path: root/tools
2014-10-21ACPICA: acpiexec: Do not put STDIN into raw mode unless it is a terminal.Bob Moore
Eliminate an error message for batch-mode processing on unix systems. ACPICA BZ 1114. This patch is mainly for fixing the issues of acpiexec which is not in the Linux upstream. Link: https://bugs.acpica.org/show_bug.cgi?id=1114 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-21ACPICA: acpidump: Add ACPI 1.0 RSDP support.Lv Zheng
The acpidump currently always uses ACPI 2.0 format to dump RSDP, this patch adds ACPI 1.0 RSDP support. Link: https://bugs.acpica.org/show_bug.cgi?id=1097 Link: https://bugs.acpica.org/show_bug.cgi?id=1103 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Reported-and-tested-by: Rudolf Marek <r.marek@assembler.cz> Reported-and-tested-by: Rafal <fatwildcat@gmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-17perf script: Add period as a default output columnJiri Olsa
Adding period as a default output column in script command fo hardware, software and raw events. If PERF_SAMPLE_PERIOD sample type is defined in perf.data, following will be displayed in perf script output: $ perf script ls 8034 57477.887209: 250000 task-clock: ffffffff81361d72 memset ([kernel.kallsyms]) ls 8034 57477.887464: 250000 task-clock: ffffffff816f6d92 _raw_spin_unlock_irqrestore ([kernel.kallsyms]) ls 8034 57477.887708: 250000 task-clock: ffffffff811a94f0 do_munmap ([kernel.kallsyms]) ls 8034 57477.887959: 250000 task-clock: 34080916c6 get_next_seq (/usr/lib64/libc-2.17.so) ls 8034 57477.888208: 250000 task-clock: 3408079230 _IO_doallocbuf (/usr/lib64/libc-2.17.so) ls 8034 57477.888717: 250000 task-clock: ffffffff814242c8 n_tty_write ([kernel.kallsyms]) ls 8034 57477.889285: 250000 task-clock: 3408076402 fwrite_unlocked (/usr/lib64/libc-2.17.so) Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: "Jen-Cheng(Tommy) Huang" <tommy24@gatech.edu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jen-Cheng(Tommy) Huang <tommy24@gatech.edu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1408977943-16594-10-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf script: Add period data columnJiri Olsa
Adding period data column to be displayed in perf script. It's possible to get period values using -f option, like: $ perf script -f comm,tid,time,period,ip,sym,dso :26019 26019 52414.329088: 3707 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329088: 44 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329093: 1987 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329093: 6 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) ls 26019 52414.329442: 537558 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so) ls 26019 52414.329442: 2099 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so) ls 26019 52414.330181: 1242100 34080917bb get_next_seq (/usr/lib64/libc-2.17.so) ls 26019 52414.330181: 3774 34080917bb get_next_seq (/usr/lib64/libc-2.17.so) ls 26019 52414.331427: 1083662 ffffffff810c7dc2 update_curr ([kernel.kallsyms]) ls 26019 52414.331427: 360 ffffffff810c7dc2 update_curr ([kernel.kallsyms]) Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: "Jen-Cheng(Tommy) Huang" <tommy24@gatech.edu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jen-Cheng(Tommy) Huang <tommy24@gatech.edu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1408977943-16594-9-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evsel: No need to drag util/cgroup.hArnaldo Carvalho de Melo
The only thing we need is a forward declaration for 'struct cgroup_sel', that is inside 'struct perf_evsel'. Include cgroup.h instead on the tools that support cgroups. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-b7kuymbgf0zxi5viyjjtu5hk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evlist: Add missing 'struct option' forward declarationArnaldo Carvalho de Melo
It was being found, by chance, because evsel.h needlessly includes util/cgroup.h, which will be sorted out in a following patch. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xsvxr747wkkpg1ay9dramorr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evsel: Move exit stuff from __delete to __exitArnaldo Carvalho de Melo
So that when an evsel is embedded into other struct it can free up resources calling perf_evsel__exit(). Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-n1w68pfe9m2vkhm4sqs8y1en@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf kvm stat live: Enable events copyingAlexander Yarygin
Process of analyzing events caused by 2 functions: mmap_read() and finished_round(). During mmap_read(), perf receives events from shared memory, queues their pointers for further processing in finished_round() and notifies the kernel that the events have been processed. By the time when finished_round() is invoked, queued events can be overwritten by the kernel, so the finished_round() occurs on potentially corrupted memory. Since there is no place where the event can be safely consumed, let's copy events when queueing. Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1412347212-28237-3-git-send-email-yarygin@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf session: Add option to copy events when queueingAlexander Yarygin
When processing events the session code has an ordered samples queue which is used to time-sort events coming in across multiple mmaps. At a later point in time samples on the queue are flushed up to some timestamp at which point the event is actually processed. When analyzing events live (ie., record/analysis path in the same command) there is a race that leads to corrupted events and parse errors which cause perf to terminate. The problem is that when the event is placed in the ordered samples queue it is only a reference to the event which is really sitting in the mmap buffer. Even though the event is queued for later processing the mmap tail pointer is updated which indicates to the kernel that the event has been processed. The race is flushing the event from the queue before it gets overwritten by some other event. For commands trying to process events live (versus just writing to a file) and processing a high rate of events this leads to parse failures and perf terminates. Examples hitting this problem are 'perf kvm stat live', especially with nested VMs which generate 100,000+ traces per second, and a command processing scheduling events with a high rate of context switching -- e.g., running 'perf bench sched pipe'. This patch offers live commands an option to copy the event when it is placed in the ordered samples queue. Based on a patch from David Ahern <dsahern@gmail.com> Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1412347212-28237-2-git-send-email-yarygin@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf Documentation: Fix typos in perf/DocumentationMasanari Iida
This patch fix spelling typos found in tool/perf/Documentation. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Randy Dunlap <rdunlap@infradead.org> Link: http://lkml.kernel.org/r/1410275930-17207-1-git-send-email-standby24x7@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf trace: Use thread_{,_set}_priv helpersNamhyung Kim
This is mechanical changes only for accounting access to thread->priv properly in the source level. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf kvm: Use thread_{,_set}_priv helpersNamhyung Kim
This is mechanical changes only for accounting access to thread->priv properly in the source level. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf callchain: Create an address space per threadNamhyung Kim
The unw_addr_space_t in libunwind represents an address space to be used for stack unwinding. It doesn't need to be create/destory everytime to unwind callchain (as in get_entries) and can have a same lifetime as thread (unless exec called). So move the address space construction/destruction logic to the thread lifetime handling functions. This is a preparation to enable caching in the unwind library. Note that it saves unw_addr_space_t object using thread__set_priv(). It seems currently only used by perf trace and perf kvm stat commands which don't use callchain. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jean Pihet <jean.pihet@linaro.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Arun Sharma <asharma@fb.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-3-git-send-email-namhyung@kernel.org [ Fixup unwind-libunwind.c missing CALLCHAIN_DWARF definition, added missing __maybe_unused on unused parameters in stubs at util/unwind.h ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf report: Set callchain_param.record_mode for future useNamhyung Kim
Normally the callchain_param.record_mode is used only for record path. But as it might need to prepare something for dwarf unwinding, setup this info for perf report too. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf evlist: Fix for double free in tools/perf statYasser Shalabi
Fix for double free bug in tools/perf due to dangling thread_map pointer in perf_evlist struct. Code path excercised when perf stat -C switch is used but not set and is followed by another switch. Example: perf stat -C -e. Signed-off-by: Yasser Shalabi <yassershalabi@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412437077-13109-1-git-send-email-yassershalabi@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf test: Add test case for pmu event new style formatKan Liang
Add test case in automated tests suite. It checks not only the two types of pmu event stytle formats "pmu_event_name" and "cpu/pmu_event_name/", but also the different formats mixtures which are more likely to trigger parse issue. The patch set including this one has been tested by the perf automated test: ./perf test parse -v" On haswell, ivybridge and Romley platform. The patch set also has been tested on haswell by the following script. Note: please make sure that your test system support TSX and L1-dcache-loads events. Otherwise, you may want to change the events to other pmu events. [lk@localhost ~]$ cat perf_style_test.sh # hardware events + kernel pmu event with different style perf stat -x, -e cycles,mem-stores,tx-start sleep 2 perf stat -x, -e cpu-cycles,cycles-ct,cycles-t sleep 2 perf stat -x, -e cycles,cpu/cycles-ct/,cpu/cycles-t/ sleep 2 perf stat -x, -e instructions,cpu/tx-start/ sleep 2 perf stat -x, -e '{cycles,tx-start}' sleep 2 perf stat -x, -e '{cycles,cpu/tx-start/}' sleep 2 # HW Cache event + kernel pmu event with different style perf stat -x, -e L1-dcache-loads,cpu/mem-stores/,tx-start sleep 2 perf stat -x, -e L1-dcache-loads,mem-stores,cpu/tx-start/ sleep 2 perf stat -x, -e '{L1-dcache-loads,mem-stores}' sleep 2 perf stat -x, -e '{L1-dcache-loads,cpu/tx-start/}' sleep 2 # Raw event + kernel pmu event with different style: perf stat -x, -e cpu/event=0xc0,umask=0x00/,mem-loads,cpu/mem-stores/ sleep 2 perf stat -x, -e cpu/event=0xc0,umask=0x00/,tx-start,cpu/el-start/ sleep 2 perf stat -x, -e '{cpu/event=0xc0,umask=0x00/,tx-start}' sleep 2 Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-5-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf tools: Add support to new style format of kernel PMU eventKan Liang
Add new rules for kernel PMU event. Currently, the patch only want to handle the PMU event name as "a-b" and "a". event_pmu: PE_KERNEL_PMU_EVENT sep_dc | PE_PMU_EVENT_PRE '-' PE_PMU_EVENT_SUF sep_dc PE_KERNEL_PMU_EVENT token is for cycles-ct/cycles-t/mem-loads/mem-stores. The prefix cycles is mixed up with cpu-cycles. loads and stores are mixed up with cache event So they have to be hardcode in lex. PE_PMU_EVENT_PRE and PE_PMU_EVENT_SUF tokens are for other PMU events. The lex looks generic identifier up in the table and return the matched token. If there is no match, generic PE_NAME token will be return. Using the rules, kernel PMU event could use new style format without // so you can use: perf record -e mem-loads ... instead of: perf record -e cpu/mem-loads/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-4-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf tools: Parse the pmu event prefix and suffixKan Liang
There are two types of event formats for PMU events. E.g. el-abort OR cpu/el-abort/. However, the lexer mistakenly recognizes the simple style format as two events. The parse_events_pmu_check function uses bsearch to search the name in known pmu event list. It can tell the lexer that the name is a PE_NAME or a PMU event name prefix or a PMU event name suffix. All these information will be used for accurately parsing kernel PMU events. The pmu events list will be read from sysfs at runtime. Note: Currently, the patch only want to handle the PMU event name as "a-b" and "a". The only exception, "stalled-cycles-frontend" and "stalled-cycles-fronted", are already hardcoded in lexer. Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-3-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15Revert "perf tools: Default to cpu// for events v5"Kan Liang
This reverts commit 50e200f07948 ("perf tools: Default to cpu// for events v5") The fixup cannot handle the case that new style format(which without //) mixed with other different formats. For example, group events with new style format: {mem-stores,mem-loads} some hardware event + new style event: cycles,mem-loads Cache event + new style event: LLC-loads,mem-loads Raw event + new style event: cpu/event=0xc8,umask=0x08/,mem-loads old style event and new stytle mixture: mem-stores,cpu/mem-loads/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-2-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf top: Add a visual cue for toggle zeroing of samplesTaeung Song
When 'perf top' is run, one can't easily find a difference between -z option and normal output. So I added a visual cue to know whether it is the zeroing or not. Output is as below. Before: $ perf top Samples: 61K of event 'cycles', Event count (approx.): 3908136933 Overhead Shared Object Symbol 1.42% firefox [.] 0x0000000000011e76 1.32% libpthread-2.17.so [.] pthread_mutex_lock If you press key 'z' or run with zero option like '$ perf top --zero', it is as below. After: Samples: 61K of event 'cycles', Event count (approx.): 3908136933 [z] Overhead Shared Object Symbol 1.42% firefox [.] 0x0000000000011e76 1.32% libpthread-2.17.so [.] pthread_mutex_lock Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1412665995-26359-1-git-send-email-treeze.taeung@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: Infrastructure fixes and changes: * Fix off-by-one bugs in map->end handling (Stephane Eranian) * Fix off-by-one bug in maps__find(), also related to map->end handling (Namhyung Kim) * Make struct symbol->end be the first addr after the symbol range, to make it match the convention used for struct map->end. (Arnaldo Carvalho de Melo) * Fix perf_evlist__add_pollfd() error handling in 'perf kvm stat live' (Jiri Olsa) * Fix python test build by moving callchain_param to an object linked into the python binding (Jiri Olsa) * Do not include a struct hists per perf_evsel, untangling the histogram code from perf_evsel, to pave the way for exporting a minimalistic tools/lib/api/perf/ library usable by tools/perf and initially by the rasd daemon being developed by Borislav Petkov, Robert Richter and Jean Pihet. (Arnaldo Carvalho de Melo) * Make perf_evlist__open(evlist, NULL, NULL), i.e. without cpu and thread maps mean syswide monitoring, reducing the boilerplate for tools that only want system wide mode. (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-14perf symbols: Make sym->end be the first address after the symbol rangeArnaldo Carvalho de Melo
To follow vm_area_struct->vm_end convention. By adhering to the convention that ->end is the first address outside the symbol's range we can do things like: sym->end = start + len; len = sym->end - sym->start; This is also now the convention used for struct map->end, fixing some off-by-one bugs. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-agomujr7tuqaq6lu7kr6z7h6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf symbols: Fix map->end fixupArnaldo Carvalho de Melo
When synthesizing maps from files that have incomplete symbol information, like kallsyms, we need to fixup the end of maps by seting its end from the ->start of the next map, fix it to set prev_map->end to curr_map->start, since ->end is the first byte outside prev_map address range. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ivbrj08sjakxdwkrcndbkoig@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf tools: Fixup off-by-one comparision in maps__findNamhyung Kim
map->end is the first addr _outside_ the a map, following the convention of vm_area_struct->vm_end. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/8761fwh1nc.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf tools: fix off-by-one error in mapsStephane Eranian
This patch fixes off-by-one errors in the management of maps. A map is defined by start address and length as implemented by map__new(): map__init(map, type, start, start + len, pgoff, dso); map->start = addr; map->end = end; Consequently, the actual address range is [start; end[ map->end is the first byte outside the range. This patch fixes two bugs where upper bound checking was off-by-one. In V2, we fix map_groups__fixup_overlappings() some more where map->start was off-by-one as reported by Jiri. Signed-off-by: Stephane Eranian <eranian@google.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20141006083532.GA4850@quad Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf machine: Add missing dsos->root rbtree root initializationArnaldo Carvalho de Melo
A segfault happens on 'perf test hists_link' because we end up using a struct machines on the stack, and then machines__init() was not initializing the newly introduced rb_root, just the existing list_head. When we introduced struct dsos, to group the two ways to store dsos, i.e. the linked list and the rbtree, we didn't turned the initialization done in: machines__init(machines->host) -> machine__init() -> INIT_LIST_HEAD into a dsos__init() to keep on initializing the list_head but _as well_ initializing the rb_root, oops. All worked because outside perf-test we probably zalloc the whole thing which ends up initializing it in to NULL. So the problem looks contained to 'perf test' that uses it on stack, etc. Reported-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Waiman Long <Waiman.Long@hp.com>, Cc: Adrian Hunter <adrian.hunter@intel.com>, Cc: Don Zickus <dzickus@redhat.com> Cc: Douglas Hatch <doug.hatch@hp.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Waiman Long <Waiman.Long@hp.com>, Link: http://lkml.kernel.org/r/20141014180353.GF3198@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf evsel: Make some exit routines staticArnaldo Carvalho de Melo
Since they are automatically called by other methods used by tools. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ne3g4any7q6ty5d6yv8t1wws@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf evsel: Add missing 'target' struct forward declarationArnaldo Carvalho de Melo
We use it in evsel.h but were getting it indirectly, fix it. Noticed while working on having evsel.h usable by rasd.c. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-94t3jvw4tmzrq3dnovvpl65e@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf evlist: Default to syswide target when no thread/cpu maps setArnaldo Carvalho de Melo
If all a tool wants is to do system wide event monitoring, there is no more the need to setup thread_map and cpu_map objects, just call perf_evlist__open() and it will do create one fd per CPU monitoring all threads. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-poovolkigu72brx4783uq4cf@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf evlist: Check that there is a thread_map when preparing a workloadArnaldo Carvalho de Melo
The perf_evlist__prepare_workload expects a thread map to be in place so that it can store the pid of the workload being started, so check it and tell the developer about it instead of segfaulting. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-jvlz2f264e7kpmhjmwltikqw@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf thread_map: Create dummy constructor out of open coded equivalentArnaldo Carvalho de Melo
Create a dummy thread_map, one that has just one entry and it is -1, meaning 'all threads', as this ends up going down to perf_event_open(). Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-8av26cz8uxmbnihl5mmrygp9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf tools: Remove hists from evselArnaldo Carvalho de Melo
Now tools that deals want to have an hists per evsel need to call hists__init() before creating any evsels, which can be as early as when parsing the command line, so do it before calling parse_options(). The current tools using hists/hist_entries are report, top and annotate, change them to request per evsel hists. This is in preparation for making evsels usable by 3rd party tools, that not necessarily live in perf's source code repository. Acked-by: Borislav Petkov <bp@suse.de> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-usjx2la743f10ippj7p1b20x@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf callchain: Move the callchain_param extern to callchain.hArnaldo Carvalho de Melo
It was lost in hist.h, move it to where it belongs, callchain.h, as there are places that gets hist.h by means of evsel.h, and since evsel.h is being untangled from hist.h... Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-0rg7ji1jnbm6q6gj35j37jby@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf evsel: SubclassingArnaldo Carvalho de Melo
Provide a method to be called at tool start to config the perf_evsel instance size, together with optional constructor and destructor. This will be used so that perf_evsel doesn't always include a struct hists, tools that works with hists/hist_entries, like report, top and annotate, will, at start, tell the evsel class the size they need per instance. v2: Don't use exit as a name of a member of function parameter, as this breaks the build on at least fedora14 and rhel6. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-7t8cay0ieryox4gqosie85ek@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-14perf session: Remove last reference to hists structArnaldo Carvalho de Melo
Now perf_session doesn't require that the evsels in its evlist are hists containing ones. Tools that are hists based and want to do per evsel events_stats updates, if at some point this turns into a necessity, should do it in the tool specific code, keeping the session class hists agnostic. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-cli1bgwpo82mdikuhy3djsuy@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-13Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel side updates: - Fix and enhance poll support (Jiri Olsa) - Re-enable inheritance optimization (Jiri Olsa) - Enhance Intel memory events support (Stephane Eranian) - Refactor the Intel uncore driver to be more maintainable (Zheng Yan) - Enhance and fix Intel CPU and uncore PMU drivers (Peter Zijlstra, Andi Kleen) - [ plus various smaller fixes/cleanups ] User visible tooling updates: - Add +field argument support for --field option, so that one can add fields to the default list of fields to show, ie now one can just do: perf report --fields +pid And the pid will appear in addition to the default fields (Jiri Olsa) - Add +field argument support for --sort option (Jiri Olsa) - Honour -w in the report tools (report, top), allowing to specify the widths for the histogram entries columns (Namhyung Kim) - Properly show submicrosecond times in 'perf kvm stat' (Christian Borntraeger) - Add beautifier for mremap flags param in 'trace' (Alex Snast) - perf script: Allow callchains if any event samples them - Don't truncate Intel style addresses in 'annotate' (Alex Converse) - Allow profiling when kptr_restrict == 1 for non root users, kernel samples will just remain unresolved (Andi Kleen) - Allow configuring default options for callchains in config file (Namhyung Kim) - Support operations for shared futexes. (Davidlohr Bueso) - "perf kvm stat report" improvements by Alexander Yarygin: - Save pid string in opts.target.pid - Enable the target.system_wide flag - Unify the title bar output - [ plus lots of other fixes and small improvements. ] Tooling infrastructure changes: - Refactor unit and scale function parameters for PMU parsing routines (Matt Fleming) - Improve DSO long names lookup with rbtree, resulting in great speedup for workloads with lots of DSOs (Waiman Long) - We were not handling POLLHUP notifications for event file descriptors Fix it by filtering entries in the events file descriptor array after poll() returns, refcounting mmaps so that when the last fd pointing to a perf mmap goes away we do the unmap (Arnaldo Carvalho de Melo) - Intel PT prep work, from Adrian Hunter, including: - Let a user specify a PMU event without any config terms - Add perf-with-kcore script - Let default config be defined for a PMU - Add perf_pmu__scan_file() - Add a 'perf test' for tracking with sched_switch - Add 'flush' callback to scripting API - Use ring buffer consume method to look like other tools (Arnaldo Carvalho de Melo) - hists browser (used in top and report) refactorings, getting rid of unused variables and reducing source code size by handling similar cases in a fewer functions (Namhyung Kim). - Replace thread unsafe strerror() with strerror_r() accross the whole tools/perf/ tree (Masami Hiramatsu) - Rename ordered_samples to ordered_events and allow setting a queue size for ordering events (Jiri Olsa) - [ plus lots of fixes, cleanups and other improvements ]" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (198 commits) perf/x86: Tone down kernel messages when the PMU check fails in a virtual environment perf/x86/intel/uncore: Fix minor race in box set up perf record: Fix error message for --filter option not coming after tracepoint perf tools: Fix build breakage on arm64 targets perf symbols: Improve DSO long names lookup speed with rbtree perf symbols: Encapsulate dsos list head into struct dsos perf bench futex: Sanitize -q option in requeue perf bench futex: Support operations for shared futexes perf trace: Fix mmap return address truncation to 32-bit perf tools: Refactor unit and scale function parameters perf tools: Fix line number in the config file error message perf tools: Convert {record,top}.call-graph option to call-graph.record-mode perf tools: Introduce perf_callchain_config() perf callchain: Move some parser functions to callchain.c perf tools: Move callchain config from record_opts to callchain_param perf hists browser: Fix callchain print bug on TUI perf tools: Use ACCESS_ONCE() instead of volatile cast perf tools: Modify error code for when perf_session__new() fails perf tools: Fix perf record as non root with kptr_restrict == 1 perf stat: Fix --per-core on multi socket systems ...
2014-10-13Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle were: - changes related to No-CBs CPUs and NO_HZ_FULL - RCU-tasks implementation - torture-test updates - miscellaneous fixes - locktorture updates - RCU documentation updates" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (81 commits) workqueue: Use cond_resched_rcu_qs macro workqueue: Add quiescent state between work items locktorture: Cleanup header usage locktorture: Cannot hold read and write lock locktorture: Fix __acquire annotation for spinlock irq locktorture: Support rwlocks rcu: Eliminate deadlock between CPU hotplug and expedited grace periods locktorture: Document boot/module parameters rcutorture: Rename rcutorture_runnable parameter locktorture: Add test scenario for rwsem_lock locktorture: Add test scenario for mutex_lock locktorture: Make torture scripting account for new _runnable name locktorture: Introduce torture context locktorture: Support rwsems locktorture: Add infrastructure for torturing read locks torture: Address race in module cleanup locktorture: Make statistics generic locktorture: Teach about lock debugging locktorture: Support mutexes locktorture: Add documentation ...
2014-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The big thing in this pile is Eric's unmount-on-rmdir series; we finally have everything we need for that. The final piece of prereqs is delayed mntput() - now filesystem shutdown always happens on shallow stack. Other than that, we have several new primitives for iov_iter (Matt Wilcox, culled from his XIP-related series) pushing the conversion to ->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c cleanups and fixes (including the external name refcounting, which gives consistent behaviour of d_move() wrt procfs symlinks for long and short names alike) and assorted cleanups and fixes all over the place. This is just the first pile; there's a lot of stuff from various people that ought to go in this window. Starting with unionmount/overlayfs mess... ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits) fs/file_table.c: Update alloc_file() comment vfs: Deduplicate code shared by xattr system calls operating on paths reiserfs: remove pointless forward declaration of struct nameidata don't need that forward declaration of struct nameidata in dcache.h anymore take dname_external() into fs/dcache.c let path_init() failures treated the same way as subsequent link_path_walk() fix misuses of f_count() in ppp and netlink ncpfs: use list_for_each_entry() for d_subdirs walk vfs: move getname() from callers to do_mount() gfs2_atomic_open(): skip lookups on hashed dentry [infiniband] remove pointless assignments gadgetfs: saner API for gadgetfs_create_file() f_fs: saner API for ffs_sb_create_file() jfs: don't hash direct inode [s390] remove pointless assignment of ->f_op in vmlogrdr ->open() ecryptfs: ->f_op is never NULL android: ->f_op is never NULL nouveau: __iomem misannotations missing annotation in fs/file.c fs: namespace: suppress 'may be used uninitialized' warnings ...
2014-10-12Merge tag 'kselftest-3.18-updates-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: - fix for missing arguments to printf - fix to build failures on 32-bit systems. - enhancement to run memfd_test run on all architectures as most architectures support __NR_memfd_create * tag 'kselftest-3.18-updates-1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests/memfd: Run test on all architectures memfd_test: Add missing argument to printf() memfd_test: Make it work on 32-bit systems
2014-10-12Merge tag 'ftracetest-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace test code from Steven Rostedt: "This patch series starts a new selftests section in the tools/testing/selftest directory called "ftrace" that holds tests aimed at testing ftrace and subsystems that use ftrace (like kprobes). So far only a few tests were written (by Masami Hiramatsu), but more will be added in the near future (3.19)" * tag 'ftracetest-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/kprobes: Add selftest scripts testing kprobe-tracer as startup test ftracetest: Add POSIX.3 standard and XFAIL result codes ftracetest: Add kprobe basic testcases ftracetest: Add ftrace basic testcases ftracetest: Initial commit for ftracetest
2014-10-12Merge tag 'ktest-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest update from Steven Rostedt: "A fix and a clean up to ktest, as well as two small features. - A way to allow users to skip a manual bisect. - Allowing cherry picked patches to be tested. The cherry pick worked for a test I needed, but stressing it may not have all the desired effects. It doesn't cause any regressions so I kept it in" * tag 'ktest-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Don't bother with bisect good or bad on replay ktest: Fix check for new kernel success on rebooting to good kernel ktest: add ability to skip during BISECT_MANUAL ktest: Add PATCHCHECK_CHERRY
2014-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "Here's a first pull request for powerpc updates for 3.18. The bulk of the additions are for the "cxl" driver, for IBM's Coherent Accelerator Processor Interface (CAPI). Most of it's in drivers/misc, which Greg & Arnd maintain, Greg said he was happy for us to take it through our tree. There's the usual minor cleanups and fixes, including a bit of noise in drivers from some of those. A bunch of updates to our EEH code, which has been getting more testing. Several nice speedups from Anton, including 20% in clear_page(). And a bunch of updates for freescale from Scott" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (130 commits) cxl: Fix afu_read() not doing finish_wait() on signal or non-blocking cxl: Add documentation for userspace APIs cxl: Add driver to Kbuild and Makefiles cxl: Add userspace header file cxl: Driver code for powernv PCIe based cards for userspace access cxl: Add base builtin support powerpc/mm: Add hooks for cxl powerpc/opal: Add PHB to cxl mode call powerpc/mm: Add new hash_page_mm() powerpc/powerpc: Add new PCIe functions for allocating cxl interrupts cxl: Add new header for call backs and structs powerpc/powernv: Split out set MSI IRQ chip code powerpc/mm: Export mmu_kernel_ssize and mmu_linear_psize powerpc/msi: Improve IRQ bitmap allocator powerpc/cell: Make spu_flush_all_slbs() generic powerpc/cell: Move data segment faulting code out of cell platform powerpc/cell: Move spu_handle_mm_fault() out of cell platform powerpc/pseries: Use new defines when calling H_SET_MODE powerpc: Update contact info in Documentation files powerpc/perf/hv-24x7: Simplify catalog_read() ...
2014-10-10perf ui browsers: Add missing includeArnaldo Carvalho de Melo
This file needs the K_{RIGHT,etc} definitions but isn't including the file where they are defined, ui/keysyms.h, fix it. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-jlpybqegpdauzx64l9r1jgm3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-10perf tools: Move events_stats struct to event.hArnaldo Carvalho de Melo
This is the only bit of hist.h that session.[ch] will end up using, so move it out of hist.h to make that abundantly clear. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-l9ftsl21ggw0c1g2ig87otmd@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-10perf session: Don't count per evsel eventsArnaldo Carvalho de Melo
PERF_RECORD_SAMPLE was not being counted here and is the only per-evsel thing anyway, the other events were not mapping to a evsel. With this we don't require that evsels used with a perf_session need to have space for hists, like the ones in annotate, report, top. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-kzchpz0l1mhrsfpkirz086m2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-09selftests/vm/transhuge-stress: stress test for memory compactionKonstantin Khlebnikov
This tool induces memory fragmentation via sequential allocation of transparent huge pages and splitting off everything except their last sub-pages. It easily generates pressure to the memory compaction code. $ perf stat -e 'compaction:*' -e 'migrate:*' ./transhuge-stress transhuge-stress: allocate 7858 transhuge pages, using 15716 MiB virtual memory and 61 MiB of ram transhuge-stress: 1.653 s/loop, 0.210 ms/page, 9504.828 MiB/s 7858 succeed, 0 failed, 2439 different pages transhuge-stress: 1.537 s/loop, 0.196 ms/page, 10226.227 MiB/s 7858 succeed, 0 failed, 2364 different pages transhuge-stress: 1.658 s/loop, 0.211 ms/page, 9479.215 MiB/s 7858 succeed, 0 failed, 2179 different pages transhuge-stress: 1.617 s/loop, 0.206 ms/page, 9716.992 MiB/s 7858 succeed, 0 failed, 2421 different pages ^C./transhuge-stress: Interrupt Performance counter stats for './transhuge-stress': 1.744.051 compaction:mm_compaction_isolate_migratepages 1.014 compaction:mm_compaction_isolate_freepages 1.744.051 compaction:mm_compaction_migratepages 1.647 compaction:mm_compaction_begin 1.647 compaction:mm_compaction_end 1.744.051 migrate:mm_migrate_pages 0 migrate:mm_numa_migrate_ratelimit 7,964696835 seconds time elapsed Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: add vmstat counters and kpageflags bitKonstantin Khlebnikov
Always mark pages with PageBalloon even if balloon compaction is disabled and expose this mark in /proc/kpageflags as KPF_BALLOON. Also this patch adds three counters into /proc/vmstat: "balloon_inflate", "balloon_deflate" and "balloon_migrate". They accumulate balloon activity. Current size of balloon is (balloon_inflate - balloon_deflate) pages. All generic balloon code now gathered under option CONFIG_MEMORY_BALLOON. It should be selected by ballooning driver which wants use this feature. Currently virtio-balloon is the only user. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09perf evsel: Add hists helperArnaldo Carvalho de Melo
Not all tools need a hists instance per perf_evsel, so lets pave the way to remove evsel->hists while leaving a way to access the hists from a specially allocated evsel, one that comes with space at the end where lives the evsel. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qlktkhe31w4mgtbd84035sr2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-09perf script: Stop updating hists stats, not usedArnaldo Carvalho de Melo
Not used here, remove to reduce perf_evsel/hists structs interaction. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-zzmoo39yalrl9hzu9nc2xqml@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-09perf sched: Stop updating hists stats, not usedArnaldo Carvalho de Melo
Not used here, remove to reduce perf_evsel/hists structs interaction. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-cb7wkk4a3jpoovzim914ih3c@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
