Signed-off-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
[linux@dominikbrodowski.net: fix .gitignore]
As cpupowerutils is intended to be included into the kernel sources,
use the kernel versioning instead of a custom version.
The script utils/version-gen.sh is largely based on the script already
found in tools/perf/util/PERF-VERSION-GEN .
Use the quiet/verbose mechanism found in kernel tools, without
relying on the special tool "ccdv"
CPU power consumption vs performance tuning is no longer
limited to CPU frequency switching anymore: deep sleep states,
traditional dynamic frequency scaling and hidden turbo/boost
frequencies are tied close together and depend on each other.
The first two exist on different architectures like PPC, Itanium and
ARM, the latter (so far) only on X86. On X86 the APU (CPU+GPU) will
only run most efficiently if CPU and GPU has proper power management
in place.
Users and Developers want to have *one* tool to get an overview what
their system supports and to monitor and debug CPU power management
in detail. The tool should compile and work on as many architectures
as possible.
Once this tool stabilizes a bit, it is intended to replace the
Intel-specific tools in tools/power/x86
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest:
ktest: Fix bug when ADD_CONFIG is set but MIN_CONFIG is not
ktest: Keep fonud configs separate from default configs
ktest: Add prompt to use OUTPUT_MIN_CONFIG
ktest: Use Kconfig dependencies to shorten time to make min_config
ktest: Add test type make_min_config
ktest: Require one TEST_START in config file
ktest: Add helper function to avoid duplicate code
ktest: Add IGNORE_WARNINGS to ignore warnings in some patches
ktest: Fix tar extracting of modules to target
ktest: Have the testing tmp dir include machine name
ktest: Add POST/PRE_BUILD options
ktest: Allow initrd processing without modules defined
ktest: Have LOG_FILE evaluate options as well
ktest: Have wait on stdio honor bug timeout
ktest: Implement our own force min config
ktest: Add TEST_NAME option
ktest: Add CONFIG_BISECT_GOOD option
ktest: Add detection of triple faults
ktest: Notify reason to break out of monitoring boot
So those friggin "spurious" PERF_RECORD_MMAP events were actually a
brain fart copy'n'paste error in the python binding, doh. I.e. they
weren't MMAPs, just SAMPLEs.
Fix it by providing routines for these events instead of using the MMAP
ones.
Cc: David Ahern <dsahern@gmail.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-b0rc8y5jd03f9f11kftodvkm@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
To remove the last case of access to the FD() macro outside the library.
Inspired by a patch by Borislav that moved the FD() macro to util.h, for
namespace concerns I rather preferred to constrain it to ev{sel,list}.c.
Cc: Borislav Petkov <bp@amd64.org>
Link: http://lkml.kernel.org/n/tip-qn893qsstcg366tkucu649qj@git.kernel.org
'irq-core-for-linus' and 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Make rwsem.S depend on CONFIG_RWSEM_XCHGADD_ALGORITHM
* 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
debug: Make CONFIG_EXPERT select CONFIG_DEBUG_KERNEL to unhide debug options
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Remove unused CHECK_IRQ_PER_CPU()
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools, x86: Fix 32-bit compile on 64-bit system
The readlink() function doesn't append a null byte to buf. So we should
zero out buf with zalloc(). Or we'll see sometimes error like this:
[root@intel-s3e36-01]~# /usr/bin/perf buildid-cache -a /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko -v
Adding f64ba8efd5f53c7ad332fc17db1d21de309038e1 /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko: Ok
[root@intel-s3e36-01]~# /usr/bin/perf buildid-cache -r /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko -v
Removing f64ba8efd5f53c7ad332fc17db1d21de309038e1 /lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko: FAIL
/lib/modules/2.6.32-130.el6.x86_64/kernel/crypto/twofish_common.ko wasn't in the cache
The change in build_id_cache__add_s() is a defense.
Tested-by: Jiri Olsa <jolsa@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20110718031314.GA5802@hpt.nay.redhat.com
Signed-off-by: Han Pingtian <phan@redhat.com>
Builds for 32-bit perf binaries on a 64-bit host currently fail
with this error:
bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages:
bench/../../../arch/x86/lib/memcpy_64.S:29: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:34: Error: invalid instruction suffix for `movs'
bench/../../../arch/x86/lib/memcpy_64.S:50: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:61: Error: bad register name `%rdi'
The problem is the detection of the host arch without considering passed in
flags. This change fixes 32-bit builds via:
make EXTRA_CFLAGS=-m32
and 64-bit builds still reference the memcpy_64.S.
Signed-off-by: David Ahern <dsahern@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/1310420304-21452-1-git-send-email-dsahern@gmail.com
Use preset debugfs path instead of hardcoded one.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: acme@redhat.com
Cc: a.p.zijlstra@chello.nl
Cc: paulus@samba.org
Link: http://lkml.kernel.org/r/1310635534-4013-4-git-send-email-jolsa@redhat.com
Adding builtin test for parse_events function, which is
responsible for parsing/processing "-e" option for
stat/top/record commands.
This new test will run within the builtin test command suite
(perf test).
One or several tests were added for each type of event.
More tests could be added easily if needed.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1310635534-4013-3-git-send-email-jolsa@redhat.com
Moving out the option parameter from parse_events function,
and adding new parse_events_option function instead.
The option parameter is used only to carry "struct perf_evlist"
pointer for chaining new events. Putting it away, enable us
to call parse_events from other places without using the
option parameter.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1310635534-4013-2-git-send-email-jolsa@redhat.com
Non-callchain path is using al.addr which prints as:
openssl 14564 17672.003587: 7862d _x86_64_AES_encrypt_compact
This should be sample->ip to print as:
openssl 14564 17672.003587: 3f7867862d _x86_64_AES_encrypt_compact
Cc: acme@ghostprotocols.net
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/1306768587-15376-1-git-send-email-dsahern@gmail.com
The perf_event_attr struct has two __u32's at the top and
they need to be swapped individually.
With this change I was able to analyze a perf.data collected in a
32-bit PPC VM on an x86 system. I tested both 32-bit and 64-bit
binaries for the Intel analysis side; both read the PPC perf.data
file correctly.
-v2:
- changed the existing perf_event__attr_swap() to swap only elements
of perf_event_attr and exported it for use in swapping the
attributes in the file header
- updated swap_ops used for processing events
Link: http://lkml.kernel.org/r/1310754849-12474-1-git-send-email-dsahern@gmail.com
Add "node" as a simple alias for NODE cache events.
The addition of NODE cache events broke the parse_alias
function, so any mismatched event caused the segfault, like:
# ./perf stat -e krava ls
The hw_cache/hw_cache_op/hw_cache_result arrays needs to follow
PERF_COUNT_HW_CACHE_*MAX enums. Adding those MAXs to be size
of those arrays, so possible ommision in future wil not lead to
segfault.
Adding read/write/prefetch as allowed operations for node cache
event.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/20110713205818.GB7827@jolsa.brq.redhat.com
Looks like I was going to stick the brand string
in the verbose ouput, but didn't get around to it.
Signed-off-by: Len Brown <len.brown@intel.com>
The MIN_CONFIG is a single config that is considered to have all the
configs that are required to boot the box.
ADD_CONFIG is a list of configs that we add that may contain configs
known to be broken (set off) or just configs that we want every box to
have and this can include shared configs.
If a config has no MIN_CONFIG defined, but has multiple files defined
for the ADD_CONFIG, the test will die, because the MIN_CONFIG will
default to ADD_CONFIG. The problem is the code to open MIN_CONFIG
expects a string of one file, not multiple, and the open will fail.
Since the real minconfig that is used is a concatination of MIN_CONFIG
and ADD_CONFIG files, we change the code to open that instead of
whatever MIN_CONFIG defaults to.
The IGNORE_CONFIG file holds the configs that we don't want to change
(with their proper settings). But on start up, the make noconfig is
executed, and the configs that are on are also put into the ignore
config category. But these are configs that were forced on by the
kconfig scripts and not something that we found must be enabled to boot
our machine. By keeping the configs that are forced on by default,
separate from the configs we found that are required to boot the box, we
can get a much more interesting IGNORE_CONFIG. In fact, the
IGNORE_CONFIG can usually end up being the must have configs to boot,
and only have 6 or 7 configs set.
If the defined OUTPUT_MIN_CONFIG in the make_min_config test exists,
then give a prompt to ask the user if they want to use that config
instead, as it is very often the case, especially when the test has been
interrupted. The OUTPUT_MIN_CONFIG is usually the config that one wants
to use to continue the test where they left off.
But if START_MIN_CONFIG is defined (thus the MIN_CONFIG is not the
default), then do not prompt, as it will be annoying if the user has
this as one of many tests, and the test pauses waiting for input, while
the user is sleeping.
To save time, the test does not just grab any option and test
it. The Kconfig files are examined to determine the dependencies
of the configs. If a config is chosen that depends on another
config, that config will be checked first. By checking the
parents first, we can eliminate whole groups of configs that
may have been enabled.
For example, if a USB device config is chosen and depends on
CONFIG_USB, the CONFIG_USB will be tested before the device.
If CONFIG_USB is found not to be needed, it, as well as all
configs that depend on it, will be disabled and removed from
the current min_config.
Note, the code from streamline_config (make localmodconfig)
was copied and used to find the dependencies in the Kconfig file.
After doing a make localyesconfig, your kernel configuration may
not be the most useful minimum configuration. Having a true minimum
config that you can use against other configs is very useful if
someone else has a config that breaks on your code. By only forcing
those configurations that are truly required to boot your machine
will give you less of a chance that one of your set configurations
will make the bug go away. This will give you a better chance to
be able to reproduce the reported bug matching the broken config.
Note, this does take some time, and may require you to run the
test over night, or perhaps over the weekend. But it also allows
you to interrupt it, and gives you the current minimum config
that was found till that time.
Note, this test automatically assumes a BUILD_TYPE of oldconfig
and its test type acts like boot.
TODO: add a test version that makes the config do more than just
boot, like having network access.
Support adding probes on offline kernel modules. This enables
perf-probe to trace kernel-module init functions via perf-probe.
If user gives the path of module with -m option, perf-probe
expects the module is offline.
This feature works with --add, --funcs, and --vars.
E.g)
# perf probe -m /lib/modules/`uname -r`/kernel/fs/btrfs/btrfs.ko \
-a "extent_io_init:5 extent_state_cache"
Add new events:
probe:extent_io_init (on extent_io_init:5 with extent_state_cache)
probe:extent_io_init_1 (on extent_io_init:5 with extent_state_cache)
You can now use it on all perf tools, such as:
perf record -e probe:extent_io_init_1 -aR sleep 1
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20110627072751.6528.10230.stgit@fedora15
Add probed module name and ":" in front of function name
if -m module option is given. In the result, the symbol
name passed to kprobe-tracer becomes MODULE:FUNCTION,
so that kallsyms can solve it as a symbol in the module
correctly.
Link: http://lkml.kernel.org/r/20110627072745.6528.26416.stgit@fedora15
Introduce debuginfo to encapsulate dwarf information.
This new object allows us to reuse and expand debuginfo easily.
Link: http://lkml.kernel.org/r/20110627072739.6528.12438.stgit@fedora15
Move dwarf library related routines to dwarf-aux.{c,h}.
This includes several minor changes.
- Add simple documents for each API.
- Rename die_find_real_subprogram() to die_find_realfunc()
- Rename line_walk_handler_t to line_walk_callback_t.
- Minor cleanups.
Link: http://lkml.kernel.org/r/20110627072727.6528.57647.stgit@fedora15
Since there are dwarf_bitsize, dwarf_bitoffset and dwarf_bytesize
defined in libdw, we don't need die_get_bit_size, die_get_bit_offset
and die_get_byte_size anymore.
Link: http://lkml.kernel.org/r/20110627072721.6528.2747.stgit@fedora15
Since strtailcmp() is enough generic, it should be defined in string.c.
Link: http://lkml.kernel.org/r/20110627072715.6528.10677.stgit@fedora15
Since die_find/walk* callbacks use DIE_FIND_CB_FOUND for
both of failed and found cases, it should be "END"
instead "FOUND" for avoiding confusion.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20110627072709.6528.45706.stgit@fedora15
While attempting to create a timechart of boot up I found perf didn't
tolerate modules being loaded/unloaded. This patch fixes this by
reading the file once and then writing the size read at the correct
point in the file. It also simplifies the code somewhat.
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
Signed-off-by: Michael Neuling <mikey@neuling.org>
Link: http://lkml.kernel.org/r/10011.1310614483@neuling.org
Add an option to perf report/annotate/script to specify which
CPUs to operate on. This enables us to take a single system wide
profile and analyse each CPU (or group of CPUs) in isolation.
This was useful when profiling a multiprocess workload where the
bottleneck was on one CPU but this was hidden in the overall
profile. Per process and per thread breakdowns didn't help
because multiple processes were running on each CPU and no
single process consumed an entire CPU.
The patch converts the list of CPUs returned by cpu_map__new
into a bitmap for fast lookup. I wanted to use -C to be
consistent with perf top/record/stat, but unfortunately perf
report already uses -C <comms>.
v2: Incorporate suggestions from David Ahern:
- Added -c to perf script
- Check that SAMPLE_CPU is set when -c is used
- Update documentation
v3: Create perf_session__cpu_bitmap()
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/20110704215750.11647eb9@kryten
Update the statistics handling and the slabinfo tool to include the new
statistics in the reports it generates.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Previously, when you want perf-stat to output the statistics in
csv mode, no information of the noise will be printed out.
For example right now we output this --repeat information:
./perf stat -r3 -x, sleep 1
1.164789,task-clock
8,context-switches
0,CPU-migrations
219,page-faults
3337800,cycles
With this patch, the output will be appended with an additional
entry for the noise value:
1.164789,task-clock,3.75%
8,context-switches,75.00%
0,CPU-migrations,100.00%
219,page-faults,0.00%
3337800,cycles,3.36%
Signed-off-by: Zhengyu He <zhengyuh@google.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Link: http://lkml.kernel.org/r/1308861942-4945-1-git-send-email-zhengyuh@google.com
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
Merge reason: Pick up the latest fixes.
We don't need to display the parent field if the parent
sorting machinery is only used for parent filtering
(as in "-p foo").
However if parent filtering is used in combination with
explicit parent sorting ( -s parent), we want to
display it.
Result with:
perf report -p kernel_thread -s parent
Before:
# Overhead Parent symbol
0.07%
--- ioread8
ata_sff_check_status
ata_sff_tf_load
ata_sff_qc_issue
ata_bmdma_qc_issue
ata_qc_issue
ata_scsi_translate
ata_scsi_queuecmd
scsi_dispatch_cmd
scsi_request_fn
__blk_run_queue
__make_request
generic_make_request
submit_bio
submit_bh
journal_submit_commit_record
jbd2_journal_commit_transaction
kjournald2
kthread
kernel_thread_helpe
After:
0.07% kernel_thread_helper
--- ioread8
ata_sff_tf_load
ata_sff_qc_issue
ata_bmdma_qc_issue
ata_qc_issue
ata_scsi_translate
ata_scsi_queuecmd
scsi_dispatch_cmd
scsi_request_fn
__blk_run_queue
__make_request
submit_bio
submit_bh
kjournald2
kthread
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Sam Liao <phyomh@gmail.com>
So that the parent sort dimension can be registered twice: once
if we add it as an explicit sort dimension (-s parent) and twice
if we request a parent filter (-p foo).
We'll have only one parent sort dimension in the end but this
allows to override the default parent filter with we gave in "-p"
option. The goal of this is to prepare to allow the use of
"-s parent" and "-p foo" at the same time, ie: sort by filtered
parent.
As for newt ui, don't display entries that have been marked
as ignored.
The practical current effect of this is to make parent
filtering really working. Before, entries that were ignored
were given a null parent but were still displayed. This
resulted in some weird effects:
# Overhead Command Shared Object Symbol
^A
--- __lock_acquire
|--95.97%-- lock_acquire
| |--30.75%-- _raw_spin_lock
Discard these from the stdio display.
These are probably some old leftovers.
These don't need to be globally visible.
Add "caller/callee" option to support inverted butterfly report,
in the inverted report (with caller option), the call graph start
from the callee's ancestor. Users can use such view to catch system's
performance bottleneck from a sysprof like view. Using this option
with specified sort order like pid gives us high level view of call
graph statistics.
Also add "-G" alias for inverted call graph.
Signed-off-by: Sam Liao <phyomh@gmail.com>
'timers-urgent-for-linus' and 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
tools/perf: Fix static build of perf tool
tracing: Fix regression in printk_formats file
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
generic-ipi: Fix kexec boot crash by initializing call_single_queue before enabling interrupts
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Make watchdog robust vs. interruption
timerfd: Fix wakeup of processes when timer is cancelled on clock change
x86, MAINTAINERS: Add x86 MCE people
x86, efi: Do not reserve boot services regions within reserved areas
