commit eb9c5836384cd2a276254df6254ed71117983626 upstream.
The out functions should only handle actual available data instead of the complete buffer.
Otherwise for example the ep0_consume function will report ghost events since it tries to decode
the complete buffer - which may contain partly invalid data.
Signed-off-by: Matthias Fend <matthias.fend@wolfvision.net>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
perf stat on PPC currently fails to run:
$ perf stat -- sleep 1
Error: open_counter returned with 6 (No such device or address). /bin/dmesg may provide additional information.
Fatal: Not all events could be opened.
The problem is that until 2.6.37 (behavior changed with commit b0a873e)
perf on PPC returns ENXIO when hw_perf_event_init() fails. With this
patch we get the expected behavior:
$ perf stat -v -- sleep 1
cycles event is not supported by the kernel.
stalled-cycles-frontend event is not supported by the kernel.
stalled-cycles-backend event is not supported by the kernel.
instructions event is not supported by the kernel.
branches event is not supported by the kernel.
branch-misses event is not supported by the kernel.
Signed-off-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1336490956-57145-1-git-send-email-dsahern@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
We don't know what types of warnings different versions of flex
and bison combined with different versions of gcc is going to
generate, so just punt and don't warn about anything.
This fixes the build of perf for me on an openSUSE 12.1 system.
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20120504183254.GA11154@kroah.com
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Fixes for perf/urgent:
- Add fallback in 'perf stat' for kernels that don't support
perf_event_attr.exclude_guest, from Stephane Eranian.
- Fix build id cache add routine to take the size of the buffer and not of a
pointer, from Namhyung Kim.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest
Pull two bug fixes in ktest from Steven Rostedt.
* tag 'ktest-for-v3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest:
ktest: Fix reboot on success stopping all reboots
ktest.pl: Fix combined usage of BISECT_REVERSE and BISECT_SKIP
By default, perf stat sets exclude_guest = 1. But when you run perf on a
kernel which does not support host/guest filtering, then you get an
error saying the event in unsupported. This comes from the fact that
when the perf_event_attr struct passed by the user is larger than the
one known to the kernel there is safety check which ensures that all
unknown bits are zero. But here, exclude_guest is 1 (part of the unknown
bits) and thus the perf_event_open() syscall return EINVAL.
To my surprise, running perf record on the same kernel did not exhibit
the problem. The reason is that perf record handles the problem by
catching the error and retrying with guest/host excludes set to zero.
For some reason, this was not done with perf stat. This patch fixes this
problem.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Robert Richter <robert.richter@amd.com>
Link: http://lkml.kernel.org/r/20120427124538.GA7230@quad
The filename is a pointer variable so the sizeof(filename) will return
length of a pointer. Fix it by using 'size'.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1335881976-3282-1-git-send-email-namhyung@gmail.com
The change to let individual tests decide to reboot the machine on
success of the entire test also prevented errors from rebooting
when an error was detected.
The "no_reboot" variable was only cleared if the test had
reboot_on_success set. But the no_reboot variable also prevents the test
rebooting when an error was detected even when REBOOT_ON_ERROR was set.
Add a new "reboot_success" variable that is used to determine if the
test should reboot on success and not touch the no_reboot variable.
When BISECT_REVERSE and BISECT_SKIP are used together with boot or test
testing, build failures are treated as boot or test failures and
'git bisect bad' is executed instead of 'git bisect skip'. This is because
the $ret value of -1 is treated as a build failure, but the $reverse_bisect
logic does not properly handle this.
Simple fix, only invert it if it is positive.
Link: http://lkml.kernel.org/r/1335235380-8509-1-git-send-email-Russ.Dill@ti.com
Signed-off-by: Russ Dill <Russ.Dill@ti.com>
When loading symbols from DSO we check multiple paths of DSO binary
until we succeed to load symbols ('.symtab' section). Once symbols are
read we try to load also plt symbols.
During the reading of plt symbols, the dso file is reopened from
location given by dso->long_name. This could be wrong in case we want
process buildid binaries.
The change is to make the plt symbols being read from the DSO path, that
normal symbols were read from.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1334756818-6631-1-git-send-email-jolsa@redhat.com
[ committer note: moved dso to be the first parameter of that function ]
They were dropped during conversion of event parser. Add test case to
make sure this will not happen again.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20120417111345.GK11918@redhat.com
The flex and bison tools generate arch-independent C code so its
binaries are not prefixed with the target-arch prefix. With this patch
the Linux 3.4-rc2 can be successfuly build on OE-Core.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Link: http://lkml.kernel.org/r/1334148270-13139-1-git-send-email-otavio@ossystems.com.br
While testing https://lkml.org/lkml/2012/4/10/123 I hit this crash:
(gdb) bt
0 0x000000000042000f in __cmd_report (rep=0x7fff80cec580) at builtin-report.c:380
1 cmd_report (argc=0, argv=<optimized out>, prefix=<optimized out>) at builtin-report.c:759
2 0x0000000000414513 in run_builtin (p=0x7724a8, argc=3, argv=0x7fff80ceca70) at perf.c:273
3 0x0000000000413d41 in handle_internal_command (argv=0x7fff80ceca70, argc=3) at perf.c:345
4 run_argv (argv=0x7fff80cec880, argcp=0x7fff80cec88c) at perf.c:389
5 main (argc=3, argv=0x7fff80ceca70) at perf.c:487
kernel_map can be NULL, so need to handle it while dumping a warning
to user.
v2:
- fixed RB_EMPTY_ROOT check -- desc takes the altnerative output when RB_EMPTY_ROOT is false.
Cc: Stephane Eranian <eranian@google.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1334544855-55021-1-git-send-email-dsahern@gmail.com
Pull perf tooling fixes from Arnaldo Carvalho de Melo:
. Properly handle ~/.debug, the build id cache, when it is a symlink,
fix from Chanho Park
. Fixes for the parser generation process, from Jiri Olsa and Namhyung Kim
. Fix build when NO_GTK2 is specified, From Stephane Eranian
. When a machine is not found, bump the relevant error stat but return
0, so that we correctly move to the next perf event. Fix from Jiri Olsa
If a '$PERF_BUILDID_DIR'(typically $HOME/.debug) is a symbolic link
directory, cutting of the path will fail.
Here is an example where a buildid directory is a symbolic link.
/ # ls -al /root
lrwxrwxrwx 1 root root 13 Mar 26 2012 /root -> opt/home/root
/ # cd ~
/opt/home/root # perf record -a -g sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.322 MB perf.data (~14057 samples) ]
/opt/home/root # perf archive
tar: Removing leading `/' from member names
Now please run:
$ tar xvf perf.data.tar.bz2 -C ~/.debug
wherever you need to run 'perf report' on.
/opt/home/root # mkdir temp
/opt/home/root # tar xf perf.data.tar.bz2 -C ./temp
/opt/home/root # find ./temp -name "*kernel*"
./temp/opt/home/root/.debug/[kernel.kallsyms]
-> If successfully cut off the path, [kernel.kallsyms] is located
in top of the archived file.
This patch enables to cut correctly even if the buildid directory
is a symbolic link.
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Link: http://lkml.kernel.org/r/1333348109-12598-1-git-send-email-chanho61.park@samsung.com
The commit 65f3e56e0c81 ("perf tools: Remove auto-generated bison/flex
files") removed those files from git, so they'll be listed on untracked
files after building perf. Fix it.
Signed-off-by: Namhyung Kim <namhyung.kim@lge.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1333948274-20043-1-git-send-email-namhyung.kim@lge.com
Currently the parsers objects (bison/flex related) are each time perf
is built. No matter the generated files are already in place, the
parser generation is executed every time.
Changing the rules to have proper flex/bison objects generation
dependencies.
The parsers code is not rebuilt until the flex/bison source files
are touched. Also when flex/bison source is changed, only dependent
objects are rebuilt.
Link: http://lkml.kernel.org/r/1334140791-3024-1-git-send-email-jolsa@redhat.com
Pull various perf tooling fixes from Arnaldo Carvalho de Melo.
Pull trivial perf build failure fix from Thomas Gleixner.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf tools: Fix getrusage() related build failure on glibc trunk
In case the user specified NO_GTK2 on the make cmdline, compilation
would fail with undefined symbol because the Makefile would not set the
correct cpp variable: NO_GTK2 vs. NO_GTK2_SUPPORT.
This patch renames the variable to the correct name.
Cc: David Ahern <dsahern@gmail.com>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/20120410103513.GA9229@quad
In case the perf_session__process_event function fails, we estimate the
next event offset.
This is not necessary for sample event failing on unknown ID or machine.
In such case we know proper size of the event, so we dont need to guess.
Also failure statistics are updated correctly so we don't miss any
information.
Forcing perf_session__process_event to return 0 in case of unknown ID or
machine.
Link: http://lkml.kernel.org/r/1334233262-5679-3-git-send-email-jolsa@redhat.com
Running 'perf kvm --host --guest --guestmount /tmp/guestmount record -a -g -- sleep 2'
Was resulting in a segfault. For event type PERF_RECORD_MMAP,
event->ip.pid is being used in perf_session__find_machine_for_cpumode,
which is not correct.
The event->ip.pid field happens to be 0 in this case and results in
returning a NULL machine object. Finally, access to self->pid in
machine__mmap_name, results in a segfault later.
For PERF_RECORD_MMAP type, pass event->mmap.pid.
Signed-off-by: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
Tested-by: David Ahern <dsahern@gmail.com>
Cc: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120409081835.10576.22018.stgit@abhimanyu.in.ibm.com
This routine was checking only if the provided address was after
sym->end, not if it was before sym->start.
Fix that by checking for both and return in both cases -ERANGE, so that
tools can communicate this to the user properly, or if they chose so, to
abort.
This problem was reported previously but the fixes involved either doing
what was being done for the > end case, i.e. silently drop the sample,
returning 0, or aborting at this function, which is in a lib (or better,
is slated to be at some point) and shouldn't abort.
The 'report' tool already checks this value and uses pr_debug to warn
the user.
This patch makes the 'top' tool check it too and warn once per map where
such range problem takes place.
Reported-by: David Miller <davem@davemloft.net>
Reported-by: Sorin Dumitru <dumitru.sorin87@gmail.com>
Reported-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-lw8gs7p9i9nhldilo82tzpne@git.kernel.org
If there's an event with no samples in data file, the perf report
command can segfault after entering the event details menu.
Following steps reproduce the issue:
# ./perf record -e syscalls:sys_enter_kexec_load,syscalls:sys_enter_mmap ls
# ./perf report
# enter '0 syscalls:sys_enter_kexec_load' menu
# pres ENTER twice
Above steps are valid assuming ls wont run kexec.. ;)
The check for sellection to be NULL is missing. The fix makes sure it's
being check. Above steps now endup with menu being displayed allowing
'Exit' as the only option.
Link: http://lkml.kernel.org/r/1333570898-10505-2-git-send-email-jolsa@redhat.com
When a process exec()'s, all the maps are retired, but we keep the hist
entries around which hold references to those outdated maps.
If the same library gets mapped in for which we have hist entries, a new
map will be created. But when we take a perf entry hit within that map,
we'll find the existing hist entry with the older map.
This causes symbol translations to be done incorrectly. For example,
the perf entry processing will lookup the correct uptodate map entry and
use that to calculate the symbol and DSO relative address. But later
when we update the histogram we'll translate the address using the
outdated map file instead leading to conditions such as out-of-range
offsets in symbol__inc_addr_samples().
Therefore, update the map of the hist_entry dynamically at lookup/
creation time.
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net
We were only decaying the entries for the offsets that were associated
with an objdump line.
That way, when we accrued the whole instruction addr range, more than
100% was appearing in some cases in the live annotation TUI.
Fix it by not traversing the source code line at all, just iterate thru
the complete addr range decaying each one.
Reported-by: Mike Galbraith <mgalbraith@suse.de>
Link: http://lkml.kernel.org/n/tip-hcae5oxa22syjrnalsxz7s6n@git.kernel.org
TODO: Accrue the cycles in the skip_list to an idle total, and show this
on the 'top' UI, as suggested by Steven.
Link: http://lkml.kernel.org/n/tip-9nfecmgghgl5747rjxqpc28f@git.kernel.org
On a system running glibc trunk perf doesn't build:
CC builtin-sched.o
builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration]
Fix it by including sys/resource.h.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20120404084527.GA294@x4
Pull perf updates and fixes from Ingo Molnar:
"It's mostly fixes, but there's also two late items:
- preliminary GTK GUI support for perf report
- PMU raw event format descriptors in sysfs, to be parsed by tooling
The raw event format in sysfs is a new ABI. For example for the 'CPU'
PMU we have:
aldebaran:~> ll /sys/bus/event_source/devices/cpu/format/*
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/any
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/cmask
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/edge
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/event
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/inv
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/offcore_rsp
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/pc
-r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/umask
those lists of fields contain a specific format:
aldebaran:~> cat /sys/bus/event_source/devices/cpu/format/offcore_rsp
config1:0-63
So, those who wish to specify raw events can now use the following
event format:
-e cpu/cmask=1,event=2,umask=3
Most people will not want to specify any events (let alone raw
events), they'll just use whatever default event the tools use.
But for more obscure PMU events that have no cross-architecture
generic events the above syntax is more usable and a bit more
structured than specifying hex numbers."
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits)
perf tools: Remove auto-generated bison/flex files
perf annotate: Fix off by one symbol hist size allocation and hit accounting
perf tools: Add missing ref-cycles event back to event parser
perf annotate: addr2line wants addresses in same format as objdump
perf probe: Finder fails to resolve function name to address
tracing: Fix ent_size in trace output
perf symbols: Handle NULL dso in dso__name_len
perf symbols: Do not include libgen.h
perf tools: Fix bug in raw sample parsing
perf tools: Fix display of first level of callchains
perf tools: Switch module.h into export.h
perf: Move mmap page data_head offset assertion out of header
perf: Fix mmap_page capabilities and docs
perf diff: Fix to work with new hists design
perf tools: Fix modifier to be applied on correct events
perf tools: Fix various casting issues for 32 bits
perf tools: Simplify event_read_id exit path
tracing: Fix ftrace stack trace entries
tracing: Move the tracing_on/off() declarations into CONFIG_TRACING
perf report: Add a simple GTK2-based 'perf report' browser
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull ACPI & Power Management changes from Len Brown:
- ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup
- cpuidle evolving, more ARM use
- thermal sub-system evolving, ditto
- assorted other PM bits
Fix up conflicts in various cpuidle implementations due to ARM cpuidle
cleanups (ARM at91 self-refresh and cpu idle code rewritten into
"standby" in asm conflicting with the consolidation of cpuidle time
keeping), trivial SH include file context conflict and RCU tracing fixes
in generic code.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits)
ACPI throttling: fix endian bug in acpi_read_throttling_status()
Disable MCP limit exceeded messages from Intel IPS driver
ACPI video: Don't start video device until its associated input device has been allocated
ACPI video: Harden video bus adding.
ACPI: Add support for exposing BGRT data
ACPI: export acpi_kobj
ACPI: Fix logic for removing mappings in 'acpi_unmap'
CPER failed to handle generic error records with multiple sections
ACPI: Clean redundant codes in scan.c
ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed()
ACPI: consistently use should_use_kmap()
PNPACPI: Fix device ref leaking in acpi_pnp_match
ACPI: Fix use-after-free in acpi_map_lsapic
ACPI: processor_driver: add missing kfree
ACPI, APEI: Fix incorrect APEI register bit width check and usage
Update documentation for parameter *notrigger* in einj.txt
ACPI, APEI, EINJ, new parameter to control trigger action
ACPI, APEI, EINJ, limit the range of einj_param
ACPI, APEI, Fix ERST header length check
cpuidle: power_usage should be declared signed integer
These should not be in the Git history - they are auto-generated.
Extend the Makefile rules of the parser files to include the generation
run.
Link: http://lkml.kernel.org/r/20120327183335.GA27621@gmail.com
[ committer note: Fixed up O= handling ]
Sometimes users have turbostat running in interval mode
when they take processors offline/online.
Previously, turbostat would survive, but not gracefully.
Tighten up the error checking so turbostat notices
changesn sooner, and print just 1 line on change:
turbostat: re-initialized with num_cpus %d
Signed-off-by: Len Brown <len.brown@intel.com>
turbostat uses /dev/cpu/*/msr interface to read MSRs.
For modern systems, it reads 10 MSR/CPU. This can
be observed as 10 "Function Call Interrupts"
per CPU per sample added to /proc/interrupts.
This overhead is measurable on large idle systems,
and as Yoquan Song pointed out, it can even trick
cpuidle into thinking the system is busy.
Here turbostat re-schedules itself in-turn to each
CPU so that its MSR reads will always be local.
This replaces the 10 "Function Call Interrupts"
with a single "Rescheduling interrupt" per sample
per CPU.
On an idle 32-CPU system, this shifts some residency from
the shallow c1 state to the deeper c7 state:
# ./turbostat.old -s
%c0 GHz TSC %c1 %c3 %c6 %c7 %pc2 %pc3 %pc6 %pc7
0.27 1.29 2.29 0.95 0.02 0.00 98.77 20.23 0.00 77.41 0.00
0.25 1.24 2.29 0.98 0.02 0.00 98.75 20.34 0.03 77.74 0.00
0.27 1.22 2.29 0.54 0.00 0.00 99.18 20.64 0.00 77.70 0.00
0.26 1.22 2.29 1.22 0.00 0.00 98.52 20.22 0.00 77.74 0.00
0.26 1.38 2.29 0.78 0.02 0.00 98.95 20.51 0.05 77.56 0.00
^C
i# ./turbostat.new -s
0.27 1.20 2.29 0.24 0.01 0.00 99.49 20.58 0.00 78.20 0.00
0.27 1.22 2.29 0.25 0.00 0.00 99.48 20.79 0.00 77.85 0.00
0.27 1.20 2.29 0.25 0.02 0.00 99.46 20.71 0.03 77.89 0.00
0.28 1.26 2.29 0.25 0.01 0.00 99.46 20.89 0.02 77.67 0.00
0.27 1.20 2.29 0.24 0.01 0.00 99.48 20.65 0.00 78.04 0.00
cc: Youquan Song <youquan.song@intel.com>
Pull cpupower updates from Dominik Brodowski.
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils:
cpupower tools: add install target to the debug tools' makefiles
cpupower tools: allow to build debug tools in a separate directory too
cpupower: Fix broken mask values
cpupower tool: allow to build in a separate directory
cpupower tool: makefile: simplify the recipe used to generate cpupower.pot target
cpupower tool: remove use of undefined variables from the clean target of the top makefile
cpupower: Fix linking with --as-needed
cpupower: Remove unneeded code and by that fix a memleak
cpupower: Fix number of idle states
cpupower: Unify cpupower-frequency-* manpages
cpupower: Add cpupower-idle-info manpage
cpupower: AMD fam14h/Ontario monitor can also be used by fam12h cpus
cpupower: Better interface for accessing AMD pci registers
We were not noticing it because symbol__inc_addr_samples was erroneously
dropping samples that hit the last byte in a function.
Working on a fix for a problem reported by David Miller, Stephane
Eranian and Sorin Dumitru, where addresses < sym->start were causing
problems, I noticed this other problem.
Cc: Sorin Dumitru <dumitru.sorin87@gmail.com>
Link: http://lkml.kernel.org/n/tip-pqjaq4cr1xs2xen73pjhbav4@git.kernel.org
turbostat -s
cuts down on the amount of output, per user request.
also treak some output whitespace and the man page.
The commit 89812fc81f8d ("perf tools: Add parser generator for events
parsing") changed event parsing engine but missed the ref-cycles event.
Add it.
Link: http://lkml.kernel.org/r/1333016517-10591-1-git-send-email-namhyung.kim@lge.com
hugepage-mmap.c, hugepage-shm.c and map_hugetlb.c in Documentation/vm are
simple pass/fail tests, It's better to promote them to
tools/testing/selftests.
Thanks suggestion of Andrew Morton about this. They all need firstly
setting up proper nr_hugepages and hugepage-mmap need to mount hugetlbfs.
So I add a shell script run_vmtests to do such work which will call the
three test programs and check the return value of them.
Changes to original code including below:
a. add run_vmtests script
b. return error when read_bytes mismatch with writed bytes.
c. coding style fixes: do not use assignment in if condition
[akpm@linux-foundation.org: build the targets before trying to execute them]
[akpm@linux-foundation.org: Documentation/vm/ no longer has a Makefile. Fixes "make clean"]
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
We have tools/vm/ folder for vm tools, so move slabinfo.c from tools/slub/
to tools/vm/
Acked-by: Christoph Lameter <cl@linux.com>
tools/ is the better place for vm tools which are used by many people.
Moving them to tools also make them open to more users instead of hide in
Documentation folder.
This patch moves page-types.c to tools/vm/page-types.c. Also add a
Makefile in tools/vm and fix two coding style problems: a) change const
arrary to 'const char * const', b) change a space to tab for indent.
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
So a "make run_tests" will build the tests before trying to run them.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Remove the run_tests script and launch the selftests by calling "make
run_tests" from the selftests top directory instead. This delegates to
the Makefile in each selftest directory, where it is decided how to launch
the local test.
This removes the need to add each selftest directory to the now removed
"run_tests" top script.
Cc: Dave Young <dyoung@redhat.com>
Therefore, in symbol__get_source_line(), use map__rip_2objdump
instead of calling map->unmap_ip() unconditionally.
Link: http://lkml.kernel.org/r/20120325.162812.59519424882536855.davem@davemloft.net
If DIE entries corresponding to declarations appear before definition
entry, probe finder returns error instead of continuing to look further
for a definition entry.
This patch ensures we reach to the DIE entry corresponding to the
definition and get the function address.
V2: A simpler solution based on Masami's suggestion.
Signed-off-by: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/4F703FB9.9020407@linux.vnet.ibm.com
Pull networking fixes from David Miller:
1) Name string overrun fix in gianfar driver from Joe Perches.
2) VHOST bug fixes from Michael S. Tsirkin and Nadav Har'El
3) Fix dependencies on xt_LOG netfilter module, from Pablo Neira Ayuso.
4) Fix RCU locking in xt_CT, also from Pablo Neira Ayuso.
5) Add a parameter to skb_add_rx_frag() so we can fix the truesize
adjustments in the drivers that use it. The individual drivers
aren't fixed by this commit, but will be dealt with using follow-on
commits. From Eric Dumazet.
6) Add some device IDs to qmi_wwan driver, from Andrew Bird.
7) Fix a potential rcu_read_lock() imbalancein rt6_fill_node(). From
Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: fix a potential rcu_read_lock() imbalance in rt6_fill_node()
net: add a truesize parameter to skb_add_rx_frag()
gianfar: Fix possible overrun and simplify interrupt name field creation
USB: qmi_wwan: Add ZTE (Vodafone) K3570-Z and K3571-Z net interfaces
USB: option: Ignore ZTE (Vodafone) K3570/71 net interfaces
USB: qmi_wwan: Add ZTE (Vodafone) K3565-Z and K4505-Z net interfaces
qlcnic: Bug fix for LRO
netfilter: nf_conntrack: permanently attach timeout policy to conntrack
netfilter: xt_CT: fix assignation of the generic protocol tracker
netfilter: xt_CT: missing rcu_read_lock section in timeout assignment
netfilter: cttimeout: fix dependency with l4protocol conntrack module
netfilter: xt_LOG: use CONFIG_IP6_NF_IPTABLES instead of CONFIG_IPV6
vhost: fix release path lockdep checks
vhost: don't forget to schedule()
tools/virtio: stub out strong barriers
tools/virtio: add linux/hrtimer.h stub
tools/virtio: add linux/module.h stub
We should use "[unknown]" in this case, in concert with the code in
_hist_entry__dso_snprintf().
Otherwise we'll crash when recomputing the histogram column lengths in
hists__calc_col_len().
Link: http://lkml.kernel.org/r/20120325.162822.2267799792062571623.davem@davemloft.net
That causes us to end up using the XPG version of basename which can
modify it's argument.
Link: http://lkml.kernel.org/r/20120327.000301.1122788061724345175.davem@davemloft.net
In perf_event__parse_sample(), the array variable was not incremented
by the amount of data used by the raw_data.
That was okay until we added PERF_SAMPLE_BRANCH_STACK which depends on
the array variable pointing to the beginning of the branch stack data.
But that was not the case if branch stack was combined with raw mode
sampling. That led to bogus branch stack addresses and count.
The bug would show up with:
$ perf record -R -b foo
This patch fixes the problem by correctly moving the array pointer
forward for RAW samples.
Link: http://lkml.kernel.org/r/20120317222317.GA8803@quad
[ committer note: Fix also later submitted by Jiri Olsa ]
The callchain stdio mode display was written using a sorted by symbol
report. In this mode we have only one callchain root per hist so we
forgot to handle cases where we have multiple callchain root, as in per
dso sorting for example.
Fix this by handling these roots like any other branch, with the hist as
the parent.
Before:
1.97% libpthread-2.12.1.so
--- __libc_write
create_worker
bench_sched_messaging
cmd_bench
run_builtin
main
__libc_start_main
--- __libc_read
create_worker
cmd_bench
run_builtin
main
__libc_start_main
After:
|--36.97%-- __libc_write
| create_worker
| cmd_bench
| run_builtin
| main
| __libc_start_main
|--31.47%-- __libc_read
| create_worker
| cmd_bench
| run_builtin
| main
| __libc_start_main
Single roots keep their entry without percentage because they have
the same overhead than the hist they refer to. ie: 100% in fractal
mode and the percentage of the hist in graph mode:
0.00% [k] reschedule_interrupt
--- default_idle
amd_e400_idle
cpu_idle
start_secondary
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Link: http://lkml.kernel.org/r/1332526010-15400-1-git-send-email-fweisbec@gmail.com
