path: root/tools
2012-02-20perf tools: Fix perf stack to non executable on x86_64Jiri Olsa
commit 7a0153ee15575a4d07b5da8c96b79e0b0fd41a12 upstream. By adding following objects: bench/mem-memcpy-x86-64-asm.o the x86_64 perf binary ended up with executable stack. The reason was that above object are assembler sourced and is missing the GNU-stack note section. In such case the linker assumes that the final binary should not be restricted at all and mark the stack as RWX. Adding section ".note.GNU-stack" definition to mentioned object, with all flags disabled, thus omiting this object from linker stack flags decision. Problem introduced in: $ git describe ea7872b v2.6.37-rc2-19-gea7872b Reported-at: https://bugzilla.redhat.com/show_bug.cgi?id=783570 Reported-by: Clark Williams <williams@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1328100848-5630-1-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> [ committer note: Backported fix to perf/urgent (3.3-rc2+) ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20perf evsel: Fix an issue where perf report fails to show the proper percentageNaveen N. Rao
commit a4a03fc7ef89020baca4f19174e6a43767c6d78a upstream. This patch fixes an issue where perf report shows nan% for certain perf.data files. The below is from a report for a do_fork probe: -nan% sshd [kernel.kallsyms] [k] do_fork -nan% packagekitd [kernel.kallsyms] [k] do_fork -nan% dbus-daemon [kernel.kallsyms] [k] do_fork -nan% bash [kernel.kallsyms] [k] do_fork A git bisect shows commit f3bda2c as the cause. However, looking back through the git history, I saw commit 640c03c which seems to have removed the required initialization for perf_sample->period. The problem only started showing after commit f3bda2c. The below patch re-introduces the initialization and it fixes the problem for me. With the below patch, for the same perf.data: 73.08% bash [kernel.kallsyms] [k] do_fork 8.97% 11-dhclient [kernel.kallsyms] [k] do_fork 6.41% sshd [kernel.kallsyms] [k] do_fork 3.85% 20-chrony [kernel.kallsyms] [k] do_fork 2.56% sendmail [kernel.kallsyms] [k] do_fork This patch applies over current linux-tip commit 9949284. Problem introduced in: $ git describe 640c03c v2.6.37-rc3-83-g640c03c Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robert Richter <robert.richter@amd.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120203170113.5190.25558.stgit@localhost6.localdomain6 Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12perf: Fix parsing of __print_flags() in TP_printk()Steven Rostedt
commit 49908a1b25d448d68fd26faca260e1850201575f upstream. A update is made to the sched:sched_switch event that adds some logic to the first parameter of the __print_flags() that shows the state of tasks. This change cause perf to fail parsing the flags. A simple fix is needed to have the parser be able to process ops within the argument. Reported-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Do no try to schedule task events if there are none lockdep, kmemcheck: Annotate ->lock in lockdep_init_map() perf header: Use event_name() to get an event name perf stat: Failure with "Operation not supported"
2011-12-07Merge branch 'perf/urgent' of git://github.com/acmel/linux into perf/urgentIngo Molnar
2011-12-06Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ftrace: Fix hash record accounting bug perf: Fix parsing of __print_flags() in TP_printk() jump_label: jump_label_inc may return before the code is patched ftrace: Remove force undef config value left for testing tracing: Restore system filter behavior tracing: fix event_subsystem ref counting
2011-12-06perf header: Use event_name() to get an event nameAndrew Vagin
perf_evsel.name may be not initialized Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arun Sharma <asharma@fb.com> Cc: devel@openvz.org Link: http://lkml.kernel.org/r/1322471015-107825-2-git-send-email-avagin@openvz.org Signed-off-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix loss of notification with multi-event perf, x86: Force IBS LVT offset assignment for family 10h perf, x86: Disable PEBS on SandyBridge chips trace_events_filter: Use rcu_assign_pointer() when setting ftrace_event_call->filter perf session: Fix crash with invalid CPU list perf python: Fix undefined symbol problem perf/x86: Enable raw event access to Intel offcore events perf: Don't use -ENOSPC for out of PMU resources perf: Do not set task_ctx pointer in cpuctx if there are no events in the context perf/x86: Fix PEBS instruction unwind oprofile, x86: Fix crash when unloading module (nmi timer mode) oprofile: Fix crash when unloading module (hr timer mode)
2011-12-05perf: Fix parsing of __print_flags() in TP_printk()Steven Rostedt
A update is made to the sched:sched_switch event that adds some logic to the first parameter of the __print_flags() that shows the state of tasks. This change cause perf to fail parsing the flags. A simple fix is needed to have the parser be able to process ops within the argument. Cc: stable@vger.kernel.org Reported-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-12-05perf stat: Failure with "Operation not supported"Anton Blanchard
perf stat is failing on PowerPC: Error: open_counter returned with 95 (Operation not supported). /bin/dmesg may provide additional information. Fatal: Not all events could be opened. commit 370faf1dd046 (perf stat: Fail softly on unsupported events) added a check for failure returning ENOENT, but the POWER backend returns EOPNOTSUPP. It looks like alpha, blackfin and mips do the same. With the patch applied, things work as expected: Performance counter stats for '/bin/true': 0.362176 task-clock # 0.623 CPUs utilized 0 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 28 page-faults # 0.077 M/sec 1,677,020 cycles # 4.630 GHz <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 431,220 instructions # 0.26 insns per cycle 101,889 branches # 281.325 M/sec 4,145 branch-misses # 4.07% of all branches 0.000581361 seconds time elapsed Cc: <stable@kernel.org> # 3.0+ Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111202093833.5fef7226@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-18ktest: Check parent options for iterated testsRabin Vincent
Let's say we have "OUTPUT_DIR = build/${TEST_NAME}", and we're iterating a test. In the second iteration of a test, the TEST_NAME of the test we're repeating is not used. Instead, ${TEST_NAME} appears literally: touch /home/rabin/kernel/test/build/${TEST_NAME}/.config ... SUCCESS Fix this by making __eval_option() check the parent test options for a repeated test. Link: http://lkml.kernel.org/r/1321616131-21352-2-git-send-email-rabin@rab.in Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-11-16perf session: Fix crash with invalid CPU listDavid Ahern
commit 5d67be9 added the option to specify a range of CPUs of interest, but does not catch an invalid CPU list: $ perf script -c foo Segmentation fault (core dumped) Cc: Anton Blanchard <anton@samba.org> Link: http://lkml.kernel.org/r/1321206327-5881-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-16perf python: Fix undefined symbol problemArnaldo Carvalho de Melo
Recently we made perf_evsel__init call hists__init, which broke the perf python binding: [root@emilia linux]# ./tools/perf/python/twatch.py Traceback (most recent call last): File "./tools/perf/python/twatch.py", line 16, in <module> import perf ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: hists__init Fix it by moving the hists__init function to its only caller, evsel.c. This way we avoid dragging in other parts of tools/perf/util/ to the perf python binding. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-5nffmdt5mu6ozxgj54oi4qon@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: (21 commits) ktest: Evaluate variables entered on the command line ktest: Add variable ${PWD} ktest: Add another monitor flush before installing kernel ktest: Do not opencode reboot in grub setting ktest: Add processing of complex conditionals ktest: Fix parsing of config section lines ktest: Sort make_min_config configs by dependecies ktest: Add DEFINED keyword for IF statements ktest: Add OVERRIDE keyword to DEFAULTS section ktest: Consolidate TEST_TYPE and DEFAULT code ktest: Add INCLUDE keyword to include other config files ktest: Let IF keyword take comparisons ktest: Add IF and ELSE to config sections ktest: Do not reboot on config or build issues ktest: Add option REBOOT_SUCCESS_LINE to stop waiting after a reboot ktest: Add NO_INSTALL option to not install for a test ktest: Fail when grub menu not found ktest: Include monitor in reboot code ktest: Only need to save .config when doing mrproper ktest: Create outputdir if it does not exist ...
2011-11-07Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf top: Fix live annotation in the --stdio interface perf top tui: Don't recalc column widths considering just the first page perf report: Add progress bar when processing time ordered events perf hists browser: Warn about lost events perf tools: Fix a typo of command name as trace-cmd perf hists: Fix recalculation of total_period when sorting entries perf header: Fix build on old systems perf ui browser: Handle K_RESIZE in dialog windows perf ui browser: No need to switch char sets that often perf hists browser: Use K_TIMER perf ui: Rename ui__warning_paranoid to ui__error_paranoid perf ui: Reimplement the popup windows using libslang perf ui: Reimplement ui__popup_menu using ui__browser perf ui: Reimplement ui_helpline using libslang perf ui: Improve handling sigwinch a bit perf ui progress: Reimplement using slang perf evlist: Fix grouping of multiple events
2011-11-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: cpuidle: Single/Global registration of idle states cpuidle: Split cpuidle_state structure and move per-cpu statistics fields cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare() cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning ACPI: Export FADT pm_profile integer value to userspace thermal: Prevent polling from happening during system suspend ACPI: Drop ACPI_NO_HARDWARE_INIT ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast() PNPACPI: Simplify disabled resource registration ACPI: Fix possible recursive locking in hwregs.c ACPI: use kstrdup() mrst pmu: update comment tools/power turbostat: less verbose debugging
2011-11-06Merge branches 'acpi', 'idle', 'mrst-pmu' and 'pm-tools' into nextLen Brown
2011-11-03perf top: Fix live annotation in the --stdio interfaceArnaldo Carvalho de Melo
In the old --stdio interface the annotation is done just after one selects a symbol, while in --tui, now the default when the required libs are installed, we annotate all symbols with samples so that when annotation is asked we see what happened recently on that symbol. To achieve that the --stdio variant checks if the hist_entry being processed is the one selected by the user via the 's' hotkey. What happens now that we share the hist_entry abstractions with 'perf report' is that for minimizing locking contention multiple rb_trees are used, one for collecting the samples and other to browse/show them after resorting it by number of samples and decay them, which is done periodically. So the simple test in record_precise_ip doesn't work as we move hist_entries between those rb_trees. To fix it just check that the underlying struct symbol associated with those hist_entries is the same. Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-bcfnraqkux88fox9ba9767ds@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf top tui: Don't recalc column widths considering just the first pageArnaldo Carvalho de Melo
It makes sense for the stdio where we can't navigate to the other pages. On the TUI it breaks as soon as we navigate to other pages that have, DSOs with longer names than the ones on the first page. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-zvqfp18mw229agb43cikgb0k@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf report: Add progress bar when processing time ordered eventsArnaldo Carvalho de Melo
So that for large perf.data files the user can have visual feedback that activity is being performed. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-3ysn01mpspfrbsy56gznzqqz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf hists browser: Warn about lost eventsArnaldo Carvalho de Melo
Just like the old perf top --tui and the --stdio version. But because we have the initial menu to choose which event to show in a session with multiple events we can see how many chunks were lost in each of the event types, clarifying which events are being affected the most. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-47yyqbubmjzch2chezmb21m6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-28ktest: Evaluate variables entered on the command lineSteven Rostedt
When ktest.pl is called without any arguments, or if the config file does not exist, ktest.pl will ask the user for some information. Some of these questions are code paths. Allowing the user to type ${PWD} for the current directory greatly simplifies these entries. Add variable processing to the entered values. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-10-28perf tools: Fix a typo of command name as trace-cmdMasami Hiramatsu
Fix a typo which may be introduced when original code has been copied from trace-cmd. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20111004104456.14591.37395.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-27perf hists: Fix recalculation of total_period when sorting entriesArnaldo Carvalho de Melo
We were doing parts of it in hists__collapse_resort and parts of it in hists__output_resort, leading to a bogus total_period. Fix it by doing just the filtering operation when collapsing because there we know that the Zoom operations adds filters just what is in hists->entries, not to the new batch of entries being collapsed. And move all the nr_entries + total_period recalculation to hists__output_resort since we will traverse all entries anyway there. Problem introduced when developing threaded addition of new batches of hist_entries, i.e. post v3.1. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-8xyh165h7hmwy0696hu25en6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: tools, slub: Fix off-by-one buffer corruption after readlink() call slub: Discard slab page when node partial > minimum partial number slub: correct comments error for per cpu partial mm: restrict access to slab files under procfs and sysfs slub: Code optimization in get_partial_node() slub: doc: update the slabinfo.c file path slub: explicitly document position of inserting slab to partial list slub: update slabinfo tools to report per cpu partial list statistics slub: per cpu cache for partial pages slub: return object pointer from get_partial() / new_slab(). slub: pass kmem_cache_cpu pointer to get_partial() slub: Prepare inuse field in new_slab() slub: Remove useless statements in __slab_alloc slub: free slabs without holding locks slub: use print_hex_dump slab: use print_hex_dump
2011-10-26perf header: Fix build on old systemsArnaldo Carvalho de Melo
For instance, on Fedora 8: CC /home/acme/git/build/perf/util/header.o cc1: warnings being treated as errors util/header.c: In function ‘write_cpudesc’: util/header.c:281: warning: implicit declaration of function ‘getline’ util/header.c:281: warning: nested extern declaration of ‘getline’ make: *** [/home/acme/git/build/perf/util/header.o] Error 1 make: Leaving directory `/home/acme/git/linux/tools/perf' [acme@localhost linux]$ This happens due to header ordering, in perf util.h sets _GNU_SOURCE, so it must come first. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-alfra9wao63euguj7gr8jw7e@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui browser: Handle K_RESIZE in dialog windowsArnaldo Carvalho de Melo
Just provide wrappers for things like ui__warning, ui__dialog_yesno and if they return K_RESIZE, refresh dimensions, redraw the entries, etc. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-3ih7hyk9weryxaxb501sfq4u@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui browser: No need to switch char sets that oftenArnaldo Carvalho de Melo
Just before and after the loop. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-0lh91cedngyg1pqarbky5vn7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf hists browser: Use K_TIMERArnaldo Carvalho de Melo
In the switch case entry for the timer routine. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ypw3i9kmxoq28skx7jy914it@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui: Rename ui__warning_paranoid to ui__error_paranoidArnaldo Carvalho de Melo
As it will exit the tool after the user is notified. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vy06m8xzlvkhr8tk7nylhbng@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26Merge branches 'slab/next' and 'slub/partial' into slab/for-linusPekka Enberg
2011-10-26perf ui: Reimplement the popup windows using libslangArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vtxnmz1t1807ykprapnk9njl@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui: Reimplement ui__popup_menu using ui__browserArnaldo Carvalho de Melo
Right now let it work just like the other browsers: in full screen, at the top left corner. If people complain we can revisit, I found it OK and the laziest/quickest approach at reusing the ui_browser ;-) Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-4bgeqizcxh04q0sk24cw43gk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui: Reimplement ui_helpline using libslangArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-gh7e1v2z7pzqmok02r6zvp17@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui: Improve handling sigwinch a bitArnaldo Carvalho de Melo
No need to unblock it at each ui__getch() and also allow other users to check if a resize is needed, or force an refresh of terminal dimensions. The 'force' one shouldn't be needed, but its in a slow path, so leave it like that for now, I'll revisit this another day. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-aujchu6yx3bfy64non1rky0w@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui progress: Reimplement using slangArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vkb9jh5kkzl5ep3puoatd6an@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (121 commits) perf symbols: Increase symbol KSYM_NAME_LEN size perf hists browser: Refuse 'a' hotkey on non symbolic views perf ui browser: Use libslang to read keys perf tools: Fix tracing info recording perf hists browser: Elide DSO column when it is set to just one DSO, ditto for threads perf hists: Don't consider filtered entries when calculating column widths perf hists: Don't decay total_period for filtered entries perf hists browser: Honour symbol_conf.show_{nr_samples,total_period} perf hists browser: Do not exit on tab key with single event perf annotate browser: Don't change selection line when returning from callq perf tools: handle endianness of feature bitmap perf tools: Add prelink suggestion to dso update message perf script: Fix unknown feature comment perf hists browser: Apply the dso and thread filters when merging new batches perf hists: Move the dso and thread filters from hist_browser perf ui browser: Honour the xterm colors perf top tui: Give color hints just on the percentage, like on --stdio perf ui browser: Make the colors configurable and change the defaults perf tui: Remove unneeded call to newtCls on startup perf hists: Don't format the percentage on hist_entry__snprintf ... Fix up conflicts in arch/x86/kernel/kprobes.c manually. Ingo's tree did the insane "add volatile to const array", which just doesn't make sense ("volatile const"?). But we could remove the const *and* make the array volatile to make doubly sure that gcc doesn't optimize it away.. Also fix up kernel/trace/ring_buffer.c non-data-conflicts manually: the reader_lock has been turned into a raw lock by the core locking merge, and there was a new user of it introduced in this perf core merge. Make sure that new use also uses the raw accessor functions.
2011-10-26Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits) staging: et131x: Remove redundant check and return statement staging: et131x: Mainly whitespace changes to appease checkpatch staging: et131x: Remove last of the forward declarations staging: et131x: Remove even more forward declarations staging: et131x: Remove yet more forward declarations staging: et131x: Remove more forward declarations staging: et131x: Remove forward declaration of et131x_adapter_setup staging: et131x: Remove some forward declarations staging: et131x: Remove unused rx_ring.recv_packet_pool staging: et131x: Remove call to find pci pm capability staging: et131x: Remove redundant et131x_reset_recv() call staging: et131x: Remove unused rx_ring.recv_buffer_pool Staging: bcm: Fix three initialization errors in InterfaceDld.c Staging: bcm: Fix coding style issues in InterfaceDld.c staging:iio:dac: Add AD5360 driver staging:iio:trigger:bfin-timer: Fix compile error Staging: vt6655: add some range checks before memcpy() Staging: vt6655: whitespace fixes to iotcl.c Staging: vt6656: add some range checks before memcpy() Staging: vt6656: whitespace cleanups in ioctl.c ... Fix up conflicts in: - drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}: vg driver movement - drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}: driver removal vs now stale changes - drivers/staging/rtl8192e/r8192E_core.c: driver removal vs now stale changes - drivers/staging/et131x/et131*: driver consolidation into one file, tried to do fixups
2011-10-26perf evlist: Fix grouping of multiple eventsArnaldo Carvalho de Melo
The __perf_evsel__open routing was grouping just the threads for that specific events per cpu when we want to group all threads in all events to the first fd opened on that cpu. So pass the xyarray with the first event, where the other events will be able to get that first per cpu fd. At some point top and record will switch to using perf_evlist__open that takes care of this detail and probably will also handle the fallback from hw to soft counters, etc. Reported-by: Deng-Cheng Zhu <dczhu@mips.com> Tested-by: Deng-Cheng Zhu <dczhu@mips.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ebm34rh098i9y9v4cytfdp0x@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-25Merge branch 'staging-next' into Linux 3.1Greg Kroah-Hartman
This was done to resolve a conflict in the drivers/staging/comedi/drivers/ni_labpc.c file that resolved a build bugfix in Linus's tree with a "better" bugfix that was in the staging-next tree that resolved the issue in a more complete manner. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-22ktest: Add variable ${PWD}Steven Rostedt
Adding the variable ${PWD} that equals `pwd` makes the config files much simpler. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-10-22ktest: Add another monitor flush before installing kernelSteven Rostedt
On some tests that do multiple boots (patchcheck, bisect, etc), the build of the next kernel to run may finish before the stable kernel has finished booting. Then the install of the new kernel will fail when it tries to connect as the machine has not finished the boot process. Do one more monitor flush to make sure the machine is up and running before trying to connect to it again. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-10-21perf symbols: Increase symbol KSYM_NAME_LEN sizeRicardo Ribalda Delgado
Fglrx propietary driver has symbol names over 128 chars (:S). This breaks the function kallsyms__parse. This fix increases the size of KSYM_NAME_LEN, so kallsyms__parse can work on such kernels. The only counterparty, is that such function requires 128 more bytes to work. Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Anton Blanchard <anton@samba.org> Cc: David Ahern <daahern@cisco.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1319096606-11568-1-git-send-email-ricardo.ribalda@gmail.com Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-21perf hists browser: Refuse 'a' hotkey on non symbolic viewsArnaldo Carvalho de Melo
We don't allocate the histogram data structures for --sort lists without "sym", so, just like was done for the menu, don't try to annotate when 'a' is pressed, just warn the user about it. Reported-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-27mjg02s2mbw8lfxqv7jpzec@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-20perf ui browser: Use libslang to read keysArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-uy6s534uqxq8tenh6s3k8ocj@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-20perf tools: Fix tracing info recordingJiri Olsa
Fixing the way the tracing information is stored within record command. The current implementation is causing issues for pipe output. Following commands fail currently: perf script syscall-counts ls perf record -e syscalls:sys_exit_read ls | ./perf report -i - The tracing information is part of the perf data file. It contains several files from within the tracing debugfs and procs directories. Beside some static header files, for each tracing event the format file is added. The /proc/kallsyms file is also added. The tracing data are stored with preceeding size. This is causing some dificulties for pipe output, since there's no way to tell debugfs/proc file size before reading it. So, for pipe output, all the debugfs files were read twice. Once to get the overall size and once to store the content itself. This can cause problem in case any of these file changed, within the storage time. To fix this behaviour and ensure the integrity of the tracing data, we: - read debugfs/proc file into the temp file - get temp file size and dump it to the pipe - dump the temp file contents to the pipe Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20111020135943.GD2092@jolsa.brq.redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-20ktest: Do not opencode reboot in grub settingSteven Rostedt
When setting the next kernel to boot to with grub, do not opencode the reboot operation. The normal reboot operation can be modified by config options (namely POWERCYCLE_AFTER_REBOOT). This needs to affect all reboots. Remove the opencoded reboot to make sure that any changes to the reboot code also affect all reboots. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-10-20perf hists browser: Elide DSO column when it is set to just one DSO, ditto ↵Arnaldo Carvalho de Melo
for threads And also no leed to show the [.] (level: k, . for userspace) when showing just one DSO. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-4h3f6ro5o7ebepjbssxf0dd3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-20perf hists: Don't consider filtered entries when calculating column widthsArnaldo Carvalho de Melo
Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-rf01wktu1e3f3az32nry86vu@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
