path: root/tools
2009-12-14perf sched: Fix build failure on sparcDavid Miller
Here, tvec->tv_usec is "unsigned int" not "unsigned long". Since the type is different on every platform, it's probably best to just use long printf formats and cast. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091213.235622.53363059.davem@davemloft.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf bench: Add "all" pseudo subsystem and "all" pseudo suiteHitoshi Mitake
This patch adds a new "all" pseudo subsystem and an "all" pseudo suite. These are for testing all subsystem and its all suite, or all suite of one subsystem. (This patch also contains a few trivial comment fixes for bench/* and output style fixes. I judged that there are no necessity to make them into individual patch.) Example of use: | % ./perf bench sched all # Test all suites of sched subsystem | # Running sched/messaging benchmark... | # 20 sender and receiver processes per group | # 10 groups == 400 processes run | | Total time: 0.414 [sec] | | # Running sched/pipe benchmark... | # Extecuted 1000000 pipe operations between two tasks | | Total time: 10.999 [sec] | | 10.999317 usecs/op | 90914 ops/sec | | % ./perf bench all # Test all suites of all subsystems | # Running sched/messaging benchmark... | # 20 sender and receiver processes per group | # 10 groups == 400 processes run | | Total time: 0.420 [sec] | | # Running sched/pipe benchmark... | # Extecuted 1000000 pipe operations between two tasks | | Total time: 11.741 [sec] | | 11.741346 usecs/op | 85169 ops/sec | | # Running mem/memcpy benchmark... | # Copying 1MB Bytes from 0x7ff33e920010 to 0x7ff3401ae010 ... | | 808.407437 MB/Sec Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1260691319-4683-1-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf tools: Introduce perf_session classArnaldo Carvalho de Melo
That does all the initialization boilerplate, opening the file, reading the header, checking if it is valid, etc. And that will as well have the threads list, kmap (now) global variable, etc, so that we can handle two (or more) perf.data files describing sessions to compare. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260573842-19720-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Ditch dso->find_symbolArnaldo Carvalho de Melo
It is always wired to dso__find_symbol. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260564999-13371-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Allow lookups by symbol name tooArnaldo Carvalho de Melo
Configurable via symbol_conf.sort_by_name, so that the cost of an extra rb_node on all 'struct symbol' instances is not paid by tools that only want to decode addresses. How to use it: symbol_conf.sort_by_name = true; symbol_init(&symbol_conf); struct map *map = map_groups__find_by_name(kmaps, MAP__VARIABLE, "[kernel.kallsyms]"); if (map == NULL) { pr_err("couldn't find map!\n"); kernel_maps__fprintf(stdout); } else { struct symbol *sym = map__find_symbol_by_name(map, sym_filter, NULL); if (sym == NULL) pr_err("couldn't find symbol %s!\n", sym_filter); else pr_info("symbol %s: %#Lx-%#Lx \n", sym_filter, sym->start, sym->end); } Looking over the vmlinux/kallsyms is common enough that I'll add a variable to the upcoming struct perf_session to avoid the need to use map_groups__find_by_name to get the main vmlinux/kallsyms map. The above example looks on the 'variable' symtab, but it is just like that for the functions one. Also the sort operation is done when we first use map__find_symbol_by_name, in a lazy way. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260564622-12392-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Add missing "Variables" entry to map_type__nameArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260552208-6824-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Add support for 'variable' symtabsArnaldo Carvalho de Melo
Example: { u64 addr = strtoull(sym_filter, NULL, 16); struct map *map = map_groups__find(kmaps, MAP__VARIABLE, addr); if (map == NULL) pr_err("couldn't find map!\n"); else { struct symbol *sym = map__find_symbol(map, addr, NULL); if (sym == NULL) pr_err("couldn't find addr!\n"); else pr_info("addr %#Lx is in %s global var\n", addr, sym->name); } exit(0); } Added just after symbol__init() call in 'perf top', then: { u64 addr = strtoull(sym_filter, NULL, 16); struct map *map = map_groups__find(kmaps, MAP__VARIABLE, addr); if (map == NULL) pr_err("couldn't find map!\n"); else { struct symbol *sym = map__find_symbol(map, addr, NULL); if (sym == NULL) pr_err("couldn't find addr!\n"); else pr_info("addr %#Lx is in %s global var\n", addr, sym->name); } exit(0); } [root@doppio linux-2.6-tip]# grep ' [dD] ' /proc/kallsyms | grep ' sched' ffffffff817827d8 d sched_nr_latency ffffffff81782ce0 d sched_domains_mutex ffffffff8178c070 d schedstr.22423 ffffffff817909a0 d sched_register_mutex ffffffff81823490 d sched_feat_names ffffffff81823558 d scheduler_running ffffffff818235b8 d sched_clock_running ffffffff818235bc D sched_clock_stable ffffffff81824f00 d sched_switch_trace [root@doppio linux-2.6-tip]# perf top -s 0xffffffff817827d9 addr 0xffffffff817827d9 is in sched_nr_latency global var [root@doppio linux-2.6-tip]# perf top -s ffffffff81782ce0 addr 0xffffffff81782ce0 is in sched_domains_mutex global var [root@doppio linux-2.6-tip]# [root@doppio linux-2.6-tip]# perf top -s ffffffff81782ce0 --vmlinux OFF The file OFF cannot be used, trying to use /proc/kallsyms...addr 0xffffffff81782ce0 is in sched_domains_mutex global var [root@doppio linux-2.6-tip]# perf top -s ffffffff818235bc --vmlinux OFF The file OFF cannot be used, trying to use /proc/kallsyms...addr 0xffffffff818235bc is in sched_clock_stable global var [root@doppio linux-2.6-tip]# So it works with both /proc/kallsyms and with ELF symtabs, either the one on the vmlinux explicitely passed via --vmlinux or in one in the vmlinux_path that matches the buildid for the running kernel or the one found in the buildid header section in a perf.data file. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260550239-5372-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Introduce ELF counterparts to symbol_type__is_aArnaldo Carvalho de Melo
For selecting the right types of symbols in ELF symtabs. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260550239-5372-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Introduce symbol_type__is_aArnaldo Carvalho de Melo
For selecting the right types of symbols in /proc/kallsyms, will be followed by elf_symbol_type__is_a, for the same purpose on ELF symtabs. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260550239-5372-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-12perf symbols: Rename kthreads to kmaps, using another abstraction for itArnaldo Carvalho de Melo
Using a struct thread instance just to hold the kernel space maps (vmlinux + modules) is overkill and confuses people trying to understand the perf symbols abstractions. The kernel maps are really present in all threads, i.e. the kernel is a library, not a separate thread. So introduce the 'map_groups' abstraction and use it for the kernel maps, now in the kmaps global variable. It, in turn, will move, together with the threads list to the perf_file abstraction, so that we can support multiple perf_file instances, needed by perf diff. Brainstormed-with: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260550239-5372-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-11perf tools: Allow building for ARMJamie Iles
Add definitions of rmb() and cpu_relax() and include the ARM unistd.h header. The __kuser_memory_barrier helper in the helper page is used to provide the correct memory barrier depending on the CPU type. [ The rmb() will work on v6 and v7, segfault on v5. Dynamic detection to add v5 support will be added later. ] Signed-off-by: Jamie Iles <jamie.iles@picochip.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mikael Pettersson <mikpe@it.uu.se> LKML-Reference: <1260534009-5394-1-git-send-email-jamie.iles@picochip.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-11perf tools: Allow cross compilingJamie Iles
For embedded platforms, we want to be able to build the perf tools on a build machine to run on a different arch. This patch allows $CROSS_COMPILE to set the cross compiler. Additionally, if NO_LIBPERL is set, then don't use perl include paths as they will be for the host arch. Signed-off-by: Jamie Iles <jamie.iles@picochip.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1260523260-15694-2-git-send-email-jamie.iles@picochip.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf kmem: Fix unused argument build warningIngo Molnar
Fix: builtin-kmem.c: In function 'parse_caller_opt': builtin-kmem.c:690: error: unused parameter 'arg' builtin-kmem.c: In function 'parse_alloc_opt': builtin-kmem.c:697: error: unused parameter 'arg' Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <4B20A195.8030106@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf symbols: perf_header__read_build_ids() offset'n'size should be u64Arnaldo Carvalho de Melo
As off_t is a long, so breaking things on 32-bit land. Now buildids work on 32-bit land. [root@ana ~]# uname -a Linux ana.ghostprotocols.net 2.6.31.6-162.fc12.i686 #1 SMP Fri Dec 4 01:09:09 EST 2009 i686 i686 i386 GNU/Linux [root@ana ~]# perf buildid-list | tail -5 136ee6792ba2ae57870ecd87369f4ae3194d5b27 /lib/libreadline.so.6.0 d202dcb1ad48d140065783657d37ae3f2d9ab83f /usr/bin/gdb 0a56c0c00dcc2e9e581ae9997f31957c9c4671df /usr/lib/libdwarf.so.0.0 5f9e6ac95241cbb3227608e0ff2a2e0cbbe72439 /home/acme/bin/perf 925d19eccc2ddb1c9d74dd178a011426f1b124a8 /bin/sleep [root@ana ~]# Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260396578-19116-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf symbols: dsos__read_build_ids() should read both user and kernel buildidsArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260396578-19116-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf tools: Align long options which have no short formsLi Zefan
Before: $ ./perf kmem ... -l, --line <num> show n lines --raw-ip show raw ip instead of symbol After: $ ./perf kmem ... -l, --line <num> show n lines --raw-ip show raw ip instead of symbol Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <4B20A1A9.3040104@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf kmem: Show usage if no option is specifiedLi Zefan
As Ingo suggested, make "perf kmem" show help information. "perf kmem stat [--caller] [--alloc] .." will show memory statistics. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <4B20A195.8030106@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf sched: Add max delay time snapshotFrederic Weisbecker
When we have a maximum latency reported for a task, we need a convenient way to find the matching location to the raw traces or to perf sched map that shows where the task has been eventually scheduled in. This gives a pointer to retrieve the events that occured during this max latency. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260391208-6808-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-10perf tools: Correct size given to memsetJulia Lawall
Memset should be given the size of the structure, not the size of the pointer. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T *x; expression E; @@ memset(x, E, sizeof( + * x)) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <Pine.LNX.4.64.0912092026000.1870@ask.diku.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf sched: Fix for getting task's execution timeXiao Guangrong
In current code, task's execute time is got by reading '/proc/<pid>/sched' file, it's wrong if the task is created by pthread_create(), because every thread task has same pid. This way also has two demerits: 1: 'perf sched replay' can't work if the kernel is not compiled with the 'CONFIG_SCHED_DEBUG' option 2: perf tool should depend on proc file system So, this patch uses PERF_COUNT_SW_TASK_CLOCK to get task's execution time instead of reading /proc file. Changelog v2 -> v3: use PERF_COUNT_SW_TASK_CLOCK instead of rusage() as Ingo's suggestion Reported-by: Torok Edwin <edwintorok@gmail.com> Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Xiao Guangrong <ericxiao.gr@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <4B1F7322.80103@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Update perf-probe documentMasami Hiramatsu
Add --list and --del option descriptions to perf-probe.txt. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091208220330.10142.73296.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Support --del optionMasami Hiramatsu
Support perf probe --del <event> option. Currently, perf probe can have only one event for each --del option. If you'd like to delete several probe events, you need to specify --del for each events. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220323.10142.62079.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Support vmlinux on cwd by defaultMasami Hiramatsu
Support vmlinux on current working direcotry by default and also update file-open messages. Now perf probe searches ./vmlinux too. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220309.10142.33040.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Remove event suffix number _0Masami Hiramatsu
Remove event suffix number _0 if it is the first. The first event has no suffix, and from the second, each event has suffix number counted from _1. This reduces typing cost :-). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220301.10142.50031.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Fix add-probe command syntax without --add optionMasami Hiramatsu
Fix add-probe command syntax without --add option. perf-probe supports add-probe command without --add option. But it treats each argument as an event definition. e.g. perf probe func arg1 arg2 is interpreted as perf probe --add func --add arg1 --add arg2 But it may be useless in many cases. This patch fixes this syntax to fold those arguments into one event definition if there is no --add option. With this change, above command is interpreted as below; perf probe --add "func arg1 arg2" Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220254.10142.73767.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Change probe-added message more user-friendlyMasami Hiramatsu
Change probe-added message more user-friendly expression and show usage of new events. Before: Added new event: p:probe/schedule_0 schedule+10 prev=%ax cpu=%bx After: Added new event: probe:schedule_1 (on schedule+1 with prev cpu) You can now use it on all perf tools, such as: perf record -e probe:schedule_1 -a sleep 1 Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220247.10142.91642.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-09perf probe: Change event list formatMasami Hiramatsu
Change event list format for user readability. perf probe --list shows event list in "[GROUP:EVENT] EVENT-DEFINITION" format, but this format is different from the output of perf-list, and EVENT-DEFINITION is a bit blunt. This patch changes the format to more user friendly one. Before: [probe:schedule_0] schedule+10 prev cpu After: probe:schedule_0 (on schedule+10 with prev cpu) Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091208220240.10142.42916.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf probe: Use pr_debug for debug messageMasami Hiramatsu
Use pr_debug() for "missing vmlinux" debugging message. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091207170059.19230.51459.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf probe: Check e_snprintf() format stringMasami Hiramatsu
Check e_snprintf() format string by gcc, and fix a bug of e_snprintf() caller. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091207170053.19230.7690.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf probe: Fix event namelist to duplicate stringMasami Hiramatsu
Fix event namelist to duplicate string. Without duplicating, adding multiple probes causes stack overwrite bug, because it reuses a buffer on stack while the buffer is already added in the namelist. String duplication solves this bug because only contents of the buffer is copied to the namelist. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091207170046.19230.55557.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf probe: Fix strtailcmp() to compare s1and s2[0]Juha Leppanen
Fix strtailcmp() to compare s1[0] and s2[0]. strtailcmp() returns 0 if "a" and "b" or "a" and "ab", it's a wrong behavior. This patch fixes it. Signed-off-by: "Juha Leppanen" <juha_motorsportcom@luukku.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Juha Leppanen <juha_motorsportcom@luukku.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091207170040.19230.37464.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf tools: Optimize parse_subsystem_tracepoint_event()Ulrich Drepper
Uses of strcat are almost always signs that someone is too lazy to think about the code a bit more carefully. One always has to know about the lengths of the strings involved to avoid buffer overflows. This is one case where the size of the object code for me is reduced by 38 bytes. The code should also be faster, especially if flags is non-NULL. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: a.p.zijlstra@chello.nl Cc: fweisbec@gmail.com Cc: jaswinderrajput@gmail.com Cc: paulus@samba.org LKML-Reference: <200912061825.nB6IPUa1023306@hs20-bc2-1.build.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf trace/scripting: Don't display 'scripting unsupported' msg unnecessarilyTom Zanussi
The 'scripting unsupported' message should only be displayed when the -s or -g options are used, and not when they aren't, as the current code does. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: rostedt@goodmis.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1260163919-6679-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf trace/scripting: Fix compile error when libperl not installedTom Zanussi
When I added the xs callbacks into perf, I forgot to re-check the no-libperl case. This patch fixes the undefined reference error for that. Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260153712.6564.4.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf_event: Eliminate raw->sizeXiao Guangrong
raw->size is not used, this patch just cleans it up. Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4B1C8CC4.4050007@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf_event: Fix __dsos__write_buildid_table()Xiao Guangrong
The remain buff size is 'len - pos->long_name_len - 1', not 'len - pos->long_name_len + 1' This bug was introduced by commit 7691b1e ("perf tools: Misc small fixes"). Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4B1C7F73.80707@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf_event: Fix raw event processingXiao Guangrong
We use 'data.raw_data' parameter to call process_raw_event(), but data.raw_data buffer not include data size. it can make perf tool crash. This bug was introduced by commit 180f95e29a ("perf: Make common SAMPLE_EVENT parser"). Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4B1C7F45.5080105@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07perf/sched: Fix 'perf sched trace'Xiao Guangrong
If we use 'perf sched trace', it will call symbol__init() again, and can lead to a perf tool crash: [root@localhost perf]# ./perf sched trace *** glibc detected *** ./perf: free(): invalid next size (normal): 0x094c1898 *** ======= Backtrace: ========= /lib/libc.so.6[0xb7602404] /lib/libc.so.6(cfree+0x96)[0xb76043b6] ./perf[0x80730fe] ./perf[0x8074c97] ./perf[0x805eb59] ./perf[0x80536fd] ./perf[0x804b618] ./perf[0x804bdc3] /lib/libc.so.6(__libc_start_main+0xe5)[0xb75a9735] ./perf[0x804af81] ======= Memory map: ======== 08048000-08158000 r-xp 00000000 fe:00 556831 /home/eric/.... 08158000-08168000 rw-p 0010f000 fe:00 556831 /home/eric/... 08168000-085fe000 rw-p 00000000 00:00 0 094ab000-094cc000 rw-p 00000000 00:00 0 [heap] Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> LKML-Reference: <4B1C7EE1.8030906@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06perf buildid-list: Fix copy'n'paste help messageArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260129790-11520-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06perf tools: Misc small fixesOGAWA Hirofumi
- util/header.c "len" is aligned to 64. So, it tries to write the out of long_name buffer. So, this use "zero_buf" to write aligned area. - util/trace-event-read.c "size" is not including nul byte. So, this allocates it, and set '\0'. - util/trace-event-parse.c It needs parens to calc correct size. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <87d42s8iiu.fsf_-_@devron.myhome.or.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06perf: Make common SAMPLE_EVENT parserOGAWA Hirofumi
Currently, sample event data is parsed for each commands, and it is assuming that the data is not including other data. (E.g. timechart, trace, etc. can't parse the event if it has PERF_SAMPLE_CALLCHAIN) So, even if we record the superset data for multiple commands at a time, commands can't parse. etc. To fix it, this makes common sample event parser, and use it to parse sample event correctly. (PERF_SAMPLE_READ is unsupported for now though, it seems to be not using.) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <87hbs48imv.fsf@devron.myhome.or.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06perf timechart: Fix header handlingOGAWA Hirofumi
Update "struct trace_entry" to match with current one. And remove "size" field from it. If it has "size", it become cause of alignment mismatch of structure with kernel. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Acked-by: Arjan van de Ven <arjan@infradead.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <87ljhg8ioe.fsf@devron.myhome.or.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06perf tools: Correct size computation in tracepoint_id_to_path()Julia Lawall
The size argument to zalloc should be the size of desired structure, not the pointer to it. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @expression@ expression *x; @@ x = <+... -sizeof(x) +sizeof(*x) ...+>// </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <Pine.LNX.4.64.0912061016120.20858@ask.diku.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03Merge branch 'perf/scripting' into perf/coreIngo Molnar
Merge reason: it's ready for v2.6.33. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02perf tools: Replace %m with %a in sscanfLiming Wang
Not all glibc support %m and it results in a compile error if %m not supported. Replace it with %a and (float *) casts. Signed-off-by: Liming Wang <liming.wang@windriver.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: peterz@infradead.org Cc: mhiramat@redhat.com LKML-Reference: <1259743374-9950-1-git-send-email-liming.wang@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02perf_event: Fix compile errorXiao Guangrong
Fix: cc1: warnings being treated as errors builtin-probe.c: In function 'cmd_probe': builtin-probe.c:163: error: unused variable 'fd' Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4B162089.8000907@cn.fujitsu.com> [ v2: use NO_LIBDWARF instead of __used ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02perf tools: Fix _GNU_SOURCE macro related strndup() build errorLiming Wang
strndup is a GNU extension. So dont include string.h without defining _GNU_SOURCE (it results in a compile error otherwise). Remove these includes as util.h does it already. Signed-off-by: Liming Wang <liming.wang@windriver.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: peterz@infradead.org Cc: mhiramat@redhat.com LKML-Reference: <1259734306-26323-1-git-send-email-liming.wang@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-01perf probe: Simplify event namingMasami Hiramatsu
Simplify event naming as <symbol>_<seqnum>. Each event name is globally unique (group name is not checked). So, if there is schedule_0, next probe event on schedule() will be schedule_1. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091201002024.10235.2353.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-01perf probe: Add --list option for listing current probe eventsMasami Hiramatsu
Add --list option for listing currently defined probe events in the kernel. This shows events in below format; [group:event] <perf-probe probe-definition> for example: [probe:schedule_0] schedule+30 cpu Note that source file/line information is not supported yet. So even if you added a probe by line, it will be shown in <symbol+offset>. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091201002017.10235.76575.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-01perf probe: Add argv_split() from lib/argv_split.cMasami Hiramatsu
Add argv_split() ported from lib/argv_split.c to string.c and use it in util/probe-event.c. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091201002005.10235.55602.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
