commit 21f5eda9b8671744539c8295b9df62991fffb2ce upstream.
Since ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work
without /dev/cpu") run-on-all.sh uses seq 0 $HOST_AFFINITY as the list
of ids of the CPUs to run the command on (assuming ids of online CPUs
are consecutive and start from 0), where $HOST_AFFINITY is the highest
CPU id in the system previously determined using lscpu. This can fail
on systems with offline CPUs.
Instead let's use lscpu to determine the list of online CPUs.
Signed-off-by: Halil Pasic <pasic@linux.vnet.ibm.com>
Fixes: ef1b144d ("tools/virtio/ringtest: fix run-on-all.sh to work without
/dev/cpu")
Reviewed-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit df21d2fa733035e4d414379960f94b2516b41296 upstream.
Test uses PMC2 to count the event. But PMC1 is being initialized.
Patch to fix it.
Fixes: 3752e453f6ba ('selftests/powerpc: Add tests of PMU EBBs')
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
commit 621cb4e7837e39d25a5af5a785ad282cdd2b4ce8 upstream.
This patch modifies the build dependencies on the jitdump support in
perf. As it stands jitdump was wrongfully made dependent 100% on using
DWARF. However, the dwarf dependency, only exist if generating the
source line table in genelf_debug.c. The rest of the support does not
need DWARF.
This patch removes the dependency on DWARF for the entire jitdump
support. It keeps it only for the genelf_debug.c support.
Signed-off-by: Maciej Debski <maciejd@google.com>
Reviewed-by: Stephane Eranian <eranian@google.com>
Cc: Anton Blanchard <anton@ozlabs.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1476356383-30100-3-git-send-email-eranian@google.com
Fixes: e12b202f8fb9 ("perf jitdump: Build only on supported archs")
[ Make it build only if NO_LIBELF isn't defined, as jitdump.o will only be built in that case ]
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit cf346d5bd4b9d61656df2f72565c9b354ef3ca0d upstream.
Both register_perl_scripting() and register_python_scripting() allocate
this variable, fix it by checking if it already was.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: 7e4b21b84c43 ("perf/scripts: Add Python scripting engine")
commit c56cb33b56c13493eeb95612f80e4dd6e35cd109 upstream.
Since 841e3558b2d ("perf callchain: Recording 'dwarf' callchains do not
need DWARF unwinding support"), --call-graph dwarf is allowed in 'perf
record' even without unwind support. A couple of other places don't
reflect this yet though: the help text should list dwarf as a valid
record mode and the dump_size config should be respected too.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
Cc: He Kuang <hekuang@huawei.com>
Fixes: 841e3558b2de ("perf callchain: Recording 'dwarf' callchains do not need DWARF unwinding support")
Link: http://lkml.kernel.org/r/1470837148-7642-1-git-send-email-rabin.vincent@axis.com
commit ed6c166cc7dc329736cace3affd2df984fb22ec8 upstream.
Fixes a perf diff regression issue which was introduced by commit
5baecbcd9c9a ("perf symbols: we can now read separate debug-info files
based on a build ID")
The binary name could be same when perf diff different binaries. Build
id is used to distinguish between them.
However, the previous patch assumes the same binary name has same build
id. So it overwrites the build id according to the binary name,
regardless of whether the build id is set or not.
Check the has_build_id in dso__load. If the build id is already set, use
it.
Before the fix:
$ perf diff 1.perf.data 2.perf.data
# Event 'cycles'
# Baseline Delta Shared Object Symbol
99.83% -99.80% tchain_edit [.] f2
0.12% +99.81% tchain_edit [.] f3
0.02% -0.01% [ixgbe] [k] ixgbe_read_reg
After the fix:
# Event 'cycles'
99.83% +0.10% tchain_edit [.] f3
0.12% -0.08% tchain_edit [.] f2
Signed-off-by: Kan Liang <kan.liang@intel.com>
CC: Dima Kogan <dima@secretsauce.net>
Fixes: 5baecbcd9c9a ("perf symbols: we can now read separate debug-info files based on a build ID")
Link: http://lkml.kernel.org/r/1481642984-13593-1-git-send-email-kan.liang@intel.com
commit 2bd42f3aaa53ebe78b9be6f898b7945dd61f9773 upstream.
There might be systems where MAP_32BIT is not defined, like some some
RHEL7 powerpc versions.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Kyle McMartin <kyle@redhat.com>
Fixes: 256763b01741 ("perf trace beauty mmap: Add more conditional defines")
Link: http://lkml.kernel.org/r/1481831814-23683-1-git-send-email-jolsa@kernel.org
[ Changed the Fixme cset to the one removing the conditional switch case for MAP_32BIT ]
commit 631ac41b46d293fb3ee43a809776c1663de8d9c6 upstream.
Removing extra '--' prefix.
Fixes: ad16511b0e40 ("perf mem: Add -U/-K (--all-user/--all-kernel) options")
Link: http://lkml.kernel.org/r/1481538943-21874-2-git-send-email-jolsa@kernel.org
commit ecf1e2253ea79c6204f4d6a5e756e8fb4aed5a7e upstream.
Instead of the one when another syscall takes place while another is being
processed (in another CPU, but we show it serialized, so need to "interrupt"
the other), and also when finally showing the sys_enter + sys_exit + duration,
where we were showing the sample->time for the sys_exit, duh.
Before:
# perf trace sleep 1
<SNIP>
0.373 ( 0.001 ms): close(fd: 3 ) = 0
1000.626 (1000.211 ms): nanosleep(rqtp: 0x7ffd6ddddfb0) = 0
1000.653 ( 0.003 ms): close(fd: 1 ) = 0
1000.657 ( 0.002 ms): close(fd: 2 ) = 0
1000.667 ( 0.000 ms): exit_group( )
After:
<SNIP>
0.336 ( 0.001 ms): close(fd: 3 ) = 0
0.373 (1000.086 ms): nanosleep(rqtp: 0x7ffe303e9550) = 0
1000.481 ( 0.002 ms): close(fd: 1 ) = 0
1000.485 ( 0.001 ms): close(fd: 2 ) = 0
1000.494 ( 0.000 ms): exit_group( )
[root@jouet linux]#
Link: http://lkml.kernel.org/n/tip-ecbzgmu2ni6glc6zkw8p1zmx@git.kernel.org
Fixes: 752fde44fd1c ("perf trace: Support interrupted syscalls")
commit a2b1e8a20c992b01eeb76de00d4f534cbe9f3822 upstream.
Nothing in this minimal script seems to require bash. We often run these
tests on embedded devices where the only shell available is the busybox
ash. Use sh instead.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit 3659f98b5375d195f1870c3e508fe51e52206839 upstream.
commit 5da889c795b1fbefc9d8f058b54717ab8ab17891 upstream.
The virtio tools implementation of READ_ONCE() has a single parameter called
'var', but erroneously refers to 'val' for its cast, and thus won't work unless
there's a variable of the correct type that happens to be called 'var'.
Fix this with s/var/val/, making READ_ONCE() work as expected regardless.
Fixes: a7c490333df3cff5 ("tools/virtio: use virt_xxx barriers")
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: virtualization@lists.linux-foundation.org
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: Jason Wang <jasowang@redhat.com>
commit edee44be59190bf22d5c6e521f3852b7ff16862f upstream.
'perf report --tui' exits with error when it finds a sample of zero
length symbol (i.e. addr == sym->start == sym->end). Actually these are
valid samples. Don't exit TUI and show report with such symbols.
Reported-and-Tested-by: Anton Blanchard <anton@samba.org>
Link: https://lkml.org/lkml/2016/10/8/189
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Chris Riyder <chris.ryder@arm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nicholas Piggin <npiggin@gmail.com>
Link: http://lkml.kernel.org/r/1479804050-5028-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
"Several fixes to the DSM (ACPI device specific method) marshaling
implementation.
I consider these urgent enough to send for 4.9 consideration since
they fix the kernel's handling of ARS (Address Range Scrub) commands.
Especially for platforms without machine-check-recovery capabilities,
successful execution of ARS commands enables the platform to
potentially break out of an infinite reboot problem if a media error
is present in the boot path. There is also a one line fix for a
device-dax read-only mapping regression.
Commits 9a901f5495e2 ("acpi, nfit: fix extended status translations
for ACPI DSMs") and 325896ffdf90 ("device-dax: fix private mapping
restriction, permit read-only") are true regression fixes for changes
introduced this cycle.
Commit efda1b5d87cb ("acpi, nfit, libnvdimm: fix / harden ars_status
output length handling") fixes the kernel's handling of zero-length
results, this never would have worked in the past, but we only just
recently discovered a BIOS implementation that emits this arguably
spec non-compliant result.
The remaining two commits are additional fall out from thinking
through the implications of a zero / truncated length result of the
ARS Status command.
In order to mitigate the risk that these changes introduce yet more
regressions they are backstopped by a new unit test in commit
a7de92dac9f0 ("tools/testing/nvdimm: unit test acpi_nfit_ctl()") that
mocks up inputs to acpi_nfit_ctl()"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
device-dax: fix private mapping restriction, permit read-only
acpi, nfit: fix bus vs dimm confusion in xlat_status
acpi, nfit: validate ars_status output buffer size
acpi, nfit, libnvdimm: fix / harden ars_status output length handling
acpi, nfit: fix extended status translations for ACPI DSMs
This reverts commit 53855d10f4567a0577360b6448d52a863929775b.
It shouldn't have come in yet - it depends on the changes in linux-next
that will come in during the next merge window. As Matthew Wilcox says,
the test suite is broken with the current state without the revert.
Requested-by: Matthew Wilcox <mawilcox@microsoft.com>
Patch "lib/radix-tree: Convert to hotplug state machine" breaks the test
suite as it adds a call to cpuhp_setup_state_nocalls() which is not
currently emulated in the test suite. Add it, and delete the emulation
of the old CPU hotplug mechanism.
Link: http://lkml.kernel.org/r/1480369871-5271-36-git-send-email-mawilcox@linuxonhyperv.com
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
A recent flurry of bug discoveries in the nfit driver's DSM marshalling
routine has highlighted the fact that we do not have unit test coverage
for this routine. Add a self-test of acpi_nfit_ctl() routine before
probing the "nfit_test.0" device. This mocks stimulus to acpi_nfit_ctl()
and if any of the tests fail "nfit_test.0" will be unavailable causing
the rest of the tests to not run / fail.
This unit test will also be a place to land reproductions of quirky BIOS
behavior discovered in the field and ensure the kernel does not regress
against implementations it has seen in practice.
For the "lea %(rsp), %rbp" case, we check if there is a rex_prefix.
But we check 'bytes' which is insn_byte_t[4] in rex_prefix (insn_field
structure). Therefore, the check is always true.
Instead, check 'nbytes' which is the right one.
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20161205105551.25917-1-jslaby@suse.cz
Pull ACPI fixes from Rafael Wysocki:
"They fix an ACPI thermal management regression introduced by a recent
FADT handling cleanup, an ACPI tools build issue introduced by a
recent ACPICA commit and a PCC mailbox initialization bug causing
lockdep to complain loudly.
Specifics:
- Revert a recent ACPICA cleanup that attempted to get rid of all
FADT version 2 legacy, but broke ACPI thermal management on at
least one system (Rafael Wysocki).
- Fix cross-compiled builds of ACPI tools that stopped working after
a recent cleanup related to the handling of header files in ACPICA
(Lv Zheng).
- Fix a locking issue in the PCC channel initialization code that
invokes devm_request_irq() under a spinlock (among other things)
and causes lockdep to complain (Hoan Tran)"
* tag 'acpi-4.9-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
tools/power/acpi: Remove direct kernel source include reference
mailbox: PCC: Fix lockdep warning when request PCC channel
Revert "ACPICA: FADT support cleanup"
Avoid breaking cross-compiled ACPI tools builds by rearranging the
handling of kernel header files.
This patch also contains OUTPUT/srctree cleanups in order to make above fix
working for various build environments.
Fixes: e323c02dee59 (ACPICA: MSVC9: Fix <sys/stat.h> inclusion order issue)
Reported-and-tested-by: Yisheng Xie <xieyisheng1@huawei.com>
Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[ rjw: Changelog ]
Pull perf fixes from Ingo Molnar:
"An uncore PMU driver hardware enablement change for Intel SkyLake
uncore PMUs (Skylake Y, U, H and S platforms), plus a number of
tooling fixes for the histogram handling/displaying code"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/uncore: Add more Intel uncore IMC PCI IDs for SkyLake
perf hists: Fix column length on --hierarchy
perf hists browser: Fix column indentation on --hierarchy
perf hists browser: Show folded sign properly on --hierarchy
perf hists browser: Fix indentation of folded sign on --hierarchy
perf hist browser: Fix hierarchy column counts
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes for perf {top,report} --hierarchy, from Arnaldo Carvalho de Melo:
- These are fixes for the --hierarchy view of perf top and report, fixing
output oddities, mostly related to scrolling. (Namhyung Kim)
* pm-tools-fixes:
cpupower: Correct return type of cpu_power_is_cpu_online() in cpufreq-set
* pm-sleep-fixes:
PM / sleep: don't suspend parent when async child suspend_{noirq, late} fails
PM / sleep: fix device reference leak in test_suspend
Markus reported that there's a weird behavior on perf top --hierarchy
regarding the column length.
Looking at the code, I found a dubious code which affects the symptoms.
When --hierarchy option is used, the last column length might be
inaccurate since it skips to update the length on leaf entries.
I cannot remember why it did and looks like a leftover from previous
version during the development.
Anyway, updating the column length often is not harmful. So let's move
the code out.
Reported-and-Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 1a3906a7e6b9 ("perf hists: Resort hist entries with hierarchy")
Link: http://lkml.kernel.org/r/20161108130833.9263-5-namhyung@kernel.org
When horizontall scrolling is used in hierarchy mode, the the right most
column has unnecessary indentation. Actually it's needed only if some
of left (overhead) columns were shown.
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20161108130833.9263-4-namhyung@kernel.org
When horizontal scrolling is used in hierarchy mode, the folded signed
disappears at the right most column.
Committer note:
To test it, run 'perf top --hierarchy, see the '+' symbol at the first
column, then press the right arrow key, the '+' symbol will disappear,
this patch fixes that.
Link: http://lkml.kernel.org/r/20161108130833.9263-3-namhyung@kernel.org
[ Move 'width -= 2' invariant to right after the if/else ]
It should indent 2 spaces for folded sign and a whitespace.
Link: http://lkml.kernel.org/r/20161108130833.9263-2-namhyung@kernel.org
The perf report/top on TUI supports horizontal scrolling using LEFT and
RIGHT keys.
But it calculate the number of columns incorrectly when hierarchy mode
is enabled so that keep pressing RIGHT key can make the output
disappeared.
In the hierarchy mode, all sort keys are collapsed into a single column,
so it needs to be applied when calculating column numbers.
Link: http://lkml.kernel.org/r/20161024162110.17918-1-namhyung@kernel.org
When converting to a shared library in ac5a181d065d ("cpupower: Add
cpuidle parts into library"), cpu_freq_cpu_exists() was converted to
cpupower_is_cpu_online(). cpu_req_cpu_exists() returned 0 on success and
-ENOSYS on failure whereas cpupower_is_cpu_online returns 1 on success.
Check for the correct return value in cpufreq-set.
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1374212
Fixes: ac5a181d065d (cpupower: Add cpuidle parts into library)
Reported-by: Julian Seward <jseward@acm.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Acked-by: Thomas Renninger <trenn@suse.com>
Cc: 4.7+ <stable@vger.kernel.org> # 4.7+
Updating the event index has a memory barrier and causes more work
on the other side to actually signal the event. It is unnecessary
if a new buffer has already appeared on the ring, so poll once before
doing the update.
The effect of this on the 0.9 ring implementation is pretty much
invisible, but on the new-style ring it provides a consistent 3%
performance improvement.
Provide new primitives used_empty/avail_empty and
build poll_avail/poll_used on top of it.
By using -flto and -fwhole-program, all functions from the ring implementation
can be treated as static and possibly inlined. Force this to happen through
the GCC flatten attribute.
The following commit:
3732710ff6f2 ("objtool: Improve rare switch jump table pattern detection")
... improved objtool's ability to detect GCC switch statement jump
tables for GCC 6. However the check to allow short jumps with the
scanned range of instructions wasn't quite right. The pattern detection
should allow jumps to the indirect jump instruction itself.
This fixes the following warning:
drivers/infiniband/sw/rxe/rxe_comp.o: warning: objtool: rxe_completer()+0x315: sibling call from callable instruction with changed frame pointer
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: 3732710ff6f2 ("objtool: Improve rare switch jump table pattern detection")
Link: http://lkml.kernel.org/r/20161026153408.2rifnw7bvoc5sex7@treble
AVX512_4VNNIW - Vector instructions for deep learning enhanced word
variable precision.
AVX512_4FMAPS - Vector instructions for deep learning floating-point
single precision.
These new instructions are to be used in future Intel Xeon & Xeon Phi
processors. The bits 2&3 of CPUID[level:0x07, EDX] inform that new
instructions are supported by a processor.
The spec can be found in the Intel Software Developer Manual (SDM) or in
the Instruction Set Extensions Programming Reference (ISE).
Define new feature flags to enumerate the new instructions in /proc/cpuinfo
accordingly to CPUID bits and add the required xsave extensions which are
required for proper operation.
Signed-off-by: Piotr Luc <piotr.luc@intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20161018150111.29926-1-piotr.luc@intel.com
"Four tooling fixes, two kprobes KASAN related fixes and an x86 PMU
driver fix/cleanup"
perf jit: Fix build issue on Ubuntu
perf jevents: Handle events including .c and .o
perf/x86/intel: Remove an inconsistent NULL check
kprobes: Unpoison stack in jprobe_return() for KASAN
kprobes: Avoid false KASAN reports during stack copy
perf header: Set nr_numa_nodes only when we parsed all the data
perf top: Fix refreshing hierarchy entries on TUI
Pull misc fixes from Ingo Molnar:
"A CPU hotplug debuggability fix and three objtool false positive
warnings fixes for new GCC6 code generation patterns"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
cpu/hotplug: Use distinct name for cpu_hotplug.dep_map
objtool: Skip all "unreachable instruction" warnings for gcov kernels
objtool: Support '-mtune=atom' stack frame setup instruction
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
- Fix handling of NUMA nodes in perf.data files (Jiri Olsa)
- Fix scrolling when refreshing 'perf top --tui --hierarchy' entries (Namhyung Kim)
- Fix building of JIT support on Ubuntu 16.04 (Anton Blanchard)
- Fix handling of events including .c and .o, that were being treated as
BPF scripts instead of vendor ones (Wang Nan)
When building on Ubuntu 16.04, I get the following error:
Makefile:49: *** the openjdk development package appears to me missing, install and try again. Stop.
The problem is that update-java-alternatives has multiple spaces between
fields, and cut treats each space as a new delimiter:
java-1.8.0-openjdk-ppc64el 1081 /usr/lib/jvm/java-1.8.0-openjdk-ppc64el
Fix this by using awk, which handles this fine.
Link: http://lkml.kernel.org/r/1476325243-15788-1-git-send-email-anton@ozlabs.org
This patch helps with Sukadev's vendor event tree where such events can happen.
>From Andi Kleen:
Any event including a .c/.o/.bpf currently triggers BPF compilation or loading
and then an error. This can happen for some Intel vendor events, which cannot
be used.
This patch fixes this problem by forbidding BPF file patch containing '{', '}'
and ',', make sure flex consumes the leading '{', instead of matching it using
a BPF file path.
Tested result:
$ perf stat -e '{unc_p_clockticks,unc_p_power_state_occupancy.cores_c0}' -a -I 1000
invalid or unsupported event: '{unc_p_clockticks,unc_p_power_state_occupancy.cores_c0}'
Run 'perf list' for a list of valid events
(as expected, interperted as event)
$ perf stat -e 'aaa.c' -a -I 1000
ERROR: problems with path aaa.c: No such file or directory
(as expected, interpreted as BPF source)
$ perf stat -e 'aaa.ccc' -a -I 1000
invalid or unsupported event: 'aaa.ccc'
(as expected, interpreted as event)
$ perf stat -e '{aaa.c}' -a -I 1000
event syntax error: '{aaa.c}'
<SKIP>
$ perf stat -e '{cycles,aaa.c}' -a -I 1000
event syntax error: '{cycles,aaa.c}'
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Reported-by: Andi Kleen <ak@linux.intel.com>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: Zefan Li <lizefan@huawei.com>
Cc: pi3orama@163.com
Link: http://lkml.kernel.org/r/1475900185-37967-1-git-send-email-wangnan0@huawei.com
Recently objtool has started reporting a few "unreachable instruction"
warnings when CONFIG_GCOV is enabled for newer versions of GCC. Usually
this warning means there's some new control flow that objtool doesn't
understand. But in this case, objtool is correct and the instructions
really are inaccessible. It's an annoying quirk of gcov, but it's
harmless, so it's ok to just silence the warnings.
With older versions of GCC, it was relatively easy to detect
gcov-specific instructions and to skip any unreachable warnings produced
by them. But GCC 6 has gotten craftier.
Instead of continuing to play whack-a-mole with gcov, just use a bigger,
more permanent hammer and disable unreachable warnings for the whole
file when gcov is enabled. This is fine to do because a) unreachable
warnings are usually of questionable value; and b) gcov isn't used for
production kernels and we can relax the checks a bit there.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/38d5c87d61d9cd46486dd2c86f46603dff0df86f.1476393584.git.jpoimboe@redhat.com
GCC 6 added a new switch statement jump table optimization which makes
objtool's life harder. It looks like:
mov [rodata addr],%reg1
... some instructions ...
jmpq *(%reg1,%reg2,8)
The optimization is quite rare, but objtool still needs to be able to
identify the pattern so that it can follow all possible control flow
paths related to the switch statement.
In order to detect the pattern, objtool starts from the indirect jump
and scans backwards through the function until it finds the first
instruction in the pattern. If it encounters an unconditional jump
along the way, it stops and considers the pattern to be not found.
As it turns out, unconditional jumps can happen, as long as they are
small forward jumps within the range being scanned.
This fixes the following warnings:
drivers/infiniband/sw/rxe/rxe_comp.o: warning: objtool: rxe_completer()+0x2f4: sibling call from callable instruction with changed frame pointer
drivers/infiniband/sw/rxe/rxe_resp.o: warning: objtool: rxe_responder()+0x10f: sibling call from callable instruction with changed frame pointer
Link: http://lkml.kernel.org/r/8a9ed68ae1780e8d3963e4ee13f2f257fe3a3c33.1476393584.git.jpoimboe@redhat.com
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest updates from Shuah Khan:
"This update consists of:
- Fixes and improvements to existing tests
- Moving code from Documentation to selftests, samples, and tools:
* Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and
networking tests from Documentation to selftests.
* Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay,
and blackfin examples from Documentation to samples.
* Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from
Documentation to tools.
* Deletes BUILD_DOCSRC and its dependencies"
* tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits)
selftests/futex: Check ANSI terminal color support
Doc: update 00-INDEX files to reflect the runnable code move
samples: move blackfin gptimers-example from Documentation
tools: move pcmcia crc32hash tool from Documentation
tools: move laptops dslm tool from Documentation
tools: move accounting tool from Documentation
samples: move auxdisplay example code from Documentation
samples: move watchdog example code from Documentation
samples: move timers example code from Documentation
samples: move misc-devices/mei example code from Documentation
samples: move mic/mpssd example code from Documentation
selftests: Move networking/timestamping from Documentation
selftests: move watchdog tests from Documentation/watchdog
selftests: move ia64 tests from Documentation/ia64
selftests: move vDSO tests from Documentation/vDSO
selftests: move ptp tests from Documentation/ptp
selftests: move prctl tests from Documentation/prctl
selftests: move dnotify_test from Documentation/filesystems
selftests/timers: Add missing error code assignment before test
selftests/zram: replace ZRAM_LZ4_COMPRESS
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull more powerpc updates from Michael Ellerman:
"Some more powerpc updates for 4.9:
Freescale updates from Scott Wood:
- qbman support (a prerequisite for datapath drivers such as ethernet)
- a PCI DMA fix+improvement
- reset handler changes
- more 8xx optimizations
- some cleanups and fixes.'
Fixes:
- selftests/powerpc: Add missing binaries to .gitignores (Michael Ellerman)
- selftests/powerpc: Fix build break caused by EXPORT_SYMBOL changes (Michael Ellerman)
- powerpc/pseries: Fix stack corruption in htpe code (Laurent Dufour)
- powerpc/64s: Fix power4_fixup_nap placement (Nicholas Piggin)
- powerpc/64: Fix incorrect return value from __copy_tofrom_user (Paul Mackerras)
- powerpc/mm/hash64: Fix might_have_hea() check (Michael Ellerman)
Other:
- MAINTAINERS: Remove myself from PA Semi entries (Olof Johansson)
- MAINTAINERS: Drop separate pseries entry (Michael Ellerman)
- MAINTAINERS: Update powerpc website & add selftests (Michael Ellerman):
* tag 'powerpc-4.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (35 commits)
arch/powerpc: Add CONFIG_FSL_DPAA to corenetXX_smp_defconfig
soc/qman: Add self-test for QMan driver
soc/bman: Add self-test for BMan driver
soc/fsl: Introduce DPAA 1.x QMan device driver
soc/fsl: Introduce DPAA 1.x BMan device driver
powerpc/8xx: make user addr DTLB miss the short path
powerpc/8xx: Move additional DTLBMiss handlers out of exception area
powerpc/8xx: use r3 to scratch CR in ITLBmiss
soc/fsl/qe: fix gpio save_regs functions
powerpc/8xx: add dedicated machine check handler
powerpc/8xx: add system_reset_exception
Sukadev reported segfault on releasing perf env's numa data. It's due
to nr_numa_nodes being set no matter if the numa data gets parsed
properly. The perf_env__exit crash the on releasing non existed data.
Setting nr_numa_nodes only when data are parsed out properly.
Reported-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/n/tip-dt9c0zgkt4hybn2cr4xiawta@git.kernel.org
Markus reported that 'perf top --hierarchy' cannot scroll down after
refresh. This was because the number of entries are not updated when
hierarchy is enabled.
Unlike normal report view, hierarchy mode needs to keep its own entry
count since it can have non-leaf entries which can expand/collapse.
Fixes: f5b763feebe9 ("perf hists browser: Count number of hierarchy entries")
Link: http://lkml.kernel.org/r/20161007050412.3000-1-namhyung@kernel.org
Merge more updates from Andrew Morton:
- a few block updates that fell in my lap
- lib/ updates
- checkpatch
- autofs
- ipc
- a ton of misc other things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits)
mm: split gfp_mask and mapping flags into separate fields
fs: use mapping_set_error instead of opencoded set_bit
treewide: remove redundant #include <linux/kconfig.h>
hung_task: allow hung_task_panic when hung_task_warnings is 0
kthread: add kerneldoc for kthread_create()
kthread: better support freezable kthread workers
kthread: allow to modify delayed kthread work
kthread: allow to cancel kthread work
kthread: initial support for delayed kthread work
kthread: detect when a kthread work is used by more workers
kthread: add kthread_destroy_worker()
kthread: add kthread_create_worker*()
kthread: allow to call __kthread_create_on_node() with va_list args
kthread/smpboot: do not park in kthread_create_on_cpu()
kthread: kthread worker API cleanup
kthread: rename probe_kthread_data() to kthread_probe_data()
scripts/tags.sh: enable code completion in VIM
mm: kmemleak: avoid using __va() on addresses that don't have a lowmem mapping
kdump, vmcoreinfo: report memory sections virtual addresses
ipc/sem.c: add cond_resched in exit_sme
Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
The pthread_mutex_t in regression1.c wasn't being initialized properly.
Link: http://lkml.kernel.org/r/20160815194237.25967-4-ross.zwisler@linux.intel.com
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
There are four cases I can see where we could end up with a NULL 'slot' in
radix_tree_next_slot(). This unit test exercises all four of them, making
sure that if in the future we have an unsafe path through
radix_tree_next_slot(), we'll catch it.
Here are details on the four cases:
1) radix_tree_iter_retry() via a non-tagged iteration like
radix_tree_for_each_slot(). In this case we currently aren't seeing a bug
because radix_tree_iter_retry() sets
iter->next_index = iter->index;
which means that in in the else case in radix_tree_next_slot(), 'count' is
zero, so we skip over the while() loop and effectively just return NULL
without ever dereferencing 'slot'.
2) radix_tree_iter_retry() via tagged iteration like
radix_tree_for_each_tagged(). This case was giving us NULL pointer
dereferences in testing, and was fixed with this commit:
commit 3cb9185c6730 ("radix-tree: fix radix_tree_iter_retry() for tagged
iterators.")
This fix doesn't explicitly check for 'slot' being NULL, though, it works
around the NULL pointer dereference by instead zeroing iter->tags in
radix_tree_iter_retry(), which makes us bail out of the if() case in
radix_tree_next_slot() before we dereference 'slot'.
3) radix_tree_iter_next() via via a non-tagged iteration like
radix_tree_for_each_slot(). This currently happens in shmem_tag_pins()
and shmem_partial_swap_usage().
As with non-tagged iteration, 'count' in the else case of
radix_tree_next_slot() is zero, so we skip over the while() loop and
effectively just return NULL without ever dereferencing 'slot'.
4) radix_tree_iter_next() via tagged iteration like
radix_tree_for_each_tagged(). This happens in shmem_wait_for_pins().
radix_tree_iter_next() zeros out iter->tags, so we end up exiting
radix_tree_next_slot() here:
if (flags & RADIX_TREE_ITER_TAGGED) {
void *canon = slot;
iter->tags >>= 1;
if (unlikely(!iter->tags))
return NULL;
Link: http://lkml.kernel.org/r/20160815194237.25967-3-ross.zwisler@linux.intel.com
Pull libnvdimm updates from Dan Williams:
"Aside from the recently added pmem sub-division support these have
been in -next for several releases with no reported issues. The sub-
division support was included in next-20161010 with no reported
issues. It passes all unit tests including new tests for all the new
functionality below.
Summary:
- PMEM sub-division support: Allow a single PMEM region to be divided
into multiple namespaces. Originally, ~2 years ago, it was thought
that partitions of a /dev/pmemX block device could handle
sub-allocations of persistent memory for different use cases. With
the decision to not support DAX mappings of raw block-devices, and
the genesis of device-dax, the need for having multiple
pmem-namespace per region has grown.
- Device-DAX unified inode: In support of dynamic-resizing of a
device-dax instance the kernel arranges for all mappings of a
device-dax node to share the same inode. This allows unmap /
truncate / invalidation events to affect all instances of the
device similar to the behavior of mmap on block devices.
- Hardware error scrubbing reworks: The original address-range-scrub
and badblocks tracking solution allowed clearing entries at the
individual namespace level, but it failed to clear the internal
list of media errors maintained at the bus level. The result was
that the next scrub or namespace disable/re-enable event would
restore the cleared badblocks, but now that is fixed. The v4.8
kernel introduced an auto-scrub-on-machine-check behavior to
repopulate the badblocks list. Now, in v4.9, the auto-scrub
behavior can be disabled and simply arrange for the error reported
in the machine-check to be added to the list.
- DIMM health-event notification support: ACPI 6.1 defines a
notification event code that can be send to ACPI NVDIMM devices. A
poll(2) capable file descriptor for these events can be obtained
from the nmemX/nfit/flags sysfs-attribute of a libnvdimm memory
device.
- Miscellaneous fixes: NVDIMM-N probe error, device-dax build error,
and a change to dedup the flush hint list to not flush the memory
controller more than necessary"
* tag 'libnvdimm-for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (39 commits)
/dev/dax: fix Kconfig dependency build breakage
dax: use correct dev_t value
dax: convert devm_create_dax_dev to PTR_ERR
libnvdimm, namespace: allow creation of multiple pmem-namespaces per region
libnvdimm, namespace: lift single pmem limit in scan_labels()
libnvdimm, namespace: filter out of range labels in scan_labels()
libnvdimm, namespace: enable allocation of multiple pmem namespaces
libnvdimm, namespace: update label implementation for multi-pmem
libnvdimm, namespace: expand pmem device naming scheme for multi-pmem
libnvdimm, region: update nd_region_available_dpa() for multi-pmem support
libnvdimm, namespace: sort namespaces by dpa at init
libnvdimm, namespace: allow multiple pmem-namespaces per region at scan time
tools/testing/nvdimm: support for sub-dividing a pmem region
libnvdimm, namespace: unify blk and pmem label scanning
libnvdimm, namespace: refactor uuid_show() into a namespace_to_uuid() helper
libnvdimm, label: convert label tracking to a linked list
libnvdimm, region: move region-mapping input-paramters to nd_mapping_desc
nvdimm: reduce duplicated wpq flushes
libnvdimm: clear the internal poison_list when clearing badblocks
pmem: reduce kmap_atomic sections to the memcpys only
