path: root/tools
2017-10-05selftests/seccomp: Support glibc 2.26 siginfo_t.hKees Cook
commit 10859f3855db4c6f10dc7974ff4b3a292f3de8e0 upstream. The 2.26 release of glibc changed how siginfo_t is defined, and the earlier work-around to using the kernel definition are no longer needed. The old way needs to stay around for a while, though. Reported-by: Seth Forshee <seth.forshee@canonical.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Will Drewry <wad@chromium.org> Cc: Shuah Khan <shuah@kernel.org> Cc: linux-kselftest@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-13selftests/x86/fsgsbase: Test selectors 1, 2, and 3Andy Lutomirski
commit 23d98c204386a98d9ef9f9e744f41443ece4929f upstream. Those are funny cases. Make sure they work. (Something is screwy with signal handling if a selector is 1, 2, or 3. Anyone who wants to dive into that rabbit hole is welcome to do so.) Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chang Seok <chang.seok.bae@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30ntb: ntb_test: ensure the link is up before trying to configure the mwsLogan Gunthorpe
commit 0eb46345364d7318b11068c46e8a68d5dc10f65e upstream. After the link tests, there is a race on one side of the test for the link coming up. It's possible, in some cases, for the test script to write to the 'peer_trans' files before the link has come up. To fix this, we simply use the link event file to ensure both sides see the link as up before continuning. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Acked-by: Allen Hubbe <Allen.Hubbe@dell.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30NTB: ntb_test: fix bug printing ntb_perf resultsLogan Gunthorpe
commit 07b0b22b3e58824f70b9188d085d400069ca3240 upstream. The code mistakenly prints the local perf results for the remote test so the script reports identical results for both directions. Fix this by ensuring we print the remote result. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem") Acked-by: Allen Hubbe <Allen.Hubbe@dell.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30perf probe: Fix --funcs to show correct symbols for offline moduleMasami Hiramatsu
commit eebc509b20881b92d62e317b2c073e57c5f200f0 upstream. Fix --funcs (-F) option to show correct symbols for offline module. Since previous perf-probe uses machine__findnew_module_map() for offline module, even if user passes a module file (with full path) which is for other architecture, perf-probe always tries to load symbol map for current kernel module. This fix uses dso__new_map() to load the map from given binary as same as a map for user applications. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148350053478.19001.15435255244512631545.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Krister Johansen <kjlx@templeofstupid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf symbols: Robustify reading of build-id from sysfsArnaldo Carvalho de Melo
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ] Markus reported that perf segfaults when reading /sys/kernel/notes from a kernel linked with GNU gold, due to what looks like a gold bug, so do some bounds checking to avoid crashing in that case. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4 Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf tools: Install tools/lib/traceevent plugins with install-binArnaldo Carvalho de Melo
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ] Those are binaries as well, so should be installed by: make -C tools/perf install-bin' too. Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Daniel Bristot de Oliveira <bristot@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06tools lib traceevent: Fix prev/next_prio for deadline tasksDaniel Bristot de Oliveira
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ] Currently, the sched:sched_switch tracepoint reports deadline tasks with priority -1. But when reading the trace via perf script I've got the following output: # ./d & # (d is a deadline task, see [1]) # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295] d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295] The task d reports the wrong priority [4294967295]. This happens because the "int prio" is stored in an unsigned long long val. Although it is set as a %lld, as int is shorter than unsigned long long, trace_seq_printf prints it as a positive number. The fix is just to cast the val as an int, and print it as a %d, as in the sched:sched_switch tracepoint's "format". The output with the fix is: # ./d & # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1] d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120] [1] d.c --- #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #include <linux/types.h> #include <linux/sched.h> struct sched_attr { __u32 size, sched_policy; __u64 sched_flags; __s32 sched_nice; __u32 sched_priority; __u64 sched_runtime, sched_deadline, sched_period; }; int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags) { return syscall(__NR_sched_setattr, pid, attr, flags); } int main(void) { struct sched_attr attr = { .size = sizeof(attr), .sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */ .sched_runtime = 10 * 1000 * 1000, .sched_period = attr.sched_deadline = 30 * 1000 * 1000, }; if (sched_setattr(0, &attr, 0) < 0) { perror("sched_setattr"); return -1; } for(;;); } --- Committer notes: Got the program from the provided URL, http://bristot.me/lkml/d.c, trimmed it and included in the cset log above, so that we have everything needed to test it in one place. Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Daniel Bristot de Oliveira <bristot@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf probe: Fix to get correct modname from elf headerMasami Hiramatsu
[ Upstream commit 1f2ed153b916c95a49a1ca9d7107738664224b7f ] Since 'perf probe' supports cross-arch probes, it is possible to analyze different arch kernel image which has different bits-per-long. In that case, it fails to get the module name because it uses the MOD_NAME_OFFSET macro based on the host machine bits-per-long, instead of the target arch bits-per-long. This fixes above issue by changing modname-offset based on the target archs bit width. This is ok because linux kernel uses LP64 model on 64bit arch. E.g. without this (on x86_64, and target module is arm32): $ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup p:probe/configfs_lookup :configfs_lookup+0 ^-Here is an empty module name. With this fix, you can see correct module name: $ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup p:probe/configfs_lookup configfs:configfs_lookup+0 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148337043836.6752.383495516397005695.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf annotate: Fix broken arrow at row 0 connecting jmp instruction to its ↵Jin Yao
target commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e upstream. When the jump instruction is displayed at the row 0 in annotate view, the arrow is broken. An example: 16.86 │ ┌──je 82 0.01 │ movsd (%rsp),%xmm0 │ movsd 0x8(%rsp),%xmm4 │ movsd 0x8(%rsp),%xmm1 │ movsd (%rsp),%xmm3 │ divsd %xmm4,%xmm0 │ divsd %xmm3,%xmm1 │ movsd (%rsp),%xmm2 │ addsd %xmm1,%xmm0 │ addsd %xmm2,%xmm0 │ movsd %xmm0,(%rsp) │82: sub $0x1,%ebx 83.03 │ ↑ jne 38 │ add $0x10,%rsp │ xor %eax,%eax │ pop %rbx │ ← retq The patch increments the row number before checking with 0. Signed-off-by: Yao Jin <yao.jin@linux.intel.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line") Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Clear FUP flag on errorAdrian Hunter
commit 6a558f12dbe85437acbdec5e149ea07b5554eced upstream. Sometimes a FUP packet is associated with a TSX transaction and a flag is set to indicate that. Ensure that flag is cleared on any error condition because at that point the decoder can no longer assume it is correct. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-9-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Use FUP always when scanning for an IPAdrian Hunter
commit 622b7a47b843c78626f40c1d1aeef8483383fba2 upstream. The decoder will try to use branch packets to find an IP to start decoding or to recover from errors. Currently the FUP packet is used only in the case of an overflow, however there is no reason for that to be a special case. So just use FUP always when scanning for an IP. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-8-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Ensure never to set 'last_ip' when packet 'count' is zeroAdrian Hunter
commit f952eaceb089b691eba7c4e13686e742a8f26bf5 upstream. Intel PT uses IP compression based on the last IP. For decoding purposes, 'last IP' is not updated when a branch target has been suppressed, which is indicated by IPBytes == 0. IPBytes is stored in the packet 'count', so ensure never to set 'last_ip' when packet 'count' is zero. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-7-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Fix last_ip usageAdrian Hunter
commit ee14ac0ef6827cd6f9a572cc83dd0191ea17812c upstream. Intel PT uses IP compression based on the last IP. For decoding purposes, 'last IP' is considered to be reset to zero whenever there is a synchronization packet (PSB). The decoder wasn't doing that, and was treating the zero value to mean that there was no last IP, whereas compression can be done against the zero value. Fix by setting last_ip to zero when a PSB is received and keep track of have_last_ip. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-6-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Ensure IP is zero when state is INTEL_PT_STATE_NO_IPAdrian Hunter
commit ad7167a8cd174ba7d8c0d0ed8d8410521206d104 upstream. A value of zero is used to indicate that there is no IP. Ensure the value is zero when the state is INTEL_PT_STATE_NO_IP. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-5-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Fix missing stack clearAdrian Hunter
commit 12b7080609097753fd8198cc1daf589be3ec1cca upstream. The return compression stack must be cleared whenever there is a PSB. Fix one case where that was not happening. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-4-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Improve sample timestampAdrian Hunter
commit 3f04d98e972b59706bd43d6cc75efac91f8fba50 upstream. The decoder uses its current timestamp in samples. Usually that is a timestamp that has already passed, but in some cases it is a timestamp for a branch that the decoder is walking towards, and consequently hasn't reached. Improve that situation by using the pkt_state to determine when to use the current or previous timestamp. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27perf intel-pt: Move decoder error setting into one conditionAdrian Hunter
commit 22c06892332d8916115525145b78e606e9cc6492 upstream. Move decoder error setting into one condition. Cc'ed to stable because later fixes depend on it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1495786658-18063-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21selftests/capabilities: Fix the test_execve testAndy Lutomirski
commit 796a3bae2fba6810427efdb314a1c126c9490fb3 upstream. test_execve does rather odd mount manipulations to safely create temporary setuid and setgid executables that aren't visible to the rest of the system. Those executables end up in the test's cwd, but that cwd is MNT_DETACHed. The core namespace code considers MNT_DETACHed trees to belong to no mount namespace at all and, in general, MNT_DETACHed trees are only barely function. This interacted with commit 380cf5ba6b0a ("fs: Treat foreign mounts as nosuid") to cause all MNT_DETACHed trees to act as though they're nosuid, breaking the test. Fix it by just not detaching the tree. It's still in a private mount namespace and is therefore still invisible to the rest of the system (except via /proc, and the same nosuid logic will protect all other programs on the system from believing in test_execve's setuid bits). While we're at it, fix some blatant whitespace problems. Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org> Fixes: 380cf5ba6b0a ("fs: Treat foreign mounts as nosuid") Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Kees Cook <keescook@chromium.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Greg KH <greg@kroah.com> Cc: linux-kselftest@vger.kernel.org Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21tools/lib/lockdep: Reduce MAX_LOCK_DEPTH to avoid overflowing lock_chain/: DepthBen Hutchings
commit 98dcea0cfd04e083ac74137ceb9a632604740e2d upstream. liblockdep has been broken since commit 75dd602a5198 ("lockdep: Fix lock_chain::base size"), as that adds a check that MAX_LOCK_DEPTH is within the range of lock_chain::depth and in liblockdep it is much too large. That should have resulted in a compiler error, but didn't because: - the check uses ARRAY_SIZE(), which isn't yet defined in liblockdep so is assumed to be an (undeclared) function - putting a function call inside a BUILD_BUG_ON() expression quietly turns it into some nonsense involving a variable-length array It did produce a compiler warning, but I didn't notice because liblockdep already produces too many warnings if -Wall is enabled (which I'll fix shortly). Even before that commit, which reduced lock_chain::depth from 8 bits to 6, MAX_LOCK_DEPTH was too large. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: a.p.zijlstra@chello.nl Link: http://lkml.kernel.org/r/20170525130005.5947-3-alexander.levin@verizon.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf probe: Add error checks to offline probe post-processingMasami Hiramatsu
commit 3e96dac7c956089d3f23aca98c4dfca57b6aaf8a upstream. Add error check codes on post processing and improve it for offline probe events as: - post processing fails if no matched symbol found in map(-ENOENT) or strdup() failed(-ENOMEM). - Even if the symbol name is the same, it updates symbol address and offset. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148411443738.9978.4617979132625405545.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Krister Johansen <kjlx@templeofstupid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf probe: Fix to probe on gcc generated symbols for offline kernelMasami Hiramatsu
commit 8a937a25a7e3c19d5fb3f9d92f605cf5fda219d8 upstream. Fix perf-probe to show probe definition on gcc generated symbols for offline kernel (including cross-arch kernel image). gcc sometimes optimizes functions and generate new symbols with suffixes such as ".constprop.N" or ".isra.N" etc. Since those symbol names are not recorded in DWARF, we have to find correct generated symbols from offline ELF binary to probe on it (kallsyms doesn't correct it). For online kernel or uprobes we don't need it because those are rebased on _text, or a section relative address. E.g. Without this: $ perf probe -k build-arm/vmlinux -F __slab_alloc* __slab_alloc.constprop.9 $ perf probe -k build-arm/vmlinux -D __slab_alloc p:probe/__slab_alloc __slab_alloc+0 If you put above definition on target machine, it should fail because there is no __slab_alloc in kallsyms. With this fix, perf probe shows correct probe definition on __slab_alloc.constprop.9: $ perf probe -k build-arm/vmlinux -D __slab_alloc p:probe/__slab_alloc __slab_alloc.constprop.9+0 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148350060434.19001.11864836288580083501.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Krister Johansen <kjlx@templeofstupid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf scripting perl: Fix compile error with some perl5 versionsWang YanQing
commit d7dd112ea5cacf91ae72c0714c3b911eb6016fea upstream. Fix below compile error: CC util/scripting-engines/trace-event-perl.o In file included from /usr/lib/perl5/5.22.2/i686-linux/CORE/perl.h:5673:0, from util/scripting-engines/trace-event-perl.c:31: /usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h: In function 'S__is_utf8_char_slow': /usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h:270:5: error: nested extern declaration of 'Perl___notused' [-Werror=nested-externs] dTHX; /* The function called below requires thread context */ ^ cc1: all warnings being treated as errors After digging perl5 repository, I find out that we will meet this compile error with perl from v5.21.1 to v5.25.4 Signed-off-by: Wang YanQing <udknight@gmail.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/20170212024655.GA15997@udknight Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf header: Fix handling of PERF_EVENT_UPDATE__SCALEArnaldo Carvalho de Melo
commit 8434a2ec13d5c8cb25716950bfbf7c9d7b64628a upstream. In commit daeecbc0c431 ("perf tools: Add event_update event scale type"), the handling of PERF_EVENT_UPDATE__SCALE cast struct event_update_event->data to a pointer to event_update_event_scale, uses some field from this casted struct and then ends up falling through to the handling of another event type, PERF_EVENT_UPDATE__CPUS were it casts that ev->data to yet another type, oops, fix it by inserting the missing break. Noticed when building perf using gcc 7 on Fedora Rawhide: util/header.c: In function 'perf_event__process_event_update': util/header.c:3207:16: error: this statement may fall through [-Werror=implicit-fallthrough=] evsel->scale = ev_scale->scale; ~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~ util/header.c:3208:2: note: here case PERF_EVENT_UPDATE__CPUS: ^~~~ This wasn't noticed because probably PERF_EVENT_UPDATE__CPUS comes after PERF_EVENT_UPDATE__SCALE, so we would just create a bogus evsel->own_cpus when processing a PERF_EVENT_UPDATE__SCALE to then leak it and create a new cpu map with the correct data. Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: daeecbc0c431 ("perf tools: Add event_update event scale type") Link: http://lkml.kernel.org/n/tip-lukcf9hdj092ax2914ss95at@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf bench numa: Avoid possible truncation when using snprintf()Arnaldo Carvalho de Melo
commit 3aff8ba0a4c9c9191bb788171a1c54778e1246a2 upstream. Addressing this warning from gcc 7: CC /tmp/build/perf/bench/numa.o bench/numa.c: In function '__bench_numa': bench/numa.c:1582:42: error: '%d' directive output may be truncated writing between 1 and 10 bytes into a region of size between 8 and 17 [-Werror=format-truncation=] snprintf(tname, 32, "process%d:thread%d", p, t); ^~ bench/numa.c:1582:25: note: directive argument in the range [0, 2147483647] snprintf(tname, 32, "process%d:thread%d", p, t); ^~~~~~~~~~~~~~~~~~~~ In file included from /usr/include/stdio.h:939:0, from bench/../util/util.h:47, from bench/../builtin.h:4, from bench/numa.c:11: /usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 17 and 35 bytes into a destination of size 32 return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cc1: all warnings being treated as errors Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Petr Holasek <pholasek@redhat.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-twa37vsfqcie5gwpqwnjuuz9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf tests: Avoid possible truncation with dirent->d_name + snprintfArnaldo Carvalho de Melo
commit 2e2bbc039fad9eabad6c4c1a473c8b2554cdd2d4 upstream. Addressing a few cases spotted by a new warning in gcc 7: tests/parse-events.c: In function 'test_pmu_events': tests/parse-events.c:1790:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 90 [-Werror=format-truncation=] snprintf(name, MAX_NAME, "cpu/event=%s/u", ent->d_name); ^~ In file included from /usr/include/stdio.h:939:0, from /git/linux/tools/perf/util/map.h:9, from /git/linux/tools/perf/util/symbol.h:7, from /git/linux/tools/perf/util/evsel.h:10, from tests/parse-events.c:3: /usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 13 and 268 bytes into a destination of size 100 return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ tests/parse-events.c:1798:29: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 100 [-Werror=format-truncation=] snprintf(name, MAX_NAME, "%s:u,cpu/event=%s/u", ent->d_name, ent->d_name); Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 945aea220bb8 ("perf tests: Move test objects into 'tests' directory") Link: http://lkml.kernel.org/n/tip-ty4q2p8zp1dp3mskvubxskm5@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf intel-pt: Use __fallthroughArnaldo Carvalho de Melo
commit 7ea6856d6f5629d742edc23b8b76e6263371ef45 upstream. To address new warnings emmited by gcc 7, e.g.:: CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-pkt-decoder.o CC /tmp/build/perf/tests/parse-events.o util/intel-pt-decoder/intel-pt-pkt-decoder.c: In function 'intel_pt_pkt_desc': util/intel-pt-decoder/intel-pt-pkt-decoder.c:499:6: error: this statement may fall through [-Werror=implicit-fallthrough=] if (!(packet->count)) ^ util/intel-pt-decoder/intel-pt-pkt-decoder.c:501:2: note: here case INTEL_PT_CYC: ^~~~ CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-decoder.o cc1: all warnings being treated as errors Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-mf0hw789pu9x855us5l32c83@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf thread_map: Correctly size buffer used with dirent->dt_nameArnaldo Carvalho de Melo
commit bdf23a9a190d7ecea092fd5c4aabb7d4bd0a9980 upstream. The size of dirent->dt_name is NAME_MAX + 1, but the size for the 'path' buffer is hard coded at 256, which may truncate it because we also prepend "/proc/", so that all that into account and thank gcc 7 for this warning: /git/linux/tools/perf/util/thread_map.c: In function 'thread_map__new_by_uid': /git/linux/tools/perf/util/thread_map.c:119:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 250 [-Werror=format-truncation=] snprintf(path, sizeof(path), "/proc/%s", dirent->d_name); ^~ In file included from /usr/include/stdio.h:939:0, from /git/linux/tools/perf/util/thread_map.c:5: /usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 7 and 262 bytes into a destination of size 256 return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-csy0r8zrvz5efccgd4k12c82@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15perf top: Use __fallthroughArnaldo Carvalho de Melo
commit 7b0214b702ad8e124e039a317beeebb3f020d125 upstream. The implicit fall through case label here is intended, so let us inform that to gcc >= 7: CC /tmp/build/perf/builtin-top.o builtin-top.c: In function 'display_thread': builtin-top.c:644:7: error: this statement may fall through [-Werror=implicit-fallthrough=] if (errno == EINTR) ^ builtin-top.c:647:3: note: here default: ^~~~~~~ Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-lmcfnnyx9ic0m6j0aud98p4e@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15tools strfilter: Use __fallthroughArnaldo Carvalho de Melo
commit d64b721d27aef3fbeb16ecda9dd22ee34818ff70 upstream. The implicit fall through case label here is intended, so let us inform that to gcc >= 7: util/strfilter.c: In function 'strfilter_node__sprint': util/strfilter.c:270:6: error: this statement may fall through [-Werror=implicit-fallthrough=] if (len < 0) ^ util/strfilter.c:272:2: note: here case '!': ^~~~ cc1: all warnings being treated as errors Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-z2dpywg7u8fim000hjfbpyfm@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15tools string: Use __fallthrough in perf_atoll()Arnaldo Carvalho de Melo
commit 94bdd5edb34e472980d1e18b4600d6fb92bd6b0a upstream. The implicit fall through case label here is intended, so let us inform that to gcc >= 7: CC /tmp/build/perf/util/string.o util/string.c: In function 'perf_atoll': util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=] if (*p) ^ util/string.c:24:3: note: here case '\0': ^~~~ Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-0ophb30v9apkk6o95el0rqlq@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15tools include: Add a __fallthrough statementArnaldo Carvalho de Melo
commit b5bf1733d6a391c4e90ea8f8468d83023be74a2a upstream. For cases where implicit fall through case labels are intended, to let us inform that to gcc >= 7: CC /tmp/build/perf/util/string.o util/string.c: In function 'perf_atoll': util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=] if (*p) ^ util/string.c:24:3: note: here case '\0': ^~~~ So we introduce: #define __fallthrough __attribute__ ((fallthrough)) And use it in such cases. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Cc: William Cohen <wcohen@redhat.com> Link: http://lkml.kernel.org/n/tip-qnpig0xfop4hwv6k4mv1wts5@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05objtool: Fix another GCC jump table detection issueJosh Poimboeuf
commit 5c51f4ae84df0f9df33ac08aa5be50061a8b4242 upstream. Arnd Bergmann reported a (false positive) objtool warning: drivers/infiniband/sw/rxe/rxe_resp.o: warning: objtool: rxe_responder()+0xfe: sibling call from callable instruction with changed frame pointer The issue is in find_switch_table(). It tries to find a switch statement's jump table by walking backwards from an indirect jump instruction, looking for a relocation to the .rodata section. In this case it stopped walking prematurely: the first .rodata relocation it encountered was for a variable (resp_state_name) instead of a jump table, so it just assumed there wasn't a jump table. The fix is to ignore any .rodata relocation which refers to an ELF object symbol. This works because the jump tables are anonymous and have no symbols associated with them. Reported-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 3732710ff6f2 ("objtool: Improve rare switch jump table pattern detection") Link: http://lkml.kernel.org/r/20170302225723.3ndbsnl4hkqbne7a@treble Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05tools arch: Sync arch/x86/lib/memcpy_64.S with the kernelArnaldo Carvalho de Melo
commit e883d09c9eb2ffddfd057c17e6a0cef446ec8c9b upstream. Just a minor fix done in: Fixes: 26a37ab319a2 ("x86/mce: Fix copy/paste error in exception table entries") Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/n/tip-ni9jzdd5yxlail6pq8cuexw2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05perf probe: Fix to probe on gcc generated functions in modulesMasami Hiramatsu
[ Upstream commit 613f050d68a8ed3c0b18b9568698908ef7bbc1f7 ] Fix to probe on gcc generated functions on modules. Since probing on a module is based on its symbol name, it should be adjusted on actual symbols. E.g. without this fix, perf probe shows probe definition on non-exist symbol as below. $ perf probe -m build-x86_64/net/netfilter/nf_nat.ko -F in_range* in_range.isra.12 $ perf probe -m build-x86_64/net/netfilter/nf_nat.ko -D in_range p:probe/in_range nf_nat:in_range+0 With this fix, perf probe correctly shows a probe on gcc-generated symbol. $ perf probe -m build-x86_64/net/netfilter/nf_nat.ko -D in_range p:probe/in_range nf_nat:in_range.isra.12+0 This also fixes same problem on online module as below. $ perf probe -m i915 -D assert_plane p:probe/assert_plane i915:assert_plane.constprop.134+0 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148411450673.9978.14905987549651656075.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05perf probe: Fix to show correct locations for events on modulesMasami Hiramatsu
[ Upstream commit d2d4edbebe07ddb77980656abe7b9bc7a9e0cdf7 ] Fix to show correct locations for events on modules by relocating given address instead of retrying after failure. This happens when the module text size is big enough, bigger than sh_addr, because the original code retries with given address + sh_addr if it failed to find CU DIE at the given address. Any address smaller than sh_addr always fails and it retries with the correct address, but addresses bigger than sh_addr will get a CU DIE which is on the given address (not adjusted by sh_addr). In my environment(x86-64), the sh_addr of ".text" section is 0x10030. Since i915 is a huge kernel module, we can see this issue as below. $ grep "[Tt] .*\[i915\]" /proc/kallsyms | sort | head -n1 ffffffffc0270000 t i915_switcheroo_can_switch [i915] ffffffffc0270000 + 0x10030 = ffffffffc0280030, so we'll check symbols cross this boundary. $ grep "[Tt] .*\[i915\]" /proc/kallsyms | grep -B1 ^ffffffffc028\ | head -n 2 ffffffffc027ff80 t haswell_init_clock_gating [i915] ffffffffc0280110 t valleyview_init_clock_gating [i915] So setup probes on both function and see what happen. $ sudo ./perf probe -m i915 -a haswell_init_clock_gating \ -a valleyview_init_clock_gating Added new events: probe:haswell_init_clock_gating (on haswell_init_clock_gating in i915) probe:valleyview_init_clock_gating (on valleyview_init_clock_gating in i915) You can now use it in all perf tools, such as: perf record -e probe:valleyview_init_clock_gating -aR sleep 1 $ sudo ./perf probe -l probe:haswell_init_clock_gating (on haswell_init_clock_gating@gpu/drm/i915/intel_pm.c in i915) probe:valleyview_init_clock_gating (on i915_vga_set_decode:4@gpu/drm/i915/i915_drv.c in i915) As you can see, haswell_init_clock_gating is correctly shown, but valleyview_init_clock_gating is not. With this patch, both events are shown correctly. $ sudo ./perf probe -l probe:haswell_init_clock_gating (on haswell_init_clock_gating@gpu/drm/i915/intel_pm.c in i915) probe:valleyview_init_clock_gating (on valleyview_init_clock_gating@gpu/drm/i915/intel_pm.c in i915) Committer notes: In my case: # perf probe -m i915 -a haswell_init_clock_gating -a valleyview_init_clock_gating Added new events: probe:haswell_init_clock_gating (on haswell_init_clock_gating in i915) probe:valleyview_init_clock_gating (on valleyview_init_clock_gating in i915) You can now use it in all perf tools, such as: perf record -e probe:valleyview_init_clock_gating -aR sleep 1 # perf probe -l probe:haswell_init_clock_gating (on i915_getparam+432@gpu/drm/i915/i915_drv.c in i915) probe:valleyview_init_clock_gating (on __i915_printk+240@gpu/drm/i915/i915_drv.c in i915) # # readelf -SW /lib/modules/4.9.0+/build/vmlinux | egrep -w '.text|Name' [Nr] Name Type Address Off Size ES Flg Lk Inf Al [ 1] .text PROGBITS ffffffff81000000 200000 822fd3 00 AX 0 0 4096 # So both are b0rked, now with the fix: # perf probe -m i915 -a haswell_init_clock_gating -a valleyview_init_clock_gating Added new events: probe:haswell_init_clock_gating (on haswell_init_clock_gating in i915) probe:valleyview_init_clock_gating (on valleyview_init_clock_gating in i915) You can now use it in all perf tools, such as: perf record -e probe:valleyview_init_clock_gating -aR sleep 1 # perf probe -l probe:haswell_init_clock_gating (on haswell_init_clock_gating@gpu/drm/i915/intel_pm.c in i915) probe:valleyview_init_clock_gating (on valleyview_init_clock_gating@gpu/drm/i915/intel_pm.c in i915) # Both looks correct. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148411436777.9978.1440275861947194930.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05objtool: Fix IRET's opcodeJiri Slaby
[ Upstream commit b5b46c4740aed1538544f0fa849c5b76c7823469 ] The IRET opcode is 0xcf according to the Intel manual and also to objdump of my vmlinux: 1ea8: 48 cf iretq Fix the opcode in arch_decode_instruction(). The previous value (0xc5) seems to correspond to LDS. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170118132921.19319-1-jslaby@suse.cz Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20perf auxtrace: Fix no_size logic in addr_filter__resolve_kernel_syms()Adrian Hunter
commit c3a0bbc7ad7598dec5a204868bdf8a2b1b51df14 upstream. Address filtering with kernel symbols incorrectly resulted in the error "Cannot determine size of symbol" because the no_size logic was the wrong way around. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1490357752-27942-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20selftests/x86/ldt_gdt_32: Work around a glibc sigaction() bugAndy Lutomirski
commit 65973dd3fd31151823f4b8c289eebbb3fb7e6bc0 upstream. i386 glibc is buggy and calls the sigaction syscall incorrectly. This is asymptomatic for normal programs, but it blows up on programs that do evil things with segmentation. The ldt_gdt self-test is an example of such an evil program. This doesn't appear to be a regression -- I think I just got lucky with the uninitialized memory that glibc threw at the kernel when I wrote the test. This hackish fix manually issues sigaction(2) syscalls to undo the damage. Without the fix, ldt_gdt_32 segfaults; with the fix, it passes for me. See: https://sourceware.org/bugzilla/show_bug.cgi?id=21269 Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/aaab0f9f93c9af25396f01232608c163a760a668.1490218061.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14x86/mpx: Re-add MPX to selftests MakefileDave Hansen
commit e64d5fbe56259c94df504af8ce804cfc6a022adb upstream. Ingo pointed out that the MPX tests were no longer in the selftests Makefile. It appears that I shot myself in the foot on this one and accidentally removed them when I added the pkeys tests, probably from bungling a merge conflict. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 5f23f6d082a9 ("x86/pkeys: Add self-tests") Link: http://lkml.kernel.org/r/20170201225629.C3070852@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14cpupower: Fix turbo frequency reporting for pre-Sandy Bridge coresBen Hutchings
commit 4cca0457686e4ee1677d69469e4ddfd94d389a80 upstream. The switch that conditionally sets CPUPOWER_CAP_HAS_TURBO_RATIO and CPUPOWER_CAP_IS_SNB flags is missing a break, so all cores get both flags set and an assumed base clock of 100 MHz for turbo values. Reported-by: GSR <gsr.bugs@infernal-iceberg.com> Tested-by: GSR <gsr.bugs@infernal-iceberg.com> References: https://bugs.debian.org/859978 Fixes: 8fb2e440b223 (cpupower: Show Intel turbo ratio support via ...) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26give up on gcc ilog2() constant optimizationsLinus Torvalds
commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c upstream. gcc-7 has an "optimization" pass that completely screws up, and generates the code expansion for the (impossible) case of calling ilog2() with a zero constant, even when the code gcc compiles does not actually have a zero constant. And we try to generate a compile-time error for anybody doing ilog2() on a constant where that doesn't make sense (be it zero or negative). So now gcc7 will fail the build due to our sanity checking, because it created that constant-zero case that didn't actually exist in the source code. There's a whole long discussion on the kernel mailing about how to work around this gcc bug. The gcc people themselevs have discussed their "feature" in https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785 but it's all water under the bridge, because while it looked at one point like it would be solved by the time gcc7 was released, that was not to be. So now we have to deal with this compiler braindamage. And the only simple approach seems to be to just delete the code that tries to warn about bad uses of ilog2(). So now "ilog2()" will just return 0 not just for the value 1, but for any non-positive value too. It's not like I can recall anybody having ever actually tried to use this function on any invalid value, but maybe the sanity check just meant that such code never made it out in public. Reported-by: Laura Abbott <labbott@redhat.com> Cc: John Stultz <john.stultz@linaro.org>, Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-15ktest: Fix child exit code processingSteven Rostedt (VMware)
commit 32677207dcc5e594254b7fb4fb2352b1755b1d5b upstream. The child_exit errno needs to be shifted by 8 bits to compare against the return values for the bisect variables. Fixes: c5dacb88f0a64 ("ktest: Allow overriding bisect test results") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12perf callchain: Reference count mapsKrister Johansen
commit aa33b9b9a2ebb00d33c83a5312d4fbf2d5aeba36 upstream. If dso__load_kcore frees all of the existing maps, but one has already been attached to a callchain cursor node, then we can get a SIGSEGV in any function that happens to try to use this invalid cursor. Use the existing map refcount mechanism to forestall cleanup of a map until the cursor iterates past the node. Signed-off-by: Krister Johansen <kjlx@templeofstupid.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Fixes: 84c2cafa2889 ("perf tools: Reference count struct map") Link: http://lkml.kernel.org/r/20170106062331.GB2707@templeofstupid.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14perf diff: Fix segfault on 'perf diff -o N' optionNamhyung Kim
commit 8381cdd0e32dd748bd34ca3ace476949948bd793 upstream. The -o/--order option is to select column number to sort a diff result. It does the job by adding a hpp field at the beginning of the sort list. But it should not be added to the output field list as it has no callbacks required by a output field. During the setup_sorting(), the perf_hpp__setup_output_field() appends the given sort keys to the output field if it's not there already. Originally it was checked by fmt->list being non-empty. But commit 3f931f2c4274 ("perf hists: Make hpp setup function generic") changed it to check the ->equal callback. Anyways, we don't need to add the pseudo hpp field to the output field list since it won't be used for output. So just skip fields if they have no ->color or ->entry callbacks. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 3f931f2c4274 ("perf hists: Make hpp setup function generic") Link: http://lkml.kernel.org/r/20170118051457.30946-1-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14perf diff: Fix -o/--order option behavior (again)Namhyung Kim
commit a1c9f97f0b64e6337d9cfcc08c134450934fdd90 upstream. Commit 21e6d8428664 ("perf diff: Use perf_hpp__register_sort_field interface") changed list_add() to perf_hpp__register_sort_field(). This resulted in a behavior change since the field was added to the tail instead of the head. So the -o option is mostly ignored due to its order in the list. This patch fixes it by adding perf_hpp__prepend_sort_field(). Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 21e6d8428664 ("perf diff: Use perf_hpp__register_sort_field interface") Link: http://lkml.kernel.org/r/20170118051457.30946-2-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26tools/virtio/ringtest: fix run-on-all.sh for offline cpusHalil Pasic
commit 21f5eda9b8671744539c8295b9df62991fffb2ce upstream. Since ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work without /dev/cpu") run-on-all.sh uses seq 0 $HOST_AFFINITY as the list of ids of the CPUs to run the command on (assuming ids of online CPUs are consecutive and start from 0), where $HOST_AFFINITY is the highest CPU id in the system previously determined using lscpu. This can fail on systems with offline CPUs. Instead let's use lscpu to determine the list of online CPUs. Signed-off-by: Halil Pasic <pasic@linux.vnet.ibm.com> Fixes: ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work without /dev/cpu") Reviewed-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26selftest/powerpc: Wrong PMC initialized in pmc56_overflow testMadhavan Srinivasan
commit df21d2fa733035e4d414379960f94b2516b41296 upstream. Test uses PMC2 to count the event. But PMC1 is being initialized. Patch to fix it. Fixes: 3752e453f6ba ('selftests/powerpc: Add tests of PMU EBBs') Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26perf jit: Enable jitdump support without dwarfMaciej Debski
commit 621cb4e7837e39d25a5af5a785ad282cdd2b4ce8 upstream. This patch modifies the build dependencies on the jitdump support in perf. As it stands jitdump was wrongfully made dependent 100% on using DWARF. However, the dwarf dependency, only exist if generating the source line table in genelf_debug.c. The rest of the support does not need DWARF. This patch removes the dependency on DWARF for the entire jitdump support. It keeps it only for the genelf_debug.c support. Signed-off-by: Maciej Debski <maciejd@google.com> Reviewed-by: Stephane Eranian <eranian@google.com> Cc: Anton Blanchard <anton@ozlabs.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1476356383-30100-3-git-send-email-eranian@google.com Fixes: e12b202f8fb9 ("perf jitdump: Build only on supported archs") [ Make it build only if NO_LIBELF isn't defined, as jitdump.o will only be built in that case ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26perf scripting: Avoid leaking the scripting_context variableArnaldo Carvalho de Melo
commit cf346d5bd4b9d61656df2f72565c9b354ef3ca0d upstream. Both register_perl_scripting() and register_python_scripting() allocate this variable, fix it by checking if it already was. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 7e4b21b84c43 ("perf/scripts: Add Python scripting engine") Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
