path: root/tools
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-12perf, MIPS: Support cross compiling of tools/perf for MIPSDeng-Cheng Zhu
Changes: v4: Fix the cosmetic issue of redundant dot-ops v3: Change rmb() to use SYNC v2: Include mips unistd.h and define rmb()/cpu_relax() in tools/perf/perf.h Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-05Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/util/ui/browsers/hists.c Merge reason: fix the conflict and merge in changes for dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-04perf trace scripting: Fix extern struct definitionsStephane Eranian
Both python_scripting_ops and perl_scripting_ops have two global definitions. One in trace-event-scripting.c and one in their respective scripting-engine modules. The issue is that depending on the linker order one definition or the other is chosen. One is uninitialized (bss), while the other is initialized. If the uninitialized version is chosen, then perf does not function properly. This patch fixes this by adding the extern prefix to the definitions in trace-event-scripting.c. Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> LKML-Reference: <4c97e41a.078fd80a.7a8b.3cc9@mx.google.com> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-10-04perf ui hist browser: Fix segfault on 'a' for annotateFrederik Deweerdt
There a typo in util/ui/browsers/hists.c that leads to a segfault when you press the 'a' key on a non-resolved symbol (plain hex address). LKML-Reference: <20100923201901.GE31726@gambetta> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@xprog.eu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-10-04perf tools: Fix build breakageKusanagi Kouichi
The patch ecafda6 introduced a problem where all object files would be always rebuilt, fix it by using: http://www.gnu.org/software/make/manual/html_node/Prerequisite-Types.html Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Bernd Petrovitsch <bernd@sysprog.at> Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-15Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-09-13perf ui browser: Don't use windows, slang is enoughArnaldo Carvalho de Melo
They are useless and take away precious columns and lines, so stop using windows. One more step in removing newt code, that after all is not being useful at all for the coalescing TUI model in perf. Suggested-by: Christoph Hellwig <hch@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100822082003.GB7365@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-09perf symbols: Fix multiple initialization of symbol systemJovi Zhang
By returning immediately if it was already initialized, do it as well at symbol__exit, refusing multiple deinitializations. This fixes problems in the kmem, sched and timechart commands. Reported-by: Davidlohr Bueso <dave@gnu.org> Cc: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jovi Zhang <bookjovi@gmail.com> LKML-Reference: AANLkTi=9Cn=R8SPMCRp5z+gEjXbaBHeb-AaOtRbuwwcn@mail.gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-09Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: Pick up pending fixes before applying dependent new changes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-08perf probe: Fix handling of arguments namesMasami Hiramatsu
Don't make argument names from raw parameters (means the parameters are written in kprobe-tracer syntax), because the argument syntax may include special characters. Just leave it, then kprobe-tracer gives a new name. Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100827113859.22882.75598.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-08perf probe: Fix return probe supportMasami Hiramatsu
Fix a bug to support %return probe syntax again. Previous commit 4235b04 has a bug which disables the %return syntax on perf probe. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100827113852.22882.87447.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-07perf: Add a script to show packets processingKoki Sanagi
Add a perf script which shows packets processing and processed time. It helps us to investigate networking or network devices. If you want to use it, install perf and record perf.data like following. If you set script, perf gathers records until it ends. If not, you must Ctrl-C to stop recording. And if you want a report from record, If you use some options, you can limit the output. Option is below. tx: show only tx packets processing rx: show only rx packets processing dev=: show processing on this device debug: work with debug mode. It shows buffer status. For example, if you want to show received packets processing associated with eth4, 106133.171439sec cpu=0 irq_entry(+0.000msec irq=24:eth4) | softirq_entry(+0.006msec) | |---netif_receive_skb(+0.010msec skb=f2d15900 len=100) | | | skb_copy_datagram_iovec(+0.039msec 10291::10291) | napi_poll_exit(+0.022msec eth4) This perf script helps us to analyze the processing time of a transmit/receive sequence. Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Kaneshige Kenji <kaneshige.kenji@jp.fujitsu.com> Cc: Izumo Taku <izumi.taku@jp.fujitsu.com> Cc: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Scott Mcmillan <scott.a.mcmillan@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <4C72439D.3040001@jp.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-08-30Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
2010-08-27Merge branch 'perf/urgent' into perf/coreFrederic Weisbecker
Conflicts: tools/perf/util/callchain.h Merge reason: Fix a non-trivial conflict with latest fixes
2010-08-27perf: Initialize callchains roots's childen hitsFrederic Weisbecker
Each histogram entry has a callchain root that stores the callchain samples. However we forgot to initialize the tracking of children hits of these roots, which then got random values on their creation. The root children hits is multiplied by the minimum percentage of hits provided by the user, and the result becomes the minimum hits expected from children branches. If the random value due to the uninitialization is big enough, then this minimum number of hits can be huge and eventually filter every children branches. The end result was invisible callchains. All we need to fix this is to initialize the children hits of the root. Reported-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: 2.6.32.x-2.6.35.y <stable@kernel.org>
2010-08-25perf tools: Fix linking errors with --as-needed flagTom Zanussi
External shared libraries should never be appended to the LDFLAGS as this messes the linking order. As EXTLIBS collects those libraries, it seems that perl and python libraries should also be appended to EXTLIBS. Also fix the broken linking order. This is a refresh of a patch by Ozan Çağlayan and improved by both Tom Zanussi and Kirill A. Shutemov. Cc: Ozan Çağlayan <ozan@pardus.org.tr> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <1282627430.28324.8.camel@tropicana> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf symbols: List symbols in a dso in ascending name orderSrikar Dronamraju
Given a dso, list the symbols in ascending name order. Needed for listing available symbols from perf probe. Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Mark Wielaard <mjw@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Naren A Devaiah <naren.devaiah@in.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100825134329.5447.92261.sendpatchset@localhost6.localdomain6> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf hists browser: Introduce "expand/collapse all callchains" actionArnaldo Carvalho de Melo
When looking at a callchains enabled perf data file one can find it tiresome to start with all callchains collapsed and then to have to go one by one expanding them. So associate 'E' with "Expand all callchains" and 'C' with "Collapse all callchains". This way now one can have the top level view and then switch to/from having all callchains expanded. More work is needed to allow expanding just from one branch down to its leaves. Reported-by: Christoph Hellwig <hch@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf hists browser: Init the has_children fields just onceArnaldo Carvalho de Melo
Not everytime we show the callchains, removing duplicated initialization of this field. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf hists browser: replace rb_first() != NULL by !RB_EMPTY_ROOT()Arnaldo Carvalho de Melo
Its way too stupid to use rb_first() for just caching if there are children, use the cheaper RB_EMPTY_ROOT() instead. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf hists: Fix hist_entry__init_have_childrenArnaldo Carvalho de Melo
It wasn't setting the ms.has_children for the hist_entry itself, just for the callchain Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: pick up perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-22perf: Support for callchains mergeFrederic Weisbecker
If we sort the histograms by comm, which is the default, we need to merge some of them, typically different thread histograms of a same process, or just same comm. But during this merge, we forgot to merge callchains. So imagine we have three threads (tids: 1000, 1001, 1002) that belong to comm "foo". tid 1000 got 100 events tid 1001 got 10 events tid 1002 got 3 events Once we merge these histograms to get a per comm result, we'll finally get: "foo" got 113 events The problem is if we merge 1000 and 1001 histograms into 1002, then the end merge result, wrt callchains, will be only callchains that belong to 1002. This is because we haven't handled callchains in the merge. Only those from one of the threads inside a common comm survive. It means during this merge, we can lose a lot of callchains. Fix this by implementing callchains merge and apply it on histograms that collapse. Reported-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org>
2010-08-22perf: Rename append_callchain into callchain_appendFrederic Weisbecker
Do that to start a consistant callchain API namespace. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-22perf: Keep track of the max depth of a callchainFrederic Weisbecker
In order to implement callchains collapsing, we need to keep track of the maximum depth in a histogram tree of callchains. This way we'll avoid allocating an arbitrary temporary buffer size on callchain merge time. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-21perf tools: add test for strlcpy()Kirill A. Shutemov
Some Linux distributions like ALT Linux provides patched glibc with contains strlcpy(). It's confilcts with strlcpy() from perf. Let's add check for strlcpy(). Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1282351101-8879-1-git-send-email-kirill@shutemov.name> Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-21perf tools: Add --tui and --stdio to choose the UIArnaldo Carvalho de Melo
Relying just on ~/.perfconfig or rebuilding the tool disabling support for the TUI is too cumbersome, so allow specifying which UI to use and make the command line switch override whatever is in ~/.perfconfig. Suggested-by: Christoph Hellwig <hch@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-19perf ui browser: Add routines to compactly specify exit keysArnaldo Carvalho de Melo
This makes the usual idiom for specifying a series of key codes to exit ui_browser__run() for specialized processing (search, annotate, etc) or plain exiting the browser more compact. It also abstracts away some more libnewt operations. At some point we'll also replace NEWT_KEY_foo with something that can be mapped to NEWT or, say, gtk. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-19perf ui browser: Return the exit key in all browsersArnaldo Carvalho de Melo
Make all browsers return the exit key uniformly and remove the newtExitStruct parameter, removing one more newt specific thing from the ui API. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-19perf ui browser: Abstract some more slang operationsArnaldo Carvalho de Melo
Browsers don't have to deal with absolute coordinates, just using (row, column) and leaving the rest to ui_browser is better and removes one more UI backend detail from the browsers. Also shorten the percent_color setting idiom, removing some more direct libslang calls. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-18perf tools: Fix build error on read only source.Kusanagi Kouichi
Parts of the build process were generating files outside the specified O= directory, causing the build to fail on systems where the sources are in a read only file system. Fix it by using $(OUTPUT) on these locations. Also check that $(OUTPUT) actually exists, just like the top level kernel Makefile does. Otherwise the failure message emitted is completely misleading. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20100817140841.0859362C03A@msa106.auone-net.jp> Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-17perf tools: Fix build on POSIX shellsBernd Petrovitsch
POSIX sh does not specify the brace expansion, so fix it by replacing the global $(shell ...) lines quite at the top creating the output directories with real rules. Cc: Ingo Molnar <mingo@elte.hu> Cc: Kusanagi Kouichi <slash@ac.auone-net.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1282046280.5822.4.camel@thorin> Signed-off-by: Bernd Petrovitsch <bernd@sysprog.at> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-16perf annotate tui: Fix exit and RIGHT keys handlingArnaldo Carvalho de Melo
As part of ongoing effort to reduce the coupling with libnewt, browsers are being changed to return the exit key. The annotate browser is not returning it as expected by builtin-annotate when annotating multiple symbols (when 'perf annotate' is called without specifying a symbol name). Fix it by returning the exit key and also adding the RIGHT key as a exit key so that going to the next symbol in the TUI can work again. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-12perf: Add back list_head data typesIngo Molnar
This commit: de5d9bf: Move list types from <linux/list.h> to <linux/types.h>. Moved the list head data types out of list.h, breaking the build. Add them to the perf types.h as well. Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-12Merge branch 'linus' into perf/urgentIngo Molnar
Merge reason: Fix upstream breakage introduced by: de5d9bf: Move list types from <linux/list.h> to <linux/types.h>. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-10perf ui hist browser: Fixup key bindingsArnaldo Carvalho de Melo
To match what is shown when '?' or 'H' is pressed, i.e. the keybind help window. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf ui browser: Add ui_browser__show counterpart: __hideArnaldo Carvalho de Melo
So that the common tasks of providing a helpline at __run entry and destroying the window and releasing resourses at exit can be abstracted away, reducing a bit more the coupling with libnewt. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf annotate: Cycle thru sorted lines with samplesArnaldo Carvalho de Melo
The annotate TUI now starts centered on the line with most samples, i.e. the hottest line in the annotated function. Pressing TAB will center on the second hottest function and so on. Shift+TAB goes in the other direction. This way one can more easily sift thru the function hotspots. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf ui: Make SPACE work as PGDN in all browsersArnaldo Carvalho de Melo
Not just on the annotate one. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf annotate: Sort by hottest lines in the TUIArnaldo Carvalho de Melo
Right now it will just sort and position at the hottest line, i.e. the one where more samples were taken. It will be at the center of the screen and later TAB/shift-TAB will cycle thru the hottest lines. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf ui: Complete the breakdown of util/newt.cArnaldo Carvalho de Melo
2010-08-10perf ui: Move hists browser to util/ui/browsers/Arnaldo Carvalho de Melo
2010-08-10perf symbols: Ignore mapping symbols on ARMDave Martin
ARM ELF files use symbols with special names $a, $t, $d to identify regions of ARM code, Thumb code and data within code sections. This can cause confusing output from the perf tools, especially for partially stripped binaries, or binaries containing user-added zero-sized symbols (which may occur in hand-written assembler which hasn't been fully annotated with .size directives). This patch filters out these symbols at load time. LKML-Reference: <1281352878-8735-2-git-send-email-dave.martin@linaro.org> Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf ui: Move map browser to util/ui/browsers/Arnaldo Carvalho de Melo
2010-08-10perf ui: Move annotate browser to util/ui/browsers/Arnaldo Carvalho de Melo
2010-08-10perf ui: Move ui_progress routines to separate file in util/ui/Arnaldo Carvalho de Melo
2010-08-10perf ui: Move ui_helpline routines to separate file in util/ui/Arnaldo Carvalho de Melo
2010-08-10perf ui: Shorten ui_browser member namesArnaldo Carvalho de Melo
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits) firewire: core: add forgotten dummy driver methods, remove unused ones firewire: add isochronous multichannel reception firewire: core: small clarifications in core-cdev firewire: core: remove unused code firewire: ohci: release channel in error path firewire: ohci: use memory barriers to order descriptor updates tools/firewire: nosy-dump: increment program version tools/firewire: nosy-dump: remove unused code tools/firewire: nosy-dump: use linux/firewire-constants.h tools/firewire: nosy-dump: break up a deeply nested function tools/firewire: nosy-dump: make some symbols static or const tools/firewire: nosy-dump: change to kernel coding style tools/firewire: nosy-dump: work around segfault in decode_fcp tools/firewire: nosy-dump: fix it on x86-64 tools/firewire: add userspace front-end of nosy firewire: nosy: note ioctls in ioctl-number.txt firewire: nosy: use generic printk macros firewire: nosy: endianess fixes and annotations firewire: nosy: annotate __user pointers and __iomem pointers firewire: nosy: fix device shutdown with active client ...
