Linux 4.1.44
* tag 'v4.1.44': (180 commits)
Linux 4.1.44
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
pinctrl: samsung: Remove bogus irq_[un]mask from resource management
pinctrl: sunxi: add a missing function of A10/A20 pinctrl driver
pnfs/blocklayout: require 64-bit sector_t
iio: adc: vf610_adc: Fix VALT selection value for REFSEL bits
usb:xhci:Add quirk for Certain failing HP keyboard on reset after resume
usb: quirks: Add no-lpm quirk for Moshi USB to Ethernet Adapter
USB: Check for dropped connection before switching to full speed
uas: Add US_FL_IGNORE_RESIDUE for Initio Corporation INIC-3069
iio: light: tsl2563: use correct event code
staging:iio:resolver:ad2s1210 fix negative IIO_ANGL_VEL read
USB: hcd: Mark secondary HCD as dead if the primary one died
USB: serial: pl2303: add new ATEN device id
USB: serial: cp210x: add support for Qivicon USB ZigBee dongle
USB: serial: option: add D-Link DWM-222 device ID
nfs/flexfiles: fix leak of nfs4_ff_ds_version arrays
fuse: initialize the flock flag in fuse_file on allocation
iscsi-target: Fix iscsi_np reset hung task during parallel delete
iscsi-target: fix memory leak in iscsit_setup_text_cmd()
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit b5bf1733d6a391c4e90ea8f8468d83023be74a2a ]
For cases where implicit fall through case labels are intended,
to let us inform that to gcc >= 7:
CC /tmp/build/perf/util/string.o
util/string.c: In function 'perf_atoll':
util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (*p)
util/string.c:24:3: note: here
case '\0':
So we introduce:
#define __fallthrough __attribute__ ((fallthrough))
And use it in such cases.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: William Cohen <wcohen@redhat.com>
Link: http://lkml.kernel.org/n/tip-qnpig0xfop4hwv6k4mv1wts5@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
target
[ Upstream commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e ]
When the jump instruction is displayed at the row 0 in annotate view,
the arrow is broken. An example:
16.86 │ ┌──je 82
0.01 │ movsd (%rsp),%xmm0
│ movsd 0x8(%rsp),%xmm4
│ movsd 0x8(%rsp),%xmm1
│ movsd (%rsp),%xmm3
│ divsd %xmm4,%xmm0
│ divsd %xmm3,%xmm1
│ movsd (%rsp),%xmm2
│ addsd %xmm1,%xmm0
│ addsd %xmm2,%xmm0
│ movsd %xmm0,(%rsp)
│82: sub $0x1,%ebx
83.03 │ ↑ jne 38
│ add $0x10,%rsp
│ xor %eax,%eax
│ pop %rbx
│ ← retq
The patch increments the row number before checking with 0.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: stable@vger.kernel.org
Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line")
Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com
Linux 4.1.43
* tag 'v4.1.43': (182 commits)
Linux 4.1.43
HID: core: prevent out-of-bound readings
ipvs: SNAT packet replies only for NATed connections
Revert "dmaengine: ep93xx: Don't drain the transfers in terminate_all()"
staging: comedi: ni_mio_common: fix E series ni_ai_insn_read() data
kvm: vmx: Do not disable intercepts for BNDCFGS
tracing: Use SOFTIRQ_OFFSET for softirq dectection for more accurate results
PM / QoS: return -EINVAL for bogus strings
sched/topology: Optimize build_group_mask()
sched/topology: Fix overlapping sched_group_mask
crypto: caam - fix signals handling
crypto: atmel - only treat EBUSY as transient if backlog
crypto: talitos - Extend max key length for SHA384/512-HMAC and AEAD
Add "shutdown" to "struct class".
mnt: Make propagate_umount less slow for overlapping mount propagation trees
mnt: In propgate_umount handle visiting mounts in any order
mnt: In umount propagation reparent in a separate pass
vt: fix unchecked __put_user() in tioclinux ioctls
exec: Limit arg stack to at most 75% of _STK_LIM
s390: reduce ELF_ET_DYN_BASE
[ Upstream commit 98dcea0cfd04e083ac74137ceb9a632604740e2d ]
liblockdep has been broken since commit 75dd602a5198 ("lockdep: Fix
lock_chain::base size"), as that adds a check that MAX_LOCK_DEPTH is
within the range of lock_chain::depth and in liblockdep it is much
too large.
That should have resulted in a compiler error, but didn't because:
- the check uses ARRAY_SIZE(), which isn't yet defined in liblockdep
so is assumed to be an (undeclared) function
- putting a function call inside a BUILD_BUG_ON() expression quietly
turns it into some nonsense involving a variable-length array
It did produce a compiler warning, but I didn't notice because
liblockdep already produces too many warnings if -Wall is enabled
(which I'll fix shortly).
Even before that commit, which reduced lock_chain::depth from 8 bits
to 6, MAX_LOCK_DEPTH was too large.
Cc: <stable@vger.kernel.org> # for versions before 4.6, use a value of 255
Cc: a.p.zijlstra@chello.nl
Link: http://lkml.kernel.org/r/20170525130005.5947-3-alexander.levin@verizon.com
[ Upstream commit 3ed5ca2efff70e9f589087c2013789572901112d ]
We catch this record to provide a visual indication that events are
getting lost, then call the default method to allow extra logging shared
with the other tools to take place.
This extra logging was done twice because we were continuing to the
"default" clause where machine__process_event() will end up calling
machine__process_lost_event() again, fix it.
Link: http://lkml.kernel.org/n/tip-wus2zlhw3qo24ye84ewu4aqw@git.kernel.org
[ Upstream commit d85ce830eef6c10d1e9617172dea4681f02b8424 ]
One line in perf_pmu__parse_unit() is indented wrongly, leading to a
warning (=> error) from gcc 6:
util/pmu.c:156:3: error: statement is indented as if it were guarded by... [-Werror=misleading-indentation]
sret = read(fd, alias->unit, UNIT_MAX_LEN);
util/pmu.c:153:2: note: ...this 'if' clause, but it is not
if (fd == -1)
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Fixes: 410136f5dd96 ("tools/perf/stat: Add event unit and scale support")
Link: http://lkml.kernel.org/r/20151214154440.GC1409@x4
[ Upstream commit d4913cbd05bab685e49c8174896e563b2487d054 ]
The issue was pointed out by gcc-6's -Wmisleading-indentation.
Fixes: c97cf42219b7 ("perf top: Live TUI Annotation")
Link: http://lkml.kernel.org/r/20151214154403.GB1409@x4
[ Upstream commit 3b556bced46aa6b1873da7faa18eff235e896adc ]
Signed-off-by: Eric Engestrom <eric.engestrom@imgtec.com>
Link: http://lkml.kernel.org/r/1461577678-29517-1-git-send-email-eric.engestrom@imgtec.com
[ Upstream commit a5e8e825bd1704c488bf6a46936aaf3b9f203d6a ]
The readdir() function is thread safe as long as just one thread uses a
DIR, which is the case in 'perf script', so, to avoid breaking the build
with glibc-2.23.90 (upcoming 2.24), use it instead of readdir_r().
See: http://man7.org/linux/man-pages/man3/readdir.3.html
"However, in modern implementations (including the glibc implementation),
concurrent calls to readdir() that specify different directory streams
are thread-safe. In cases where multiple threads must read from the
same directory stream, using readdir() with external synchronization is
still preferable to the use of the deprecated readdir_r(3) function."
Noticed while building on a Fedora Rawhide docker container.
Link: http://lkml.kernel.org/n/tip-mt3xz7n2hl49ni2vx7kuq74g@git.kernel.org
[ Upstream commit 7093b4c963cc4e344e490c774924a180602a7092 ]
DIR, which is the case when synthesizing events for pre-existing threads
by traversing /proc, so, to avoid breaking the build with glibc-2.23.90
CC /tmp/build/perf/util/event.o
util/event.c: In function '__event__synthesize_thread':
util/event.c:466:2: error: 'readdir_r' is deprecated [-Werror=deprecated-declarations]
while (!readdir_r(tasks, &dirent, &next) && next) {
In file included from /usr/include/features.h:368:0,
from /usr/include/stdint.h:25,
from /usr/lib/gcc/x86_64-redhat-linux/6.0.0/include/stdint.h:9,
from /git/linux/tools/include/linux/types.h:6,
from util/event.c:1:
/usr/include/dirent.h:189:12: note: declared here
Link: http://lkml.kernel.org/n/tip-i1vj7nyjp2p750rirxgrfd3c@git.kernel.org
[ Upstream commit 2e2bbc039fad9eabad6c4c1a473c8b2554cdd2d4 ]
Addressing a few cases spotted by a new warning in gcc 7:
tests/parse-events.c: In function 'test_pmu_events':
tests/parse-events.c:1790:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 90 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "cpu/event=%s/u", ent->d_name);
In file included from /usr/include/stdio.h:939:0,
from /git/linux/tools/perf/util/map.h:9,
from /git/linux/tools/perf/util/symbol.h:7,
from /git/linux/tools/perf/util/evsel.h:10,
from tests/parse-events.c:3:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 13 and 268 bytes into a destination of size 100
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
tests/parse-events.c:1798:29: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 100 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "%s:u,cpu/event=%s/u", ent->d_name, ent->d_name);
Fixes: 945aea220bb8 ("perf tests: Move test objects into 'tests' directory")
Link: http://lkml.kernel.org/n/tip-ty4q2p8zp1dp3mskvubxskm5@git.kernel.org
[ Upstream commit d7dd112ea5cacf91ae72c0714c3b911eb6016fea ]
Fix below compile error:
CC util/scripting-engines/trace-event-perl.o
In file included from /usr/lib/perl5/5.22.2/i686-linux/CORE/perl.h:5673:0,
from util/scripting-engines/trace-event-perl.c:31:
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h: In function 'S__is_utf8_char_slow':
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h:270:5: error: nested extern declaration of 'Perl___notused' [-Werror=nested-externs]
dTHX; /* The function called below requires thread context */
cc1: all warnings being treated as errors
After digging perl5 repository, I find out that we will meet this
compile error with perl from v5.21.1 to v5.25.4
Signed-off-by: Wang YanQing <udknight@gmail.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/20170212024655.GA15997@udknight
[ Upstream commit bdf23a9a190d7ecea092fd5c4aabb7d4bd0a9980 ]
The size of dirent->dt_name is NAME_MAX + 1, but the size for the 'path'
buffer is hard coded at 256, which may truncate it because we also
prepend "/proc/", so that all that into account and thank gcc 7 for this
warning:
/git/linux/tools/perf/util/thread_map.c: In function 'thread_map__new_by_uid':
/git/linux/tools/perf/util/thread_map.c:119:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 250 [-Werror=format-truncation=]
snprintf(path, sizeof(path), "/proc/%s", dirent->d_name);
from /git/linux/tools/perf/util/thread_map.c:5:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 7 and 262 bytes into a destination of size 256
Link: http://lkml.kernel.org/n/tip-csy0r8zrvz5efccgd4k12c82@git.kernel.org
[ Upstream commit 7b0214b702ad8e124e039a317beeebb3f020d125 ]
The implicit fall through case label here is intended, so let us inform
that to gcc >= 7:
CC /tmp/build/perf/builtin-top.o
builtin-top.c: In function 'display_thread':
builtin-top.c:644:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (errno == EINTR)
builtin-top.c:647:3: note: here
default:
Link: http://lkml.kernel.org/n/tip-lmcfnnyx9ic0m6j0aud98p4e@git.kernel.org
[ Upstream commit 94bdd5edb34e472980d1e18b4600d6fb92bd6b0a ]
that to gcc >= 7:
if (*p)
case '\0':
Link: http://lkml.kernel.org/n/tip-0ophb30v9apkk6o95el0rqlq@git.kernel.org
Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
[ Upstream commit 4cca0457686e4ee1677d69469e4ddfd94d389a80 ]
The switch that conditionally sets CPUPOWER_CAP_HAS_TURBO_RATIO and
CPUPOWER_CAP_IS_SNB flags is missing a break, so all cores get both
flags set and an assumed base clock of 100 MHz for turbo values.
Reported-by: GSR <gsr.bugs@infernal-iceberg.com>
Tested-by: GSR <gsr.bugs@infernal-iceberg.com>
References: https://bugs.debian.org/859978
Fixes: 8fb2e440b223 (cpupower: Show Intel turbo ratio support via ...)
[ Upstream commit 32677207dcc5e594254b7fb4fb2352b1755b1d5b ]
The child_exit errno needs to be shifted by 8 bits to compare against the
return values for the bisect variables.
Fixes: c5dacb88f0a64 ("ktest: Allow overriding bisect test results")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Linux 4.1.39
* tag 'v4.1.39': (138 commits)
Linux 4.1.39
KVM: x86: remove data variable from kvm_get_msr_common
KVM: VMX: Fix host initiated access to guest MSR_TSC_AUX
KVM: x86: pass host_initiated to functions that read MSRs
perf/core: Fix the perf_cpu_time_max_percent check
perf/core: Make sysctl_perf_cpu_time_max_percent conform to documentation
perf/core: Fix implicitly enable dynamic interrupt throttle
perf/core: Fix dynamic interrupt throttle
Fix missing sanity check in /dev/sg
printk: use rcuidle console tracepoint
vfs: fix uninitialized flags in splice_to_pipe()
drm/radeon: Use mode h/vdisplay fields to hide out of bounds HW cursor
ARM: 8658/1: uaccess: fix zeroing of 64-bit get_user()
drm/dp/mst: fix kernel oops when turning off secondary monitor
[media] siano: make it work again with CONFIG_VMAP_STACK
mmc: core: fix multi-bit bus width without high-speed mode
futex: Move futex_init() to core_initcall
xen-netfront: Delete rx_refill_timer in xennet_disconnect_backend()
scsi: aacraid: Fix INTx/MSI-x issue with older controllers
cpumask: use nr_cpumask_bits for parsing functions
[ Upstream commit 3659f98b5375d195f1870c3e508fe51e52206839 ]
Nothing in this minimal script seems to require bash. We often run these
tests on embedded devices where the only shell available is the busybox
ash. Use sh instead.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit a2b1e8a20c992b01eeb76de00d4f534cbe9f3822 ]
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit f594bae08183fb6b57db55387794ece3e1edf6f6 ]
I'm surprised this remained undocumented since at least 2011. And it is
actually a very useful switch, as Steve and I came to realize recently.
Add the text from
2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
which added the incrementing aspect to -d.
Cc: Davidlohr Bueso <dbueso@suse.com>
Cc: Mel Gorman <mgorman@suse.com>
Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de
[ Upstream commit 89fee59b504f86925894fcc9ba79d5c933842f93 ]
Steam frequently puts game binaries in folders with spaces.
Note: "(deleted)" markers are now treated as part of the file name.
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps")
Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720
[ Upstream commit 106b816cb46ebd87408b4ed99a2e16203114daa6 ]
At the end of process_filter(), collapse_tree() was changed to update
the parg parameter, but the reassignment after the call wasn't removed.
What happens is that the "current_op" gets modified and freed and parg
is assigned to the new allocated argument. But after the call to
collapse_tree(), parg is assigned again to the just freed "current_op",
and this causes the tool to crash.
The current_op variable must also be assigned to NULL in case of error,
otherwise it will cause it to be free()ed twice.
Cc: stable@vger.kernel.org # 3.14+
Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()")
Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home
[ Upstream commit 940db6dcd3f4659303fdf6befe7416adc4d24118 ]
When an error happens during alias parsing currently the complete
parsing of all attributes of the PMU is stopped. This is breaks old perf
on a newer kernel that may have not-yet-know alias attributes (such as
.scale or .per-pkg).
Continue when some attribute is unparseable.
This is IMHO a stable candidate and should be backported to older
versions to avoid problems with newer kernels.
v2: Print warnings when something goes wrong.
v3: Change warning to debug output
Cc: stable@vger.kernel.org # v3.6+
Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org
[ Upstream commit 50fe6dd10069e7c062e27f29606f6e91ea979399 ]
Use the local uapi headers to keep in sync with "recently" added #define's
(e.g. VSS_OP_REGISTER1).
Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv")
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 ]
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
[ Upstream commit c8ad7063626406181a7ebab10cb31b4f741b13d4 ]
Building perf out of kernel tree is currently broken because the
MANIFEST file refers to kernel files that have been removed. With this
patch make perf-targz-src-pkg succeeds as does building perf using the
generated tarfile.
Signed-off-by: David Ahern <david.ahern@oracle.com>
Link: http://lkml.kernel.org/r/1433526173-172332-1-git-send-email-david.ahern@oracle.com
recording/reporting guest data
[ Upstream commit 3caeaa562733c4836e61086ec07666635006a787 ]
While recording guest samples in host using perf kvm record, it will
populate unprocessable sample error, though samples will be recorded
properly. While generating report using perf kvm report, no samples will
be processed and same error will populate. We have seen this behaviour
with upstream perf(4.4-rc3) on x86 and ppc64 hardware.
Reason behind this failure is, when it tries to fetch machine from
rb_tree of machines, it fails. As a part of tracing a bug, we figured
out that this code was incorrectly refactored in commit 54245fdc3576
("perf session: Remove wrappers to machines__find").
This patch will change the functionality such that if it can't fetch
machine in first trial, it will create one node of machine and add that to
rb_tree. So next time when it tries to fetch same machine from rb_tree,
it won't fail. Actually it was the case before refactoring of code in
aforementioned commit.
This patch is generated from acme perf/core branch.
Below I've mention an example that demonstrate the behaviour before and
after applying patch.
Before applying patch:
[Note: One needs to run guest before recording data in host]
ravi@ravi-bangoria:~$ ./perf kvm record -a
Warning:
5903 unprocessable samples recorded.
Do you have a KVM guest running and not using 'perf kvm'?
[ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ]
ravi@ravi-bangoria:~$ ./perf kvm report --stdio
Warning:
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 285 of event 'cycles'
# Event count (approx.): 88715406
# Overhead Command Shared Object Symbol
# (For a higher level overview, try: perf report --sort comm,dso)
After applying patch:
[ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ]
# Samples: 17 of event 'cycles'
# Event count (approx.): 700746
34.19% :5758 [unknown] [g] 0xffffffff818682ab
22.79% :5758 [unknown] [g] 0xffffffff812dc7f8
22.79% :5758 [unknown] [g] 0xffffffff818650d0
14.83% :5758 [unknown] [g] 0xffffffff8161a1b6
2.49% :5758 [unknown] [g] 0xffffffff818692bf
0.48% :5758 [unknown] [g] 0xffffffff81869253
0.05% :5758 [unknown] [g] 0xffffffff81869250
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org # v3.19+
Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find")
Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com
machines
[ Upstream commit 32abc2ede536aae52978d6c0a8944eb1df14f460 ]
When a long value is read on 32 bit machines for 64 bit output, the
parsing needs to change "%lu" into "%llu", as the value is read
natively.
Unfortunately, if "%llu" is already there, the code will add another "l"
to it and fail to parse it properly.
Link: http://lkml.kernel.org/r/20151116172516.4b79b109@gandalf.local.home
For ctrl out test, it needs length > vary, so in order to run it with
default parameters, we do this change.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The 'length' is the transfer length, not the packet size, so
change the help text.
[ Upstream commit d7475de58575c904818efa369c82e88c6648ce2e ]
(e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I.
Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
commit c2e4b24ff848bb180f9b9cd873a38327cd219ad2 upstream.
When a trace recorded on a 32-bit device is processed with a 64-bit
binary, the higher 32-bits of the address need to ignored.
The lack of this results in the output of the 64-bit pointer
value to the trace as the 32-bit address lookup fails in find_printk().
Before:
burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c
After:
burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated
The problem occurs in PRINT_FIELD when the field is recognized as a
pointer to a string (of the type const char *)
Heterogeneous architectures cases below can arise and should be handled:
* Traces recorded using 32-bit addresses processed on a 64-bit machine
* Traces recorded using 64-bit addresses processed on a 32-bit machine
Reported-by: Juri Lelli <juri.lelli@arm.com>
Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Javi Merino <javi.merino@arm.com>
Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com
commit caa470475d9b59eeff093ae650800d34612c4379 upstream.
The original patch introducing this header wrote the number of CPUs available
and online in one order and then swapped those values when reading, fix it.
Before:
# perf record usleep 1
# perf report --header-only | grep 'nrcpus \(online\|avail\)'
# nrcpus online : 4
# nrcpus avail : 4
# echo 0 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 4
# nrcpus avail : 3
# echo 0 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 2
After the fix, bringing back the CPUs online:
# nrcpus online : 2
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu2/online
# nrcpus online : 3
# nrcpus avail : 4
# echo 1 > /sys/devices/system/cpu/cpu1/online
# nrcpus online : 4
# nrcpus avail : 4
Cc: Borislav Petkov <bp@suse.de>
Cc: Stephane Eranian <eranian@google.com>
Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)")
Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org
commit 93df8a1ed6231727c5db94a80b1a6bd5ee67cec3 upstream.
perf currently fails to build on MIPS as there is no
tools/perf/arch/mips/Build file. Adding an empty file fixes this as
there are no MIPS-specific sources to build.
It looks like the same is needed for Alpha and PA-RISC, though I
haven't been able to test those.
Fixes: 5e8c0fb6a957 ("perf build: Add arch x86 objects building")
Link: http://lkml.kernel.org/r/1438704627.7315.2.camel@decadent.org.uk
commit 601083cffb7cabdcc55b8195d732f0f7028570fa upstream.
print_aggr() fails to print per-core/per-socket statistics after commit
582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
if events have differnt cpus. Because in print_aggr(), aggr_get_id needs
index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be
used to get aggregated id.
Here is an example:
Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has
cpumask 0,18)
$ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2
Without this patch, it failes to get CPU 18 result.
Performance counter stats for 'CPU(s) 0,18':
S0-C0 1 7526851 cycles
S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/
S1-C0 0 <not counted> cycles
S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/
With this patch, it can get both CPU0 and CPU18 result.
S0-C0 1 6327768 cycles
S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/
S1-C0 1 330228 cycles
S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/
Signed-off-by: Kan Liang <kan.liang@intel.com>
Acked-by: Stephane Eranian <eranian@google.com>
Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events")
Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com
commit e8e6d37e73e6b950c891c780745460b87f4755b6 upstream.
When we introduce a new sort key, we need to update the
hists__calc_col_len() function accordingly, otherwise the width
will be limited to strlen(header).
We can't update it when obtaining a line value for a column (for
instance, in sort__srcline_cmp()), because we reset it all when doing a
resort (see hists__output_recalc_col_len()), so we need to, from what is
in the hist_entry fields, set each of the column widths.
Fixes: 409a8be61560 ("perf tools: Add sort by src line/number")
Link: http://lkml.kernel.org/n/tip-jgbe0yx8v1gs89cslr93pvz2@git.kernel.org
commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d upstream.
A copy of /proc/kcore containing the kernel text can be made to the
buildid cache. e.g.
perf buildid-cache -v -k /proc/kcore
To workaround objdump limitations, a copy is also made when annotating
against /proc/kcore.
The copying process stops working from libelf about v1.62 onwards (the
problem was found with v1.63).
The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails
because additional validation has been added to gelf_getphdr().
The use of gelf_getphdr() is a misguided attempt to get default
initialization of the Gelf_Phdr structure. That should not be
necessary because every member of the Gelf_Phdr structure is
subsequently assigned. So just remove the call to gelf_getphdr().
Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be
removed also.
Committer notes:
Note to stable@kernel.org, from Adrian in the cover letter for this
patchkit:
The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think
it is important enough for stable.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com
commit 0bc2f2f7d080561cc484d2d0a162a9396bed3383 upstream.
When setting yup the symbols library we setup several filter lists,
for dsos, comms, symbols, etc, and there is code that, if there are
filters, do certain operations, like recalculate the number of non
filtered histogram entries in the top/report TUI.
But they were considering just the "Zoom" filters, when they need to
take into account as well the above mentioned filters (perf top --comms,
--dsos, etc).
So store in symbol_conf.has_filter true if any of those filters is in
place.
Link: http://lkml.kernel.org/n/tip-f5edfmhq69vfvs1kmikq1wep@git.kernel.org
Cc: Andre Tomt <lkml@tomt.net>
commit 9c0fa8dd3d58de8b688fda758eea1719949c7f0a upstream.
At some point:
commit 2c86c7ca7606
Author: Namhyung Kim <namhyung@kernel.org>
Date: Mon Mar 17 18:18:54 2014 -0300
perf report: Merge al->filtered with hist_entry->filtered
We stopped dropping samples for things filtered via the --comms, --dsos,
--symbols, etc, i.e. things marked as filtered in the symbol resolution
routines (thread__find_addr_map(), perf_event__preprocess_sample(),
etc).
But then, in:
commit 268397cb2a47
Date: Tue Apr 22 14:49:31 2014 +0900
perf top/tui: Update nr_entries properly after a filter is applied
We don't take into account entries that were filtered in
perf_event__preprocess_sample() and friends, which leads to
inconsistency in the browser seek routines, that expects the number of
hist_entry->filtered entries to match what it thinks is the number of
unfiltered, browsable entries.
So, for instance, when we do:
perf top --symbols ___non_existent_symbol___
the hist_browser__nr_entries() routine thinks there are no filters in
place, uses the hists->nr_entries but all entries are filtered, leading
to a segfault.
Tested with:
perf top --symbols malloc,free --percentage=relative
Freezing, by pressing 'f', at any time and doing the math on the
percentages ends up with 100%, ditto for:
perf top --dsos libpthread-2.20.so,libxul.so --percentage=relative
Both were segfaulting, all fixed now.
More work needed to do away with checking if filters are in place, we
should just use the nr_non_filtered_samples counter, no need to
conditionally use it or hists.nr_filter, as what the browser does is
just show unfiltered stuff. An audit of how it is being accounted is
needed, this is the minimal fix.
Reported-by: Michael Petlan <mpetlan@redhat.com>
Fixes: 268397cb2a47 ("perf top/tui: Update nr_entries properly after a filter is applied")
Link: http://lkml.kernel.org/n/tip-6w01d5q97qk0d64kuojme5in@git.kernel.org
commit 2b42b09b88c831ba4da2d669581dde371c38c2af upstream.
With commit: e1e455f4f4d3 (perf tools: Work around lack of sched_getcpu
in glibc < 2.6), perf_bench numa mem with -c or -m option is not able to
correctly calculate convergence.
With the above commit, sched_getcpu always seems to return -1. The
intention of commit e1e455f was to add a sched_getcpu in glibc < 2.6.
Hence keep the sched_getcpu definition under an ifdef.
This regression happened occurred between v4.0 and v4.1
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Vinson Lee <vlee@twitter.com>
Fixes: e1e455f4f4d3 ("perf tools: Work around lack of sched_getcpu in glibc < 2.6")
Link: http://lkml.kernel.org/r/20150624111004.GA5220@linux.vnet.ibm.com
commit 60df4642a83546fa6ea8286f5094ce8c0906c3ec upstream.
Make 3.81 doesn't have the 'undefine' command. Using undefine
to clear LDFLAGS fails when make version 3.81 is used. Fix it
to use override to clear LDFLAGS.
Tested-by: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Link: http://lkml.kernel.org/r/20150514151225.GH23588@kernel.org
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 75e84ab906ef8935cff3df3d8929f1bafea81599 upstream.
Invoking Makefile.perf with prefix= breaks the build since Makefile.perf
hands that variable down to Makefile.build where it overrides
prefix := $(subst ./,,$(OUTPUT)$(dir)/)
leading to errors like this:
No rule to make target '/usrabspath.o', needed by '/usrlibperf-in.o'
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Fixes: c819e2cf2eb6f65d3208d195d7a0edef6108d5
Link: http://lkml.kernel.org/r/5582c48a.84a22b0a.a918.5285SMTPIN_ADDED_MISSING@mx.google.com
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- early_idt_handlers[] fix that fixes the build with bleeding edge
tooling
- build warning fix on GCC 5.1
- vm86 fix plus self-test to make it harder to break it again"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/asm/irq: Stop relying on magic JMP behavior for early_idt_handlers
x86/asm/entry/32, selftests: Add a selftest for kernel entries from VM86 mode
x86/boot: Add CONFIG_PARAVIRT_SPINLOCKS quirk to arch/x86/boot/compressed/misc.h
x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull turbostat tool fixes from Len Brown:
"Just one minor kernel dependency in this batch -- added a #define to
msr-index.h"
* 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
tools/power turbostat: update version number to 4.7
tools/power turbostat: allow running without cpu0
tools/power turbostat: correctly decode of ENERGY_PERFORMANCE_BIAS
tools/power turbostat: enable turbostat to support Knights Landing (KNL)
tools/power turbostat: correctly display more than 2 threads/core
