Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 4cca0457686e4ee1677d69469e4ddfd94d389a80 ]
The switch that conditionally sets CPUPOWER_CAP_HAS_TURBO_RATIO and
CPUPOWER_CAP_IS_SNB flags is missing a break, so all cores get both
flags set and an assumed base clock of 100 MHz for turbo values.
Reported-by: GSR <gsr.bugs@infernal-iceberg.com>
Tested-by: GSR <gsr.bugs@infernal-iceberg.com>
References: https://bugs.debian.org/859978
Fixes: 8fb2e440b223 (cpupower: Show Intel turbo ratio support via ...)
[ Upstream commit 32677207dcc5e594254b7fb4fb2352b1755b1d5b ]
The child_exit errno needs to be shifted by 8 bits to compare against the
return values for the bisect variables.
Fixes: c5dacb88f0a64 ("ktest: Allow overriding bisect test results")
Cc: stable@vger.kernel.org
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Linux 4.1.39
* tag 'v4.1.39': (138 commits)
Linux 4.1.39
KVM: x86: remove data variable from kvm_get_msr_common
KVM: VMX: Fix host initiated access to guest MSR_TSC_AUX
KVM: x86: pass host_initiated to functions that read MSRs
perf/core: Fix the perf_cpu_time_max_percent check
perf/core: Make sysctl_perf_cpu_time_max_percent conform to documentation
perf/core: Fix implicitly enable dynamic interrupt throttle
perf/core: Fix dynamic interrupt throttle
Fix missing sanity check in /dev/sg
printk: use rcuidle console tracepoint
vfs: fix uninitialized flags in splice_to_pipe()
drm/radeon: Use mode h/vdisplay fields to hide out of bounds HW cursor
ARM: 8658/1: uaccess: fix zeroing of 64-bit get_user()
drm/dp/mst: fix kernel oops when turning off secondary monitor
[media] siano: make it work again with CONFIG_VMAP_STACK
mmc: core: fix multi-bit bus width without high-speed mode
futex: Move futex_init() to core_initcall
xen-netfront: Delete rx_refill_timer in xennet_disconnect_backend()
scsi: aacraid: Fix INTx/MSI-x issue with older controllers
cpumask: use nr_cpumask_bits for parsing functions
[ Upstream commit 3659f98b5375d195f1870c3e508fe51e52206839 ]
Nothing in this minimal script seems to require bash. We often run these
tests on embedded devices where the only shell available is the busybox
ash. Use sh instead.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit a2b1e8a20c992b01eeb76de00d4f534cbe9f3822 ]
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit f594bae08183fb6b57db55387794ece3e1edf6f6 ]
I'm surprised this remained undocumented since at least 2011. And it is
actually a very useful switch, as Steve and I came to realize recently.
Add the text from
2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
which added the incrementing aspect to -d.
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Davidlohr Bueso <dbueso@suse.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Mel Gorman <mgorman@suse.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de
[ Upstream commit 89fee59b504f86925894fcc9ba79d5c933842f93 ]
Steam frequently puts game binaries in folders with spaces.
Note: "(deleted)" markers are now treated as part of the file name.
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps")
Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720
[ Upstream commit 106b816cb46ebd87408b4ed99a2e16203114daa6 ]
At the end of process_filter(), collapse_tree() was changed to update
the parg parameter, but the reassignment after the call wasn't removed.
What happens is that the "current_op" gets modified and freed and parg
is assigned to the new allocated argument. But after the call to
collapse_tree(), parg is assigned again to the just freed "current_op",
and this causes the tool to crash.
The current_op variable must also be assigned to NULL in case of error,
otherwise it will cause it to be free()ed twice.
Cc: stable@vger.kernel.org # 3.14+
Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()")
Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home
[ Upstream commit 940db6dcd3f4659303fdf6befe7416adc4d24118 ]
When an error happens during alias parsing currently the complete
parsing of all attributes of the PMU is stopped. This is breaks old perf
on a newer kernel that may have not-yet-know alias attributes (such as
.scale or .per-pkg).
Continue when some attribute is unparseable.
This is IMHO a stable candidate and should be backported to older
versions to avoid problems with newer kernels.
v2: Print warnings when something goes wrong.
v3: Change warning to debug output
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: stable@vger.kernel.org # v3.6+
Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org
[ Upstream commit 50fe6dd10069e7c062e27f29606f6e91ea979399 ]
Use the local uapi headers to keep in sync with "recently" added #define's
(e.g. VSS_OP_REGISTER1).
Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv")
Cc: <stable@vger.kernel.org>
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 ]
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
[ Upstream commit c8ad7063626406181a7ebab10cb31b4f741b13d4 ]
Building perf out of kernel tree is currently broken because the
MANIFEST file refers to kernel files that have been removed. With this
patch make perf-targz-src-pkg succeeds as does building perf using the
generated tarfile.
Signed-off-by: David Ahern <david.ahern@oracle.com>
Link: http://lkml.kernel.org/r/1433526173-172332-1-git-send-email-david.ahern@oracle.com
recording/reporting guest data
[ Upstream commit 3caeaa562733c4836e61086ec07666635006a787 ]
While recording guest samples in host using perf kvm record, it will
populate unprocessable sample error, though samples will be recorded
properly. While generating report using perf kvm report, no samples will
be processed and same error will populate. We have seen this behaviour
with upstream perf(4.4-rc3) on x86 and ppc64 hardware.
Reason behind this failure is, when it tries to fetch machine from
rb_tree of machines, it fails. As a part of tracing a bug, we figured
out that this code was incorrectly refactored in commit 54245fdc3576
("perf session: Remove wrappers to machines__find").
This patch will change the functionality such that if it can't fetch
machine in first trial, it will create one node of machine and add that to
rb_tree. So next time when it tries to fetch same machine from rb_tree,
it won't fail. Actually it was the case before refactoring of code in
aforementioned commit.
This patch is generated from acme perf/core branch.
Below I've mention an example that demonstrate the behaviour before and
after applying patch.
Before applying patch:
[Note: One needs to run guest before recording data in host]
ravi@ravi-bangoria:~$ ./perf kvm record -a
Warning:
5903 unprocessable samples recorded.
Do you have a KVM guest running and not using 'perf kvm'?
[ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ]
ravi@ravi-bangoria:~$ ./perf kvm report --stdio
Warning:
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 285 of event 'cycles'
# Event count (approx.): 88715406
# Overhead Command Shared Object Symbol
# (For a higher level overview, try: perf report --sort comm,dso)
After applying patch:
[ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ]
# Samples: 17 of event 'cycles'
# Event count (approx.): 700746
34.19% :5758 [unknown] [g] 0xffffffff818682ab
22.79% :5758 [unknown] [g] 0xffffffff812dc7f8
22.79% :5758 [unknown] [g] 0xffffffff818650d0
14.83% :5758 [unknown] [g] 0xffffffff8161a1b6
2.49% :5758 [unknown] [g] 0xffffffff818692bf
0.48% :5758 [unknown] [g] 0xffffffff81869253
0.05% :5758 [unknown] [g] 0xffffffff81869250
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org # v3.19+
Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find")
Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com
machines
[ Upstream commit 32abc2ede536aae52978d6c0a8944eb1df14f460 ]
When a long value is read on 32 bit machines for 64 bit output, the
parsing needs to change "%lu" into "%llu", as the value is read
natively.
Unfortunately, if "%llu" is already there, the code will add another "l"
to it and fail to parse it properly.
Link: http://lkml.kernel.org/r/20151116172516.4b79b109@gandalf.local.home
For ctrl out test, it needs length > vary, so in order to run it with
default parameters, we do this change.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The 'length' is the transfer length, not the packet size, so
change the help text.
[ Upstream commit d7475de58575c904818efa369c82e88c6648ce2e ]
(e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I.
Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
commit c2e4b24ff848bb180f9b9cd873a38327cd219ad2 upstream.
When a trace recorded on a 32-bit device is processed with a 64-bit
binary, the higher 32-bits of the address need to ignored.
The lack of this results in the output of the 64-bit pointer
value to the trace as the 32-bit address lookup fails in find_printk().
Before:
burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c
After:
burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated
The problem occurs in PRINT_FIELD when the field is recognized as a
pointer to a string (of the type const char *)
Heterogeneous architectures cases below can arise and should be handled:
* Traces recorded using 32-bit addresses processed on a 64-bit machine
* Traces recorded using 64-bit addresses processed on a 32-bit machine
Reported-by: Juri Lelli <juri.lelli@arm.com>
Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Javi Merino <javi.merino@arm.com>
Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com
commit caa470475d9b59eeff093ae650800d34612c4379 upstream.
The original patch introducing this header wrote the number of CPUs available
and online in one order and then swapped those values when reading, fix it.
Before:
# perf record usleep 1
# perf report --header-only | grep 'nrcpus \(online\|avail\)'
# nrcpus online : 4
# nrcpus avail : 4
# echo 0 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 4
# nrcpus avail : 3
# echo 0 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 2
After the fix, bringing back the CPUs online:
# nrcpus online : 2
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 3
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 4
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)")
Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org
commit 93df8a1ed6231727c5db94a80b1a6bd5ee67cec3 upstream.
perf currently fails to build on MIPS as there is no
tools/perf/arch/mips/Build file. Adding an empty file fixes this as
there are no MIPS-specific sources to build.
It looks like the same is needed for Alpha and PA-RISC, though I
haven't been able to test those.
Fixes: 5e8c0fb6a957 ("perf build: Add arch x86 objects building")
Link: http://lkml.kernel.org/r/1438704627.7315.2.camel@decadent.org.uk
commit 601083cffb7cabdcc55b8195d732f0f7028570fa upstream.
print_aggr() fails to print per-core/per-socket statistics after commit
582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
if events have differnt cpus. Because in print_aggr(), aggr_get_id needs
index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be
used to get aggregated id.
Here is an example:
Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has
cpumask 0,18)
$ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2
Without this patch, it failes to get CPU 18 result.
Performance counter stats for 'CPU(s) 0,18':
S0-C0 1 7526851 cycles
S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/
S1-C0 0 <not counted> cycles
S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/
With this patch, it can get both CPU0 and CPU18 result.
S0-C0 1 6327768 cycles
S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/
S1-C0 1 330228 cycles
S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/
Signed-off-by: Kan Liang <kan.liang@intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Stephane Eranian <eranian@google.com>
Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com
commit e8e6d37e73e6b950c891c780745460b87f4755b6 upstream.
When we introduce a new sort key, we need to update the
hists__calc_col_len() function accordingly, otherwise the width
will be limited to strlen(header).
We can't update it when obtaining a line value for a column (for
instance, in sort__srcline_cmp()), because we reset it all when doing a
resort (see hists__output_recalc_col_len()), so we need to, from what is
in the hist_entry fields, set each of the column widths.
Fixes: 409a8be61560 ("perf tools: Add sort by src line/number")
Link: http://lkml.kernel.org/n/tip-jgbe0yx8v1gs89cslr93pvz2@git.kernel.org
commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d upstream.
A copy of /proc/kcore containing the kernel text can be made to the
buildid cache. e.g.
perf buildid-cache -v -k /proc/kcore
To workaround objdump limitations, a copy is also made when annotating
against /proc/kcore.
The copying process stops working from libelf about v1.62 onwards (the
problem was found with v1.63).
The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails
because additional validation has been added to gelf_getphdr().
The use of gelf_getphdr() is a misguided attempt to get default
initialization of the Gelf_Phdr structure. That should not be
necessary because every member of the Gelf_Phdr structure is
subsequently assigned. So just remove the call to gelf_getphdr().
Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be
removed also.
Committer notes:
Note to stable@kernel.org, from Adrian in the cover letter for this
patchkit:
The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think
it is important enough for stable.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com
commit 0bc2f2f7d080561cc484d2d0a162a9396bed3383 upstream.
When setting yup the symbols library we setup several filter lists,
for dsos, comms, symbols, etc, and there is code that, if there are
filters, do certain operations, like recalculate the number of non
filtered histogram entries in the top/report TUI.
But they were considering just the "Zoom" filters, when they need to
take into account as well the above mentioned filters (perf top --comms,
--dsos, etc).
So store in symbol_conf.has_filter true if any of those filters is in
place.
Link: http://lkml.kernel.org/n/tip-f5edfmhq69vfvs1kmikq1wep@git.kernel.org
Cc: Andre Tomt <lkml@tomt.net>
commit 9c0fa8dd3d58de8b688fda758eea1719949c7f0a upstream.
At some point:
commit 2c86c7ca7606
Author: Namhyung Kim <namhyung@kernel.org>
Date: Mon Mar 17 18:18:54 2014 -0300
perf report: Merge al->filtered with hist_entry->filtered
We stopped dropping samples for things filtered via the --comms, --dsos,
--symbols, etc, i.e. things marked as filtered in the symbol resolution
routines (thread__find_addr_map(), perf_event__preprocess_sample(),
etc).
But then, in:
commit 268397cb2a47
Date: Tue Apr 22 14:49:31 2014 +0900
perf top/tui: Update nr_entries properly after a filter is applied
We don't take into account entries that were filtered in
perf_event__preprocess_sample() and friends, which leads to
inconsistency in the browser seek routines, that expects the number of
hist_entry->filtered entries to match what it thinks is the number of
unfiltered, browsable entries.
So, for instance, when we do:
perf top --symbols ___non_existent_symbol___
the hist_browser__nr_entries() routine thinks there are no filters in
place, uses the hists->nr_entries but all entries are filtered, leading
to a segfault.
Tested with:
perf top --symbols malloc,free --percentage=relative
Freezing, by pressing 'f', at any time and doing the math on the
percentages ends up with 100%, ditto for:
perf top --dsos libpthread-2.20.so,libxul.so --percentage=relative
Both were segfaulting, all fixed now.
More work needed to do away with checking if filters are in place, we
should just use the nr_non_filtered_samples counter, no need to
conditionally use it or hists.nr_filter, as what the browser does is
just show unfiltered stuff. An audit of how it is being accounted is
needed, this is the minimal fix.
Reported-by: Michael Petlan <mpetlan@redhat.com>
Fixes: 268397cb2a47 ("perf top/tui: Update nr_entries properly after a filter is applied")
Link: http://lkml.kernel.org/n/tip-6w01d5q97qk0d64kuojme5in@git.kernel.org
commit 2b42b09b88c831ba4da2d669581dde371c38c2af upstream.
With commit: e1e455f4f4d3 (perf tools: Work around lack of sched_getcpu
in glibc < 2.6), perf_bench numa mem with -c or -m option is not able to
correctly calculate convergence.
With the above commit, sched_getcpu always seems to return -1. The
intention of commit e1e455f was to add a sched_getcpu in glibc < 2.6.
Hence keep the sched_getcpu definition under an ifdef.
This regression happened occurred between v4.0 and v4.1
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Vinson Lee <vlee@twitter.com>
Fixes: e1e455f4f4d3 ("perf tools: Work around lack of sched_getcpu in glibc < 2.6")
Link: http://lkml.kernel.org/r/20150624111004.GA5220@linux.vnet.ibm.com
commit 60df4642a83546fa6ea8286f5094ce8c0906c3ec upstream.
Make 3.81 doesn't have the 'undefine' command. Using undefine
to clear LDFLAGS fails when make version 3.81 is used. Fix it
to use override to clear LDFLAGS.
Tested-by: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Link: http://lkml.kernel.org/r/20150514151225.GH23588@kernel.org
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 75e84ab906ef8935cff3df3d8929f1bafea81599 upstream.
Invoking Makefile.perf with prefix= breaks the build since Makefile.perf
hands that variable down to Makefile.build where it overrides
prefix := $(subst ./,,$(OUTPUT)$(dir)/)
leading to errors like this:
No rule to make target '/usrabspath.o', needed by '/usrlibperf-in.o'
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Fixes: c819e2cf2eb6f65d3208d195d7a0edef6108d5
Link: http://lkml.kernel.org/r/5582c48a.84a22b0a.a918.5285SMTPIN_ADDED_MISSING@mx.google.com
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- early_idt_handlers[] fix that fixes the build with bleeding edge
tooling
- build warning fix on GCC 5.1
- vm86 fix plus self-test to make it harder to break it again"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/asm/irq: Stop relying on magic JMP behavior for early_idt_handlers
x86/asm/entry/32, selftests: Add a selftest for kernel entries from VM86 mode
x86/boot: Add CONFIG_PARAVIRT_SPINLOCKS quirk to arch/x86/boot/compressed/misc.h
x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull turbostat tool fixes from Len Brown:
"Just one minor kernel dependency in this batch -- added a #define to
msr-index.h"
* 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
tools/power turbostat: update version number to 4.7
tools/power turbostat: allow running without cpu0
tools/power turbostat: correctly decode of ENERGY_PERFORMANCE_BIAS
tools/power turbostat: enable turbostat to support Knights Landing (KNL)
tools/power turbostat: correctly display more than 2 threads/core
Test a couple of special cases in 32-bit kernels for entries
from vm86 mode. This will OOPS both old kernels due to a bug
and and 4.1-rc5 due to a regression I introduced, and it should
make sure that the SYSENTER-from-vm86-mode hack in the kernel
keeps working.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Jan Beulich <JBeulich@suse.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Link: http://lkml.kernel.org/r/09a9916761e0a9e42d4922f147af45a0079cc1e8.1432936374.git.luto@kernel.org
Tests: 394838c96013 x86/asm/entry/32: Fix user_mode() misuses
Tests: 7ba554b5ac69 x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode
Signed-off-by: Len Brown <len.brown@intel.com>
Linux-3.7 added CONFIG_BOOTPARAM_HOTPLUG_CPU0,
allowing systems to offline cpu0.
But when cpu0 is offline, turbostat will not run:
# turbostat ls
turbostat: no /dev/cpu/0/msr
This patch replaces the hard-coded use of cpu0 in turbostat
with the current cpu, allowing it to run without a cpu0.
Fewer cross-calls may also be needed due to use of current cpu,
though this hard-coding was used only for the --debug preamble.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
When EPB is 0xF, turbosat was incorrectly describing it as "custom"
instead of calling it "powersave":
< cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x0000000f (custom)
> cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x0000000f (powersave)
Changes mainly to account for minor differences in Knights Landing(KNL):
1. KNL supports C1 and C6 core states.
2. KNL supports PC2, PC3 and PC6 package states.
3. KNL has a different encoding of the TURBO_RATIO_LIMIT MSR
Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com>
Without this update, turbostat displays only 2 threads per core.
Some processors, such as Xeon Phi, have more.
With recent debugging, I noticed that bpf_jit_disasm segfaults when
there's no debugging output from the JIT compiler to the kernel log.
Reason is that when regexec(3) doesn't match on anything, start/end
offsets are not being filled out and contain some uninitialized garbage
from stack. Thus, we need zero out offsets first.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal fixes from Zhang Rui:
"Specifics:
- fix an issue in intel_powerclamp driver that idle injection target
is not accurately maintained on newer Intel CPUs. Package C8 to
C10 states are introduced on these CPUs but they were not included
in the package c-state residency calculation. From Jacob Pan.
- fix a problem that package c-state idle injection was missing on
Broadwell server, by adding its id to intel_powerclamp driver.
From Jacob Pan.
- a couple of small fixes and cleanups from Joe Perches, Mathias
Krause, Dan Carpenter and Anand Moon"
* 'for-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
tools/thermal: tmon: fixed the 'make install' command
thermal: rockchip: fix an error code
thermal/powerclamp: fix missing newer package c-states
thermal/intel_powerclamp: add id for broadwell server
thermal/intel_powerclamp: add __init / __exit annotations
thermal: Use bool function return values of true/false not 1/0
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest fixes from Shuah Khan:
"Urgent fix for Kselftest regression introduced in 4.1-rc1 by the new
x86 test due to its hard dependency on 32-bit build environment.
A set of 5 patches fix the make kselftest run and kselftest install"
* tag 'linux-kselftest-4.1-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests, x86: Rework x86 target architecture detection
selftests, x86: Remove useless run_tests rule
selftests/x86: install tests
selftest/x86: have no dependency on all when cross building
selftest/x86: build both bitnesses
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into perf/urgent
Pull liblockdep fixes from Sasha Levin:
"two fixes that deal with compilation errors in liblockdep."
Recent changes to kernel/locking/lockdep.c broke the liblockdep build. Fix
that.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
If we try to cross compile liblockdep, even if we set the CROSS_COMPILE variable
the linker error can occur because LD is not set with CROSS_COMPILE.
This patch adds "LD" can be set automatically with CROSS_COMPILE variable so
fixes linker error problem.
We currently fail to build on a non-multilib x86_64 target. We
print a helpful error, but it's nicer to allow the build to succeed.
Fix it and improve cross-compilation support by detecting
architecture support directly and building only the relevant tests.
Now that selftests/x86 uses the kselftest infrastructure, the
run_x86_tests.sh mechanism is just in the way.
Include lib.mk and set TEST_PROGS where appropriate.
Signed-off-by: Tyler Baker <tyler.baker@linaro.org>
If the CROSS_COMPILE is set remove all's dependency on all_32 and all_64.
Acked-by: Andy Lutomirski <luto@kernel.org>
Using uname with the processor flag option in some cases can yield 'unknown'
so lets use the machine flag option as it is deterministic. Add a dependency
for all_32 when building on a x86 64 bit host so that both bitnesses are
built in this case.
Parsing /proc/cpuinfo is a fiddly, arch-dependent business and a recent
change to get it working for Sparc broke arm and arm64 platforms.
Use sysconf to determine the number of online CPUs only parsing
/proc/cpuinfo when sysconf is not available.
Cc: David Ahern <david.ahern@oracle.com>
Cc: Mark Rutland <Mark.Rutland@arm.com>
Link: http://lkml.kernel.org/r/20150423140454.GJ1652@arm.com
[ Made it fall back to parsing /proc when getconf not found ]
