho de Melo
Just one use so far, on the hists browser, for completeness since there we use perf_evlist__{first,last} and perf_evsel__next() for handling the TAB and UNTAB keys. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-d09l4lejp5427enuf3igpckw@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf tools: Use perf_evlist__{first,last}, perf_evsel__nextArnaldo Carvalho de Melo
In a few remaining places where the equivalent open coded variant was still being used. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-4vjnloi5fisilykwxalb5nel@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf tools: Synthesize anon MMAP records againDon Zickus
When introducing the PERF_RECORD_MMAP2 in: 5c5e854bc760 perf tools: Add attr->mmap2 support A check for the number of entries parsed by sscanf was introduced that assumed all of the 8 fields needed to be correctly parsed so that particular /proc/pid/maps line would be considered synthesizable. That broke anon records synthesizing, as it doesn't have the 'execname' field. Fix it by keeping the sscanf return check, changing it to not require that the 'execname' variable be parsed, so that the preexisting logic can kick in and set it to '//anon'. This should get things like JIT profiling working again. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Bill Gray <bgray@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Cc: Richard Fowles <rfowles@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/n/tip-bo4akalno7579shpz29u867j@git.kernel.org [ commit log message is mine, dzickus reported the problem with a patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf top: Add missing newline if the 'uid' is invalidIngo Molnar
Add missing newline if the 'uid' is invalid: hubble:~> perf top --stdio -u help Error: Invalid User: helphubble:~> Fixed by this patch: comet:~/tip/tools/perf> perf top --stdio -u help Error: Invalid User: help comet:~/tip/tools/perf> Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131112232609.GA31474@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf tools: Remove trivial extra semincolonDavidlohr Bueso
Accidentally ran into these, get rid of them. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Link: http://lkml.kernel.org/r/1384323864.2527.8.camel@buesod1.americas.hpqcorp.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14perf trace: Tweak summary outputPekka Enberg
Tweak the summary output as suggested by Ingo Molnar: [penberg@localhost ~]$ perf trace -a --duration 10000 --summary -- sleep 1 ^C Summary of events: Xorg (817), 148 events, 0.0%, 0.000 msec syscall calls min avg max stddev (msec) (msec) (msec) (%) --------------- -------- --------- --------- --------- ------ read 7 0.002 0.004 0.011 32.00% rt_sigprocmask 40 0.001 0.001 0.002 1.31% ioctl 6 0.002 0.003 0.005 19.45% writev 7 0.004 0.018 0.059 43.76% select 9 0.000 74.513 507.869 74.61% setitimer 4 0.001 0.002 0.002 10.08% Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Pekka Enberg <penberg@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Link: http://lkml.kernel.org/r/1384345308-24404-1-git-send-email-penberg@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-14tools/perf/build: Fix feature-libunwind-debug-frame handlingIngo Molnar
Set feature-libunwind-debug-frame. We don't want it in CORE_FEATURE_TESTS because it's not the generic case, but we need to set it in the !feature-libunwind case. Also, because x86 distributions typically don't have dwarf_find_debug_frame() unwinding method: test-libunwind-debug-frame.c:(.text+0x31): undefined reference to `_Ux86_64_dwarf_find_debug_frame' Restrict this new API to ARM for the time being. With this patch test-all.c works again, so repeat perf builds are fast again: comet:~/tip> perf stat --null --repeat 5 make -C tools/perf/ [...] 0,452899660 seconds time elapsed ( +- 0,11% ) While with before it was: comet:~/tip> perf stat --null --repeat 5 make -C tools/perf/ [...] 1,674001829 seconds time elapsed ( +- 0,16% ) [ Includes fix to config/feature-checks/Makefile from Will Deacon. ] Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Jean Pihet <jean.pihet@linaro.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/n/tip-scsoctqzmou3rpkixCHezy9e@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-14tools/perf/build: Fix timerfd feature checkIngo Molnar
'feature_timerfd' is checked all the time and calculated explicitly, in a serial fashion. Add it to CORE_FEATURE_TESTS which causes it to be built in parallel, using the newfangled parallel build autodetection code. This shaves 137 msecs off the perf build time on my system, which speeds up the common case cached build by 43%: Before: comet:~/tip> perf stat --null --repeat 5 make -C tools/perf/ [...] 0,453771441 seconds time elapsed ( +- 0,09% ) After: comet:~/tip> perf stat --null --repeat 5 make -C tools/perf/ [...] 0,316290185 seconds time elapsed ( +- 0,24% ) Cc: David Ahern <dsahern@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-bb92CmexihopoSyqnkqepvsy@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "A number of fixes: - Fix segfault on perf trace -i perf.data, from Namhyung Kim. - Fix segfault with --no-mmap-pages, from David Ahern. - Don't force a refresh during progress update in the TUI, greatly reducing startup costs, fix from Patrick Palka. - Fix sw clock event period test wrt not checking if using > max_sample_freq. - Handle throttle events in 'object code reading' test, fix from Adrian Hunter. - Prevent condition that all sort keys are elided, fix from Namhyung Kim. - Round mmap pages to power 2, from David Ahern. And a number of late arrival changes: - Add summary only option to 'perf trace', suppressing the decoding of events, from David Ahern - 'perf trace --summary' formatting simplifications, from Pekka Enberg. - Beautify fifth argument of mmap() as fd, in 'perf trace', from Namhyung Kim. - Add direct access to dynamic arrays in libtraceevent, from Steven Rostedt. - Synthesize non-exec MMAP records when --data used, allowing the resolution of data addresses to symbols (global variables, etc), by Arnaldo Carvalho de Melo. - Code cleanups by David Ahern and Adrian Hunter" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) tools lib traceevent: Add direct access to dynamic arrays perf target: Shorten perf_target__ to target__ perf tests: Handle throttle events in 'object code reading' test perf evlist: Refactor mmap_pages parsing perf evlist: Round mmap pages to power 2 - v2 perf record: Fix segfault with --no-mmap-pages perf trace: Add summary only option perf trace: Simplify '--summary' output perf trace: Change syscall summary duration order perf tests: Compensate lower sample freq with longer test loop perf trace: Fix segfault on perf trace -i perf.data perf trace: Separate tp syscall field caching into init routine to be reused perf trace: Beautify fifth argument of mmap() as fd perf tests: Use lower sample_freq in sw clock event period test perf tests: Check return of perf_evlist__open sw clock event period test perf record: Move existing write_output into helper function perf record: Use correct return type for write() perf tools: Prevent condition that all sort keys are elided perf machine: Simplify synthesize_threads method perf machine: Introduce synthesize_threads method out of open coded equivalent ...
2013-11-14Merge branch 'linus' into perf/urgentIngo Molnar
Merge dependencies to apply a fix. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-14Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "This time we only have a few changes as there are no soc thermal changes from Eduardo. The only big change is the introduction of TMON, a tool to help visualize, tune, and test the thermal subsystem. The rest is mostly cleanups and fixes all over. Specifics: - introduce TMON, a tool base on thermal sysfs I/F. It can be used to visualize, tune and test the thermal subsystem. - fix a zone/cooling device binding problem, when both thermal zone bind parameters and .bind() callback are available" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: tools/thermal: Introduce tmon, a tool for thermal subsystem thermal: Fix binding problem when there is thermal zone params thermal: cpu_cooling: fix return value check in cpufreq_cooling_register() Thermal: Check for validity before doing kfree thermal/intel_powerclamp: Add newer CPU models Thermal: Tidy up error handling in powerclamp_init thermal: Kconfig: cosmetic fixes ACPI/thermal : Remove zone disabled warning typo in drivers/thermal/Kconfig: lpatform instead of platform
2013-11-14Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this series are: 1. BE8 (modern big endian) changes for ARM from Ben Dooks 2. big.Little support from Nicolas Pitre and Dave Martin 3. support for LPAE systems with all system memory above 4GB 4. Perf updates from Will Deacon 5. Additional prefetching and other performance improvements from Will. 6. Neon-optimised AES implementation fro Ard. 7. A number of smaller fixes scattered around the place. There is a rather horrid merge conflict in tools/perf - I was never notified of the conflict because it originally occurred between Will's tree and other stuff. Consequently I have a resolution which Will forwarded me, which I'll forward on immediately after sending this mail. The other notable thing is I'm expecting some build breakage in the crypto stuff on ARM only with Ard's AES patches. These were merged into a stable git branch which others had already pulled, so there's little I can do about this. The problem is caused because these patches have a dependency on some code in the crypto git tree - I tried requesting a branch I can pull to resolve these, and all I got each time from the crypto people was "we'll revert our patches then" which would only make things worse since I still don't have the dependent patches. I've no idea what's going on there or how to resolve that, and since I can't split these patches from the rest of this pull request, I'm rather stuck with pushing this as-is or reverting Ard's patches. Since it should "come out in the wash" I've left them in - the only build problems they seem to cause at the moment are with randconfigs, and since it's a new feature anyway. However, if by -rc1 the dependencies aren't in, I think it'd be best to revert Ard's patches" I resolved the perf conflict roughly as per the patch sent by Russell, but there may be some differences. Any errors are likely mine. Let's see how the crypto issues work out.. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits) ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h" ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg(). ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h ARM: 7871/1: amba: Extend number of IRQS ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise() ARM: 7872/1: Support arch_irq_work_raise() via self IPIs ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode ARM: 7878/1: nommu: Implement dummy early_paging_init() ARM: 7876/1: clear Thumb-2 IT state on exception handling ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}() ARM: footbridge: fix build warnings for netwinder ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu ARM: fix misplaced arch_virt_to_idmap() ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation ARM: 7869/1: remove unused XSCALE_PMU Kconfig param ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments ARM: 7862/1: pcpu: replace __get_cpu_var_uses ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code ...
2013-11-13tools/vm/page-types.c: support KPF_SOFTDIRTY bitNaoya Horiguchi
Soft dirty bit allows us to track which pages are written since the last clear_ref (by "echo 4 > /proc/pid/clear_refs".) This is useful for userspace applications to know their memory footprints. Note that the kernel exposes this flag via bit[55] of /proc/pid/pagemap, and the semantics is not a default one (scheduled to be the default in the near future.) However, it shifts to the new semantics at the first clear_ref, and the users of soft dirty bit always do it before utilizing the bit, so that's not a big deal. Users must avoid relying on the bit in page-types before the first clear_ref. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12tools / power turbostat: Support SilvermontLen Brown
Support the next generation Intel Atom processor mirco-architecture, formerly called Silvermont. The server version, formerly called "Avoton", is named the "Intel(R) Atom(TM) Processor C2000 Product Family". The client version, formerly called "Bay Trail", is named the "Intel Atom Processor Z3000 Series", as well as various "Intel Pentium Processor" and "Intel Celeron Processor" brands, depending on form-factor. Silvermont has a set of MSRs not far off from NHM, but the RAPL register set is a sub-set of those previously supported. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-12Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: * Add summary only option to 'perf trace', suppressing the decoding of events, from David Ahern * 'perf trace --summary' formatting simplifications, from Pekka Emberg. * Beautify fifth argument of mmap() as fd, in 'perf trace', from Namhyung Kim. * Fix segfault on perf trace -i perf.data, from Namhyung Kim. * Fix segfault with --no-mmap-pages, from David Ahern. * Round mmap pages to power 2, from David Ahern. * Add direct access to dynamic arrays in libtraceevent, from Steven Rostedt. * Handle throttle events in 'object code reading' test, fix from Adrian Hunter. * Prevent condition that all sort keys are elided, fix from Namhyung Kim. * Synthesize non-exec MMAP records when --data used, allowing the resolution of data addresses to symbols (global variables, etc). * Don't force a refresh during progress update in the TUI, greatly reducing startup costs, fix from Patrick Palka. * Fix sw clock event period test wrt not checking if using > max_sample_freq. * Code cleanups by David Ahern and Adrian Hunter. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-12tools lib traceevent: Add direct access to dynamic arraysSteven Rostedt
Jiri Olsa was writing a plugin for the cfg80211_tx_mlme_mgmt trace event, and was not able to get the implemented function working. The event's print fmt looks like: "netdev:%s(%d), ftype:0x%.2x", REC->name, REC->ifindex, __le16_to_cpup((__le16 *)__get_dynamic_array(frame)) As there's no helper function for __le16_to_cpup(), Jiri was creating one with a plugin. But unfortunately, it would not work even though he set up the plugin correctly. The problem is that the function parameters do not handle the helper function "__get_dynamic_array()", and that passes in a NULL pointer. Adding PRINT_DYNAMIC_ARRAY direct support to eval_num_arg() allows the use of __get_dynamic_array() in function parameters. Reported-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131111160810.0ba9df7d@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf target: Shorten perf_target__ to target__Arnaldo Carvalho de Melo
Getting unwieldly long, for this app domain should be descriptive enough and the use of __ to separate the class from the method names should help with avoiding clashes with other code bases. Reported-by: David Ahern <dsahern@gmail.com> Suggested-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20131112113427.GA4053@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf tests: Handle throttle events in 'object code reading' testAdrian Hunter
Unhandled events cause an error that fails the test, fix it. Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/5281DFE5.3000909@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf evlist: Refactor mmap_pages parsingDavid Ahern
Logic will be re-used for the out-pages argument for mmap based writes in perf-record. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1384267617-3446-4-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf evlist: Round mmap pages to power 2 - v2David Ahern
Currently perf requires the -m / --mmap_pages option to be a power of 2. To be more user friendly perf should automatically round this up to the next power of 2. Currently: $ perf record -m 3 -a -- sleep 1 --mmap_pages/-m value must be a power of two.sleep: Terminated With patch: $ perf record -m 3 -a -- sleep 1 rounding mmap pages size to 16384 (4 pages) ... v2: Add bytes units to rounding message per Ingo's request. Other suggestions (e.g., prefixing INFO) should be addressed by wrapping pr_info to catch all instances. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1384267617-3446-3-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf record: Fix segfault with --no-mmap-pagesDavid Ahern
Adrian reported a segfault when using --no-out-pages: $ tools/perf/perf record -vv --no-out-pages uname Segmentation fault (core dumped) The same occurs with --no-mmap-pages. Fix by checking that str is non-NULL before parsing it. Signed-off-by: David Ahern <dsahern@gmail.com> Reported-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1384267617-3446-2-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Add summary only optionDavid Ahern
Per request from Pekka make --summary a summary only option meaning do not show the individual system calls. Add another option to see all syscalls along with the summary. In addition use 's' and 'S' as shortcuts for the options. Requested-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: David Ahern <dsahern@gmail.com> Tested-by: Pekka Enberg <penberg@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Link: http://lkml.kernel.org/r/1384273875-3751-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Simplify '--summary' outputPekka Enberg
The output of 'perf trace --summary' tries to be too cute with formatting and makes it very hard to read. Simplify it in the spirit of "strace -c": [penberg@localhost libtrading]$ perf trace -a --duration 10000 --summary -- sleep 1 ^C Summary of events: dbus-daemon (555), 10 events, 0.0%, 0.000 msec msec/call syscall calls min avg max stddev --------------- -------- -------- -------- -------- ------ sendmsg 2 0.002 0.005 0.008 55.00 recvmsg 2 0.002 0.003 0.005 44.00 epoll_wait 1 0.000 0.000 0.000 0.00 NetworkManager (667), 56 events, 0.0%, 0.000 msec msec/call syscall calls min avg max stddev --------------- -------- -------- -------- -------- ------ poll 2 0.000 0.002 0.003 100.00 sendmsg 10 0.004 0.007 0.016 15.41 recvmsg 16 0.002 0.003 0.005 8.24 zfs-fuse (669), 4 events, 0.0%, 0.000 msec msec/call syscall calls min avg max stddev --------------- -------- -------- -------- -------- ------ futex 2 0.000 0.001 0.002 100.00 Signed-off-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Link: http://lkml.kernel.org/r/1384267334-18953-1-git-send-email-penberg@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Change syscall summary duration orderPekka Enberg
Switch duration order to minimum, average, maximum for the '--summary' command line option because it's more natural to read. Signed-off-by: Pekka Enberg <penberg@kernel.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Link: http://lkml.kernel.org/r/1384265410-12344-1-git-send-email-penberg@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf tests: Compensate lower sample freq with longer test loopAdrian Hunter
Doesn't work for me: ./perf test -v 19 19: Test software clock events have valid period values : --- start --- mmap size 528384B mmap size 528384B All (0) samples have period value of 1! ---- end ---- Test software clock events have valid period values: FAILED! Compensate the lower freq introduced in 67c1e4a53b17 with a longer loop, Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/5281D3B8.2030104@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Fix segfault on perf trace -i perf.dataNamhyung Kim
When replaying a previous record session, it'll get a segfault since it doesn't initialize raw_syscalls enter/exit tracepoint's evsel->priv for caching the format fields. So fix it by properly initializing sys_enter/exit evsels that comes from reading the perf.data file header. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1384237500-22991-2-git-send-email-namhyung@kernel.org [ Split the syscall tp field caching part in the previous patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Separate tp syscall field caching into init routine to be reusedNamhyung Kim
We need to set this in evsels coming out of a perf.data file header, not just for new ones created for live sessions. So separate the code that caches the syscall entry/exit tracepoint format fields into a new function that will be used in the next changeset. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20131112115700.GC4053@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-12perf trace: Beautify fifth argument of mmap() as fdNamhyung Kim
The fifth argument of mmap syscall is fd and it often contains -1 as a value for anon mappings. Without this patch it doesn't show the file name as well as it shows -1 as 4294967295. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1384237500-22991-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
